  • HEADLINE滤芯705N-60
  • 发布时间:2025/6/28 10:25:35   修改时间:2025/6/28 10:25:35 浏览次数:429
  • 2017HEADLINE工厂上海航欧中国区销售
     HEADLINE过滤器、HEADLINE滤芯、HEADLINE空气过滤器、HEADLINE液体过滤器、HEADLINE排气过滤器
     英国HEADLINEFILTERS公司制造销售各种不同材质的气体,液体过滤器以及过滤器件。
     英国HEADLINEFILTERS产品主要有:
     HEADLINE空气压缩过滤器
     HEADLINE空气过滤器
     HEADLINE液体过滤器
     HEADLINE排气过滤器
     HEADLINE过滤器外壳
     HEADLINE过滤器
     HEADLINE滤芯
     HEADLINE部分型号:12mmElements12-32-4012-32-5012-32-6012-32-7012-32-8012-56-80
     25mmElements25-64-4025-64-5025-64-6025-64-7025-64-8025-127-4025-127-5025-127-6012-57-4012-57-5012-57-6012-57-7012-57-80过滤器filterhousing137G-50HEADLINE过滤器360F-70CHEADLINE12163过滤器360F-50CHEADLINE滤芯filterelements12-57-50KHEADLINE滤芯filterelements25-57-50CHEADLINE
     滤芯filterelements25-64-100HEADLINE
     滤芯filterelementsPT-120-03HEADLINE25mmElements(continued)25-127--7025-127-8025-178-4025-178-5025-178-6025-178-7025-178-8025-127-70DataSheet25-127-80DataSheet25-178-40DataSheet25-178-50DataSheet25-178-60DataSheet25-178-70DataSheet25-178-80DataSheet51mmElements51-89-4051-89-5051-89-6051-89-7051-89-8051-230-4051-230-5051-230-60
     过滤器filterhousing122S1/4''HEADLINE过滤器HEADLINE滤芯705N-60HEADLINE滤芯filterelements51-476-70CHEADLINE滤芯filterelements12-57-50CHEADLINE过滤器filterhousing137G-50C-2590HEADLINE56453过滤芯Filterelement25-40-50CHEADLINE滤芯filterelementsSS-140-251HEADLINE
     过滤器filter122PGK-PT120-25HEADLINE过滤芯CATCHPOTFORFIDPGC780N-CPHEADLINE过滤器带滤芯filterhousing760P-50HEADLINE
     滤芯filterelements12-57-60CHEADLINE滤芯filterelements12-32-60KHEADLINE电机HAT051Headline-motor滤芯filterelements25-64-50CHEADLINE过滤器filterhousing137G-2590HEADLINE滤芯filterelements12-57-70KHEADLINE38mmElements38-58-4038-58-5038-58-6038-58-7038-58-8038-152-4038-152-5038-152-6038-152-7038-152-80
     滤芯filterelements12-57-80KHEADLINE
     滤芯filterelementsSS-120-100HEADLINE
     过滤器filter122HEADLINE滤芯filterelementsSS-120-100THEADLINE
     滤芯filterelementsSS-130-10THEADLINE过滤器filter136HEADLINE滤芯filterelementsSS-130-100VHEADLINE过滤器127GHEADLINE滤芯PT100-10HEADLINE滤芯PT120-30HEADLINE滤芯PT130-10HEADLINE滤芯PT130-30HEADLINE
     滤芯IN-lineFiltersDIF-BN50HEADLINE不锈钢过滤外壳Stainless航欧机电FilterHousing110HEADLINE
     过滤器外壳filterhousing137GHEADLINE滤芯p/n25-64-50cHEADLINE过滤器filterhousing755NCP-1/2"HEADLINE
     滤芯12-51-60CHEADLINE过滤器外壳Filterhousing370-50HEADLINE过滤器外壳Filterhousing750-NC-60SHEADLINE过滤器外壳Filterhousing770NHEADLINE
     滤芯Filterelement25-178-60SHEADLINE
     滤芯Filterelement25-64-60SHEADLINE
     凝结过滤器1225000PISGHEADLINE过滤器FilterHousing705NC-70CHEADLINE
     滤芯12-32-70CHEADLINE
     过滤器玻璃罩GB137/138GHEADLINE过滤器玻璃罩GB137/138GHEADLINE
     过滤器滤芯A18002HEADLINE滤芯25-178-50HEADLINE过滤器137G-1/4"ports100PSIGHEADLINE
     HEADLINE过滤器137G-50
     HEADLINE过滤器360F-70C
     HEADLINE过滤器360F-50C
     HEADLINE过滤器12-57-50K
     HEADLINE过滤器5-57-50C
     HEADLINE过滤器5-64-100
     HEADLINE过滤器PT-120-03
     HEADLINE过滤器122S1/4''
     HEADLINE过滤器705N-60
     HEADLINE过滤器51-476-70C
     HEADLINE过滤器12-57-50C
     HEADLINE过滤器137G-50C-2590
     HEADLINE过滤器25-40-50C
