上海自动有限公司
  • 易福门SF6200
  • 发布时间:2011/10/8 14:19:27   修改时间:2011/10/8 14:19:27 浏览次数:799
  • 易福门SF6200 -13...176 [°F]    1...10    —    —    SF5200
    3...300 [cm/s]
    5...590 [ft/min]    200...3000 [cm/s]
    393...5905 [ft/min]    3...60 [cm/s]
    5...118 [ft/min]    200...800 [cm/s]
      华东区: 销售张龙刚  13817798194 邮箱:zlgsh@hotmail.com
    393...1574 [ft/min]    -25...80 [°C]
    -13...176 [°F]    1...10    —    —    SF5201
    3...300 [cm/s]
    -13...176 [°F]    1...10    —    —    SF5700
    型号 SFD ? 用于适配器的内螺纹M18 x 1.5 ? PUR电缆
        3...300 [cm/s]
    -13...176 [°F]    1...10    —    —    SF5350
    型号 SFD ? 用于适配器的内螺纹M18 x 1.5 ? 硅镀层电缆
    SF5301    3...300 [cm/s]
    393...1574 [ft/min]    0...120 [°C]
    32...248 [°F]    1...10    —    —    SF5301
        3...300 [cm/s]
    32...248 [°F]    1...10    —    —    SF5300
    3...300 [cm/s]
    32...248 [°F]    1...10    —    —    SF5800
    型号 SFG ? ? 10 mm ? M12接插件
        3...300 [cm/s]
    393...1574 [ft/min]    -20...70 [°C]
    -4...158 [°F]    1...10    —    —    SF620A
    3...300 [cm/s]
    -13...176 [°F]    1...10    —    —    SF6200
    3...300 [cm/s]
    -13...176 [°F]    1...10    —    —    SF6201
    -13...176 [°F]    1...2 / 1...10 *    19...36 DC    60    SI5011
    型号 SID ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件 ? DC PNP ? 输出功能 2x 可选
        3...300 [cm/s]
    393...5905 [ft/min]    3...100 [cm/s]
    5...196 [ft/min]    200...800 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI0556
    3...300 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI5002
    3...300 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI5007
    型号 SID ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件 ? DC PNP ? 输出功能 可选
        3...300 [cm/s]
    -13...176 [°F]    1...10    20...36 DC     80    SI0508
        3...300 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI5000
    3...300 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI500A
    3...300 [cm/s]
    -13...176 [°F]    1...10    48 DC - 10 %    40    SI0555
        3...300 [cm/s]
    -13...176 [°F]    1...2 / 1...10 *    19...36 DC    60    SI5010
    3...300 [cm/s]
    -13...176 [°F]    1...2 / 1...10 *    19...36 DC    60    SI5100
            [s]    [V]
    型号 SLG ? mm ? PUR / PVC-电缆 ? AC/DC ? 输出功能1x 继电器
        100...1000 [cm/s]
    196,85...1968,5 [ft/min]    100...400 [cm/s]
    196,85...787,4 [ft/min]    1 [bar]
    14,51 [psi]    3...60     80...250 AC/DC     SL0101
    100...1000 [cm/s]
    14,51 [psi]    3...60     80...250 AC/DC     SL0105
    100...1000 [cm/s]
    14,51 [psi]    3...60     80...250 AC/DC     SL0106
    型号 SLG ? mm ? PUR / PVC-电缆 ? DC ? 输出功能1x 继电器
        100...1000 [cm/s]
    14,51 [psi]    3...60    24 DC ± 25 %    SL5101
    100...1000 [cm/s]
    14,51 [psi]    3...60    24 DC ± 25 %    SL5105
    型号 SLG ? mm ? PUR / PVC-电缆 ? DC ? 输出功能3UTH34
        100...1000 [cm/s]
    14,51 [psi]    3...60    24 DC ± 25 %    SL5102
    型号 SLG ? mm ? PUR电缆 ? AC ? 输出功能1x 继电器
        100...1000 [cm/s]
    14,51 [psi]    3...60    24 AC    SL0201
    型号 SLG ? mm ? PUR电缆 ? AC/DC ? 输出功能1x 继电器
        100...1000 [cm/s]
    14,51 [psi]    3...60    80...250 AC/DC     SL0301
    型号 SLG ? mm ? 带接插件M18的电缆 ? DC ? 输出功能 0...10 V模拟
        3...300 [cm/s]
    3...300 [cm/s]
    3...300 [cm/s]
        3...300 [cm/s]
    3...300 [cm/s]
                    [s]    [V]    [mA]
    型号 SIS ? 用于Aseptoflex适配器 ? M12接插件 ? DC PNP ? 输出功能 可选
        3...300 [cm/s]
    393...1574 [ft/min]    -25...95 [°C]
    -13...203 [°F]    1...10    19...36 DC    60    SI6100
        3...300 [cm/s]
    -13...203 [°F]    1...10    19...36 DC    60    SI6200
                 [s]    [V]    [mA]
