2023年WOHRLE工厂授权上海航欧中国区代理WOHRLE电源
上海航欧销售WOHRLE电源选型、WOHRLE单相电源选型WOHRLE不间断电源选型WOHRLE模块选型、WOHRLE继电器选型、WOHRLE开关选型根据客户需要提供系统定制解决方案
WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
主要型号:
ATS2-440-11-400;MS224009;PH120-1306;EPH231506;AV3-220-06-300;ANKA-V3-220-06-300;MS2-240-09-11-201;AV3-220-06-300WOHRLE航欧 WISUS-K-6主轴驱动
WOHRLE航欧 AKKU-SYS24180S
WOHRLE航欧 SW-200-01
WOHRLE航欧 USVWISUS-M(360-480kVA)
WOHRLE航欧 DPNW2420
WOHRLE航欧
Profibus-ConverteralsErg?nzungzumCS121-SCM;
WOHRLE航欧 DB-14C/SK2/PC/203/UB
WOHRLE航欧 USVWISUS-K(6-20kVA)
WOHRLE航欧 RS232-Kabel,9-polig
WOHRLE航欧 EPNSW240588-264VAC/24-28VDC5A
WOHRLE航欧 UGVC2412超级电容
WOHRLE航欧 EPNW2404
WOHRLE航欧 EDI-RED20UE?0,5V
WOHRLE航欧 DPNW2440
WOHRLE航欧 SNMP-AdapterCS121BudgetUniversal-Box
WOHRLE航欧 EPNW2405
WOHRLE航欧 UGV-LI2402
WOHRLE航欧 BE2405CY
WOHRLE航欧 EPNW1202
WOHRLE航欧 CS-121-SPI-2显示器和LCD显示器
WOHRLE航欧 UGVC2420超级电容
WOHRLE航欧 USVWISUS-M(25-480kVA)
WOHRLE航欧 Tiefentladeschutzbis100VDC
WOHRLE航欧 EPN233020/N
WOHRLE航欧 STS16
WOHRLE航欧 DPNW2410
WOHRLE航欧
SNMP-AdapterCS121SlotProfessionalmitModbus
WOHRLE航欧 AV4-240-06-100高压电源
WOHRLE航欧 EPNSW240185-264VAC/21,6-26,4VDC1A
WOHRLE航欧 SNMP-AdapterCS121BudgetSlot
WOHRLE航欧 SNMP-AdapterCS121SlotProfessional
WOHRLE航欧 EPNSW240285-264VAC/24-30VDC2,5A
WOHRLE航欧 ZPNW2405
WOHRLE航欧 AV3-220-06-300温度控制器
WOHRLE航欧 Entkoppeldiode
WOHRLE航欧 CS-121-BL编码器
WOHRLE航欧 BE2405CY24–29V
WOHRLE航欧 CONVERTVT1
WOHRLE航欧
EPNW240332430Ue=690VUimp=8kvLu=25A50/510HzIEC60439-1
熔断器开关WOHNER160ALTS-00
液晶面板WOHRLEANKANr.:ATS2-440-06-11-400SN:PN-100C0.4/3.090.75AMP
电源WOHRLEMP1001050364整流电源NGI402430Prim:3*400+5%1-3A
DISPLAYWOHRLEMP6121103022100COMMUNICATIONWITHPROCESSOR
备件WOHRLEEU-ANW-WD1/230230VS-NYH60146
配件WOHRLEANKAG50173AN:AV3-220-06-30024VDC0.4AVERS50.2
显示器WOHRLEMBF2-14C-21111100
操作显示屏WOHRLEANKAARTNR:AV3-220-06-30
显示器WOHRLEANKAART:AV3-240-06-300SN:K5.000424DC
操作箱WOHRLEANKAART.NR:ATS2-440-06-11-400SN:PN-10024VDC0.75AMP
配件WOHRLE21235DC24V20A继电器
备件WOHRLETPYE:ANKAARTNR:AV3-220-06-300SERNR:M50012
显示器WOHRLEANKAR4-02224VDC0.40AArtNO:AV3-220-06-300
