压力传感器和压力变送器
易福门全国经销 IFM 全国 销售 选型及技术参数
华东区: 张龙刚13817798194
邮箱:zlgsh@hotmail.com
G 1 A / Aseptoflex vario V4A -1,00...10,00 bar /
-14,5...145,0 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2794
G 1 A / Aseptoflex vario V4A -1,000...4,000 bar /
-14,50...58,00 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2795
G 1 A / Aseptoflex vario V4A -0,124...2,5 bar /
-1,8...36,27 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2796
G 1 A / Aseptoflex vario V4A -0,05...1 bar /
-0,73...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2797
G 1 A / Aseptoflex vario V4A -12,4...250,0 mbar /
-5,0...100,4 inH2O M12 DC PNP/NPN 3A cULus EHEDG FDA PG2798
G 1 A / Aseptoflex vario V4A -1...1 bar /
-14,5...14,5 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2799
G 1 A / Aseptoflex vario V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2793
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2794
-14,50...58,00 PSI /
-100,0...400,0 kPa M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2795
G 1 A / Aseptoflex vario V4A -1000...1000 mbar /
-14,5...14,5 PSI M12 2线DC / 3线DC PNP/NPN 3A cULus EHEDG FDA PI2799
压力传感器和压力变送器
设计 输出功能 许可证 订购编号
Aseptoflex 过程连接 V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP 3A cULus EHEDG FDA PIM093
Aseptoflex 过程连接 V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP 3A cULus EHEDG FDA PIM094
G 1 A V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP 3A cULus EHEDG FDA PIM693
G 1 A V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP 3A cULus EHEDG FDA PIM694
G ? I V4A -1000...0 mbar M12 DC PNP
cULus PE3029
G ? I V2A -1000...1000 mbar M12 DC PNP/NPN cULus PE7009
Aseptoflex 过程连接 V4A -1,0...25 bar /
-15...363 PSI /
-0,1...2,5 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2053
G 1 A V4A -0,99...1,00 bar /
-30...30 inHg /
-99...100 kPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2609
G 1 A V4A -1,0...100 bar /
-10...1450 PSI /
-0,10...10,0 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PF2652
G 1 A V4A -1,0...25 bar /
-15...363 PSI /
3A cULus EHEDG FDA PF2653
G ? A V4A -1,0...25 bar /
-15...363 PSI /
cULus FDA PF2953
G12 V4A -1...1 bar /
-14,52...14,52 PSI M12 DC PNP/NPN cULus PG2409
G12 V4A -1...25 bar /
-14,5...362,5 PSI M12 DC PNP/NPN cULus PG2453
G12 V4A -1...10 bar /
-14,4...145 PSI M12 DC PNP/NPN cULus PG2454
G12 V4A -1...4 bar /
-14,5...58 PSI M12 DC PNP/NPN cULus PG2455
G12 V4A -0,125...2,5 bar /
-1,8...36,25 PSI M12 DC PNP/NPN cULus PG2456
G12 V4A -0,05...1 bar /
-0,72...14,5 PSI M12 DC PNP/NPN cULus PG2457
G12 V4A -12,5...250 mbar /
-5,0...100,4 inH2O M12 DC PNP/NPN cULus PG2458
G12 V4A -5...100 mbar /
-2,00...40,16 inH2O M12 DC PNP/NPN cULus PG2489
G 1 A / Aseptoflex vario V4A -5,0...100,0 mbar /
-2,0...40,15 inH2O M12 DC PNP/NPN 3A EHEDG FDA PG2789
-14,4...362,7 PSI M12 DC PNP/NPN 3A cULus EHEDG FDA PG2793
G 1 A V4A -5,0...100,0 mbar /
-2,0...40,15 inH2O M12 DC PNP/NPN cULus EHEDG PG2889
