上海自动有限公司
  • 易福门IFMPG2795
  • 发布时间:2011/10/24 16:09:38   修改时间:2011/10/24 16:09:38 浏览次数:962
  • 易福门全国经销     IFM   全国 销售 华东区: 张龙刚13817798194
    -5,0...100,4 inH2O    M12       DC PNP/NPN         cULus      PG2458
        G ? A    V4A    -5...100 mbar /
    -2,00...40,16 inH2O    M12       DC PNP/NPN         cULus      PG2489
        G 1 A / Aseptoflex vario    V4A    -5,0...100,0 mbar /
    -2,0...40,15 inH2O    M12       DC PNP/NPN         3A EHEDG FDA      PG2789
        G 1 A / Aseptoflex vario    V4A    -1,00...25,00 bar /
    -14,4...362,7 PSI    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2793
        G 1 A / Aseptoflex vario    V4A    -1,00...10,00 bar /
    -14,5...145,0 PSI    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2794
        G 1 A / Aseptoflex vario    V4A    -1,000...4,000 bar /
    -14,50...58,00 PSI    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2795
        G 1 A / Aseptoflex vario    V4A    -0,124...2,5 bar /
    -1,8...36,27 PSI    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2796
        G 1 A / Aseptoflex vario    V4A    -0,05...1 bar /
    -0,73...14,5 PSI    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2797
        G 1 A / Aseptoflex vario    V4A    -12,4...250,0 mbar /
    -5,0...100,4 inH2O    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2798
        G 1 A / Aseptoflex vario    V4A    -1...1 bar /
    -14,5...14,5 PSI    M12       DC PNP/NPN         3A cULus EHEDG FDA      PG2799
        G 1 A    V4A    -5,0...100,0 mbar /
    -2,0...40,15 inH2O    M12       DC PNP/NPN         cULus EHEDG      PG2889
        G 1 A    V4A    -1,00...25,00 bar /
    -14,4...362,7 PSI    M12       DC PNP/NPN         cULus EHEDG      PG2893
        G 1 A    V4A    -1,00...10,00 bar /
    -14,5...145,0 PSI    M12       DC PNP/NPN         cULus EHEDG      PG2894
        G 1 A    V4A    -1,000...4,000 bar /
    -14,50...58,00 PSI    M12       DC PNP/NPN         cULus EHEDG      PG2895
        G 1 A    V4A    -0,124...2,5 bar /
    -1,8...36,27 PSI    M12       DC PNP/NPN         cULus EHEDG      PG2896
        G 1 A    V4A    -0,05...1 bar /
    -0,73...14,5 PSI    M12       DC PNP/NPN         cULus EHEDG      PG2897
        G 1 A    V4A    -12,4...250,0 mbar /
    -5,0...100,4 inH2O    M12       DC PNP/NPN         cULus EHEDG      PG2898
        G 1 A    V4A    -1...1 bar /
    -14,5...14,5 PSI    M12       DC PNP/NPN         cULus EHEDG      PG2899
        Varivent 型号N    V4A    -1,00...10,00 bar /
    -14,5...145,0 PSI    M12       DC PNP/NPN               PH4004
            输出功能    许可证    订购编号
        G ? I    V2A    0...600 bar    M12       AS-i               PPA060
        G ? I    V2A    0...600 bar    M12       DC               PA3060
        G ? I    V2A    0...600 bar    M12       DC               PA9060
        G ? I    V2A    0...600 bar    M12       DC               PX9060
    输出功能    许可证    订购编号
        G ? I    V2A    0...100 bar    M12       DC         cULus      PA3022
        ?" NPT    V2A    0...100 bar    M12       DC         cULus      PA3222
        G ? A / M5 I    V2A    0...100 bar    M12       DC         cULus      PA3522
        G ? I    V2A    0...100 bar    M12       DC         cULus      PA9022
        G ? A / M5 I    V2A    0...100 bar    M12       DC         cULus      PA9522
        G ? A    V4A    0...100 bar    M12       DC         cULus      PC3542
        G ? A / M5 I        0...100 bar /
    0...1450 PSI    M12       DC PNP         cULus      PK5522
        ?" NPT A / M5 I    V4A    0...100 bar /
    0...1450 PSI    M12       DC PNP         cULus      PK6222
        G ? A / M5 I    V4A    0...100 bar /
    0...1450 PSI    M12       DC PNP         cULus      PK6522
    0...10 MPa    M12       DC PNP         cULus      PK6532
        R ? A / M5 I    V4A    0...100 bar /
    0...10 MPa    M12       DC PNP         cULus      PK6732
    0...1450 PSI    M12       DC PNP         cULus      PK7522
    0...10 MPa    M12       DC NPN         cULus      PK8732
        G 1 A    V4A    -1...100 bar /
    -10...1450 PSI /
    -0,1...10 MPa    M12       3线DC ; 2线DC         3A cULus EHEDG FDA      PL2652
        G ? A / M5 I    V2A    0...100 bar /
    0...1450 PSI /
    0...10 MPa    M12       DC PNP         e1      PP002E
    0...1450 PSI /
    0...10 MPa    M12       DC NPN         cULus      PP0522
