  • MONITRAN编码器MTN/1185CQ-20
  • 发布时间:2025/5/31 10:14:29   修改时间:2025/5/31 10:14:29 浏览次数:2
  • 2010年MONITRAN工厂上海航欧中国区销售
     MONITRAN加速计、MONITRAN加速度传感器、MONITRAN传感器、MONITRAN编码器、MONITRAN震动探头
     上海航欧销售英国MONITRAN传感器,成立于1986年,是英国的振动传感器制造商。Monitran对速度计、机械保护和维修涡流探头的开发、生产和应用。Monitran的振动传感器,固定和移动监测系统及其辅助设备,如传感器,探头,转接器加速器探头驱动器和电缆组件等产品,Monitran产品通过ISO9001:2008认证,Monitran的加速计用于监测,如水泵、电机、传感器、加速器、探头风机、发动机、探头驱动器、
     常用型号:
     MTN/1185CM8-20
     1185CMPG7-100
     MTN/1185IC-50
     MTN/1185-CM8-25F
     MTN/1185CM-25
     MTN/EP080
     MTN/1187-10
     MTN/1187CM8-1/219
     MTN/IEAIW-75
     MTN/1185IC-20
     IEIRG050
     MTN/1187-10
     MTN/1188Q-1
     MTN/1120IHCF1/4
     MTN/1185ICM-25
     MTN/MH008
     MTN/1185
     MTN/1187
     VM120
     MTN/1100SC,,,5shanghaihangousalesesarmouredETFE
     Extratwincore,screened,overbraidedETFEcable,
     MTN/1100WSubmersible,,waterproofgland,5shanghaihangousaleses
     PUwaterproofshanghaihangousalest
     MTN/1100SWSubmersible,,waterproofgland,5shanghaihangousaleses
     PUwaterproofshanghaihangousalestr
     Extrathree-core,polyurethane,waterproofcable,
     MTN/1100IATEX/IECEx,,,2pinMS
     MTN/1100ICATEX/IECEx,,,5shanghaihangousaleses
     armouredETFEcableshanghaihangousales
     MTN/1100ISATEX/IECEx,,,2pinMS
     MTN/1100ISCATEX/IECEx,,,5shanghaihangousaleses
     MTN/7100Low,strain,smallfourmet
     MTN/7110Low,strain,largefourshanghaihangousales
     MTN/7120Low,strain,shanghaihangoushanghaihangousales
     Aboveallsuppliedwith5shanghaihangousalesesoverbraidedcable.Specifyrangeing
     MTN/7200Low,4-20mA,smallfourshanghaihangousales
     MTN/7210Low,4-20mA,largefourshanghaihangousales
    MTN/7220Low , 4-20mA , shanghai hangou shanghai hangou sales
    Above all supplied with 5 shanghai hangou saleses overbraided cable. Specify range in g
    MTN/P1100, charge , 1100pC/g, TNC connectorshanghai hangou sales
    MTN/P100T, charge , 20pC/g,
    MTN/P100, charge , 20pC/g,
    MTN/P50, charge , 50pC/g, , 5 shanghai hangou saleseshanghai hangou sales
    MTN/P05, charge , 5pC/g, , 5 shanghai hangou saleseshanghai hangou sales
    MTN/CA003In-line charge amplifier in stainless steel enclosure with connectors, 2mV/pC
    MTN/MS001Quick-fit to glue studshanghai hangou sales3.20metshanghai hangou sales2.70
    MTN/MS002Quick-fit to M8 male studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS003Quick-fit to M10 male studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS004Quick-fit to 1/4"UNF male studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS005Quick-fit to 1/4"UNF femaleshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS006Quick-fit to M6 male studshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS007Quick-fit to 10-32UNF femaleshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS008Quick-fit to M8 female studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS00910-32UNF to male glue studshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS010Quick-fit to glue stud (for 1020Q/1120Q series)shanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS0131/4"-28UNF male to glue studshanghai hangou sales3.20shanghai hangou sales356shanghai hangou sales2.70
    MTN/MS01410-32UNF male to glue studshanghai hangou sales3.20shanghai hangou sales356shanghai hangou sales2.70
    MTN/MS055Quick-fit to M8 male stud (for 1020Q/1120Q series)shanghai hangou sales3.20shanghai hangou sales2.70
