防水金属电线保护软管,新铝合金防水接头:
构造:
*内管为镀锌金属软管,单扣或双扣,柔软度良好,抗压抗拉,提供机械保护
*外层为PVC披覆,防潮,防水。
NEW!!! 新铝合金防水接头 NEW!!!
应用:
*工厂、机械设备电源通信线路保护;
*汽车火车线路保护;
*公共设施线路保护;
*仪表,医疗设备线路保护
http://www.delikon.com
Liquidtight Flexible Conduits and NEW ALUMINUM connectors
( Protecting wiring in wet locations )
Liquid-tight conduit is ideal when used with liquid-tight fittings for applications where a high degree of liquid tightness is required. This product is suitable for a number of general purpose wiring applications and ideal for environments with lots of water, coolant, and vibrations such as machine tool workshops.
Aluminum Liquid-tight Connectors
This new line of connectors are made of high-quality forged aluminum for superior strength and durability. These unique configurations work perfectly with our whole range of flexible conduits and hoses. All forged connectors feature:
* All aluminum construction
* Totally re-useable
* Unique taper design for simple assembly and superior water tightness.
* Fixed or swivel type.
