  • ARIS调节器PE55-06
  • 发布时间:2025/3/4 9:34:13   修改时间:2025/3/4 9:34:13 浏览次数:1020
  • 上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机
    ARIS    PD35
    ARIS    ARIS调节器PE55-06
    ARIS    BE41-21003
    ARIS    ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
    ARIS    EF06-1
    ARIS    K3006/1242-84873-01001
    ARIS    FNr.1420-6259-01010;Typ:EF 1 MA333312
    ARIS    PE40-08
    ARIS Antriebe und Steuerungen GmbH    PE30-08
    aris    FNr: 0736-67622-01002
    aris    6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
    ARIS    N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
    Aris    PMR2 0700002 NR:0216-52001-001
    ARIS     0542-61428-02010 N-B1-E
    Aris    K3006 FNR.1137-5461-01059
    ARIS    FNr:1142-5481-02040
    ARIS    FNr:1219-83411-01003
    Aris    K3012,Stroke -- 300mm;actuating force --- 1200N;voltage --- 230V/50Hz;actuating speed --- 1.7(2) sec;
    ARIS    PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise 81020/06
    ARIS    PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27, counterclockwise 81928/03
    ARIS    N 5 1209-82710-01003 30 s / 90??+ PMR 3
    ARIS    Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
    ARIS    FNr:0908-4966-01008 Typ:EF1
    ARIS    NL-90/120
    Aris    Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage: 220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
    ARIS    TYP.N5 FNr.1117-79726-01002
    Aris    1206-S2453-02002 N5L SNR107504
    ARIS    0906-71866-01002??N6S DN1120d
    aris    PE60-08 0087.00033
    aris    0301-54088-01006
    ARIS     TYPE:N5 230V 50HZ 18VA 110Nm 90' 50S IP54
    Aris    Nr.1012-5165-02067
    ARIS    WRK 3012 Nr.9425-16842-01011 220V 50HZ 17VA 1200N 200S/300MM
    ARIS    NL-90/120
    ARIS    EV61-521MJ1
    ARIS    K 3012 1126-79613-01002
    ARIS    K 3012 1126-79612-01002
    ARIS    N5 RD-S/DN250d /0620-62724-01001/:230v 50(60)HZ
    ARIS    N1-RD-S/DN125d/1108-78827-02036
    ARIS    N4 230v 50HZ 30Nm 35VA 6U 4??2(3??5)S/90??FNr??0816-69661-01002
    ARIS    type K3012 1,7/1200 2ZW; regulating distance: 300 mm;actuating force: 1200 N; actuating time: 176 s; nominal ,voltage: 230 V AC, 50Hz; nominal power: 31 W; protection ,class: IP 54; limit switches: 2 (standard), 2 (additio
    ARIS    BE41-210003
    ARIS     N5 1209-82710-0100330 S/90+PMR3
    Aris    FNr:1136-5463-01001 TYP:K1512
    Aris    FNr.1112-5375-04014 TPY:K3012
    Aris    FNr.1026-5230-01040 TPY:K3006
    ARIS    1217-83288-01001
    ARIS    1217-83288-01002
    ARIS    FNr.0906-71866-01003 TYP.N68 DN1120d
    ARIS    FNr.0751-4710-02034 Typ.K 3006
    Aris    K-A 3025
    ARIS Antriebe und Steuerungen GmbH    PE 30-08
    aris    typ nk3015 dn150d,FNr:1118-79608-02001
    Aris    PE20-08
    ARIS    0338-55766-01005 TYP:N3
    ARIS    RD-S DN125+N1 JN0 O-BDNR 2139147;TLNR 148048 257270/#16
    Aris    EV61-521MJ1
    Aris    K3012 1012-5165-02062
    Aris    see picture
    Aris    K3012, 1029-5247-02029
    Aris    K3006, 1013-75710-02003
    Aris    FNr: 1235-84300-02061 TYP: NK3015 230V 50(60)Hz 7VA 15Nm
    Aris    Nr.1442-90991-01001
    Aris    PMR3(FNR:1219-83411-0100)
    Aris    6444LI 230V 375/450rpm
    ARIS    FNr:0633-64053-01001 Typ:N3 230V 50(60)Hz 18VA 30Nm 90?? 30(25)s IP65 A.121.879.6234
