  • WOHRLE航欧 USVWISUS-M(360-480kVA)
  • 发布时间:2025/10/8 11:00:18   修改时间:2025/10/8 11:00:18 浏览次数:51
  •  2023WOHRLE工厂授权上海航欧中国区代理
    上海航欧销售WOHRLE电源选型、WOHRLE单相电源选型WOHRLE不间断电源选型WOHRLE模块选型、WOHRLE继电器选型、WOHRLE开关选型根据客户需要提供系统定制解决方案
    WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
    主要型号:
    ATS2-440-11-400MS224009PH120-1306EPH231506AV3-220-06-300ANKA-V3-220-06-300MS2-240-09-11-201AV3-220-06-300WOHRLE航欧 WISUS-K-6主轴驱动
     WOHRLE航欧 AKKU-SYS24180S
     WOHRLE航欧 SW-200-01
     WOHRLE航欧 DPNW2420
     WOHRLE航欧 Profibus-ConverteralsErg?nzungzumCS121-SCM;
     WOHRLE航欧 DB-14C/SK2/PC/203/UB
     WOHRLE航欧 USVWISUS-K(6-20kVA)
     WOHRLE航欧 RS232-Kabel,9-polig
     WOHRLE航欧 EPNSW240588-264VAC/24-28VDC5A
     WOHRLE航欧 UGVC2412超级电容
     WOHRLE航欧 EPNW2404
     WOHRLE航欧 EDI-RED20UE?0,5V
     WOHRLE航欧 DPNW2440
     WOHRLE航欧 SNMP-AdapterCS121BudgetUniversal-Box
     WOHRLE航欧 EPNW2405
     WOHRLE航欧 UGV-LI2402
     WOHRLE航欧 BE2405CY
     WOHRLE航欧 EPNW1202
     WOHRLE航欧 CS-121-SPI-2显示器和LCD显示器
     WOHRLE航欧 UGVC2420超级电容
     WOHRLE航欧 USVWISUS-M(25-480kVA)
     WOHRLE航欧 Tiefentladeschutzbis100VDC
     WOHRLE航欧 EPN233020/N
     WOHRLE航欧 STS16
     WOHRLE航欧 DPNW2410
     WOHRLE航欧 SNMP-AdapterCS121SlotProfessionalmitModbus
     WOHRLE航欧 AV4-240-06-100高压电源
     WOHRLE航欧 EPNSW240185-264VAC/21,6-26,4VDC1A
     WOHRLE航欧 SNMP-AdapterCS121BudgetSlot
     WOHRLE航欧 EPNSW240285-264VAC/24-30VDC2,5A
     WOHRLE航欧 ZPNW2405
     WOHRLE航欧 AV3-220-06-300温度控制器
     WOHRLE航欧 Entkoppeldiode
     WOHRLE航欧 CS-121-BL编码器
     WOHRLE航欧 BE2405CY2429V
     WOHRLE航欧 CONVERTVT1
     WOHRLE航欧 EPNW240332430Ue=690VUimp=8kvLu=25A50/510HzIEC60439-1
     熔断器开关WOHNER160ALTS-00
     液晶面板WOHRLEANKANr.:ATS2-440-06-11-400SN:PN-100C0.4/3.090.75AMP
     电源WOHRLEMP1001050364整流电源NGI402430Prim:3*400+5%1-3A
     DISPLAYWOHRLEMP6121103022100COMMUNICATIONWITHPROCESSOR
     备件WOHRLEEU-ANW-WD1/230230VS-NYH60146
     配件WOHRLEANKAG50173AN:AV3-220-06-30024VDC0.4AVERS50.2
     显示器WOHRLEMBF2-14C-21111100
     操作显示屏WOHRLEANKAARTNR:AV3-220-06-30
     显示器WOHRLEANKAART:AV3-240-06-300SN:K5.000424DC
     操作箱WOHRLEANKAART.NR:ATS2-440-06-11-400SN:PN-10024VDC0.75AMP
     配件WOHRLE21235DC24V20A继电器
     备件WOHRLETPYE:ANKAARTNR:AV3-220-06-300SERNR:M50012
     显示器WOHRLEANKAR4-02224VDC0.40AArtNO:AV3-220-06-300
     显示器WOHRLEMC-09/SK2L-103序列号:10156
     显示器WOHRLEATS2-440-06-11-400815-057-21
     upsWOHRLE71144steinenbronnUNG402420prim3*400V±5%(A)
     显示器WOHRLECB-09/SK2L-303ser-nr.K8-09290-260VAC
     文本显示器WOHRLEAV3-220-06-300E6000424V/DC0.4AE0.2文本显示器
     显示屏WOHRLEDB5-14C-3525AA-0221000SERNO:G8-008230V50/60HZ
     显示屏WOHRLEDM-14C/SK20PCSERNO:12344/15220VAC50/60HZ显示屏
     配件WOHRLE21295DC24V20A继电器
     传感器WOHRLETYPE:ANKAARTNR:AV3-200-06-30024VDC
     光学传感器WOLF&BECKOTM3A-20
     光学传感器WOLF&BECKOTM3A-50
     备件WOLFERD315M-4B
     备件WOLFERD180L-4
     备件WOLFERD112M-4
     电机WOLFERDRKO200L-4B/SFB16HT30KWSN:156476
     WOHRLE航欧 KA-USV-Typ01
     WOHRLE航欧 DPN402480/W
     WOHRLE航欧 DB5-1211AA-0221000CPU和处理器
     WOHRLE航欧 CS-121-SC图表记录
     WOHRLE航欧 BP/CON6k电子离合器,刹车模块
