上海欧桥电子科技有限公司
  • GPS接收机系列
  • 发布时间:2008/4/25 10:36:29   修改时间:2008/4/25 10:36:29 浏览次数:1260
  • GPS接收机系列
  • GPS接收机系列
    产品名称: XL-750 GPS Time Source for Power Industry
    产 品 说 明
    Symmetricom’s XL-750 GPS Time Source has been developed to address key power industry timing requirements. Whether it’s the monitor, control or analysis of the power system, the XL-750 is the cost-effective GPS time synchronization solution.
    The XL-750 directly meets the recent recommendations from NERC (North American Electric Reliability Council) for event timing at power substations. Specifically, it fully satisfies NERC’s Recommendation # 12 concerning GPS time-synchronized recording devices.
    Using GPS satellites, the XL-750 generates extremely accurate output pulses and time codes in multiple formats and offers superb timing accuracy (100nanoseconds to UTC). The XL-750 synchronizes a wide variety of microprocessor-based power system equipment including: SCADA systems, remote terminal units (RTUs), protection relays, sequence of event recorders, digital fault recorders, power/tariff meters and other intelligent electronic devices (IEDs).
    Field programmable using a Windows-based configuration program, the XL-750 allows the user to define time code formats, output pulses rates and durations, device status, and a wide variety of operational parameters. Each output can feed directly to different areas through electrically isolated outputs which insures reliable operation in a harsh substation environment.
    The XL-750 generates a wide range of timing signals via four output ports. A fixed output provides an IRIG B amplitude modulated (AM) time code signal. Three independently configurable digital ports can provide pulse rates or unmodulated (DC level shift) time code. The XL-750 pulse output is easily configured to provide common power industry pulse rates including a 1 pulse-per-second (PPS), 1 pulse-per-minute (PPM), and 1 pulse-per-hour (PPH). Signal levels are also selectable at time of order from TTL (standard) to optional RS422, fiber optic or high voltage MOSFET switch. A RS232 serial port is provided for configuration and synchronous time string broadcasts. A dual channel event time tagging option is available for precise time tagging of external event pulses. Also available is network time server option to synchronize computers with the Network Time Protocol (NTP).
欧桥电子科技发展有限公司是英国Universal Corporate Ltd. (UK)在中国的分公司,旗下包含上海欧桥电子、天津欧桥、杭州欧桥等多个分支机构,从事涵盖电子通信产品、仪器、工业及机电产品等不同领域的业务与技术服务。公司本着良好的信誉和出色的售后服…  更多>>
上海欧桥电子科技有限公司
联系人:瞿建
地址:上海市浦东新区康桥路1100号保康大厦1103室
邮编:201315
电话:021-58126804
传真:021-58126844
公司网址:http://www.ouqiao.com/
  • 张克雄 在2025/6/26 17:30:00留言
  • 详细留言:产品尺寸图
  • 何先生 在2023/10/16 18:46:00留言
  • 详细留言:UCL-HP2000-A(B)
  • 李小姐 在2021/9/22 12:16:00留言
  • 详细留言:UCL-HT80GH-18,5PCS
  • huyiping 在2011/5/17 15:20:00留言
  • 详细留言:4142b+41420A+41420A
  • 李永珍 在2010/9/28 19:41:00留言
  • 详细留言:True Time XL-AK GPS Receiver (600-000-03)
