龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C4051 带有4K系统内可编程Flash存储器
  • 发布时间:2009/8/11 8:41:31   修改时间:2009/8/11 8:41:31 浏览次数:765
    Flash (Kbytes)   4
    RAM (Bytes)   128
    F.max (MHz)   24
    Vcc (V)   2.7-6.0
    I/O Pins   15
    UART   1
    16-bit Timers   2
    Pb-Free Packages    SOIC 20
    PDIP 20
    AT89C4051 概述
    The AT89C4051 is a low-voltage, high-performance CMOS 8-bit microcontroller with 4K bytes of Flash programmable and erasable read-only memory. The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry-standard MCS-51 instruction set. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C4051 is a powerful microcontroller which provides a highly-flexible and cost-effective solution to many embedded control applications.
    The AT89C4051 provides the following standard features: 4K bytes of Flash,128 bytes of RAM, 15 I/O lines, two 16-bit timer/counters, a five-vector, two-level interrupt architecture, a full duplex serial port, a precision analog comparator, on-chip oscillator and clock circuitry. In addition, the AT89C4051 is designed with static logic for operation down to zero frequency and supports two software-selectable power saving modes. The Idle Mode stops the CPU while allowing the RAM, timer/counters, serial port and interrupt system to continue functioning. The power-down mode saves< the RAM contents but freezes the oscillator disabling all other chip functions until the next hardware reset.
    AT89C4051 特性
    • Compatible with MCS?51 Products
    • 4K Bytes of Reprogrammable Flash Memory
      – Endurance: 1,000 Write/Erase Cycles
    • 2.7V to 6V Operating Range
    • Fully Static Operation: 0 Hz to 24 MHz
    • Two-level Program Memory Lock
    • 128 x 8-bit Internal RAM
    • 15 Programmable I/O Lines
    • Two 16-bit Timer/Counters
    • Six Interrupt Sources
    • Programmable Serial UART Channel
    • Direct LED Drive Outputs
    • On-chip Analog Comparator
    • Low-power Idle and Power-down Modes
    • Brown-out Detection
    • Power-On Reset (POR)
    • Green (Pb/Halide-free/RoHS Compliant) Packaging
    AT89C4051 订购型号
    Speed (MHz) Power
    Supply
    Ordering Code Package Operation Range
    12 2.7V to 6.0V AT89C4051-12PC
    AT89C4051-12SC
    20P3
    20S
    Commercial (0°C to 70°C)
    AT89C4051-12PI
    AT89C4051-12SI
    20P3
    20S
    Industrial (-40°C to 85°C)
    24 4.0V to 6.0V AT89C4051-24PC
    AT89C4051-24SC
    20P3
    20S
    AT89C4051-24PI
    AT89C4051-24SI
    20P3
    20S
    12 2.7V to 6.0V AT89C4051-12PU
    AT89C4051-12SU
    20P3
    20S
    24 4.0V to 6.0V AT89C4051-24PU
    AT89C4051-24SU
    20P3
    20S
    AT89C4051 技术支持
    1. AT89C4051 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
