南京益工科技有限公司
  • 南京益工科技有限公司专业现货供应HONEYWELL 卡件备件
  • 发布时间:2008/7/22 18:05:30   修改时间:2008/7/21 15:55:27 浏览次数:1137
  • 下载
  • 01-W2039E02A 60MB SCSI CD ROM EA 51196707-100
    01-W2223E01A ATX TOWER CHASSIS W/O PWR SUPPLY EA
    01-W2223E02A ATX DESK CHASSIS W/O PWR SUPPLY EA
    01-W2734D01A TOWER W/PS EA 51196708-100
    01-W2747D01B 1.44MB FLOPPY DRIVE EA 51196703-100
    01-W2950D03A 1GBSCSI H/D EA 51196704-200
    01W2728D02A TOWER P/S EA 51196708-110
    03267 FILLER PLATE EA 51196982-910
    0458C 350MGHX1 PROCESSOR H EA
    04670008-037 FUSE, 1.6A EA 51107142-125
    0562D GX1 MOTHERBOARD EA 51196982-912
    06087 TOSHIBA 32X CDROM IDE EA
    07890 2GB H/D EA 51196935-922
    09552 PWB RISER (DELL) EA
    09714 TERM 2ND PROG EA 51196935-902
    11860 CD,680M,12/24X EA
    15253 DELL 400Mhz ADAPTEC DUAL UW EA
    15279 PROCESSOR,2334M,512KN/ECC EA
    15283 PROCESSOR, 80522, 266MH,512,ECC EA
    15284 PROCESSOR 80522 300MH 512K ECC C1 EA
    15753655-001 KEYLOCK ASSM FOR HIWAY OR LCN MARKHON EA
    15831 P/S DELL EA
    17463 DATA CBL 50 PIN EA
    17464 CABLE, DATA EA
    1756-IM16I AC IN 220VAC ISO EA TC-IDW161
    1784-KTCX CTRLNET EISA MOD EA 9904-KTCX15
    18614 DATA CBL 40P, INT, EIDE EA
    18618 FLOPPY CABLE EA
    18783 DELL 400Mhz FLOPPY DRIVE EA
    2162C KEYBOARD, 104 EA 4939R
    24978 CASTERS NON-LOCKING EA
    24979 CASTER, LOCKING EA
    30-W2762D01A SCSI CABLE EA
    30076014-001 FUSE, 1A 250V EA
    30076014-002 FUSE, 2A EA
    30076014-003 FUSE, 5A EA
    30076014-004 FUSE, .25A 250V EA
    30076014-005 FUSE, 8A EA
    30076014-006 FUSE AGC 1/2 EA
    30076014-009 FUSE, 3A 250V EA
    30076014-010 FUSE, .75 AMP EA
    30076014-011 FUSE, .125A 250V EA
    30076014-012 FUSE, 10A EA
    30076014-014 FUSE, 15A EA
    30076014-023 FUSE, .6A EA
    30076014-025 FUSE, 4A EA
    30185-H ESD KIT EA
    30351949-003 FUSE (PACK OF 2) EA
    30351949-005 FUSE EA
    30351949-006 FUSE 1.6A,250V, SLOBLO EA
    30351949-008 FUSE EA
    30353315-002 NEON GLOW LAMP EA
    30357380-002 SWITCH EA
    30640014-017 GROUND LUG EA
    30640014-018 CABLE CLAMP EA
    30669206-001 C-AC100 SINGLE UNIT CASE EA
    30669314-001 SINGLE UNIT CASE EA 30669206-001
    30669316-001 FLEX CIRCUIT ASSY EA
    30669635-003 TRIM STRIP 48 INCHES LONG EA
    30670531-001 I/F ADAPTER EA 30670531-501
    30670559-001 GPCI ADAPTER EA
    30671400-001 ANTI-PERSONNEL SCREEN FOR CABINET FAN ASSY EA
    30671408-002 CARRYING CASE EA
    30671456-001 SHORT MOUNTING PLATE EA
    30671467-001 SYSTEM REFERENCE BUSBAR EA
    30671467-002 SYSTEM REFERENCE BUSBAR EA
    30671467-006 SYSTEM REFERENCE BUSBAR EA
    30671467-007 SYSTEM REFERENCE BUSBAR EA
    30671467-008 SYSTEM REFERENCE BUSBAR EA
    30671471-001 PORT-A-DEP (EC) EA
    30671471-002 PORT-A-DEP (BC) EA
    30671513-001 TERM PANEL, HI-DEN C-TCB30 EA
    30671517-001 GROUND LUG EA
    30671526-001 ESD LO-POP KIT EA
    30671526-002 ESD HI-POD KIT EA
    30671526-003 ESD MODULE KIT EA
    30671526-004 ESD END PANEL KI EA
    30671529-001 CABLE, 3FT LCN HOOTER EA
    30671529-002 CABLE, 7FT LCN HOOTER EA
    30671529-003 CABLE 12FT LCN HOOTER EA
    30678484-001 LAMP EA
    30680582-005 FUSE PIGTAIL 2.3 EA
    30680582-006 FUSE PIGTAIL .26 EA
    30682112-001 LAMP EXTRACTOR EA
    30682951-002 FUSE, 5AMP EA
    30731391-001 TERM PANEL, AUX C-TAF00 EA
    30731406-001 TERM PANEL EA 30751315-001
    30731408-001 TERM PANEL, RED/IND C-TRD00 EA
    30731539-001 METER, HORIZONTAL INDICATOR EA
    30731539-002 METER, HORIZONTAL INDICATOR EA
    30731540-001 SINGLE VERT METER EA 30731540-501
    30731540-002 DUAL VERT METER EA 30731540-502
    30731540-501 SINGLE VERT METER EA
    30731540-502 DUAL VERT METER EA
    30731565-001 PWR SPLY, 7A/24V, 115V/60HZ V-PWR71 EA
    30731565-002 PWR SPLY, 20A/24V, 115V/60HZ V-PWR61 EA
    30731565-003 PWR SPLY, 7A/24V, 120V/50HZ V-PWR73 EA
    30731565-004 PWR SPLY, 20A/24V, 120V/50HZ V-PWR51 EA
    30731565-005 PWR SPLY, 7A/24V, 240V/50HZ V-PWR72 EA
    30731565-006 PWR SPLY, 20A/24V, 240V/50Hz V-PWR52 EA
    30731575-001 AUXILIARY FILE ASSM, C-AF000 EA
    30731575-002 AUXILIARY FILE ASSY, C-AF002 EA
    30731582-001 TOGGLE SWITCH EA
    30731611-002 FTA I/O CBL, 2M EA 51201420-002
    30731611-003 FTA I/O CBL, 3M EA 51201420-003
    30731611-005 FTA I/O CBL, 5M EA 51201420-005
    30731611-008 FTA I/O CBL, 8M EA 51201420-008
    30731611-030 FTA I/O CBL, 30M EA 51201420-030
    30731611-045 FTA I/O CBL, 45M EA 51201420-045
    30731611-060 FTA I/O CBL, 60M EA 51201420-060
    30731611-901 FTA I/O CBL, 1.5M EA 51201420-915
    30731611-902 FTA I/O CBL, 3M EA 51201420-003
    30731614-007 ROCKER SWITCH EA
    30731618-001 KEYSWITCH & KEY EA
    30731619-003 P B SWITCH EA
    30731619-006 P.B. SWITCH EA
    30731619-007 P.B. SWITCH EA
    30731619-008 SWITCH PUSHBUTTON EA
    30731620-001 LAMP INCANDESCENT EA
    30731642-001 SWITCH, PUSHBUTTON EA
    30731642-002 SWITCH, PUSHBUTTON EA
    30731674-001 RELAY (C-AR000) EA
    30731686-001 PWA, ANALOG DISPLAY EA 30731686-501
    30731686-002 PWA, ANALOG DISPLAY EA 30731686-502
    30731686-004 PWA, ANALOG DISPLAY EA 30731686-504
    30731686-005 PWA, ANALOG DISPLAY EA 30731686-505
    30731686-006 PWA, ANALOG DISPLAY EA 30731686-506
    30731686-007 PWA, ANALOG DISPLAY EA 30731686-507
    30731686-008 PWA, ANALOG DISPLAY EA 30731686-508
    30731686-501 PWA, ANALOG DISPLAY EA
    30731686-502 PWA, ANALOG DISPLAY EA
    30731686-504 PWA, ANALOG DISPLAY EA
    30731686-506 PWA, ANALOG DISPLAY EA
    30731686-507 PWA, ANALOG DISPLAY EA
    30731686-508 PWA, ANALOG DISPLAY EA
    30731689-001 JNCT PANEL,SHORT EA
    30731691-001 JNCT PANEL,B.C. EA
    30731702-001 MODE LAMP EA
    30731709-001 SINGLE VERT METER EA 30731540-501
    30731709-002 DUAL VERT METER EA 30731540-502
    30731710-001 HORIZ MTR ASSY EA 30731710-501
    30731710-501 HORIZ MTR ASSY EA
    30731710-502 METER HORIZ INDI EA
    30731719-001 C-ASD00 (W10/98) AUXILIARY EA
    30731720-001 C-AXD00 (W10/98)MULT/DIV AUX EA
    30731721-001 C-AML01 2MV/I AUX EA 30731721-002
    30731721-002 C-AML01 2MV/I AUX EA
    30731721-003 C-AML02 2MV/I AUX EA
    30731721-004 MV/I I/P 2-100 C-AML03 EA
    30731722-002 C-AEX01 SQ ROOT EXTR EA
    30731723-001 C-AMH00 AUX PWA EA
    30731724-001 R/I FM+CSA APPRO EA 30731724-002
    30731724-002 R/I FM+CSA APPRO C-ARB01 EA
    30731724-003 C-ARB02 R/I AUX BASEEFA EA
    30731724-004 C-ARB03 R/I AUX BASEEFA EA
    30731737-003 C-LAS00 ANALOG DISPLAY ASSM EA
    30731737-005 C-LC101 MANUAL W/ STANDBY MANUAL CAP EA
    30731737-006 C-LA201 AUTO/MANUAL W/SNDBY MANL CAP EA
    30731738-002 C-LD100 SGL INDICTOR EA
    30731738-003 ASSM,DUAL VERT EA
    30731739-002 C-LMD00 MANUAL LOADRW/INDICATOR EA
    30731740-002 MANUAL W/STDBY EA
    30731746-001 SWITCH MODE EA
    30731746-002 SW PADDLE ASSY EA
    30731746-003 SWITCH .R/L EA
    30731765-001 PANEL,DATA ENTRY EA 30731765-002
    30731765-002 PANEL,DATA ENTRY EA
    30731779-501 PWB, KEYBOARD ASSM EA
    30731782-501 LOGIC X PWB EA
    30731783-501 LOGIC Y PWB EA
    30731784-001 VOLT REG PWB EA 30731784-501
    30731784-501 VOLT REG PWB EA
    30731787-501 DISPLAY PWB EA
    30731795-001 C-DPX00 DEP SELCTOR EA
    30731804-002 SLOT SEL. LOG. PWB EA 30731804-501
    30731804-501 SLOT SEL.LOG.PWB EA
    30731808-001 PWA, REGULATOR EA 30731808-503
    30731808-002 PWA, REGULATOR EA 30731808-504
    30731808-003 PWA REGULATOR CARD EA 30731808-503
    30731808-004 PWA, REGULATOR EA 30731808-504
    30731808-501 PWA, REGULATOR EA 30731808-503
    30731808-502 PWA, REGULATOR EA 30731808-504
    30731808-503 PWA, REGULATOR EA 51196989-100
    30731808-504 PWA, REGULATOR EA 51196989-100
    30731811-001 PWA, OUTPUT EA 30731811-501
    30731811-002 OUTPUT PWB EA 30731811-501
    30731811-003 PWA, OUTPUT EA 30731811-501
    30731811-501 PWA, OUTPUT EA
    30731811-503 OUTPUT PWB EA 30731811-501
    30731814-002 P/W BD ASSY-HWY #2 EA 30750338-505
    30731814-003 PWA HIWAY #2 EA 30750338-505
    30731814-004 PWA ASSM HIWAY #2 EA 30750338-505
    30731814-005 PWA HIWAY #2 EA 30750338-505
    30731814-501 PWB,HWY II ANALG EA 30750338-506
    30731814-502 P W BOARD HWY#2 EA 30750338-505
    30731814-503 PWA HIWAY #2 EA 30750338-505
    30731814-504 PWB ASSY HIGHWAY #2 EA 30750338-505
    30731814-505 PWB, HIWAY #2 EA 30750338-505
    30731817-005 PWAY HIWAY #1 EA 30731817-506
    30731817-503 P W BOARD HWY #1 EA 30731817-506
    30731817-504 PWB, HIWAY #1 EA 30731817-506
    30731817-505 PWB, HIWAY #1 EA 30731817-506
    30731817-506 PWB, HIWAY #1 EA
    30731820-001 PWA DEP I/F EA 30750318-501
    30731820-501 PWA DEP I/F EA 30750318-501
    30731823-001 A/D MUX PWB EA 30731823-501
    30731823-501 A/D MUX PWB EA
