北京祥顺达恒商贸有限公司
  • A-B PLC4
  • 发布时间:2008/9/4 10:11:58   修改时间:2008/9/4 10:11:58 浏览次数:800
  •   如需了解相关信息咨询      薛晨:13801020197
    1326AB-B430E-M2LS MOTOR,SERVO,460V,6.6NM,3000RPM,MULTI,IP67,CRS
    1326AB-B430E-S2K4L MOTOR,SERVO,460V,6.6NM,3000RPM,SINGL,BRK,IP67
    1326AB-B430E-S2K4LS MOTOR,SERVO,460V,6.6NM,3000RPM,SINGL,BRK,IP67,CRS
    1326AB-B430E-S2L MOTOR,SERVO,460V,6.6NM,3000RPM,SINGL,IP67
    1326AB-B430E-S2LS MOTOR,SERVO,460V,6.6NM,3000RPM,SINGL,IP67,CRS
    1326AB-B430G-21 MOTOR,SERVO,460V,6.4NM,5000RPM
    1326AB-B430G-21-K4 MOTOR,SERVO,460V,6.4NM,5000RPM,BRK
    1326AB-B430G-21-K4L MOTOR,SERVO,460V,6.4NM,5000RPM,BRK,IP67
    1326AB-B430G-21-L MOTOR,SERVO,460V,6.4NM,5000RPM,IP67
    1326AB-B430G-21MK4L MOTOR,SERVO,460V,6.4NM,5000RPM,MULTI,BRK,IP67
    1326AB-B430G-21ML MOTOR,SERVO,460V,6.4NM,5000RPM,MULTI,IP67
    1326AB-B430G-M2K4L MOTOR,SERVO,460V,6.4NM,5000RPM,MULTI,BRK,IP67
    1326AB-B430G-M2K4LS MOTOR,SERVO,460V,6.4NM,5000RPM,MULTI,BRK,IP67,CRS
    1326AB-B430G-M2L MOTOR,SERVO,460V,6.4NM,5000RPM,MULTI,IP67
    1326AB-B430G-M2LS MOTOR,SERVO,460V,6.4NM,5000RPM,MULTI,IP67,CRS
    1326AB-B430G-S2K4L MOTOR,SERVO,460V,6.4NM,5000RPM,SINGL,BRK,IP67
    1326AB-B430G-S2K4LS MOTOR,SERVO,460V,6.4NM,5000RPM,SINGL,BRK,IP67,CRS
    1326AB-B430G-S2L MOTOR,SERVO,460V,6.4NM,5000RPM,SINGL,IP67
    1326AB-B430G-S2LS MOTOR,SERVO,460V,6.4NM,5000RPM,SINGL,IP67,CRS
    1326AB-B515E-21 MOTOR,SERVO,460V,10.4NM,3000RPM
    1326AB-B515E-21-K5 MOTOR,SERVO,460V,10.4NM,3000RPM,BRK
    1326AB-B515E-21-K5L MOTOR,SERVO,460V,10.4NM,3000RPM,BRK,IP67
    1326AB-B515E-21-L MOTOR,SERVO,460V,10.4NM,3000RPM,IP67
    1326AB-B515E-21MK5L MOTOR,SERVO,460V,10.4NM,3000RPM,MULTI,BRK,IP67
    1326AB-B515E-21ML MOTOR,SERVO,460V,10.4NM,3000RPM,MULTI,IP67
    1326AB-B515E-M2K5L MOTOR,SERVO,460V,10.4NM,3000RPM,MULTI,BRK,IP67
    1326AB-B515E-M2K5LS MOTOR,SERVO,460V,10.4NM,3000RPM,MULTI,BRK,IP67,CRS
    1326AB-B515E-M2L MOTOR,SERVO,460V,10.4NM,3000RPM,MULTI,IP67
    1326AB-B515E-M2LS MOTOR,SERVO,460V,10.4NM,3000RPM,MULTI,IP67,CRS
    1326AB-B515E-S2K5L MOTOR,SERVO,460V,10.4NM,3000RPM,SINGL,BRK,IP67
    1326AB-B515E-S2K5LS MOTOR,SERVO,460V,10.4NM,3000RPM,SINGL,BRK,IP67,CRS
    1326AB-B515E-S2L MOTOR,SERVO,460V,10.4NM,3000RPM,SINGL,IP67
    1326AB-B515E-S2LS MOTOR,SERVO,460V,10.4NM,3000RPM,SINGL,IP67,CRS
    1326AB-B515G-21 MOTOR,SERVO,460V,10.4NM,5000RPM
    1326AB-B515G-21-K5 MOTOR,SERVO,460V,10.4NM,5000RPM,BRK
    1326AB-B515G-21-K5L MOTOR,SERVO,460V,10.4NM,5000RPM,BRK,IP67
    1326AB-B515G-21-L MOTOR,SERVO,460V,10.4NM,5000RPM,IP67
    1326AB-B515G-21MK5L MOTOR,SERVO,460V,10.4NM,5000RPM,MULTI,BRK,IP67
    1326AB-B515G-21ML MOTOR,SERVO,460V,10.4NM,5000RPM,MULTI,IP67
    1326AB-B515G-M2K5L MOTOR,SERVO,460V,10.4NM,5000RPM,MULTI,BRK,IP67
    1326AB-B515G-M2K5LS MOTOR,SERVO,460V,10.4NM,5000RPM,MULTI,BRK,IP67,CRS
    1326AB-B515G-M2L MOTOR,SERVO,460V,10.4NM,5000RPM,MULTI,IP67
    1326AB-B515G-M2LS MOTOR,SERVO,460V,10.4NM,5000RPM,MULTI,IP67,CRS
    1326AB-B515G-S2K5L MOTOR,SERVO,460V,10.4NM,5000RPM,SINGL,BRK,IP67
    1326AB-B515G-S2K5LS MOTOR,SERVO,460V,10.4NM,5000RPM,SINGL,BRK,IP67,CRS
    1326AB-B515G-S2L MOTOR,SERVO,460V,10.4NM,5000RPM,SINGL,IP67
    1326AB-B515G-S2LS MOTOR,SERVO,460V,10.4NM,5000RPM,SINGL,IP67,CRS
    1326AB-B520E-21 MOTOR,SERVO,460V,13.0NM,3000RPM
    1326AB-B520E-21-K5 MOTOR,SERVO,460V,13.0NM,3000RPM,BRK
    1326AB-B520E-21-K5L MOTOR,SERVO,460V,13.0NM,3000RPM,BRK,IP67
    1326AB-B520E-21-L MOTOR,SERVO,460V,13.0NM,3000RPM,IP67
    1326AB-B520E-21MK5L MOTOR,SERVO,460V,13.0NM,3000RPM,MULTI,BRK,IP67
    1326AB-B520E-21ML MOTOR,SERVO,460V,13.0NM,3000RPM,MULTI,IP67
    1326AB-B520E-M2K5L MOTOR,SERVO,460V,13.0NM,3000RPM,MULTI,BRK,IP67
    1326AB-B520E-M2K5LS MOTOR,SERVO,460V,13.0NM,3000RPM,MULTI,BRK,IP67,CRS
    1326AB-B520E-M2L MOTOR,SERVO,460V,13.0NM,3000RPM,MULTI,IP67
    1326AB-B520E-M2LS MOTOR,SERVO,460V,13.0NM,3000RPM,MULTI,IP67,CRS
    1326AB-B520E-S2K5L MOTOR,SERVO,460V,13.0NM,3000RPM,SINGL,BRK,IP67
    1326AB-B520E-S2K5LS MOTOR,SERVO,460V,13.0NM,3000RPM,SINGL,BRK,IP67,CRS
    1326AB-B520E-S2L MOTOR,SERVO,460V,13.0NM,3000RPM,SINGL,IP67
    1326AB-B520E-S2LS MOTOR,SERVO,460V,13.0NM,3000RPM,SINGL,IP67,CRS
    1326AB-B520F-21 MOTOR,SERVO,460V,13.1NM,3500RPM
    1326AB-B520F-21-K5 MOTOR,SERVO,460V,13.1NM,3500RPM,BRK
    1326AB-B520F-21-K5L MOTOR,SERVO,460V,13.1NM,3500RPM,BRK,IP67
    1326AB-B520F-21-L MOTOR,SERVO,460V,13.1NM,3500RPM,IP67
    1326AB-B520F-21MK5L MOTOR,SERVO,460V,13.1NM,3500RPM,MULTI,BRK,IP67
    1326AB-B520F-21ML MOTOR,SERVO,460V,13.1NM,3500RPM,MULTI,IP67
    1326AB-B520F-M2K5L MOTOR,SERVO,460V,13.1NM,3500RPM,MULTI,BRK,IP67
    1326AB-B520F-M2K5LS MOTOR,SERVO,460V,13.1NM,3500RPM,MULTI,BRK,IP67,CRS
    1326AB-B520F-M2L MOTOR,SERVO,460V,13.1NM,3500RPM,MULTI,IP67
    1326AB-B520F-M2LS MOTOR,SERVO,460V,13.1NM,3500RPM,MULTI,IP67,CRS
    1326AB-B520F-S2K5L MOTOR,SERVO,460V,13.1NM,3500RPM,SINGL,BRK,IP67
    1326AB-B520F-S2K5LS MOTOR,SERVO,460V,13.1NM,3500RPM,SINGL,BRK,IP67,CRS
    1326AB-B520F-S2L MOTOR,SERVO,460V,13.1NM,3500RPM,SINGL,IP67
    1326AB-B520F-S2LS MOTOR,SERVO,460V,13.1NM,3500RPM,SINGL,IP67,CRS
    1326AB-B530E-21 MOTOR,SERVO,460V,18.0NM,3000RPM
    1326AB-B530E-21-K5 MOTOR,SERVO,460V,18.0NM,3000RPM,BRK
    1326AB-B530E-21-K5L MOTOR,SERVO,460V,18.0NM,3000RPM,BRK,IP67
    1326AB-B530E-21-L MOTOR,SERVO,460V,18.0NM,3000RPM,IP67
    1326AB-B530E-21MK5L MOTOR,SERVO,460V,18.0NM,3000RPM,MULTI,BRK,IP67
    1326AB-B530E-21ML MOTOR,SERVO,460V,18.0NM,3000RPM,MULTI,IP67
    1326AB-B530E-M2K5L MOTOR,SERVO,460V,18.0NM,3000RPM,MULTI,BRK,IP67
    1326AB-B530E-M2K5LS MOTOR,SERVO,460V,18.0NM,3000RPM,MULTI,BRK,IP67,CRS
    1326AB-B530E-M2L MOTOR,SERVO,460V,18.0NM,3000RPM,MULTI,IP67
    1326AB-B530E-M2LS MOTOR,SERVO,460V,18.0NM,3000RPM,MULTI,IP67,CRS
    1326AB-B530E-S2K5L MOTOR,SERVO,460V,18.0NM,3000RPM,SINGL,BRK,IP67
