  • 2016年Status工厂上海航欧中国区销售
  • 发布时间:2021/5/6 14:20:43   修改时间:2021/5/6 14:20:43 浏览次数:627
  • 2016Status工厂上海航欧中国区销售
    Status变换器,Status隔离器,Status流量表,Status显示器,Status变送器,Status传感器
    http://www.status.co.uk/distributors.aspx
    Status变送器,Status传感器
     StatusInstrumentsLtd1982年创立,主要Status变换器,Status隔离器,Status流量表,Status显示器,Status变送器,Status传感器,Status热电偶,型号主要以SEM,MED,DM,WTX,WTR,HTR,TTR,TTC,STS,STW,PTX系列为主,
     主要型号:
     SEM203/P
     SEM203/TC
     SEM203/W
     SEM206/P
     SEM206/TC
     SEM206/TH
     TTR200
     TTC200
     TTR200X
     TTC200X
     SEM210
     SEM210X
     SEM310
     SEM310X
     SEM110/P/TC/W/Z
     SEM110/X
     SEM104P
     SEM104TC
     HTR200
     HTR201
     HTR200V
     HTR201V
     SEM710
     SCH4/*/0
     SCH15/F
     SCH15/F/W
     STA206
     SEM213/P
     SEM213/TC
    SEM1603/P
    SEM1603/TC
    SEM1610
    SEM1801XR
    SEM1802XR
    SEM315
    USB-CONFIG-MKII
    48-200-0001-01
    HART-KIT-UK
    HART-KIT-EUR
    HART-KIT-USA
    HART-KIT-AUS
    MTL7787+
    MTL5541
    WTX700/SCH4/B
    WTX700/SCH4/C
    WTX700/SCH11
    WRX900/04/S1
    WRX900/04/S2
    WRX900/22/S1
    WRX900/22/S2
    WRX900/ANTENNA
    WIRELESS CONFIG KIT
    SEM1000
    SEM1020
    SEM1300
    MED2911
    SEM1600T\
    SEM1600VI
    SEM1600B
    SEM1600F
    SEM1630
    SEM1700
    MED2100
    MED2133
    MED2222
    MED2322
    MED2411
    MED2922
    DM3430/S*
    DM3600/A/00/S*
    POD-3000-02
    DM4500U/S*
    OPT4500/MA
    OPT4500/485
    ACC4000/01
    DM640/TC
    DM640X/TC
    SCH15/A/W
    SCH15/C/W
    DM660P/A
    DM660P/B
    DM660P/C
    DM500/F
    DM700/I
    DM700HM/I
    DM700XHM/I*
    SCH15/F
    DM720
    SEM160ID/H02
    SEM160ID/HP01
    SEM160IW/H
    SEM160IW/HP
    SEM161D/H01/DP
    SEM161D/H02/DP
    SEM161D/H03/DP
    SEM161R/H01/DP
    SEM161R/H02/DP
    SEM161W/H/DP
    SEM162D/HP01/DP
    SEM162D/HP02/DP
    SEM162D/HP03/DP
    SEM162R/HP01/DP
    SEM162W/HP/DP
    SEM160-FT10
    HUMICHECK-11
    IR200/2/100
    IR200/30/100
    IR200/15/250
    IR200/30/250
    IR200/15/500
    IR200/30/500
    IR200/CABLE
    IR / BKT
    IR/ADJBKT
    SCH4/*/0
    31-341-1987-01
    SCH15/A
    SCH15/A/W
    SCH15/C/W
    SCH15/F/W
    SCH50A/L/W
    SCH50S/L/W
    SCH51A/L/0
    SCH51S/L/0
    SCH52A/L/W
    SCH52S/L/W
    SCH50/51/52
    SCH50DMK
    SMK/2G, T
    RMK/1G, T
    PMK/300
    PMK/600
    WMK/SCH4
    PMK/SCH4
    34-255-9960-00
    PTX130G1
    PTX130G4
    PTX130A2
    PTX130S2
    PTX130
    PTX19/*/5
    PTX20X/*/*
    PTX21/*/2
    PTX22/23 OPTIONS
    产品型号         0821303403                       REXROTH
    产品型号         0821300316                       REXROTH
    产品型号         0821303433             0821303449     REXROTH
    产品型号         0821300920                       REXROTH
    产品型号         0821100024             R412010715    REXROTH
    产品型号         VMK 32 DR NC 503006                      COAX
    产品型号         ARBB5B7UDF DN200 PN10                        CENTERLINE
    产品型号         TX350-1DA-LS+SKL-10               TX2-1DA+SKL-10      KEIHIN
    产品型号         TX350-1DA +325-15                   TX2-1DA-LS+SKL-15 KEIHIN
    产品型号         11647579 (Festo)                       NETTER
    产品型号         TX350-1DSR-LS+SKL-20             TX2-1DSRSKL-20  KEIHIN
    产品型号         VMK 15 NC 546113                    COAX
    产品型号         VKL-3201                    VERSA
    产品型号         0821300303                       REXROTH
    产品型号         0821300907                       REXROTH
    产品型号         0821300929                       REXROTH
    产品型号         0821303436              0821303305     REXROTH
    产品型号         0821303428              R412010792    REXROTH
    产品型号         0821302406                       REXROTH
    产品型号         YT-300N1                            YTC
    产品型号         3755-12000000000000.00                         SAMSON
    产品型号         SD095-LB800-S90-A10S   1463494            Desoutter
    产品型号         111482                       Linnemann
    产品型号         P2/PKPPP/TNU/TF/PTV/0400                     Wilden
    产品型号         HUSKY 515       D52911             GRACO
    产品型号         DM 50/565 PEE-F1-HP-SP上的膜片EPDM 1 50 50 08                     DELLMECO
    产品型号         524气动阀      K524-X200-14000            AQUAMATIC
    产品型号         625 15D82C11311/1502          625 15D82C31311/1507 GEMU
