- Ext. to 128 inputs by coupler boards
- Dual access RAM with auto. Refresh
- Choice of 12/14/16 -bit converters
- Software progr. gains in 2n, 1 to 8
- High acq. rate up to 200,000 acq./s
- Possible galvanic isolat. from the system
- Analog power supply on board
- External triggers possible
- Gains in NOVRAMS with readback
- VME-ANSI/IEEE 1014 standard
常用相关型号,如有不明,请来电详细咨询! Produits au standard VME
ICV107/20 CARTE VME MAITRE ACQUISITION RAPIDE 16MHz 2048K. mesures/s
ICV108 CARTE VME MAITRE ACQUISITION RAPIDE 64 BITS Buffers de 2M. mesures/s
ICV150/D-12/4/106-I CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 100K.acq./s ±0.05% PE
ICV150/D-12/4/206-I CARTE VME 32 E. DIFFERENTIELLES ISO. 12 bits G1 à 8 50K.acq./s ±0.03% PE
ICV150/D-14/4/256-I CARTE VME 32 E.DIFFERENTIELLES ISO 14 bits G1 à 8 40K.acq./s ±0.016% PE
ICV150/D-16/4/336-I CARTE VME 32 E. DIFFERENTIELLES ISO. 16 bits G1 à 8 30K.acq./s ±0.008% PE
ICV178 CARTE VME ET COUPLEUR ICV108 8 E. ANA. ISOLEES 16 bits 1,2MSPS SIGMA DELTA ADCs
ICV196 CARTE VME ENTREES SORTIES DIGITALES Protégées 70V / 100mA ICV296 CARTE VME ET COUPLEUR ICV10x 96 ENTREES/SORTIES DIGITALES
ICV307 6 ISOLATED, HIGH SPEED 32-BIT COUNTER CHANNELS
ICV320/RB CARTE VME 32 SORTIES RELAIS 1RT 125V / 2A
ICV320/SB CARTE VME 32 SORTIES RELAIS STATIQUES 1T 60V / 0,5A
ICV706 CARTE VME SORTIE ANA. 4 VOIES ISOLEES BIPOLAIRE 16 BITS RAM DE 512 MOTS PAR VOIES
ICV714 CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS 0/5V;0/10V;±5V;±10V
ICV714/BC CARTE VME SORTIE ANA. 16 VOIES ISOLEES 12 BITS 0/5V;0/10V;±5V;±10V;0/20 4/20mA
ICV716 CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V
ICV716/BC CARTE VME SORTIE ANA. 8 VOIES 16 BITS 0/10V;±10V BOUCLE DE COURANT
ICV726 CARTE VME SORTIE ANA. 24 VOIES 12 OU 14 BITS ±10V
ICV914 CARTE VME 4 VOIES DE COMMANDE D'AXES RCV20 RACK VME 20 SLOTS 9U 19" p=480mm ALIM 600W +5V/120A;+/-12V/10A DEFLECTEUR-19" DEFLECTEUR VENTILATION CHASSIS 19" 1U INT-1-MEDIA INTEGRATION DANS UN CHASSIS DE 1 MEDIA FOURNI PAR VOS SOINS. RCV-20/20 RACK 19" 7U P1=20 SLOTS / P2=20SLOTS ALIM 600W (5V/120A ; EUR 24 CHASSIS EUROMULT 24 SLOTS ALIM 600W Produits au standard PCI PCI102/05 CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s ; 512K. mesures
PCI102/20 CARTE PCI GESTION D'ACQUISITION RAPIDE 20 Méga échantillons/s 2048K. mesures
PCI150 CARTE PCI 32 E.DIFF. 64 E. UNI. ISO 12 14 16 bits G1 à 8 100K.acq./s MAX
PCI160 CARTE PCI 16 E. ANA. 32 E/S TTL 8 S ANA. 16 bits G1 200K.acq. / voie
PCI220/D CARTE PCI 32E.DIFF.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
PCI220/S CARTE PCI 64E.UNI.ISOLEES 12/14/16 bits G1 à 8 100K à 30K.acq./s
PCI224 CARTE PCI 32 E.DIFF 12 14 16 bits G1 à 8 100K.acq./s MAX
PCI228 CARTE PCI 16 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie
PCI238/BE CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BESSEL
PCI238/BU CARTE PCI 8 E.DIFF. ISOLEES 16 bits G1 à 8 100K.acq./voie +FLT.BUTH.