     WOHRLE航欧 CS-121-Mini计时器
     WOHRLE航欧 USVWISUS-M(25-320kVA)
     WOHRLE航欧 wandeltMODBUSinProfibus
     WOHRLE航欧 EPNW2410
     WOHRLE航欧 EDI402128V
     WOHRLE航欧 AV3-240-06-100
     WOHRLE航欧 Akkumulatoren-Systembestehendaus2Akkumulatoren12V/18Ah,Halterung,Sicherung40A
     WOHRLE航欧 AV3-240-09-300
     WOHRLE航欧 EPNSW4810
     WOHRLE航欧 WISUS-K-20
     WOHRLE航欧 ZPNW2420
     WOHRLE航欧 SW-100-01100A9,1VDC
     WOHRLE航欧 CONVERT19KIT
     WOHRLE电源 DB-12/SK2L/CP/200流量计
     WOHRLE电源 USR24402129V
     WOHRLE电源 überwachungs-undSteuerbaugruppefür24VDCUSV-Anlagen
     WOHRLE电源 UGVCM2420-100超级电容
     WOHRLE电源 CP526CP581DB06WF470
     WOHRLE电源 USVWISUS-G(30-120kVA)
     WOHRLE电源 CONVERTVT3
     WOHRLE电源 WISUS-K-10电子离合器,刹车模块
     WOHRLE电源 EntkoppeldiodemitEingangsüberwachung
     WOHRLE电源 SW-50-0150A9,1VDC
     WOHRLE电源 AS2-440-06-11-00-00矢量驱动
     WOHRLE电源 USVWISUS-M(25-480kVA)
     WOHRLE电源 CONVERTVT6
     WOHRLE电源 EPNSW240488-264VAC/24-30VDC4A
     WOHRLE电源 MO12TC/20/U电源
     WOHRLE电源 BS2-240-09-111-400HVAC控制系统
     WOHRLE电源 CS-121-SCM模拟和数字电路板
     WOHRLE电源 AV3-240-06-101数控机床控制
     WOHRLE电源 EPNW2420
     WOHRLE电源 EPNSW241088-264VAC/24-28VDC10A
     WOHRLE电源 AV3-240-09-101离合器和制动器
    上海航欧销售WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
     ST-B8 1/2 316SS 0.7MPA 012A 80        现货查询上海航欧                            KTM
    215205U1-10BL-L200      现货查询上海航欧                            LINCOLN
    No.2P magnet 现货查询上海航欧                            SANTEST
    AS-1 DN50 PN16 length125mm  现货查询上海航欧                            STENFLEX
    1222B       现货查询上海航欧                            SFERAX
    21-212B3/100 现货查询上海航欧                            HOHNER
    VA500AE1-3-10-39-120-50-60 现货查询上海航欧                            HUMPHREY
    TMEQ-50-30K  现货查询上海航欧                            TAC GIKEN
    HS3510248446B7    现货查询上海航欧                   HS35R102484P7      DYNAPAR
    223-12270-9    现货查询上海航欧                            LINCOLN
    PRSU/4  24v   现货查询上海航欧                            TAPESWITCH
    GYCAT4-2210-BD-M-CN 更新型号:GYcAT4-2210-S/S-M-M2P-CN-BD        现货查询上海航欧         (same as S/N:127606)              SANTEST
    GYSE-A-650-M-CN-BD/N-MO  现货查询上海航欧                   GYSE-A-650-100/S-M-AW-CN-BD/N-M0 SANTEST
    68578800         现货查询上海航欧                            MADLER
    AES-R        现货查询上海航欧                   AES-N       ASA-RT
    68541500         现货查询上海航欧                            MADLER
    STR1001SG1M90P01       现货查询上海航欧                            MP-FILTRI
    68578100         现货查询上海航欧                            MADLER
    ATB-PE100/1000/ASNN   现货查询上海航欧                            ASA-RT
    EPDM DN150  现货查询上海航欧         108999              GHIBSON
    C16W00000  TX050恒温器配件 XR03CX-PVRC3  LIFMBXB5AC          现货查询上海航欧                            TEXA
    NP1-628AB-M 现货查询上海航欧         083686              EUCHNER
    2755         现货查询上海航欧         027550169                SCHRADER
    CLS-40      现货查询上海航欧         322556     320404     BEDIA
