德国WOERNER分配器
德国WOERNER致力于研发、制造并且推广先进的润滑技术。WOERNER努力为相当一部分客户的优质主机显著延长了使用寿命,或者达到了原本不可能达到的功能。凭借WOERNER强大的创新能力和对客户贴心周到的服务, WOERNER公司已成为全球领先的润滑设备供应商。
WOERNER产品包括各种类型的润滑元件、润滑系统,以及各类根据客户特殊工况而特别设计的润滑系统。WOERNER为全球客户奉献从润滑系统方案咨询、系统设计、产品提供、现场安装以及售后技术支持等一系列服务。
上海秋腾贸易代理销售德国WOERNER润滑泵,WOERNER油气分配器,WOERNER温度控制器,WOERNER液位计,WOERNER齿轮泵,WOERNER阀,WOERNER液压开关等全系列产品,价格优惠,欢迎来电咨询!
Dosing pumps :
Dosing Pumps are pumps with one or or more plungers. When activated by an e.g. solenoid, lubricant is delivered at each oulet.
Single-line pumps :
Single-Line Pumps are pumps which are either driven by an electric motor, hydraulicly, pneumatically or manually.After the pumping operation has been completed, the delivery line is relieved.
Drum pumps:
Barrel Pumps pump directly from a barrel. The Barrel-Pump can be used as a delivery pump i.e. lubricant is delivered directly into the lubrication system, or as a refill pump.
Manual pumps:
Hand pumps are operated manually. There are different requirements for these with regards to pressure, volume and resistance to chemicals.
Multi-line lubrication pumps:
Multi-Line pumps are pumps with more than one outlet. Lubricant volumes can be adjusted individually at every outlet.
Lubricant feeder:
Lubricators are compact battery powered pumps, complete with electronic control and monitoring to lubricate of a few lubrication points.
Gear-type pumps:
