龙人旗下深圳市龙芯世纪科技有限公司
  • AT87C51RD2 高性能八位单片机
  • 发布时间:2009/8/11 15:52:38   修改时间:2009/8/11 15:52:38 浏览次数:1304
    Mask ROM (Kbytes) 64
    RAM (Bytes) 1024
    F.max (MHz) 40
    Vcc (V) 2.7—5.5
    I/O Pins 32
    UART 1
    16-bit Timers 3
    Watchdog Yes
    Packages  PDIP 40
    LQFP 64
    LQFP 44
    PLCC 44
    PLCC 68
    Pb-Free Packages    PDIP 40
    LQFP 64
    LQFP 44
    PLCC 44
    PLCC 68
    AT87C51RD2 概述
    Atmel TS8xC51Rx2 is a high performance CMOS ROM, OTP, EPROM and ROMless versions of the 80C51 CMOS single chip 8-bit microcontroller.
    The TS8xC51Rx2 retains all features of the 80C51 with extended ROM/EPROM capacity (16/32/64 Kbytes), 256 bytes of internal RAM, a 7-source , 4-level interrupt system, an on-chip oscilator and three timer/counters.
    In addition, the TS80C51Rx2 has a Programmable Counter Array, an XRAM of 256 or 768 bytes, a Hardware Watchdog Timer, a more versatile serial channel that facilitates multiprocessor communication (EUART) and an X2 speed improvement mechanism.
    The fully static design of the TS80C51Rx2 allows to reduce system power consumption by bringing the clock frequency down to any value, even DC, without loss of data.
    The TS80C51Rx2 has 2 software-selectable modes of reduced activity for further reduction in power consumption. In the idle mode the CPU is frozen while the timers, the serial port and the interrupt system are still operating. In the power-down mode the RAM is saved and all other functions are inoperative.
    AT87C51RD2 特性
    • 80C52 Compatible
      – 8051 pin and instruction compatible
      – Four 8-bit I/O ports
      – Three 16-bit timer/counters
      – 256 bytes scratchpad RAM
    • High-Speed Architecture
      – 40 MHz @ 5V, 30MHz @ 3V
      – X2 Speed Improvement capability (6 clocks/machine cycle)
      – 30 MHz @ 5V, 20 MHz @ 3V (Equivalent to
      – 60 MHz @ 5V, 40 MHz @ 3V)
    • Dual Data Pointer
    • On-chip ROM/EPROM (16K-bytes, 32K-bytes, 64K-bytes)
    • On-chip eXpanded RAM (XRAM) (256 or 768 bytes)
    • Programmable Clock Out and Up/Down Timer/Counter 2
    • Programmable Counter Array with
      – High Speed Output,
      – Compare / Capture,
      – Pulse Width Modulator,
      – Watchdog Timer Capabilities
    • Hardware Watchdog Timer (One-time enabled with Reset-Out)
    • 2 extra 8-bit I/O ports available on RD2 with high pin count packages
    • Asynchronous port reset
    • Interrupt Structure with
      – 7 Interrupt sources,
      – 4 level priority interrupt system
    • Full duplex Enhanced UART
      – Framing error detection
      – Automatic address recognition
    • Low EMI (inhibit ALE)
    • Power Control modes
      – Idle mode
      – Power-down mode
      – Power-off Flag
    • Once mode (On-chip Emulation)
    • Power supply: 4.5-5V, 2.7-5.5V
    • Temperature ranges: Commercial (0 to 70oC) and Industrial (-40 to 85oC)
    • Packages: PDIL40, PLCC44, VQFP44 1.4, PLCC68, VQFP64 1.4
    AT87C51RD2 订购型号
    Part Number Memory size Supply Voltage Temperature Range Max Frequency Package Packing
    AT87C51RD2-3CSUM OTP 64k Bytes 5V Industrial Green 40 MHz (20 MHz X2) PDIL40 Stick
    AT87C51RD2-SLSUM OTP 64k Bytes 5V Industrial Green 40 MHz (20 MHz X2) PLCC44 Stick
    AT87C51RD2-RLTUM OTP 64k Bytes 5V Industrial Green 40 MHz (20 MHz X2) VQFP44 Tray
    AT87C51RD2-3CSUL OTP 64k Bytes 3-5V Industrial Green 30 MHz (20 MHz X2) PDIL40 Stick
    AT87C51RD2-SLSUL OTP 64k Bytes 3-5V Industrial Green 30 MHz (20 MHz X2) PLCC44 Stick
    AT87C51RD2-RLTUL OTP 64k Bytes 3-5V Industrial Green 30 MHz (20 MHz X2) VQFP44 Tray
    AT87C51RD2 技术支持
    1. AT87C51RD2 数据资料 DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
