厦门兴锐达自动化设备有限公司
  • GE IC3600 特价处理
  • 发布时间:2010/6/4 11:12:12   修改时间:2010/6/4 11:12:12 浏览次数:1486
  • 本公司专业销售大型进口各种品牌DCS系统模块备件:AB,ABB Advant OCS,ABB MOD 30/MODCELL,ABB MOD 300,ABB Bailey INFI 90,ABB Procontic,ABB Procontrol,H&B Contronic,Moore APACS,Moore Panel Controllers,Rosemount RS-3,Siemens Iskamatic,Siemens Simatic S5,Siemens Simatic C1,Yokogawa Centum XL,Yokogawa microXL,FOXBORO I/A,Westinghouse,Ovation,Honeywell QCS,Honeywell TDC系列,Honeywell S9000,HITACHI,Mitsubishi PLC,Motorola MVME,ALSTOM MVME,Other VME,TOSHIBA,HP,Yaskawa,FANUC等大型模组,有着充足的库存,交货期快,欢迎来电查询。
    厦门兴锐达自动化设备有限公司
    联系人:王文光
    手机:15359273780
    电话:0592-5580707
    传真:0592-5580710
    邮编:361009
    QQ:1282972140
    网址:http://www.xrdauto.com
    GE IC3600  特价处理
    IC3600AAIA1 CIRCUIT BOARD
    IC3600AAIB1 ANALOG INTERFACE IC3600AAIB
    IC3600AAID1 GE SPEEDTRONIC
    IC3600AAMA1 CARDS
    IC3600ABAA1 CIRCUIT BOARD
    IC3600ACLS1 CURR LIMIT BD IC3600ACLS
    IC3600ADAA1 D/A CONVERTER
    IC3600ADAC1 D/A CONVERTER
    IC3600ADAD1 DIODE D/A CONVERTER IC3600ADAD
    IC3600ADAE1 GE SPEEDTRONIC
    IC3600ADAF1 D/A CONVERTER
    IC3600ADNA1 DISCRIMINATOR
    IC3600AEXA1 EXPANDER CARD IC3600AEXA
    IC3600AFGA1 FUNC GEN BOARD IC3600AFGA
    IC3600AFGB1 FUNC GEN BOARD
    IC3600AFGD1 FUNC GEN BOARD
    IC3600AFGH1 TIMED ACCEL BD
    IC3600AFMA1 FAULT MON BOARD IC3600AFMA
    IC3600AFRA1 FIELD-TAPER-CONTROL
    IC3600AFRB1 FIELD-TAPER-AUX
    IC3600AIAA1 CURRENT-SENSOR
    IC3600AIAC1 AMPLIFIER BOARD IC3600AIAC
    IC3600AIAD1 TRANS ISOL BD IC3600AIAD
    IC3600AIAE1 CURRENT-SENSOR
    IC3600AJBA1 JUMPER BOARD IC3600AJBA
    IC3600ALTC1 GE SPEEDTRONIC
    IC3600ALTD1 LINEAR TAPE
    IC3600AMIA1 ANALOG MUX BD
    IC3600AMIB1 CARD SINGLE END MULT
    IC3600AMIP1 SINGLE END MULTIPLEX IC3600AMIP
    IC3600AMLB1 IC3600AMLB
    IC3600AMLG1 ANALOG MUX BD IC3600AMLG
    IC3600AOAA1 3-STAGE-OPER-AMPL
    IC3600AOAA2 OP AMP BOARD IC3600AOAA
    IC3600AOAB1 5-STAGE-OPER-AMPL
    IC3600AOAC1 OP AMP BOARD IC3600AOAC
    IC3600AOAD1 SUMMING AMP BD
    IC3600AOAF1 OP AMP BOARD
    IC3600AOAF2 OPERATIONAL AMPL
    IC3600AOAH1 OP AMP BOARD IC3600AOAH
    IC3600AOAJ1 OP AMP
    IC3600AOAK1 CARD
    IC3600AOAL1 OP AMP BOARD IC3600AOAL
    IC3600AOAL2 OP AMP BOARD
    IC3600AOTM1 T/C DETECTOR BD
    IC3600APAA1 POWER AMP BOARD
    IC3600APAB1 POWER AMP BOARD IC3600APAB
    IC3600APSG1 GAYNO-POWER-SUPPLY-C
    IC3600ARFA1 LOGIC/ANALOG BD IC3600ARFA
    IC3600ARHA1 ANALOG READ AND HOLD
    IC3600ARHA2 READ/HOLD BOARD
    IC3600ARHB1 ANALOG READ AND HOLD
    IC3600ARHB2 READ/HOLD BOARD
    IC3600ARTM2 R/T CONVERTER
    IC3600ARTM4 R/T CONVERTER
    IC3600AVAIA1
    IC3600AVIA1 VOLTAGE ISOL BD IC3600AVIA
    IC3600AVIB1 VOLTAGE ISOLATOR
    IC3600AVIC1 VOLTAGE ISOLATOR
    IC3600AVLA1 INPUT-VOLT-LIMITER
    IC3600AVRA1 REFERENCE BOARD
    IC3600AVSA1 VOL REL BOARD
    IC3600AVSB1 REFER TO ARGO/HOUSTON
    IC3600AVSD1 VOL REL BD
    IC3600CCCA1 ACCT. RECTIFIER
    IC3600DAEA1 IC3600DAEA
    IC3600DBMA1 CIRCUIT BOARD ASM
    IC3600DCDA1 IC3600DCDA
    IC3600DCWA1 CARD-DELAY-&-CROWBAR
    IC3600DCWB1 CARD-CROWBAR
    IC3600DCWC1 IC3600DCWC
    IC3600DEXB1 EXTENSION CARD
    IC3600DGRA1 IC3600DGRA
    IC3600DIGA1 IC3600DIGA
    IC3600DIVA1 CARD-PART OF ICR607D104A
    IC3600DJBB1 IC3600DJBB
    IC3600DLIG1 DIO INTERFACE IC3600DLIG
    IC3600DLIJ1 DLC AIR INTERFACE IC3600DLIJ
    IC3600DLIK1 SPEEDTRONIC INTFC IC3600DLIK
    IC3600DLIL1 DIO INTERFACE IC3600DLIL
    IC3600DLPC1 DATA LINE PULL UP
    IC3600DPSA1 CRD-15V-POWER-SUPPLY
    IC3600DPSB1 CRD-15V-POWER-SUPPLY
    IC3600DRDC8 CARD-RELAY-DRIVER
    IC3600DRGA1 SPEEDTRONIC
    IC3600DRGB1 CARD-PART OF ICR607D104A
    IC3600DSPB1 CARD-PART OF 68B9453211
    IC3600EPSA1 REGULATOR IC3600EPSA
    IC3600EPSAB1
    IC3600EPSB1 100V REGULATOR IC3600EPSB
    IC3600EPSC1 INVTR. DR. IC3600EPSC
    IC3600EPSD1 28V PS. IC3600EPSD
    IC3600EPSE1 INDICATOR
    IC3600EPSE2 INDICATOR CARD IC3600EPSE
    IC3600EPSH1 POWER SUPPLY BD IC3600EPSH