显示器WOHRLEMC-09/SK2L-103序列号:10156
显示器WOHRLEATS2-440-06-11-400815-057-21
upsWOHRLE71144steinenbronnUNG402420prim3*400V±5%(A)
显示器WOHRLECB-09/SK2L-303ser-nr.K8-09290-260VAC
文本显示器WOHRLEAV3-220-06-300E6000424V/DC0.4AE0.2文本显示器
显示屏WOHRLEDB5-14C-3525AA-0221000SERNO:G8-008230V50/60HZ
显示屏WOHRLEDM-14C/SK20PCSERNO:12344/15220VAC50/60HZ显示屏
配件WOHRLE21295DC24V20A继电器
传感器WOHRLETYPE:ANKAARTNR:AV3-200-06-30024VDC
光学传感器WOLF&BECKOTM3A-20
光学传感器WOLF&BECKOTM3A-50
备件WOLFERD315M-4B
备件WOLFERD180L-4
备件WOLFERD112M-4
电机WOLFERDRKO200L-4B/SFB16HT30KWSN:156476
WOHRLE航欧 KA-USV-Typ01
WOHRLE航欧 DPN402480/W
WOHRLE航欧 DB5-1211AA-0221000CPU和处理器
WOHRLE航欧 CS-121-SC图表记录
WOHRLE航欧 BP/CON6k电子离合器,刹车模块
WOHRLE航欧 CS-121-Mini计时器
WOHRLE航欧 USVWISUS-M(25-320kVA)
WOHRLE航欧 wandeltMODBUSinProfibus
WOHRLE航欧 EPNW2410
WOHRLE航欧 EDI4021–28V
WOHRLE航欧 AV3-240-06-100
WOHRLE航欧
Akkumulatoren-Systembestehendaus2Akkumulatoren12V/18Ah,Halterung,Sicherung40A
WOHRLE航欧 AV3-240-09-300
WOHRLE航欧 EPNSW4810
WOHRLE航欧 WISUS-K-20
WOHRLE航欧 ZPNW2420
WOHRLE航欧 SW-100-01100A9,1VDC
WOHRLE航欧 CONVERT19KIT
WOHRLE电源 DB-12/SK2L/CP/200流量计
WOHRLE电源 USR244021–29V
WOHRLE电源 überwachungs-undSteuerbaugruppefür24VDCUSV-Anlagen
WOHRLE电源 UGVCM2420-100超级电容
WOHRLE电源 CP526CP581DB06WF470
WOHRLE电源 USVWISUS-G(30-120kVA)
WOHRLE电源 CONVERTVT3
WOHRLE电源 WISUS-K-10电子离合器,刹车模块
WOHRLE电源 EntkoppeldiodemitEingangsüberwachung
WOHRLE电源 SW-50-0150A9,1VDC
WOHRLE电源 AS2-440-06-11-00-00矢量驱动
WOHRLE电源 USVWISUS-M(25-480kVA)
WOHRLE电源 CONVERTVT6
WOHRLE电源 EPNSW240488-264VAC/24-30VDC4A
WOHRLE电源 MO12TC/20/U电源
WOHRLE电源 BS2-240-09-111-400HVAC控制系统
WOHRLE电源 CS-121-SCM模拟和数字电路板上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
793-503 现货查询 标记 WAGO
793178(用于SZS-67/82,4油缸的密封件) 现货查询 密封圈 ROHM
7932 现货查询 计数器 TRUMETER
793405250 现货查询 中强度螺纹紧固胶\50g BACO
793411050 现货查询 高强度螺纹紧固密封胶\50g\红色 BACO
7954 现货查询 计数器 TRUMETER
79763251 现货查询 79764036 接线盒 MAHLE
7C-23658-DCA 现货查询 开关 GOSWITCH
7D2C50-AAACJCAAAADESKA1+AK 现货查询 涡街流量计 E+H
7E1651 10.8V 现货查询 气动胶枪电池 COX
7E1652 现货查询 气动胶枪充电器 COX
7EX290.50-1 现货查询 数控模块 B&R