PCI264 CARTE PCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA μD68 PINS
PCI307 CARTE PCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS μD68 PINS
PCI744 CARTE PCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits μD68 PINS
PCI786 CARTE PCI 8 SORTIES ANALOGIQUES ISOLEES ± 10 VOLTS 16 bits μD68 PINS
PCIDX6 CARTE CPU POUR LE TEMPS REEL
BLA102/02 BUS LOCAL 2 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/03 BUS LOCAL 3 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/04 BUS LOCAL 4 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/05 BUS LOCAL 5 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/06 BUS LOCAL 6 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/07 BUS LOCAL 7 SLOTS POUR PCI102 ET CARTES COUPLEURS
BLA102/09 BUS LOCAL 9 SLOTS POUR PCI102 ET CARTES COUPLEURS
Produits au standard CPCI – PXI CPCI1150 CARTE PXI 32 E. DIFFERENTIELLES ISO. 12 14 16 bits G1 à 8 100K.acq./s MAX
CPCI1228 CARTE PXI 16 E. ANA. 32 E/S TTL 16 bits G1 200K.acq. / voie
CPCI1264 CARTE PXI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA AVEC POSTTTION DE REPLIS
CPCI1786 CARTE PXI 8 SORTIES ANALOGIQUES ± 10 VOLTS 16 bits
CPCI228 CARTE CPCI 16 E. ANA. 32 E/S DIGITALES ECHANTILLONNAGE SUMULTANE 250 kHz
CPCI264 CARTE CPCI 64 ENTREES SORTIES DIGITALES PROTEGEES 70V / 100mA
CPCI307 CARTE CPCI 4 VOIES DE COMPTAGE ISOLEES 32 BITS
CPCI412 CARTE CPCI 3U 4 entrées analogiques 12 bits /22MHz 4Mech/voies
CPCI744 CARTE CPCI 16 SORTIES ANALOGIQUES ± 10 VOLTS 14 bits
CPCISYN CARTE FORMAT CPCI POUR SYNCHRONISATION INTER CHASSIS
Produits au standard LMC LMC-429 MODULE COUPLEUR LIAISONS ARINC 429
LMC-ADC MODULE 8D / 16S ENTREES ANALOGIQUES 14 bits ±10.24Volts
LMC-CAN MODULE GESTIONNAIRE DE RESEAU CAN
LMC-DAC MODULE 8 SORTIES ANALOGIQUES 14 bits ; ± 10V
LMC-DDS MODULE 8 SORTIES ANALOGIQUES DDS / SYNTHE
LMC-DIO MODULE 16 ENTREES / SORTIES TOR ISOLEES
LMC-ESCC/16 MODULE INTEL 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 16 MHz
LMC-ESCC/20 MODULE INTEL. 2 LIAISONS SERIES MULTI- PROTOCOLES GEREES PAR DSP à 20MHz
LMC-SSI MODULE GESTIONNAIRE DE 4 LIAISONS SYNCHRONES 24 à 32 BITS 104-LMC CARTE PC104 SUPPORT DE 1 MODULE LMC
CPCI-LMC CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS VIA DMC
CPCI-LMC-D CARTE COMPACT PCI 3U SUPPORT DE 2 MODULES LMCS HD44pts
ICV-LMC CARTE VME SUPPORT DE 3 MODULES LMCS
PCI-LMC CARTE PCI SUPPORT DE 2 MODULES LMCS SUBD HD44PTS
UCV-DIO CARTE VME 3U 32 ENTREES / SORTIES DIGITALES ISOLEES + 2 SUPPORTS LMCS
UCV-LMC CARTE VME 3U SUPPORT DE 2 MODULES LMCS
