宏盛国际发展有限公司
企业空间 > 资料下载 > 正文
  • 上传时间:2009/6/23 11:14:19
  • 下载次数:1672
  • 详细介绍:
    澳洲macnaught换油设备
    澳洲macnaught换油设备
    澳洲macnaught换油设备
    澳洲macnaught换油设备
    澳洲macnaught换油设备
    澳洲macnaught换油设备,macnaught油脂泵,macnaught,澳洲macnaught换油设备,macnaught油脂泵,macnaught,宏盛国际
    产品描述
     宏盛国际发展有限公司
    TEL:0512-55177726   55177728  FAX:0512-55177725
    http://www.hs889.com  E-mail:hs-889@163.com
    macnaught *玛乐*成立于1948年,是澳洲全资公司。*玛乐*专注于打油器材的发展。他们针对农业,工业及汽车市场的需要发展该行业特有''设计" ."生产"及''市场推广"以提供所需之专用器材。
    澳洲*玛乐*提供高品质的产品及服务作为未来成功的指标,更无时无刻地注意市场的变化而更改其产品系列及设计。现时*玛乐*已成为澳洲市场上提供有关产品的领导者,同时*玛乐*已发展了横跨60个国家的完整分销网络。
    澳洲*玛乐*在产品设计上亦已荣获三项国家出口奖及两项澳洲设计奖,足以证明*玛乐*在打油器材方面的认许成就。
    宏盛国际发展有限公司为澳洲macnaught *玛乐*加油系统中国代理.
    FAX:0512-55177725
    K29 Flexigun? 450g (15.9oz) cartidge
    K29 Flexigun? Z Zinc version 450g (15.9oz) cartidge
    K40 Levergun? 400G (14.5oz) cartidge
    K45 Levergun? 450G (15.5oz) cartidge
    K6 Minilube?
    The K6 MINILUBE? is a portable, manual greasing system designed for use both in workshop environments and for on site applications. Macnaught produces models to suit pail sizes from 2.5 kg (5 lbs) to 5 kg (11 lbs) with depths of 146 mm to 225 mm.
    K3 Superlube?
    The K3 SUPERLUBE? is a manual greasing system designed for powerful, professional greasing. A cost effective solution for all workshop greasing requirements, Macnaught produces models to suit pails from 12.5 kg (28 lbs) up to 22 kg (48 lbs) with depths of 310 mm to 430 mm.
    J2 Grease Pump
    J2B Bucket Pump
    The J2 Grease Pump is a grease transfer pump designed for bulk filling grease dispensing equipment, and depending on model can fit pails from 12.5 kg (28 lbs) up to 22 kg (48 lbs), with depths of 315 mm to 390 mm. The J2 Grease Pump is an ideal workshop complement combining economical bulk grease purchasing with the portability of a hand operated pump.
    P3 Powerlube ?
    The P3 POWERLUBE? is the ultimate in high pressure, air operated greasing. With models available to suit containers from 12.5 kg (28 lbs) to 22 kg (48 lbs), it is fitted with a 50:1 ratio air motor and can operate off most small compressors to provide fast, continuous greasing.
    P8 Maxilube?
    A larger version of the P6 MAXILUBE?, the P8 MAXILUBE? is a 50:1 ratio pump is designed to fit 180 kg (400 lbs) grease containers.
    GP Rapidflo?
    The GP RAPIDFLO? is a durable, high quality impellor pump incorporating a gearbox for high output (up to 100 L per minute) and easy operation. Designed for 205 L (55 US gal) or 60 L (16 US gal) drums, this pump is ideal for any fuel transfer task.
    HP Litrestroke?
    The HP LITRESTROKE? has an easy lever action and is designed for either 205 L (55 US gal) or 60 L (16 US gal) drums. The pump is built for very harsh working conditions and is ideal for most types of fuel transfer operations when an economical and long lasting pump is required.
    PVR Rotary Vane Pump
    PVRH Rotary Vane Pump with Hose
    These economical rotary pumps are designed to dispense various types of lubricating oils and fuels up to 20 L (5 US gal) per minute from 60 L (16 US gal) to 205 L (55 US gal) drums.
    MH50F Electronic Oil Control Gun with Flexible Outlet
    MH50R Electronic Oil Control Gun with Rigid Outlet
    The MH40 is a low cost oil control gun with a fully integrated mechanical meter. Suitable for dispensing engine oil, gear oil, automatic transmission fluid and anti-freeze/anti-boil, with a maximum viscosity of SAE 140
    OS100
    The OS100 is a portable oil and grease system that caters for any workplace needs. All spare parts are available separately, and more information on a particular component from any of the systems is detailed separately in this catalogue.
    OS500
    The OS500, OS600 & OS 800 systems are suitable for mounting onto IBC pods to create an easy to use and portable pumping system.