     HEADLINE过滤器SS-140-251
     HEADLINE过滤器122PGK-PT120-25
     HEADLINE过滤器780N-CP
     HEADLINE过滤器760P-50
     HEADLINE过滤器12-57-60C
     HEADLINE过滤器12-32-60K
     HEADLINE电机HAT051
     HEADLINE过滤器25-64-50C
     HEADLINE过滤器137G-2590
     HEADLINE过滤器12-57-70K
     HEADLINE过滤器2-57-80K
     HEADLINE过滤器SS-120-100
    HEADLINE过滤器122
    HEADLINE过滤器SS-120-100T 51-89-40 Data Sheet    51-89-50 Data Sheet        51-89-60 Data Sheet        51-89-70 Data Sheet         51-89-80 Data Sheet        51-230-40 Data Sheet      51-230-50 Data Sheet      51-230-60 Data Sheet
    51mm Elements(continued)    51-230-70         51-230-80         51-476-40         51-476-50         51-476-60         51-476-70         51-476-80
    51-230-70 Data Sheet      51-230-80 Data Sheet      51-476-40 Data Sheet      51-476-50 Data Sheet      51-476-60 Data Sheet         51-476-70 Data Sheet      51-476-80 Data Sheet
    63mm Elements       63-762-40         63-762-50         63-762-60         63-762-70         63-762-80
    63-762-40 Data Sheet      63-762-50 Data Sheet      63-762-60 Data Sheet      63-762-70 Data Sheet      63-762-80 Data Sheet
    12-32-50C  12-32-60C  12-32-70C  12-32-80C  12-57-50C  12-57-60C  12-57-70C  12-57-80C  25-64-50C  25-64-60C  25-64-70C  25-64-80C  25-127-50C  25-127-60C  25-127-70C  25-127-80C  25-178-50C  25-178-60C  25-178-70C  25-178-80C  38-58-50C  38-58-60C  38-58-70C  38-58-80C  38-152-50C  38-152-60C  38-152-70C  38-152-80C  45-250-50C  45-250-60C  45-250-70C  45-250-80C  51-89-50C  51-89-60C  51-89-70C  51-89-80C  51-230-50C  51-230-60C  51-230-70C  51-230-80C  51-476-50C  51-476-60C  51-476-70C  51-476-80C  63-762-50C  63-762-60C  63-762-70C  63-762-80C
    Related Products
    110-126 Stainless 航欧机电 Housings
    Exotics (Alloy 400, Alloy C-276, Titanium etc) Membrane Housings
    130 - 146 Stainless 航欧机电 Housings
    117 - 127G Stainless 航欧机电 Housings
    137 - 148G Stainless 航欧机电 Housings
    150 - 162 Stainless 航欧机电 Housings
    Inline Filter Housings 116IL - 146IL
    Stainless 航欧机电 Housings 116IL-3 - 146IL-3
    Stainless 航欧机电 Heatable Housings H122ST - H140ST
    120P - 142P PTFE Housings
    120PG - 132PG PTFE Housings
    700N - 710NC 上海 Housings
    750N - 760NC 上海 Housings
    701P - 710PC Polypropylene Housings
    750P - 760PC Polypropylene Housings
    PVDF Filter Housings 700K-760K
    707N - 778NC 上海 Housings
    200 - 213AL上海 航、欧 Housings
    223 - 253A上海 航、欧 Housings
    910 - 920E Inlet & Outlet Housings
    310 - 315A上海 航、欧 Housings
    360 - 360AFI上海 航、欧 Housings
    365 - 365AFI上海 航、欧 Housings
    370 - 370AFI上海 航、欧 Housings
    420 - 456 Vacuum 上海 、欧 Exhaust Housings
    420S - 456S Vacuum 上海 、欧 Exhaust Housings
    110HP-126HP Stainless 航欧机电 Housings
    130HP - 146HP Stainless 航欧机电 Housings
    150HP - 162HP Stainless 航欧机电 Housings
    150VP - 162VP Stainless 航欧机电 Housings
    720P - 730PC Polypropylene Housing
    721N - 730NC 上海 Housings
    771N - 780NC 上海 Housings
    771P - 780PC Polypropylene Housings
