2016年Waddington工厂上海航欧中国区销售
上海航欧销售Waddington变速循环控制单元Waddington传感器Waddington超声波传感器Waddington开关 Waddington电源,Waddington控制器,Waddington动力控制
主要型号:Waddington开关PSPCB10000
PSPCB10000-BIN
PSENC10000
PSENC10031
PSENC10032
PSENC10009
Waddington电源 PSENC10010
PSENC10000-NE
PSENC10001
PSENC10021
PSENC10035
PSENC50002
PCDIO10003
PCDIO10008
PCDIO10000
PCDIO10008
PCDIO10003
PCDIO10000
STTOPLIMIT1
STTOPLIMIT2
STBOTTOMLIMIT1
STBOTTOMLIMIT2
ST2NDTOPLIMIT
ST2NDBOTTOMLIMI
PSCBL70012
PSCBL70006
PSCBL70008
PSCBL70013
PSCBL70014
PSCBL70019
PSCBL70015
WESTAMRSH2R1
WESTAMRSH2R2
WESTAMRSH2R2SST
WESTAMRSH3
WESTAMRSH2R1H
WESTAMRSH2R2H
WESTAMRSH2FG
WESTAMRSH2R1H
WESTAMRSH2R2HFG
WESTASSH1
WESTASSH2
STHEADsonatrolheadoptionsExtrasensors
WESTAMRSH2R1mrsh-2/r15in-20ftsonarsensor3800
WESTAMRSH2R2mrsh-2/r218in-20ftsonarsenso3800
WESTAMRSH2R2SSTmrsh-2/r218in-20ftsstransdu5500
WESTAMRSH3sonatrolsensorwithdual7700
WESTAMRSH2R1Hr1sensorw/hornN8800
WESTAMRSH2R2Hr2sensorw/hornN8800
WESTAMRSH2FGmrsh-2fgsensorr2fixedgain0000
WESTAMRSH2R2HFGr2sensorw/hornandfixedgainN2000
WESTASSSH1 r-1 stainless steel sensor 7500
WESTASSSH2
r-2 stainless steel sensor 7500
STWESTA30FT st6z mods for 30 ft range Range Mods
WESTA30FT st6z mods for 30 ft range 000
STWESTAAOAB air output a/b option
WESTAAOAB air output a / b selec switch $ -
STWESTAAUTO/MAN auto manual out put option
WESTAAUTO/MAN auto/manual selector switch $ -
STWESTAF/V1 freq to voltage option
WEEZAFV1 f/v-1 frequency to voltage oe Y $ -
STWESTAGUIDE001 sensor guide adjust able
width call
WESTASTANDWH1 stand-wh sensor stand w/wheels N
3000
STWESTAMTRSEL dc motor sel a/b contactor
WESTAMTRSEL dc motor sel a/b contactor 5000
STWESTAUTF1 upper time filter option
WESTAUTF1 utf-1 upper time filter option $ -
STWEST/F1 voltage to frequecny option
PSMDL04 v/f-1 voltage to frequency $ -
WESTAQCON Sensor Head quick connector $ -
STWESTAMUX2 option analog multiplier
WESTAMUX2 mux-2 analog multiplier option 8900
STWESTAHVAO1 option 0-90v dc output
WESTAHVAO1 hvao-1 0-90vdc output option 2500
STWESTAJOG option jog option
WESTAJOG jog pushbutton option $ -
STWESTALFO1 option ac line filter
WESTALFO1 lfo-1 ac line filter option 500
STWESTATAP1 option percent taper option
WESTATAP1 tap-1 percent taper option 1800
STWESTATW1 option limit thumbwheel setpoi
WESTATW1 thumbwheel set point pot 5000
STWESTARP1 option remote distance pot
WESTARP1 rp-1 10 turn remote distance 000
STWESTARP2 option remote gain pot
WESTARP2 rp-2 ten turn remote gain 000
STWESTARP3 option remote speed on output
WESTARP3 option remote speed on output 000
STWESTAPT1 option payoff/takeup switch
WESTAPT1 payout take up switch option 500
STWESTAFR1 option forward reverse switch
WESTAFR1 fr-1 forward-reverse switch 500
STWESTAMAO20 option 4-20 ma output current loop optput
WESTAMAO20 mao-20 4-20ma output option 6600
STWESTAMAO10 option 0-10 ma output
WESTAMAO10 mao-10 0-10ma output option 6600
STWESTABOB1 option 12 bit binary output 12 bit binary output
WESTABOB1 bob-1 12bit binary output 5000
STWESTASY2M option sy2 sequencer(master
op Sequencer for 2 units operating close
together
WESTASY2M sy2-m sy-2 sequencer master 5000 master
STWESTASYS option sle option
WESTASYS sy-s sle option 000 sle
STWESTASY8 option sy8 sequencer
