英国HEPCO轴承
英国HEPCO是世界上线形转动行业的领头军,HEPCO产品可以满足现今自动化控制及工业市场的数千种。我们生产各种各样的V形导轨,欧动产品,滚珠丝杠,齿条,小齿轮及全套的机械桶架,HEPCO可以供应优质的HEPCO流水系统,提供给用户全套机械的所有解决方案。
HEPCO产品特点:
1、在恶劣环境下的高可靠性;
2、减小机器下降的时间,提高底轨运转的效率;
3、可以在高速的环境下安全可靠的工作更长的时间;
4、噪音低;
5、广范围的系统包装及装配,设计简单;
上海秋腾贸易有限公司专业销售HEPCO产品:轴承,HEPCO偏心轴承,HEPCO同心轴承,HEPCO轴承罩,单列超薄轴承,环形导轨,循环导轨,滚珠丝杆,齿条、小齿轮,HEPCO滑轨,减震器,自动滑行汽缸,重载组合型轴承,重载紧密柱
HEPCO Products
Hepco Group - Hepco
HEPCO Linear guide GV3 Series
HEPCO Linear guide Simple Select? Series
HEPCO Heavy duty linear guide HDS2 Series
HEPCO Heavy duty linear guide HDCB Series
HEPCO Stainless steel linear guide SL2 Series
HEPCO Recirculating ball-bearing telescopic slide max. 280 kg | HTS Series
HEPCO Aluminum profile MCS Series
HEPCO Ball screw BSP Series
HEPCO Linear roller guide max. 6 m/s | MHD Series
HEPCO Linear ball guide LBG Series
HEPCO Precision ring and track guide HDRT Series
HEPCO Linear actuator DAPDU2 Series
HEPCO Motorized linear guide HEPCO
HEPCO Heavy duty linear drive unit HEPCO
HEPCO max. 10 000 N, max. 6 m/s | HDLS Series
HEPCO Guided screw actuator PSD Series
HEPCO Linear drive unit with ball screw drive HDCS Series
HEPCO Driven ring and track guide system DTS Series
HEPCO Shock absorber SH Series
HEPCO Belt driven actuated linear guide SBD Series
HEPCO Belt driven actuated linear guide PDU2 Series
HEPCO Precision ring and track guide PRT Series
HEPCO Rodless pneumatic cylinder HPS Series