    IC3600EPSK1 MODULE
    IC3600EPSM1 CB-75W-PWR-SUPPLY-CO
    IC3600EPSN1 12V,28V POWER SUPPLY
    IC3600EPSN3 POWER SUPPLY BD
    IC3600EPSN4 CRD-15V-POWER-SUPPLY
    IC3600EPSS1 50VTO-12V REGULATOR IC3600EPSS
    IC3600EPSU1 MODULE
    IC3600EPSV1 POWER SUPPLY IC3600EPSV
    IC3600EPSW1 REGULATOR BOARD IC3600EPSW
    IC3600EPSX1 12V LAMP REGULATOR IC3600EPSX
    IC3600EPSY1 REGULATOR BOARD IC3600EPSY
    IC3600EPZU1 POWER SUPPLY CARD
    IC3600KHDA2 RELAY BOARD
    IC3600KHDB2 RELAY BOARD
    IC3600KHDC2 RELAY BOARD
    IC3600KHVA1 RELAY BOARD
    IC3600KHVA2 RELAY BOARD
    IC3600KHVB2 RELAY BOARD
    IC3600KHVD2 RELAY BOARD
    IC3600KMRA2 MEDIUM-DUTY-RELAY
    IC3600KMRA5 MEDIUM DUTY RELAY
    IC3600KMRA6 MEDIUM-DUTY-RELAY
    IC3600KMRA9 RELAY
    IC3600KMRB1 MEDIUM-DUTY-RELAY
    IC3600KMRB2 RELAY
    IC3600KMRB3 MEDIUM-DUTY-RELAY
    IC3600KMRB5 MEDIUM-DUTY-RELAY
    IC3600KMRB6 RELAY, ALT P/N: L8934 (COMMUNICATIONS INST
    IC3600KMRB9 RELAY
    IC3600KMRC1 MEDIUM-DUTY-RELAY
    IC3600KMRC2 MEDIUM-DUTY-RELAY
    IC3600KMRC5 RELAY
    IC3600KMRC6 MEDIUM-DUTY-RELAY-MI
    IC3600KMRC9 RELAY
    IC3600KMRCD RELAY
    IC3600KMRD2 MEDIUM-DUTY-RELAY
    IC3600KMRD5 MEDUIM DUTY RELAY
    IC3600KMRD6 MEDIUM DUTY RELAY
    IC3600KMRD9 MEDIUM-DUTY-RELAY
    IC3600KMRDD
    IC3600KMRE2 MEDIUM-DUTY-RELAY
    IC3600KMRE3 MEDIUM-DUTY-RELAY
    IC3600KMRE5 MEDIUM-DUTY-RELAY
    IC3600KMRE6 MEDIUM-DUTY-RELAY
    IC3600KMRE9 MEDIUM-DUTY-RELAY
    IC3600KMRF2 MEDIUM-DUTY-RELAY
    IC3600KMRF5 MEDIUM DUTY RELAY
    IC3600KMRF6 RELAY
    IC3600KMRF9 MEDIUM-DUTY-RELAY
    IC3600KMRH9 RELAY
    IC3600KMVA1 RELAY BOARD
    IC3600KMVA2 REED-RELAY-CARD
    IC3600KMVB2 RELAY BOARD IC3600KMVB
    IC3600KMVD2 RELAY BOARD
    IC3600KMVH1 RELAY BOARD IC3600KMVH
    IC3600KRMB9 RELAY
    IC3600KRSA1 REED RELAY
    IC3600KRSA2 RELAY BOARD
    IC3600KRSB2 RELAY BOARD IC3600KRSB
    IC3600KRSC2 RELAY BOARD
    IC3600KRSD1 RELAY BOARD IC3600KRSD
    IC3600KRSD2 RELAY BOARD IC3600KRSD
    IC3600KRSE1 RELAY BOARD
    IC3600KRSE2 RELAY BOARD IC3600KRSE
    IC3600KRSL2 REED-RELAY-CARD
    IC3600KRSP1 RELAY BOARD
    IC3600KRSR1 REED RELAY
    IC3600KRSS1 REED RELAY
    IC3600KRSS2 RELAY BOARD
    IC3600KRST1 RELAY BOARD IC3600KRST
    IC3600KRSU1 RELAY BOARD
    IC3600KRSV1 RELAY CARD
    IC3600KRSV2 RELAY BOARD
    IC3600KVSA1 ZERO-SPEED-RELAY
    IC3600LANA1 SPEEDTRONIC
    IC3600LANB1 ANNUNCIATOR BD
    IC3600LANC1 CIRCUIT BOARD
    IC3600LBCA1 BINARY-COUNTER
    IC3600LBDA1 CARD TRANSLATOR
    IC3600LBEA1 BIT-EQUATOR
    IC3600LBSB1 CIRCUIT BOARD
    IC3600LCDA1 CLOCK/LOGIC BD IC3600LCDA
    IC3600LCLA1 CRD-CUR-LOOP-ADAPTER
    IC3600LDCA1 DEC COUNTER BD
    IC3600LDDA1 DISPLAY DRIVER IC3600LDDA
    IC3600LDDB1 DISPLAY DRIVER
    IC3600LDEB1 SER DECODER BD
    IC3600LDEG1 DECODER-OPTICAL-TAC
    IC3600LDGE1 GE MK2 CIRCUIT BOARD
    IC3600LESM1 PER-MEM SWITCH
    IC3600LFFA1 FLIP-FLOP
    IC3600LFFC1 CIRCUIT BOARD
    IC3600LFFM1 PER-MEM-FLIP-FLOP
    IC3600LGXA1 GATE EXP BOARD IC3600LGXA
    IC3600LIBA1 INPUT BUFFER BD IC3600LIBA
    IC3600LIBB1 INPUT BUFFER BD IC3600LIBB
    IC3600LINA1 LIGHT IND BOARD IC3600LINA
    IC3600LINB1 LIGHT IND BOARD IC3600LINB
    IC3600LINE1 LIGHT IND BOARD
    IC3600LING1 LIGHT IND BOARD IC3600LING
    IC3600LISB1 INPUT BUFFER
    IC3600LIVA1 LOGIC INVERTER IC3600LIVA
    IC3600LIVC1 INVERTER
    IC3600LIVD1 LOGIC INVERTER IC3600LIVD
    IC3600LIVE1 LOGIC INVERTER
    IC3600LIVF1 LOGIC INVERTER IC3600LIVF
    IC3600LLDB1 LINE DRIVER BD
    IC3600LLDD1 CARD LINE DRIVER (10
    IC3600LLDD2 LINE DRIVER BD
    IC3600LLEA1 LOGIC ELEMENT IC3600LLEA
    IC3600LLEB1 LOGIC ELEMENT IC3600LLEB
    IC3600LLRB1 LINE-RECEIVER
    IC3600LLRC1 LINE-RECEIVER
    IC3600LLRD1 LINE RECEIVER
    IC3600LLXA1 LOGIC EXPANDER
    IC3600LMIA1 MULTIPLEX IN BD
    IC3600LOEA1 OR-EXCLUSIVE
    IC3600LPCG1 V CONT PULSE GEN/ONLY
    IC3600LPGA1 GE SPEEDTRONIC
    IC3600LPGB1 SPEEDTRONIC GE CARD
    IC3600LPGC1 V CONT-PULSE-GEN/R&R
    IC3600LPMB1 GE SPEEDTRONIC