    MTN/MS0671/4"-28UNF to M8shanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS0361/4"-28UNF to M6shanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS1241/4"-28UNF to M10shanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS1321/4"-28UNF to M12shanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS02410-32 UNF grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS032M6 x 12mm grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS0681/4"-28UNF grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS11Quick-fit female - 1/4" UNF malemet
    MTN/MS15Quick-fit female - 10-32 UNF maleshanghai hangou sales
    MTN/MS034Isolation Adaptor 1/4"-28UNF male to 1/4"-28UNF femaleshanghai hangou sales
    MTN/MS062Isolation Adaptor 10-32UNF male to 10-32UNF malemet
    MTN/MS093Isolation Adaptor Q/F male to M8 maleshanghai hangou sales
    MTN/MS112Isolation Adaptor M8 male to M8 femaleshanghai hangou sales
    MTN/MM0011/4"-28UNF male, 35mm, 2 pole type, 20kgsmet
    MTN/MM00210-32UNF male, 19mm, 7kgsshanghai hangou sales
    MTN/MM0031/4"-28UNF male, 38mm, 2 pole typemet
    MTN/MM00410-32UNF male, 35mm, 2 pole type, 20kgsshanghai hangou sales
    MTN/MM005Quick-fit male, 35mm, 2 pole type, 20kgsmet
    MTN/MM006M6 female, 19mm, 7kgsshanghai hangou sales
    MTN/MM007M8 female, 35mm, 2 pole type, 20kgsmet
    MTN/MM0081/4"-28UNF male 25.35mm, 2 pole type, 11kgsshanghai hangou sales
    MTN/MM00910-32UNF male, 25mm, 2 pole typemet
    MTN/MM010Quick-fit male, 25mm, 2 pole typemet
    MTN/MM0231/4"-28UNF female, 35mm, 20kgs shanghai hangou sales
    MTN/MM027M10 female, 35mm, 2 pole typeshanghai hangou sales
    MTN/PS0011/4" UNF , 25mmshanghai hangou sales
    MTN/PS0021/4" UNF , 100mmmet
    MTN/PS0031/4" UNF , 150mmmet
    MTN/PS0041/4" UNF , 200mmshanghai hangou sales
    MTN/PS00510-32 UNF , 25mmshanghai hangou sales
    MTN/PS00610-32 UNF , 100mmshanghai hangou sales4
    MTN/PS00710-32 UNF , 150mmshanghai hangou sales
    MTN/PS00810-32 UNF , 200mmshanghai hangou sales
    MTNMH001M8 spot face toolmet
    MTN/MH010ing stud adhesive (liquid steel type), for 20 -25 glue-on adaptorsmet
    MTN/3008Switch box, 8 , , IP65shanghai hangou sales
    MTN/3010Switch box, 10 , , IP65shanghai hangou sales
    MTN/3012Switch box, 12 , , IP65met
    MTN/3014Switch box, 14 , , IP65shanghai hangou sales
    MTN/3016Switch box, 16 , , IP65met
    MTN/3018Switch box, 18 , , IP65shanghai hangou sales
    MTN/3020Switch box, 20 , , IP65shanghai hangou sales
    MTN/3025Switch box, 25 , , IP65shanghai hangou sales
    MTN/3040Switch box, 40 , , IP65shanghai hangou sales
    MTN/3064Switch box, 64 , , IP65shanghai hangou sales
    MTN/9003-HD3 ,
    MTN/9004-HD4 ,
    MTN/9005-HD5 ,  shanghai hangou sales
    MTN/9006-HD6 ,  shanghai hangou sales
    MTN/9007-HD7 ,
    MTN/9008-HD8 ,  shanghai hangou sales
    MTN/9009-HD9 ,  shanghai hangou sales
    MTN/9010-HD10 ,  shanghai hangou sales
    MTN/9011-HD11 ,  shanghai hangou sales
    MTN/9012-HD12 ,  shanghai hangou sales
    MTN/9025-HD25 ,  shanghai hangou sales
    MTN/9040-HD40 ,  shanghai hangou sales
    MTN/9002-GRP2 t
    MTN/9003-GRP3 t
    MTN/9004-GRP4 shanghai hangou sales
    MTN/9005-GRP5 shanghai hangou sales
    MTN/9006-GRP6
    MTN/9007-GRP7 shanghai hangou sales
    MTN/9008-GRP8 t
    MTN/9009-GRP9 shanghai hangou sales
    MTN/9010-GRP10 shanghai hangou sales
    MTN/9011-GRP11 t
    MTN/9012-GRP12 t
    MTN/9002-ABS2
    MTN/9003-ABS3
    MTN/9004-ABS4 shanghai hangou sales
    MTN/9005-ABS5
    MTN/9006-ABS6
    MTN/9007-ABS7
    MTN/9008-ABS8
    MTN/9009-ABS9
    MTN/9010-ABS10 shanghai hangou sales
    MTN/9011-ABS11 shanghai hangou sales
    MTN/9012-ABS12 shanghai hangou sales
    Consult the sales office for other sizes
    MTN9000-GRP Series Junction Boxes
    hangou sales
    MTN/VM120KVM120, probe, cable, magnet, spike, case - kit as aboveshanghai hangou sales
