2023年WOHRLE工厂授权上海航欧中国区代理
上海航欧销售WOHRLE电源选型、WOHRLE单相电源选型WOHRLE不间断电源选型WOHRLE模块选型、WOHRLE继电器选型、WOHRLE开关选型根据客户需要提供系统定制解决方案
WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
主要型号:
ATS2-440-11-400;MS224009;PH120-1306;EPH231506;AV3-220-06-300;ANKA-V3-220-06-300;MS2-240-09-11-201;AV3-220-06-300WOHRLE航欧 WISUS-K-6主轴驱动
WOHRLE航欧 AKKU-SYS24180S
WOHRLE航欧 SW-200-01
WOHRLE航欧 USVWISUS-M(360-480kVA)
WOHRLE航欧 DPNW2420
WOHRLE航欧
Profibus-ConverteralsErg?nzungzumCS121-SCM;
WOHRLE航欧 DB-14C/SK2/PC/203/UB
WOHRLE航欧 USVWISUS-K(6-20kVA)
WOHRLE航欧 RS232-Kabel,9-polig
WOHRLE航欧 EPNSW240588-264VAC/24-28VDC5A
WOHRLE航欧 UGVC2412超级电容
WOHRLE航欧 EPNW2404
WOHRLE航欧 WOHRLE模块EDI-RED20UE?0,5V
WOHRLE航欧 DPNW2440
WOHRLE航欧 SNMP-AdapterCS121BudgetUniversal-Box
WOHRLE航欧 EPNW2405
WOHRLE航欧 UGV-LI2402
WOHRLE航欧 BE2405CY
WOHRLE航欧 EPNW1202
WOHRLE航欧 CS-121-SPI-2显示器和LCD显示器
WOHRLE航欧 UGVC2420超级电容
WOHRLE航欧 USVWISUS-M(25-480kVA)
WOHRLE航欧 Tiefentladeschutzbis100VDC
WOHRLE航欧 EPN233020/N
WOHRLE航欧 STS16
WOHRLE航欧 DPNW2410
WOHRLE航欧
SNMP-AdapterCS121SlotProfessionalmitModbus
WOHRLE航欧 AV4-240-06-100高压电源
WOHRLE航欧 EPNSW240185-264VAC/21,6-26,4VDC1A
WOHRLE航欧 SNMP-AdapterCS121BudgetSlot
WOHRLE航欧 SNMP-AdapterCS121SlotProfessional
WOHRLE航欧 EPNSW240285-264VAC/24-30VDC2,5A
WOHRLE航欧 ZPNW2405
WOHRLE航欧 AV3-220-06-300温度控制器
WOHRLE航欧 Entkoppeldiode
WOHRLE航欧 CS-121-BL编码器
WOHRLE航欧 BE2405CY24–29V
WOHRLE航欧 CONVERTVT1
WOHRLE航欧
EPNW240332430Ue=690VUimp=8kvLu=25A50/510HzIEC60439-1
熔断器开关WOHNER160ALTS-00
液晶面板WOHRLEANKANr.:ATS2-440-06-11-400SN:PN-100C0.4/3.090.75AMP
电源WOHRLEMP1001050364整流电源NGI402430Prim:3*400+5%1-3A
DISPLAYWOHRLEMP6121103022100COMMUNICATIONWITHPROCESSOR
备件WOHRLEEU-ANW-WD1/230230VS-NYH60146
配件WOHRLEANKAG50173AN:AV3-220-06-30024VDC0.4AVERS50.2
显示器WOHRLEMBF2-14C-21111100
操作显示屏WOHRLEANKAARTNR:AV3-220-06-30
显示器WOHRLEANKAART:AV3-240-06-300SN:K5.000424DC
操作箱WOHRLEANKAART.NR:ATS2-440-06-11-400SN:PN-10024VDC0.75AMP
配件WOHRLE21235DC24V20A继电器
备件WOHRLETPYE:ANKAARTNR:AV3-220-06-300SERNR:M50012
显示器WOHRLEANKAR4-02224VDC0.40AArtNO:AV3-220-06-300
显示器WOHRLEMC-09/SK2L-103序列号:10156
显示器WOHRLEATS2-440-06-11-400815-057-21
upsWOHRLE71144steinenbronnUNG402420prim3*400V±5%(A)
显示器WOHRLECB-09/SK2L-303ser-nr.K8-09290-260VAC
文本显示器WOHRLEAV3-220-06-300E6000424V/DC0.4AE0.2文本显示器
显示屏WOHRLEDB5-14C-3525AA-0221000SERNO:G8-008230V50/60HZ
显示屏WOHRLEDM-14C/SK20PCSERNO:12344/15220VAC50/60HZ显示屏
配件WOHRLE21295DC24V20A继电器
传感器WOHRLETYPE:ANKAARTNR:AV3-200-06-30024VDC
光学传感器WOLF&BECKOTM3A-20
光学传感器WOLF&BECKOTM3A-50
备件WOLFERD315M-4B
备件WOLFERD180L-4