    X20A6-CN         现货查询上海航欧         3222219            PIAB VACUUM
    KF32RF1-D15   现货查询上海航欧                   KF32RF2-D15   KRACHT
    HT-400-S-J        现货查询上海航欧                            AMCI
    ETN-40    现货查询上海航欧                            TECNINT HTE
    AS 12/60  现货查询上海航欧                            METO-FER
    ST-11G-3B-U2X         现货查询上海航欧                            METO-FER
    44D30-01-2-AJS        现货查询上海航欧                            GRAYHILL
    BMC-332A        现货查询上海航欧                            C-TEK
    ALP1-D-3 现货查询上海航欧                            MARZOCCHI
    TOP-2MY750-210HBMVB AC380V/50HZ         现货查询上海航欧                            NIPPON
    URG4/10 现货查询上海航欧                            WAIRCOM
    PGP511A0080AS1Q4NJ7J5B1B1    现货查询上海航欧         3349112275              PARKER
    K63 A10 T12 135° 现货查询上海航欧                   V 63.1 BR3 A10 T12 135°     TUNKERS
    K50 A12 T12 90°    现货查询上海航欧                   V 50.1 A12 T12 90°        TUNKERS
    CXHA-XBN        现货查询上海航欧                            SUN
    BVM-1116R15R      现货查询上海航欧                            KOBOLD
    PR5210/11       现货查询上海航欧                   PR5211/11替代PR5215          SARTORIUS
    B30NC001        现货查询上海航欧                            AEROFILM
    SK 63S/4 OL/H MS NO:203176974-100   现货查询上海航欧                            NORD
    PI 21004 DN PS3      现货查询上海航欧                            MAHLE
    SSV10      现货查询上海航欧         619-26841-1              LINCOLN
    MGB-L1-AR-AB9A1-S1-R-109887    现货查询上海航欧         109887     MGB-L1-ARA-AK1A1-S1-R-121034  EUCHNER
    ECFUF-236        现货查询上海航欧                            KILLARK
    6111-0020121711110000.00 4-20ma 0-5bar(产编同473787          现货查询上海航欧         Var ID 1104446(以此为准)                 SAMSON
    SN4N225Y        现货查询上海航欧                   SN4N225G        GIMATIC
    RNB0.8G 现货查询上海航欧                            OGURA
    M0001A-097-AAO MANOCOMB-IP65/1K 0-1.6mpa        现货查询上海航欧                            PINTER
    7200276  现货查询上海航欧         TYPEAMS(3/8")  P/N:7200276                 twiflex
    TCN-100-1-714-V02          现货查询上海航欧                            TUNKERS
    19862004        现货查询上海航欧                            GEMCO
    410 39 24VDC 现货查询上海航欧                            HUMPHREY
    991W04-1BP    现货查询上海航欧                            BENLOC
    7020020200     现货查询上海航欧                            Metal Work
    1017A-GBP       现货查询上海航欧                            SFERAX
    DP1-RJ45-R-24LS     现货查询上海航欧                            MENCOM
    CEV582M-20009    现货查询上海航欧                            TR
    RI-58D/10EF.49KD   现货查询上海航欧         0532568            HENGSTLER
    8KB-052-1         现货查询上海航欧                            DESTACO
    14001020        现货查询上海航欧                            SOCOMEC
    HB031LK  现货查询上海航欧                            CONTRAVES
    LS-G02-2cA-25-EN-645   现货查询上海航欧                            DAIKIN
    02041-216015 现货查询上海航欧                            Norelem
    MT500SH          现货查询上海航欧                            M+S
