TURCK·图尔克电容传感器
TURCKBCF10-S30-VP4X 2506111 S007 0.1 -25...+70 IP67 PA PA PVC 2 m
BCF10-S30-VN4X 2506011 S010 0.1 -25...+70 IP67 PA PA PVC 2 m
BCF10-S30-VP4X-H1141 2506117 S008 0.1 -25...+70 IP67 PA PA –
BCF10-S30-VN4X-H1141 2506016 S012 0.1 -25...+70 IP67 PA PA –
销售:张龙刚
手机:13817798194 工作QQ: 304158330 QQ: 1491218376 MSN:zlgsh@hotmail.com
BCF15-K34-AZ3X 2502136 S092 0.02 -25...+70 IP67 PBT PBT PVC 2 m
BCF15-K34-RZ3X 2502135 S094 0.02 -25...+70 IP67 PBT PBT PVC 2 mBC10-Q14-AP4X2 2530001 S001 0.1 -25...+70 IP67 PBT PBT
BC10-Q14-RP4X2 2530014 S054 0.1 -25...+70 IP67 PBT PBT
BC10-Q14-AN4X2 2530010 S004 0.1 -25...+70 IP67 PBT PBT
BC10-Q14-VP4X2 2530020 S007 0.1 -25...+70 IP67 PBT PBT
BC10-Q14-AP4X2-V1131 2530002 S002 0.1 -25...+70 IP67 PBT PBT
BC10-Q14-AN4X2-V1131 2530011 S005 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-AP4X2 2530100 S001 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-RP4X2 2530106 S054 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-AN4X2 2530110 S004 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-AP4X2-H1141 2530101 S002 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-AN4X2-H1141 2530111 S005 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-RP4X2-H1143 2530107 S056 0.1 -25...+70 IP67 PBT PBT
BC20-Q20-VN4X2-H1141 2530131 S011 0.1 -25...+70 IP67 PBT PBTBC3-M12-AP6X 2601000 S001 0.1 -25...+70 IP67 CuZn-Cr ABS PVC 2 m
BC3-M12-AN6X 2601100 S004 0.1 -25...+70 IP67 CuZn-Cr ABS PVC 2 m
BC3-M12-RP6X 2601103 S054 0.1 -25...+70 IP67 CuZn-Cr ABS PVC 2 m
BC5-M18-AP4X 2504001 S001 0.1 -25...+70 IP67 CuZn-Cr PBT PVC 2 m
BC5-M18-AN4X 2504002 S004 0.1 -25...+70 IP67 CuZn-Cr PBT PVC 2 m
BC5-M18-RP4X 2504026 S001 0.1 -25...+70 IP67 CuZn-Cr PBT PVC 2 m
BC5-M18-AP4X-H1141/S250 2504024 S002 0.1 -25...+70 IP67 CuZn-Cr PBT -
BC5-M18-AN4X-H1141/S250 2504025 S005 0.1 -25...+70 IP67 CuZn-Cr PBT -
BC5-M18-RP4X-H1141/S250 2504023 S056 0.1 -25...+70 IP67 CuZn-Cr PBT -
BC10-M30K-VP4X 2503022 S007 0.1 -25...+70 IP67 CuZn-Cr PA PVC 2 m
