龙人旗下深圳市龙芯世纪科技有限公司
  • ATtiny44A 带有4K系统内可编程Flash存储器
  • 发布时间:2009/8/8 8:59:15   修改时间:2009/8/8 8:59:15 浏览次数:1708
    Flash (Kbytes)   4
    EEPROM (Kbytes)   0.25
    SRAM (Bytes)   256
    Max I/O Pins   12
    F.max (MHz)   20
    Vcc (V)   1.8-5.5
    16-bit Timers   1
    8-bit Timer   1
    PWM (channels)   4
    SPI   USI
    TWI   USI
    ISP   Yes
    10-bit A/D (Channe   8
    Analog Comparator   Yes
    Brown Out Detector   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Interrupts   17
    Ext Interrupts   12
    Self Program Memor   Yes
    Pb-Free Packages  MLF (VQFN) 20
     MLF (WQFN) 20
     PDIP 14
     SOIC (150mil) 14
    4K Bytes of In-System Self-Programmable Flash, 256 Bytes In-System Programmable EEPROM, 256 Bytes Internal SRAM. 8-bit and 16-bit timer/counters with PWM, 10-bit ADC, USI-Universal Serial Interface, On-chip Temperature Sensor. debugWIRE for on-chip-debug. Up to 20 MIPS throughput at 20 MHz. 1.8 - 5.5V operation.
    ATtiny24A/44A are low-power CMOS 8-bit microcontrollers based on the AVR enhanced RISC
    architecture. By executing powerful instructions in a single clock cycle, the ATtiny24A/44A
    achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize
    power consumption versus processing speed.
    ATtiny44A 特性
    • ? High Performance, Low Power AVR? 8-Bit Microcontroller
      ? Advanced RISC Architecture
      – 120 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      ? High Endurance, Non-Volatile Memory Segments
      – 2K/4K Bytes of In-System, Self-Programmable Flash Program Memory
      ? Endurance: 10,000 Write/Erase Cycles
      – 128/256 Bytes of In-System Programmable EEPROM
      ? Endurance: 100,000 Write/Erase Cycles
      – 128/256 Bytes of Internal SRAM
      – Data retention: 20 years at 85°C / 100 years at 25°C
      – Programming Lock for Self-Programming Flash & EEPROM Data Security
      ? Peripheral Features
      – One 8-Bit and One 16-Bit Timer/Counter with Two PWM Channels, Each
      – 10-bit ADC
      ? 8 Single-Ended Channels
      ? 12 Differential ADC Channel Pairs with Programmable Gain (1x / 20x)
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-Chip Analog Comparator
      – Universal Serial Interface
      ? Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – Internal and External Interrupt Sources
      ? Pin Change Interrupt on 12 Pins
      – Low Power Idle, ADC Noise Reduction, Standby and Power-Down Modes
      – Enhanced Power-on Reset Circuit
      – Programmable Brown-Out Detection Circuit with Software Disable Function
      – Internal Calibrated Oscillator
      – On-Chip Temperature Sensor
      ? I/O and Packages
      – Available in 20-Pin QFN/MLF & 14-Pin SOIC and PDIP
      – Twelve Programmable I/O Lines
      ? Operating Voltage:
      – 1.8 – 5.5V
      ? Speed Grade:
      – 0 – 4 MHz @ 1.8 – 5.5V
      – 0 – 10 MHz @ 2.7 – 5.5V
      – 0 – 20 MHz @ 4.5 – 5.5V
      ? Industrial Temperature Range: -40°C to +85°C
      ? Low Power Consumption
      – Active Mode:
      ? 210 μA at 1.8V and 1MHz
      – Idle Mode:
      ? 33 μA at 1.8V and 1MHz
      – Power-Down Mode:
      ? 0.1 μA at 1.8V and 25°C
      8-bit
      Microcontroller
      with 2K/4K
      Bytes In-System
      Programmable
      Flash
      ATtiny24A
      (Preliminary)
      ATtiny44A
    ATtiny44A 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    20 1.8 - 5.5V ATtiny44A-SSU
    ATtiny44A-PU
    ATtiny44A-MU
    ATtiny44A-MMH
    14S1
    14P3
    20M1
    20M2
    Industrial (-40°C to 85°C)
    ATtiny44A 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATtiny44A 数据手册DataSheet 下载. PDF (简洁版)
    2. ATMEL 爱特梅尔AVR 微控制器ATtiny44A 数据手册DataSheet 下载. PDF (完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