    IC3600LRDC1 RELAY DRIVER BD IC3600LRDC
    IC3600LRDC2 GE SPEEDTRONIC
    IC3600LRDD1 RELAY-DRIVER
    IC3600LRDG1 RELAY DRIVER BD
    IC3600LRDH1 RELAY DRIVER BD IC3600LRDH
    IC3600LRDJ1 RELAY DRIVER BD IC3600LRDJ
    IC3600LRLB1 LOGIC BINARY BD IC3600LRLB
    IC3600LRLD1 REV LOGIC BOARD
    IC3600LROC1 SPEEDTRONIC CARD
    IC3600LSFA1 DIG-SIGNAL-FILTER
    IC3600LSFD INPUT FILTER CARD IC3600LSFD
    IC3600LSFD1 INPUT FILTER CARD IC3600LSFD
    IC3600LSFD2 INPUT BUFFER
    IC3600LSFE1 REED-RLY-SIG-COND-CD
    IC3600LSIA1 CURCUIT BOARD
    IC3600LSIB1 SIGNAL ISOLATION CAR
    IC3600LSOC CIRCUIT BOARD
    IC3600LSRB1 SHIFT REG BOARD IC3600LSRB
    IC3600LSRD1 SHIFT REG BOARD IC3600LSRD
    IC3600LSSA1 SINGLE SHOT IC3600LSSA
    IC3600LTDA1 TIME DELAY BD IC3600LTDA
    IC3600LTGA1 TRIGGER/FILTER IC3600LTGA
    IC3600LVDA1 CIRCUIT BOARD
    IC3600MEXB1 CARD EXTENDER BOARD
    IC3600MSSC1 SINGLE-SHOT
    IC3600PCZA1 PERIPHERY BOARD IC3600PCZA
    IC3600PCZG1 PERIPHERY CARD
    IC3600PCZH1 PERIPHERY BOARD
    IC3600PEZB1 CEMF REGULATOR
    IC3600PSZA1 SPEED REG BOARD IC3600PSZA
    IC3600PSZD1 SPEED REGULATOR
    IC3600PSZE1 SPEED-REGULATOR
    IC3600PTJA1 TRANSFORMER IC3600PTJA
    IC3600PTJA4 LVDT TRANSFORMER
    IC3600PVZA1 PERIPHERY CARD
    IC3600PVZB1 PERIPHERAL  CARD
    IC3600PVZC1 PERIPHERY CARD
    IC3600Q0XC3 CARDS
    IC3600Q0XC4 CARD
    IC3600QDMA187 CIRCUT BOARD
    IC3600QDMA188 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QDMA189 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QDMA7 CIRCUT BOARD
    IC3600QDMA9 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QEAA1 EXPANDABLE AMPLIFIER IC3600QEAA
    IC3600QEAA3 EXPANDABLE AMPL
    IC3600QEAAD GE GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QIXA01 JUMPER-CARD
    IC3600QIXA04 JUMPER CARD
    IC3600QIXA1 PCB
    IC3600QIXA15 PCB
    IC3600QIXA20 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QIXA5 PCB
    IC3600QIXA57 GE JUMPER CARD
    IC3600QIXB0 JUMPER CARD
    IC3600QIXB01 JUMPER CARD
    IC3600QIXB06 CARD JUMPER
    IC3600QIXB1 PCB IC3600QIXB
    IC3600QIXB50 JUMPER CARD
    IC3600QMIB1 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QMIB2 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QMIB2A GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QOAX1
    IC3600QOXA1 OVER SPEED
    IC3600QOXA2 O/S SENSOR BD IC3600QOXA
    IC3600QOXA3 OVER SPEED
    IC3600QOXA4 OVER-SPEED-CARD
    IC3600QOXA5 GE SPEEDTRONIC
    IC3600QOXAL1
    IC3600QOXAM10 OVERSPEED SENS
    IC3600QOXB2 OVERSPEED-SENSOR
    IC3600QOXB5 OVERSPEED-SENSOR
    IC3600QOXB6 OVERSPEED-SENSOR
    IC3600QOXB7 OVERSPEED-SENSOR
    IC3600QOXB7D GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QOXC1 O/S SENSOR CD IC3600QOXC
    IC3600QOXC10
    IC3600QOXC11 OVERSPEED SENSOR CAR
    IC3600QOXC12 OVER SPD SENSOR CARD
    IC3600QOXC13 JUMPER CARD
    IC3600QOXC19 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QOXC2
    IC3600QOXC20 OVERSPEED SENSOR
    IC3600QOXC23 CARD
    IC3600QOXC2C
    IC3600QOXC3 CARD
    IC3600QOXC4 O/S SENSOR IC3600QOXC
    IC3600QOXC5 OVERSPEED-SENSOR
    IC3600QOXC5
    IC3600QOXC6 OVERSPEED-SENSOR
    IC3600QOXC7
    IC3600QOXC8 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QOXC9 O/S SENSOR
    IC3600QSCR1 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QSCR13 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QSCR2 GENERAL ELECTRIC CIRCUIT BOARD
    IC3600QSCR20 RTD SIGNAL
    IC3600QSPA04A SERVO-POTENTIOMETER
    IC3600QSPA04B CARD SERVO POTENTIOMETER
    IC3600QSPA104A104A SERVO-POTENTIOMETER
    IC3600QSPA104B104B CARD SERVO POTENTIOMETER
    IC3600QSPA252B252B SERVO-POTENTIOMETER
    IC3600QSPA253A122A SERVO POTENTIOMETER
    IC3600QSPA253B122B GE SPEEDTRONIC
    IC3600QSPA253B253B SERVO POTENTIOMETER
    IC3600QSPA254B254B GE SPEEDTRONIC
    IC3600QSPA502B122A GE SPEEDTRONIC
    IC3600QSPA50BA GE SPEEDTRONIC
    IC3600QSPA53AA SERVO POTENTIOMETER
    IC3600QSPA53B53B SERVO POTENTIOMETER
