上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机
ARIS
PD35
ARIS
PE55-06
ARIS
BE41-21003
ARIS
ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
ARIS
EF06-1
ARIS
K3006/1242-84873-01001
ARIS
FNr.1420-6259-01010;Typ:EF 1 MA333312
ARIS
ARIS液压伺服缸PE40-08
ARIS Antriebe und Steuerungen GmbH PE30-08
aris
FNr: 0736-67622-01002
aris
6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
ARIS
N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
Aris
PMR2 0700002 NR:0216-52001-001
ARIS
0542-61428-02010 N-B1-E
Aris
K3006 FNR.1137-5461-01059
ARIS
FNr:1142-5481-02040
ARIS
FNr:1219-83411-01003
Aris
K3012,Stroke -- 300mm;actuating force --- 1200N;voltage ---
230V/50Hz;actuating speed --- 1.7(2) sec;
ARIS
PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise
81020/06
ARIS
PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27,
counterclockwise 81928/03
ARIS
N 5 1209-82710-01003 30 s / 90??+ PMR 3
ARIS
Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
ARIS
FNr:0908-4966-01008 Typ:EF1
ARIS
NL-90/120
ARIS
Aris
Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage:
220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal
frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
ARIS
TYP.N5 FNr.1117-79726-01002
Aris
1206-S2453-02002 N5L SNR107504
ARIS
0906-71866-01002??N6S DN1120d
aris
PE60-08 0087.00033
aris
0301-54088-01006
ARIS
TYPE:N5 230V 50HZ 18VA 110Nm 90' 50S IP54
Aris
Nr.1012-5165-02067
ARIS
WRK 3012 Nr.9425-16842-01011 220V 50HZ 17VA 1200N 200S/300MM
ARIS
NL-90/120
ARIS
EV61-521MJ1
ARIS
K 3012 1126-79613-01002
ARIS
K 3012 1126-79612-01002
ARIS
N5 RD-S/DN250d /0620-62724-01001/:230v 50(60)HZ
ARIS
N1-RD-S/DN125d/1108-78827-02036
ARIS
N4 230v 50HZ 30Nm 35VA 6U 4??2(3??5)S/90??FNr??0816-69661-01002
ARIS
type K3012 1,7/1200 2ZW; regulating distance: 300 mm;actuating force:
1200 N; actuating time: 176 s; nominal ,voltage: 230 V AC, 50Hz; nominal power:
31 W; protection ,class: IP 54; limit switches: 2 (standard), 2 (additio
ARIS
BE41-210003
ARIS
N5 1209-82710-0100330 S/90+PMR3
Aris
FNr:1136-5463-01001 TYP:K1512
Aris
FNr.1112-5375-04014 TPY:K3012
Aris
FNr.1026-5230-01040 TPY:K3006
ARIS
1217-83288-01001
ARIS
1217-83288-01002
ARIS
FNr.0906-71866-01003 TYP.N68 DN1120d
ARIS
FNr.0751-4710-02034 Typ.K 3006
Aris
K-A 3025
ARIS Antriebe und Steuerungen GmbH PE 30-08
aris
typ nk3015 dn150d,FNr:1118-79608-02001
Aris
PE20-08
ARIS
0338-55766-01005 TYP:N3
ARIS
RD-S DN125+N1 JN0 O-BDNR 2139147;TLNR 148048 257270/#16
Aris
EV61-521MJ1
Aris
K3012 1012-5165-02062
Aris
Aris
see picture
Aris
K3012, 1029-5247-02029
Aris
K3006, 1013-75710-02003
Aris
FNr: 1235-84300-02061 TYP: NK3015 230V 50(60)Hz 7VA 15Nm
Aris
Nr.1442-90991-01001