    0...1450 PSI /
    0...10 MPa    M12       DC PNP         cULus      PP7552
        G ? A    V4A    0...100 bar    M12       DC         cULus      PT3542
        G ? A    V4A    0...100 bar    M12       DC         cULus      PT3552
        G ? A    V4A    0...100 bar    M12       DC         cULus      PT9542
        G ? A    V4A    0...100 bar    M12       DC         cULus      PT9552
        G ? I    V4A    0...35 bar    M12       DC         cULus      PX9973施克SICk选型及技术参数
    华东区: 张龙刚13817798194
    易福门全国经销     IFM   全国 销售
    易福门全国总经销     IFM   全国 销售
    易福门全国总经销     IFM   全国 销售
    易福门全国总经销     IFM   全国 销售
    易福门全国总经销     IFM   全国 销售
        通用转接头    V4A    V4A    M12       DC NPN     否    否    cULus      SI5001
        通用转接头    V4A    V4A    M12       DC PNP     否    否    cULus      SI5002
        通用转接头    V4A    V4A    M12       DC NPN     否    否    cULus      SI5003
        通用转接头    V4A    V4A    M12       DC     否    否    cULus      SI5004
        通用转接头    V4A    V4A    1/2"       AC / 继电器     否    否    cULus      SI5006
        通用转接头    V4A    V4A    M12       DC PNP     是    否    cULus      SI5007
        通用转接头    V4A    V4A    M12       DC PNP     否    否    ATEX 3G ATEX 3D      SI500A
        通用转接头    V4A    V4A    M12       DC PNP     否    否    cULus      SI5010
        通用转接头    V4A    V4A    M12       DC NPN     否    否    cULus      SI5011
        通用转接头    V4A    钛    M12       DC PNP     否    否          SI5100
        许可证    订购编号
        ? 10 mm    V4A    V4A    M12       连接控制显示器     否    否    cULus      SF6200
        ? 10 mm    V4A    V4A    M12       连接控制显示器     否    否    cULus      SF6201
        ? 10 mm    V4A    V4A    M12       连接控制显示器     否    否    ATEX 2G      SF620A
    控    许可证    订购编号
        ? 23 mm    塑料    钛    2 m       AC/DC     否    否          SL0101
        ? 23 mm    塑料    钛    6 m       AC/DC     否    否          SL0105
        ? 23 mm    塑料    钛    2 m       AC/DC     否    否          SL0106
        ? 23 mm    塑料    钛    2 m       AC     否    否          SL0201
        ? 23 mm    塑料    钛    2 m       AC/DC     否    否    CSA      SL0301
        ? 23 mm    塑料    钛    2 m       DC     否    否          SL5101
    功能    许可证    订购编号
        G ? A    V4A    -1...1 bar /
    -14,52...14,52 PSI    M12       DC PNP/NPN         cULus      PG2409
        G ? A    V4A    0...400 bar /
    0...5800 PSI    M12       DC PNP/NPN               PG2450
        G ? A    V4A    0...250 bar /
    0...3625 PSI    M12       DC PNP/NPN         cULus      PG2451
        G ? A    V4A    0...100 bar /
    0...1449 PSI    M12       DC PNP/NPN         cULus      PG2452
        G ? A    V4A    -1...25 bar /
    -14,5...362,5 PSI    M12       DC PNP/NPN         cULus      PG2453
        G ? A    V4A    -1...10 bar /
    -14,4...145 PSI    M12       DC PNP/NPN         cULus      PG2454
        G ? A    V4A    -1...4 bar /
    -14,5...58 PSI    M12       DC PNP/NPN         cULus      PG2455
        G ? A    V4A    -0,125...2,5 bar /
    -1,8...36,25 PSI    M12       DC PNP/NPN         cULus      PG2456
        G ? A    V4A    -0,05...1 bar /
    -0,72...14,5 PSI    M12       DC PNP/NPN         cULus      PG2457
        G ? A    V4A    -12,5...250 mbar /
TO:采购 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士 罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO 西门子仪器仪表 销售:张龙刚 手机:13817798194 邮箱:zlgsh@hotmail.com 价格优惠!…  更多>>
上海自动有限公司
联系人:张龙刚
地址:上海松江区
邮编:201613
电话:13817798194
公司网址:http://xhzlg.b2b.youboy.com
  • Ferenc Nagy 在2024/11/29 23:20:00留言
  • 详细留言:RFQ 1-2 x Sick SCS70HLA0K01 ID: 1034069
  • 明小姐 在2015/3/26 16:05:00留言
  • 详细留言:还看了HYDAC给水泵:http://www.hydac-zh.com/gsb/ 贺德克给水泵:http://www.hydac-zh.com/gsb/ 给水泵:http://www.hydac-zh.com/gsb/ 贺德克轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ HYDAC轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 贺德克内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ HYDAC内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ 内齿轮油泵:http://www.hydac-zh.com/nniclb/ 贺德克外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ 外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC压力传感器:http://www.hydac-zh.com/ylcgq/ 贺德克压力传感器:http://www.hydac-zh.com/ylcgq/
  • 王力 在2014/12/10 18:16:00留言
  • 梁先生 在2014/7/17 9:23:00留言
  • 详细留言:流量传感器0-15ml/min
  • 荣玉成 在2014/4/15 14:14:00留言
  • 详细留言:压力传感器:范围不+-20Pa 范围0-50Pa 电压24VDC 电流4-20mA