    30731829-005 12K ROM 1K RAM EA 30750218-510
    30731829-006 12K ROM 1K RAM EA 30750218-510
    30731829-505 PW BOARD ASSY-MEMORY BD EA 30750218-510
    30731829-506 PW BOARD ASSY-MEMORY BD EA 30750218-510
    30731832-001 PWA, PROCESSOR EA 30731832-501
    30731832-002 PWA, PROCESSOR EA 30731832-502
    30731832-501 PWA, PROCESSOR EA
    30731832-502 PWA, PROCESSOR EA
    30731832-504 PWA, PROCESSOR EA
    30731832-505 PWA, PROCESSOR (PIU & OP STATION FILES ONLY) EA
    30731832-506 PWA, PROCESSOR (FOR DHP FILES ONLY) EA
    30731832-507 PWA CPU OP. STATION EA
    30731857-001 C-TPM02 LOCAL MARSHALLING PANEL EA
    30731865-001 C-TPM01 REMOTE MARSHALLING PANEL EA
    30731866-001 C-DPL00 DEP CBL LEFT EA
    30731866-002 C-DPR00 DEP CBL RGHT EA
    30731900-012 BASIC CTLR W/O DEP EA
    30731900-013 BASIC CTLR W/DEP EA
    30731900-014 EXTENDED CTLR W/O DIDEP EA
    30731900-015 EXTENDED CTLR W/DIDEP EA
    30731900-502 FILE & BACKPLANE EA 30731900-511
    30731900-505 FILE & BACKPLANE EA 30731900-511
    30731900-506 FILE & BACKPLANE EA 30731900-511
    30731900-507 FILE & BACKPLANE EA 30731900-511
    30731900-508 FILE & BACKPLANE EA 30731900-511
    30731900-509 FILE & BACKPLANE EA 30731900-511
    30731900-511 FILE & BACKPLANE EA
    30731900-891 CONTR FILE KIT EA
    30731906-001 C-ATC00 EXT CARD FOR AF000 EA
    30731944-001 C-LPX00 (COVER) EA
    30731950-001 C-JMP00 TERMINAL PNL EA
    30731957-002 SWITCH TOGGLE 1P EA
    30731958-001 JNCT PANEL, LONG EA
    30731959-001 C-JCA00 W/82 JUNCT PNL EA
    30731963-001 C-LT200 TRIM KIT DUAL TRIM EA
    30731992-001 MTG. PLATE EA
    30731993-001 RELAY MTG PANEL C-ARM00 EA
    30731995-001 RANGE RES PKG (8 PER PACKAGE) EA
    30731995-002 RANGE RES PKG (8 PER PACKAGE) EA
    30731995-003 RANGE RES PKG (8 PER PACKAGE) EA
    30731995-004 RANGE RES PKG (4 PER PACKAGE) EA
    30731995-005 RANGE RES PKG (4 PER PACKAGE) EA
    30731995-006 RANGE RES PKG (4 PER PACKAGE) EA
    30731995-008 C-ARR12 RANGE RESISTORS EA
    30731995-009 C-ARR13 RANGE RESISTORS EA
    30731995-010 C-ARR14 RANGE RESISTORS EA
    30731995-011 C-ARR15 RANGE RESISTORS EA
    30731995-012 C-ARR16 RANGE RESISTORS EA
    30731996-001 RGE RES, 100 OHM EA
    30731996-002 RGE RES, 250 OHM EA
    30731996-003 RGE RES,1000 OHM EA
    30732003-001 FAN, VENTILATING EA 30733258-007
    30732003-003 FAN VENTILATING EA 30732003-004
    30732003-004 FAN, TUBEAXIAL CLE2T2,115VAC EA 38002994-115
    30732003-005 FAN, TUBEAXIAL CLE3T2,220/240VAC EA 38002994-230
    30732028-001 VENTILATING FAN EA
    30732034-501 PWA, DISPLAY PANEL EA
    30732036-001 BRACKET EA
    30732037-001 DIAPLAY MODULE A EA 30732037-501
    30732037-501 DISPLAY EA
    30732038-001 CONNECTOR ADPTER EA
    30732038-002 C-KD000 CBL SPLICE EA
    30732048-001 PANEL EA
    30732050-001 CONNECTOR,LARGE EA
    30732051-001 COAX SPLICE EA
    30732052-001 PLUG TERMINATOR EA
    30732054-001 COAX CON (SMALL) FOR FM59 20 GAUGE COAX CBL EA
    30732055-001 COAX TEE CONNECTOR EA 30732100-001
    30732077-001 BUS BAR EA
    30732079-001 SPACER EA
    30732081-001 BUS BAR DIV EA
    30732081-002 BUS BAR DIV EA
    30732081-007 BUS BAR DIV EA
    30732093-001 PARTS KIT EA
    30732094-002 C-EPS20 MNTG PLATE 24IN EA
    30732094-004 C-EPD20 MNTING PLATE EA
    30732096-001 SUPP PARALLEL BUSBAR EA
    30732096-002 SUPPORT PANEL&BU EA
    30732098-001 INSULATOR BNC EA
    30732100-001 COAX TEE KIT (QTY 1) EA
    30732100-002 TEE CONN(2) KIT EA
    30732101-001 C-MH128 BACKPANEL KIT 28IN EA
    30732101-003 C-MH163 MOUNTING HDW EA
    30732101-005 C-MH177 BACKPANEL KIT FOR 77IN CABINET EA
    30732101-006 C-MH200 MOUNTING HDW EA
    30732101-007 C-MHP00 SIDE PLATE EA
    30732101-008 C-MH121 BACKPANEL KIT 21IN EA
    30732102-001 PARTS KIT CABINET EA
    30732102-002 PARTS KIT CABINET EA
    30732104-001 SWITCH ELEC AIR EA
    30732106-001 7A PWR SPLY KIT C-SSC61 EA
    30732106-002 20A PWR SPLY KIT C-STC61 EA
    30732106-004 20A 50HZ PWR SPLY EA
    30732106-005 7A 50HZ PWR SPLY EA
    30732106-006 20A 50HZ PWR SPL C-STC51 EA
    30732106-890 7A P.S. MTG KIT EA
    30732106-891 20A P.S. MTG KIT EA
    30732107-006 COAX CON KIT-LGE EA
    30732107-007 COAX SPLICE KIT EA
    30732107-009 COAX TERM KIT (QTY 2) EA
    30732107-010 SMALL CONN KIT (4) EA
    30732107-011 CRIMP TOOL KIT EA
    30732111-001 SWITCH, P.B. EA
    30732126-001 Y - DEP EA
    30732128-001 Y-MARSHAL. PANEL EA
    30732130-001 Y - MANUAL EA
    30732132-001 Y - AUTO/MANUAL EA
    30732134-001 Y - TERM EA
    30732138-001 RES ASSM(2) C-AJC00 EA
    30732160-001 MTG BRKT KIT EA
    30732160-002 C-MPK01 ANGLE BRACKT EA
    30732171-002 BASIC CTRL, HWY EA 30732171-004
    30732171-004 BASIC CTRL, HWY EA
    30732171-005 KIT HWY I/F (C-HCB20) EA
    30732172-204 C-SW204 PWR JUNC BLK EA
    30732172-904 C-SW204 PWR JUNC BLK EA
    30732175-001 C-SJA00 P/S JUNCTASM+24V AND COM EA
    30732175-002 P/S JUNCT.ASSM EA
    30732214-002 CIRC BREAKER EA
    30732219-001 PWB, CABLE LOGIC EA 30732219-504
    30732219-002 PWB, CABLE LOGIC EA 30732219-504
    30732219-003 PWB, CABLE LOGIC EA 30732219-504
    30732219-004 PWB, CABLE LOGIC EA 30732219-504
    30732219-501 PWA, CABLE LOGIC EA 30732219-504
    30732219-502 PWA, CABLE LOGIC EA 30732219-504
    30732219-503 PWA, CABLE LOGIC EA 30732219-504
    30732219-504 PWB, CABLE LOGIC EA
    30732233-001 PWB, CBL DRVS & RCRVRS EA 30732233-501
    30732233-501 PWA, CABLE DR/REC EA
    30732236-001 PL & SW ASSY EA
    30732238-501 PWR END CAP EA
    30732242-501 P/B SEL ASSY EA 30750272-501
    30732254-001 PWA, DISPLAY GENERATOR DMA EA 30732254-501
    30732254-501 PWA, DISPLAY GENERATOR DMA EA
    30732260-001 CABLE ASSM EA
    30732266-001 PWA, 8K MEMORY EA 30732266-501
    30732266-002 PWA, 8K MEMORY EA 30732266-501
    30732266-501 PWA, 8K MEMORY EA
    30732307-001 FAN ASSY-REPL EA 30732307-501
    30732307-501 FAN ASSY-REPL EA
    30732316-001 OP STA BACKPLANE EA
    30732316-002 OP STA BACKPLANE EA
    30732316-003 OP STA BACKPLANE EA
    30732316-004 OP STA BACKPLANE EA
    30732329-001 CASSETTE, BLANK EA
    30732333-001 POWER SUPPLY, 12V EA
    30732333-002 POWER SUPPLY, 12V EA
    30732344-501 PWR SPLY, AC/DC EA
    30732356-501 SPARE FILE & BACKPLANE EA 30732356-504
    30732356-502 SPARE FILE & BACKPLANE EA 30732356-504
    30732356-503 SPARE FILE & BACKPLANE EA 30732356-504
    30732356-504 SPARE FILE & BACKPLANE EA
    30732367-002 TERMINAL BOARD EA
    30732368-001 CABLE, KYBD I/F EA 30754513-001
    30732372-002 POWER SUPPLY ASSY EA 30732372-502
    30732372-502 POWER SUPPLY ASSY EA
    30732383-001 GPCI FILE C-HC10 EA
    30732383-501 FILE & BACKPLANE EA
    30732386-501 TEST LOGIC PWB EA
    30732389-501 T/P USED ON GPCI EA
    30732389-502 TEST PANEL EA
    30732393-001 DRIVER/RECEIVER EA 30732393-501
    30732393-501 HIWAY DRI/REC EA
    30732396-501 HIWAY LOGIC PWB EA
    30732403-501 PWA, POWER MONITOR EA
    30732406-001 LAMP (RED) EA
    30732406-002 LAMP (YEL/AMB) EA
    30732410-501 PWR SPLY, 1.5AMP EA
    30732411-501 PWR SUPPLY, 3 AMP EA
    30732416-001 I/O CABLE 25FT EA
    30732416-002 RIBBON CABLE 1M EA
    30732418-001 POWER SUPPLY ASSY EA 30732418-501
    30732418-002 POWER SUPPLY ASSY EA 30732418-502
    30732418-501 PS/CHARGER 115V EA
    30732418-502 PS/CHARGER 240V EA
    30732425-501 I/F PWB C-DSR01 EA
    30732432-501 PWR SUPPLY, 24VDC EA
    30732437-501 FAN EA 30732307-501
    30732439-501 PWA, DISPLAY GENERATOR EA 51304797-100
    30732439-502 PWA, DISPLAY GENERATOR EA 51304797-100
    30732439-503 PWA, DISPLAY GENERATOR EA 51304797-100
    30732463-001 TOGGLE SWITCH EA
    30732480-001 POWER SUPPLY ASSY EA 30732480-501
    30732480-002 POWER SUPPLY ASSY EA 30732480-502
    30732480-501 POWER SUPPLY ASSY, 115V EA
    30732480-502 POWER SUPPLY ASSY, 240V EA
    30732485-002 COM I/F CABLE EA
    30732486-001 LAMPHOLDER ASSY EA
    30732486-002 LAMPHOLDER ASSY EA
    30732487-001 RELAY EA
    30732489-001 RELAY-PLUG IN EA
    30732494-001 PLATE EA
    30732495-001 24VAC XFMR, 60HZ C-SCD61 EA
    30732498-001 TRANSFORMER EA 4DP7APPRT101
    30732498-002 TRANSFORMER EA 4DP7APPRT102
    30733155-501 REGULATOR PWB EA 51196989-100
    30733157-001 CABLE I/F PWB EA 30733157-501
    30733157-501 CABLE I/F PWB EA
    30733159-501 PWB, HTD LOGIC EA 30733159-502
    30733159-502 PWB, HTD LOGIC EA
    30733174-001 FILE&BACKPLANE HTD C-HTD00 EA 30733174-003
    30733174-002 HTD/C-HTD20 EA 30733174-003
    30733174-003 HTD/C-HTD20 EA
    30733174-501 HTD FILE&BCKPLN EA 30733174-502
    30733174-502 HTD FILE&BCKPLN EA
    30733258-001 FAN & PLATE ASSM EA
    30733258-002 C-EF151 FAN ASSEMBLY EA
    30733258-003 FAN & PLATE ASSY EA
