北京因科思国际贸易有限公司
  • PXT Series Pressure Transmitters压力传感器
  • 发布时间:2008/12/4 15:36:08   修改时间:2008/12/4 15:36:08 浏览次数:1939
    The PXT Series Pressure Transmitters are state-of-the-art instruments providing a 4 to 20 mA output. They can be used in applications such as compressors, engines, process
    control, liquid level and pumps. They feature a precision micro-machined silicon diaphragm with a fully welded stainless steel pressure port for greater accuracy, stability and a wide
    range of compatibility.
     PXT-100: Pressure Transmitter
    The PXT-100 Pressure Transmitter is a state-of-the-art instrument providing a 4 to 20 mA output. The pressure range for this model is 0-100 psi (689 kPa) [6.89 bar].
    PXT-200: Pressure Transmitter
    The PXT-200 Pressure Transmitter is a state-of-the-art instrument providing a 4 to 20 mA output. The pressure range for this model is 0-200 psi (1.38 MPa) [13.78 bar].
     PXT-300: Pressure Transmitter
    The PXT-300 Pressure Transmitter is a state-of-the-art instrument providing a 4 to 20 mA output. The pressure range for this model is 0-300 psi (2.07 MPa) [20.67 bar].
    PXT-400: Pressure Transmitter
    The PXT-400 Pressure Transmitter is a state-of-the-art instrument providing a 4 to 20 mA output. The pressure range for this model is 0-400 psi (2.75 MPa) [27.56 bar].
     PXT-600: Pressure Transmitter
    The PXT-600 Pressure Transmitter is a state-of-the-art instrument providing a 4 to 20 mA output. The pressure range for this model is 0-600 psi (4.14 MPa) [41.34 bar].
北京因科思国际贸易有限公司是经中华人民共和国商务部批准成立的拥有自营进出口权的外贸企业。专业化从事工程机械、仪表、阀门、开关及工业控制产品的销售与服务。 经过多年的专业运作,我公司已与多家世界知名制造商建立了紧密的合作关系。同时…  更多>>
北京因科思国际贸易有限公司
联系人:杨健
地址:北京市朝阳区胜古中路2号金基业大厦201室
邮编:100029
电话:010-84282935,13910122694
传真:010-84288762
公司网址:http://www.increaseinc.cn
  • 吴文峰 在2018/12/3 9:57:00留言
  • 详细留言:argus球阀询价
  • 王力 在2014/12/15 17:53:00留言
  • 王建立 在2014/5/14 10:57:00留言
  • 详细留言:压力表 型号:25-1009-SW02L-1.6MPa ,品牌:Ashcroft
  • 尹先生 在2013/2/17 15:22:00留言
  • 详细留言:询: 原装进口罗茨风机真空泵 型号:16V-RA1-1 要求最大真空度50.8KPaV 真空量大于750mm3/h 能匹配15马力电机和SE-15型消音罩