    MTN/VM110Meter onlymet
    MTN/VM120Meter onlymet
    MTN/2100Hand held  probe with coiled cable (CA418), 1/4"-28UNF
    female ingshanghai hangou sales15556shanghai hangou sales14356shanghai hangou sales13256
    MTN/CA418Coiled cable assembly TNC to IA110 for use with MTN/2100 hand-held
    probeshanghai hangou sales4556shanghai hangou sales4256shanghai hangou sales3856
    MTN/1100, , , 2 pin MS connectormet
    MTN/CA042Coiled cable assembly 2 pin MS to IA110 for use with MTN/1100shanghai hangou sales
    MTN/1020, , , TNC connectormet
    MTN/CA043Coiled cable assembly TNC to IA110 for use with MTN/1020shanghai hangou sales
    MTN/MM001Magnetic base, 1/4"-28UNF male, 2 pole, 35mm dia, 20Kg forcemet
    MTN/PS001Spike probe, stainless steel, 25mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/PS002Spike probe, stainless steel, 100mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/PS003Spike probe, stainless steel, 150mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/PS004Spike probe, stainless steel, 200mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/HE001Carrying case with foam cutoutsshanghai hangou sales
    MTN/RC0100Recalibration, recommended annuallyshanghai hangou sales
    MTN/6000
    MTN/HE003Wall ed enclosure to accommodate shanghai hangou rackshanghai hangou sales25056shanghai hangou sales23156
    MTN/HE004Wall ed enclosure to accommodate two racksshanghai hangou sales35056shanghai hangou sales32456
    MTN/6200
    MTN/6100V
    MTN/6100GVibration module as above but measuring  (g)
    MTN/6500-1Temperature module for AD590, 1μA/oK  temperature sensormet
    MTN/6500-2Temperature module for PT100 2 wireshanghai hangou sales
    MTN/6500-3Temperature module for PT100 3 wireshanghai hangou sales
    MTN/6500-4Temperature module for 10mV/oC  temperature sensorshanghai hangou sales
    MTN/MH007Flashing light and sirenshanghai hangou sales
    MTN/MH099Flashing light onlyshanghai hangou sales20056shanghai hangou sales18556
    A complete 6000 system consists of an electronics rack with power supply,
    display, various signal input cards (one reqired for each sensor input) in an
    IP65 enclosure with up to 12 s, temperature sensors or eddy
    current probes. See the relevant sections for individual sensor prices.
    Any complete 6000 monitoring system including 6 or more  and
    sensors will receive a 5% overall discount.
    Model 6050 4 channel monitor
    MTN/6050-65
    MTN/6200
    MTN/6050-4V
    MTN/6050-4VT
    MONITORING SYSTEMS
    MONITORING SYSTEMS
    MTN/MH0022 pin MS mating connector, femaleshanghai hangou sales
    MTN/MH0083 pin 62GB mating connector, femaleshanghai hangou sales
    MTN/CA067BNC plug with strain relief, fitted to  cable. For connection to
    datalogger having a BNC socketshanghai hangou sales
    MTN/CA054BNC socket with dust cap in 90deg bracket, fitted to  cable.
    For connection to datalogger through accessory cable fitted with BNC plug or
    VS0004 vibration switchshanghai hangou sales
    MTN/CA0532 pin MS socket to free ends, overbraided ETFE, 5 shanghai hangou salesesshanghai hangou sales
    MTN/CA1373 pin 62GB socket to free ends, overbraided ETFE, 5 shanghai hangou salesesshanghai hangou sales
    Extra twin core, screened, armoured ETFE cable, per shanghai hangou salese
    Above are for connecting remote sensors to switch boxes, junction boxes or
    data systems. For other cable assemblies and cables to connect to portable
    data loggers please contact the sales office. We will need to know the type of
    cable required, length, sensor and measuring device to give a price.