-14,4...362,7 PSI M12 DC PNP/NPN cULus EHEDG PG2893
-14,5...145,0 PSI M12 DC PNP/NPN cULus EHEDG PG2894
G 1 A V4A -1,000...4,000 bar /
-14,50...58,00 PSI M12 DC PNP/NPN cULus EHEDG PG2895
G 1 A V4A -0,124...2,5 bar /
-1,8...36,27 PSI M12 DC PNP/NPN cULus EHEDG PG2896
G 1 A V4A -0,05...1 bar /
-0,73...14,5 PSI M12 DC PNP/NPN cULus EHEDG PG2897
G 1 A V4A -12,4...250,0 mbar /
-5,0...100,4 inH2O M12 DC PNP/NPN cULus EHEDG PG2898
G 1 A V4A -1...1 bar /
-14,5...14,5 PSI M12 DC PNP/NPN cULus EHEDG PG2899
SPA-Varivent 型号N V4A -1,00...10,00 bar /
-14,5...145,0 PSI M12 DC PNP/NPN PH4004
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2694
-100,0...400,0 kPa M12 DC PNP/NPN
3A cULus EHEDG FDA PI2695
G 1 A V4A -1000...1000 mbar M12 DC PNP/NPN
3A cULus EHEDG FDA PI2699
-14,4...362,7 PSI /
-14,5...145,0 PSI /
G ? A V4A -1,00...25,00 bar /
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN
cULus FDA PI2993
G ? A V4A -1,00...10,00 bar /
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP/NPN
cULus FDA PI2994
G ? A V4A -1,000...4,000 bar /
cULus FDA PI2995
G ? A V4A -50...1000 mbar M12 DC PNP/NPN
cULus FDA PI2997
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI7093
-14,5...145,0 PSI /
-0,100...1,000 MPa M12 DC PNP/NPN 3A cULus EHEDG FDA PI7094
-14,4...362,7 PSI /
-0,100...2,500 MPa M12 DC PNP/NPN cULus FDA PI7993
G ? I V2A -1000...0 mbar M12 DC PNP
ATEX 3D PN009A
G ? I V2A -1000...1000 mbar /
cULus PN2009
?" NPT V2A -14,5...14,5 PSI M12 DC PNP/NPN
cULus PN2209
cULus PN3029
G ? I V2A -1000...1000 mbar M12 DC PNP/NPN cULus PN7009
?" NPT V2A -14,5...14,5 PSI /
-1000...1000 mbar M12 DC PNP/NPN cULus PN7209
G 1/8 I V2A -1000...1000 mbar /
-14,5...14,5 PSI /
-100...100 kPa M12 DC PNP/NPN cULus PN7809
G 1/8 I V2A -1...10 bar /
-14,5...145 PSI /
-0,1...1,0 MPa M12 DC PNP/NPN cULus PN7834
G 1/8 I V2A -1...1 bar M8 DC NPN cULus PQ0809
G 1/8 I V2A -1...10 bar M8 DC NPN cULus PQ0834
G 1/8 I V2A -1...1 bar M8 DC PNP cULus PQ7809
G 1/8 I V2A -1...10 bar M8 DC PNP cULus PQ7834
G 1 A V4A -1,0...150,0 bar M12 DC PNP/NPN
EHEDG FDA PY2692
测量范围 设计 输出功能 许可证 订购编号
cULus PE3029
ATEX 3D PN009A
cULus PN2209
cULus PN3029
许可证 订购编号
-30...30 inHg /
Aseptoflex 过程连接 V4A -1000...1000 mbar M12 DC PNP/NPN
3A cULus EHEDG FDA PI2099
cULus FDA PI2997
cULus PN2009
-14,5...14,5 PSI /
-100...100 kPa M12 DC PNP/NPN 易福门全国经销 IFM 全国 销售 选型及技术参数
华东区: 张龙刚13817798194
邮箱:zlgsh@hotmail.com cULus PN7809
范围 设计 输出功能 许可证 订购编号
-14,4...362,7 PSI /
-14,5...145,0 PSI /
许可证 订购编号
-14,4...362,7 PSI /
-14,5...145,0 PSI /
许可证 订购编号
FDA ATEX 3G ATEX 3D PI003A
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2093
-14,5...145,0 PSI /
3A cULus EHEDG FDA PI2094
Aseptoflex 过程连接 V4A -1,000...4,000 bar /
3A cULus EHEDG FDA PI2095
G 1 A V4A -1,0...100,0 bar /
-15...1450 PSI /
-0,10...10,00 MPa M12 DC PNP/NPN
3A cULus EHEDG FDA PI2692
-14,4...362,7 PSI /
3A cULus EHEDG FDA PI2693
-14,5...145,0 PSI /
华东区: 张龙刚13817798194