BC10-M30K-VP4X 5M 2503036 S007 0.1 -25...+70 IP67 CuZn-Cr PA PVC 5 m
BC10-M30K-VN4X 2503024 S010 0.1 -25...+70 IP67 CuZn-Cr PA PVC 2 m
BC10-M30K-RN4X 2503027 S055 0.1 -25...+70 IP67 CuZn-Cr PA PVC 2 m
BC10-M30K-AN4X-H1141 2503030 S005 0.1 -25...+70 IP67 CuZn-Cr PA PVC 2 m
70 x ? 18 mm , 5 / , 7.5 BC5-S18-AZ3X 2305500PVC 2 m
70 x ? 18 mm , 5 / , 7.5 BC5-S18-RZ3X 2305400PVC 2 m
70 x ? 18 mm / , 5 BC5-M18-AZ3X 2305000PVC 2 m
70 x ? 18 mm / , 5 BC5-M18-RZ3X 2305100PVC 2 m
83 x ? 18 mm / , 5 BC5-M18-AZ3X-B3331/S250 2305001 1/2"
83 x ? 18 mm / , 5 BC5-M18-RZ3X-B3331/S250 2305101 1/2"
63 x ? 30 mm , 10 / , 15 BC10-S30-AZ3X 2310700PVC 2 m
63 x ? 30 mm , 10 / , 15 BC10-S30-RZ3X 2310800PVC 2 m
63 x ? 30 mm , 10 / , 15 BCF10-S30-AZ3X 2506015PVC 2 m
63 x ? 30 mm , 10 / , 15 BCF10-S30-RZ3X 2506013PVC 2 m
91 x ? 30 mm , 10 / , 15 BC10-S30-AZ3X-B3131 2310710 1/2"
91 x ? 30 mm , 10 / , 15 BCF10-S30-AZ3X-B3131 2506012 1/2"
91 x ? 30 mm , 10 / , 15 BCF10-S30-RZ3X-B3131 2506014 1/2"
91 x ? 30 mm , 10 / , 15 BC10-S30-RZ3X-B3131 2310810 1/2"
60 x ? 30 mm / , 10 BC10-M30K-AZ3X 7M 2503029 PVC 7 m
60 x ? 30 mm / , 10 BC10-M30K-AZ3X 2503031 PVC 2 m
60 x ? 30 mm / , 10 BC10-M30K-RZ3X 2503025 PVC 2 m
80 x ? 30 mm / , 10 BC10-M30-AZ3X-B3131 2310030 1/2"
80 x ? 30 mm / , 10 BC10-M30-RZ3X-B3131 2310100 1/2"
81 x ? 30 mm / , 10 BC10-M30-AZ3X 23100 PVC 2 m
115 x ? 30 mm , 10 / , 15 program. BC10-P30SR-FZ3X2 23104
80 x ? 34 mm , 15 / , 23 BCF15-K34-AZ3X 2502136PVC 2 m
80 x ? 34 mm , 15 / , 23 BCF15-K34-RZ3X 2502135PVC 2 m
80 x ? 34 mm , 15 / , 23 BC15-K34-AZ3X 2310008PVC 2 m
80 x ? 34 mm , 15 / , 23 BC15-K34-RZ3X 2310110PVC 2 m
106 x ? 34 mm , 15 / , 23 program. BC15-K34SR-FZ3X2 2310009
90 x ? 40 mm , 20 / , 30 program. BC20-K40SR-FZ3X2 23103
114 x ? 40 mm , 20 / , 30 program. BC20-CP40-FZ3X2 23105
80 x 80 x 40.5 mm , 50 program. NC50-CP80-FZ3X2 2310600 感应距离
Sn (mm)
32 x 20 x 8 mm / , 5, PNPBC5-Q08-AP6X2/S250 26200 PVC 2 m
32 x 20 x 8 mm / , 5, NPNBC5-Q08-AN6X2/S250 26201 PVC 2 m
32 x 20 x 8 mm / , 5, PNPBC5-Q08-RP6X2/S250 2530108 PVC 2 m
