龙人旗下深圳市龙芯世纪科技有限公司
  • ATtiny28L 带有2K系统内可编程Flash存储器
  • 发布时间:2009/8/8 8:58:05   修改时间:2009/8/8 8:58:05 浏览次数:1705
    Flash (Kbytes)   2
    SRAM (Bytes)   32
    Max I/O Pins   11
    F.max (MHz)   4
    Vcc (V)   1.8-5.5
    8-bit Timer   1
    Analog Comparator   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Interrupts   5
    Ext Interrupts   2(+8)
    Packages   TQFP 32
    MLF 32
    PDIP 28
    2K Flash Program Memory, 32 bytes register file, Keyboard interrupt, high-current LED driver, Analog Comparator. Up to 4 MIPS throughput at 4 MHz.
    The fast-access register file concept contains 32 x 8-bit general-purpose working registers with a single clock cycle access time. This means that during one single clock cycle,one ALU (Arithmetic Logic Unit) operation is executed. Two operands are output from the register file, the operation is executed, and the result is stored back in the register file – in one clock cycle.Two of the 32 registers can be used as a 16-bit pointer for indirect memory access. This pointer is called the Z-pointer and can address the register file and the Flash program memory.
    ATtiny28L 特性
    • Utilizes the AVR? RISC Architecture
    • AVR – High-performance and Low-power RISC Architecture
      – 90 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General-purpose Working Registers
      – Up to 4 MIPS Throughput at 4 MHz
    • Nonvolatile Program Memory
      – 2K Bytes of Flash Program Memory
      – Endurance: 1,000 Write/Erase Cycles
      – Programming Lock for Flash Program Data Security
    • Peripheral Features
      – Interrupt and Wake-up on Low-level Input
      – One 8-bit Timer/Counter with Separate Prescaler
      – On-chip Analog Comparator
      – Programmable Watchdog Timer with On-chip Oscillator
      – Built-in High-current LED Driver with Programmable Modulation
    • Special Microcontroller Features
      – Low-power Idle and Power-down Modes
      – External and Internal Interrupt Sources
      – Power-on Reset Circuit with Programmable Start-up Time
      – Internal Calibrated RC Oscillator
    • Power Consumption at 1 MHz, 2V, 25°C
      – Active: 3.0 mA
      – Idle Mode: 1.2 mA
      – Power-down Mode: <1 μA
    • I/O and Packages
      – 11 Programmable I/O Lines, 8 Input Lines and a High-current LED Driver
      – 28-lead PDIP, 32-lead TQFP, and 32-pad MLF
    • Operating Voltages
      – VCC: 1.8V - 5.5V for the ATtiny28V
      – VCC: 2.7V - 5.5V for the ATtiny28L
    • Speed Grades
      – 0 - 1.2 MHz for the ATtiny28V
      – 0 - 4 MHz For the ATtiny28L
    ATtiny28L 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operation Range
    4 2.7 - 5.5 ATtiny28L-4AC
    ATtiny28L-4PC
    ATtiny28L-4MC
    32A
    28P3
    32M1-A
    Commercial (0°C to 70°C)
    ATtiny28L-4AI
    ATtiny28L-4AU 无铅环保封装
    ATtiny28L-4PI
    ATtiny28L-4PU 无铅环保封装
    ATtiny28L-4MI
    ATtiny28L-4MU 无铅环保封装
    32A
    32A
    28P3
    28P3
    32M1-A
    32M1-A
    Industrial (-40°C to 85°C)
    12 1.8 - 5.5 ATtiny28V-1AC
    ATtiny28V-1PC
    ATtiny28V-1MC
    32A
    28P3
    32M1-A
    ATtiny28V-1AI
    ATtiny28V-1AU 无铅环保封装
    ATtiny28V-1PI
    ATtiny28V-1PU 无铅环保封装
    ATtiny28V-1MI
    ATtiny28V-1MU 无铅环保封装
    32A
    32A
    28P3
    28P3
    32M1-A
    32M1-A
    ATtiny28L 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATtiny28L 数据手册DataSheet 下载. PDF
    2. ATMEL 爱特梅尔半导体公司产品线. PDF (编号:Atmel Products)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