Borniers conditionneurs industriels BCI BCI128- BNC BORNIER 8 PRISES BNC POUR ICV128 / ICV138 / ICV148
BCI138 BORNIER PASSIF 8 VOIES POUR ICV138 ET MODULE MAL
BCI140/C BORNIER 16 ENTREES DIGITALES ISOLEES Vin=24Volts
BCI140/D BORNIER 16 ENTREES DIGITALES ISOLEES Vin=48Volts
BCI146 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 64 PTS
BCI148 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 48 PTS
BCI160/RB BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
BCI160/SB BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC /0.5A
BCI160/SH BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0.1A
BCI168 BORNIER 8 SORTIES ANALOGIQUES ISOLEES TENSION/COURANT
BCI184/XX/YY BORNIER COND. 8 E ANA. HAUT MODE COMMUN VERSION A DEFINIR
BCI100-PB PLAQUE DE BOUCHAGE 6U 5TE
BCI100-RACK-9U RACK 9U POUR RECEVOIR 16 BCI SERIE 100 ALIM 250W +5V/35A;+12V/8A ; -12V/8A
BCI300-PRL CARTE DE PROLONGATION POUR BCI SERIE 300
BCI300-VISU BORNIER DE RECOPIE 16 VOIES
BCI314/ALPF BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT FILTRE PASSE BAS AJUSTABLE
BCI314/SF BORNIER 8 ENTREES ANALOGIQUES CONDITIONNEES POLYVALENT SANS FILTRE
BCI328-5/037/BU BORNIER 8 ENTREES ANALOGIQUES FILTREES FC A DEFINIR
BCI328-5/037/BU-TEDS BORNIER 8 ENTREES ANALOGIQUES FILTREES GESTION DES CAPTEURS TEDS
BCI360-5/RB/INV BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A LOGIQUE
INVERSEE BCI364-5/B72 BORNIER 4 SORTIES ANALOGIQUES ISOLEES Vout = ±72 Volts FAV 5TE
BCI368-5 BORNIER 8 SORTIES ANALOGIQUES ISOLEES Vout = ±10 Volts FAV 5TE
BCI382-5/XX BORNIER COD. 8 E ANALOGIQUES ISOLEES 5 TE (version à préciser)
BCISIN BORNIER COND. 4 E ANALOGIQUES ISOLEES DEPHASEUR
BCI300-PB-5TE PLAQUE DE BOUCHAGE 6U 5TE
BCI300-PB-6T E PLAQUE DE BOUCHAGE 6U 6TE
BCI300-RACK RACK 9U POUR RECEVOIR 12 BCI SERIE 300 EQUIPE D'UNE ALIMENTATION 24V/12A
BCI300-RACK-16 RACK 9U POUR RECEVOIR 16 BCI SERIE 300 5Te EQUIPE D'UNE ALIMENTATION 24V/12A
Borniers industriels STB STB-SSI BORNIER D'INTERFACE FILAIRE POUR 1 LMC VERS ICVLMC
STB306 TERMINAL BLOCK FOR INCREMENTAL ENCODERS STB306/ISO/C BORNIER INTERFACE ISOLE POUR CARTES ICV307 PCI307 (Vnom=24V ; I=5mA)
STB504 BORNIER CONDITIONNEUR DE NIVEAU 4 VOIES DE COMPTAGE
STB512 BORNIER INTERFACE PASSAGE DE 1x32 VOIES à 2x16 VOIES
STB514 BORNIER INTERFACE PASSAGE DE 1x64 VOIES à 4x16 VOIES
STB516 BORNIER 16 ENTREES SORTIES DIGITALES MODULAIRES
STB520/8SB/24RB BORNIER 32 SORTIES RELAIS 0à7-->SB 8à31-->RB
STB520/RB BORNIER 32 SORTIES RELAIS 1RT 220V DC/2A
STB520/SB BORNIER 32 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