    IC3600QSPA53BB GE SPEEDTRONIC
    IC3600QSPA54B54B GE SPEEDTRONIC
    IC3600QSPA5B5B SERVO-POTENTIOMETER
    IC3600QTXB1 CIRCUIT BOARD
    IC3600RP551 GE FANUC SIX SERIES RPU
    IC3600SAHC1 ANTI-HUNT BOARD
    IC3600SAHD1 ANTI-HUNT BOARD
    IC3600SANB1 GE SPEEDTRONIC
    IC3600SAOA1 CIRCUIT BOARD
    IC3600SASA1 ASYN TO SYNC CONV`
    IC3600SASC1 MICROSYNCHRONIZER IC3600SASC
    IC3600SBIA1 RATIO & BIAS INPT CT IC3600SBIA
    IC3600SBMA1 BUS MONITOR BD IC3600SBMA
    IC3600SBMB1 PRINTED CIRCUIT CD IC3600SBMB
    IC3600SBMB3 CIRCUIT BOARD ASM
    IC3600SBXA1 IC3600SBXA
    IC3600SBXB1 GE CIRCUIT BOARD
    IC3600SBXC1 SPEEDTRONIC
    IC3600SBXD1 IC3600SBXD
    IC3600SBXE1 IC3600SBXE
    IC3600SCBA1 COMPONENT BOARD IC3600SCBA
    IC3600SCBB1 COMPONENT BOARD IC3600SCBB
    IC3600SCBB2 COMPONENT BOARD IC3600SCBB
    IC3600SCBC1 COMPONENT-BOARD
    IC3600SCBD1 COMPONENT BOARD IC3600SCBD
    IC3600SCBD2A
    IC3600SCBD3A SPEEDTRONIC GE CARD
    IC3600SCBD4 COMPONENT-BOARD
    IC3600SCBE1 COMPONENT BOARD IC3600SCBE
    IC3600SCBE2A COMPONENT CARD
    IC3600SCBH1 INPUT COMPARISON CIRCUIT
    IC3600SCBJ1
    IC3600SCBK1 COMPONENT BOARD
    IC3600SCBL1 COMPONENT BOARD
    IC3600SCBM2 CIRCUIT BOARD
    IC3600SCBN1 COMPONENT BOARD IC3600SCBN
    IC3600SCBN2 COMPONENT BOARD IC3600SCBN
    IC3600SCBN3 COMPONENT BOARD
    IC3600SCBS1 COMPONENT-BOARD
    IC3600SCFD1 CIRCUIT BOARD
    IC3600SCNB1 GE CIRCUIT BOARD
    IC3600SCTD1 COUNTER TORQUE
    IC3600SCZA1 SIGNAL SOURCE IC3600SCZA
    IC3600SDAA1 MATCHED CARD
    IC3600SDAB1 GE SPEEDTRONIC
    IC3600SDAB7 CIRCUIT BOARD
    IC3600SDAC1 GE MODULE, SUB P/N IC3600SHCC1-C
    IC3600SDCA1 CARD DIO
    IC3600SEKC1
    IC3600SFCC1 GE SPEEDTRONIC
    IC3600SFCD1 FIRING CIRCUIT
    IC3600SFCG1 FIRING CIRCUIT CARD
    IC3600SFIA1 FLAME IND BOARD
    IC3600SFIB1 FLAME IND BOARD IC3600SFIB
    IC3600SFKA1 VCE FUEL MODULE IC3600SFKA
    IC3600SFKC1 VALVE CTRL BD IC3600SFKC
    IC3600SFKD1 FUEL SPLITTER IC3600SFKD
    IC3600SFKE1 CIRCUIT BOARD
    IC3600SFKK1 FUEL VALVE CTRL IC3600SFKK
    IC3600SFKL1 FUEL SPLITTER IC3600SFKL
    IC3600SFPA1 GENERATOR DRIVE
    IC3600SFPB1 GENERATOR DRIVE IC3600SFPB
    IC3600SFSA1 CIRCUIT BOARD ASM
    IC3600SFUA1 FUEL FLOW CTRL IC3600SFUA
    IC3600SFUB1 IC3600SFUB
    IC3600SFUC1 FUEL FLOW CONTROL IC3600SFUC
    IC3600SGBA1 CIRCUIT BOARD
    IC3600SGDA1 SINGLE SHAFT AUXIL IC3600SGDA
    IC3600SGDD1 GROUND DETECTOR CARD IC3600SGDD
    IC3600SGDE1 GROUND DETECTOR IC3600SGDE
    IC3600SGDF1 GROUND DETECTOR CARD
    IC3600SHPA1 SINGLE-SHAFT-AUXIL
    IC3600SHPB1 SINGLE SHAFT AUXIL IC3600SHPB
    IC3600SHPC1 IC3600SHPC
    IC3600SIAA1 CARD
    IC3600SIAB1 ISOLATION-AMPLIFIER
    IC3600SIXD1 DUMMY CARD IC3600SIXD
    IC3600SIXH1 INTERFACE CARD ANNUN IC3600SIXH
    IC3600SIXJ1 POWER SUPPLY SEL. DD. IC3600SIXJ
    IC3600SIXK1 POWER SENSOR MODULE IC3600SIXK
    IC3600SIXL1 RELAY MODULE EXT. CARD IC3600SIXL
    IC3600SIXM1 INTERFACE BOARD IC3600SIXM
    IC3600SKVA1 CIRCUIT BOARD
    IC3600SLEH1 LOGIC ELEMENT IC3600SLEH
    IC3600SLPA1 AUX FUNCTION LP SHFT IC3600SLPA
    IC3600SLPB1 AUX FUNC LP SHAFT
    IC3600SMAA1 CIRCUIT BOARD
    IC3600SMFA1 TACH LOSS PROTECT
    IC3600SNCA1 NOZZLE
    IC3600SNCB1 NOZZLE CONTROL IC3600SNCB
    IC3600SNCF1 NOZZLE-CONTROL
    IC3600SNCG1 CARD ASM
    IC3600SOLA1
    IC3600SOSF1 LVDT OSC BOARD IC3600SOSF
    IC3600SOSG1 PCB IC3600SOSG
    IC3600SOTD1 OVERTEMP BOARD IC3600SOTD
    IC3600SOTE1 OVERTEMP IC3600SOTE
    IC3600SOTG1 OVERTEMP BOARD IC3600SOTG
    IC3600SOTH1 O/T RELAY BOARD IC3600SOTH
    IC3600SOTJ1 OVER TEMP PROTECTION IC3600SOTJ
    IC3600SOTK1 MK2 CIRCUIT BOARD
    IC3600SPCJ1 SPEEDTRONIC
    IC3600SPKA1 CIRCUIT BOARD
    IC3600SPOA1 PEAKING OP BD IC3600SPOA
    IC3600SPPA1 CIRCUIT BOARD
    IC3600SPPB1 CIRCUIT BOARD
    IC3600SPRA1 PULSE RATE BD
    IC3600SPRB1 PULSE IC3600SPRB
    IC3600SPRC1 PULSE RATE BD
    IC3600SPRF1 PULSE RATE TO ANALOG
    IC3600SPSF1 POWER-SUPPLY
    IC3600SPSG1 POWER SUPPLY BD
    IC3600SPSJ1 POWER-SUPPLY