    30733258-004 FAN & PLATE ASSM EA
    30733258-005 FAN ASSM 24IN 220V (C-EF251) EA
    30733258-007 FAN ASSY, 115VAC (INCL FAN CL2L2) EA
    30733258-008 FAN ASSY, 220/240VAC (INCL FAN CL3L2) EA
    30733262-501 PWA,CASSETTE I/F EA
    30734500-001 C-SBU11 40A BATT B/U110/115V W/MERC RELAY EA
    30734500-002 BATTERY BACKUP EA
    30734500-003 C-SBU01 BATTERY BACKUP ASSM EA
    30734500-505 BBU FILE ASSY EA
    30734538-001 BLACK CABLE ASSY EA
    30734538-002 RED CABLE ASSY EA
    30734538-003 CABLE ASSEMBLY EA
    30734551-001 RECRD TRIP STRIP EA
    30734558-001 BBU PWB EA 30734558-501
    30734558-501 BBU PWB EA
    30734572-001 CRT, KIT EA
    30734578-001 C-CBK00 CONTROLLER PARTS KIT EA
    30734578-002 C-CBK01 CONTROLLER PARTS KIT EA
    30734578-003 C-CBK02 CONTROLLER PARTS KIT EA
    30734579-001 C-DPK00 SPARES KIT EA
    30734592-001 C-LSM01 1-LOOP STBY EA
    30734680-001 BBU MTG HARDWARE EA
    30734680-002 C-SBH02 BBU TRAY KIT24" EA
    30734772-001 PWB C-AA191 EA
    30734772-002 PWB C-AA291 EA
    30734910-501 PWB ASSY EA
    30734980-004 TAPE, R300 DIAG EA
    30734980-005 TAPE,HIWAY TEST EA
    30734980-006 TAPE,R310 DIAG EA
    30734980-300 TAPE,R310 PROG EA 30734980-310
    30734980-301 TAPE,R310 TREND EA 30734980-311
    30734980-310 TAPE,R310 PROG EA
    30734980-311 TAPE,R310 TREND EA
    30734982-001 PWA,CASS BOOTSTR EA 30750783-504
    30734982-501 PWA,CASS BOOTSTR EA 30750783-504
    30735047-001 PWB, INTEGRITY EA 30735047-501
    30735087-001 BACKPLANE SUB-AS EA
    30735088-002 C-SBK11 BBU TRAY KIT EA
    30735150-002 ENH, HWY ACCESS EA 30735150-004
    30735150-004 ENH, HWY ACCESS EA
    30735150-503 FILE & BACKPLANE EA
    30735150-504 SPARE PAE FILE EA
    30735173-002 PWA, PAE LOGIC EA 30735173-502
    30735173-501 PWA, PAE LOGIC EA 30735173-502
    30735173-502 PWA, PAE LOGIC EA 30752608-003
    30735465-001 C-LAK00 ANALOG DISP KIT EA
    30735586-001 C-DEL00 ENERGY LMTR EA
    30735589-001 FLAT WIRE CLIP EA
    30735685-001 KEY BD ALARM_ EA 30735685-501
    30735685-002 KYBD,ALARM OPSTN EA 30735685-502
    30735685-003 KYBD,OP STN ALRM EA 30735685-503
    30735685-004 KEYBOARD EA 30735685-504
    30735685-501 KEY BD ALARM EA
    30735685-502 KYBD,ALARM OPSTN EA
    30735685-503 KYBD,OP STN ALRM EA
    30735685-504 KEYBOARD EA
    30735841-001 PWB, INTEGRITY EXT EA
    30735857-001 PWB, CMOS MEMORY EA 30735857-501
    30735857-005 PWB, CMOS MEMORY EA 30735857-505
    30735857-501 PWB, CMOS MEMORY EA
    30735857-505 PWB, CMOS MEMORY EA
    30735860-001 TRANSCEIVER PWB EA 30735860-501
    30735860-501 TRANSCEIVER PWB EA
    30735863-001 SWITCHING PWB EA 30735863-501
    30735863-002 C-CDS00 ANALOG SWITCHCARD EA 30735863-502
    30735863-501 SWITCHING PWB EA
    30735863-502 C-CDS00 ANALOG SWTCHCARD EA
    30735866-001 DECODER PWB EA 30735866-501
    30735866-501 DECODER PWB EA
    30735871-002 EXT CTLR B/DIR EA 30735871-004
    30735871-003 RCD FILE C-CD100 EA 30735871-004
    30735871-004 UNIVERSAL RCD FILE (C-CD300) EA
    30735871-501 FILE & BACKPLANE EA 30735871-503
    30735871-502 FILE & BACKPLANE EA 30735871-504
    30735871-503 FILE & BACKPLANE EA 30735871-504
    30735871-504 FILE & BACKPLANE EA
    30735873-501 PWA, LOOP MANUAL EA
    30735876-001 JNCT PANEL, PRIM EA
    30735879-001 JNCT PANEL, RCD EA
    30735887-001 P/W BOARD ASSY P EA 30735887-501
    30735887-501 PWB, PRINTER I/F EA
    30735892-001 CABLE ASSEMBLY EA
    30735892-003 CABLE ASSY RESER EA
    30735893-001 C-KR001 RBN CBL FOR UAC 1M EA
    30735893-002 C-KR002 RBN CBL FOR UAC 2M EA
    30735893-003 C-KR003 RBN CBL FOR UAC 3M EA
    30735893-005 C-KR005 RBN CBL FOR UAC 5M EA
    30735893-008 C-KR008 RBN CBL FOR UAC 8M EA
    30735974-001 P/W BOARD ASSY TREND MEMORY EA 30735974-503
    30735974-003 TREND MEMORY PWB EA 30735974-503
    30735974-004 PWB, TREND MEM. EA 30735974-504
    30735974-501 TREND MEMORY PWB EA 30735974-503
    30735974-502 TREND MEMORY PWB EA
    30735974-503 TREND MEMORY PWB FOR BASIC OPER STATION EA
    30735974-504 PWB, TREND MEM. EA
    30736012-001 KYBD MASK EA
    30736012-002 KEYBD MASK ASSY EA
    30736013-001 KEY-SWITCH ASSY EA
    30736014-001 KEYLOCK/SWITCH EA
    30736015-001 KEYBAROD, STD. EA 30736015-501
    30736015-501 KEYBOARD ,STD. EA
    30736020-001 KYBD MOUNTING BAR, RIGHT EA
    30736020-002 KYBD MOUNTING BAR, LEFT EA
    30736215-001 PWR SPLY, 5V EA
    30736215-501 PWR SUPPLY 5VDC EA
    30736216-001 POWER SUPPLY 5V EA
    30736220-501 PWB, KYBD I/F EA 30750990-502
    30736260-001 INTEGRITY CARD W/EXTENDER (C-FMH00) EA
    30736275-001 RIBBON CABLE EA
    30736324-001 BATTERY CLIP EA
    30736325-001 BATTERY CABLE EA
    30736326-001 BATTERY-NICKEL CADIUM 7.2V EA
    30736335-001 POWER CABLE ASSM EA
    30736337-001 PTR I/F CABLE EA 30736338-001
    30736338-001 PTR I/F CABLE EA
    30736346-001 C-CBM01 EA 51196689-100
    30736346-002 UPGRADE BASIC CMOS EA 51196689-100
    30736356-001 C-ASK00 SPARE PARTS KIT EA
    30736388-001 PWR SUPPLY, OPERATOR STN EA 30736388-501
    30736388-501 PWR SUPPLY, OPERATOR STN EA
    30747002-001 CIRC BREAKER EA
    30747003-001 CIRCUIT BREAKER BOX EA
    30747074-003 PANDUIT EA
    30747074-004 PANDUIT EA
    30747074-005 PANDUIT 4X4 EA
    30747074-007 PANDUIT 3X4 EA
    30747074-010 PANDUIT COVER 2IN EA
    30747074-012 PANDUIT COVER 4IN EA
    30747074-013 PANDUIT 4 X 3 IN EA
    30747083-001 DIODE ASSY EA
    30747093-001 CIRCUIT BREAKER BOX EA
    30747205-169 BARRIER GND BLK EA
    30747225-001 YLW BARRIER-FM EA
    30747225-002 GRN BARRIER-FM EA
    30747225-003 RED BARRIER-CSA EA
    30747225-004 RED BARRIER-FM EA
    30747225-006 GRN BARRIER-CSA EA
    30747243-001 RAIL TERM BLOCK EA
    30747537-001 BOX-OUTLET-4 IN EA
    30747538-001 COVER-BLANK-4 IN EA
    30747646-001 GPCI ADAPTER EA 30747646-501
    30747646-501 GPCI ADAPTER EA
    30748679-001 HOOTER HORN EA 51190924-100
    30748863-001 SHIELD ASSM 39IN EA
    30750218-001 PWA EA 30750218-511
    30750218-003 SS MEMORY PWB EA 30750218-511
    30750218-005 12K ROM/IK RAM EA 30750218-511
    30750218-007 12K ROM 1K RAM A EA 30750218-507
    30750218-008 12K ROM 1K RAM EA 30750218-510
    30750218-009 12K ROM 1K RAM EA 30750218-510
    30750218-011 PWA EA 30750218-511
    30750218-502 SS MEMORY PWB EA 51191556-100
    30750218-503 SS MEMORY PWB EA 30750218-511
    30750218-504 12K ROM 1K RAM A EA 30750218-507
    30750218-505 12K ROM 1K RAM A EA 30750218-510
    30750218-506 12K ROM 1K RAM A EA 30750218-507
    30750218-507 PWA, 12K ROM 1K RAM EA
    30750218-508 12K ROM 1K RAM EA 30750218-510
    30750218-509 12K ROM 1K RAM EA 30750218-510
    30750218-510 12K ROM 1K RAM EA
    30750218-511 SS MEMORY PWB EA
    30750272-001 P/B SEL ASSM EA 30750272-501
    30750272-501 P/B SEL ASSM EA
    30750308-001 JUNCT PANEL, DI EA
    30750318-001 PWA, DEP I/F (-501 OBSOLETE) EA 51196880-100
    30750318-002 PWA, DEP I/F EA 30750318-502
    30750318-003 PWA, DEP I/F EA 30750318-503
    30750318-501 PWA, DEP I/F BASIC CTLR (C-DP100) EA 51196880-100
    30750318-502 PWA, DEP I/F EXTENDED CTLR WITH DI (C-DP201) EA 51196882-100
    30750318-503 PWA, DEP I/F EXTD CTLR W/OUT DI (C-DP200) EA 51196880-100
    30750338-002 PWA, HIWAY #2 EA 30750338-504
    30750338-003 PWA, HIWAY #2 EA 30750338-505
    30750338-004 PWA, HIWAY #2 EA 30750338-504
    30750338-005 PWA, HIWAY #2 EA 30750338-505
    30750338-501 PWA, HIWAY #2 EA 30750338-504
    30750338-502 PWA, HIWAY #2 EA 30750338-504
    30750338-503 PWA, HIWAY #2 EA 30750338-505
    30750338-504 PWA, HIWAY #2 EA
    30750338-505 PWA, HIWAY #2 EA
    30750354-001 CONNECTOR EA
    30750362-001 LED (RED) EA
    30750509-001 C-KDP01 DIGITAL CBL 1.25M EA
    30750509-002 C-KDP02 DIGITAL CBL 2M EA
    30750509-003 C-KDP03 DIGITAL CBL 3M EA
    30750509-005 C-KDP05 DIGITAL CBL 5M EA
    30750509-008 C-KDP08 DIGITAL CBL 8M EA
    30750540-001 PWR SUPPLY OP ST (-502 OBSOLETE) EA 30750540-502
    30750540-002 PWR SUPPLY OP ST (-502 OBSOLETE) EA
    30750540-501 PWR SUPPLY OP ST (-502 OBSOLETE) EA 30750540-502
    30750565-002 KEY REPL EA
    30750565-003 KEY EA
    30750565-004 CABINET KEY EA
    30750730-501 PWA, DISKETTE I/F EA
    30750732-501 PWA, CORE MEMORY EA
    30750745-001 PARTS KIT, GPCI EA
    30750768-003 DIGITAL SWITCH CARD EA 30750768-503
    30750768-501 DIGITAL SWITCH CARD EA 30750768-503
    30750768-502 PWA, DIGITAL I/O EA
    30750768-503 PWA, DIGITAL I/O SWITCH EA
    30750771-001 PWA, DIG I/O EA 30750771-501
    30750771-501 PWA, DIGITAL I/O EA
    30750774-003 PWB ASSY UAC DIGITAL OUTPUT EA 30750774-503
    30750774-501 PWA, UAC D/O EA 30750774-503
    30750774-502 PWA, UAC D/O EA 30750774-503
    30750774-503 PWA, UAC D/O EA
    30750780-001 RESERVE JUNC PNL EA
