  • 2016年FPZ上海航欧机中国区销售SK05MS+ACHG5
  • 发布时间:2025/5/20 9:52:13   修改时间:2025/5/20 9:52:13 浏览次数:148
  •   2016FPZ上海航欧机中国区销售SK05MS+ACHG5
    上海航欧机销售FPZ风机FPZ马达FPZ安全阀FPZ压力计FPZ过滤器FPZ滤芯FPZ电机FPZ弹性垫FPZ鼓风机FPZ高温风机FPZ轴承FPZ联轴器FPZ
     2016FPZ上海航欧机中国区销售
     意大利FPZ公司成立于1975年,FPZ公司是世界上的回收和侧通道风机的供应商,主要为空气和工业气体的输送、回收、循环服务。SK05MS+ACHG50SK05MS+ACHG50SCLK05-MSMOR2900-3500RPMM.E.2POLIKW2.2-2.55V/HZ230/400/50-265/460/60IP55CL.FTROP.L50K03-K04-K05-K06MS
     2016
    FPZ上海航欧机中国区销售
     FPZ1975FPZFPZSCL-06-0.20SCL-06SCL-K03-MS-0.37SCL-K03-MS-0.55SCL-K04-MS-0.75SCL-K04-MS-1.10SCL-K04-MS-1.50SCL-K05-MS-3.00SCL-K05-MS-1.10SCL-K05-MS-1.50SCL-K05-MS-2.20SCL-K06-MS-2.20SCL-K06-MS-3.00SCL-K06-MS-4.00SCL-K07-MS-2.20SCL-K07-MS-3.00SCL-K07-MS-4.00SCL-K07-MS-5.50SCL-K75-MS-4.00SCL-K75-MS-5.50SCL-K75-MS-7.50SCL-K08-MS-3.00SCL-K08-MS-4.00SCL-K08-MS-5.50SCL-K08-MS-7.50SCL-10DL-0.50SCL-15DH-0.75SCL-15DH-1.00SCL-20DH-1.00SCL-20DH-1.50SCL-30DH-2.00SCL-30DH-3.00SCL-40DH-3.00SCL-40DH-4.00SCL-K07R-MD-3.0SCL-K07R-MD-4.0SCL-K07R-MD-5.5SCL-K07R-MD-7.5SCL-K08R-MD-5.5SCL-K08R-MD-7.5SCL-K08R-MD-10.0SCL-K08R-MD-15.0SCL-K09-MD-5.5SCL-K09-MD-7.5SCL-K09-MD-10.0SCL-K09-MD-15.0SCL-K10-MD-7.5SCL-K10-MD-10.5SCL-K10-MD-15.0SCL-K10-MD-20.0SCL-K11-MD-10.0SCL-K11-MD-15.0SCL-K11-MD-20.5SCL-K11-MD-25.0SCL-K12-MD-15.0SCL-K12-MD-20.5SCL-K12-MD-25.0SCL-K03-TD-1.5SCL-K04-TD-2.0SCL-K04-TD-3.0SCL-K05-TD-3.0SCL-K05-TD-4.0SCL-K05-TD-5.5SCL-K06-TD-5.5SCL-K06-TD-7.5SCL-K06-TD-10.0SCL-K07-TD-7.5SCL-K07-TD-10.0SCL-K07-TD-15.0SCL-K08-TD-7.5SCL-K08-TD-10.0SCL-K08-TD-15.0SCL-K09-TD-15.0SCL-K09-TD-20.0SCL-K09-TD-25.0SCL-K10-TD-15.0SCL-K10-TD-20.0SCL-K10-TD-25.0SCL-K11-TD-20.0SCL-K11-TD-25.0SCL-115DH-15.00SCL-115DH-20.00SCL-115DH-25.00SCL-115DH-30.00SCL-115DH-40.00SCL-K03-TS-0.75SCL-K03-TS-1.10SCL-K04-TS-1.50SCL-K04-TS-2.20SCL-K05-TS-2.20SCL-K05-TS-3.00SCL-K05-TS-4.00SCL-K06-TS-4.00SCL-K06-TS-5.50SCL-K06-TS-7.50SCL-K07-TS-5.50SCL-K07-TS-7.50SCL-K07-TS-9.20SCL-K07-TS-11.00SCL-K07-TSSCL-K08-TS-5.50SCL-K08-TS-7.50SCL-K08-TS-9.20SCL-K08-TS-11.00SCL-K08-TS-15.00SCL-K09-TS-9.20SCL-K09-TS-11.00SCL-K09-TS-15.00SCL-K09-TS-18.50SCL-K10-TS-11.00SCL-K10-TS-15.00SCL-K10-TS-18.50SCL-K11-TS-11.00SCL-K11-TS-15.00SCL-K11-TS-18.50SCL-K11-TS-22.00SCL-115SH-11.00SCL-115SH-15.00SCL-115SH-18.50SCL-115SH-22.00SCL-115SH-30.00SCL-115SHSK05MS+ACHG50SK05MS+ACHG50SCLK05-MSMOR010-65681076QQ743116803
     2016FPZ上海航欧机中国区销售
    63-34047-843-NC    现货查询         6334047858 MARECHAL          插座本体         MELTRIC
    63-5008-S-D-02-B-0/1600 KPA          现货查询                   压力表     ASHCROFT
    63/100 XT/M    现货查询                   气缸         WAIRCOM
    63/50 XT/M      现货查询                   气缸         WAIRCOM
    63/700 XT/M 90°/EX      现货查询                   气缸         WAIRCOM
    630-1        现货查询                   涡流管*冷风枪       VORTEC
    6300D-63L        现货查询                   电磁阀   MAC
    6301K77  现货查询                   调平脚     MCMASTER CARR