    IC3600SPSK1 MONITOR BOARD
    IC3600SPSP1 BUS-MONITER
    IC3600SPSV1 REG AMPL BOARD IC3600SPSV
    IC3600SPSZ1 PWR SUPPLY AND OUTPUT IC3600SPSZ
    IC3600SPUA1 IC3600SPUA
    IC3600SPUA2 SPEEDTRONIC
    IC3600SQIA1 AUX FUNC MODULE
    IC3600SQIC1 INPUT-COMP-MODULE
    IC3600SRDF1 RELAY DRIVER BD
    IC3600SRKA1
    IC3600SRRA1 SPEEDTRONIC
    IC3600SSDA1 IC3600SSDA
    IC3600SSFG1 SOLENID FILTER IC3600SSFG
    IC3600SSIA1 SPEEDTRONIC GE CARD
    IC3600SSIB1 SPEEDTRONIC GE CARD
    IC3600SSKA1 STARTUP CONTROL IC3600SSKA
    IC3600SSKB1 STARTUP CONTROL IC3600SSKB
    IC3600SSKC1 CAL BOARD IC3600SSKC
    IC3600SSKE1 STARTUP CONTROL {R&R} IC3600SSKE
    IC3600SSLA1 SETPOINT IC3600SSLA
    IC3600SSLB1 SETPOINT BOARD IC3600SSLB
    IC3600SSLD1 SETPOINT CONTROL IC3600SSLD
    IC3600SSLE1 SETPOINT CONTROL IC3600SSLE
    IC3600SSNA1 MOTOR CTRL BD
    IC3600SSNA2 MOTOR CTRL BD
    IC3600SSNB1 MOTOR CTRL BD
    IC3600SSNC1 IC3600SSNC
    IC3600SSND1 IC3600SSND
    IC3600SSOA1 SPEEDTRONIC
    IC3600SSVA1 SERVO CTRL BD IC3600SSVA
    IC3600SSVB1 PRESSURE CTRL IC3600SSVB
    IC3600SSVC1 SERVO VALVE DRIVE IC3600SSVC
    IC3600SSVD1 SRV-DRIVE
    IC3600SSVE1 SERVO CARD IC3600SSVE
    IC3600SSVF1 VLV FDBK BOARD IC3600SSVF
    IC3600SSVG1 SERVO VALVE DRIVE IC3600SSVG
    IC3600SSVJ1 PCB
    IC3600SSZA1 PCB IC3600SSZA
    IC3600SSZAC SPEED CONTROL
    IC3600SSZB1 SPEED CTRL BD IC3600SSZB
    IC3600SSZD1 SPEED CONTROL CD
    IC3600SSZE1 SPEED CONTROL
    IC3600STDC1 TIME DELAY BD IC3600STDC
    IC3600STFA1 OVERSPEED-TEST-FUNCT
    IC3600STFB1 METER TAP SWITCH
    IC3600STKA1 TEMPERATURE CONTROL
    IC3600STKD1 TEMP CONTROL IC3600STKD
    IC3600STKF1 IC3600STKF
    IC3600STKG1 TEMPERATURE CONTROL
    IC3600STKH1 CARD TEMP CONTROL IC3600STKH
    IC3600STKJ1 AMPLIFIER BOARD IC3600STKJ
    IC3600STKK1 TEMP CONTROL BD IC3600STKK
    IC3600STKL1 TEMP MTR AMP BD
    IC3600STKP1 PEAKING OPERATION IC3600STKP
    IC3600STKS1 TEMP CONTROL
    IC3600STML1 THERMOCOUPLE AVERAGING MOD
    IC3600STSA1 PCD PWR SUPPLY IC3600STSA
    IC3600STXD1 CIRCUIT BOARD
    IC3600SVA1
    IC3600SVDA1 VIBR DET BOARD IC3600SVDA
    IC3600SVDB1 VIBRATION CALIBRATOR IC3600SVDB
    IC3600SVDC1 VIBR DET BOARD IC3600SVDC
    IC3600SVDD1 VIBRATION-CALIBRATOR
    IC3600SVDE1 VIBR ALARM BD IC3600SVDE
    IC3600SVFA1 VOLTAGE TO FREQ CONV IC3600SVFA
    IC3600SVSA1 HP SPEED SENSORS
    IC3600SVSC1 SPEED RELAY BD IC3600SVSC
    IC3600SVSD1 SPEED-SENSOR
    IC3600SVSE1 SPEED SENSOR IC3600SVSE
    IC3600SVSF1 SPEED-SENSOR
    IC3600SVSG1 SPEEDTRONIC
    IC3600SVZA1 12-28V REG BD IC3600SVZA
    IC3600SVZB1 50V REG BOARD IC3600SVZB
    IC3600SVZC1 5.3V REG BOARD
    IC3600SVZD1 50V REGULATOR
    IC3600SWIE1 SPEEDTRONIC
    IC3600TAIA1 ANALOG-INTERFACE
    IC3600TBAA1 BUFFER-AMPLIFIER
    IC3600TCBA1 COMP BD/SFE BD
    IC3600TCFB1 GE SPEEDTRONIC
    IC3600TCSA1 CURRENT-SENSOR
    IC3600TCSB1 CARD CURRENT SENSOR
    IC3600TCUC1
    IC3600TDIA1 DIGITAL-INTERFACE
    IC3600TDTA1 DIFF TRIP BOARD
    IC3600TDUA1 DIFFERENTIAL-TRIP
    IC3600TFCA1 AMPLISTAT-FIRING-CIR
    IC3600TFCU1 FIRING CIRCUIT IC3600TFCU
    IC3600TFCV1 FIRING CIRCUIT
    IC3600TFMA1 FAULT MON BOARD
    IC3600TGDD1 GATE DRIVER
    IC3600TGDE1 PULSE AMPL TRAN
    IC3600TILA1 INV LIMIT BOARD
    IC3600TILB1 INVERTER LIMIT CARD
    IC3600TLFA1 GE SPEEDTRONIC
    IC3600TLFC1 PHASE SHIFT BD
    IC3600TLFD1 PHASE SHIFT LINE FIL
    IC3600TLFE1 CARD PHASE SHIFT LINE
    IC3600TLOA1 LOCKOUT
    IC3600TPAA1 GATE PULSE AMP IC3600TPAA
    IC3600TPAB1 GATE PULSE AMP
    IC3600TPAE1 GATE PULSE AMPLIFIER
    IC3600TPAH1 GATE PULSE AMP
    IC3600TPAM1 GATE-PULSE-AMPL
    IC3600TPGA1 GATE PLS GEN BD
    IC3600TPGB1 GATE PLS GEN BD
    IC3600TPGD1 GATE PULSE GENERATOR
    IC3600TPGE1 PULSE-GENERATOR
    IC3600TPSA1 POWER SUPPLY BD IC3600TPSA
    IC3600TPSB1 3-PH-POWER-SUPPLY
    IC3600TPSC1 POWER-SUPPLY-CARD
    IC3600TPSD1 UNREG-PWR-SUPPLY-CRD
    IC3600TPSE1 67/9V 2AMP CONVERTER
    IC3600TPSF1 9/5.3V-2A REGULATOR