WESTASY8 sy-8 8 unit sequencing option 6000 8 CH sequencer for up to 8 units close
together
STWESTASTAND1 option sensorhead stand
WESTASTAND1A stand-1 sensor head stand N 0900
Sensor Stands
WESTASTAND10 stand with spool guide N $ -
WESTASTAND1B sensor head stand with guides N $
STWESTASTANDWH1
8200
STWESTARAAC1 cable adapter rapid air
raac1 Adapter Cables for other OEM
equipment
WESTARAAC1 raac-1 5 pin rapid adapter 000
STWESTARAAC2 option 15 pin rapidair cable
WESTARAAC2 raac-2 V2 rapid air adapter 500
STWESTARAAC2J option 15 pin rapidair cable
WESTARAAC2J raac-2j rapid air adapter 0000
STWESTAGOODMAN1 option cable to goodman cutter
WESTAGOODMAN1 goodman cutter adapter 15
ft 000
STWESTARAAC3 option d shell rapidair connec
WESTARAAC3 rapid air d-shell adapter 500
STWESTADIV2 option analog divider
WESTADIV2 div-2 analog divider option 0000
STWESTABSO1 option base speed option
WESTABSO1 bso-1 base speed option 7500
STWESTAAOM1 option anolog meter output meters
WESTAAOM2 analog meter 0-90 vdc $ -
WESTAAOM1 aom-1 analog output meter+-15 0000
STWESTADMS1 option digital display
WESTADMS1 dms-1 digital display 9900
STWESTAEAO1 option extra analog output Extra analog outputs
WESTAEAO1 eoa-1 normal extra analog 5000
STWESTAEAON1 option extra analog output inv
WESTAEAON1 eaon-1 inverted extra analog 5000
STWESTADUAL option relay for dual sensor o
WESTADUAL relay option for dual heads 6500 Relay for 2nd sensor switchable
STWESTATOGGLE option on off toggle switch
WESTATOGGLE on/off toggle switch option 500 on off power switch
STWESTASUM3 option line speed summing
WESTASUM3 sum-3 3input summing amplifier 7600 Summing input
STWESTATC6 option tension control(auto/ma
WESTATC6 tc-6 tension control option 0000
STWESTADF1 option dust filter option Dust filter for sensor
WESTADF1 df-1 dust filter for 500
STWESTAPID2 option pid output
WESTAPID2 pid2 output option 6500 PID Output
STWESTAONOFF two setpoint on off control
WESTAONOFF 2-set point on/off relay 500 dual setpoint On/Off relay
WEPTAONOFFNS
WEPTAPT1LSA
WEPTAPT1-1
PTTOPLIMIT
WEPTATL1
PTBOTTOMLIMIT
WEPTABL1
PTSTAND
WEPTASTAND
PTWESTAEXTBASE
WESTAEXTBASE
STWESTAMAO20
WESTAMAO20
STWESTAMAO10
WESTAMAO10
STWESTARAAC1
WESTARAAC1
STWESTARAAC2
WESTARAAC2
STWESTARAAC2J
WESTARAAC2J
STWESTARAAC3
WESTARAAC3
STWESTASUM3
WESTASUM3
PSOSDA10003
PSENC10032-PT
PSDRV10001-PT
PSDRV10002-PT
PSSPR10000
PSPTA10006
PSOPR10001
PTTOPLIMIT
WEPTATL1
PTBOTTOMLIMIT
WEPTABL1
PTSTAND
WEPTASTAND
STWESTAF/V1
WEEZAFV1
PTWESTAEXTBASE
WESTAEXTBASE
STWESTAMAO20
WESTAMAO20
STWESTAMAO10
WESTAMAO10
STWESTARAAC1
WESTARAAC1
STWESTARAAC2
WESTARAAC2
STWESTARAAC2J
WESTARAAC2J
STWESTARAAC3
WESTARAAC3
STWESTAAOM1
WESTAAOM2
WESTAAOM1
STWESTASUM3
WESTASUM3
2016年Waddington工厂上海航欧中国区销售1017A-GBP 现货查询上海航欧 SFERAX
DP1-RJ45-R-24LS 现货查询上海航欧 MENCOM
CEV582M-20009 现货查询上海航欧 TR
RI-58D/10EF.49KD 现货查询上海航欧 0532568 HENGSTLER
8KB-052-1 现货查询上海航欧 DESTACO
14001020 现货查询上海航欧 SOCOMEC
HB031LK 现货查询上海航欧 CONTRAVES
LS-G02-2cA-25-EN-645 现货查询上海航欧 DAIKIN
02041-216015 现货查询上海航欧 Norelem
MT500SH 现货查询上海航欧 M+S
AKR 50 B420L 现货查询上海航欧 LEM
RF 1005-SG5 现货查询上海航欧 Rasmi
202-U 现货查询上海航欧 DESTACO
8MB-055-1 D-61440 现货查询上海航欧 DESTACO
VDLI-1S11/Ex 现货查询上海航欧 9150/1 VSE
D2532KL0 现货查询上海航欧 DYNAMCO
PVSE 230/24-10 现货查询上海航欧 BLOCK
PVSE 400/24-40 现货查询上海航欧 BLOCK
CEW58M-00165 现货查询上海航欧 CEW582M-10165 TR