    30750783-003 DISKETTE BOOTSTR EA 30750783-503
    30750783-004 DISKETTE BOOTSTR EA 30750783-504
    30750783-503 PWA,DISK BOOTSTR EA
    30750783-504 PWA,CASS BOOTSTR EA
    30750786-001 PWB, RAM/EDAC EA 51304528-100
    30750786-501 PWB, RAM/EDAC EA 51304528-100
    30750847-001 FLOPPY DISK DRIVE 8IN EA 30751177-503
    30750851-001 RCD JUNCTION PNL EA
    30750897-001 FILE, UAC DIG IO EA
    30750897-501 FILE & BACKPLANE EA
    30750903-001 CABLE, DIG I/O EA
    30750944-001 KEYBOARD, STANDARD EA 30750944-501
    30750944-003 KEYBOARD, OP STN STD EA 30750944-503
    30750944-004 KEYBOARD EA 30750944-504
    30750944-501 KEYBOARD ,STD. EA
    30750944-503 KYBD,OP STN STD EA
    30750944-504 KEYBOARD EA
    30750947-001 FILTER PERM WASH EA
    30750954-001 LAMP, 5V .075AMP EA 51109392-100
    30750957-001 KEYBOARD MASK AS EA
    30750957-003 KEYBOARD MASK EA 30750957-004
    30750957-004 KEYBOARD MASK EA
    30750990-001 PWB, KEYBOARD I/F EA 30750990-502
    30750990-501 PWB, KEYBOARD I/F EA 30750990-502
    30750990-502 PWA, KEYBOARD I/F EA
    30751044-004 PWA, DHPII ROM EA 30751044-508
    30751044-005 PWA, DHPII ROM EA 30751044-508
    30751044-006 PWA, DHPII ROM EA 30751044-508
    30751044-007 PWA, DHIPII ROM EA 30751044-508
    30751044-008 PWA, DHPII ROM EA 30751044-508
    30751044-501 PWA, DHPII ROM EA 30751044-508
    30751044-502 PWA, DHPII ROM EA 30751044-508
    30751044-503 PWB_ASSM CONT II ROM BD _ EA 30751044-508
    30751044-504 PWB ASSM CONT II ROM BD EA 30751044-508
    30751044-505 PWA, DHPII ROM EA 30751044-508
    30751044-506 PWB, DHPII ROM EA 30751044-508
    30751044-507 PWB, CTLR II ROM EA 30751044-509
    30751044-508 PWA, DHPII ROM EA
    30751044-509 PWA, CTLR II ROM EA
    30751044-510 PWA, DHPII ROM EA
    30751082-008 ID PLATE, KYBD EA
    30751083-001 DSG40 KYBD ASSM EA
    30751083-003 DSG52 KYBD ASSM EA
    30751083-004 DSG55 KYBD ASSM EA
    30751083-005 DSG56 KYBD ASSM EA
    30751139-001 FLOPPY DISK DRIVE 8IN EA
    30751139-002 FLOPPY DISK DRIVE 8IN, 50HZ EA
    30751139-003 C-DSD61 DISK DRIVE #1 EA
    30751139-004 C-DSD51 DISC DRIVE #1 EA
    30751144-001 BLANK 8IN TEST DISK FOR BASIC OPER STATIONS EA
    30751144-002 DIAGNOSTIC DISK EA
    30751144-003 HIWAY TEST DISK EA 30751793-003
    30751144-004 DIAGNOSTIC DISK EA
    30751144-005 DIAG DISK FOR R610 OR R615 BASIC OPER STA EA
    30751144-360 R360 PRGM DISK EA
    30751144-420 R420 PROG DISK EA
    30751144-460 R460 PRG DISKETT EA
    30751144-610 R610 PRGM DISK EA
    30751144-615 R615 PRGM DISK 8IN MEDIA EA
    30751153-001 FDD SIGNAL CABLE EA
    30751153-002 FDD SIGNAL CABLE EA
    30751176-003 C-DSD62 EA
    30751176-004 C-DSD52 EA
    30751177-001 FLOPYY DISK DRIVE 8IN, NON-UNIV EA 30751177-501
    30751177-002 DISK DRIVE EA
    30751177-003 DISK DRIVE EA
    30751177-004 DISK DRIVE EA
    30751177-005 DISK DRIVE 60 HZ EA
    30751177-006 DISK DRIVE 50 HZ EA
    30751177-501 FLOPPY DISK DRIVE 8I, NON-UNIV EA
    30751228-001 C-TBR10 BARRIER RESISTOR MODULE EA
    30751238-003 FAN GUARD EA
    30751315-001 C-TCB20 CONTROLLER TERMINAL PANEL EA
    30751315-002 C-TCB21 CONTROLLER TERMINAL PANEL EA
    30751394-001 BASIC DEP/EXT DE EA
    30751395-001 BASIC DEP/EXT DE EA
    30751404-001 PARTS KIT-OUTPUT C-ARR10 EA
    30751473-001 DISKETTE EA
    30751731-001 DISK CLEANING KIT FOR 8IN FDD BAS/ENH OP STAT EA
    30751793-001 DIAGNOSTIC DISK EA
    30751793-002 PROG MEDIA R420 EA
    30751793-003 HIWAY TEST DISK EA
    30751793-004 DIAGNOSTIC DISK EA
    30751793-005 PROG MEDIA R360 EA
    30751793-006 PROG MEDIA R460 EA
    30751793-007 PROG MEDIA R610 EA
    30751793-008 PROG MEDIA R615 EA
    30751793-009 R360 5-1/4IN SET EA P-DK361
    30751793-010 R615 5-1/4IN SET EA P-DK616
    30751853-501 PWA,ERROR DETECT EA
    30751856-501 PWA, 128K MEM EA
    30752106-001 KYBD UPDATE KIT EA
    30752106-002 KEYCAP KIT EA
    30752117-002 1MW MEMORY REPLC EA
    30752117-003 MEM UPDATE KIT EA
    30752117-004 MEM UPDATE KIT EA 30752117-003
    30752117-005 MEM UPDATE KIT EA 30752117-003
    30752548-501 PWB PANEL ASM EA
    30752588-001 PWB, CMOS RAM ASSM DHP 8KX17 EA 30752588-501
    30752588-501 PWB, CMOS RAM ASSM DHP 8KX17 EA
    30752606-001 BATTERY,STORAGE EA
    30752608-001 KIT-DIR FILE UPD EA
    30752608-002 HTD UPGRADE KIT EA
    30752608-003 PAE UPGRADE KIT EA
    30752766-001 PWA, TRANSCEIVER EA 30752766-501
    30752766-501 PWA, TRANSCEIVER EA
    30752783-001 BATTERY TEST CARD EA
    30752787-002 PWA, COMM LOGIC EA 30752787-502
    30752787-502 PWA, COMM LOGIC EA
    30752787-503 PWA, COMM LOGIC EA
    30752832-501 PWA, EIU MICROENGINE EA
    30752923-501 EIU PROM CARRIER EA
    30752946-001 DHP TEST PANEL EA 30752946-501
    30752946-501 DHP TEST PANEL EA
    30752948-001 DHP BATTERY ASSM EA 30752948-501
    30752948-501 DHP BATTERY ASSM EA
    30752981-501 PWA, EIU RAM I/F EA
    30752984-501 EIU HWY INTERFACE EA
    30752986-501 FILE & BACKPLANE,EIU EA
    30753004-001 DHPII_(C-HL200) EA 30753004-002
    30753004-002 DHPII (C-HL200) EA
    30753004-003 DHP II W/RETRY EA
    30753004-502 DHP FILE & BACKPLANE EA 30753004-503
    30753004-503 DHP II W/RETRY FILE AND BACKPLANE EA
    30753018-001 CABLE ASSY-INTER EA
    30753019-001 CABLE ASS'Y DHP EA
    30753020-001 I/F CABLE-15' LL EA
    30753020-002 I/F CABLE-50' EA
    30753022-001 DHP CABLE-15F' MODIFIED EA
    30753022-002 DHP CABLE-50FT MODIFIED EA
    30753023-001 DHP CABLE-15' EA
    30753023-002 DHP CABLE-50' EA
    30753024-001 CABLE ASSEMBLY 15',A/B CBL EA
    30753024-002 I/F CABLE-50' EA
    30753419-001 FLOPPY DISC 60HZ EA
    30753732-001 HIWAY COUPLER MO EA 30753732-501
    30753732-501 HIWAY COUPLER MO EA
    30753985-001 HARNESS ASSY EA
    30754051-001 C-KFT02 PRE-TERMIN. FIBER OPTIC CBL 2M EA
    30754051-004 C-KFT10 PRE-TERMIN. FIBER OPTIC CBL 10M EA
    30754051-006 C-KFT50 PRE-TERMIN. FIBER OPTIC CBL 50M EA
    30754096-001 LINK, TERM JMPR EA
    30754117-001 DC POWER CABLE EA
    30754118-001 CABLE ASM, DISK EA
    30754170-001 GENICOM PTR, MODEL C-DSP40 EA 30754171-001
    30754171-001 GENICOM PTR, MODEL C-DSP40 EA
    30754171-002 PTR & PEDESTAL EA
    30754362-001 KIT, PARTS (HCM) EA
    30754420-001 PWA, LOOP I/F EA 51196478-101
    30754420-002 APHO PWB ASSY EA
    30754420-003 PWA, APTR/12 EA 51196478-103
    30754420-004 PWA, PRNTHD DRIV EA 51196478-104
    30754420-005 PWA, PWR BOARD EA 51196478-105
    30754420-006 PWA, ACL/1_REG EA 51196478-106
    30754420-007 PRINTHEAD 18WIRE EA 51196478-107
    30754420-008 CARRIAGE ASM EA 51196478-108
    30754420-009 CABLE, CARRIAGE EA 51196478-109
    30754420-010 MOTOR, CARRIAGE EA 51196478-110
    30754420-011 CABLE, PRINTHEAD EA 51196478-111
    30754420-012 CABLE, PRINTHEAD EA 51196478-112
    30754420-013 CARRIAGE STOP EA 51196478-113
    30754420-015 SHAFT,TURNAROUND EA 51196478-115
    30754420-016 Bracket, Turnaround EA
    30754420-017 Ribbon, Printer EA
    30754420-018 MOTOR,RIBBON DRI EA 51196478-118
    30754420-019 Cable, Printer EA
    30754420-020 Left Tractor Asm EA
    30754420-021 TRACTOR ASM,RGHT EA 51196478-121
    30754420-022 Motor, Paper Feed EA
    30754420-023 BUSHING,TRACTOR EA 51196478-123
    30754420-024 PAPER DRIVE BELT EA
    30754420-025 ROLLER (SET) EA
    30754420-026 ROLLER (SET) EA
    30754420-027 GEAR, UP FRICTIO EA 51196478-127
    30754420-028 GEAR, TRACTOR EA 51196478-128
    30754420-029 Knob, Paper Advance EA
    30754420-030 FAN & SHROUD ASM EA 51196478-130
    30754420-031 STRAP,JUMPER EA 51196478-131
    30754420-033 Fuse Link EA
    30754420-034 FUSE, 25A 125V EA 51196478-134
    30754420-035 FUSE, 3A 125V EA 51196478-135
    30754420-036 FUSE, 7A 125V EA 51196478-136
    30754420-037 Fuse, 3A, 300V EA
    30754420-038 ECPU/1 Card (Printer) EA
    30754420-039 RIBBON,REINKABLE EA 51196478-139
    30754420-040 PWA,ECPU/I EA 51196478-140
    30754420-042 Control Panel, C-DSP40 EA
    30754513-001 CABLE ASS'Y KEY EA
    30754514-001 CABLE ASS'Y ALAR EA
    30754536-001 PWA, REG MONITOR EA 30754536-501
    30754536-501 PWA, REG MONITOR EA
    30754579-001 FUSE EA
    30754584-003 GROUNDSTRAP EA
    30754649-001 SPDT RELAY FOR 110V CABINET FAN ASSY EA
    30754649-002 SPDT RELAY FOR 220V CABINET FAN ASSY EA
    30754651-001 FAN & PLATE ASSM EA
    30754651-003 FAN & PLATE ASSM EA
    30754651-004 C-EF252 FAN ASSEMBLY24IN, 230V, CENTERED EA
    30754661-009 FUSE, MICRO 1/8 EA
    30754661-011 FUSE,SUBMINI.25A EA
    30754661-014 FUSE, .5 AMP EA
    30754661-019 FUSE, 1.0A EA
    30754661-021 2 AMP MICROFUSE EA
    30754661-022 FUSE, 3A EA
    30754718-001 PTR I/F KIT MODEL C-DSP01 EA
    3123C PENTIUM II CPU 400MZ EA
    31324 POWER CORD 6' EA
    3150045 FUSE EA 30076014-001
