  • Waddington开关PSENC10032
  • 发布时间:2024/12/14 12:46:28   修改时间:2024/12/14 12:46:28 浏览次数:355
  • 2016Waddington工厂上海航欧中国区销售
    上海航欧销售Waddington变速循环控制单元Waddington传感器Waddington超声波传感器Waddington开关 Waddington电源,Waddington控制器,Waddington动力控制
     主要型号:PSPCB10000
     PSPCB10000-BIN
     PSENC10000
     PSENC10031
    Waddington开关 PSENC10032
     PSENC10009
     PSENC10010
     PSENC10000-NE
     PSENC10001
     PSENC10021
     PSENC10035
     PSENC50002
     PCDIO10003
     PCDIO10008
     PCDIO10000
     PCDIO10008
     PCDIO10003
     PCDIO10000
     STTOPLIMIT1
     STTOPLIMIT2
     STBOTTOMLIMIT1
     STBOTTOMLIMIT2
     ST2NDTOPLIMIT
     ST2NDBOTTOMLIMI
     PSCBL70012
     PSCBL70006
     PSCBL70008
     PSCBL70013
     PSCBL70014
     PSCBL70019
     PSCBL70015
     WESTAMRSH2R1
     WESTAMRSH2R2
     WESTAMRSH2R2SST
     WESTAMRSH3
     WESTAMRSH2R1H
     WESTAMRSH2R2H
     WESTAMRSH2FG
     WESTAMRSH2R1H
     WESTAMRSH2R2HFG
     WESTASSH1
     WESTASSH2
     STHEADsonatrolheadoptionsExtrasensors
     WESTAMRSH2R1mrsh-2/r15in-20ftsonarsensor3800
     WESTAMRSH2R2mrsh-2/r218in-20ftsonarsenso3800
     WESTAMRSH2R2SSTmrsh-2/r218in-20ftsstransdu5500
     WESTAMRSH3sonatrolsensorwithdual7700
     WESTAMRSH2R1Hr1sensorw/hornN8800
     WESTAMRSH2R2Hr2sensorw/hornN8800
     WESTAMRSH2FGmrsh-2fgsensorr2fixedgain0000
     WESTAMRSH2R2HFGr2sensorw/hornandfixedgainN2000
     WESTASSSH1 r-1 stainless steel sensor  7500
     WESTASSSH2 r-2 stainless steel sensor  7500
     STWESTA30FT st6z mods for 30 ft range  Range Mods
     WESTA30FT st6z mods for 30 ft range  000
     STWESTAAOAB air output a/b option
     WESTAAOAB air output a / b selec switch  $ -
     STWESTAAUTO/MAN auto manual out put option
     WESTAAUTO/MAN auto/manual selector switch  $ -
     STWESTAF/V1 freq to voltage option
     WEEZAFV1 f/v-1 frequency to voltage oe Y $ -
     STWESTAGUIDE001 sensor guide adjust able width  call
     WESTASTANDWH1 stand-wh sensor stand w/wheels N 3000
     STWESTAMTRSEL dc motor sel a/b contactor
     WESTAMTRSEL dc motor sel a/b contactor  5000
     STWESTAUTF1 upper time filter option
     WESTAUTF1 utf-1 upper time filter option  $ -
     STWEST/F1 voltage to frequecny option
     PSMDL04 v/f-1 voltage to frequency  $ -
     WESTAQCON Sensor Head quick connector  $ -
     STWESTAMUX2 option analog multiplier
     WESTAMUX2 mux-2 analog multiplier option  8900
     STWESTAHVAO1 option 0-90v dc output
     WESTAHVAO1 hvao-1 0-90vdc output option  2500
     STWESTAJOG option jog option
     WESTAJOG jog pushbutton option  $ -
     STWESTALFO1 option ac line filter
     WESTALFO1 lfo-1 ac line filter option  500
     STWESTATAP1 option percent taper option
     WESTATAP1 tap-1 percent taper option  1800
     STWESTATW1 option limit thumbwheel setpoi
     WESTATW1 thumbwheel set point pot  5000
     STWESTARP1 option remote distance pot
     WESTARP1 rp-1 10 turn remote distance  000
     STWESTARP2 option remote gain pot
     WESTARP2 rp-2 ten turn remote gain  000
     STWESTARP3 option remote speed on output
     WESTARP3 option remote speed on output  000
     STWESTAPT1 option payoff/takeup switch
     WESTAPT1 payout take up switch option  500
     STWESTAFR1 option forward reverse switch
     WESTAFR1 fr-1 forward-reverse switch  500
     STWESTAMAO20 option 4-20 ma output  current loop optput
     WESTAMAO20 mao-20 4-20ma output option  6600
     STWESTAMAO10 option 0-10 ma output
     WESTAMAO10 mao-10 0-10ma output option  6600
     STWESTABOB1 option 12 bit binary output  12 bit binary output
     WESTABOB1 bob-1 12bit binary output  5000
     STWESTASY2M option sy2 sequencer(master op  Sequencer for 2 units operating close together
     WESTASY2M sy2-m sy-2 sequencer master  5000 master
     STWESTASYS option sle option
     WESTASYS sy-s sle option  000 sle
     STWESTASY8 option sy8 sequencer
     WESTASY8 sy-8 8 unit sequencing option  6000 8 CH sequencer for up to 8 units close together
     STWESTASTAND1 option sensorhead stand
     WESTASTAND1A stand-1 sensor head stand N 0900 Sensor Stands