    1326AB-B530E-S2K5LS MOTOR,SERVO,460V,18.0NM,3000RPM,SINGL,BRK,IP67,CRS
    1326AB-B530E-S2L MOTOR,SERVO,460V,18.0NM,3000RPM,SINGL,IP67
    1326AB-B530E-S2LS MOTOR,SERVO,460V,18.0NM,3000RPM,SINGL,IP67,CRS
    1326AB-B720E-21 MOTOR,SERVO,460V,30.9NM,3500RPM
    1326AB-B720E-21-K7 MOTOR,SERVO,460V,30.9NM,3500RPM,BRK
    1326AB-B720E-21-K7L MOTOR,SERVO,460V,30.9NM,3500RPM,BRK,IP67
    1326AB-B720E-21-L MOTOR,SERVO,460V,30.9NM,3500RPM,IP67
    1326AB-B720E-21MK7L MOTOR,SERVO,460V,30.9NM,3500RPM,MULTI,BRK,IP67
    1326AB-B720E-21ML MOTOR,SERVO,460V,30.9NM,3500RPM,MULTI,IP67
    1326AB-B720E-M2K7L MOTOR,SERVO,460V,30.9NM,3500RPM,MULTI,BRK,IP67
    1326AB-B720E-M2K7LS MOTOR,SERVO,460V,30.9NM,3500RPM,MULTI,BRK,IP67,CRS
    1326AB-B720E-M2L MOTOR,SERVO,460V,30.9NM,3500RPM,MULTI,IP67
    1326AB-B720E-M2LS MOTOR,SERVO,460V,30.9NM,3500RPM,MULTI,IP67,CRS
    1326AB-B720E-S2K7L MOTOR,SERVO,460V,30.9NM,3500RPM,SINGL,BRK,IP67
    1326AB-B720E-S2K7LS MOTOR,SERVO,460V,30.9NM,3500RPM,SINGL,BRK,IP67,CRS
    1326AB-B720E-S2L MOTOR,SERVO,460V,30.9NM,3500RPM,SINGL,IP67
    1326AB-B720E-S2LS MOTOR,SERVO,460V,30.9NM,3500RPM,SINGL,IP67,CRS
    1326AB-B720F-21 MOTOR,SERVO,460V,31.8NM,5000RPM
    1326AB-B720F-21-K7 MOTOR,SERVO,460V,31.8NM,5000RPM,BRK
    1326AB-B720F-M2K7L MOTOR,SERVO,460V,31.8NM,5000RPM,MULTI,BRK,IP67
    1326AB-B720F-M2K7LS MOTOR,SERVO,460V,31.8NM,5000RPM,MULTI,BRK,IP67,CRS
    1326AB-B720F-M2L MOTOR,SERVO,460V,31.8NM,5000RPM,MULTI,IP67
    1326AB-B720F-M2LS MOTOR,SERVO,460V,31.8NM,5000RPM,MULTI,IP67,CRS
    1326AB-B720F-S2K7L MOTOR,SERVO,460V,31.8NM,5000RPM,SINGL,BRK,IP67
    1326AB-B720F-S2K7LS MOTOR,SERVO,460V,31.8NM,5000RPM,SINGL,BRK,IP67,CRS
    1326AB-B720F-S2L MOTOR,SERVO,460V,31.8NM,5000RPM,SINGL,IP67
    1326AB-B720F-S2LS MOTOR,SERVO,460V,31.8NM,5000RPM,SINGL,IP67,CRS
    1326AB-B730E-21 MOTOR,SERVO,460V,39.0NM,3350RPM
    1326AB-B730E-21-K7 MOTOR,SERVO,460V,39.0NM,3350RPM,BRK
    1326AB-B730E-21-K7L MOTOR,SERVO,460V,39.0NM,3350RPM,BRK,IP67
    1326AB-B730E-21-L MOTOR,SERVO,460V,39.0NM,3350RPM,IP67
    1326AB-B730E-21MK7L MOTOR,SERVO,460V,39.0NM,3350RPM,MULTI,BRK,IP67
    1326AB-B730E-21ML MOTOR,SERVO,460V,39.0NM,3350RPM,MULTI,IP67
    1326AB-B730E-M2K7L MOTOR,SERVO,460V,39.0NM,3350RPM,MULTI,BRK,IP67
    1326AB-B730E-M2K7LS MOTOR,SERVO,460V,39.0NM,3350RPM,MULTI,BRK,IP67,CRS
    1326AB-B730E-M2L MOTOR,SERVO,460V,39.0NM,3350RPM,MULTI,IP67
    1326AB-B730E-M2LS MOTOR,SERVO,460V,39.0NM,3350RPM,MULTI,IP67,CRS
    1326AB-B730E-S2K7L MOTOR,SERVO,460V,39.0NM,3350RPM,SINGL,BRK,IP67
    1326AB-B730E-S2K7LS MOTOR,SERVO,460V,39.0NM,3350RPM,SINGL,BRK,IP67,CRS
    1326AB-B730E-S2L MOTOR,SERVO,460V,39.0NM,3350RPM,SINGL,IP67
    1326AB-B730E-S2LS MOTOR,SERVO,460V,39.0NM,3350RPM,SINGL,IP67,CRS
    1326AB-B740C-21 MOTOR,SERVO,460V,53.0NM,2200RPM
    1326AB-B740C-21-K7 MOTOR,SERVO,460V,53.0NM,2200RPM,BRK
    1326AB-B740C-21-K7L MOTOR,SERVO,460V,53.0NM,2200RPM,BRK,IP67
