  • brusatori马达VL 132 M 31 KW 02
  • 发布时间:2023/7/1 8:45:49   修改时间:2023/7/1 8:45:49 浏览次数:493
  •  2016brusatori工厂上海欧航中国区销售
    brusatori电机、brusatori马达、brusatori泵、brusatori配件
     上海航欧销售brusatori电机,brusatori马达
     brusatori电机,brusatori马达brusatoribrusatori配件
     2016
     主要型号:BR120,553
     BR140,871
     BR161,193
     BR221,160
     BR241,985
     BR262,415
     BR28343
     BR51221
     BR52442
     BR535,467
     BR546,993
     BR558,224
     BR569,358
     BR5710,482
     BR5811,506
     BR715,8228,1295
     BR72117515,448
     BR7315,32821,400
     BR7419,58127,353
     BR7522,53531,507
     BR76269236,464
     BR7730524225
     BR78341647,690
     BR82306248.026
     BR8457.14385.309
     BR8680.436115.612
     BR88105.754147.938
     BR9292.572120.787
     BR94179.369236.603
     BR96255.992338.251
     BR98332.914442.181
     Brushlessmotors-BRseries-EXPORT
     Validfrom01/01/2015to31/12/2015
     Prezzo
    FEEDBACK
    2 POLES RESOLVER Include
    2 POLES RESOLVER Included in the price above
    Incremental encoder EF36K6-1024-only for BR1 / BR2 0
    Incremental encoder 1024 ppr 0
    Incremental encoder 2048 ppr 0
    Incremental encoder 4096 ppr 0
    Incremental encoder ERN 1323 4096 ppr 36
    SinCos encoder Heidenhain ERN 1385 00
    EnDat encoder Heidenhain EQN 1325 25
    CONNECTORS
    Flying power connector for BR1 / BR2 3
    Flying signal connector for BR1 / BR2 3
    Flying power connector per BR3 / BR5 / BR7 5
    Flying signal connector per BR3 / BR5 / BR7 / BR8 / BR9 0
    Strip Phoenix clamps 5
    BRAKES
    Holding brake BR1 00
    Holding brake BR2 27
    Holding brake BR5 7
    Holding brake BR7 07
    Holding brake BR8 60
    Holding brake BR92/BR94 57
    Holding brake BR96/BR98 22
    FEET MOUNT
    Feet for BR5 5
    Feet for BR7 5
    Feet for BR8 1
    Feet for BR9 4
    PROTECTION DEGREE
    IP65 protection 0
    OBJ INSULATION SYSTEM
    BR5 10%
    BR7 8%
    BR8 5%
    BR9 4%
    SPECIAL SHAFT (After technical approval)
    Special shaft for BR5 1
    Special shaft for BR7 1
    Special shaft for BR8 15
    Special shaft for BR9 15
    VL 132 S 16 KW 95
    VL 132 M 21 KW 05
    VL 132 L 24 KW 18
    VL 132 P 30 KW 35
    VL 132 X 33 KW 30
    VL 160 S 40 KW 30
    VL 160 M 45 KW 02
    VL 160 L 49 KW 12
    VL 160 P 52 KW .012
    VL 180 S 64 KW 40
    VL 180 M 80 KW 80
    VL 180 L 88 KW 45
    VL 225 S 93 KW 80
    VL 225 M 130 KW 20
    VL 225 L 184 KW 10
    VL 280 S 270 KW 550
    VL 280 M 264 KW 645
    VL 280 L 342 KW 970VL 132 S 23 KW 94
    VL 132 L 34 KW 16
    VL 132 P 39 KW 35
    VL 132 X 42 KW 75
    VL 160 S 63 KW 80
    VL 160 M 71 KW 26
    VL 160 L 82 KW 72
    VL 160 P 88 KW .072
    VL 180 S 100 KW 32
    VL 180 M 124 KW 76
    VL 180 L 138 KW 50
    VL 225 S 144 KW 30
    VL 225 M 190 KW .065
    VL 225 L 280 KW .056
    VL 280 S 407 KW 585
    VL 280 M 401 KW 700
    VL 280 L 524 KW 900VL132 VL160 VL180 VL225 VL280
    -- 16 65 12 --
    Flange
    Mounting B3/B5 5 5 45 70
    Bearings
    VL 132 VL 160 VL180 VL225 VL280
    Ball bearing Std Std Std Std
    Insulated bearing -- 60 40 40 .074
    Brake (Motor IP54)
    K7 KTD K9 K9D K9D NIA63 NIA400
    VL 132 65 20
    VL 160 25 090
    VL 180 420
    VL 225 700
    VL 280
    Brake (Motor IP23)
    VL 132 08 60
    VL 160 056 260
    VL 180 415
    VL 225 700
    VL 280
    Feedback
    VFS60 - Incremental programmable encoder 15
    VT 71 M 0,37 2,5
    VT 71 L 0,63 4,0
    VT 80 S 0,75 3,8
    VT 80 L 1,1 5,1
    VT 90 S 1,5 10,1
    VT 90 L 2,2 14,8
    VT 90 P 3 20
    VT 90 X 4 25 920
    VT100A 4 25
    VT 100 S 6 38
    VT 100 M 7,5 46
    VT 100 L 8,5 54
    VT 100 P 10 60
    VT 132 S 11 72
    VT 132 M 17 110
    VT 132 L 22 143
    VT 132 P 28 176
  • 在2025/11/19 14:10:00留言
  • 详细留言:温度探头 1*PT100/B
  • 官冰 在2025/10/31 13:30:00留言
  • 侯杰 在2025/10/22 9:51:00留言
  • 详细留言:AWF95-12/VK
  • 在2025/9/23 14:11:00留言