    IC3600TPSJ1 50V POWER SUPPLYCARD
    IC3600TPSR1 +-15 VOLT P SUPPLY
    IC3600TRAA1 AMPLIFIER BOARD
    IC3600TRLA1 REV LOGIC BOARD
    IC3600TRLB1 REV LOGIC BOARD
    IC3600TRLC1 REV LOGIC BOARD
    IC3600TRLD1 REV LOGIC BOARD
    IC3600TRLE1 REV LOGIC BOARD
    IC3600TRLH1 REV LOGIC BOARD IC3600TRLH
    IC3600TRLJ1 REVERSING-LOGIC
    IC3600TRLM1 REVERSING LOGIC
    IC3600TSKA1 SPEEDTRONIC GE CARD
    IC3600TSKB1 STARTUP CONTROL & SU
    IC3600TSUA1 GE SPEEDTRONIC
    IC3600TSUC1 GATE AMP BOARD
    IC3600TSUD1 SUPPRESSION AND BIAS
    IC3600TSUE1 BIAS-AND-SUPPRESSION
    IC3600TSUJ1 SUPP/BIAS BOARD IC3600TSUJ
    IC3600TUAA1 UNI-AMP
    IC3600TVSE1 VOLTAGE-SENSOR
    IC3600VANA1 ANNUNCIATOR BD IC3600VANA
    IC3600VANB1 ANNUNCIATOR BD IC3600VANB
    IC3600VANC1 ANNUNCIATOR BD
    IC3600VBCA1
    IC3600VBCD1 DOWN COUNTER BD
    IC3600VBCG1 CIRCUIT BOARD
    IC3600VBCU1 BINARY COUNTER IC3600VBCU
    IC3600VBEA1 BIT EQUATOR
    IC3600VCDA1 CLOCK DRIVER
    IC3600VCUA1 PCB
    IC3600VCUB1 PCB
    IC3600VCUD1 PCB
    IC3600VCUE1 PCB
    IC3600VCUF1 PCB
    IC3600VCUG1 PCB
    IC3600VCUH1 PCB
    IC3600VCUJ1 PCB
    IC3600VCUK1 PCB
    IC3600VDAA1 DIG SERVO BOARD
    IC3600VDAB1 D/A CONVERTER
    IC3600VDAC1 D/A CONVERTER IC3600VDAC
    IC3600VDAD1 D/A CONVERTER IC3600VDAD
    IC3600VDFC1 PCB
    IC3600VDOA1 CIRCUIT BOARD
    IC3600VFAB1 PCB
    IC3600VFAB2 PCB
    IC3600VFFA1 GATE FLIP-FLOP
    IC3600VFFB1 GATE FLIP FLOP
    IC3600VFFC1 STATUS MONITOR
    IC3600VFMC1 PCB
    IC3600VLEA1 LOGIC ELEMENT IC3600VLEA
    IC3600VLEB1 LOGIC ELEMENT IC3600VLEB
    IC3600VMIA1 INVERTING MULTIPLEX
    IC3600VMPA1 MECH PROTECTIVE IC3600VMPA
    IC3600VORA1 OR LOGIC IC3600VORA
    IC3600VPCA1 PCB
    IC3600VPCB1 PROG CONTROL BD
    IC3600VPGA1 PULSE GENERATOR
    IC3600VPSA06 POWER SUPPLY CARD
    IC3600VPSA1 POWER SUPPLY CARD
    IC3600VRCA1 REV COUNTER BD
    IC3600VRCB1 ERROR-REGISTER
    IC3600VRCC1 REVERSIBLE COUNTER
    IC3600VSLA1 GE SPEEDTRONIC
    IC3600VSLB1 CIRCUIT BOARD
    IC3600VSRA1 SHIFT REGISTER
    IC3600VSRB1 SHIFT REGISTER
    IC3600VSRD1 SHIFT REGISTER
    IC3600VSSA1 SINGLE-SHOT
    IC3600VTDA1 TIME DELAY
    IC3600VTSB1 PCB
    IC3600VTSC1 PCB
    IC3600XJBA1 CIRCUIT BOARD
    IC3600YSQA2 GE CARD
    IC3601 214A POWER SUPPLY
    IC3601 238A POWER SUPPLY
    IC3601 290A SUBCOMPONENT OF IC3601214A
    IC3601 A105A POWER SUPPLY BD
    IC3601 A115A POWER SUPPLY 150 MA
    IC3601 A115B POWER SUPPLY
    IC3601 A133B POWER SUPPLY 67V
    IC3601 A136A POWER SUPPLY 67V
    IC3601 A148A PWR SUPPLY:120VAC-10
    IC3601 A148B PWR SUP-120VAC TO 10
    IC3601 A14A POWER SUPPLY
    IC3601 A191 POWER SUPPLY 15V
    IC3601 A208B MODULE
    IC3601 A214A DC-DC CONVERTER - 50 V
    IC3601 A228A POWER SUPPLY BD
    IC3601 A238A DC-DC CONVERTER - 12 V
    IC3601 A249A POWER SUPPLY
    IC3601 A250A INVERTOR MODULE
    IC3601 A250B INVERTOR MODULE
    IC3601 A250C SUBCOMPONENT OF 232A51913
    IC3601 A251 GE POWER SUPPLY
    IC3601 A252A INVERTER MODULE
    IC3601 A254A POWER SUPPLY
    IC3601 A254B
    IC3601 A254C POWER SUPPLY
    IC3601 A277A THERMOCOUPLE AVERAGING MOD
    IC3601 A282A POWER INVERTERS PANEL
    IC3601 BOSH3E SUBCOMPONENT OF IC4484B103
    IC3601105A POWER SUPPLY BD
    IC3601115A POWER SUPPLY 150 MA
    IC3601115B POWER SUPPLY
    IC3601133B POWER SUPPLY 67V
    IC3601136A POWER SUPPLY 67V
    IC3601148A PWR SUPPLY:120VAC-10
    IC3601148B PWR SUP-120VAC TO 10
    IC360114A POWER SUPPLY
    IC3601191 POWER SUPPLY 15V
    IC3601208B MODULE
    IC3601214A POWER SUPPLY
    IC3601228A POWER SUPPLY BD
    IC3601238A POWER SUPPLY
    IC3601249A POWER SUPPLY
    IC3601250A INVERTER MODULE
    IC3601250B INVERTER MODULE
    IC3601250C INVERTER MODULE
    IC3601251 GE POWER SUPPLY
    IC3601252A INVERTER MODULE
    IC3601254A POWER SUPPLY
    IC3601254B BULK-POWER-SUPP
    IC3601254C PWR SUPPLY INV RG
    IC3601277A THERMOCOUPLE AVERAGING MOD
    IC3601282A POWER INVERTERS PANEL
    IC3601290A SUBCOMPONENT OF IC3601214A
    IC3601H3E SUBCOMPONENT OF IC4484B103