32 x 20 x 8 mm / , 5, PNPBC5-Q08-AP6X2-V1131/S250 26210 O8 mm
32 x 20 x 8 mm / , 5, NPNBC5-Q08-AN6X2-V1131/S250 26211 O8 mm
32 x 20 x 8 mm / , 5, PNPBC5-Q08-RP6X2-V1131/S250 2620152 O8 mm
42 x 25 x 10.8 mm / , 8, PNPBC8-Q10-AP6X2/S250 2621200 PVC 2 m
42 x 25 x 10.8 mm / , 8, NPNBC8-Q10-AN6X2/S250 2621203 PVC 2 m
42 x 25 x 10.8 mm / , 8 , PNPBC8-Q10-RP6X2/S250 2621205 PVC 2 m
42 x 25 x 10.8 mm / , 8 , NPN BC8-Q10-RN6X2/S250 2621199 PVC 2 m
42 x 25 x 10.8 mm / , 8, PNPBC8-Q10-AP6X2-V1131/S250 2621201 M8 x 1
42 x 25 x 10.8 mm / , 8, NPNBC8-Q10-AN6X2-V1131/S250 2621202 M8 x 1
42 x 25 x 10.8 mm / , 8, PNPBC8-Q10-RP6X2-V1131/S250 2621204 M8 x 1
52 x 30 x 14 mm , 10 / , 15 , PNPBC10-Q14-AP4X2 2530001 PVC 2 m
52 x 30 x 14 mm , 10 /, 15 , NPNBC10-Q14-AN4X2 2530010 PVC 2 m
52 x 30 x 14 mm , 10 / , 15 , PNPBC10-Q14-RP4X2 2530014 PVC 2 m
52 x 30 x 14 mm , 10 / , 15 , PNPBC10-Q14-AP4X2-V1131 2530002 M8 x 1
52 x 30 x 14 mm , 10 / , 15 , NPNBC10-Q14-AN4X2-V1131 2530011 M8 x 1
52 x 30 x 14 mm , 10 / , 15 , PNP BC10-Q14-VP4X2 2530020 PVC 2 m
68 x 40 x 20 mm , 20 / , 30 , PNPBC20-Q20-AP4X2 2530100PUR 2 m
68 x 40 x 20 mm , 20 / , 30 , NPNBC20-Q20-AN4X2 2530110PUR 2 m
68 x 40 x 20 mm , 20 / , 30 , PNPBC20-Q20-RP4X2 2530106PUR 2 m
52 x 30 x 20 mm , 20 / , 30 , NPNBC20-Q20-VN4X2-H1141 2530131 M12 x 1
68 x 40 x 20 mm , 20 / , 30 , PNPBC20-Q20-AP4X2-H1141 2530101 M12 x 1
68 x 40 x 20 mm , 20 / , 30 , NPNBC20-Q20-AN4X2-H1141 2530111 M12 x 1
68 x 40 x 20 mm , 20 / , 30 , PNPBC20-Q20-RP4X2-H1143 2530107 M12 x 1
50 x 20.3 x 5.5 mm / , 10 , PNPBC10-QF5,5-AP6X2 2620117PUR 2 m
50 x 20.3 x 5.5 mm / , 10 , NPNBC10-QF5,5-AN6X2 2620121PUR 2 m
50 x 20.3 x 5.5 mm / , 10 , PNPBC10-QF5,5-AP6X2/S250 2620115PUR 2 m
50 x 20.3 x 5.5 mm / , 5, PNPBC5-QF5,5-AP6X2/S250 2620116PUR 2 m
50 x 20.3 x 5.5 mm / , 5, PNPBC5-QF5,5-RP6X2/S250 2620127PUR 2 m
50 x 20.3 x 5.5 mm / , 5, PNPBC5-QF5,5-RP6X2 2620126PUR 2 m
60 x ? 12 mm ,3 / , 4.5 , PNPBC3-S12-AP6X2601200 PVC 2 m
60 x ? 12 mm ,3 / , 4.5 , NPNBC3-S12-AN6X 2601300 PVC 2 m
