上海欧桥电子科技有限公司
  • L1 GPS Antenna Down/Up Converter
  • 发布时间:2008/10/28 9:25:21   修改时间:2008/10/28 9:25:21 浏览次数:1113
       点击查看详细信息
    产品编号:
    12271413916
    产品名称:
    规  格:
    产品备注:
    产品类别:
    GPS定位及时钟基准系统
        产 品 说 明
    GPS signal down/up conversion is required when signal losses in the antenna cable limit the distance between the receiver and the antenna assembly. At just over 250 feet (76 meters) in cable length, the benefits can be realized using a Down/Up Converter assembly versus the use of low loss cable and amplifiers. Signal strengths and noise immunity as well as the cost benefits over the use of low loss cable and amplifiers are the main advantages of using the Antenna Down/Up Converter assembly.
    The down converter antenna and up converter unit replace the standard L1 GPS antenna. Power for the system is provided by the GPS receiver or an optional external power supply. The down/up conversion process is transparent to the GPS receiver. As with any precision timing GPS receiver, only cable delay and downconversion delays need to be entered into the receiver.
    The Down/Up Converter may also work with non-Symmetricom L1 GPS receivers. The signal output from the converter is L1 C/A code that can be decoded by any L1 GPS receiver. Since the Down/Up Converter can be externally powered, L1 GPS receivers that can interface to the Down/Up Converter BNC connector should be able to use the signal. However, note that the Down/Up Converter introduces latency in the signal in addition to cable delay. For precision timing applications the receiver must be able to account for these factors.
欧桥电子科技发展有限公司是英国Universal Corporate Ltd. (UK)在中国的分公司,旗下包含上海欧桥电子、天津欧桥、杭州欧桥等多个分支机构,从事涵盖电子通信产品、仪器、工业及机电产品等不同领域的业务与技术服务。公司本着良好的信誉和出色的售后服…  更多>>
上海欧桥电子科技有限公司
联系人:瞿建
地址:上海市浦东新区康桥路1100号保康大厦1103室
邮编:201315
电话:021-58126804
传真:021-58126844
公司网址:http://www.ouqiao.com/
  • 张克雄 在2025/6/26 17:30:00留言
  • 详细留言:产品尺寸图
  • 何先生 在2023/10/16 18:46:00留言
  • 详细留言:UCL-HP2000-A(B)
  • 李小姐 在2021/9/22 12:16:00留言
  • 详细留言:UCL-HT80GH-18,5PCS
  • huyiping 在2011/5/17 15:20:00留言
  • 详细留言:4142b+41420A+41420A
  • 李永珍 在2010/9/28 19:41:00留言
  • 详细留言:True Time XL-AK GPS Receiver (600-000-03)