    6306340     P 400 motor - 0.75kW - IP00    现货查询                   电机         PERFECTA
    631  现货查询                   涡流管*冷风枪       VORTEC
    6310         现货查询                   轴承         SKF
    6313         现货查询                   轴承         SKF
    6314010 NH3 0-100%LEL Sensor for OLCT100        现货查询                   传感器     OLDHAM
    6314029 NH3 0-100ppm Sensor for OLCT100          现货查询                   传感器     OLDHAM
    63165K92         现货查询                   配件         MCMASTER CARR
    63165K92         现货查询                   配件         MC MASTER-CARR
    632-S        现货查询                   脚踏开关         LINEMASTER
    637.35D/0.5-16bar 现货查询                   压力调节器     RIEGLER
    63700000001  现货查询                   硅脂         KASON
    63ET         现货查询                   熔断器     BUSSMANN
    63NZ02 63A     现货查询                   熔断器     BUSSMANN
    640.126 K-HA  现货查询                   过滤器     RIEGLER
    641-6        现货查询                   风速变送器     DWYER
    6420-24VDC F/I      现货查询                   转换器     NOKEVAL
    64331000         现货查询                   螺母         MAEDLER
    644-37460-1    现货查询                        LINCOLN
    644-37474-1    现货查询                        LINCOLN
    6441001  现货查询                   接头         CANTEX
    6493-011L01    现货查询         6493-0324105 控制器     SAMSON
    650-0300 现货查询                   连接器     DELTRON
    650-0600 现货查询                   连接器     DELTRON
    6507915001     现货查询                   传感器     BERNSTEIN
    650C/K     现货查询         FI04-12H  过滤器     STASTO
    651-0700    现货查询                   连接器     DELTRON
    6511B-322-PM-871DA MOD:CLSF  现货查询                   电磁阀     MAC
    6523B-251-PM-691DA     现货查询                   电磁阀     MAC
    65242400K       现货查询                   螺母         MADLER
    65433015         现货查询                   牛眼轮     MAEDLER
    65433022         现货查询                   牛眼轮     MAEDLER
    65433045         现货查询                   牛眼轮     MAEDLER
    6554024  现货查询                   联轴器     ATLANTA
    6559407  现货查询                   法兰         ATLANTA
    6580-4/20mA-4/20mA           现货查询                   转换器     NOKEVAL
    6580/6535        现货查询         6580-99401      Timken的轴承         timken
    659168-0251 24VDC        现货查询                   电磁阀     KIP
    65U4.75L-52   380V      现货查询         65U4.75  380V 50Hz      水泵         Tsurumi
    66-514-26         现货查询                   工控松档条     ELMA
    66002       现货查询                   冲头套装         mayhew
    6613  230/50 现货查询                   电磁阀     CEME
    663-105K 现货查询                   杠杆臂     Magtork
    663-BBBANF    现货查询                   数字显示器     MR
    663.6-001-4-1-001 230V, 50-60 Hz 现货查询                   计数器     BAUSER
    6639S-301-502         现货查询                   电位器     BOURNS
    666.66.5353        现货查询                   联轴器     HUCO