    MTN/8301 cable checkershanghai hangou sales
    MTN/8302 signal simulatorshanghai hangou sales
    MTN/APSU01Battery powered constant current power supply with BNC socket for shanghai hangou
    MTN/8001Constant current power supply in DIN rail ed enclosure for use on
    24VDCshanghai hangou sales
    MTN/8001BNCConstant current power supply in DIN rail ed enclosure for use on
    24VDC with integral BNC socketshanghai hangou sales
    MTN/VC10Vibration calibrator shanghai hangou sales2,
    MTN/EP0802mm range, M8 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP2005mm range, M16 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP3408.5mm range, M24 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP340F8.5mm range, 3  flange including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP48012mm range, M30 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    Extra cable (priced per shanghai hangou salese)shanghai hangou sales
    Up to a maximum of 9 shanghai hangou saleses including the extension
    Alternative probe length and thread sizes available, consult the sales office
    MTN/EX--1 shanghai hangou salese extension cableshanghai hangou sales4
    Up to a maximum of 9 shanghai hangou saleses including the probe
    MTN/ECPDDriver, 0-16VDC  gap, -24VDCshanghai hangou sales
    MTN/ECPD+24Driver, 0-16VDC  gap, +24VDCshanghai hangou sales
    MTN/ECPD/78Driver, 0-10VDC  gap, +24VDCshanghai hangou sales
    MTN/ECPD/604-20mA  vibration, three wireshanghai hangou sales
    MTN/ECPD/854-20mA  gap, three wireshanghai hangou sales
    MTN/ECPD2AC4-20mA  vibration, two wire loop poweredshanghai hangou sales
    MTN/ECPD2DC4-20mA  gap, two wire loop poweredshanghai hangou sales
    MTN/P2424V DC power supply housed in die-cast box with glanded , 240 or
    110 volts input to power above drivers.shanghai hangou sales0C0088-0100380M 现货查询上海航欧                            FEBROTEC
    B35-12-BART-W3 停产  现货查询上海航欧                   B35-12-HW3    PLACID
    26-0190   现货查询上海航欧                            MCC
    delock gigabit LAN PCI express X4 card  PN4811G-2X2B  现货查询上海航欧                            Delock
    DIF DIG    现货查询上海航欧                            AR FILTRAZIONI
    ARNO3VFA PLUS YG CE 2,2KW 400V50HZ RAL9010+5012 Left?200      现货查询上海航欧         Art. 9393.20.21                 AR FILTRAZIONI
    914N-001          现货查询上海航欧                   SA914N    ECCO
    EEC-35     现货查询上海航欧                            FAGOR
    YP1K-PC/1N     现货查询上海航欧                            CAMOZZI
    PFA9165A0103001+ LIMITEG AG 2 contacts  现货查询上海航欧         EXA9000A0103014(包含PFA9000A0103014)                   TER
    GP1507S16       现货查询上海航欧                            HAMMOND
    Z5M18B3-F-520-lg90       现货查询上海航欧         ZM18GF510              Z-LASER
    BOS 12M-PS-RD12-S4      现货查询上海航欧                            BALLUFF
    VD-129     现货查询上海航欧                            GUTEKUNST
    D-100A-07        现货查询上海航欧                            GUTEKUNST
    D-008       现货查询上海航欧                            GUTEKUNST
    VD-232T  现货查询上海航欧                            GUTEKUNST
    401.23.05         现货查询上海航欧                            Dopag
    VC 1 C1 P1 P2 SH     现货查询上海航欧                            KRACHT
    ACU-307-1-V1309F  现货查询上海航欧                            TUNKERS
    4Z524A    现货查询上海航欧                            DAYTON
    PF-070703        现货查询上海航欧                            MEYLE
    AGX-2       现货查询上海航欧                            HI-Q
    FMS 18-34 UL4-60   现货查询上海航欧         510-51590                 SENSOPART
    EMAD108/EMAD208      现货查询上海航欧         61E024990                EUROGI
    VB28G210LM-230   现货查询上海航欧                            ACOPIAN
    TC-20/25EF 3340*50      现货查询上海航欧                            Habasit
    SMC-12L NO    现货查询上海航欧                            AECO
    X1-5150-0000  现货查询上海航欧                            ASCON
    893-1624VDC  现货查询上海航欧                            MARCH PUMP
    5-VMK 15NC    现货查询上海航欧         520798              COAX
