  • ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀
  • 发布时间:2025/5/21 9:09:34   修改时间:2025/5/21 9:09:34 浏览次数:2060
  • 上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机
    ARIS    PD35
    ARIS    PE55-06
    ARIS    BE41-21003
    ARIS    ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
    ARIS    EF06-1
    ARIS    K3006/1242-84873-01001
    ARIS    FNr.1420-6259-01010;Typ:EF 1 MA333312
    ARIS    PE40-08
    ARIS Antriebe und Steuerungen GmbH    PE30-08
    aris    FNr: 0736-67622-01002
    aris    6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
    ARIS    N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
    Aris    PMR2 0700002 NR:0216-52001-001
    ARIS     0542-61428-02010 N-B1-E
    Aris    K3006 FNR.1137-5461-01059
    ARIS    FNr:1142-5481-02040
    ARIS    FNr:1219-83411-01003
    Aris    K3012,Stroke -- 300mm;actuating force --- 1200N;voltage --- 230V/50Hz;actuating speed --- 1.7(2) sec;
    ARIS    PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise 81020/06
    ARIS    PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27, counterclockwise 81928/03
    ARIS    N 5 1209-82710-01003 30 s / 90??+ PMR 3
    ARIS    Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
    ARIS    FNr:0908-4966-01008 Typ:EF1
    ARIS    NL-90/120
    Aris    Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage: 220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
    ARIS    TYP.N5 FNr.1117-79726-01002
    Aris    1206-S2453-02002 N5L SNR107504
    ARIS    0906-71866-01002??N6S DN1120d
    aris    PE60-08 0087.00033
    aris    0301-54088-01006
    ARIS     TYPE:N5 230V 50HZ 18VA 110Nm 90' 50S IP54
    Aris    Nr.1012-5165-02067
    ARIS    WRK 3012 Nr.9425-16842-01011 220V 50HZ 17VA 1200N 200S/300MM
    ARIS    NL-90/120
    ARIS    EV61-521MJ1
    ARIS    K 3012 1126-79613-01002
    ARIS    K 3012 1126-79612-01002
    ARIS    N5 RD-S/DN250d /0620-62724-01001/:230v 50(60)HZ
    ARIS    N1-RD-S/DN125d/1108-78827-02036
    ARIS    N4 230v 50HZ 30Nm 35VA 6U 4??2(3??5)S/90??FNr??0816-69661-01002
    ARIS    type K3012 1,7/1200 2ZW; regulating distance: 300 mm;actuating force: 1200 N; actuating time: 176 s; nominal ,voltage: 230 V AC, 50Hz; nominal power: 31 W; protection ,class: IP 54; limit switches: 2 (standard), 2 (additio
    ARIS    BE41-210003
    ARIS     N5 1209-82710-0100330 S/90+PMR3
    Aris    FNr:1136-5463-01001 TYP:K1512
    Aris    FNr.1112-5375-04014 TPY:K3012
    Aris    FNr.1026-5230-01040 TPY:K3006
    ARIS    1217-83288-01001
    ARIS    1217-83288-01002
    ARIS    FNr.0906-71866-01003 TYP.N68 DN1120d
    ARIS    FNr.0751-4710-02034 Typ.K 3006
    Aris    K-A 3025
    ARIS Antriebe und Steuerungen GmbH    PE 30-08
    aris    typ nk3015 dn150d,FNr:1118-79608-02001
    Aris    PE20-08
    ARIS    0338-55766-01005 TYP:N3
    ARIS    RD-S DN125+N1 JN0 O-BDNR 2139147;TLNR 148048 257270/#16
    Aris    EV61-521MJ1上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
    0811404603     现货查询                   比例阀     BOSCH
    0811404773     现货查询         R901396519  4WRPE 10 W6-80SJ-3X/M/24A1           REXROTH
    081509-0141   现货查询                   集电器     WAMPFLER
    081509-0142   现货查询                   碳刷         WAMPFLER
    0820029002   现货查询         5813490650     电磁阀     BOSCH
    0822008207     现货查询                   气缸         BOSCH
    0822334674     现货查询                   气缸         AVENTICS
    0822406001     现货查询                   气缸         AVENTICS
    083002-1X4  现货查询                   集电器     WAMPFLER
    0830100488     现货查询         R412022872    磁性开关         REXROTH
    083321   现货查询                   气弹簧     STABILUS
    084A36    现货查询                   动态力传感器冲击帽     PCB
    0850R010BN4HC     现货查询         0850R010ON   滤芯         HYDAC
    085146     现货查询                   气弹簧     STABILUS