     WESTASTAND10 stand with spool guide N $ -
     WESTASTAND1B sensor head stand with guides N $ -
     STWESTASTANDWH1 stand-wh sensor stand w/wheels
     WESTASTANDWH1 stand-wh sensor stand w/wheels N 8200
     STWESTARAAC1 cable adapter rapid air raac1  Adapter Cables for other OEM equipment
     WESTARAAC1 raac-1 5 pin rapid adapter  000
     STWESTARAAC2 option 15 pin rapidair cable
     WESTARAAC2 raac-2 V2 rapid air adapter  500
     STWESTARAAC2J option 15 pin rapidair cable
     WESTARAAC2J raac-2j rapid air adapter  0000
     STWESTAGOODMAN1 option cable to goodman cutter
     WESTAGOODMAN1 goodman cutter adapter 15 ft  000
     STWESTARAAC3 option d shell rapidair connec
     WESTARAAC3 rapid air d-shell adapter  500
     STWESTADIV2 option analog divider
     WESTADIV2 div-2 analog divider option  0000
     STWESTABSO1 option base speed option
     WESTABSO1 bso-1 base speed option  7500
     STWESTAAOM1 option anolog meter  output meters
     WESTAAOM2 analog meter 0-90 vdc  $ -
     WESTAAOM1 aom-1 analog output meter+-15  0000
     STWESTADMS1 option digital display
     WESTADMS1 dms-1 digital display  9900
     STWESTAEAO1 option extra analog output  Extra analog outputs
     WESTAEAO1 eoa-1 normal extra analog  5000
     STWESTAEAON1 option extra analog output inv
     WESTAEAON1 eaon-1 inverted extra analog  5000
     STWESTADUAL option relay for dual sensor o
     WESTADUAL relay option for dual heads  6500 Relay for 2nd sensor switchable
     STWESTATOGGLE option on off toggle switch
     WESTATOGGLE on/off toggle switch option  500 on off power switch
     STWESTASUM3 option line speed summing
     WESTASUM3 sum-3 3input summing amplifier  7600 Summing input
     STWESTATC6 option tension control(auto/ma
     WESTATC6 tc-6 tension control option  0000
     STWESTADF1 option dust filter option  Dust filter for sensor
     WESTADF1 df-1 dust filter for  500
     STWESTAPID2 option pid output
     WESTAPID2 pid2 output option  6500 PID Output
     STWESTAONOFF two setpoint on off control
     WESTAONOFF 2-set point on/off relay  500 dual setpoint On/Off relay
    WEPTAONOFFNS
    WEPTAPT1LSA
    WEPTAPT1-1
    PTTOPLIMIT
    WEPTATL1
    PTBOTTOMLIMIT
    WEPTABL1
    PTSTAND
    WEPTASTAND
    PTWESTAEXTBASE
    WESTAEXTBASE
    STWESTAMAO20
    WESTAMAO20
    STWESTAMAO10
    WESTAMAO10
    STWESTARAAC1
    WESTARAAC1
    STWESTARAAC2
    WESTARAAC2
    STWESTARAAC2J
    WESTARAAC2J
    STWESTARAAC3
    WESTARAAC3
    STWESTASUM3
    WESTASUM3
    PSOSDA10003
    PSENC10032-PT
    PSDRV10001-PT
    PSDRV10002-PT
    PSSPR10000
    PSPTA10006
    PSOPR10001
    PTTOPLIMIT
    WEPTATL1
    PTBOTTOMLIMIT
    WEPTABL1
    PTSTAND
    WEPTASTAND
    STWESTAF/V1
    WEEZAFV1
    PTWESTAEXTBASE
    WESTAEXTBASE
    STWESTAMAO20
    WESTAMAO20
    STWESTAMAO10
    WESTAMAO10
    STWESTARAAC1
    WESTARAAC1
    STWESTARAAC2
    WESTARAAC2
    STWESTARAAC2J
    WESTARAAC2J
    STWESTARAAC3
    WESTARAAC3
    STWESTAAOM1
    WESTAAOM2
    WESTAAOM1
    STWESTASUM3
    WESTASUM3
     OCV81/D2PNORMC5       现货查询上海航欧                            Selet
    KBIC-240DS      现货查询上海航欧                         KB ELECTRONICS
    BES M08MG-GSC20B-BP00,3-GS04         现货查询上海航欧                            BALLUFF
    MCS11-G-S3-MCS 0.2-0.4        现货查询上海航欧                            MOELLER
    BES 516-324-SA33   现货查询上海航欧                            BALLUFF
    S15B1I1WABS000    现货查询上海航欧         422527              WARREN
    N01K550-M      现货查询上海航欧         084904              EUCHNER
    PSK-60C  0-600V    现货查询上海航欧                            DAIICHI
    5000-1503-003-0     现货查询上海航欧                            Helius
    5000-1502-002-0     现货查询上海航欧                            Helius
    5000-1522-001-0     现货查询上海航欧                            Helius
  • 胡光旭 在2025/12/10 16:20:00留言
  • 林小姐 在2025/11/27 16:54:00留言
  • 详细留言:采购MTE电容器MTECAP-283
  • 刘言 在2025/11/24 15:20:00留言
  • 详细留言:PBL6/VMP 38/5.TS.S
  • 在2025/11/19 14:10:00留言
  • 详细留言:温度探头 1*PT100/B
  • 官冰 在2025/10/31 13:30:00留言