    666120-344-C  现货查询                        ingersoll rand
    666120-344-C          现货查询                   隔膜泵     ARO
    6682A38  现货查询                   配件         MCMASTER CARR
    6696042  现货查询                   功率控制器     UNITED AUTOMATION
    66GH-100ULTC         现货查询                   熔断器     HINODE
    670.66.5336   现货查询                   联轴器     HUCO
    670.66.5354    现货查询                   联轴器     HUCO
    6704         现货查询                   O型圈     Collins
    6704-CH505     现货查询                   O型圈     Collins
    6704-K      现货查询                   O型圈     Collins
    6705         现货查询                   支撑滤网         Collins
    6711         现货查询                   疏水元件         Collins
    6712         现货查询                   过滤器膜片     Collins
    671271NU0-5  现货查询                   "感应开关       "       ELOBAU
    671271NUO-10        现货查询                   磁性传感器     ELOBAU
    6715         现货查询                   过滤器膜片     Collins
    6725         现货查询                   滤芯         Collins
    6730         现货查询                   过滤器膜片     Collins
    6733         现货查询                   过滤器膜片     Collins
    6740-24VDC    现货查询                   变送器     NOKEVAL
    67441       现货查询                   灯座         HENNY PENNY
    6745         现货查询                   滤芯         Collins
    67600-30401   现货查询                        KYB
    676366-M-1105       现货查询         676366-M-1205       滤芯         MARVEL
    679150001P/AGZN67<P1>   15M         现货查询                   量仪电缆         MARPOSS
    6800-3330        现货查询                  过滤器     Collins
    6800-4504-4    现货查询                   过滤器     Collins
    6809705  现货查询                   双氧水低液位传感器H2O2 LC sensor  DRAGER
    684-2461-212-17     现货查询                   直流接触器     TROMBFTTA
    684mGF0-SM   现货查询                   单向阀     Goetze
    6850286 33mm        现货查询                   轮廓仪 测针  MAHR
    68512115 RTD  3x15mm   现货查询                   传感器     DITTMER
    6851527  现货查询                   测杆         MAHR
    6852406  现货查询                   粗糙度仪测针         MAHR
    68541500         现货查询                   MADLER  MADLER
    68578100         现货查询                   MADLER  MADLER
    68578800         现货查询                   MADLER  MADLER
    68580430         现货查询                   减震块     MAEDLER
    68580500         现货查询                   减震块     MAEDLER
    68584500         现货查询                   减震块     MAEDLER
    68591       现货查询                   皮带         MAC
    68880       现货查询                   皮带         MAC
    6893322601(每包25张)   现货查询                   滤清器     MANN+HUMMEL
    69-RS232 现货查询                        Binding Union
    690-0500 现货查询                   连接器     DELTRON
    690-0600 现货查询                   连接器     DELTRON
    6911-1002-030         现货查询                   电阻器     SPECTRUM
    6923K62  现货查询                   配件         MCMASTER CARR