    0866165  现货查询                   计数器     HENGSTLER
    0881317000000000         现货查询                        NORGREN
    08860  1/8"   现货查询                   截流阀     Aignep
    0893574050     现货查询                   中强度平面密封胶-DOS-桔红色-50G    WURTH
    08B-3(12350000006)       现货查询                   链条接头         TUNKERS
    09(BF 80/10)  09-1.28.33.34.44-0243   现货查询                   继电器     EMB
    09(BF 80/10)  09-3.28.33.36.44-0243   现货查询                   继电器     EMB
    09098-04 现货查询                   工业标准件     Norelem
    09120063041  现货查询                   外壳         HARTING
    09150006121  现货查询                   压针         HARTING
    09150006221  现货查询                   连接器     HARTING
    09160723001  现货查询                   连接器     HARTING
    09161083001  现货查询                   连接器     HARTING
    09161083101  现货查询                   连接器     HARTING
    09320323001  现货查询                   连接器     HARTING
    09330006123  现货查询                   连接器     HARTING
    09330009808  现货查询                   公头         HARTING
    09330009809  现货查询                   母头         HARTING
    09330062601  现货查询                   插头         HARTING
    09330242601+19300241522  现货查询                   连接器(含外壳)         HARTING
    095486 0300N 130/07 UF        现货查询                   气弹簧     STABILUS
    095739 BETAETIGER-S-GT-LN         现货查询                   固定件     EUCHNER
    0981 ENC 100  现货查询                   模块         LUMBERG
    09813-C   现货查询                   机械密封         BURKSPUMP
    0996000100     现货查询                   小额订单服务费     WURTH
    09990000012          现货查询                   连接器     HARTING
    0C0088-0100380M 现货查询                   弹簧         FEBROTEC
    0C0240-038-0880S  现货查询                   弹簧         FEBROTEC
    0C0300-0220380S   现货查询                   弹簧         FEBROTEC
    0D02170130OC00   现货查询         OD02360130OC00  线圈         OILCONTROL
    0D20910  现货查询                   弹簧         FEBROTEC
    0D21660  现货查询                   弹簧         FEBROTEC
    0GN120K 现货查询                   减速机     ORIENTAL
    0GS-EF-BJ005S          现货查询                   弹簧         FEBROTEC
    0GS-V08DAE0650    现货查询                   弹簧         FEBROTEC
    0W2827-024    现货查询                   弹簧         FEBROTEC
    1 4CB3600XTB2       现货查询                   执行器     JAMESBURY
    1-000000-05043-7 00M-11071536 现货查询                   电缆有接头     SANGEL
    1-000000-05821-10 00M-15070080        现货查询                   电缆有接头     SANGEL
    1-1/2"SANITRX HPX-90(SF)GAS ONLY      现货查询                   爆破片     CONTINENTAL
    1-1/2MAFB5CC        现货查询                   气缸         SHEFFER
    1-1/2MHSL2K  现货查询                   液压缸     SHEFFER
    1-1/2 Fig 301 Tank Heater  现货查询                   油箱加热器     Schutte+Koerting
    1-4635      现货查询                   计数器     TRUMETER
    1-C2/1T    现货查询                   传感器     HBM
    1-HLCA1C3/1.1T- 1         现货查询                   压力模块         HBM
    1-T210/10NM+3-3301.0159    现货查询                   传感器及附件         HBM
    1-Z6FC3/200Kg-1     现货查询                   荷重传感器     HBM
    1-Z6FC3/50KG-1    现货查询                   传感器     HBM
    1.1401-G25-A-00-0-P       现货查询         1.1401-G25-A-0C-0-P       滤芯         EPE
    1.18.3.A.E.---.DQFT.43M.S10  现货查询                   压力表     NUOVA FIMA
    1.561G40-A00-O-P  现货查询         1.561-G40-A-0C-0-P         滤芯         EPE
    1.5PE6.2D-G080S0  现货查询                   油泵         SALAMI
    1.691.1600.51 现货查询                   接头         HUMMEL
    1.6PB6,1D-G80S0    现货查询         1,5PE6,2/D-G80S0                   油泵         SALAMI
    1.71.212.001/0000 现货查询                   灯座         RAFI
    1.901-P10-A-00-0-P 现货查询         1.901-P10-A-0C-0-P 滤芯         EPE
    1//2'NPT 1.4539 HH500 VAC(50/60HZ) PALL:00890        现货查询                   执行机构         BADGER
    1/2  SAD-EP 2211050     现货查询                   振动器     CLEVELAND