    380AHP - 390AHP上海 航、欧 Housings 12-32-40K  12-32-50K  12-32-60K  12-32-70K  12-32-80K  12-57-40K  12-57-50K  12-57-60K  12-57-70K  12-57-80K  25-64-40K  25-64-50K  25-64-60K  25-64-70K  25-64-80K  25-127-40K  25-127-50K  25-127-60K  25-127-70K  25-127-80K  25-178-40K  25-178-50K  25-178-60K  25-178-70K  25-178-80K  38-58-40K  38-58-50K  38-58-60K  38-58-70K  38-58-80K  38-152-40K  38-152-50K  38-152-60K  38-152-70K  38-152-80K  51-89-40K  51-89-50K  51-89-60K  51-89-70K  51-89-80K  51-230-70K  51-230-40K  51-230-50K  51-230-60K  51-230-80K  51-476-40K  51-476-50K  51-476-60K  51-476-70K  51-476-80K  63-762-40K  63-762-50K  63-762-60K  63-762-70K  63-762-80K
    Related Products
    380AHP - 390AHP上海 航、欧 Housings 12-32-40S  12-32-50S  12-32-60S  12-32-70S  12-32-80S  12-57-40S  12-57-50S  12-57-60S  12-57-70S  12-57-80S  25-64-40S  25-64-50S  25-64-60S  25-64-70S  25-64-80S  25-127-40S  25-127-50S  25-127-60S  25-127-70S  25-127-80S  25-178-40S  25-178-50S  25-178-60S  25-178-70S  25-178-80S  38-58-40S  38-58-50S  38-58-60S  38-58-70S  38-58-80S  38-152-50S  38-152-60S  38-152-70S  38-152-80S  51-89-40S  51-89-50S  51-89-60S  51-89-70S  51-89-80S  51-230-40S  51-230-50S  51-230-60S  51-230-70S  51-230-80S  51-476-40S  51-476-50S  51-476-60S  51-476-70S  51-476-80S  63-762-40S  63-762-50S  63-762-60S  63-762-70S  63-762-80S
    Related Products
    380AHP - 390AHP上海 航、欧 Housings SS-12-32-01  SS-12-32-03  SS-12-32-10  SS-12-32-25  SS-12-32-100  SS-12-57-01  SS-12-57-03  SS-12-57-10  SS-12-57-25  SS-12-57-100  SS-25-64-01  SS-25-64-03  SS-25-64-10  SS-25-64-25  SS-25-64-100  SS-25-178-01  SS-25-178-03  SS-25-178-10  SS-25-178-25  SS-25-178-100  SS-51-230-01V  SS-51-230-03V  SS-51-230-10V  SS-51-230-25V  SS-51-230-100V  SS-51-476-01V  SS-51-476-03V  SS-51-476-10V  SS-51-476-25V  SS-51-476-100V
    Related Products
    130VP - 146VP Stainless 航欧机电 Housings SS-12-32-01  SS-12-32-03  SS-12-32-10  SS-12-32-25  SS-12-32-100  SS-12-57-01  SS-12-57-03  SS-12-57-10  SS-12-57-25  SS-12-57-100  SS-25-64-01  SS-25-64-03  SS-25-64-10  SS-25-64-25  SS-25-64-100  SS-25-178-01  SS-25-178-03  SS-25-178-10  SS-25-178-25  SS-25-178-100  SS-51-230-01H  SS-51-230-03H  SS-51-230-10H  SS-51-230-25H  SS-51-230-100H  SS-51-476-01H  SS-51-476-03H  SS-51-476-10H  SS-51-476-25H  SS-51-476-100H SS-12-32-01  SS-12-32-03  SS-12-32-10  SS-12-32-25  SS-12-32-100  SS-12-57-01  SS-12-57-03  SS-12-57-10  SS-12-57-25  SS-12-57-100  SS-25-64-01  SS-25-64-03  SS-25-64-10  SS-25-64-25  SS-25-64-100  SS-25-178-01  SS-25-178-03  SS-25-178-10  SS-25-178-25  SS-25-178-100  SS-51-230-01T  SS-51-230-03T  SS-51-230-10T  SS-51-230-25T  SS-51-230-100T  SS-51-476-01T  SS-51-476-03T  SS-51-476-10T  SS-51-476-25T  SS-51-476-100T ?  PT-12-32-03
    ?  PT-12-32-25
    ?  PT-12-57-03
    ?  PT-12-57-25
    ?  PT-25-64-03
    ?  PT-25-64-25
    ?  PT-25-178-03
    ?  PT-25-178-25
  • 在2025/11/19 14:10:00留言
  • 详细留言:温度探头 1*PT100/B
  • 官冰 在2025/10/31 13:30:00留言
  • 侯杰 在2025/10/22 9:51:00留言
  • 详细留言:AWF95-12/VK
  • 在2025/9/23 14:11:00留言