    3150360 FUSE EA 30076014-001
    3253E PS2 MOUSE EA 51196982-900
    3340D KEYBOARD, 104 EA
    340-0291 ADAPTOR, 2940 EA 51196935-907
    3593U MOUSE, PS2 EA
    38001057-300 5V PWR SUPPLY EA
    38001072-100 PWB, KJUMP EA 51401594-200
    38001508-100 Adapter, Coupler Module EA
    38001774-100 PWB,CLM TIWAY II EA 51195863-100
    38001897-100 FTA MOD 120VDIEC EA 38001897-125
    38002210-100 IOP, HLAI (CC) EA 51304754-150
    38002211-100 A/O IOP PWA (8) EA 51309152-175
    38002218-100 FTA,TC_MUX EA 51309223-175
    38002669-110 PWR SUPPLY 110V, OPERATOR STATION EA
    38002669-220 PWR SUPPLY 220V, OPERATOR STATION EA
    38002931-100 MCRAM Battery 3.6VNicD EA
    38002994-115 FAN/RELAY KIT 115V EA
    38002994-230 FAN/RELAY KIT 230V EA
    38002996-100 Monitor, Basic in KOP Furn. EA 51195868-800
    38002996-200 Monitor, Basic in Univ. Furn EA 51195868-925
    38003025-100 DIN to Phone Adapter Kit EA
    38500143-100 LCNE HUB ASSY EA
    38500143-200 LCNE HUB ASSY EA
    38500143-300 LCNE HUB ASSY EA
    38500143-400 LCNE HUB ASSY EA
    38500143-500 LCNE HUB Z-FURN EA
    38500143-600 RED LCNE HUB Z-FURN EA
    38500148-300 LCNE HUB PWR SUPPLY (5 SLOT) EA
    3884D 1.44M FLOPPY DR EA
    38XEV SI,HNYWL,CD,SCSI,17/40X,680M EA
    40079 POWER CORD 6' EA
    4023C MOTHERBOARD DELL 400MHZ GX1 EA
    40800601-100 PWB, HDLC COM EA
    40800601-200 HDLC COMM PWB EA
    40800605-100 2GB DAT TAPE DRV EA
    40800605-200 4/8 GB TAPE DR EA
    40800606-100 1GB OPTICAL DRIV EA
    40800621-300 SVGA MONITOR EA
    40800624-100 MODEM EA
    40800626-050 RS449, CABLE 50M EA
    40800627-100 PWB, ETNERNET EA 40800627-102
    40800627-102 Ethernet Card EA
    40800632-100 TOKEN RING ADPTR EA
    40800632-200 TOKEN RING ADPTR EA
    40800730-100 DESKTOP SERVER EA
    40800730-300 DESK TOP SERVER EA
    40800731-100 TOWERSERVER BASE EA
    40800731-300 SERVER EA
    4123C 450MHz DESKTOP EA 51196982-902
    4160U 9GB U160 HARD DRIVE EA
    416434 0303 FUSE 3A 250V EA 30076014-009
    42601193-002 HARNESS P/E,CIRC BRK EA
    42601377-006 AIR FILTER, LCN TS8 RITTAL CABINET EA
    42601517-002 RETAINING SPRING, LCN TS8 RITTAL CABINET EA
    42601650-003 POWER ENTRY, 240VAC, 2-POLE, LCN TS8 CAB EA
    42601650-004 POWER ENTRY, 240VAC, 1-POLE, LCN TS8 CAB EA
    42601902-002 Digital Isolator, MTL3052 EA
    42601902-009 EMC IS-LL Multiplexer, MTL831B EA
    42601902-014 IS-LLMux Receiver, Russian T/C, MTL838B-HONEC EA
    42601902-020 IS-LLMux Receiver, MTL838B-HONEC EA
    42601902-021 IS-LLMux Receiver, Sgl Hiway, MTL838B-HONEC EA
    42602252-001 DO Isolator, MTL4021S EA
    42602252-005 DO Magnetic Isolator, MTL4021RS EA
    42602252-100 Connector, MTL SPCON01, Yellow EA
    42602358-005 CIRCUIT BREAKER, 2A, 2-POLE, HPM TS8 CAB EA
    42602358-007 CIRCUIT BREAKER, 10A, 2-POLE, HPM TS8 CAB EA
    42602358-010 CIRCUIT BREAKER, 2A, 1-POLE, HPM TS8 CAB EA
    42602358-012 CIRCUIT BREAKER, 10A, 1-POLE, HPM TS8 CAB EA
    42602367-002 MOUNTING BRACKET, 1 TAP SET, LCN TS8 CAB EA
    42602367-012 MOUNTING BRACKET, 2 TAP SETS, LCN TS8 CAB EA
    42602375-001 Mounting Plate, FTA "B" Size EA
    42621215-001 Mounting Plate, ISLLMUX EA
    42622195-001 Temperature Converter, MTL4073 EA
    42622195-002 Russian XK T/C Converter, MTL4073 EA
    42622212-016 HART Interface Module, MTL4842 EA
    42622212-018 HART Communications Module, MTL4841 EA
    42622212-019 HART Maintenance System Baseplate EA
    42622212-020 RS232-RS485 Converter, Westermo K9999M2000 EA
    42622212-021 HART Communications Module-AMS, MTL4841-AMS EA
    42622216-001 Connector w/CJS, MTL SCJ01 EA
    42623231-001 Cable, HART Bus, 150cm EA
    42623231-002 Cable, HART Bus, 80cm EA
    42623233-001 Cable, HART/FTA, 70cm EA
    42623233-002 Cable, HART/FTA, 90cm EA
    42623233-003 Cable, HART/FTA, 140cm EA
    42623233-004 Cable, HART/FTA, 180cm EA
    42623233-005 Cable, HART/FTA, 220cm EA
    42964 CABLE, HD, AUX EA
    44WUW PRC,80526,933,256,133,FC,C0 EA
    463CD KYBD,104,6P,US,NMB,RD,SB EA
    4780D KEYBOARD, 104 EA 51196982-901
    4939R KEYBOARD, 104 EA
    49788023-001 BARRIER BOX USA C-TBU10 EA
    49788023-002 BARRIER BOX C-TBU11 EA
    49788023-003 BARRIER BOX EA
    49788026-001 C-TB110 INPUT MODULE(IS) EA
    49788031-001 LINK MOD (C-TBL10) EA
    49788042-001 C-TB010 OUTPUT MOD (IS) EA
    4DP7APARR005 RANGE RES PKG EA 30731995-002
    4DP7APBIC101 HLPIU BUS INTEGR EA
    4DP7APCFA106 HL CCFA EA
    4DP7APCFA107 HL PCFA-TRM TYPE EA
    4DP7APCFA108 HL PCFA-CON TYPE EA
    4DP7APCFA109 HL PCFA EA
    4DP7APCFA207 LL PCFA EA
    4DP7APCFA208 LL,PCFA ASSY EA
    4DP7APCFA209 LL 7100 CFA EA
    4DP7APCFA306 LE CCFA(STD MNT) EA 4DP7APCFA309
    4DP7APCFA309 LE CCFA(STD MNT) EA
    4DP7APCFA402 HL CCFA, R320B EA 4DP7APCFA403
    4DP7APCFA403 HL CCFA, R320B EA
    4DP7APCFA502 LL CCFA EA
    4DP7APCFA601 LE CCFA-BKPNL MT EA
    4DP7APCIM104 CSA TC W/NEMA BOX EA
    4DP7APCIM204 RTD MUX CONSISTI EA
    4DP7APFIM104 FM TC W/NEMA BOX EA
    4DP7APFIM204 RTD MUX ASM EA
    4DP7APFIM304 ASM,SAT MUX PWA TC EA
    4DP7APISB101 P-ISB11 BARR BOX EA 51190843-001
    4DP7APISB102 P-ISB12 BARR BOX EA 51104957-100
    4DP7APISB103 P-ISB13 BARR BOX EA 51104957-101
    4DP7APISB104 P-ISB14 BARR BOX EA 51104957-102
    4DP7APISB105 P-ISB15 BARR BOX EA 51104957-103
    4DP7APNMA101 NEMA 4 BOX (P-NMA11) EA
    4DP7APODP202 HL 24VDC POWER FILTER EA
    4DP7APODP203 POWER FILTER EA
    4DP7APODP204 DUAL D/I PWR FIL EA
    4DP7APOIM104 TC LOGIC&TERM BDS CBLS AND NEMA BOX ASSM EA
    4DP7APOIM204 RTD LOGIC&TERM BDS, CBLS AND NEMA BOX EA
    4DP7APOIM301 NEMA ASSM-NON IS EA
    4DP7APOIM304 TC LOGIC & TERM BDS, MTG HDW CBLS-NON IS EA
    4DP7APOIM401 MUX SET W/NEMA EA
    4DP7APOIM403 LE-RTD-MUX-LOGIC EA
    4DP7APOSE101 PWA, HIWAY SOE EA
    4DP7APOSP101 SURGE PROTECT EA 4DP7APXSP111
    4DP7APOSP201 SURGE PROTECT EA 4DP7APXSP211
    4DP7APOSP301 SURGE PROTECT EA 4DP7APXSP311
    4DP7APOSP401 SURGE PROTECT EA 4DP7APXSP411
    4DP7APOSP501 SURGE PROTECT EA 4DP7APXSP511
    4DP7APPRT101 LE REFERENCE TRANSFORMER, 60HZ EA
    4DP7APPRT102 LE REFERENCE TRANSFORMER, 50HZ EA
    4DP7APPRT202 LE PHASE REF TRA EA
    4DP7APTCK101 CONNECTOR KIT P-TCK11 EA
    4DP7APXAD211 A/D CONVERTER R3 EA
    4DP7APXAD611 A/D CONVERTER LL EA
    4DP7APXAD911 ANALOG DIG CONVE EA
    4DP7APXCA111 BARRIER ADAPTOR EA
    4DP7APXDH111 PWB, HIWAY I/F EA
    4DP7APXDH122 SOE HIWAY I/F EA
    4DP7APXDH211 DATA HIGHWAY INT EA 4DP7APXDH233
    4DP7APXDH222 PWA, DATA HIWAY I/F EA 4DP7APXDH233
    4DP7APXDH233 PWA, DATA HIWAY I/F EA
    4DP7APXDH244 PWB, HIWAY LOGIC EA
    4DP7APXI0111 I/O BUS CONTROL EA 4DP7APXIO111
    4DP7APXIA111 PWA, VOLTAGE INPUT 5V EA 4DP7APXIA122
    4DP7APXIA122 PWA, VOLTAGE INPUT 5V P-XIA12 EA
    4DP7APXIA211 PWA, 4-20MA W/O XMTR EA 4DP7APXIA222
    4DP7APXIA222 PWA, 4-20MA W/O XMTR P-XIA22 EA
    4DP7APXIA311 PWA, 4-20MA W/XMTR EA 4DP7APXIA322
    4DP7APXIA322 PWA, 4-20MA W/XMTR P-XIA32 EA
    4DP7APXIA411 PWA, 5V W/FAST FILTER EA 4DP7APXIA422
    4DP7APXIA422 PWA, 5V W/FAST FILTER P-XIA42 EA
    4DP7APXIA811 LL AN INPUT MUX P-XIA81 EA
    4DP7APXIA911 LL ANALOG INPUT P-XIA91 EA
    4DP7APXID111 HL 24V CONTACT LL P-XID11 EA
    4DP7APXID211 1 MEC 24V DIG IN P-XID21 EA
    4DP7APXID311 HL 48V CONTACT I P-XID31 EA
    4DP7APXID411 HL 48V CONTACT 2 P-XID41 EA
    4DP7APXID511 HL TTL LOGIC 0.1 P-XID51 EA
    4DP7APXID611 HL 125 VDC CONTA P-XID61 EA
    4DP7APXID622 HL 125VDC CONTAC P-XID62 EA
    4DP7APXIO111 I/O BUS CONTROL EA
    4DP7APXIO211 I/O BUS CONTROL EA
    4DP7APXIP111 I/O BUS CONTROL P-XIP11 EA
    4DP7APXIP211 PULSE INPUT FAST EA 4DP7APXIP411
    4DP7APXIP311 PULSE INP SLOW P-XIP31 EA
    4DP7APXIP411 PULSE INPUT FAST P-XIP41 EA
    4DP7APXMD111 MUX DRIVER EA
    4DP7APXMD211 MUX DRIVER EA
    4DP7APXOA111 PWA, ANALOG OUTPUT EA 4DP7APXOA311
    4DP7APXOA211 ANALOG OUTPUT EA 4DP7APXOA311
    4DP7APXOA311 ANALOG OUTPUT P-XOA31 EA
    4DP7APXOD111 DIGITAL OUTPUT EA 4DP7APXOD311
    4DP7APXOD211 7100 DIGITAL OUTPUT EA 4DP7APXOD411
    4DP7APXOD311 DIGITAL OUTPUT P-XOD31 EA
    4DP7APXOD411 7100 DIGITAL OUT P-XOD41 EA
    4DP7APXPM122 R300 PROM PWA EA
    4DP7APXPM133 PROM/MEM HLPIU R EA
    4DP7APXPM144 PWA, MEMORY EA 51109323-100
    4DP7APXPM155 PWA, HL MEMORY EA
    4DP7APXPM222 PWA, PROM EA
    4DP7APXPM233 PWA, PROM/RAM EA
    4DP7APXPM333 PWA, PROM/RAM EA
    4DP7APXPR111 PWA REGULATOR EA 30731808-503
    4DP7APXPR211 1 POINT FILE CON EA 51196989-100
    4DP7APXPR311 POINT FILE CONVE EA 51196989-100
    4DP7APXPU111 MOS CPU PWB EA 30731832-501
    4DP7APXRM111 RAM CARD EA
    4DP7APXRP111 RTD POWER SUPPLY P-XRP11 EA
    4DP7APXSC111 LL SIG COND-CURR P-XSC11 EA
    4DP7APXSD111 SIG COND-FEED TH P-XSD11 EA