    型号 SIR11 ? G1 / Aseptoflex Vario ? M12接插件 ? DC PNP ? 输出功能 可选
        3...300 [cm/s]
    -13...203 [°F]    1...10    19...36 DC    60    SI6600
        3...300 [cm/s]
    -13...203 [°F]    1...10    19...36 DC    60    SI6700
        3...300 [cm/s]
    -13...203 [°F]    1...10    19...36 DC    60    SI6800
     型号    液体设定范围    气体设定范围    用于液体最大灵敏度时的测量范围    用于气体最大灵敏度时的测量范围    介质温度    反应时间    工作电压    耗用电流    订购编号
                            [s]    [V]    [mA]
    型号 ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件 ? DC PNP ? 输出功能 可选
        3...300 [cm/s]
    -13...176 [°F]    1...2 / 1...10 *    19...36 DC    60    SI0553
    型号 SAE ? ? M12接插件 ? DC PNP/NPN ? 输出功能5GQDTM
        —    —    —    —    0...80 [°C]
    32...176 [°F]    5 (10%...90%)    20...28 DC    80    SA3010
    型号 SID ? 用于适配器的内螺纹M18 x 1.5 ? 1/2" UNF接插件 ? AC / 继电器 ? 输出功能 可选
        3...300 [cm/s]
    -13...176 [°F]    1...10    85...265 AC    —    SI1106
        3...300 [cm/s]
    -13...176 [°F]    1...10    85...265 AC    —    SI5006
    型号 SID ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件 ? DC NPN ? 输出功能 2x 可选
        3...300 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI5003
    型号 SID ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件 ? DC NPN ? 输出功能 可选
        3...300 [cm/s]
    -13...176 [°F]    1...10    19...36 DC    60    SI5001
        3...300 [cm/s]
        —    —    1 [bar]
    14,51 [psi]    —    24 DC ± 10 %    SL5201
     [s]    [V]    [mA]
    型号 SFM ? M12 x 1 ? M12接插件
        3...300 [cm/s]
    5...590 [ft/min]    200...2000 [cm/s]
    393...3937 [ft/min]    3...60 [cm/s]
    -4...158 [°F]    1...10    —    —    SF120A
    型号 SFM ? M12 x 1 ? TPE-S电缆
        3...300 [cm/s]
    5...590 [ft/min]    200...2000 *) [cm/s]
    5...118 [ft/min]    200...800 *) [cm/s]
    393...1574 [ft/min]    -20...60 [°C]
    -4...140 [°F]    1...10    —    —    SF111A
    3...300 [cm/s]
    -4...158 [°F]    1...10    —    —    SF121A
                            [s]    [V]    [mA]
    型号 SFD ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件
        3...300 [cm/s]
                    [s]    [V]    [mA]
    型号 SID ? 用于适配器的内螺纹M18 x 1.5 ? M12接插件 ? DC ? 输出功能 4...20 mA 模拟
        3...300 [cm/s]
    5...590 [ft/min]    —    3...100 [cm/s]
    5...196 [ft/min]    —    -25...80 [°C]
                            [s]    [V]    [mA]
        3...300 [cm/s]
        3...300 [cm/s]
        3...300 [cm/s]
        3...300 [cm/s]
        3...300 [cm/s]
        3...300 [cm/s]
        3...300 [cm/s]
    3...300 [cm/s]
    3...300 [cm/s]
        3...300 [cm/s]
TO:采购 公司经营品牌:施克SICK 倍加福P+F, 易福门IFM ,基恩士 罗斯蒙特(Rosemount) . 图尔克TURCK,美国 埃福创编码器AVTRON. 宜科、ABB瑞士。巴鲁夫 , SMC ,费斯托FESTO 西门子仪器仪表 销售:张龙刚 手机:13817798194 邮箱:zlgsh@hotmail.com 价格优惠!…  更多>>
上海自动有限公司
联系人:张龙刚
地址:上海松江区
邮编:201613
电话:13817798194
公司网址:http://xhzlg.b2b.youboy.com
  • Ferenc Nagy 在2024/11/29 23:20:00留言
  • 详细留言:RFQ 1-2 x Sick SCS70HLA0K01 ID: 1034069
  • 明小姐 在2015/3/26 16:05:00留言
  • 详细留言:还看了HYDAC给水泵:http://www.hydac-zh.com/gsb/ 贺德克给水泵:http://www.hydac-zh.com/gsb/ 给水泵:http://www.hydac-zh.com/gsb/ 贺德克轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ HYDAC轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 轴向柱塞泵:http://www.hydac-zh.com/zxzsb/ 贺德克内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ HYDAC内啮合齿轮泵:http://www.hydac-zh.com/nniclb/ 内齿轮油泵:http://www.hydac-zh.com/nniclb/ 贺德克外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ 外啮合齿轮泵:http://www.hydac-zh.com/wniclb/ HYDAC压力传感器:http://www.hydac-zh.com/ylcgq/ 贺德克压力传感器:http://www.hydac-zh.com/ylcgq/
  • 王力 在2014/12/10 18:16:00留言
  • 梁先生 在2014/7/17 9:23:00留言
  • 详细留言:流量传感器0-15ml/min
  • 荣玉成 在2014/4/15 14:14:00留言
  • 详细留言:压力传感器:范围不+-20Pa 范围0-50Pa 电压24VDC 电流4-20mA