    1326AB-B740C-21-L MOTOR,SERVO,460V,53.0NM,2200RPM,IP67
    1326AB-B740C-21MK7L MOTOR,SERVO,460V,53.0NM,2200RPM,MULTI,BRK,IP67
    1326AB-B740C-21ML MOTOR,SERVO,460V,53.0NM,2200RPM,MULTI,IP67
    1326AB-B740C-M2K7L MOTOR,SERVO,460V,53.0NM,2200RPM,MULTI,BRK,IP67
    1326AB-B740C-M2K7LS MOTOR,SERVO,460V,53.0NM,2200RPM,MULTI,BRK,IP67,CRS
    1326AB-B740C-M2L MOTOR,SERVO,460V,53.0NM,2200RPM,MULTI,IP67
    1326AB-B740C-M2LS MOTOR,SERVO,460V,53.0NM,2200RPM,MULTI,IP67,CRS
    1326AB-B740C-S2K7L MOTOR,SERVO,460V,53.0NM,2200RPM,SINGL,BRK,IP67
    1326AB-B740C-S2K7LS MOTOR,SERVO,460V,53.0NM,2200RPM,SINGL,BRK,IP67,CRS
    1326AB-B740C-S2L MOTOR,SERVO,460V,53.0NM,2200RPM,SINGL,IP67
    1326AB-B740C-S2LS MOTOR,SERVO,460V,53.0NM,2200RPM,SINGL,IP67,CRS
    1326AB-B740E-21 MOTOR,SERVO,460V,50.0NM,3400RPM
    1326AB-B740E-21-K7 MOTOR,SERVO,460V,50.0NM,3400RPM,BRK
    1326AB-B740E-21-K7L MOTOR,SERVO,460V,50.0NM,3000RPM,RSLVR,BRK,IP67
    1326AB-B740E-21-L MOTOR,SERVO,460V,50.0NM,3400RPM,IP67
    1326AB-B740E-M2K7L MOTOR,SERVO,460V,50.0NM,3400RPM,MULTI,BRK,IP67
    1326AB-B740E-M2K7LS MOTOR,SERVO,460V,50.0NM,3400RPM,MULTI,BRK,IP67,CRS
    1326AB-B740E-M2L MOTOR,SERVO,460V,50.0NM,3400RPM,MULTI,IP67
    1326AB-B740E-M2LS MOTOR,SERVO,460V,50.0NM,3400RPM,MULTI,IP67,CRS
    1326AB-B740E-S2K7L MOTOR,SERVO,460V,50.0NM,3400RPM,SINGL,BRK,IP67
    1326AB-B740E-S2K7LS MOTOR,SERVO,460V,50.0NM,3400RPM,SINGL,BRK,IP67,CRS
    1326AB-B740E-S2L MOTOR,SERVO,460V,50.0NM,3400RPM,SINGL,IP67
    1326AB-B740E-S2LS MOTOR,SERVO,460V,50.0NM,3400RPM,SINGL,IP67,CRS
    1326AB-C1C-11 SERV MTR,105-IN-LB,2K-RPM,STD INCH
    1326AB-C3E-21-2287B SERV MTR,310-IN-LB,3000RPM,SHFT SEAL,METRIC
    1326AB-C4C-11-2287B AC SERVO,420 LB-IN,2KRPM,SHAFT SEAL
    1326AB-MOD-KEYLES KIT,MODIFICATION,KEYED TO KEYLESS 1326AB (460V)
    1326AB-MOD-M41 KIT,ADAPTER,T&R CE-100M-ISI TO 1326AB-B4XXX 460V
    1326AB-MOD-M42 ADAPTER,842A-31-XX ENC MNTG FOR 1326AB-B4XXXX
    1326AB-MOD-M51 KIT,ADAPTER,T&R CE-100M-ISI TO 1326AB-B5XXX 460V
    1326AB-MOD-M52 ADAPTER,842A-31-XX ENC MNTG FOR 1326AB-B5XXXX
    1326AB-MOD-M61 KIT,ADAPTER,T&R CE-100M-ISI TO 1326AB-B7XXX 460V
    1326AB-MOD-M72 ADAPTER,842A-31-XX ENC MNTG FOR 1326AB-B7XXXX
    1326AB-MOD-RJAB1 KIT, RIGHT ANGLE JUNCTION,FOR 1326AB-B4,B5 MOTOR
    1326AB-MOD-RJC1 KIT,RIGHT ANGLE JUNCTION BOX,FOR 1326AB-B7 MOTOR
    1326AB-MOD-SSV-AB4 SHAFT SEAL KIT A4 & B4 MOTOR, VITON METRIC
    1326AB-MOD-SSV-B2 SHFT SEAL KIT,METRIC,VITON B SERIES MOTOR (-21)
    1326AB-MOD-SSV-C2 SHFT SEAL KIT,METRIC,VITON C SERIES MOTOR (-21)
    1394-CCAE01 CABLE,MO2AE TO 1394-SJTXX-A,2AXES,1M
    1394-CCAE03 CABLE,MO2AE TO 1394-SJTXX-A,2AXES,3M
    1394-CCAE08 CABLE,MO2AE TO 1394-SJTXX-A,2AXES,8M
    1394-CCAE15 CABLE,MO2AE TO 1394-SJTXX-A,2AXES,15M
    1394-CFLAE01 CABLE,MO2AE FLYING LEAD TO 1394-SJTXX-A,1 AXIS,1M
    1394-CFLAE03 CABLE,MO2AE FLYING LEAD TO 1394-SJTXX-A,1 AXIS,3M