    4DP7APXSJ111 LL SIGNAL COND - REFERENCE EA 51104410-100
    4DP7APXSM111 SUB MULTIPLEXER EA
    4DP7APXSP111 SURGE PROTECT A/I (HIGH LEVEL) EA
    4DP7APXSP211 SURGE PROTECT D/O RELAY AND D/I EA
    4DP7APXSP311 SURGE PROTECT A/O AND SOLID STATE D/O EA
    4DP7APXSP411 SURGE PROTECT PWR SUPPLY A/I LOW LEVEL EA
    4DP7APXSP511 SURGE PROTECT A/I (LOW LEVEL) EA
    4DP7APXSR111 PWA, LL RTD SGN COND P-XSR11 EA
    4DP7APXSR211 LL SIG COND-RTD P-XSR21 EA
    4DP7APXSR311 LL SIG COND-RTD P-XSR31 EA
    4DP7APXSV111 LL SIG COND-ATTE P-XSV11 EA
    4DP7APXSV211 LL +1-5,10,20,40 P-XSV21 EA
    4DP7APZHC301 COAX CABLE EA 51195476-150
    4DP7APZHC302 COAX CABLE EA 51195476-500
    4DP7APZHC303 COAX CABLE EA 51195477-015
    4DP7APZHC304 COAX CABLE EA
    4DP7APZHC305 COAX CABLE EA 51195476-022
    4DP7APZHC306 COAX CABLE EA 51195476-050
    4DP7APZHC307 COAX CABLE EA 51195476-100
    4DP7APZHC308 COAX CABLE EA 51195476-200
    4DP7APZHC401 CABLE SET, 150CM EA 51195476-150
    4DP7APZHC402 COAX CABLE - SEE NOTE EA
    4DP7APZHC403 CABLE SET, 75CM EA
    4DP7APZHC404 COAX CABLE - SEE NOTE EA
    51100008-300 NAMEPLATE EA
    51102863-100 ANALOG CABLE EA
    51102866-101 DATA CABLE 2 PT EA
    51102866-102 DATA CABLE EA
    51102866-103 DATA CABLE EA
    51102866-104 DATA CABLE EA
    51102866-105 DATA CABLE EA
    51103224-100 FILTER BOARD POD EA
    51103940-100 TRANSFORMER EA 4DP7APPRT102
    51103940-200 TRANSFORMER EA 4DP7APPRT101
    51104307-100 TEMP SENSOR PANE EA
    51104410-100 REF SIGNAL COND P-XSJ11 EA
    51104883-121 CFA LABEL EA
    51104886-105 CABLE,DC PWR DIS EA
    51104886-106 CABLE,DC PWR DIS EA
    51104886-111 DIST CBL CFA-CFA EA
    51104886-112 DIST CBL CFA-CFA EA
    51104887-100 POWER WIRE 15VDC EA
    51104957-100 INTRINSIC BAR BOX -PTB CERTIFIED P-ISB13 EA
    51104957-101 INTRISIC BARR BOX - FM CERTIFIED P-ISB13 EA
    51104957-102 INTRINSIC BARR BOX -CSA CERTIFIED P-ISB14 EA
    51104957-103 P-ISB15 BARR BOX EA
    51105208-200 MODIF. ANALOG IN EA
    51105244-100 POWER SUPPLY EA 51301926-100
    51105347-101 MUX CABLE SET EA
    51105347-102 CABLE SET EA
    51107137-101 FUSE, 1.6 AMP EA
    51107137-102 FUSE, 1.25 AMP EA
    51107137-103 FUSE, 3.15A, F03 EA
    51107137-117 PRINTHEAD, ASPI 32 PTR EA
    51107137-118 HEAD CABLE EA
    51107137-119 ASPI 32 PRINT HEAD EA 51107137-117
    51107142-105 PRINTHEAD, ASPI 46 PTR EA
    51107142-119 BELT, CARRIAGE EA
    51107142-120 BELT, PAPER EA
    51107142-125 FUSE, 1.6A EA
    51107143-101 AYDIN 19IN TUBE EA
    51107143-102 FSP-001 CARD ASM EA
    51107144-101 FUSE, 3A 250V EA
    51107145-112 REMOTE CBL ASSY EA
    51107325-101 19IN HITACHI MONITOR A-VMD11 EA
    51107403-100 LCN I/O EA 51305072-400
    51107424-101 310/320 TO 30B U/G WITH CONVERTER EA 51109322-101
    51107550-100 BACKPNL DAUGH BD EA
    51107595-100 PWR SUPPLY, WINC EA
    51107693-130 VIDEO COPIER 60HZ EA
    51107698-143 LABEL ONLY FOR K4 EXTRACTOR WITH 4M INSTALLED EA
    51107698-144 LABEL,K4-8 EXTRC EA
    51107712-100 JUMPER WIRE EA
    51107754-100 MCPU I/O CARD EA 51304286-100
    51107754-200 PWB, MCPU I/O EA 38001499-100
    51107758-001 PWB VID&DEFLECT EA
    51107758-002 DIFFERNTIAL AMP. EA 51107758-004
    51107758-004 DIFFERENTIAL AMP EA
    51107954-100 PWB, MCPU I/O EA 38001499-100
    51107982-100 P-CFA16 SPARE CARDFILE EA
    51107982-101 P-CFA17 SPARE CARDFILE EA
    51107982-102 P-CFA18 SPARE CARDFILE EA
    51107982-103 P-CFA19 SPARE CARDFILE EA
    51107982-104 LL CCFA W/O BDS EA
    51107982-105 P-CFA27 SPARE CARDFILE EA
    51107982-106 LL CF W/O BDS EA
    51107982-107 P-CFA29 SPARE CARDFILE EA
    51107982-111 P-CFA39 W/O BDS EA 51107982-113
    51107982-112 P-CFA41 SPARE CARDFILE EA
    51107982-113 P-CFA39 SPARE CARDFILE EA
    51107982-114 P-CFA61 SPARE CARDFILE EA
    51107982-115 P-CFA43 SPARE CARDFILE EA
    51107998-100 FLOPPY DISC I/O EA
    51108088-100 PWB, DHI I/O EA
    51108088-200 DHI I/O ADAPTOR EA
    51108139-100 HITACHI CRT OBSOLETE EA
    51108254-100 PRINTER W/BASKET EA
    51108254-400 ASPI32 SER PTR EA
    51108304-100 ASPI41 PRINTER EA 51108305-100
    51108305-100 ASPI41 PRINTER EA
    51108305-100REP PTR, ASPI41 EA
    51108305-700 ASPI41 RIBBON EA
    51108305-900 ASPI41 PRNTR PED EA
    51108306-100 TRACKBALL REPLCT EA 51196267-100
    51108306-200 TRACKBALL EA 51196714-100
    51108307-100 MONITOR 14 IN EA 51196793-100
    51108308-100 MONITOR, 19IN INTERLACED EA
    51108311-100 CRT EA 51196793-100
    51108311-200 CRT, 14IN UWS EA 51196793-100
    51108311-300 CRT EA 51196793-100
    51108311-400 CRT, 14IN UWS EA 51196793-100
    51108312-100 MONITOR 8939 EA 51304449-500
    51108313-100 TRACKBALL, US EA
    51108313-200 TRACKBALL EA
    51108313-300 TRACKBALL EA 51108313-400
    51108313-400 TRACKBALL US/UxS EC EA
    51108367-100 MOD REMOTE RTD EA
    51108385-308 M3X8 PAN HEAD SCREW EA
    51108385-310 SCREW PAN HEAD M3X10MM EA
    51108385-508 M4X8 PAN HD SCREW EA
    51108385-510 SCREW EA
    51108387-610 SCREW_HEX_HD_M5_X10MM EA
    51108389-001 LOCKNUT M3 EA
    51108389-004 NUTS, HEX EA
    51108389-006 HEX NUT LOCK M8 EA
    51108390-005 FLAT WASHER, M4 EA
    51108392-005 LK WASHER, SPLIT M4 EA
    51108393-003 LOCKWASHER,EXT-TH M 3 EA
    51108393-004 WASHER LOCK EA
    51108393-006 WASHER LOCK M5 EA
    51108393-008 LOCKWASHER EA
    51108436-204 SCREW, PAN HEAD EA
    51108436-304 MACH SCR PAN HD #6 EA
    51108437-003 WASHER,LOCK,INT #6 EA
    51108441-103 GROMMET MATERIAL EA
    51108461-001 NUT WASHER ASM EA
    51108475-301 GOTHIC BLACK 12 OZ CAN SPRAY PAINT EA
    51108475-302 EXECUTIVE WHITE 12 OZ CAN SPRAY PAINT EA
    51108475-303 CARIBEAN BLUE 12 OZ CAN SPRAY PAINT EA
    51108475-304 DRIFTWOOD 12 OZ CAN SPRAY PAINT EA
    51108475-305 OPAQUE BEIGE 12 OZ CAN SPRAY PAINT EA
    51108475-306 OPAGUE GREY 12 OZ CAN SPRAY PAINT EA
    51108475-307 LIGHT ASH 12 OZ CAN SPRAY PAINT EA
    51108475-308 DARK LAVA 12 OZ CAN SPRAY PAINT EA
    51108566-100 P/S UPGRADE KIT EA
    51108609-100 WHITE LABEL EA
    51108623-100 LEVELER GUIDE ADJ. CLASSIC CONSOLE EA
    51108687-100 LATCH KEEPER EA
    51108695-100 19IN ELECTROHOME MONITOR EA
    51108800-100 WREN I DRIVE EA
    51108843-100 PWB, SIO I/O EA
    51108845-100 PWB, TR PEN TERM EA
    51108845-200 PWB, TR PEN TERM EA
    51108871-100 CMPLX KIT,FR,NO IKB EA
    51108871-200 CMPLX KIT,REAR EA
    51108871-300 CMPLX KIT,CBL COVER EA
    51108871-400 CMPLX KIT,FR,W/IKB EA
    51108880-408 SCREWS EA
    51108880-430 PAN HD SCREW M3 .5/30 EA
    51108882-005 FLAT WASHER M4 EA
    51108882-006 SM M5 FL WSHR, BL/ZI EA
    51108883-002 W FLAT WASHER M3.5 EA
    51108883-004 LG M5 FL WASHER ZINC EA
    51108884-006 LOCK WASHER M5 EA
    51108888-508 HEX HD SCREW M4/8 EA
    51108888-510 HEX HD SCREW M4 X10MM EA
    51108888-610 M5X10 SCREW EA
    51108888-612 HEX HD SCREW M5 /12 EA
    51108888-616 HEX HD SCREW EA
    51108888-820 HEX HD SCREW M8 /20 EA
    51108892-100 CARD FILE EA 51196692-100
    51108893-100 FILE, 10 SLOT EA
    51108893-200 C/F 6/4,3/4 CL EA 51196736-100
    51108894-100 POWER SUPPLY EA
    51108899-100 PWB, FIBER OP I/O EA
    51108899-200 FIBER OPTIC LNK EA
    51109040-100 CLI TEST CABLE EA
    51109041-100 CLI TESY PLUG EA
    51109153-100 C51109153-300 EA
    51109153-200 VIDEO DR PCB EA
    51109153-300 PWB EA
    51109153-400 CRT SOCKET PGB EA
    51109153-500 CONTROL CIRCUIT EA
    51109153-600 INPUT CIR PWB EA
    51109153-700 PWB Sup PCB EA
    51109169-010 GROUND CABLE EA
    51109169-018 GROUND CABLE EA
    51109181-003 LCN COAX CBL SET 3M EA 51308112-003
    51109181-005 LCN COAX CBL SET 5M EA 51308112-005
    51109181-008 LCN COAX CBL SET 8M EA 51308112-008
    51109181-010 LCN COAX CBL SET 10M EA 51308112-010
    51109181-015 LCN COAX CBL SET 15M EA 51308112-015
    51109181-020 LCN COAX CBL SET 20M EA 51308112-020
    51109181-025 LCN COAX CBL SET 25M EA 51308112-025
    51109181-030 LCN COAX CBL SET 30M EA 51308112-030
    51109181-050 LCN COAX CBL SET 50M EA 51308112-050
    51109181-060 LCN COAX CBL SET 60M EA 51308112-060
    51109181-075 LCN COAX CBL SET 75M EA 51308112-075
    51109181-100 LCN COAX CBL SET 100M EA 51308112-100
    51109181-125 LCN COAX CBL SET 125M EA 51308112-125
    51109181-150 LCN COAX CBL SET 150M EA 51308112-150
    51109181-200 LCN COAX CBL SET 200M EA 51308112-200
    51109181-250 LCN COAX CBL SET 250M EA 51308112-250
    51109181-300 LCN COAX CBL SET 300M EA 51308112-300
    51109182-003 LCN CABLE (SET 3) 3M EA
    51109182-025 LCN CABLE (SET 3) 25M EA
    51109182-050 LCN CABLE (SET 3) 50M EA
    51109182-100 LCN CABLE (SET 3) 100M EA
    51109322-100 310/320 TO 320B U/G W/O AD CONVERTER P-ZHL11 EA