Aris
PMR3(FNR:1219-83411-0100)
Aris
6444LI 230V 375/450rpm
Aris
Aris
Aris
ARIS
FNr:0633-64053-01001 Typ:N3 230V 50(60)Hz 18VA 30Nm 90?? 30(25)s IP65
A.121.879.6234
ARIS Antriebe und Steuerungen GmbH 0633-S4053-01001
ArIS
NL3040 (including limit switches, PMR2-LC, electric heating)
ARIS Antriebe und Steuerungen GmbH FNr:1012-5165-02067;Typ:K 3012
ARIS
0203-51259-01003 K3012
ARIS
NL-90/100
ARIS
KA3050
ARIS
K3012
ARIS Antriebe und Steuerungen GmbH 0850-71942-01001;6443LI 230V 50 (60)HZ
18VA
ARIS
K1506 40NM 23OV 50(60HZ)
ARIS
HK40.1 ?A:20mm--?B:20mm
ARIS
HK60.5 ?A:12mm--?B:12mm
Aris
K3012 1,7/1200 2ZW ARIS art.-no. 0100.03217
ARIS Antriebe und Steuerungen GmbH /motor
6443LI/230V/50(60)Hz/18VA/375rpm/78MA/0.56uF
Aris
Aris
WAN 3 Nr.9914-43637-01002
Aris
CL-L 140-70
Aris
WAK 3012 N; Nr.2473672
Aris
WAK 3012N NR:2473672
Aris
FNr: 0836-71033-01002 230V 50 (60) Hz, 30Nm 35VA 6U 4,2 (3,50 s/90??,
Ip65 UTO/+60 ??C PMR3
Aris
Aris
PD25HT MAX10BAR 8BAR 90NM
ARIS
0523-4198-02046 K3012
ARIS
0615-4394-01008
ARIS
SM6585-4 1-2UF
ARIS
KA3050
ARIS
K3012??
ARIS
NL-90/100
Aris
0080.10013 6444LI 230V 375/450RPM
Aris
Nano M 40-60 Nr.VA03.00002
Aris
VA02.L0001
Aris
117.00501
Aris
CL 12-17 300(replace K3012)+0117.00501
Aris
VA02.L0005
VARISCO
117.00588
VARISCO
JE1-110 G10 ET20
Aris
117.00501
Aris
117.00652
VARISCO
VA02.L0001
Aris
CL12-17 300 Nr:VA02.L1001(Replace K3012)
Aris
06-17 300(0429-4002-01003)
Aris
VA02.L0001
Aris
117.00501
Aris
VA02.L0005
VARISCO
117.00652
Aris
117.00588
Aris
Artikel-Nr.0045.00011
Aris
Artikel-Nr.0016.X9014
Aris
Artikel-Nr.1110.00115
VARISCO
14440012
Aris
10014358
Aris
10008895
Aris
10009010
Aris
999990.999.00000(1:1 ersetzt K 3012 1305-5758-01018)
Aris
06-17-300 230V 50Hz
Aris
10007593
Aris
10005371
Aris
10016934
Aris
10014358
Aris
10009010
Aris
10008895
Aris
14440012
Aris
117.00652
Aris
VA02.L0005
Aris
117.00501
Aris
Linearis TE 12-17 300 ARIS Klappenversteller
Aris
I-ACT-Regler, eingebaut
Aris
Aris
Aris
Linearis N+ 12-17 300 (replacement K3012 1012-5165-02062)
Aris
1672.82004
Aris
1672.82003
Aris
VA07.L0001
Aris
117.00501
Aris
117.00652
Aris
VA02.L0005
Aris
1110.00200 Endschaltersatz BE41
Aris
EV61-521MJ1
Aris
000988.024.60153; Stellantrieb Typ EF 1
Aris
8047GG+GG514+TYP.1A
Aris
8047GG+GG514+TYP.1A
Aris
Typ:WAN V71-R1;FNr:0115-49153-04001
Aris
Typ:WAN V71-R1;FNr:0115-49153-03003
Aris
K 3012 Nr.0243-03671-01016
Aris
N6S DN1120d 0906-71866-01002
Aris
Nr 9843-42249-01006 typ WAK 3012
Aris
|ADJUSTING DRIVE|TYPE WAK 3012; VOLTAGE: 220V; 09346.401.011006.000
Aris
K3012 H300,Nr.1505-91626-04001
Aris
CL-M60-25
Aris
FNr??1302-5756-01023
Aris
K3006
Aris
ype: CL-S 30-30 30Nm 30s/90?230V 50(60)Hz 11VA 48mA UT-15/+60??