    1394-CFLAE08 CABLE,MO2AE FLYING LEAD TO 1394-SJTXX-A,1 AXIS,8M
    1394-CFLAE15 CABLE,MO2AE FLYING LEAD TO 1394-SJTXX-A,1 AXIS,15M
    1394-SR10A KIT,EXTERNAL SHUNT,1400W CONT,40,000 PEAK
    1394-SR10A-FUSE-A KIT,FUSE AND LABEL,FOR 1394A-SR10A,SERIES A
    1394-SR36A MODULE,SHUNT,1800W,NO FAN
    1394-SR36A-FUSE-A KIT,FUSE AND LABEL,FOR 1394A-SR36A,SERIES A
    1394-SR36A-FUSE-B KIT,FUSE AND LABEL,FOR 1394A-SR36A,SERIES B
    1394-SR36AF MODULE,SHUNT,3600W,W/ FAN
    1394-SR36AF-FUSE-A KIT,FUSE AND LABEL,FOR 1394A-SR36AF,SERIES A
    1394-SR36AF-FUSE-B KIT,FUSE AND LABEL,FOR 1394A-SR36AF,SERIES B
    1394-SR9A MODULE,SHUNT,300W,NO FAN
    1394-SR9A-FUSE-A KIT,FUSE AND LABEL,FOR 1394A-SR9A,SERIES A
    1394-SR9A-FUSE-B KIT,FUSE AND LABEL,FOR 1394A-SR9A,SERIES B
    1394-SR9AF MODULE,SHUNT,900W,NO FAN
    1394-SR9AF-FUSE-A KIT,FUSE AND LABEL,FOR 1394A-SR9AF,SERIES A
    1394-SR9AF-FUSE-B KIT,FUSE AND LABEL,FOR 1394A-SR9AF,SERIES B
    1394C-8AWG-GCLAMP KIT, GROUND CLAMP FOR 1394C-AM75 FDBK / PWR 1LG
    1394C-AM03 MODULE,AXIS,2KW,3.0A CONT,6.0A PEEK
    1394C-AM04 MODULE,AXIS,3KW,4.5A CONT,9.0A PEAK
    1394C-AM07 MODULE,AXIS,5KW,7.5A CONT,15.0A PEAK
    1394C-AM50 MODULE,AXIS,10KW,23.3A CONT,33.2A PEAK
    1394C-AM50-IH MODULE,AXIS,INTL HTSNK,10KW,23.3A CONT,33.2A PK
    1394C-AM75 MODULE,AXIS,15KW,35.0A CONT,50.0A PEAK
    1394C-AM75-IH MODULE,AXIS,INTL HTSNK,15KW,35.0A CONT,50.0A PK
    1394C-SJT05-D MODULE,SYSTEM,5KW,SERVO,W/SERCOS INTF.NO HIM
    1394C-SJT10-D MODULE,SYSTEM,10KW,SERVO,W/SERCOS INTF,NO HIM
    1394C-SJT22-D MODULE,SYSTEM,22KW,SERVO,W/SERCOS INTF,NO HIM
    1398-DDM-005 DRIVE,7.5A PEAK, ULTRA 100
    1398-DDM-005-DN DRIVE,7.5A PEAK, ULTRA 100 W/DNET
    1398-DDM-005X DRIVE,7.5A PEAK, ULTRA 100 W/INDEX
    1398-DDM-005X-DN DRIVE,7.5A PEAK, ULTRA 100 W/DNET INDEX
    1398-DDM-009 DRIVE,15A PEAK, ULTRA 100
    1398-DDM-009-DN DRIVE,15A PEAK, ULTRA 100 W/DNET
    1398-DDM-009-TTL 15AMP ULTRA 100 DRIVE -TTL
    1398-DDM-009X DRIVE,15A PEAK, ULTRA 100 W/INDEX
    1398-DDM-009X-DN DRIVE,15A PEAK, ULTRA 100 W/DNET,INDEX
    1398-DDM-010 DRIVE,10A PEAK, ULTRA 200
    1398-DDM-010X DRIVE,10A PEAK, ULTRA 200 W/INDE
    1398-DDM-019 DRIVE,30A PEAK, ULTRA 100
    1398-DDM-019-DN DRIVE,30A PEAK, ULTRA 100 W/DNET
    1398-DDM-019X DRIVE,30A PEAK, ULTRA 100 W/INDEX
    1398-DDM-019X-DN DRIVE,30A PEAK, ULTRA 100 W/DNET,INDEX
    1398-DDM-020 DRIVE,20A PEAK, ULTRA 200
    1398-DDM-020X DRIVE,20A PEAK, ULTRA 200 W/INDE
    1398-DDM-030 DRIVE,30A PEAK, ULTRA 200
    1398-DDM-030X DRIVE,30A PEAK, ULTRA 200 W/INDE
    1398-DDM-075 DRIVE,75A PEAK, ULTRA 200
    1398-DDM-075X DRIVE,75A PEAK, ULTRA 200 W/INDE
    1398-DDM-150 DRIVE,150A,PEAK,ULTRA 200
    1398-DDM-150X DRIVE,150A,PEAK,ULTRA 200 W/INDEXING
    1398-HMI-001 TOUCHPAD INTERFACE MODULE, ULTRA
    1398-SR3AF KIT,ACTIVE EXTERNAL SHUNT,300W CONT.
    1398-SR9P KIT,PASSIVE EXTERNAL SHUNT,900W CONT.