7H 现货查询 联轴器弹性胶块 T B WOODS
7HS 现货查询 联轴器弹性胶块 T B WOODS
7J 现货查询 联轴器弹性胶块 T B WOODS
7MM,291 现货查询 L型套筒扳手 USAG
7N 现货查询 联轴器弹性胶块 T B WOODS
7SM2 200L 4 30KW B5 现货查询 电机 SMEM
7WAR 72 N4 THTF 现货查询 3AWAR 71-04F 0,37KW
IE1(最新的替代型号:3CWAR 71-04F-TH,0.37KW, 1395RPM, 230/400V) 电机 watt drive
7i77 现货查询 控制器 MESA
8-263-610-021-1 现货查询 制动器配件(快放阀) WICHITA
8.5000.0000.1024.S066 现货查询 编码器 KUBLER
8.5000.8351.1000 现货查询 编码器 KUBLER
8.5000.8352.0500 现货查询 编码器 KUBLER
8.5020.0A10.2048.S149 现货查询 编码器 KUBLER
8.5020.4551.1024 现货查询 编码器 KUBLER
8.5020.C35F.0500.0020-C 现货查询 编码器 KUBLER
8.5020.D310.2048.S130 现货查询 编码器 KUBLER
8.5020.D511.4096 现货查询 编码器 KUBLER
8.5020.D544.4096 现货查询 编码器 KUBLER
8.5020.D55A.5000.0020 现货查询 编码器 KUBLER
8.5821.0020.1000.S011 现货查询 编码器 KUBLER
8.5852.0000.G121.Y026 现货查询 编码器 KUBLER
8.5868.12C2.C212 现货查询 编码器 KUBLER
8.5883.B00D.0303.S005 现货查询 编码器 KUBLER
8.A02H.T05B.2048.S003 现货查询 编码器 KUBLER
80 CMR 现货查询 变流器膨胀罐 Ibaiondo
80-01-0003-00 现货查询 通球指示仪主板 Control Devices
80-X3011X-1024.MN26 现货查询 编码器 HOHNER
80.549.364 for DM-150/120amp 模块包含程序,适用于变频器DM150. 现货查询 变频器模块 ELECTROCRAFT
80/200 CPUI/M 现货查询 80/200 XT/M 气缸 WAIRCOM
80/3/2 现货查询 弹簧 HENNLICH
80/3/3 现货查询 弹簧 HENNLICH
80/55 CX 现货查询 80/55 CXL 气缸 WAIRCOM
80/80 DBUI/M7 现货查询 气缸 WAIRCOM
80/SG/AX/S2 现货查询 密封件 WAIRCOM
800# 228*280 现货查询 水砂纸 DEER
800-026 现货查询 过滤芯 HTI
8000 现货查询 隔膜泵 Larius
8001458 现货查询 传动皮带 PAXTON PRODUCTS
8006 500 N1/min 现货查询 流量计 Burkert
800R-3HZ4R 现货查询 继电器 AB
800T-A2D1 现货查询 继电器 AB
800TXAP 现货查询 继电器 AB
801 156
M4/φ5.0/Tx 10 PLUS 现货查询 螺丝刀批头 STOGER
801 370 M8,φ10,0, Tx 30 Plus 现货查询 可互换螺丝刀批头 STOGER
8017141 TYPE 24 现货查询 隔膜片 MGM
80184S 现货查询 弹簧 CENTURY SPRING
80210-100K 现货查询 称重传感器 ARTECHE
80210-125K 现货查询 称重传感器 ARTECHE
8027 现货查询 双向阀 Larius
80299 现货查询 配件 LEGRAND
802T-DPD 现货查询 限位开关 AB
8040/1180X-10L07SA08 现货查询 感应传感器 STAHL
804001E03M050 现货查询 884031K05M050 接插件 BRAD HARRISON
804448-SX 现货查询 力矩测试仪用底座 Solartron
8049-4 现货查询 阀门定位器 SCHUBERT&SALZER
805-122-541 现货查询 汽车连接器 HIRSCHMANN
805-200-521 现货查询 端子外壳 HIRSCHMANN
805490-SX 现货查询 力矩测试仪用块规 Solartron