    51109322-101 310/320 TO 30B U/G WITH CONVERTER EA
    51109323-100 310A TO 320B U/G WITH A/D CONVERTER EA
    51109399-100 T-SCREEN BRUSH EA
    51109417-100 AO MANUAL STANDBY CONNECTOR ADAPTER EA
    51109456-100 PM POWER SUPPLY EA 51109684-100
    51109456-200 PM POWER SUPPLY EA 51109684-100
    51109456-300 PM POWER SUPPLY EA 51198947-200
    51109469-100 NYLON WASHER EA
    51109470-200 LABEL, APM MODEM EA
    51109470-250 Label, APM Modem EA
    51109477-150 LABEL, AO (CC) EA
    51109482-100 BALL STUD EA
    51109485-100 8-DROP TAP ASSM MU-NTAP08 EA
    51109487-200 RITTAL PM KEY (No. 3254) EA
    51109488-100 LOUVER KIT EA
    51109488-200 AIR FILTER EA
    51109496-100 NUT SPRING CLIP EA
    51109501-100 CONNECTOR KIT EA 51195162-100
    51109504-100 UCN SPLICE KIT EA 51195160-100
    51109516-100 FAN CABLE 10FT EA
    51109516-200 FAN CABLE 5FT EA
    51109516-300 FAN CABLE 8FT EA
    51109516-400 FAN CABLE 12FT EA
    51109516-500 FAN CABLE 15FT EA
    51109516-600 FAN CABLE 20FT EA
    51109524-100 KIT, CAB COMPLEX EA
    51109524-300 HPM DUAL-ACCESS CAB COMPLEXING KIT, TS8-PS EA
    51109524-400 HPM SGL-ACCESS CAB COMPLEXING KIT, TS8-PS EA
    51109524-600 HPM DUAL-ACCESS CAB COMPLEXING KIT, TS8-TS8 EA
    51109524-700 HPM SGL-ACCESS CAB COMPLEXING KIT, TS8-TS8 EA
    51109532-100 CAB COMPLEX KIT FOR DUAL ACCESS CAB EA
    51109532-200 COMPLEXING KIT FOR SINGLE ACCESS CAB EA
    51109541-100 CABINET FILTER FOR PM 15.5 X 24 EA
    51109545-100 SCREW M2.5X.045 EA 51198946-100
    51109559-100 BB PWR CBL ASM EA
    51109583-100 FOAM/COMPLEX - DUAL EA
    51109583-200 CABINET INSERT EA
    51109594-100 EYEBLT ASM (4) MU-CLBM01 EA
    51109612-100 TORQUE WRENCH MU-NKTQ01 EA
    51109614-100 BLNK PLATE, FILE EA
    51109620-000 G.I. PWR CBL, IN CAB (SEE NOTE) EA 51109620-195
    51109620-020 CABLE,(IN CAB) 20IN EA
    51109620-030 PWR CABLE (IN CAB) 30IN .76M EA
    51109620-040 PWR CABLE (IN CAB) 40IN 1.02M EA
    51109620-050 PWR CABLE (IN CAB) 50IN 1.27M EA
    51109620-080 PWR CABLE (IN CAB) 80IN EA
    51109620-120 PWR CABLE (IN CAB) 120IN EA
    51109620-160 PWR CABLE (IN CAB) 160IN EA
    51109620-195 PWR CABLE (IN CAB) 5M EA
    51109620-390 PWR CABLE (IN CAB) 10M EA
    51109625-100 TRIM PANEL BRKT A.C . EA
    51109625-200 TRIM PANEL BRKT OPPOSITE EA
    51109663-100 LABEL, STIMV EA
    51109684-100 PM POWER SUPPLY EA 51198947-100
    51109684-200 Y-H ONLY-P/S MIN ORDER 50 EA 51198947-200
    51109684-300 PM POWER SUPPLY EA 51198947-100
    51109688-100 KIT, PWA MTG EC EA
    51109705-100 CRT, 19IN INTERLAC EA 51195793-100
    51109705-110 CRT, 19IN INTERLAC EA 51195793-100
    51109715-100 DRIVE, WREN II EA
    51109806-002 CABLE SET 2M EA 51308111-002
    51109818-100 PWR SUPPLY, FD EA 51199164-100
    51109823-100 FLOPPY NUT PLATE EA
    51109881-100 PWB, LCNE II EA 51304540-100
    51109896-100 GROUND CABLE EA
    51109919-100 PWB, PCSR EA 51304286-100
    51109925-100 FAN, LGE MUFFIN EA
    51109931-100 GROUNDING WASHER EA
    51109933-001 SERRATED WASHER M6 EA
    51109933-002 SERRATED WASHER M8 EA
    51109933-003 SERRATED WASHER M5 EA
    51151197-100 DRIVE, PRI 525MB EA
    51190101-100 RES/ZERO OHM EA
    51190102-100 RANGE RES 100OHM EA
    51190102-300 250 Ohm Dummy Resistor EA
    51190115-114 RESISTOR NETWORK - NOT AVAILABLE EA
    51190405-106 PS 48V 60HZ 115V EA
    51190422-100 BAT'Y,1.2V NICAD EA
    51190424-200 SEALED BATTERY EA
    51190424-300 48V BATTERY ASSM EA 51303948-100
    51190465-100 PWR SUPPLY, 8AMP EA
    51190465-150 PWR SUPPLY, 8AMP COATED EA
    51190465-200 PWR SUPPLY,16AMP EA
    51190465-250 PWR SUPPLY,16AMP 120V COATED EA
    51190467-100 BATTERY,1.5V ALK EA
    51190516-100 S.S. RELAY EA
    51190516-122 SOLID STATE RELAY EA
    51190516-132 RELAY SOLID STAT EA
    51190516-134 RELAY SOLID STAT EA
    51190516-202 RELAY, FILE ASSY EA
    51190516-325 S.S. RELAY EA
    51190516-332 RELAY SOLID STAT EA
    51190516-400 SOLID STATE RELAY EA 51190516-325
    51190516-402 S.S. RELAY EA
    51190516-404 RELAY SOLIDSTATE EA
    51190516-405 SOLID STATE RELAY EA 51190516-122
    51190517-100 ANN CTR W/CBL EA 51303642-600
    51190523-100 RELAY EA 51190523-125
    51190523-125 RELAY EA
    51190523-200 RELAY EA 51190523-225
    51190523-225 RELAY EA
    51190523-300 RELAY EA 51190523-325
    51190523-325 RELAY EA
    51190526-100 RELAY, SS EA
    51190528-100 RELAY K1 EA 51191945-100
    51190528-200 RELAY EA 51191945-200
    51190528-300 RELAY EA 51191945-200
    51190529-200 SOCKET REPLAY SPRING CLIP EA
    51190566-110 CIRCUIT BREAKER EA
    51190569-115 CIRCUIT BRK,15A EA
    51190572-101 FUSE, 1/8 AMP EA
    51190572-102 FUSE, 1/4 AMP EA
    51190574-014 FUSE, .5 AMP EA
    51190574-018 FUSE, .8A EA
    51190574-020 FUSE, 1.25A EA
    51190574-023 FUSE, 2A EA
    51190574-028 FUSE, 5A EA
    51190577-150 FUSE, .5 AMP EA
    51190582-120 FUSE, .2 AMP EA
    51190582-125 FUSE, .25 AMP EA
    51190582-210 FUSE, 1 AMP EA
    51190582-220 FUSE, 2 AMP EA
    51190582-230 FUSE, 3 AMP EA
    51190582-240 FUSE, 4 AMP EA
    51190582-250 FUSE, 5 AMP EA
    51190584-150 FUSE, SLO-BLO .5A EA
    51190584-210 FUSE, 1A SLO-BLO EA
    51190584-216 FUSE, 1.6A S/B EA
    51190584-225 FUSE, 2.5A SLO-BLO EA
    51190584-230 FUSE, 3A SLO-BLO EA
    51190584-260 FUSE, 6A SLO-BLO EA
    51190586-100 FUSE HANDLER EA
    51190589-100 TOGGLE SWITCH EA
    51190624-902 CONNECTOR MINI JMPR EA
    51190660-001 TRANSFORMER, 60MZ EA 4DP7APPRT101
    51190696-076 CABLE, 250FT EC EA 51192139-114
    51190696-152 CABLE, 500FT EC EA 51192139-124
    51190696-305 CABLE, 1000FT EC EA 51192139-134
    51190721-101 CONNECTOR EA
    51190721-203 SMALL SERVICE POST S1 EA
    51190721-205 SERVICE POST EA
    51190728-105 COAX TEE CONN EA
    51190746-102 BAND TAP EA
    51190782-100 TERMINATOR EA
    51190787-209 PLUG-IN TERMBLK 8PT 1-8 EA
    51190787-309 PLUG-IN TERMBLK 8PT 9-19 EA
    51190787-408 PLUGIN TBLK 8PT EA
    51190787-411 PLUGIN TBLK 11PT EA
    51190787-508 PLUGIN TBLK 8PT EA
    51190795-100 CONN, RG-11 CBLE (ORDER AT KIT LEVEL) EA 51195162-100
    51190795-200 CRIMP TOOL,RG-11 MU-NKTT01 EA
    51190797-100 CONN, RG-6 CABLE EA
    51190797-200 CRIMP TOOL, RG-6 MU-NKDT01 EA
    51190826-300 PROGRAMMING JUMPER INSULATED EA
    51190826-301 PLUG PROGRAM JUMPER EA
    51190843-001 P-ISB11 BARR BOX EA
    51190876-100 FAN, TUBE AXIAL EA
    51190879-006 ADJUSTABLE CABLE CL AMP EA
    51190879-010 SMALL TIE-WRAP EA
    51190879-017 TIE MOUNT, SMALL EA
    51190879-019 TIE WRAP PUSH MTD EA
    51190884-101 (E) ENG KEY S/S EA
    51190884-102 (S)SUP KEY S/S EA
    51190884-200 US KEYLOCK UPGKT EA MP-ZUSKL1-100
    51190884-201 (S) SUP KEY D/S EA
    51190884-202 (E) ENG KEY D/S EA
    51190890-101 TAPE 108FT ROLL EA
    51190896-100 CABLE SET EA 51190896-200
    51190896-200 CABLE SET EA
    51190899-152 UCN RG-11 RAW CBL INDOOR USE 500FT/152M ROLL EA
    51190899-305 UCN RG-11 RAW CBL INDOOR USE 1000FT/394M ROLL EA
    51190899-762 UCN RG-11 RAW CBL INDOOR USE 2500FT/762M ROLL EA
    51190899-914 UCN RG-11 CABLE EA
    51190907-100 FILTER EA
    51190907-300 PWR LINE FILTER EA
    51190908-121 CLICKER EA
    51190909-100 KYBD ALARM CABLE EA 51303416-010
    51190916-102 2-DROP TAP ASSM EA 51201394-100
    51190916-104 ROLLING 4 DRP TAP EA
    51190921-100 POWER CORD 110V 2M EA
    51190921-110 POWER CORD 110V 3M EA
    51190921-200 POWER CORD 220V 2M EA
    51190981-100 STRAPPING TAPE EA
    51190985-100 FAN, TUBEAXIAL EA
    51190985-200 FAN DC 3.62 IN EA
    51190985-600 FAN AXIAL DC EA 51195124-500
    51191508-100 EC KEYBOARD W/EMI COAT EA
    51191510-100 IKB KB FLD KIT EA
    51191511-100 IKB SUMMA TB FLD KIT EA
    51191512-100 IKB PS/2 FW FLD SVC KIT EA
    51191524-100 IKB TRACKBALL BUTTNS EA
    51191545-100 LOWER 17 CRT EZ-CONS MTG KIT EA
    51191545-200 UPPER 17 CRT EZ-CONS NTG KIT EA
    51191554-100 MAU INSULATOR EA
    51191556-100 URCD REPLACEMENT KIT FOR BC/EC EA
    51191558-100 KVM SWITCH ASM 4 NODE EA
    51191560-100 H/D 1.8GB D/L LOGICAL EA MP-ZHMU18-100
    51191560-200 H/D 875MB D/L LOGICAL EA MP-ZHMU11-100
    51191561-100 SPC FIRMWARE U/G KIT EA
    51191564-100 TRAILBLAZER VIDEO BOARD REPLACEMENT KIT EA
    51191566-525 SCREW, OVAL HEAD PHILLIPS EA
    51191573-100 TOUCHSCREEN PWA 21IN EA
    51191575-100 LOWER MONITOR EZ KIT EA
    51191575-200 UPPER MONITOR EZ KIT EA
    51191578-100 19" IR TOUCHSCREEN PWA EA
    51191579-100 1.8 GB DUAL LOGICAL DRIVE EA MP-ZHMU18-100
    51191579-200 875 GB DUAL LOGICAL DRIVE EA MP-ZHMU11-100
    51191579-300 H/D 9.1GB EA
    51191607-152 UCN RG-11 RAW CBL OUTDOOR USE 500FT(152M)ROLL EA
    51191607-305 UCN RG-11 RAW CBL OUTDOOR 1000FT(304M)ROLL EA
    51191607-457 RAW CBL FOR OUTDOOR USE 475M ROLL EA
