深圳市申克工业设备有限公司
  • ADAS分析仪器和过程控制功能模组PCI 264,64 digital inputs/outputs
  • 发布时间:2020/8/14 15:39:02   修改时间:2008/8/25 11:45:48 浏览次数:1726
  • Pci StbBciSoftwareAdas Electronique
    Description
    • 64 digital I/O programmed using 8-channel ports
    • High switching power 70V/100mA
    • TTL compatible Inputs / Outputs
    • Protected inputs (70V)
    • Readable by PCI 102
    • Read / Write by PCI DX6
    • Output readback
    • 16 interrupt sources
    • "Photo" and external latch mode
    • High reliability / High density
    • I/O space in 32 bits
    • Support and supply of drivers (option)
    Adas board
    Description
    The PCI 264 provides 64 digital inputs / outputs programmed by 8-channel ports.
    The outputs are able to supply the necessary power for items such as: small relays, lamps, displays, etc.
    The inputs are protected by diodes (70V max.) and remain TTL compatible.
    Interrupt triggering can be defined by a change of front for each of the first 16 channels. These interrupt sources are maskable.
    The PCI 264 owns a private bus to be managed by PCI 102 or PCI DX6 boards, this in the case of determinable real time applications.
    PCI 164 similar software.
    Iqnet
    9 rue Georges Besse – BP 47 – 78330 FONTENAY LE FLEURY – FRANCE
    Afaq
    PCI 264
    64 DIGITAL INPUTS / OUTPUTS
    PCI 264
    SPECIFICATIONS (t = 25°C)
    TYPE
    INPUTS
    - Number of channels 64
    - Direction
    Direction programming in 8 groups of 8 channels
    DIGITAL OUTPUTS
    - Type OPEN COLLECTOR
    - DATA 1 = ON ; 0 = OFF
    - Max. sust. voltage. 70V
    - Max. current 100mA
    - Max. power 2W
    - Vce SAT < 300mV at 100mA
    - Switching time
    T"on" = 500ns T”off” = 2.5μs (RL = 1K Ω )
    DIGITAL INPUTS
    - Type TTL compatible triggers
    - Protection 70V max.
    - Impedance ≥ 470K Ω
    - Readback These inputs enable automatic readback of the channels programmed as outputs
    - Input frequency
    100KHz maximum
    POWER-UP
    Channels programmed as inputs
    Output registers at "0" "off" state
    INTERRUPTS
    16 channels can generate an interrupt as can the timers
    1 interrupt level on ? INTA ?
    PCI INTERFACE
    - Bus PCI
    - Transfers
    32 bits in the Memory space
    PRIVATE BUS
    - Exchanges 16 bits
    - Read PCI 102
    - Read / Write
    PCI DX6
    POWER SUPPLY
    - Voltage
      + 5V/2A
    PRESENTATION
    - Dimensions in mm Short PCI format
    - Front panel connector
    1 μD 68 pins Female
    ENVIRONMENT
    - Operating temperature 0°C to + 60°C
    - Storage temperature - 10°C to + 70°C
    - Relative humidity
    90 % (without condensation)
    EUROPEAN NORMS
      EMC - EN 61326
      CE Compliance
      ROHS - 2002/95/EC
深圳市申克工业设备有限公司仪器和过程控制部负责销售ADAS电子模板,并且有法国ADAS电子公司所有系列产品在亚州的独家销售权.ADAS提供品种众多的独立的I/O模块,适用于各种不同的物理总线(PC/PCI,CompactPCI,PMC …),在数据分析仪器和过…  更多>>
深圳市申克工业设备有限公司
联系人:赵工
地址:深圳市 福田区 福强路32号
邮编:518048
电话:0755-83841930
传真:0755-83841895
公司网址:http://www.sz-victory.com.cn
  • 彭聖才 在2024/11/29 14:10:00留言
  • 详细留言:您好,本公司位在台灣 網路查詢貴公司有ADAS PCI 264 数字输入输出卡 不知道能否跟您交易買賣此卡片。 http://www.cechina.cn/Company/84091_146953/messagedetail.aspx
  • 陈碧娟 在2024/3/28 17:47:00留言
  • 详细留言:ADAS ICV150 1个,有货吗?价格是?