备件WOLFERD112M-4
电机WOLFERDRKO200L-4B/SFB16HT30KWSN:156476
WOHRLE航欧 KA-USV-Typ01
WOHRLE航欧 DPN402480/W
WOHRLE航欧 DB5-1211AA-0221000CPU和处理器
WOHRLE航欧 CS-121-SC图表记录
WOHRLE航欧 BP/CON6k电子离合器,刹车模块
WOHRLE航欧 CS-121-Mini计时器
WOHRLE航欧 USVWISUS-M(25-320kVA)
WOHRLE航欧 wandeltMODBUSinProfibus
WOHRLE航欧 EPNW2410
WOHRLE航欧 EDI4021–28V
WOHRLE航欧 AV3-240-06-100
WOHRLE航欧
Akkumulatoren-Systembestehendaus2Akkumulatoren12V/18Ah,Halterung,Sicherung40A
WOHRLE航欧 AV3-240-09-300
WOHRLE航欧 EPNSW4810
WOHRLE航欧 WISUS-K-20
WOHRLE航欧 ZPNW2420
WOHRLE航欧 SW-100-01100A9,1VDC
WOHRLE航欧 CONVERT19KIT
WOHRLE电源 DB-12/SK2L/CP/200流量计
WOHRLE电源 USR244021–29V
WOHRLE电源 überwachungs-undSteuerbaugruppefür24VDCUSV-Anlagen
WOHRLE电源 UGVCM2420-100超级电容
WOHRLE电源 CP526CP581DB06WF470
WOHRLE电源 USVWISUS-G(30-120kVA)
WOHRLE电源 CONVERTVT3
WOHRLE电源 WISUS-K-10电子离合器,刹车模块
WOHRLE电源 EntkoppeldiodemitEingangsüberwachung
WOHRLE电源 SW-50-0150A9,1VDC
WOHRLE电源 AS2-440-06-11-00-00矢量驱动
WOHRLE电源 USVWISUS-M(25-480kVA)
WOHRLE电源 CONVERTVT6
WOHRLE电源 EPNSW240488-264VAC/24-30VDC4A
WOHRLE电源 MO12TC/20/U电源
WOHRLE电源 BS2-240-09-111-400HVAC控制系统
WOHRLE电源 CS-121-SCM模拟和数字电路板
WOHRLE电源 AV3-240-06-101数控机床控制
WOHRLE电源 EPNW2420
WOHRLE电源 EPNSW241088-264VAC/24-28VDC10A
WOHRLE电源 AV3-240-09-101离合器和制动器
2023年WOHRLE工厂授权上海航欧中国区代理DSLC PX VX
230V 现货查询上海航欧 VPM-VC V1.0 DUNGS
FM157E/C 现货查询上海航欧 WAIRCOM
4200-06-9243 现货查询上海航欧 SPARTAN
6P45C (孔径1"/ 1")货号:6P45C WITH 1.000 BORE WITH KEYWAY * WITH 1.000 BORE
WITH KEYWAY 现货查询上海航欧 6P45C-007-007-01 ZERO-MAX
H23204802253F 现货查询上海航欧 DYNAPAR
40MPG-1 1/2 现货查询上海航欧 RUBBERFAB
430-SS 现货查询上海航欧 MERCOTAC
XCSG500C 现货查询上海航欧 CABUR
MF1002P25NBP01 现货查询上海航欧 MP-FILTRI
AWI58X-082-300 现货查询上海航欧 HOHNER
00.79.0228 现货查询上海航欧 DALMEC
CLS-K-65/S 现货查询上海航欧 10042787 CLS1000-AI-NPN ELTROTEC
UBC10.241 现货查询上海航欧 PULS
AWI40X-008-120 现货查询上海航欧 HOHNER
PSR 230/24-1.3 现货查询上海航欧 PM-0124-020-0 BLOCK
99143781005 现货查询上海航欧 BINDER
223.2461.000 现货查询上海航欧 taconova
SO 50003-10-7 056.0031.180 现货查询上海航欧 SERTO
C1518PB00U6468 现货查询上海航欧 C1518PB00UOM RGS
KR-41B 现货查询上海航欧 lahti precision
TPL-300T-0-0-LS1-LP1(V0004130) 现货查询上海航欧 TPL-400T-0-0-LS1-LP1 lahti precision
CF/CB1-20 现货查询上海航欧 DIELL
PI 5205 PS VST 6 现货查询上海航欧 MAHLE
EM1-2-2048-I 现货查询上海航欧 US
DIGITAL
HUBDISK-2-2048-984-IE 现货查询上海航欧 US DIGITAL
ZWS-15/CD/QS 现货查询上海航欧 MICROSONIC
TB-1225 IM 24V GS d=40H7PN 现货查询上海航欧 WARNER
1DM401 现货查询上海航欧 HONEYWELL
FC90L-4 2.2kw 现货查询上海航欧 2212351 T2A90L4 2.2KW B5 220/380V 50HZ ELECTRO ADDA
E106DE45///20E 现货查询上海航欧 ACL
上海航欧销售WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