    ARIS Antriebe und Steuerungen GmbH    0633-S4053-01001
    ArIS    NL3040 (including limit switches, PMR2-LC, electric heating)
    ARIS Antriebe und Steuerungen GmbH    FNr:1012-5165-02067;Typ:K 3012
    ARIS    0203-51259-01003 K3012
    ARIS    NL-90/100
    ARIS    KA3050
    ARIS    K3012
    ARIS Antriebe und Steuerungen GmbH     0850-71942-01001;6443LI 230V 50 (60)HZ 18VA
    ARIS    K1506 40NM 23OV 50(60HZ)
    ARIS    HK40.1 ?A:20mm--?B:20mm
    ARIS    HK60.5 ?A:12mm--?B:12mm
    Aris    K3012 1,7/1200 2ZW ARIS art.-no. 0100.03217
    ARIS Antriebe und Steuerungen GmbH    /motor 6443LI/230V/50(60)Hz/18VA/375rpm/78MA/0.56uF
    Aris    WAN 3 Nr.9914-43637-01002
    Aris    CL-L 140-70
    Aris    WAK 3012 N; Nr.2473672
    Aris    WAK 3012N NR:2473672
    Aris    FNr: 0836-71033-01002 230V 50 (60) Hz, 30Nm 35VA 6U 4,2 (3,50 s/90??, Ip65 UTO/+60 ??C PMR3
    Aris    PD25HT MAX10BAR 8BAR 90NM
    ARIS    0523-4198-02046 K3012
    ARIS    0615-4394-01008
    ARIS    SM6585-4 1-2UF
    ARIS    KA3050
    ARIS    K3012??
    ARIS    NL-90/100
    Aris    0080.10013 6444LI 230V 375/450RPM
    Aris    Nano M 40-60 Nr.VA03.00002
    Aris    VA02.L0001
    Aris    117.00501
    Aris    CL 12-17 300(replace K3012)+0117.00501
    Aris    VA02.L0005
    VARISCO    117.00588
    VARISCO    JE1-110 G10 ET20
    Aris    117.00501
    Aris    117.00652
    VARISCO    VA02.L0001
    Aris    CL12-17 300 NrVA02.L1001Replace K3012
    Aris    06-17 3000429-4002-01003
    Aris    VA02.L0001
    Aris    117.00501
    Aris    VA02.L0005
    VARISCO   117.00652
    Aris    117.00588
    Aris    Artikel-Nr.0045.00011
    Aris    Artikel-Nr.0016.X9014
    Aris    Artikel-Nr.1110.00115
    VARISCO    14440012
    Aris    10014358
    Aris    10008895
    Aris    10009010
    Aris    999990.999.000001:1 ersetzt K 3012 1305-5758-01018
    Aris    06-17-300 230V 50Hz
    Aris    10007593
    Aris    10005371
    Aris    10016934
    Aris    10014358
    Aris    10009010
    Aris    10008895
    Aris    14440012
    Aris    117.00652
    Aris    VA02.L0005
    Aris    117.00501
    Aris    Linearis TE 12-17 300 ARIS Klappenversteller
    Aris    I-ACT-Regler, eingebaut
    Aris    Linearis N+ 12-17 300 (replacement K3012 1012-5165-02062)
    Aris    1672.82004
    Aris    1672.82003
    Aris    VA07.L0001
    Aris    117.00501
    Aris    117.00652
    Aris    VA02.L0005
    Aris    1110.00200 Endschaltersatz BE41
    Aris    EV61-521MJ1
    Aris    000988.024.60153; Stellantrieb Typ EF 1
    Aris   8047GG+GG514+TYP.1A
    Aris    Typ:WAN V71-R1;FNr:0115-49153-04001
    Aris    Typ:WAN V71-R1;FNr:0115-49153-03003
    Aris    K 3012 Nr.0243-03671-01016
    Aris    N6S DN1120d 0906-71866-01002
    Aris    Nr 9843-42249-01006 typ WAK 3012
    Aris    |ADJUSTING DRIVE|TYPE WAK 3012; VOLTAGE: 220V; 09346.401.011006.000
    Aris    K3012 H300,Nr.1505-91626-04001
    Aris    CL-M60-25
    Aris    FNr??1302-5756-01023
    Aris    K3006
    Aris    ype: CL-S 30-30 30Nm 30s/90?230V 50(60)Hz 11VA 48mA UT-15/+60?? ED-S1-100%Pa?f. MP21 FNr:1538-93225-01001
    Aris    Type:N3230V 50(60)Hz18VA 30Nm90?30(25)SIP54 UT-15/+60?? FNr:1342-88096-01001
    Aris    Typ:K 1512,FNr:0936-73991-01001,pls see the pic
    Aris    CL-S?40-120 FNr:1136-81073-01001??Typ:N3??230V 50(60)Hz 7VA 40Nm 90?? 120(100)s IP65 UT-15/+60??