    IC3602 478A GE MICROSYNCHRONIZER
    IC3602 A122 ZERO SPEED RELAY
    IC3602 A124A CARD MODULES
    IC3602 A161 RTD REG/AMP BD
    IC3602 A178A MICROSYNCH
    IC3602 A178A1 MICRO. ISOL MODULE IC3602A 178A 1
    IC3602 A179A GE LOGIC TEST AID MODULE CALIBRATOR
    IC3602478A GE MICROSYNCHRONIZER
    IC3602A122 ZERO SPEED RELAY
    IC3602A124A CARD MODULE
    IC3602A161 RTD REG/AMP BD
    IC3602A178A MICROSYNCH
    IC3602A178A1 MICRO. ISOL MODULE IC3602A 178A 1
    IC3602A179A GE LOGIC TEST AID MODULE CALIBRATOR
    IC3603271 SCRAP IC3603271
    IC3603A111 POWER SUPPLY
    IC3603A130C REACTOR ASM
    IC3603A132A MODULE ASM
    IC3603A143F HEAT-SINK-ASSEMBLY
    IC3603A161 HEAT SINK ASSEMBLY
    IC3603A162A HEAT SINK ASM
    IC3603A163A HEAT SINK ASM
    IC3603A163B HEAT SINK ASM
    IC3603A165D ANNUNCIATOR PART
    IC3603A166A AC-&-DC-SOURCE
    IC3603A166B POWER SUPPLY
    IC3603A166C POWER SUPPLY
    IC3603A17 GE COIL DIODE
    IC3603A177
    IC3603A177AA2 HER-SEAL-MED-DUT-REL
    IC3603A177AA5 POTTED RELAY
    IC3603A177AA6 POTTED-RELAY
    IC3603A177AA9 HER-SEAL-MED-DUT-REL
    IC3603A177AB2 POTTED RELAY
    IC3603A177AB6 HER-SEAL-MED-DUT-REL
    IC3603A177AB9 POTTED-RELAY
    IC3603A177AC2 POTTED RELAY IC3603A177A C2
    IC3603A177AC6 RELAY
    IC3603A177AC9 POTTED RELAY
    IC3603A177AD2 POTTED RELAY
    IC3603A177AD5 POTTED RELAY
    IC3603A177AD9 POTTED-RELAY
    IC3603A177AE2 MEDIUM DUTY RELAY-28
    IC3603A177AE5 POTTED RELAY
    IC3603A177AE9 POTTED RELAY
    IC3603A177AF2 POTTED RELAY IC3603A177A F2
    IC3603A177AF6 POTTED-RELAY
    IC3603A177AF9 POTTED RELAY
    IC3603A177AFZ MODULE CONTROL/ POTTED RELAY
    IC3603A177AG2 POTTED RELAY
    IC3603A177AG9 POTTED-RELAY
    IC3603A177AH1 RELAY
    IC3603A177AH2 POTTED RELAY
    IC3603A177AH5 POTTED RELAY
    IC3603A177AH6 MEDIUM DUTY RELAY-12
    IC3603A177AH9 POTTED-RELAY  COIL 1
    IC3603A177BB2 POTTED RELAY
    IC3603A177BB6 POTTED RELAY
    IC3603A177BB9 POTTED RELAY
    IC3603A177CA6 POTTED-RELAY
    IC3603A177CB2 POTTED-RELAY
    IC3603A177CB6 POTTED-RELAY
    IC3603A177CC2 POTTED-RELAY
    IC3603A177CC5 POTTED RELAY
    IC3603A177CC6 POTTED RELAY ASM
    IC3603A177CD2 POTTED-RELAY
    IC3603A177CD5 POTTED RELAY
    IC3603A177CE2 POTTED-RELAY
    IC3603A177CE5 POTTED RELAY
    IC3603A177CE6 POTTED-RELAY
    IC3603A177CF2 POTTED-RELAY IC3603A177C F2
    IC3603A177CG2 POTTED-RELAY
    IC3603A177CG5 POTTED-RELAY
    IC3603A177CG6 POTTED RELAY
    IC3603A177CH2 POTTED-RELAY
    IC3603A177CH5 POTTED-RELAY
    IC3603A177CH6 POTTED-RELAY
    IC3603A177CJ3 RELAY MED-DUTY POTTED W/DIODE
    IC3603A177CJ6 POTTED-RELAY
    IC3603A200A TIRASTAT-MODULE
    IC3603A200B TIRASTAT-MODULE
    IC3603A200C TIRASTAT-MODULE
    IC3603A201 SCR ASSEMBLY
    IC3603A229A FIELD EXCITER
    IC3603A229B FIELD RECTIFIER
    IC3603A250A FULL WAVE-BR-SIN
    IC3603A250B FULL WAVE-BR-SIN-PH
    IC3603A251 HSINK ASM
    IC3603A253A SINGLE PHASE BRIDGE ASM
    IC3603A253B SINGLE PHASE BRIDGE
    IC3603A271 THERMOCOUPLE AVGING MOD
    IC3603A274B THERMOCOUPLE AVERAGING MOD
    IC3603A277A THERMOCOUPLE AVERAGING MOD IC3603A277
    IC3603A277C THERMOCOUPLE AVERAGING MOD
    IC3603A278A THERMOCOUPLE AVERAGING MOD
    IC3603A278B THERM PROCESS MOD
    IC3603A278E THERMOCOUPLE PROCESSOR ASM
    IC3603A279A THERMOCOUPLE MO
    IC3603A280A HEAT SINK ASSY
    IC3603A280B SUBCOMPONENT OF IC3603A282C
    IC3603A281 HEAT SINK ASM
    IC3603A281-1 SUBCOMPONENT OF IC3601282A
    IC3603A282A POWER SUPPLY
    IC3603A282B INVERTER
    IC3603A282C GE BLACK START INVERTER
    IC3603A282D POWER SUPPLY
    IC3603A285 POWER SUPPLY
    IC3603A285A POWER SUPPLY
    IC3603A285B POWER SUPPLY
    IC3603A285E POWER SUPPLY
    IC3603A290A RECTIFIER MODULE
    IC3603A291 RECTIFIER
    IC3603A310A SUBCOMPONENT OF IC3607D108A
    IC3603A328A HEAT SINK ASM
    IC3605  C022CP250FGAY FIELD EXCITER
    IC3605  C040FP090FGBY FIELD EXCITER
    IC3605  C080FP360FGBY RECTIFIER ASSEMBLY
    IC3605  C120FP360FGBY RECTIFIER ASSEMBLY
