LBD serise 隔离信号变送器分配器正式量产
- 发布时间:2006/4/25 11:44:11
修改时间:2006/4/25 11:44:11 浏览次数:1887
Isolated Signal Transmitters/Splitters
FEATURE
◆ Measuring:DC Voltage,DC Current,thermocouple,potentiometer and so on.
◆ Accuracy:≤±0.2%R.O.
◆ Isolation:among input/output/power.
◆ Output:0~5V,0~10V,1~5V,2~10V,4~20Ma,0~20mA and so on.
◆ Power supply:AC/DC24~265V
◆ Light case,beautiful appearance,DIN rail 35mm,convenient fix.
SUMMARY
Series LBD isolated signal transmitters/splitters can make high accurate measurement of industrial
signal(current,voltage, thermocouple, potentiometer) ,isolate and transmit into standard analog output.It can directly connect pointer meters,digital display meters,sensors,and matches with automation meters(PLC),kinds of A/D converter,computer system.It use widely in machine field, electric field, telecom field,power field , petroleum field, chemical field ,steel field,sewage field,architecture electric field and so on.
SPECIFICATION
Accuracy ≤±0.2%R.O.
Input DC Voltage、DC Current、thermocouple、potentiometer and so on
linearity ≤±0.1%R.O.
Span adjustment ≤20%of R.O.
Zero adjustment ≤10%of R.O.
Electric isolation 1500Vdc(1min.) or AC parameter among input/output/power
Power supply AC/DC24~265V±10%
Power consumption AC about 4VA,DC about 4W
Respone time ≤400msec.
Operating Tem./Hum. -10~60℃/<95% relative humidity(non-condensing)
Storage Tem./Hum. -20~70℃/ <70% relative humidity(non-condensing)
Output ripple ≤0.2% of peak-peak parameter
Output load 0~10Vdc(load resistance=input voltage/10mA);
4~20mA(load resistance=10V/output current)
Case material ABS material
Mounting DIN rail 35mm
Case dimension 110(L)×23.5(W)×80(H)mm
Weight About 200g
OUTLINE DIMENSION
ADJUSTMENT
WIRING
ORDER INFORMATION
LBD - - - - -
Signal input Input range Output 1 Output 2
V:DC Votage V range V05:0~5V V05:0~5V
A:DC Current A range V010:0~10V V010:0~10V
T:thermocouple K J… T range V15:1~5V V15:1~5V
TP:thermocouple PT100 PM range V21:2~10V V21:2~10V
R:potentiometer A420:4~20mA A420:4~20mA
A020:0~20mA A020:0~20mA
A010:0~10mA A010:0~10mA
A01:0~1mA A01:0~1mA
Y:Specify Y:Specify
Code V range Code A range Code T range Code PM range
V05 0~5V A420 4~20mA A 0~100℃ R0 0~50Ώ
V010 0~10V A020 0~20mA B 0~200℃ R1 0~100Ώ
V15 1~5V A010 0~10mA C 0~400℃ R2 0~200Ώ
V21 2~10V A01 0~1mA D 0~800℃ R4 0~400Ώ
V060 0~60mV Y Specify E 0~1000℃ R5 0~1KΏ
V075 0~75mV F 0~1200℃ R6 0~2KΏ
V3 0~300V G 400~1600℃ R7 0~10KΏ
V6 0~600V Y Specify R8 10~100KΏ
Y Specify Y Specify
N:No AD:Aux.power