60 x ? 12 mm ,3 / , 4.5 , PNPBC3-S12-RP6X2601202 PVC 2 m
70 x ? 18 mm ,5 / , 7.5 , PNPBC5-S18-AP4X25030 PVC 2 m
70 x ? 18 mm ,5 / , 7.5 , NPN BC5-S18-AN4X 25031 PVC 2 m
70 x ? 18 mm ,5 / , 7.5 , PNPBC5-S18-RP4X2503020 PVC 2 m
60 x ? 18 mm ,5 / , 5, PNPBC5-S18-AP4X-H1141/S2502503602 M12 x 1
60 x ? 18 mm ,5 / , 5, NPNBC5-S18-AN4X-H1141/S2502503108 M12 x 1
60 x ? 18 mm ,5 / , 7.5 , PNPBC5-S18-RP4X-H1141/S2502601209 M12 x 1
60 x 18 mm ,5 / , 7.5 , PNPBC5-S18-RP4X-0.15-RS41542573 PVC 1.5m M12x1
63 x ? 30 mm ,10 / , 15 , PNPBC10-S30-VP4X 2506110 PVC 2 m
63 x ? 30 mm ,10 / , 15 , NPNBC10-S30-VN4X 2506000 PVC 2 m
91 x ? 30 mm ,10 / , 15 , PNPBC10-S30-VP4X-H1141 2506100 M12 x 1
91 x ? 30 mm ,10 / , 15 , NPNBC10-S30-VN4X-H11412506010 M12 x 1
115 x ? 30 mm ,10 / , 15 , PNPBC10-P30SR-VP4X225050
115 x ? 30 mm ,10 / , 15 , NPNBC10-P30SR-VN4X225051
80 x ? 34 mm ,15 / , 23 , PNPBC15-K34-VP4X2502124 PVC 2 m
80 x ? 34 mm ,15 / , 23 , NPNBC15-K34-VN4X 2502127 PVC 2 m
74.5 x ? 34 mm ,15 / , 23 , PNPBC15-K34-AP4X-H1141 2502126 M12 x 1
74.5 x ? 34 mm ,15 / , 23 , NPNBC15-K34-AN4X-H1141 2502125 M12 x 1
80 x ? 34 mm , 20 , PNPNC20-KT34-VP4X2 2550300 PVDF
PVC 2 m
80 x ? 34 mm , 20 , NPNNC20-KT34-VN4X2 2550100 PVDF
PVC 2 m
90 x ? 40 mm ,20 / , 30 , PNPBC20-K40SR-VP4X225100
90 x ? 40 mm ,20 / , 30 , NPNBC20-K40SR-VN4X225101
90 x ? 40 mm ,20 / , 30 , NPNBC20-K40SR-VN4X2-H1141 2510104 M12 x 1
114 x 40 x 40 mm , 20 / , 30 , PNPBC20-CP40-VP4X2 25160
114 x 40 x 40 mm , 20 / , 30 , NPNBC20-CP40-VN4X2 25161
114 x 40 x 40 mm , 20 / , 30 , PNPBC20-CP40-VP4X2-H1141 2516102 M12 x 1
80 x 80 x 40.5 mm , 50 , PNP NC50-CP80-VP4X2 2580202
80 x 80 x 40.5 mm , 50 , NPN NC50-CP80-VN4X2 2580102
80 x 80 x 40.5 mm , 50 , PNP NC50-CP80-VP4X2-H1141 2580400 M12 x 1
BC10-S30-VP4X-H1141
BC10-S30-VP4X-H1141
BC10-S30-Y1X
BC15-K34-AN4X-H1141
BC15-K34-AP4X-H1141
BC15-K34-AZ3X
BC15-K34-RZ3X
BC15-KK34SR-FZ3X2
BC15-K34-VN4X
BC15-K34-VP4X
BC20-CP40-FZ3X2
BC20-CP40-VN4X2
BC20-CP40-VP4X2
BC20-K40SR-FZ3X2
BC20-K40SR-VN4X2
BC20-K40SR-VP4X2
BC20-Q20-AN4X2
