上海欧桥电子科技有限公司
  • GPSnetworking OQ-ALDCBS1X8 分路器
  • 发布时间:2008/10/21 16:39:42   修改时间:2008/10/21 16:39:42 浏览次数:1402
  •   点击查看详细信息
    产品编号:
    122713375516
    产品名称:
    规  格:
    Standard
    产品备注:
    active/passive,N/SMA/BNC weatherproof,Hi-ISolation
    产品类别:
    GPS定位及时钟基准系统
        产 品 说 明
    The ALDCBS1X8 GPS Amplified Splitter is a one input, eight output device with 13dB min. gain block. The frequency response covers GPS L1, L2 & GLONASS bands with excellent gain flatness. In the normal configuration, the splitter RF output (J1) passes DC from the connected GPS receiver through the splitter to the antenna, allowing the GPS receiver to power both the antenna and the splitter amplifier. The other RF outputs (J2 - J8) are DC loaded with 200 Ohm resistors to simulate the antenna current draw.
    ALDCBS 1 X 8
    Technical Product Data
    Features
    *  Amplifier Gain of 14dB
    Gain ≥ 13dB
    *  Extremely Flat Group Delay
    Less that 1ns variation
    *  Phase Matched Outputs
    o
    Phase (J1 – J2) < 1.0
    Description
    The ALDCBS1X8 GPS Amplified Splitter is a one input, eight output device with 13dB minimum gain.
    The frequency response covers the GPS L1 & L2 bands with excellent gain flatness.  In the normal
    configuration, one of the splitter RF outputs (J1) passes DC from the connected GPS receiver through
    the splitter to the antenna, allowing the GPS receiver to power both the antenna and the splitter’s
    amplifier. The other RF outputs (J2, J3, J4, J5, J6, J7 and J8) are DC loaded with 200Ω resistors to
    simulate antenna current draw to prevent antenna fault readings from connected GPS receivers.
    Part Number
           N  HI  AL DCB S1X8- S / 5 / 110
    Network Option:
                N = Network Option; Blank = No Network
    Isolation Option:
               HI = Hi Isolation Option; Blank = Normal
    DC Options:
               DCB = DC Blocked; PDC = Pass DC
    Connector Options:
               N = N type; S = SMA; T = TNC; B = BNC
    DC Output Voltage:
               3.3, 5, 7.5, 9, 12, 15, CXX (Custom: “XX” denotes desired V)
    Source Voltage:
               110 -Transformer, 220 – Transformer, 240 – Transformer, MC – Military DC Connector (User
    supplies 9-32 VDC)
    Mechanical
    Dimensions:    Height:  1.3”
          Length (not including connectors)  Body: 4.5”
    Base Plate:  5.25”
       Width (not including connectors): 2.5”
    Weight:      16.2 oz. (459 grams)
    o o
    Operating Temp. Range: -40  to + 75 C
    Performance
    ALDCBS1X8 (Normal Output Isolation Option):
          Input SWR (Ant. Port) and Frequency Response: Ant. To JX (X=1…8) (Typical, type N connector):
    ALDCBS1X8 (Normal Output Isolation Option) (continued):
    Output SWR JX (X=1…8) and Adjacent Output Isolation (J1-J3, J2-J4, etc) (Typical, type N connectors):
      Opposite Output Isolation (J1-J2,J3-J4, etc) (Typical, type N conn.):
    HIALDCBS1X8 (Hi Output Isolation Option) (continued):
    Output SWR (J1, J2, J3, J4) and Adjacent Output Isolation (J1-J3, J2-J4) (Typical, type N connectors):
    Opposite Output Isolation (J1-J2, J3-J4) (Typical, type N connectors):
欧桥电子科技发展有限公司是英国Universal Corporate Ltd. (UK)在中国的分公司,旗下包含上海欧桥电子、天津欧桥、杭州欧桥等多个分支机构,从事涵盖电子通信产品、仪器、工业及机电产品等不同领域的业务与技术服务。公司本着良好的信誉和出色的售后服…  更多>>
上海欧桥电子科技有限公司
联系人:瞿建
地址:上海市浦东新区康桥路1100号保康大厦1103室
邮编:201315
电话:021-58126804
传真:021-58126844
公司网址:http://www.ouqiao.com/
  • 张克雄 在2025/6/26 17:30:00留言
  • 详细留言:产品尺寸图
  • 何先生 在2023/10/16 18:46:00留言
  • 详细留言:UCL-HP2000-A(B)
  • 李小姐 在2021/9/22 12:16:00留言
  • 详细留言:UCL-HT80GH-18,5PCS
  • huyiping 在2011/5/17 15:20:00留言
  • 详细留言:4142b+41420A+41420A
  • 李永珍 在2010/9/28 19:41:00留言
  • 详细留言:True Time XL-AK GPS Receiver (600-000-03)