    IC3605  C150FP560FGDY RECTIFIER ASSEMBLY
    IC3605  D018FP090FGBY FIELD EXCITER
    IC3605  D018NP180FGAN RECTIFIER ASSEMBLY
    IC3605  D080FP360FGBY RECTIFIER ASSEMBLY
    IC3605  E018FP180FGBY FIELD EXCITER
    IC3605  E080NP090FGAN CELL STACK ASM
    IC3605  G080FP360FGBN FIELD EXCITER
    IC3605  G080FP360FGBY RECTIFIER CONTROL ASM
    IC3605  G080NP360FGAN SILCON RECTIFIER PAC
    IC3605  G120FP360FGBN RECTIFIER CONTROL ASM
    IC3605  G120NP360FGAN RECTIFER CONTROL ASM
    IC3605  G150NP280FGAN CONTACT SALEM REN PT
    IC3605C022CP250FGAY FIELD EXCITER
    IC3605C040FP090FGBY FIELD EXCITER
    IC3605C080FP360FGBY RECTIFIER ASSEMBLY
    IC3605C120FP360FGBY RECTIFIER ASSEMBLY
    IC3605C150FP560FGDY RECTIFIER ASSEMBLY
    IC3605D018FP090FGBY FIELD EXCITER
    IC3605D018NP180FGAN RECTIFIER ASSEMBLY
    IC3605D080FP090FGBY FIELD EXCITER
    IC3605D080FP360FGBY RECTIFIER ASSEMBLY
    IC3605E018FP180FGBY FIELD EXCITER
    IC3605E080NP090FGAN CELL STACK ASM
    IC3605G080FP360FGBN FIELD EXCITER
    IC3605G080FP360FGBY RECTIFIER CONTROL ASM
    IC3605G080NP360FGAN SILCON RECTIFIER PAC
    IC3605G120FP360FGBN RECTIFIER CONTROL ASM
    IC3605G120NP360FGAN RECTIFER CONTROL ASM
    IC3605G150NP280FGAN CONTACT SALEM REN PT
    IC36065119A
    IC3606AMIL1 PCB CIRCUIT BOARD
    IC3606ATCA1 IC3606ATCA
    IC3606ATCB1 THERMO CONDT.PASSIVE IC3606ATCB
    IC3606DEXB1 CARD-EXTENDER-BOARD
    IC3606DEXC1 MODULE
    IC3606SANB1 ANNUNCIATOR MASTER
    IC3606SASB1 AUTO-SYNCH-MOD-PWB
    IC3606SFCK1 SNUBBER CARD
    IC3606SIFA9 FILTER CARD IC3606SIFA
    IC3606SIIA9 ISOLATOR CARD
    IC3606SIIE9 ISOLATED INPUT CARD
    IC3606SPCA1 6-PULSE-NR-CONT-CRD
    IC3606SPCB1 CARD
    IC3606SPCC1 6-PULSE-NR-SPEED-CUR
    IC3606SPCD1 CARD
    IC3606SPCE1 SNUBBER-CARD
    IC3606SPCF1 SNUBBER CARD
    IC3606SPCG1 SILTROL+CORE-REG-CBD
    IC3606STMF1 THERMOCOUPLE AVERAGING MOD
    IC3606STMG1 SW CD-THERMOCOUP AVG
    IC3606STMJ1 THERMO AVERAGING MODULE IC3606STMJ
    IC3606STML1 THERMOCOUPLE AVERAGING MODULE
    IC3606TPAN1 PCB IC3606TPAN
    IC3606TPAS1 PULSE XFMR BD
    IC3606TPAV1 PULSE AMPLIFIER
    IC3606YABA1 GE CARD
    IC3606YAUA1 DLC BOARD
    IC3606YDBA2 DIG BUS CONTROL
    IC3606YMID1 RAM/ROM CARD 8K
    IC3606YSMA1 MAINTENANCE MODULE FUNCTION
    IC3606YSMID1 SPEEDTRONIC
    IC3606YSQA2A GE SPEEDTRONIC
    IC3606YSQB1 GE CARD
    IC3606YSQC1 GE CARD
    IC3607D104A H.S.A.
    IC3607D105A GENERAL ELECTRIC SPEEDTRONIC
    IC3607D107A POWER SUPPLY
    IC3607D109A POWER SUPPLY
    IC3607D11 POWER SUPPLY
    IC3625DE4U34A POWER SUPPLY
    IC3655A105A3D030D POWER SUPPLY
    IC3800TLFA1
    IC4501101
    IC4501108A POWER SUPPLY
    IC4988A100AA GE CALIBRATOR
    IC600CB524M
    IC600FP500K
    IC660ELB912J SPEEDTRONIC
厦门兴锐达自动化设备有限公司是一家从事科研开发和工程技术服务的高新技术企业.主营业务:中低压电气,电气自动化,工程设计,技术服务等,是福建省著名的工业电气自动化单位.公司本着"准确,高效,全面,公平,创造财富,提高资源利用率"为宗旨,服务于省内外各…  更多>>
厦门兴锐达自动化设备有限公司
联系人:王文光
地址:厦门市湖里区五缘湾营运中心1号楼2层EF单元
邮编:361009
电话:0592-5580707
传真:0592-5361289
公司网址:http://www.xmxrdauto.com.cn
  • 劉治安 在2025/7/8 16:34:00留言
  • 详细留言:安川HW9171094-A請惠予報價
  • William Almeida 在2015/3/19 1:32:00留言
  • 详细留言:Dear Sirs, We, at Motivax, would be glad to work with your company, in a mutual colaboration. To achieve this goal, we would like to ask your promptly help to quote the selected parts below, giving us your best price for sale: Item 1. Reference: 5501-470. Gás turbine module WOODWARD. 1 UNIT. Item 9. Reference: 5466-031. specific card for Gás turbine Pratt&Whitne. WOODWARD. 9 UNIT. Please make sure to send me the Lead Time to delivery, the weight and dimension of the material. If you are offering an alternative item, please send its datasheet. Best Regards, Mr. WillIam de Almeida Commercial Department Motivax 1982 NW 82nd Ave Miami, FL 33126, USA Phone: +1(786)2205825 7001498012
  • Petruzzi 在2011/10/24 18:44:00留言
  • 详细留言:OMRON R88M-H50030 AC SERVO MOTOR 500W speed 3000 rpm
  • joe scarlotto 在2011/10/5 2:48:00留言
  • 详细留言:Need p/a qty 3 A2260A 745/50 CPU'S
