上海纽沃柯电子科技有限公司
  • TEXAS-TMS320系列DSP -上海纽沃柯
  • 发布时间:2007/6/29 15:21:01   修改时间:2007/6/29 15:21:01 浏览次数:3867
  • 产品描述 型号 订货号
    Evaluation board for the TMS320C6201xx processor TMDS3260A6201 334-9809
    20 MIPS, 16-bit Fixed point DSP with 16K Flash, 12 PWM outputs, 16 Channel 10 bit ADC, 3 timers, 2 Serial ports, Pins/Package :132 PQFP TMS320F240PQ 316-7732
    20 MIPS, 16-bit Fixed point DSP with 8K Flash, 12 PWM outputs, 16 Channel 10 bit ADC, 3 timers, 2 Serial ports ,Pins/Package :68 PLCC TMS320F241FN 316-7756
    20 MIPS, 16-bit Fixed point DSP with 8K Flash, 8 PWM outputs, 8 Channel 10 bit ADC, 3 timers, 2 Serial ports ,Pins/Package :64 PQFP TMS320F241PG 316-7744
    20 MIPS, 16-bit Fixed point DSP with 8K Flash, 8 PWM outputs, 8 Channel 10 bit ADC, 2 timers, 2 Serial ports ,Pins/Package :144 PQFP TMS320F243PGE 316-7768
    40 MIPS, 16-bit Fixed point DSP with 8K Flash, 8 PWM outputs, 8 channel 10-bit ADC, 2 timers, 1 Serial port ,Pins/Package :64 PQFP TMS320LF2402APGA 509-9110
    40 MIPS, 16-bit Fixed point DSP with 16K Flash, 8 PWM outputs, 8 channel 10-bit ADC, 2 timers, 2 Serial port, SPI/SCI/CAN module ,Pins/Package :64 TQFP TMS320LF2403APAGA. 509-9122
    40 MIPS, 16-bit Fixed point DSP with 32K Flash, 16 PWM outputs, 16 channel 10-bit ADC, 4 timers, 2 Serial port, SPI/SCI/CAN module , TMS320LF2406APZA.. 509-9134
    40 MIPS, 16-bit Fixed point DSP with 32K Flash, 16 PWM outputs, 16 channel 10-bit ADC, 4 timers, 2 Serial port, SPI/SCI/CAN module, external memory interface ,Pins/Package :144 LQFP TMS320LF2407APGEA.. 509-9146
    60MIPS, 32-bit floating point, Hi performance DSP,Pins/Package :144 LQFP  TMS320VC33PGE-120 355-5951
    75MIPS, 32-bit floating point, Hi performance DSP,Pins/Package :144 LQFP  TMS320VC33PGE-150 355-5963
    100MIPS, 40-bit ALU, 16-bit memory fixed point advanced bus DSP,Pins/Package :144 TQFP TMS320VC549PGE-100 355-5987
    80mips, 40-bit ALU, 16-bit Memory fixed point advanced bus DSP ,Pins/Package :144 TQFP TMS320VC549PGE-80 355-5999
    100MIPS, 40-bit ALU, 16-bit Memory point advanced bus DSP ,Pins/Package :144 TQFP TMS320VC5409PGE-100 355-5975
    50 MIPS, 16-bit fixed point, low voltage with 2 timers, 2 Serial ports ,Pins/Package :144 LQFP  TMS320VC5401PGE50 509-9158
    160 MIPS, 16-bit fixed point, low voltage with 1 timer, 3 Serial ports ,Pins/Package :144 LQFP  TMS320VC5402APGE16 509-9160
    100 MIPS, 16-bit fixed point, low power, low cost DSP,Pins/Package :144 BGA TMS320VC5402GGU100 316-7781
    100 MIPS, 16-bit fixed point, low power, low cost DSP,Pins/Package :144 TQFP  TMS320VC5402PGE100 316-7770
    120 MIPS, 16-bit fixed point, low voltage with 2 timer, 3 Serial ports, Pins/Package :144 LQFP  TMS320VC5404PGE 509-9171
    160 MIPS, 16-bit fixed point, low voltage with 1 timer, 3 Serial ports ,Pins/Package :144 LQFP  TMS320VC5410APGE16 509-9183
    100 MIPS, 16-bit fixed point, low power DSP,Pins/Package :176 BGA TMS320VC5410GGW100 316-7800
    100 MIPS, 16-bit fixed point, low power DSP, Pins/Package :144 TQFP  TMS320VC5410PGE100 316-7793
    1600 MIPS, 200MHz High Performance 32-bit fixed point DSP,Pins/Package :16mm 288 BGA TMS320C6204GHK200 509-9201
    1200 MIPS, 150MHz High Performance 32-bit fixed point DSP, Pins/Package :27mm 256 BGA TMS320C6211BGFN150 509-9195
    900 MFLOPS, 150MHz High Performance 32-bit floating point DSP,Pins/Package :27mm 256 BGA  TMS320C6711BGFN150. 509-9213
    1200 MFLOPS, 200MHz High Performance 32-bit floating point DSP ,Pins/Package :28mm 208 TQFP TMS320C6713PYP200 509-9225
    产品目录链接如下,敬请点击查看:
    http://www.newark.com/jsp/content/printCatalog.jsp?cat=cat124&page=1&display=single
    TYCO产品专辑目录链接如下,请点击查看:
    http://www.newark.com/jsp/content/printCatalog.jsp?cat=tyco&page=1&display=single
    Farnell-Newark部分产品特价回馈客户,全新产品,上海现货库存,欢迎查询订购。
    具体特价产品链接如下:http://www.vanking.cn/cp.php?nowmenuid=101411
    请登陆我司网站的"产品查询"栏,进入"NEWARK INONE电子产品世界"和"FARNELL INONE电子产品世界"搜索您需要的产品。
    通过我们的服务,您将轻松购买超过25万种世界知名品牌的电子元器件
    我们的服务特点:
    不设最小订购数量 不设最低订货金额  上海库存2-3日送达 国外库存7-10日送达
上海纽沃柯电子科技有限公司
联系人:魏先生
地址:万源路788弄32号202室
邮编:201103
电话:QQ:1003000751 13501905617
传真:021-34228879
公司网址:http://www.vanking.cn
  • 黎浩 在2023/12/22 8:33:00留言
  • 详细留言:帮客户询价
  • 在2023/7/27 11:11:00留言
  • 详细留言:MHP1400R010F*18PCS
  • 在2023/3/2 17:44:00留言
  • 杨女士 在2022/11/8 16:08:00留言
  • 伍余华 在2022/2/11 22:05:00留言
  • 详细留言:TYCO FLHTCO311-14-2