    产品型号         UDS105 KUEC/KUEC                           WAIRCOM
    产品型号         PVT406K-20A                     KONAN
    产品型号         P531501                     JOYNER
    产品型号         C320TP1                     CUTLER HAMMER
    产品型号         EKCA4 AR/AR                             WAIRCOM
    产品型号         EZRR2/7                     WAIRCOM
    产品型号         EZRR2/7F20PM/SM                            WAIRCOM
    产品型号         514 15D137 51 0 2061-Z04                        GEMU
    产品型号         8070/2-1-W-U60                         STAHL
    产品型号         11 ACOR-305MF-AS DN 40 PN 63 + APD-075 + NBN3-F31K-Z8/BT65               A11 ACOR-305MF-AS DN 40 PN 63 + RE076-DA + NBN3-F31K-Z8/BT65   ASEKO
    产品型号         EXNER 640  DN50                    FRANK
    产品型号         0820402101                       BOSCH
    产品型号         4AM-ARV-119                    GAST
    产品型号         4AM-NRV-22B          4AM-NRV-22F GAST
    产品型号         4840U2                       ingersoll rand
    产品型号         VA1X                            Globe motors
    产品型号         2H410-150-ATEX      2051473214              Desoutter
    产品型号         6AM-NRV-22A                   GAST
    产品型号         16AMFRV2                          GAST
    产品型号         4AM-RV-75-GR25                       GAST
    产品型号         TAM4-030F                         TAIYO
    产品型号         LZB33AR009-11       8411030805              ATLAS COPCO
    产品型号         MUD40-2400 29906817 F77 0.39KW 2400r/min                       DEMAG
    产品型号         NK70D      8711260            OBER
    产品型号         8731186  LFB4R                OBER
    产品型号         207385                       GRACO
    产品型号         K40                     SINGOLD
    产品型号         SD160-AB320-S4Q   1462774            Desoutter
    产品型号         SD070-LB1100-S90-A4H                     Desoutter
    产品型号         24-TD-075/2R3D-AX                           A-T Controls
    产品型号         PKN-2/0-050-C086 DN50                   PKN-2/0-050-C088           BAR
    产品型号         Z19586-4516AU                          FAIRCHILD
    产品型号         83667                          LINCOLN
    产品型号         AT-7009                      PUMA
    产品型号         6CB-200-2II                        HYUNDAI
    产品型号         MKS-3502-K                        NBK
    产品型号         PPD 014/25,4  19.16.014.04            MWM
    产品型号         CH10-B                       NKE
    产品型号         CHP304-100SH1                CHP304A-100SH1    NKE
    产品型号         CH01-DO-SP                       NKE
    产品型号         CHP303A-40                       NKE
    产品型号         EC20W-10                  EC204-A-10      NKE
    产品型号         CH21-M5                   NKE
    产品型号         188.12.X.X.1.1.PS Incl. Diaphragm, excl. body                           SED
    产品型号         188.12.X.X.4.1.PS Incl. Diaphragm, excl. body                           SED
    产品型号         C0D1200-50                       ATLAS COPCO
    产品型号         SH420-LR400-S90-A10S   2051478004              Desoutter
    产品型号         AP3DA                        SIRCA
    产品型号         AX10 215/20 N1                          ALFAMATIC
    产品型号         SH700-LR225-S90-A13S   2051474744              Desoutter
    产品型号         GT16                           FINDEVA
    产品型号         JEK270                        JUNG
    产品型号         S92-0930 92-0920-11300532           BRAY CONTROLS
    产品型号         ES0025                        EL-O-Matic
    产品型号         S92-0830 92-0830-11300-532                  BRAY CONTROLS
    产品型号         9479-BY-2SPDT                  9479NBY2B2M0600U      WESTLOCK
    产品型号         SC00600-6U对应FA AT501US12                       Airtorque
    产品型号         AT251US10                         Airtorque
    产品型号         SC00450-5.5U 对应FA AT451US11                           Airtorque
    产品型号         QG06-825                            COMPACT
    产品型号         IA300S12.F05-F07-F1014                            INTERAPP
    产品型号         5.32 S                          Walton
    产品型号         PT100B DA F05+F07 14DS                          Airtorque
    产品型号         GTE-163/090-11-V27-F    62613488                   BAR
    产品型号         RP63DA                      ROPO
    产品型号         5.18 S Ingersoll                           Walton
    产品型号         PASR10              PAS10       CHEMLINE
    产品型号         PPSR00              PPS00       CHEMLINE
