龙人旗下深圳市龙芯世纪科技有限公司
  • ATMEL 爱特梅尔CAN网络
  • 发布时间:2007/4/1 15:22:51   修改时间:2009/2/27 15:15:37 浏览次数:2648
  • ATMEL 爱特梅尔CAN网络
  • 首页ATMEL 爱特梅尔CAN网络
    CAN网络
    CANary 的8位Flash 微控制器将Atmel(r) 先进的Flash技术与知名的80C51 功能相结合。高度灵活的自编程的能力提供了远程程序和现场升级的可能性。 充分兼容V2.0A 和V2.0B 标准, CAN控制器在空闲时使独立消息对象可编程。Atmel 设备支持CANopen, DeviceNet(tm) 与OSEK(tm) 的实现,完全适用于工业和汽车应用。
    CAN网络
    - 8051-based Microcontroller
    - AVR-based Microcontroller
    AT91系列单片机产品参数表 CAN网络系列产品参数表
    设备 描述
    AT89C51CC03 8-bit microcontroller with CAN controller and 64-Kbyte Flash. 2-Kbyte RAM 2-Kbyte EEPROM SPI. Power Fail Detect (no need for external brown- out). Pinout compatible with T89C51CC01. The AT89C51CC03 is also available in Automotive Quality grade.
    AT89C51CC01 T89C51CC01
    8-bit microcontroller with CAN controller and 32- Kbyte Flash We recommend to implement an external brown out to prevent any Flash/EEPROM corruption during power-on or power-off. Please refer to related application note: External Brown-out Protection for C51 Microcontrollers with Active High Reset Input
    AT89C51CC02 T89C51CC02
    Low pin count 8-bit microcontroller with CAN controller and 16-Kbyte Flash We recommend to implement an external brown out to prevent any Flash/EEPROM corruption during power-on or power-off. Please refer to related application note: External Brown-out Protection for C51 Microcontrollers with Active High Reset Input
    设备 描述
    AT90CAN128 8-bit AVR Microcontroller with 128K Bytes of ISP Flash and CAN Controller. V2.0A and V2.0B standard compliant the CAN controller handles independent message objects programmable on-the-fly. Perfectly suited for Industrial and Automotive applications the microcontroller support CANopen DeviceNet?and OSEK?implementation. Automotive Version: AT90CAN128 Automotive
    AT90CAN128 AVR-CAN总线 带128k ISP FLASH存储器和CAN控制器的8 bit AVR微控制器,V2.0A和V2.0B标准兼容,能处理15个独立信息块,适合工业和汽车应用订购型号: AT90CAN128-16MU ,AT90CAN128-16AU
    AT90CAN32 8-bit AVR Microcontroller with 32K Bytes of ISP Flash and CAN Controller. V2.0A and V2.0B standard compliant the CAN controller handles independent message objects programmable on-the-fly. Perfectly suited for Industrial applications the microcontroller support CANopen DeviceNet?and OSEK?implementation.
    AT90CAN64 8-bit AVR Microcontroller with 64K Bytes of ISP Flash and CAN Controller. V2.0A and V2.0B standard compliant the CAN controller handles independent message objects programmable on-the-fly. Perfectly suited for Industrial applications the microcontroller support CANopen DeviceNet?and OSEK?implementation.
    CAN网络系列产品参数表
    设备 CAN (mess. Obj.) Flash (Kbytes) EEPROM (Kbytes) SRAM (Bytes) F.max (MHz) Vcc (V) Max I/O Pins 10-bit A/D (channels) 16-bit Timers UART ISP 封装 绿色封装
    AT89C51CC01
    T89C51CC01
    15 32 2 1.2K 40 3-5.5 - 8 2 1 Yes LQFP 44 Plastic J-Lead 44 CBGA 64 LQFP 44 Plastic J-Lead 44 CBGA 64
    AT89C51CC02
    T89C51CC02
    4 16 2 512 40 3-5.5 - 8 1 1 Yes LQFP 32 Plastic J-Lead 28 Narrow SOIC 24 Narrow SOIC 28 LQFP 32 Plastic J-Lead 28 Narrow SOIC 24 Narrow SOIC 28
    AT89C51CC03 15 64 2 2.2K 40 3-5.5 - 8 2 1 Yes LQFP 64 LQFP 44 Plastic J-Lead 52 Plastic J-Lead 44 CBGA 64 LQFP 64 LQFP 44 Plastic J-Lead 52 CBGA 64
    AT90CAN128 15 128 4 4K 16 2.7-5.5 53 8 2 2 Yes MLF 64 LQFP 64 MLF 64 LQFP 64
    AT90CAN32 15 32 1 2048 16 2.7-5.5 53 8 2 2 Yes MLF 64 LQFP 64 MLF 64 LQFP 64
    AT90CAN64 15 64 2 4096 16 2.7-5.5 53 8 2 2 Yes MLF 64 LQFP 64 MLF 64 LQFP 64
    CANary 的8位Flash 微控制器将Atmel(r) 先进的Flash技术与知名的80C51 功能相结合。高度灵活的自编程的能力提供了远程程序和现场升级的可能性。充分兼容V2.0A 和V2.0B 标准, CAN控制器在空闲时使独立消息对象可编程。Atmel 设备支持CANopen, DeviceNet(tm) 与OSEK(tm) 的实现,完全适用于工业和汽车应用。
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