    1400-CC COMMUNICATION CONVERTOR (RS232/RS485)
    1400-DCU COMM CARD FOR 1400PD
    1400-PD51A POWERMONITOR DISPLAY MODULE
    1400-PD51B POWERMONITOR DISPLAY MODULE
    1400-PD52A POWERMONITOR DISPLAY MODULE
    1402-LS51 LINE SYNCHRONIZATION MODULE (LSM)
    1403-BA BATTERY, LITHIUM FOR POWERMONITOR
    1403-CF000 2 X 25 CM F LINK FOR POWERMONITOR
    1403-CF001 2 X 1 M F LINK FOR POWERMONITOR
    1403-CF003 2 X 3 M F LINK FOR POWERMONITOR
    1403-CF005 2 X 5 M F LINK FOR POWERMONITOR
    1403-CF010 10 M F LINK FOR POWERMONITOR
    1403-CF020 20 M F LINK FOR POWERMONITOR
    1403-CF050 50 M F LINK FOR POWERMONITOR
    1403-CF100 F LINK,50 M
    1403-CF250 F LINK,50 M
    1403-DMA DISPLAY UNIT FOR POWERMONITOR 120/240V AC 50/60 MZ OR 125/250V DC
    1403-DMB DISPLAY UNIT FOR POWERMONITOR 12/24V AC 50/60 HZ OR 12/24/48V DC
    1403-LM01A MASTER MODULE FOR POWERMONITOR 120/240V AC 50/60 HZ OR 25/250V DC, .1% ACCURACY, LTD PWR QLTY INFO
    1403-LM01B MASTER MODULE FOR POWERMONITOR 24V AC 50/60 HZ OR 24/48V DC, .1% ACCURACY, LTD PWR QLTY INFO
    1403-LM05A MASTER MODULE FOR POWERMONITOR 120/240V AC 50/60 HZ OR 125/250V DC, .1% ACCURACY
    1403-LM05B MASTER MODULE FOR POWERMONITOR 24V AC 50/60 HZ OR 24/48V DC, .1% ACCURACY, LTD PWR QLTY INFO
    1403-MM01A MASTER MODULE FOR POWERMONITOR 120/240V AC 50/60 HZ OR 125/250V DC, .05% ACCURACY
    1403-MM01B MASTER MODULE FOR POWERMONITOR 24V AC 50/60 HZ OR 24/48V DC, .05% ACCURACY
    1403-MM05A MASTER MODULE FOR POWERMONITOR 120/240V AC 50/60 HZ OR 125/250V DC, .05% ACCURACY
    1403-MM05B MASTER MODULE FOR POWERMONITOR 24V AC 50/60 HZ OR 24/48V DC, .05% ACCURACY
    1403-N10 CONNECTOR FOR POWER MONITOR
    1403-NENET COMMUNICATION MODULE (ETHERNET)
    1403-NSC COMMUNICATION MODULE FOR POWERMONITOR (REMOTE I/O & SERIAL DF1)
    1404-CAL CALIBRATION SERVICE FOR THE POWERMONITOR 3000 SERVICE IS ORDERED THROUGH GMS SERVICE MANAGEMENT SYSTEM (SMS)
    1404-DM DISPLAY MODULE           FOR POWERMONITOR
    1404-M405A-000 MASTER MODULE            FOR POWERMONITOR
    1404-M405A-232 MASTER MODULE            FOR POWERMONITOR
    1404-M405A-CNT 1404-M4 CONTROLNET PM3000 120/240V P.S.
    1404-M405A-DNT MASTER MODULE            FOR POWERMONITOR
    1404-M405A-ENT 1404-M4 ETHERNET PM3000
    1404-M405A-RIO MASTER MODULE            FOR POWERMONITOR
    1404-M405B-000 MASTER MODULE - PQ24V POWER SUPPLY
    1404-M405B-232 MASTER MODULE - PQ 24V POWER SUPPLY 232 COM
    1404-M405B-CNT 1404-M4 CONTROLNET PM3000 24V P.S.
    1404-M405B-DNT MASTER MODULE- PQ 24V POWER SUPPLY DNET COM
    1404-M405B-ENT 1404-M4 ETHERNET PM3000
    1404-M405B-RIO MASTER MODULE - PQ 24V POWER SUPPLY RIO COM
    1404-M505A-000 MASTER MODULE - PQ
    1404-M505A-000-02 1404-M5 MASTER MODULE CLASS 0.2
    1404-M505A-232 MASTER MODULE - PQ 232 COM
    1404-M505A-232-02 1404-M5 MASTER MODULE CLASS 0.2
    1404-M505A-CNT 1404 M5 CONTROLNET PM3000 120/240V P.S.
    1404-M505A-CNT-02 1404-M5 CONTROLNET PM3000 CLASS 0.2 120/240V P.S.
    1404-M505A-DNT MASTER MODULE - PQ DNET COM
    1404-M505A-DNT-02 1404-M5 MASTER MODULE CLASS 0.2
    1404-M505A-ENT 1404-M5 ETHERNET PM3000
    1404-M505A-ENT-02 1404-M5 ETHERNET PM3000 CLASS 0.2
    1404-M505A-RIO MASTER MODULE - PQ RIO COM
    1404-M505A-RIO-02 1404-M5 MASTER MODULE CLASS 0.,2
    1404-M505B-000 MASTER MODULE - PQ 24V P/S
    1404-M505B-000-02 1404-M5 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M505B-232 MASTER MODULE - PQ 24V P/S 232 COM
    1404-M505B-232-02 1404-M5 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M505B-CNT 1404 M5 CONTROLNET PM3000 24V P.S.
    1404-M505B-CNT-02 1404-M5 CONTROLNET PM3000 CLASS 0.2 24V P.S.
    1404-M505B-DNT MASTER MODULE - PQ 24V P/S DNET COM
    1404-M505B-DNT-02 1404-M5 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M505B-ENT 1404-M5 ETHERNET PM3000
    1404-M505B-ENT-02 1404-M5 ETHERNET PM3000 CLASS 0.2
    1404-M505B-RIO MASTER MODULE  - PQ 24V P/S RIO COM
    1404-M505B-RIO-02 1404-M5 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M605A-000 MASTER MODULE            FOR POWERMONITOR
    1404-M605A-000-02 1404-M6 MASTER MODULE CLASS 0.2
    1404-M605A-232 MASTER MODULE            FOR POWERMONITOR
    1404-M605A-232-02 1404-M6 MASTER MODULE CLASS 0.2
    1404-M605A-CNT 1404-M6 CONTROLNET PM3000 120/240V P.S.
    1404-M605A-CNT-02 1404-M6 CONTOLNET PM 3000 CLASS 0.2 120/240V P.S.