    Aris    CL-M60-25
    Aris    SN:038895 SW-REV PMR3_06
    Aris    CL-M 100-25
    Aris    117.00501
    Aris    CL-L160-17
    Aris    1110.00003
    Aris    1110.00309
    Aris    1110.0031
    Aris    40.02291
    Aris    1110.00309
    Aris    1110.00003
    Aris    1110.0031
    Aris    1145-78525-01001 NL-3040
    Aris    FNr??0851-4915-01003 typ??K 3006
    Aris    PE30-08
    Aris    0016.02076+1110.00107+0045.00011
    Aris    FNr:1445-91087-01016 Typ??LINEARIS 06-17 300 23V 50(60) HZ 18VA 1.7(2) mm 600N H300 IP65 UT-15/+60?? 2ZW, PMR-CL
    Aris    Typ??K 3012 1142-5481-02045
    Aris    Typ??K 3006
    Aris    PE60-08
    Aris    FNr:0827-70285-01004 Typ:N1 230V 50(60)Hz 7VA 30Nm 90?? 120??100??s IP54 UT-15/+60??
    Aris    1209-82710-01003 TYP??N5
    Aris    K 3012 1305-5758-01018
    Aris    CL-L 140-70 140Nm 220v/50HZ,4-20mA
    Aris    CL12-17 300??Nr??VA02.L1001??Replace K3012??
    Aris    NL-3040
    Aris    NL-3040
    Aris    FNr:1219-83411-01009TYP: K 3012
    Aris    PMR3 (FNR:1219-83411-0100)
    Aris    K3006 4-20MA 600N FNr??1307-85809-01039
    Aris    EV61-521MB1
    Aris    K3006??Nr0914-72779-01009
    ARIS    Nr.1442-90991-01001 Typ??LINEARIS12-17 300
    aris    1102-78517-03002
    ARIS Antriebe und Steuerungen GmbH    TYP:WAK 3012 N ,Nr:9310-12551-01004
    ARIS    EF06
    ARIS    K3012
    ARIS    K3006
    ARIS    K1512
    ARIS     K3006 NR.1145-81511-01006
    ARIS    PMR3(FNR:1219-83411-01008)
    ARIS Antriebe und Steuerungen GmbH     FNr:1219-83411-01009 TYP: K 3012
    ARIS     K3012 Nr??1107-78855-01001 IP54 50/60HZ
    ARIS    1010-75416-01002
    ARIS    K3012.ED-S3-50%,~230V.50HZ.31VA.1200N.H300.1.7(2)mm/S
    ARIS    WAN 1 Nr??2214859
    ARIS    1141-81317-01003
    ARIS     Type:K3012 1,7/1200 2ZW RP19 1029-5247-02016
    ARIS    K3006 1316-5830-01002
    ARIS Antriebe und Steuerungen     0016x9014+1110.0 0107+0045.0011
    ARIS    FNr:1219-83411-01008 TYP:K3012
    ARIS    K3006??Nr.0914-72779-01009 230v 50??60??HZ 180VA 600N
    Aris    K3006 FNR:1048-5310-01033
    ARIS    "type WAK 3012; stroke: 300 mm; actuating force: 11200 N
  • 在2025/12/25 9:25:00留言
  • 详细留言:6A37-SS
  • 胡光旭 在2025/12/10 16:20:00留言
  • 林小姐 在2025/11/27 16:54:00留言
  • 详细留言:采购MTE电容器MTECAP-283
  • 刘言 在2025/11/24 15:20:00留言
  • 详细留言:PBL6/VMP 38/5.TS.S
  • 在2025/11/19 14:10:00留言
  • 详细留言:温度探头 1*PT100/B