    P3-0S2
    This portable grease system allows for pails up to 25 L (6 US g) to be placed inside the supplied 4 wheeled container.
    Model Description Hose ID Hose Length Working Pressure Hose Material Reel Colour Hose Colour Max Working Temp. Reel Inlet (BSP/NPT) Hose outlet (BSP/NPT) Weight Max Viscosity
    AB100 air breathing 10mn 17mn 1 700 kPa
    (250 psi)
    reinforced PVC blue yellow 60' C 3/8" 1/4" 10kg n/a
    AR100 compressed air 10mn 20mn 1 700 kPa
    (250 psi)
    reinforced PVC red red 60' C 3/8" 1/4" 10kg n/a
    AR200 compressed air 12.5mn 15mn 1 700 kPa
    (250 psi)
    reinforced PVC red red 60' C 3/8" 3/8" 10kg n/a
    AW100 compressed air/water 10mn 20mn 1 700 kPa
    (250 psi)
    reinforced PVC blue blue 60' C 3/8" 1/4" 10kg n/a
    AW150 compressed air/water 10mn 15mn 1 700 kPa
    (250 psi)
    AW200 compressed air/water 12.5mn 15mn 1 700 kPa
    (250 psi)
    reinforced PVC blue blue 60' C 3/8" 3/8" 10kg n/a
    AW100 compressed air/water 10mm 20m 1 700 kPa (250 psi) reinforced PVC blue blue 60' C 3/8" 1/4" 10kg n/a
    AW150 compressed air/water 10mm 15m 1 700 kPa (250psi) reinforced PVC blue blue 60' C 3/8" 1/4" 10kg n/a
    AW200 compressed air/water 12.5mm 15m 1 700 kPa (250 psi) reinforced PVC blue blue 60' C 3/8" 3/8" 10kg n/a
    CW100 cold wash 12.5mm 15m 1 000 kPa (150 psi) reinforced PVC blue white 60' C 3/8" hose nozzle 10kg n/a
    DR100 garden water 12.5mm 18m 860 kPa (125 psi) reinforced PVC green green 60' C 3/8" hose nozzle 10kg n/a
    HW100 hot water 12.5mm 12m 1 400 kPa (200 psi) reinforced rubber red red 90' C 3/8" 3/8" 10kg n/a
    HWP100 high pressure hot water 10mm 12m 20 700 kPa (3000 psi) reinforced rubber (SAE 100 R2AT) red black 95' C 3/8" 3/8" 10kg n/a
    PW100 potable water 12.5mm 15m 1 000 kPa (150 psi) reinforced LDPE blue blue 60' C 3/8" 3/8" 10kg n/a
    GR100 grease 6mm 10m 34 500 kPa (5000 psi) reinforced rubber (SAE 100R2) black black n/a 1/4" 1/4" 13kg n/a
    OA100 oxy/acetylene 5mm 15m 1 400 kPa (200 psi) reinforced rubber (AS 1335) blue red/blue n/a 5/8" UNF 5/8" UNF 13kg n/a
    OLPG100
    oxy/LPG gas
    5mm 15m 1 400 kPa (200 psi) reinforced rubber (AS 1335) black orange/blue n/a 5/8" UNF 5/8" UNF 13kg n/a
    FG100 food gas/CO2 6mm 20m 17 000 kPa (250 psi) NTP red clear 60' C 3/8" 1/4" 10kg n/a
    WP100
    weedicide-pesticide
    10mm 16m 1 700 kPa (250 psi) reinforced PVC red red 60' C 3/8" 1/4" 10kg n/a
     宏盛国际发展有限公司
宏盛国际发展有限公司成立于1992年8月,公司拥有技术工程师、销售工程师近80人,是一支年轻而富有朝气的团队。我们秉承:用户至上,信誉第一的宗旨为广大客户提供一流的产品、一流的服务。 由于全球一体化,在工业发展方面一日千里,我们本着过往累…  更多>>
宏盛国际发展有限公司
联系人:宏盛国际
地址:江苏.昆山
邮编:215300
电话:0512-55177726/55177728
传真:0512-55177725
公司网址:http://www.hs889.com
  • 在2024/4/11 11:02:00留言
  • 详细留言:您好 这边看到你们代理了多个品牌的产品 我想咨询一些产品 方便的话能否让销售加一下我的联系方式15659211233(微信)
  • 王力 在2015/3/17 10:39:00留言
  • 徐工 在2014/8/18 17:33:00留言
  • 详细留言:有4个DEUBLIN 的旋转接头要询价: 557-130-199 4个 657-130-125 1个 657-130-124 1个 557-130-198-171 RH 1个
  • 程小翠 在2014/3/27 8:32:00留言
  • 详细留言:Deublin油缸 型号:2300-001-109
  • 钱锡南 在2014/3/15 16:22:00留言
  • 详细留言:我要样本
