  • WOHRLE继电器、WOHRLE开关经销商
  • 发布时间:2026/3/19 9:30:55   修改时间:2026/3/19 9:30:55 浏览次数:53
  • WOHRLE电源代理商WOHRLE单相电源经销商
     2023WOHRLE工厂授权上海航欧中国区代理
    上海航欧销售WOHRLE电源选型、WOHRLE单相电源选型WOHRLE不间断电源选型WOHRLE模块选型、WOHRLE继电器选型、WOHRLE开关选型根据客户需要提供系统定制解决方案
    WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
    主要型号:
    ATS2-440-11-400MS224009PH120-1306EPH231506AV3-220-06-300ANKA-V3-220-06-300MS2-240-09-11-201AV3-220-06-300WOHRLE航欧 WISUS-K-6主轴驱动
     WOHRLE航欧 AKKU-SYS24180S
     WOHRLE航欧 SW-200-01
     WOHRLE航欧 USVWISUS-M(360-480kVA)
     WOHRLE航欧 DPNW2420
     WOHRLE航欧 Profibus-ConverteralsErg?nzungzumCS121-SCM;
     WOHRLE航欧 DB-14C/SK2/PC/203/UB
     WOHRLE航欧 USVWISUS-K(6-20kVA)
     WOHRLE航欧 RS232-Kabel,9-polig
     WOHRLE航欧 EPNSW240588-264VAC/24-28VDC5A
     WOHRLE航欧 UGVC2412超级电容
     WOHRLE航欧 EPNW2404
     WOHRLE航欧 EDI-RED20UE?0,5V
     WOHRLE航欧 DPNW2440
     WOHRLE航欧 SNMP-AdapterCS121BudgetUniversal-Box
     WOHRLE航欧 EPNW2405
     WOHRLE航欧 UGV-LI2402
     WOHRLE航欧 BE2405CY
     WOHRLE航欧 EPNW1202
     WOHRLE航欧 CS-121-SPI-2显示器和LCD显示器
     WOHRLE航欧 UGVC2420超级电容
     WOHRLE航欧 USVWISUS-M(25-480kVA)
     WOHRLE航欧 Tiefentladeschutzbis100VDC
     WOHRLE航欧 EPN233020/N
     WOHRLE航欧 STS16
     WOHRLE航欧 DPNW2410
     WOHRLE航欧 SNMP-AdapterCS121SlotProfessionalmitModbus
     WOHRLE航欧 AV4-240-06-100高压电源
     WOHRLE航欧 EPNSW240185-264VAC/21,6-26,4VDC1A
     WOHRLE航欧 SNMP-AdapterCS121BudgetSlot
     WOHRLE航欧 EPNSW240285-264VAC/24-30VDC2,5A
     WOHRLE航欧 ZPNW2405
     WOHRLE航欧 AV3-220-06-300温度控制器
     WOHRLE航欧 Entkoppeldiode
     WOHRLE航欧 CS-121-BL编码器
     WOHRLE航欧 BE2405CY2429V
     WOHRLE航欧 CONVERTVT1
     WOHRLE航欧 EPNW240332430Ue=690VUimp=8kvLu=25A50/510HzIEC60439-1
     熔断器开关WOHNER160ALTS-00
     液晶面板WOHRLEANKANr.:ATS2-440-06-11-400SN:PN-100C0.4/3.090.75AMP
     电源WOHRLEMP1001050364整流电源NGI402430Prim:3*400+5%1-3A
     DISPLAYWOHRLEMP6121103022100COMMUNICATIONWITHPROCESSOR
     备件WOHRLEEU-ANW-WD1/230230VS-NYH60146
     配件WOHRLEANKAG50173AN:AV3-220-06-30024VDC0.4AVERS50.2
     显示器WOHRLEMBF2-14C-21111100
     操作显示屏WOHRLEANKAARTNR:AV3-220-06-30
     显示器WOHRLEANKAART:AV3-240-06-300SN:K5.000424DC
     操作箱WOHRLEANKAART.NR:ATS2-440-06-11-400SN:PN-10024VDC0.75AMP
     配件WOHRLE21235DC24V20A继电器
     备件WOHRLETPYE:ANKAARTNR:AV3-220-06-300SERNR:M50012