    1/2      现货查询                   气动隔膜泵     VERSA-MATIC
    10 100001 0610       现货查询                   交流稳压电源模块         MSF
    10" Deck Brush        现货查询                   10寸软毛刷头(黄色)        SHURHOLD
    10-2513.1149  现货查询                   白色二极管     EAO
    10-3 现货查询                   接头         FOSTER
    10-3s/s     现货查询                   接头         FOSTER
    10-4000W020  现货查询                   增压泵     SC HYDRAULIC
    10-782-PP         现货查询                   液位开关         ERECTA SWITCH
    10.01.38.00408        现货查询                   密封板     SCHMALZ
    10.02.02.00655        现货查询                   过滤器插件(圆形)     SCHMALZ
    100-03670        现货查询                   螺栓         HORSTHEMKE
    100-150A-1-1-2-25,输入10-30VDC,输出4-20mA 现货查询                   压力传感器     NOSHOK
    100-203   现货查询                   螺丝M5 /M5 /15mm    MAS
    100-25-CS         现货查询                   过滤器滤芯     Balston
    100-7616-A      现货查询                   光纤面板         INCOM
    100/100 DFAB 现货查询                   气缸         WAIRCOM
    100/1800 XT/M5      现货查询                   气缸         WAIRCOM
    100/200 CPUI/M1 功能替代型号:100/200 XT/M1     现货查询                   气缸         WAIRCOM
    100/250 CPUI/M      现货查询         100/250 XT/M 气缸         WAIRCOM
    100/50AMAKV          现货查询                   气缸         API
    100/600 CPUI/M      现货查询         100/600 XT/M 气缸         WAIRCOM
    100007     现货查询                   电缆接头         SEAMETRICS
    100041 GP-DZ-050x020-M10x28-NR70  现货查询                   橡胶缓冲器     ELKO
    1000485 20米线缆   现货查询                   负荷传感器     BROSA
    1000895-180   现货查询                   气源管     TLD
    100150A  现货查询                   轴承         SFERAX
    10019728         现货查询                   火花塞     ECLIPSE
    1002-E1035      现货查询         1002-E1185      差压表     ORANGE RESEARCH
    1002692          现货查询                   美国Walker 滤芯  WALKER
    1003-S-0100-220V   现货查询         1003-S-0100(标准品需要自行配一个110V 适配器)         传感器     TRANS-TEK
    1004-1332        现货查询                   轴承零配件     TOLOMATIC
    1005-020-045  现货查询                   旋转接头         DEUBLIN
    10056005002  现货查询                   门栓         KASON
    10056CH5020 现货查询                   门锁        KASON
    10056CL5020  现货查询                   锁体         KASON
    10056L05020   现货查询                   门锁        KASON
    10058CL5020  现货查询                   门锁         KASON
    10059005001  现货查询                   锁钩         KASON
    10066000004  现货查询                   卡扣         KASON
    1007037          现货查询                   滤网         NORDSON
    1007063000     现货查询                   墙式对讲机终端     STENTOFON
    100832 75/1    现货查询                   支架         RIEGLER
    100848300       现货查询                   保护帽     Z-LASER
    100922.578.020.K_HA    现货查询                   过滤调节器     RIEGLER
    100932 NW8 L=4M 现货查询                   加热喉管         ROBATECH
    100LP/4 BRE40 TF F IG12 (NO.201569655-200   现货查询                   电机         NORD
    100MPB PLUG       现货查询                   接头         FOSTER
    100P50+50 CPUI/M1 功能替代型号:100P50+50 XT/M1   现货查询                   气缸         WAIRCOM
    101-0019 现货查询                   解调器     MICROFLEX
    101-0020 现货查询                   USB转换器     MICROFLEX
    101-0027 现货查询                   调制解调器     MICROFLEX
    101-0032 现货查询                   解调器     MICROFLEX
    101-1130-009  现货查询                   液压马达         EATON
    101-1512-009  现货查询                   液压马达         EATON
    101-1699-009  现货查询                   液压马达         EATON
    101090     现货查询                   控制模块         EZM
    1011.52.3.5M4R      现货查询                   电磁阀     PNEUMAX
  • 胡光旭 在2025/12/10 16:20:00留言
  • 林小姐 在2025/11/27 16:54:00留言
  • 详细留言:采购MTE电容器MTECAP-283
  • 刘言 在2025/11/24 15:20:00留言
  • 详细留言:PBL6/VMP 38/5.TS.S
  • 在2025/11/19 14:10:00留言
  • 详细留言:温度探头 1*PT100/B
  • 官冰 在2025/10/31 13:30:00留言