    产品型号         PASR00              PAS00       CHEMLINE
    产品型号         805490-SX                           Solartron
    产品型号         GTE-210/090-09-V36-F                       BAR
    产品型号         αB-83DA                         ALPHA
    产品型号         P20SBF 07220001                       TOLOMATIC
    产品型号         0705-0001                           TOLOMATIC
    产品型号         HCM8F                       WAIRCOM
    产品型号         FCLR8                          WAIRCOM
    产品型号         180003-112-0001                       MAC
    产品型号         4-DP-2                         HUMPHREY
    产品型号         HTDA6X1/2                         HUMPHREY
    产品型号         CHR633                      NKE
    产品型号         CP8D-LB-3-40                     KONAN
    产品型号         7-DP-4M                     HUMPHREY
    产品型号         CP611-N-LB 50*50                     KONAN
    产品型号         38.150.012                         KUHNKE
    产品型号         SC100X200                          AIRTAC
    产品型号         MGB038SK10.25 FM1                        TOL-O-MATIC
    产品型号         EC206-A-10                       NKE
    产品型号         QJ98-3317                           COMPACT
    产品型号         AC4017-5                            AIRPOT
    产品型号         RA/8100/M/50                            NORGREN
    产品型号         AR3X12-TM                        COMPACT
    产品型号         KE160-80                            GOPA
    产品型号         40/1310 CPU                      WAIRCOM
    产品型号         5-DP-3/4 F                           HUMPHREY
    产品型号         GP19-B                       SOMMER
    产品型号         DNB50N160                      UNIMEC
    产品型号         HS-2518                      GIMATIC
    产品型号         CH92A                        NKE
    产品型号         160/500XL/N/EX                         WAIRCOM
    产品型号         125/500 XL/M/S      S002055001250                 WAIRCOM
    产品型号         2KS160C1.0NF                          AIRPOT
    产品型号         VRG16-60                            TECNOMORS
    产品型号         W-10X5-T                            TOKUYAMA SEIKI
    产品型号         6-DP-1-3/4 F                       HUMPHREY
    产品型号         50/370 CPUI/M                 50/370 XT/M    WAIRCOM
    产品型号         70/400 DFAB                      WAIRCOM
    产品型号         KD2000400150M                       Univer
    产品型号         K-5-X                          FABCO-AIR
    产品型号         40/60 XT/N                          WAIRCOM
    产品型号         V2 40 BR2 A10 T12 90°                   TUNKERS
    产品型号         40/75 XT/N                          WAIRCOM
    产品型号         KD 100 050 0300M                    Univer
    产品型号         KD 100 050 0220M                    Univer
    产品型号         MXP25S GP SM1772 AH2         729820              TOLOMATIC
    产品型号         70/430 DFAB                     WAIRCOM
    产品型号         63R100 CPUI/M                63R100 XT/M   WAIRCOM
    产品型号         D-121-XASK                         FABCO-AIR
    产品型号         W1000500030                   Univer
    产品型号         REECO6.00R2                    REECO
    产品型号         REECO3.25R4                    REECO
    产品型号         CHP306A-60-SH2                        NKE
    产品型号         200V40-50 XL/N2/S                    WAIRCOM
    产品型号         B118X2                              COMPACT
    产品型号         25/25UDC                           WAIRCOM
    产品型号         PRA/182032/M70+QA/8032/23                PRA/802032/M/70+QA/8032/23     NORGREN
    产品型号         0822341002                       CPOAC
    产品型号         DFM-32-30-P-A-GF                     FESTO
    产品型号         SZK40.A00 T12 40                      TUNKERS
    产品型号         8-DP-1                         HUMPHREY
    产品型号         HLC-16AS                            KONSEI
    产品型号         MXE25P BN08 SK29.000 LMI                     TOLOMATIC
    产品型号         R11A-3-180-P-D-A-H                           PHD
    产品型号         7A2-O-CA100S007B150            10A-2 CA100B150-AB-J   TAIYO
    产品型号         39.230.004                         KUHNKE
    产品型号         V2 40 BR2 A10 T12 105                      TUNKERS
    产品型号         ZK18                            EBINGER DETT
    产品型号         50/50 XT/M/EX                            WAIRCOM
    产品型号         81L16-10100                     DESTACO
    产品型号         M-0070.5-DT2T4                        BIMBA
