珠海科尔迈测试设备有限公司
  • simpson228 AC/DC泄漏电流测试表
  • 发布时间:2008/11/26 16:15:41   修改时间:2008/11/26 16:15:41 浏览次数:2202
  • 228 AC/DC泄漏电流测试表
    Simpson228测试对于与危险的泄漏电流,设计符合最新的UL、IEC和ANSI规格。228查出当前AC和DC漏出并且模仿人的反应在三个不同水平-- 反应,放弃,以及烧伤危险。每个Simpson228具有弹簧夹、指南和电池以及测试笔。
    • 查出危险AC & DC 泄漏电流在电子或电子设备导电性表面
    • 设计遇见新的IEC、ANSI和UL指南
    • 反应,放弃和无重负的烧伤危险网络测量
    • 电池操作为最大轻便
      Opecifications
      GENERAL
      Reaction
      ResponseNetwork
      Let-Go
      ResponseNetwork
      UnweightedBurnHazard
      Response Network
      Equivalent network component values:
      Complies with values specified in IEC 990 (excluding fuse)
      Equivalent measuring instrument load:
      1 MΩ- 10pF
      1 MΩ- 62 pF
      1 MΩ- 1 pF
      Ranges:
      0.3, 1, 3, 10 M.I.U.
      0-100 mA RMS
      Current accuracy:
      ±2% F.S. @ 60 Hz
      Meter measurement method:
      True RMS
      Meter frequency response:
      (Relative to ANSI C101-1992 or UL-1459 2nd edition)
      DC to 1 Hz
      Pointer shall track within 5% of peak
      2Hz to 19Hz (Accuracy not supported)
      20 Hz to 200 KHz
      ±2% F.S.
      ±2.5% of F.S.
      ±2% F.S.
      200 KHz to 1 MHz
      ±2% F.S.
      ±2.5% F.S.
      ±5% F.S.
      Output sensitivity:
      Full scale meter indication equals 1V RMS (Measured with a 1 MΩ- 12 pF load)
      Output accuracy:
      ±2% of reading @ 60 Hz
      Output frequency response:
      DC to 50Hz
      ±2% of reading
      50 Hz to 100 KHz
      ±2.5% of reading
      ±2% /-3% of reading
      ±2% of reading
      100 kHz to 1 MHz
      ±5% of reading
      Voltmeter range:
      0-300 V (AC or DC)
      Voltmeter accuracy: DC to 1 Hz
      20 Hz to 1KHz
      ±3% F.S. @ 60 Hz (Add ±1% for every additional 100Hz)
      Voltmeter frequency response:
      DC to 1 KHz
      Power requirements:
      Power requirements: (2) 9V (NEDA 1604A) batteries
      Physical:
      7" x 5.25" x 3.125", 2-1/2 lbs (1.4kg), ABS plastic,fusedinput
      Environmental:
      27°C ±2° C, 70% non condensing relative humidity. Outside thisrangederate by 10% per °C
      Maximum operating range:
      0° to 40° C
珠海科尔迈测试设备有限公司位于珠海市吉大景园路,是一家专业经销世界一流科学仪器,工业测试仪器,环境实验设备,光学仪器,力学仪器,电磁兼容,电子安规等检测设备的公司。主要客户有研发实验室,认证机构,学校及电子,汽车制造业,玩具加…  更多>>
珠海科尔迈测试设备有限公司
联系人:陈小姐
地址:珠海市吉大景园路16号华庆大厦3楼
邮编:519000
电话:0756-3353658
传真:0756-3361895
公司网址:http://www.keermai.com