    695049     现货查询                   部件(SKR-3M软管)   YAMADA
    69524       现货查询                   泵芯         LINCOLN
    6A180  PB3204-026       现货查询                   电机         HURST
    6A18C  WITH 0.625 BORE WITH KEYWAY * WITH 16mm BORE WITH KEYWAY   现货查询                   联轴器     ZERO-MAX
    6A26C  WITH 18mm BORE WITH KEYWAY * WITH 19mm BORE WITH KEYWAY 现货查询                   联轴器     ZERO-MAX
    6A26C  WITH 18mm BORE WITH KEYWAY * WITH 24mm BORE WITH KEYWAY 现货查询                   联轴器     ZERO-MAX
    6A30-A1C  WITH 18mm BORE WITHOUT KEYWAY * WITH 25mm BORE WITHOUT KEYWAY      现货查询                   轮毂         ZERO-MAX
    6A30-AC  WITH 16mm BORE WITHOUT KEYWAY * WITH 16mm BORE WITHOUT KEYWAY         现货查询                   联轴器         ZERO-MAX
    6A30-AC  WITH 18mm BORE WITH KEYWAY * WITH 1.125 BORE WITH KEYWAY       现货查询                   联轴器     ZERO-MAX
    6A30-AC  WITH 18mm BORE WITHOUT KEYWAY * WITH 0.875 BORE WITHOUT KEYWAY 现货查询                   联轴器     ZERO-MAX
    6A30-AC WITH 18mm BORE WITHOUT KEYWAY * WITH 18mm BORE WITHOUT KEYWAY   现货查询                   联轴器     ZERO-MAX
    6A30-AC(20mm W_KEY25mm W_KEY)        现货查询                   联轴器     ZERO-MAX
    6A30-AC-1   18.00mm * 22.23mm7/8"  不带键槽    现货查询                   联轴器     ZERO-MAX
    6A30C  3/4 * 3/4   现货查询                   联轴器     ZERO-MAX
    6A30C  WITH 1.000 BORE WITH KEYWAY * WITH 22mm BORE WITH KEYWAY   现货查询                   联轴器     ZERO-MAX
    6A37-ACWITH 18 mm BORE WITH KEYWAYWITH 35 mm BORE WITH KEYWAY    现货查询                   联轴器     ZERO-MAX
    6A37C WITH 1.250 BORE WITHOUT KEYWAYWITH 32 mm BORE WITHOUT KEYWAY      现货查询                   联轴器     ZERO-MAX
    6A37C WITH 1.500inch BORE WITH 0.375inch KEYWAY*WITH 40mm BORE WITH 12mm KEYWAY      现货查询                   联轴器         ZERO-MAX
    6A45  WITH 1.125 BORE WITH KEYWAY * WITH 1.375 BORE WITH KEYWAY       现货查询                   联轴器     ZERO-MAX
    6A45C  WITH 32mm BORE WITH KEYWAY * WITH 40mm BORE WITH KEYWAY 现货查询                   联轴器     ZERO-MAX
    6A45C (孔径1" / 1.625") 货号:6A45C  WITH 1.000 BORE WITH KEYWAY * WITH 1.625 BORE WITH KEYWAY      现货查询                  联轴器     ZERO-MAX
    6A52C   (1-1/4" KEY * 38mm KEY)        现货查询                   联轴器     ZERO-MAX
    6A52C  WITH 38 mm BORE WITH KEYWAYWITH 38 mm BORE WITH KEYWAY        现货查询                   联轴器(标准键槽10mm)         ZERO-MAX
    6A52QD   现货查询                   联轴器(不含衬套)     ZERO-MAX
    6A60-AC  WITH 50mm BORE WITHOUT KEYWAY * WITH 55mm BORE WITHOUT KEYWAY         现货查询                   联轴器         ZERO-MAX
    6A6DR5-2200EG205KA0 现货查询                   定位器     BRAY
    6AAB25-AADBCAASAD2SK+ABDADB     现货查询                   流量计T-mass A 150 DN25    E+H
    6APE80M-4      现货查询         8APE80M-4-IE3        电机         ROBERT  BIRKENBEUL
  • 蔡莉 在2025/2/26 15:49:00留言
  • 详细留言:CTC AC184—1A 需求报价及购买方式