    AKR 50 B420L  现货查询上海航欧                            LEM
    RF 1005-SG5    现货查询上海航欧                            Rasmi
    202-U      现货查询上海航欧                            DESTACO
    8MB-055-1 D-61440             现货查询上海航欧                            DESTACO
    VDLI-1S11/Ex   现货查询上海航欧         9150/1               VSE
    D2532KL0         现货查询上海航欧                            DYNAMCO
    PVSE 230/24-10        现货查询上海航欧                            BLOCK
    PVSE 400/24-40        现货查询上海航欧                            BLOCK
    CEW58M-00165       现货查询上海航欧                   CEW582M-10165    TR
    M1A-15K/15K  现货查询上海航欧                            NSD
    170M4417 700A 690V     现货查询上海航欧                            BUSSMANN
    XCSW241C       现货查询上海航欧                            CABUR
    SMR 6306 SG T3       现货查询上海航欧                            TELCO
    MTL5541 现货查询上海航欧                            MTL
    24EB35  24VDC 350MA         现货查询上海航欧                            ACOPIAN
    Q400-054 LQT400 型号均已升级,       现货查询上海航欧                   LQT40A-22110000   Tillquist
    SCS 7kv 16mm 现货查询上海航欧                            FAVIER
    8570/12-406    现货查询上海航欧                            STAHL
    DCE12/4309KS         现货查询上海航欧                   DCE12/4309KS-CC   BDC
    GE100*80-320/250C/C   现货查询上海航欧                            Global
    A200-D90         现货查询上海航欧                   A200-D90 UL   NISSEI
    16-7-3391         现货查询上海航欧                            PINET
    PU10         现货查询上海航欧         491-00002                 TR
    AX/2.5/S  现货查询上海航欧         922503              Solartron
    CMV58M-00027      现货查询上海航欧                            TR
    DZ135      现货查询上海航欧                            MICRO-EPSILON
    TZ1RE024RC18VAB-C1826      现货查询上海航欧         084247              EUCHNER
    HF532-WB1XX1XX   现货查询上海航欧                            ROTRONIC
    KTS 25-38-T5-A-KB   现货查询上海航欧                   KTS 25 38T-G-KB     KNOLL
    223.1300.000  现货查询上海航欧                            taconova
    MRE-32SP062SAC    现货查询上海航欧                            NSD
    J205V-1S-F12TS-X30932  现货查询上海航欧                            WHITMAN CONTROLS
    8HP3202M10ANP01        现货查询上海航欧                            MP-FILTRI
    8HP1352A10ANP01          现货查询上海航欧                            MP-FILTRI
    2209K745         现货查询上海航欧                            McMaster-Carr
    2209K761         现货查询上海航欧                            McMaster-Carr
    2209K763         现货查询上海航欧                            McMaster-Carr
    RE20NV25C16R       现货查询上海航欧                            TOSOKU
    DP/10/P   现货查询上海航欧         971115-3          Solartron
    020G         现货查询上海航欧                            Elfin
    020PTAARK      现货查询上海航欧                   020PTFAR         Elfin
    70/400 DFAB    现货查询上海航欧                            WAIRCOM
    LV25-600/SP1  现货查询上海航欧                            LEM
  • 在2025/11/19 14:10:00留言
  • 详细留言:温度探头 1*PT100/B
  • 官冰 在2025/10/31 13:30:00留言
  • 侯杰 在2025/10/22 9:51:00留言
  • 详细留言:AWF95-12/VK
  • 在2025/9/23 14:11:00留言