ED-S1-100%Pa?f. MP21 FNr:1538-93225-01001
Aris
Type:N3230V 50(60)Hz18VA 30Nm90?30(25)SIP54 UT-15/+60??
FNr:1342-88096-01001
Aris
Typ:K 1512,FNr:0936-73991-01001,pls see the pic
Aris
CL-S?40-120 FNr:1136-81073-01001??Typ:N3??230V 50(60)Hz 7VA 40Nm 90??
120(100)s IP65 UT-15/+60??
Aris
CL-M60-25
Aris
SN:038895 SW-REV PMR3_06
Aris
CL-M 100-25
Aris
117.00501
Aris
CL-L160-17
Aris
1110.00003
Aris
1110.00309
Aris
1110.0031
Aris
40.02291
Aris
1110.00309
Aris
1110.00003
Aris
1110.0031
Aris
1145-78525-01001 NL-3040
Aris
FNr??0851-4915-01003 typ??K 3006
Aris
PE30-08
Aris
Aris
0016.02076+1110.00107+0045.00011
Aris
FNr:1445-91087-01016 Typ??LINEARIS 06-17 300 23V 50(60) HZ 18VA 1.7(2)
mm 600N H300 IP65 UT-15/+60?? 2ZW, PMR-CL
Aris
Typ??K 3012 1142-5481-02045
Aris
Typ??K 3006
Aris
PE60-08
Aris
FNr:0827-70285-01004 Typ:N1 230V 50(60)Hz 7VA 30Nm 90?? 120??100??s IP54
UT-15/+60??
Aris
06-17-300 230V 50Hz
Aris
1209-82710-01003 TYP??N5
Aris
Aris
Aris
Aris
CL-L 140-70 140Nm 220v/50HZ,4-20mA
Aris
CL12-17 300??Nr??VA02.L1001??Replace K3012??
Aris
Aris
NL-3040
Aris
NL-3040
Aris
FNr:1219-83411-01009TYP: K 3012
Aris
PMR3 (FNR:1219-83411-0100)
Aris
K3006 4-20MA 600N FNr??1307-85809-01039
Aris
EV61-521MB1
Aris
K3006??Nr0914-72779-01009
ARIS
Nr.1442-90991-01001 Typ??LINEARIS12-17 300
aris
1102-78517-03002
ARIS Antriebe und Steuerungen GmbH TYP:WAK 3012 N ,Nr:9310-12551-01004
ARIS
EF06
ARIS
K3012
ARIS
K3006
ARIS
K1512
ARIS
K3006 NR.1145-81511-01006
ARIS
PMR3(FNR:1219-83411-01008)
ARIS Antriebe und Steuerungen GmbH FNr:1219-83411-01009 TYP: K 3012
ARIS
K3012 Nr??1107-78855-01001 IP54 50/60HZ
ARIS
1010-75416-01002
ARIS
K3012.ED-S3-50%,~230V.50HZ.31VA.1200N.H300.1.7(2)mm/S
ARIS
WAN 1 Nr??2214859
ARIS
1141-81317-01003
ARIS
Type:K3012 1,7/1200 2ZW RP19 1029-5247-02016
ARIS
K3006 1316-5830-01002
ARIS Antriebe und Steuerungen 0016x9014+1110.0 0107+0045.0011
ARIS
FNr:1219-83411-01008 TYP:K3012
ARIS
K3006??Nr.0914-72779-01009 230v 50??60??HZ 180VA 600N
Aris
K3006 FNR:1048-5310-01033
"type WAK 3012; stroke: 300 mm; actuating force: 11200 N
