珠海科尔迈测试设备有限公司
  • UL试验指/ULP-01
  • 发布时间:2008/11/26 16:19:40   修改时间:2008/11/26 16:19:40 浏览次数:3998
  • UL试验指/ULP-01
  • ACCESSIBILITY PROBES 试验探针
    FOR TESTING THE PROTECTION AGAINST ACCESS TO HAZARDOUS PARTS
    Model ULP-01: UL Finger Probe(UL试验指)
    产地:美国 品牌:ED&D
    Model TPP-01: Short Test Pin Probe
    Used to test accessibility through enclosure openings per IEC, EN, UL and CSA Standards. Body is Delrin, tip is stainless steel.
    NOTE: Don’t ever purchase an all plastic version - the tip is too narrow to maintain tip rigidity!
    Model TPP-02: Long Test Pin Probe
    This pin is used on appliances for verifying that there is no access to hazardous live parts of heating elements which could be touched accidentally by a tool (i.e. screwdriver). Meets IEC & EN requirements. Body is Delrin, tip is stainless steel.
    Model UFP-01: Rigid Finger Probe
    A “rigid” version of the International Test Finger, model TFP-01, (see next page). Used for force applications on openings (i.e. vents) as required by IEC, EN, UL and CSA Standards. Handle made of Delrin, rigid finger made of chrome plated steel.
    Model TRP-02: 1.0mm Test Wire
    Used to verify protection of persons against access with a wire. Meets IEC and EN Standards including IEC 529 for IP4 and suffix D codes. The handle and stop face are made of Delrin. The wire is made of stainless steel.
    Model TRP-01: 2.5mm Test Rod
    Used to verify the protection of persons against access to hazardous parts. Also used to verify the protection against access with a tool. Meets IEC and EN Standards including IEC 529 for IP3 and suffix C codes. The handle and stop face are made of Delrin. The rod is made of stainless steel.
    Model PCP-01: 3.0mm Preset Controls Probe
    Used to verify protection against access to hazardous parts by use of a tool through holes which give access to pre-set controls. Meets IEC, EN, UL and CSA Standards including IEC 1010, EN 61010-1, U- 3101-1, UL 3111-1 and CSA 1010-1. The handle and stop face are made of Delrin. The rod is stainless steel.
    Model HLP-01: 4.0mm Hazardous Live Parts Probe
    Used to verify protection against access to hazardous parts through top openings. Meets IEC, EN, UL and CSA Standards including IEC 1010, EN61010-1, UL3101-1, and CSA 1010-1. The handle and stop face are made of Delrin. The rod is made of stainless steel.
    Model TFP-01: Test Finger Probe
    This is the “International” test finger required by most IEC, EN and CSA Standards, in addition to many UL Standards. Built in strict accordance to the newest requirements - with integral palm simulator. This is the ONLY Finger Probe available with a integral jack in the handle for continuity testing - as mandated by the IEC CB Scheme. Finger made of chrome plated steel. All parts precision machined.
    This is the “UL” test finger, researched and designed by UL and required by most UL Standards. Palm simulator and restricted joint movement simulates human finger movement. Made of all nylon. Bell-Core accessory available.
    Model ULP-02: Articulated Probe with Discs
    Probe is required by GR-1089-CORE. Probe is plastic with 2 precision Delrin? disks. The disks are positioned at 35 mm. and 9 mm. from the top of probe. It is used to verify protection from hazardous parts.
    Model THN-01: Test Thorn Probe
    For testing accessibility in appliances with visibly glowing heating elements. Also for testing parts supporting such elements. Complies with IEC, EN, UL & CSA requirements. Made entirely of stainless steel.
    Model TSP-01: Test Sphere Probe
    This probe is intended to verify protection of persons against access to hazardous parts for an IP1 Code. Also used to verify protection from access with the back of the hand for an IP suffix A code.
    Model TSP-02: Test Sphere Probe
    This sphere is intended to verify the degree of protection of enclosures for an IP2 Code per IEC 529. Sphere is hardened steel with chrome finish.
    Model RTR-01: Rigidity Test Rod Probe
    For testing enclosure rigidity in accordance with clause 8.1 of IEC 1010 and the EN, UL and CSA versions of this Standard. Handle is Delrin, tip is stainless steel.
    Model TUP-01: Uninsulated Live Parts Probe
    For testing accessibility in accordance with many UL Standards. The handle is Delrin and the tip is stainless steel.
    Model EWP-01: Enameled Wire Probe
    For testing accessibility in accordance with many UL Standards. In many Standards, this probe is used for access to enamel coated wire (i.e. transformers and inductors). The handle is Delrin and the tip is stainless steel.
    Model HMP- 01: Hazardous Moving Parts Probe
    For testing accessibility to hazardous moving parts such as access to fan blades through a fan finger guard. Complies with UL Standards. Made entirely of stainless steel, weighs 1 lb.
    Model CP-01: Coin Probe
    Four probes in one! Used to determine accessibility to shock hazards in many household and audio/video products, including Standards UL 1410 and UL 6500. Made entirely of nickel-plated steel.
    Model TH-01: Test Hook Probe
    Used on enclosures prior to accessibility testing. The test hook is “hooked” into vents and seams in the enclosure & then pulled with a force (usually 20N). The hook has a hole at its long end, for use in conjunction with a PFI series Force Gauge. Made entirely of stainless steel.
    Model FNP-01: Finger Nail Probe
    For testing the requirement of snap-in devices and snap together enclosures that protect the user from accessibility to hazardous parts. Complies with most Standards including IEC 335 based Standards and UL 1025.
    Model BEP-01: Blunt-End Probe
    Stainless steel probe required by various UL, CSA, IEC, and EN standards.
    Model TTP-01:Telecom Test Probe
    Required by IEC, EN, and some UL and CSA standards to test accessibility to TNV circuits (telecom). The handle and stop face are Delrin, the tip is stainless steel.
    美国.ED&D产品服务于:IBM ,美国航空暨太空总署,英代尔,苹果, NCR ,索尼公司,太阳,飞利浦公司,思科, AT&T , Compaq , JVC , Hewlett-Packard ,摩托罗拉, Mattel ,戴尔,3 Com 等公司;专为UL , CSA , ETL , TUV,Demko等试验室提供检测产品
珠海科尔迈测试设备有限公司位于珠海市吉大景园路,是一家专业经销世界一流科学仪器,工业测试仪器,环境实验设备,光学仪器,力学仪器,电磁兼容,电子安规等检测设备的公司。主要客户有研发实验室,认证机构,学校及电子,汽车制造业,玩具加…  更多>>
珠海科尔迈测试设备有限公司
联系人:陈小姐
地址:珠海市吉大景园路16号华庆大厦3楼
邮编:519000
电话:0756-3353658
传真:0756-3361895
公司网址:http://www.keermai.com
