  • Dwyer流量传感器,Dwyer流量计
  • 发布时间:2021/9/19 9:02:18   修改时间:2021/9/19 9:02:18 浏览次数:653
  • Dwyer流量传感器,Dwyer流量计,Dwyer开关,Dwyer变送器,Dwyer风速计,Dwyer温度传感器
    Dwyer公司建立与1931年,在1955年时把制造总部从伊利诺斯州的芝加哥迁移到印第安纳州的密歇根市并建立起新的制造工厂和辅助设施.
    Dwyer Magnehelic2000-1.5KPA
    Dwyer ATH411-0-N
    Dwyer持式数字压力计475-000-FM
    Dwyer差压计2000-500PA
    Dwyer差压变送器605-2
    Dwyer TFS100L1GA4A8X,0-150cm/s;-20~70;1.0MPA
    Dwyer 1638-0
    Dwyer OEM2601G-74
    Dwyer SFI-100-MP-3/4
    Dwyer压力变送器679-64-20mA0-1250Pa
    Dwyer UFB-2230.1~10m/s±0.5%
    Dwyer RMB-55SSV-40
    Dwyer RMB-53SSV-20
    Dwyer RMB-53SSV-10
    Dwyer RANGE:0-500mmH2OMODEL:MP-020
    Dwyer压力开关SA1111E-S5-K2
    Dwyer压力开关1910-1Range0.40-1.6"w.c.
    Dwyer 2002D0-500Pa1/8"NPT
    Dwyer 2000-3KPA0-3000Pa1/8"NPT
    Dwyer Model:MP-020Range:0-20inw.c.
    Dwyer MS-131
    Dwyer Type:2002D
    Dwyer Type:2000-3KPA
    Dwyer RMB-55-SSV
    Dwyer RMB-54-SSV
    Dwyer RMB-53-SSV
    Dwyer压力开关1910-20
    Dwyer压力控制单元1950-10-2F
    Dwyer压力控制单元1950-1-2F
    Dwyer 477AV-7
    Dwyer ADPS-03-2-N0.2-2.0WC(50-500pa)
    Dwyer SGY-D11022N
    Dwyer 477-7-FM
    Dwyer DESPATCHFR0-35GPM
    Dwyer VFB-55-BV
    Dwyer DH-008
    Dwyer AT11910-0-AB2X
    Dwyer 2-5020-NPTN340MIMIHELICGAGE0~20INCHIESW.C.
    Dwyer差压开关Type:1950-0-2F
    Dwyer VFA-6-SSV
    Dwyer PHOTOHELIC30002-300mm.H2O)
    Dwyer DWYERINSTRUMENTSINCMICHIGANCITYIN46360USACAT.NO.1910-00PRESSURERATINGMAXPRESSUDwyer 628-18-CH-P1-E1-S1-LED0-3000PSI压力变送器
    Dwyer 1910-10压力开关
    Dwyer model607-8
    Dwyer 160159173526-00T23V
    Dwyer 013504RWB-54D-SSVT20V流量计
    Dwyer DM-2003-LCD压力变送器
    Dwyer 1626-20-wp
    Dwyer T33S-S70662401(1635-1-MIL)
    Dwyer RMA-16-SSV1000-10000CC/MIN)流量计
    Dwyer ADPS-03-2-N
    Dwyer RHP-2W44
    Dwyer RHP-2F11
    Dwyer V6EPB-B-S-LF
    Dwyer V6EPB-B-S-L-3-B
    Dwyer Type: A3000   Range. 0 to 300 mm H2O
    Dwyer FC01-U1R2C1 PUF-1002
    Dwyer VFA-3-SSV-VIT
    Dwyer VFA-3-VITDwyer    压力变送器           628-18-CH-P1-E1-S1-LED 0-3000PSI
    Dwyer      压力开关              1910-10
    Dwyer                  model 607-8
    Dwyer                  160159 173526-00     T23V
    Dwyer      流量计    013504  RWB-54D-SSV   T20V
    Dwyer      压力变送器           DM-2003-LCD
    Dwyer                  1626-20-wp
    Dwyer      流量计    RMA-16-SSV1000-10000CC/MIN)
    Dwyer                  ADPS-03-2-N
    Dwyer                  RHP-2W44
    Dwyer                  RHP-2F11
    Dwyer                  V6EPB-B-S-LF
    Dwyer                  VFA-3-SSV-VIT
    Dwyer                  VFA-3-VIT
    Dwyer                  VFA-6-SSV
    Dwyer                  DWYER INSTRUMENTS INC MICHIGAN CITY IN46360USA CAT.NO.1910-00 PRESSURE RATING  MAX PRESSURE 45 IN .W.C SURGE PRESSURE 10 PSI UNITS WITH CONDUIT ENCLOSURE AND COVER MEET TYPE 1SPECS DIAPHRAGM WERTICAL ELECT RATING 15A 125250480VAC,1/8HP 125VAC1/4HP250VAC附图
    Dwyer                  1" V6EPB-B-S-3-B
    Dwyer                  1/2" V6EPB-B-S-LF
    Dwyer      差压开关              1950-5-2F
    Dwyer                  AQTI-VP1
    Dwyer                  HM3531DLK300
    Dwyer                  SSM-04
    Dwyer                  Typ: V6EPB-B-S-2-B
    Dwyer                  fch31pdd03x
    Dwyer                  2000-3KPA
    Dwyer                  V6EPB BS2B
    Dwyer                  MP-002
    Dwyer                  2636200
    Dwyer                  7112-GC100
    Dwyer                  7112-GC010
    Dwyer                  7112-G200
    Dwyer                  8904
    Dwyer                  2000-1.5KPA
    Dwyer                  MS311/0-500pa
    Dwyer                  MS311/0-250pa