STB520/SH BORNIER 32 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
STB524 32 SORTIES POWER SWITCH
STB525 BORNIER INTERFACE POUR PASSAGE DE 1 MICRO 68 PTS VERS 2 HE501 25 PTS
STB532/A BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 5 Volts
STB532/B BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 12Volts
STB532/C 32 ISOLATED DIGITAL INPUTS TERMINAL BLOCK STB532/E BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 115Volts
STB532/F BORNIER 32 ENTREES DIG. ISO. AC/DC Vin 220Volts
STB534 BORNIER INTERFACE PASSAGE DE 2x32 VOIES à 1x64 VOIES
STB540/C BORNIER 16 ENTREES DIG. ISO. AC/DC Vin=24Volts
STB542 BORNIER INTERFACE CARTE SORTIES ANA. 8 CANAUX
STB544 BORNIER D'INTERFACE FILAIRE POUR 2 LMCS
STB546 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 68 PTS
STB548/F1 BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS FILTRES FC =10Hz
STB550 BORNIER D'INTERCONNEXIONS D'USAGE GENERAL 50 PTS
STB552 BORNIER INTERFACE ENTREES / SORTIES 32 CANAUX UNIFILAIRES
STB554 BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX DIFFERENTIELS
STB554/BC/0250 BORNIER INTERFACE CARTE ENTREES ANA. 16 VOIES BOUCLE DE COURANT R=250Ohms
STB556 BORNIER INTERFACE CARTE ENTREES ANA. 16 CANAUX POUR ENTREES THERMOCOUPLES
STB560/RB BORNIER 16 SORTIES RELAIS 1RT 220V DC/2A
STB560/SB BORNIER 16 SORTIES RELAIS STATIQUES 1T 60V DC/0,5A
STB560/SH BORNIER 16 SORTIES RELAIS STATIQUES 1T 400V DC/0,5A
STB562 BORNIER 16 SORTIES RELAIS 1RT 380V DC/5A
ACM/IN/xx/RMS MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM VERSION RMS
ACM/INxx MODULE D'ENTREE POUR STB658 STB6x2 STB4ACM STB/LA55P/XX MODULE TRANSDUCER 10A
STB/SHUNT-XX SHUNT POUR STB R=0.010 OHM ±1%
STB4ACM BORNIER D'INTERFACE POUVANT RECEVOIR 4 MODULES ADAS
STB658 BORNIER D'INTERFACE POUVANT RECEVOIR 16 MODULES ADAS
STB6x2 ANALOG CONDITIONING MODULES 8 CHANNELS BACK PANEL
Cables WF245/300 CABLE ROND BLINDE 3 m SUBD-HD 44P VERS SUBD-HD 44S
WR205/300 NAPPE RONDE BLINDEE 3,00 m SUBD 50P VERS HE10 50S
WR212/050 NAPPE RONDE BLINDEE 0 m 50 HE10 50S VERS HE10 50S
WR212/300 NAPPE RONDE BLINDEE 3 m HE10 50S VERS HE10 50S
WR214/300 NAPPE RONDE BLINDEE 3 m HE10 50S VERS 2 HE10 26S
WR215/300 NAPPE RONDE BLINDEE 3 m SUBD 50P VERS 2 HE10 26S
WR228/300 NAPPE RONDE BLINDEE 3m00 SUBD 50P VERS SUBD 50P
WR233/300 NAPPE RONDE BLINDEE 3 m SUBD 25P VERS SUBD 25P
WR235/300 NAPPE RONDE BLINDEE 3 m SUBD 25S VERS SUBD 25S
WR2XX-METRE-SUP. METRE DE NAPPE SUPPLEMENTAIRE
WR368/100 MICRO NAPPE BLINDEE 68PTS μSUBD 1m00
WR368/180 MICRO NAPPE BLINDEE 68PTS μSUBD 1m80
WR368/300 MICRO NAPPE BLINDEE 68PTS μSUBD 3m00