     显示器WOHRLEANKAR4-02224VDC0.40AArtNO:AV3-220-06-300
     显示器WOHRLEMC-09/SK2L-103序列号:10156
     显示器WOHRLEATS2-440-06-11-400815-057-21
     upsWOHRLE71144steinenbronnUNG402420prim3*400V±5%(A)
     显示器WOHRLECB-09/SK2L-303ser-nr.K8-09290-260VAC
     文本显示器WOHRLEAV3-220-06-300E6000424V/DC0.4AE0.2文本显示器
     显示屏WOHRLEDB5-14C-3525AA-0221000SERNO:G8-008230V50/60HZ
     显示屏WOHRLEDM-14C/SK20PCSERNO:12344/15220VAC50/60HZ显示屏
     配件WOHRLE21295DC24V20A继电器
     传感器WOHRLETYPE:ANKAARTNR:AV3-200-06-30024VDC
     光学传感器WOLF&BECKOTM3A-20
     光学传感器WOLF&BECKOTM3A-50
     备件WOLFERD315M-4B
     备件WOLFERD180L-4
     备件WOLFERD112M-4
     电机WOLFERDRKO200L-4B/SFB16HT30KWSN:156476
     WOHRLE航欧 KA-USV-Typ01
     WOHRLE航欧 DPN402480/W
     WOHRLE航欧 DB5-1211AA-0221000CPU和处理器
     WOHRLE航欧 CS-121-SC图表记录
     WOHRLE航欧 BP/CON6k电子离合器,刹车模块
     WOHRLE航欧 CS-121-Mini计时器
     WOHRLE航欧 USVWISUS-M(25-320kVA)
     WOHRLE航欧 wandeltMODBUSinProfibus
     WOHRLE航欧 EPNW2410
     WOHRLE航欧 EDI402128V
     WOHRLE航欧 AV3-240-06-100
     WOHRLE航欧 Akkumulatoren-Systembestehendaus2Akkumulatoren12V/18Ah,Halterung,Sicherung40A
     WOHRLE航欧 AV3-240-09-300
     WOHRLE航欧 EPNSW4810
     WOHRLE航欧 WISUS-K-20
     WOHRLE航欧 ZPNW2420
     WOHRLE航欧 SW-100-01100A9,1VDC
     WOHRLE航欧 CONVERT19KIT
     WOHRLE电源 DB-12/SK2L/CP/200流量计
     WOHRLE电源 USR24402129V
     WOHRLE电源 überwachungs-undSteuerbaugruppefür24VDCUSV-Anlagen
     WOHRLE电源 UGVCM2420-100超级电容
     WOHRLE电源 CP526CP581DB06WF470
     WOHRLE电源 USVWISUS-G(30-120kVA)
     WOHRLE电源 CONVERTVT3
     WOHRLE电源 WISUS-K-10电子离合器,刹车模块
     WOHRLE电源 EntkoppeldiodemitEingangsüberwachung
     WOHRLE电源 SW-50-0150A9,1VDC
     WOHRLE电源 AS2-440-06-11-00-00矢量驱动
     WOHRLE电源 USVWISUS-M(25-480kVA)
     WOHRLE电源 CONVERTVT6
     WOHRLE电源 EPNSW240488-264VAC/24-30VDC4A
     WOHRLE电源 MO12TC/20/U电源
     WOHRLE电源 BS2-240-09-111-400HVAC控制系统
     WOHRLE电源 CS-121-SCM模拟和数字电路板
     WOHRLE电源 AV3-240-06-101数控机床控制
     WOHRLE电源 EPNW2420
     WOHRLE电源 EPNSW241088-264VAC/24-28VDC10A
     WOHRLE电源 AV3-240-09-101离合器和制动器
    上海航欧销售WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
  • 朱磊 在2026/3/18 8:59:00留言
  • 详细留言:1906R-035单向阀
  • 在2025/12/25 9:25:00留言
  • 详细留言:6A37-SS
  • 胡光旭 在2025/12/10 16:20:00留言
  • 林小姐 在2025/11/27 16:54:00留言
  • 详细留言:采购MTE电容器MTECAP-283
  • 刘言 在2025/11/24 15:20:00留言
  • 详细留言:PBL6/VMP 38/5.TS.S