806410-SX 现货查询 夹具 Solartron
8064A7716-AA 现货查询 恒温阀 AMOT
8066 现货查询 8067 便携式手持式气体检测仪 MATHESON
8066 现货查询 8068 气体检测仪 MATHESON
807-NY-24W-K 现货查询 继电器 TAKAMISAWA
8070/2-1-W-U60 现货查询 开关 STAHL
808-10 现货查询 压力开关 HAVER&BOECKER
8082/1 现货查询 触点 STAHL
8082/1-1-00 现货查询 盒子内常开开关触点 STAHL
8082/1-2-00(NO) 现货查询 按钮开关接点 STAHL
8082/3-11-2-0 现货查询 8082/3-21-2-0 240899 安全输出模块 STAHL
809-BR-HS 115V 现货查询 磁力泵 MARCH PUMP
80H/KS113/214 现货查询 PVA KL26 放大器 KOPPEN&LETHEM
80PS080X3.10-01 现货查询 电源模块 B&R
80VD100PD. C000-01 现货查询 驱动器 B&R
81 P ML A3/2 242 现货查询 081P00 8P070A B 压力指示控制器 OMC
81-062-06 现货查询 金属弹片 ELMA
81-20518-A2 现货查询 行程开关 GO SWITCH
81-255 现货查询 上下把手 ELMA
81-256 现货查询 上把手 ELMA
8102/21-42-C1151 现货查询 STAHL STAHL
8102111305 RHGP-G 现货查询 8104116203 RLGP-G 压力开关 ANTUNES CONTROLS
8104116304 RLGP-G 现货查询 压力开关 ANTUNES CONTROLS
814-00064 现货查询 滑动轴承组件 PRG
81441121-001 现货查询 软保护盖 AZBIL
8146 R5K L.1 现货查询 电阻 BI
815 B-GBP 现货查询 轴承 SFERAX
81505160 现货查询 气动可调开关 CROUZET
81532001 现货查询 底座 CROUZET
816B 现货查询 直线轴承 SFERAX
8185591 现货查询 整流器 MAYR
81901 现货查询 比例电磁阀 THOMAS
"8194231-1(899
.000.01)" 现货查询 制动器 MAYR
82.031.0002.0 现货查询 82.003.0110.0 隔离变送器 WIELAND
82054 现货查询 气动润滑泵 LINCOLN
821001108 现货查询 不锈钢旋转接头 RAMEX
822-10-5 220V 250W 现货查询 加热器 RABOURDIN
82263 现货查询 报警灯 SIRENA
822TD10H-UNI 现货查询 继电器 MAGNECRAFT
824-NLU-0000-T 现货查询 90-286-LSD-00 液位传感器 COOPER
8252.H4.2517.24.19.44.61.1M 现货查询 压力传感器 Trafag
82548644 现货查询 主钩钢索 DEMAG
82570 现货查询 柱塞泵 LINCOLN
829-151.21K0+point milieu 现货查询 操纵杆 MEGATRON
82A-BB-BKA-TM-DDAJ-1KE 现货查询 电磁阀 MAC
82A-BC-000-TM-DAAP-3DA 现货查询 电磁阀 MAC
83054 现货查询 维修包 LINCOLN
83186003 现货查询 限位开关 CROUZET
8332474.6176.02400 现货查询 电磁阀 BUSCHJOST
83336-4 现货查询 注油器 LINCOLN
83338
现货查询 注油器 LINCOLN
834-3540M 现货查询 驱动器 APPLIED MOTION
8344G44 24VDC 现货查询 8344G044,24VDC 电磁阀 ASCO
83513 现货查询 气动泵 LINCOLN
836222.04,A638484A1/1, 30 kW 400V 现货查询 加热器 Vulcanic
83668 现货查询 气动泵 LINCOLN
83834 现货查询 干油泵 LINCOLN
84-6020.0020A 现货查询 84-6820.0020A 按钮 EAO
842-1-5 现货查询 气动报警器 ROTOTHERM
843DP-A4I1SK-AM 或者IDP10-A22C21F-M1 现货查询 IDP10S-T22C21FA-M1 压差变送器 FOXBORO
