龙人旗下深圳市龙芯世纪科技有限公司
  • ATtiny43U 带有4K系统内可编程Flash存储器
  • 发布时间:2009/8/8 8:58:38   修改时间:2009/8/8 8:58:38 浏览次数:1678
    Flash (Kbytes) 4
    EEPROM (Kbytes) 0.0625
    SRAM (Bytes) 256
    Max I/O Pins 16
    F.max (MHz) 8
    Vcc (V) 0.7 - 1.8
    10-bit A/D Channels 4
    Analog Comparator Y
    8-bit Timer 2
    Brown Out Detector Y
    Ext Interrupts 17
    Interrupts 16
    ISP Y
    PWM Channels 4
    SPI Y
    Watchdog Y
    Pb-Free Packages MLF (WQFN) 20
    SOIC (300mil) 20
    4-Kbyte In-System programmable Flash Program Memory, 256-Byte SRAM, 64-Byte EEPROM, 32-Byte Register File, Two 8-bit Timer/Counters with PWM channels, 4-channel 10-bit A/D, Analog Comparator, Temperature Sensor, USI-Universal Serial Interface, and debugWIRE for on-chip-debug. Up to 1 MIPS throughput per MHz.
    The ATtiny43U is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny43U achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATtiny43U 特性
    • ? High Performance, Low Power AVR? 8-Bit Microcontroller
      ? Advanced RISC Architecture
      – 120 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      ? Non-Volatile Program and Data Memories
      – 4K Bytes of In-System Programmable Program Memory Flash
      – 64 Bytes of In-System Programmable EEPROM
      – 256 Bytes of Internal SRAM
      – Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM
      – Data retention: 20 years at 85°C/ 100 years at 25°C(1)
      – Programming Lock for Software Security
      ? Peripheral Features
      – Two 8-Bit Timer/Counters with two PWM Channels, Each
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-Chip Analog Comparator
      – 10-bit ADC
      4 Single-Ended Channels
      – Universal Serial Interface
      – Boost Converter
      ? Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – External and Internal Interrupt Sources
      – Pin Change Interrupt on 16 Pins
      – Low Power Idle, ADC Noise Reduction and Power-Down Modes
      – Enhanced Power-On Reset Circuit
      – Programmable Brown-Out Detection Circuit
      – Internal Calibrated Oscillator
      – Temperature Sensor On Chip
      ? I/O and Packages
      – Available in 20-Pin SOIC and 20-Pin QFN/MLF
      – 16 Programmable I/O Lines
      ? Operating Voltage:
      – 0.7 – 1.8V (via On-Chip Boost Converter)
      – 1.8 – 5.5V (Boost Converter Bypassed)
      ? Speed Grade
      – Using On-Chip Boost Converter
      0 – 4 MHz
      – External Power Supply
      0 – 4 MHz @ 1.8 – 5.5V
      0 – 8 MHz @ 2.7 – 5.5V
      ? Low Power Consumption
      – Active Mode, 1 MHz System Clock (Without Boost Converter)
      400 μA @ 3V
      – Power-Down Mode (Without Boost Converter)
      150 nA @ 3V
    ATtiny43U 相关订购信息
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    8 1.8 - 5.5V ATtiny43U-MU
    ATtiny43U-SU
    20M1
    20S2
    Industrial (-40°C to 85°C)
    ATtiny43U 技术支持
    1. ATtiny43U 数据手册DataSheet 在线下载(简洁版)
    2. ATtiny43U 数据手册DataSheet 在线下载(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF
    4. 面向新手的AVR开发工具,及基本知识.PDF
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