    SEQ U11Y101U003  现货查询上海航欧                            MATHESON
    6T1 80A4 KW0,55 P4 230/400V-50HZ B3 IE1 ATEX II 3G Ex ec IIC T4 Gc - II 3D Ex tc IIIC T135°C Dc IP65"         现货查询上海航欧                            ELVEM
    G1314-60100   现货查询上海航欧                            AGILENT
    MGB-L2-ARA-AA2A1-S1-L-110709  现货查询上海航欧         110709              EUCHNER
    MGB2-H-BA1A8-L-157022       现货查询上海航欧                            EUCHNER
    MGB2-L1-BP-M-X0000-BX-162628 现货查询上海航欧                            EUCHNER
    8.A02H.T05B.2048.S003 现货查询上海航欧                            KUBLER
    8.5883.B00D.0303.S005 现货查询上海航欧                            KUBLER
    8.5020.4551.1024   现货查询上海航欧                            KUBLER
    CD/I 200/25 IE3       现货查询上海航欧                            EBARA
    SPDP-RF30-002         现货查询上海航欧                            ELCO
    CA-FC10-SH-FC10-2  (线长2英尺) 现货查询上海航欧                            US DIGITAL
    GR.110 UBC 用于UBC轴承座SN524  现货查询上海航欧         Z110                   UBC
    35780       现货查询上海航欧                            MESABI
    WB   现货查询上海航欧                            MESABI
    VS-130      现货查询上海航欧                            VIBCO
    CFW72-89-10/14.5 氟胶         现货查询上海航欧                            CFW
    HW-TRC Dust bag for AC200V TR-04-002       现货查询上海航欧                            SANKYO
    VBG000102      现货查询上海航欧                            hiessl
    SPK000218       现货查询上海航欧                            hiessl
    W1C 2xT1500 N16 WR    现货查询上海航欧         219039              IDEAL
    DT4-24     现货查询上海航欧         A21280559                ATR
    AM-215B-13-7R-SSX-UXW0     现货查询上海航欧                            watanabe
    SS-5T         现货查询上海航欧                            OMRON
    UCC-AB 687101.UC SBL 17207       现货查询上海航欧                            SF-FILTER
    375.03-ES         现货查询上海航欧         103483              RIEGLER
    206057111       现货查询上海航欧                            BACO
    DT09PY2  现货查询上海航欧         DE001256                  DELTRON
    HD-D 15 SY2    现货查询上海航欧         DE009647                  DELTRON
    SC100-600-5-YBY-36        现货查询上海航欧                            Tokyo sensor
    2470121  现货查询上海航欧                   2400121  EUROSWITCH
    E4T-1000-157-S-H-M-B    现货查询上海航欧                            US DIGITAL
    E8T-720-157-S-H-M-B      现货查询上海航欧                            US DIGITAL
    A5-48-14-C       现货查询上海航欧         63182900(MAEDLER)                MICHAUD CHAILLY
    ADA1000F-36  现货查询上海航欧                            COSEL
    ROTEX-GS12-92SH-A-GS-2.1-8/2.1-8       现货查询上海航欧                            KTR
    S30114  线长10        现货查询上海航欧                            EGE
    D2-08TD2         现货查询上海航欧                            automation direct
    213435   现货查询上海航欧                            IDEAL
    原产地证明     现货查询上海航欧                            FANOX
    6P18-A1C  WITH 18mm BORE WITH KEYWAY * WITH 18mm BORE WITH KEYWAY     现货查询上海航欧         6P18-A1C-035-035-01                   ZERO-MAX
    CT-1/160 现货查询上海航欧                            FANOX
    CT-1/80    现货查询上海航欧                            FANOX
    TEB051DW12018    现货查询上海航欧                   SJIC6060604WS12   KILLARK
    SIRC004C2O0DAB   现货查询上海航欧                            FANOX
    PRSL1810PI     现货查询上海航欧                            TER
    CU2102M60ANP01 现货查询上海航欧                            MP-FILTRI
    CU4002M250ZNP01        现货查询上海航欧                            MP-FILTRI
    R3EW-3/8         现货查询上海航欧                            SENOTEC
    XR70CX-5N0C0         现货查询上海航欧                            DIXELL
    QB2TBNICZP145PSG3D+PSR2PN+DSBEY00ZP145PSGA          现货查询上海航欧                            PROPORTION-AIR
    14000136         现货查询上海航欧                            BERGES
    VODL/N1116/38/G5.p4/ac CODE: 1554322100         现货查询上海航欧                            Walvoil
    MTN/RC0600Eddy Probe recalibration and certification in factory.met
  • 蔡莉 在2025/2/26 15:49:00留言
  • 详细留言:CTC AC184—1A 需求报价及购买方式