    1404-M605A-DNT MASTER MODULE            FOR POWERMONITOR
    1404-M605A-DNT-02 1404-M6 MASTER MODULE CLASS 0.2
    1404-M605A-ENT 1404-M6 ETHERNET PM3000
    1404-M605A-ENT-02 1404-M6 ETHERNET PM3000
    1404-M605A-RIO MASTER MODULE            FOR POWERMONITOR
    1404-M605A-RIO-02 1404-M6 MASTER MODULE CLASS 0.2
    1404-M605B-000 MASTER MODULE - PQ 24V POWER SUPPLY
    1404-M605B-000-02 1404-M6 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M605B-232 MASTER MODULE - PQ 24V POWER SUPPLY 232 COM
    1404-M605B-232-02 1404-M6 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M605B-CNT 1404-M6 CONTROLNET PM3000 24V P.S.
    1404-M605B-CNT-02 1404-M6 CONTROLNET PM3000 CLASS 0.2 24V P.S.
    1404-M605B-DNT MASTER MODULE - PQ 24V POWER SUPPLY DNET COM
    1404-M605B-DNT-02 1404-M6 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M605B-ENT 1404-M6 ETHERNET PM3000
    1404-M605B-ENT-02 1404-M6 ETHERNET PM3000 CLASS 0.2
    1404-M605B-RIO MASTER MODULE - PQ 24V POWER SUPPLY RIO COM
    1404-M605B-RIO-02 1404-M6 MASTER MODULE CLASS 0.2 / 24 VOLT P.S.
    1404-M805A-000 MASTER MODULE-PQ-120/24
    1404-M805A-000-02 MASTER MODULE-PQ-120/240V P/S-CLASS 0.2
    1404-M805A-232 MASTER MODULE-PQ 232 COM-120/240V P/S
    1404-M805A-232-02 MASTER MODULE-PQ 232 COM-120/240V P/S-CLASS0.2
    1404-M805A-CNT 1404-M8 CONTROLNET PM3000 120/240V P.S.
    1404-M805A-CNT-02 1404-8 CONTROLNET PM3000 CLASS 0.2 120/240V P.S.
    1404-M805A-DNT MASTER MODULE-PQ DNET COM-120/240V P/S
    1404-M805A-DNT-02 MASTER MODULE-PQ DNET COM-120/240V P/S-CLASS0.2
    1404-M805A-ENT 1404-M8 ETHERNET PM3000
    1404-M805A-ENT-02  1404-M8 ETHERNET PM3000 CLASS 0.2
    1404-M805A-RIO MASTER MODULE-PQ RIO COM-120/240V P/S
    1404-M805A-RIO-02 MASTER MODULE-PQ RIO COM-120/240V P/S-CLASS0.2
    1404-M805B-000 MASTER MODULE-PQ-24V P/S
    1404-M805B-000-02 MASTER MODULE-PQ-24V P/S-CLASS 0.2
    1404-M805B-232 MASTER MODULE-PQ 232 COM-24V P/S
    1404-M805B-232-02 MASTER MODULE-PQ 232 COM-24V P/S-CLASS 0.2
    1404-M805B-CNT 1404-M8 CONTROLNET PM3000 24V P.S.
    1404-M805B-CNT-02 1404-M8 CONTROLNET PM3000 CLASS 0.2 24V P.S.
    1404-M805B-DNT MASTER MODULE-PQ DNET COM-24V P/S
    1404-M805B-DNT-02 MASTER MODULE-PQ DNET COM-24V P/S-CLASS 0.2
    1404-M805B-ENT MASTER MODULE-PQ ENET COM-24V P/S
    1404-M805B-ENT-02 1404-M8 ETHERNET PM3000 CLASS 0.2
    1404-M805B-RIO MASTER MODULE-PQ RIO COM-24V P/S
    1404-M805B-RIO-02 MASTER MODULE-PQ RIO COM-24V P/S-CLASS 0.2
    1405-DIN MINIPOWERMONITOR DIN RAIL BRACKET
    1405-M610 MINIPOWERMONITOR, 5 AMP INPUTS, 120V
    1405-M610-240 MINIPOWERMONITOR, 5 AMP INPUTS, 240V
    1405-M620 MINIPOWERMONITOR, 1 OR 5 AMP INPUTS, 120V
    1405-M620-120-420 MINIPOWERMONITOR, 6 ANALOG OUTPUTS, 120V
    1405-M620-240 MINIPOWERMONITOR, 1 OR 5 AMP INPUTS, 240V
    1405-M620-240-420 MINIPOWERMONITOR, 6 ANALOG OUTPUTS, 240V
    1405-M620-400 MINIPOWERMONITOR, 1 OR 5 AMP INPUTS, 400V
    1405-M620-400-420 MINIPOWERMONITOR, 6 ANALOG OUTPUTS, 400V
    1405-M620-480 MINIPOWERMONITOR, 1 OR 5 AMP INPUTS, 480V
    1405-PRO MINIPOWERMONITOR PROTECTIVE COVER
    1407-CGCM COMBINATION GENERATOR CONTROL MODULE
    1411-120-102 MODEL 120, 1000:5 RATIO
    1411-120-122 MODEL 120, 1200:5 RATIO
    1411-120-152 MODEL 120, 1500:5 RATIO
    1411-120-162 MODEL 120, 1600:5 RATIO
    1411-120-202 MODEL 120, 2000:5 RATIO
    1411-120-252 MODEL 120, 2500:5 RATIO
    1411-120-302 MODEL 120, 3000:5 RATIO
    1411-120-402 MODEL 120, 4000:5 RATIO