BC20-Q20-AP4X2
BC20-Q20-RP4X2
BCC10-S30-AP4X
BCC10-S30-RP4X
BCC10-S30-RP4X-H1143
BCC10-S30-AP4X-H1143
BCC10-S30-VP4X-H1143
BCF10-Q20L60-AP4X
BCF10-Q20L60-AP4X-H1141
BCF10-S30-AZ3X
BCF10-S30-RZ3X
BCF10-S30-VN4X
BCF10-S30-VP4X
BCF15-K34-AZ3X
BCF15-K34-AZ3X
BCF15-K34-RZ3X
BCF15-K34-RZ3X
BCF5-S18-AN4X
BCF5-S18-AN4X-H1141/S250
BCF5-S18-AP4XBC3-M12-AN6X
BC3-M12-AP6X
BC3-M12-AP6X/S90/3GD
BC3-M12-RP6X
BC3-S12-AN6X
BC3-S12-AP6X
BC3-S12-AP6X/S100
BC3-S12-RP6X
BC3-S12-RP6X/S90/3GD
BC5-M18-AN4X
BC5-M18-AP4X
BC5-M18-AZ3X
BC5-M18-RP4X
BC5-M18-RZ3X
BC5-Q08-AN6X2/S250
BC5-Q08-AP6X2/S250
BC5-Q08-RP6X2/S250
BC5-QF5,5-Y1X/S250
BC5-QF5,5-Y1X/S250
BC5-S185-AN4X/S100
BC5-S185-AP4X
BC5-S185-AP4X/S100
BC5-S185-Y0X/S90 4M
BC5-S185-Y0X/S90 4M
BC5-S18-AN4X
BC5-S18-AP4X
BC5-S18-AZ3X
BC5-S18-RP4X
BC5-S18-RZ3X
BC5-S18-Y1X/S100
BC5-S18-Y1X/S100
BC5-S18-Y1X/S100
BC5-S18-Y1X
BC5-S18-Y1XBC8-Q10-AN6X2/S250
BC8-Q10-AP6X2/S250
BC8-Q10-RN6X2/S250
BC8-Q10-RP6X2/S250
BC10-M30-AN4X
BC10-M30-AP4X-H1141
BC10-M30-AZ3X
BC10-M30-AZ3X-B3131
BC10-M30-RZ3X-B3131
BC10-M30-VN4X-H1141
BC10-M30-VP4X-H1141
BC10-M30K-AZ3X
BC10-M30K-AZ3X 7M
BC10-M30K-RZ3X
BC10-M30K-RN4X
BC10-M30K-VN4X
BC10-M30K-VP4X
BC10-M30K-VP4X 5M
BC10-P30SR-FZ3X2
BC10-P30SR-VN4X2
BC10-P30SR-VP4X2
BC10-P30SR-VP4X2/3GD
BC10-PT30-VN4X2
BC10-PT30-VP4X2
BC10-PT30-Y0X
BC10-PT30-Y0X 9M
BC10-Q14-AN4X2
BC10-Q14-AP4X2
BC10-Q14-RP4X2
BC10-Q14-VP4X2
BC10-QF5,5-AN6X2
BC10-QF5,5-RP6X2
BC10-QF5,5-RP6X2/S250
BC10-QF5,5-AP6X2
BC10-S30-AZ3X
BC10-S30-AZ3X-B3131
BC10-S30-RZ3X
BC10-S30-RZ3X-B3131
BC10-S30-VN4X
BC10-S30-VN4X-H1141
BC10-S30-VP4XBCF5-S18-AP4X/S90
BCF5-S18-AP4X-H1141/S2
BCF5-S18-RN4X
BCF5-S18-RP4X/S90
BS12
BS18
BS34.1
BS40
BSN18
BSS12
BSS18
BSS30
BSS-CP40
BSS-SPV1
BSS-SPV2
BSS-SPV4
BSS-SPV5
BSS-TSM
JS025/037
MAP-K40
MAP-M18
MAP-M30
MH-Q14
MH-Q20
MW-12
MW-18
MW-30
MW-Q08/Q10
MW-Q14/Q20
NC50-CP80-FZ3X2
NC50-CP80-VN4X2
NC50-CP80-VP4X2
RK30-2
SG40
SG40/2
SKP3-L/S90
SMBDX80DIN
SWKP3-L/S90
TB-2
TB3-CP80
WAK3-L/Q
WAK4.21-L/P00
WAK4-L/Q
WKB3T-2/S68
WWAK3-L/Q
WWAK4.21-L/P00
WWAK4-L/Q销售:张龙刚