    1411-120-601 MODEL 120, 600:5 RATIO
    1411-120-801 MODEL 120, 800:5 RATIO
    1411-125-102 MODEL 125, 1000:5 RATIO
    1411-125-122 MODEL 125, 1200:5 RATIO
    1411-125-152 MODEL 125, 1500:5 RATIO
    1411-125-162 MODEL 125, 1600:5 RATIO
    1411-125-202 MODEL 125, 2000:5 RATIO
    1411-125-252 MODEL 125, 2500:5 RATIO
    1411-125-302 MODEL 125, 3000:5 RATIO
    1411-125-352 MODEL 125, 3500:5 RATIO
    1411-125-402 MODEL 125, 4000:5 RATIO
    1411-126-102 MODEL 126, 1000:5  RATIO
    1411-126-122 MODEL 126, 1200:5 RATIO
    1411-126-152 MODEL 126, 1500:5  RATIO
    1411-126-162 MODEL 126, 1600:5  RATIO
    1411-126-202 MODEL 126, 2000:5 RATIO
    1411-126-252 MODEL 126, 2500:5  RATIO
    1411-126-302 MODEL 126, 3000:5  RATIO
    1411-126-322 MODEL 126, 3200:5  RATIO
    1411-126-352 MODEL 126, 3500:5  RATIO
    1411-126-401 MODEL 126, 400:5  RATIO
    1411-126-402 MODEL 126, 4000:5  RATIO
    1411-126-501 MODEL 126, 500:5 RATIO
    1411-126-502 MODEL 126, 5000:5  RATIO
    1411-126-601 MODEL 126, 600:5  RATIO
    1411-126-602 MODEL 126, 6000:5  RATIO
    1411-126-801 MODEL 126, 800:5  RATIO
    1411-180RL-101 MODEL 180RL, 100:5 RATIO
    1411-180RL-102 MODEL 180RL, 1000:5 RATIO
    1411-180RL-122 MODEL 180RL, 1200:5 RATIO
    1411-180RL-151 MODEL 180RL, 150:5 RATIO
    1411-180RL-152 MODEL 180RL, RATIO 1500:5
    1411-180RL-162 MODEL 180RL, 1600:5 RATIO
    1411-180RL-201 MODEL 180RL, 200:5 RATIO
    1411-180RL-202 MODEL 180RL, 2000:5 RATIO
    1411-180RL-251 MODEL 180RL, 250:5 RATIO
    1411-180RL-301 MODEL 180RL, 300:5 RATIO
    1411-180RL-401 MODEL 180RL, 400:5 RATIO
    1411-180RL-500 MODEL 180RL, 50:5 RATIO
    1411-180RL-501 MODEL 180RL, 500:5 RATIO
    1411-180RL-601 MODEL 180RL, 600:5 RATIO
    1411-180RL-750 MODEL 180RL, 75:5 RATIO
    1411-180RL-751 MODEL 180RL, 750:5 RATIO
    1411-180RL-801 MODEL 180RL, 800:5 RATIO
    1411-180SHT-101 MODEL 180SHT, 100:5 RATIO
    1411-180SHT-102 MODEL 180SHT, 1000:5 RATIO
    1411-180SHT-122 MODEL 180SHT, 1200:5 RATIO
    1411-180SHT-151 MODEL 180SHT, 150:5 RATIO
    1411-180SHT-152 MODEL 180SHT, RATIO 1500:5
    1411-180SHT-162 MODEL 180SHT, 1600:5 RATIO
    1411-180SHT-201 MODEL 180SHT, 200:5 RATIO
    1411-180SHT-202 MODEL 180SHT, 2000:5 RATIO
    1411-180SHT-251 MODEL 180SHT, 250:5 RATIO
    1411-180SHT-301 MODEL 180SHT, 300:5 RATIO
    1411-180SHT-401 MODEL 180SHT, 400:5 RATIO
    1411-180SHT-500 MODEL 180SHT, 50:5 RATIO
    1411-180SHT-501 MODEL 180SHT, 500:5 RATIO
    1411-180SHT-601 MODEL 180SHT, 600:5 RATIO
北京祥顺达恒有限公司主营产品:美国A-B,罗克韦尔,ALLEN-BRADLEY,ABB,丹佛斯,施耐德,变频器,PLC,压力变送器,温度变送器,SLC500,电磁阀,压力开关,触摸屏,伺服系统,PLC编程软件,组态软件,安全开关,软启动器,松下摄像头. …  更多>>
北京祥顺达恒商贸有限公司
联系人:薛晨
地址:北京市宣武区福长街四条4号213室
邮编:100055
电话:010-63388986
传真:010-51417964
公司网址:http://www.81817979.cn
  • 钟先生 在2015/9/11 11:55:00留言
  • 详细留言:EK2107/70/00/1/10轴位移传感器\EK2107/70/00/1/10\离心压缩机\3BCL459(美国ENTEK)
  • 王力 在2015/3/17 11:01:00留言
  • 邓成阳 在2013/8/21 15:38:00留言
  • 详细留言:您好,我是中科院沈阳计算技术研究所的 想购买AB的PLC CPU SLC500 1747-L543
  • Katrina Koh 在2013/3/12 14:35:00留言
  • 详细留言:Dear Sir/Madam Please quote us your best price for the following item :- (1) Prosoft Modbus Module Unit Model : MVI-94-MCM, REV : B03 Qty : 1 Your earliest reply will be most appreciated. Best Regards Katrina Koh Status Code Sdn Bhd 34A, Jalan Jaya Mas 2 Taman Jaya Mas 81300 Skudai Johor Bahru MALAYSIA Tel : 607-5113800 Fax : 607-5113808
  • clayton 在2012/4/17 18:01:00留言
  • 详细留言:5X 1753-L32BBBM8A 1X 1753-PCSPAR