    51191607-762 UCN RG-11 RAW CBL OUTDOOR 2500FT (762M) ROLL EA
    51191607-914 UCN RG-11 RAW CBL FOR OUTDOOR USE 914M ROLL EA
    51191673-305 CABLE, SDI/SI 305M (MU-KSX305) EA
    51191696-100 MODULE, 4-20MA EA 51192097-200
    51191697-100 MODULE, HLAI/GI EA 51191697-200
    51191697-200 MODULE, HLAI/GI EA
    51191698-100 MODULE, DO FTA EA
    51191699-100 MODULE, DI FTA EA
    51191737-100 CONNECTOR, CRIMP EA
    51191737-201 PIN, CRIMP 14-20 EA
    51191738-100 CONNECTOR, COMPR EA
    51191783-100 CBL, MAU (USX) EA
    51191783-100A CBL, MAU (USX) EA 51191783-100
    51191784-100 CRT I/F CBL EA
    51191784-200 CBL, CRT SIGNAL EA 51192126-200
    51191784-300 CBL, CRT SIGNAL EA
    51191785-100 HP DAT ADAPTER EA
    51191787-100 CRIMP TOOL FOR GI/I S FTA EA
    51191787-200 EXTRACTION TOOL EA
    51191792-200 CONNECTOR EA
    51191814-100 DAT TAPE BLANK EA
    51191817-100 STRIP, MAGNETIC FLEX. SOLD BY FOOT FT
    51191819-100 ELEC OUTLET BOX EA
    51191839-100 CBL,PTR OUTLET EA
    51191902-101 FERRITE, LCN T/C EA
    51191902-102 FERRITE, SMALL EA
    51191926-100 24 VDC DI GALV EA
    51191927-100 DO GALV ISO MOD EA
    51191928-100 HLAI, GAL ISOMOD EA
    51191945-100 RELAY EA
    51191945-200 DC POWER RELAY EA
    51191982-100 TERM, HDDT I/O EA
    51192039-122 LOAD, RESISTOR EA
    51192054-101 CABLE, SCSI 1M EA
    51192054-102 CABLE, SCSI 2M EA
    51192054-103 CABLE, SCSI 3M EA
    51192054-104 CABLE, SCSI 1.5M EA
    51192056-206 CONN PLUG 6 POLES EA
    51192060-100 NI CAD BATTERY (EA1) EA
    51192065-100 BE-CU FINGER CONTACT EA
    51192065-300 BE-CU FINGER CONTACT EA
    51192091-124 POWER SUPPLY PWB 24V EA
    51192094-124 FAN 24VDC EA
    51192097-100 MODULE, 4-20MA EA 51192097-200
    51192097-200 MODULE, 4-20MA EA
    51192107-300 FERRITE BEAD FTC EA
    51192125-150 ADAPTER, CONN EA
    51192126-200 CBL, CRT INT EA
    51192126-400 CBL CRT W/FERR EA
    51192139-113 THREE COND, CABLE EC150FT EA
    51192139-114 CABLE, 250' EC MU-KLX076 EA
    51192139-124 CABLE, 500' EC MU-KLX152 EA
    51192139-134 CABLE, 1000' EC MU-KLX305 EA
    51192191-100 EMI GASKET EA
    51192196-150 CONN APATER 50 PIN EA
    51192296-100 GASKET, EMI EA
    51192537-100 P/SMODULE MLT4053 EA
    51192538-100 P/S MODULE MTL4995 EA
    51192565-200 MTL 4046C GI/IS BARR EA
    51192615-100 SCSI 1 SCSI 3 ADAPTER EA
    51192619-110 THERMOSTAT EA
    51192700-100 SCSI M-M IF ADAPTER EA
    51192706-100 SCSI TERMINATOR EA
    51192707-100 MODLR TERMINATOR EA
    51192708-100 T-ADAPTER CAT5 EA
    51192887-100 Adapter, ST-SMA EA
    51195004-001 BATTERY HOLDER EA
    51195018-048 8GA BLK 24.5IN LEAD EA
    51195018-248 8GA RED 24.5IN LEAD EA
    51195019-053 4GA BLK 29.5IN LEAD EA
    51195019-253 LEAD-ELECTRICAL-4GA-RED EA
    51195022-001 BBU MTG KIT-24IN(C-SBM02) EA
    51195022-002 BBU MTG KIT-19IN (C-SBM01) EA
    51195023-001 PWR SPLY MTG KIT EA
    51195023-002 PWR SPLY MTG KIT EA
    51195023-003 PWR SPLY MTG KIT EA
    51195023-004 PWR SPLY MTG KIT EA
    51195023-005 PWR SPLY MTG KIT EA
    51195023-006 PWR SPLY MTG KIT EA
    51195023-891 KIT,PS MTG 24IN EA
    51195024-001 KIT-POWER BUS C-PSB02 EA
    51195042-100 ALUM._RIVET EA
    51195053-100 PWA, ST/DC P-AST10 EA
    51195058-100 PWB, PDG TTL I/O EA
    51195062-100 CRT 13IN DIGITAL EA
    51195066-100 PWR SPLY, 5 SLOT EA 51402184-200
    51195066-200 10 SLOT P/S EA 51402184-300
    51195083-100 MOUSE KIT EA MP-ZMSE01-100
    51195083-200 MOUSE KIT EA MP-ZMSE01-100
    51195091-100 ASPI46 SER PTR EA
    51195091-100REP PTR, ASPI46 110V EA
    51195091-300 ASPI46 PTR, 220V EA
    51195091-700 ASPI46 RIBBON EA
    51195091-900 PEDESTAL PACKAGE EA
    51195093-100 DC/DC CONVERTER EA 51304186-100
    51195095-100 5-1/4IN FDD EA 51195439-400
    51195095-101 FDD EA 51196659-100
    51195095-200 FDD EA 51196659-100
    51195095-300 5-1/4"_FDD EA 51196659-100
    51195095-300A 5-1/4IN FDD EA 51196659-100
    51195096-100 PLCI I/O CARD EA
    51195096-200 PLCI I/O ADPTR EA
    51195105-100 CABLE I/F P-TCB71 EA
    51195111-001 BLANK TEST DISK EA
    51195111-005 DIAGNOSTIC DISK EA
    51195111-361 R361 SYSTEM DISK EA
    51195111-616 R616 SYSTEM DISK EA
    51195119-120 WHT/BLK CBL,20FT EA
    51195124-100 FAN ASSM EA
    51195124-200 FAN ASSM EA
    51195124-300 FAN DC_ .62 IN EA 51190985-200
    51195124-500 FAN ASSM EA
    51195127-100 19" ENH CRT ASSY EA 51304449-500
    51195153-001 CABLE SET, 1M RG 6 EA
    51195153-002 CABLE SET, 2M RG 6 MU-NKD002 EA
    51195153-003 CABLE SET, 3M RG 6 EA
    51195153-004 CABLE SET, 4M RG-6, MU-NKD004 EA
    51195153-005 CABLE SET, 5M RG 6 MU-NKD005 EA
    51195153-010 CABLE SET, 10M RG6 MU-NKD010 EA
    51195153-020 CABLE SET, 20M RG6 MU-NKD020 EA
    51195153-030 CABLE SET, 30M RG6 MU-NKD030 EA
    51195153-040 CABLE SET, 40M RG6 MU-NKD040 EA
    51195153-050 CABLE SET, 50M RG6 MU-NKD050 EA
    51195153-900 CABLE SET, .5M RG6 EA
    51195153-901 CABLE SET, 1.5M RG 6 EA
    51195153-902 DROP CBL SET 2.5M EA
    51195153-903 CAABLE SET, 3.5M RG6 EA
    51195153-904 CABLE SET, 4.5M RG 6 EA
    51195154-002 CABLE SET, 2.5M EA 51195199-002
    51195154-010 CABLE SET, 10M EA 51195199-010
    51195154-020 CABLE SET, 20M EA 51195199-020
    51195154-030 CABLE SET, 30M EA 51195199-030
    51195155-100 DRIVE, WREN III EA
    51195156-100 CARTRIDGE DRIVE, 20MB EA 51195156-300
    51195156-200 CARTRIDGE DRIVE, 20MB EA 51195156-300
    51195156-300 CARTRIDGE DRIVE, 20MB EA
    51195160-100 UCN SPLICE KIT EA
    51195161-100 CONNECTOR KIT MU-NKDK01 EA
    51195162-100 CONNECTOR KIT MU-NKTK01 (QTY. 24) EA
    51195168-510 M4X10 THRD FRMG SCR EW EA
    51195168-612 D FORMING SCREW EA
    51195168-616 HEX HEAD SCREW EA
    51195168-635 THREAD FORMING SCREW, M5X35mm EA
    51195169-101 CLEANING KIT, LCN 150MB CARTRIDGE DRIVE EA 51196485-500
    51195178-100 TERM ASSY,WREN EA
    51195180-100 CARD GUIDE EA
    51195190-200 VDG/PIC REPL KIT EA MP-ZUSCP1-100
    51195191-100 KYBD REPLACE KIT EA
    51195192-100 TCHSCRN RPLC KIT EA
    51195195-221 PUB MANUAL K4SS U/G EA
    51195195-278 WREN STYLE HM U/G KIT INST 875MB/1.8GB EA
    51195195-279 WDA STYLE HM U/G KIT INST 875MB/1.8GB EA
    51195199-002 UCN TRUNK CABLE SET, RG-11, 2.5M MU-NKT002 EA
    51195199-005 UCN TRUNK CABLE SET, RG-11, 5M MU-NKT005 EA
    51195199-010 UCN TRUNK CABLE SET, RG-11, 10M MU-NKT010 EA
    51195199-020 UCN TRUNK CABLE SET, RG-11, 20M MU-NKT020 EA
    51195199-030 UCN TRUNK CABLE SET, RG-11, 30M MU-NKT030 EA
    51195199-050 UCN TRUNK CABLE SET, RG-11, 50M MU-NKT050 EA
    51195199-060 UCN TRUNK CABLE SET, RG-11, 60M EA
    51195199-075 UCN TRUNK CABLE SET, RG-11, 75M EA
    51195199-100 UCN TRUNK CABLE SET, RG-11, 100M MU-NKT100 EA
    51195199-150 UCN TRUNK CABLE SET, RG-11, 150M EA
    51195199-200 UCN TRUNK CABLE SET, RG-11, 200M MU-NKT200 EA
    51195199-300 UCN TRUNK CABLE SET, RG-11, 300M EA
    51195199-350 UCN TRUNK CABLE SET, RG-11, 350M EA
    51195199-400 UCN TRUNK CABLE SET, RG-11, 400M MU-NKT400 EA
    51195199-600 UCN TRUNK CABLE SET, RG-11, 600M MU-NKT600 EA
    51195339-101 Cable, UCIO EA
    51195439-300 KIT, FDD REPL EA 51195439-400
    51195439-400 KIT, FDD REPL EA
    51195440-002 PRE-TERMINATED FIBER_OPTIC CABLE 2M P-KFA02 EA
    51195440-005 PRE-TERMINATED FIBER OPTIC CABLE 5M P-KFA05 EA
    51195440-010 PRE-TERMINATED FIBER OPTIC CABLE 10M P-KFA10 EA
    51195440-020 PRE-TERMINATED FIBER OPTIC CABLE 20M P-KFA20 EA
    51195440-050 PRE-TERMINATED FIBER OPTIC CABLE 50M P-KFA50 EA
    51195454-100 KIT, COLOR CODE EA
    51195454-200 LCN CBL CLR KIT EA
    51195466-300 GROUNDING STRAP EA
    51195466-400 GROUNDING STRAP EA
    51195476-022 COAX CABLE SET FM 59 22CM EA
    51195476-050 COAX CABEL SET FM59 50CM EA
    51195476-100 COAX CABLE SET FM59 100CM EA
    51195476-150 COAX CABLE SET FM59 150CM EA
    51195476-200 COAX CABLE SET FM59 200CM EA
    51195476-300 COAX CABLE SET FM59 300CM EA
    51195476-460 COAX CABLE SET FM59 460CM EA 51195476-500
    51195476-500 COAX CABLE SET FM59 5M EA
    51195476-700 COAX CABLE SET FM59 7M EA
    51195477-010 COAX CABLE SET FM59 10M EA
    51195477-015 COAX CABLE SET FM59 15M EA
    51195477-020 COAX CABLE SET FM59 20M EA
    51195477-025 COAX CABLE SET FM59 25M EA
    51195477-030 COAX CABLE SET FM59 30M EA
    51195477-045 COAX CABLE SET FM59 45M EA
    51195479-100 I/O LINK CBL SET EA
    51195479-200 I/O LINK CBL SET EA
    51195479-300 I/O LINK CBL SET (LINKS FOUR FILES) EA
    51195479-400 I/O LINK CBL SET EA
    51195479-500 I/O LINK CBL SET EA
    51195493-100 PWR SPLY RPL KIT, 110V EA
    51195493-200 PWR SPLY RPL KIT, 220V EA
    51195497-002 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH02. EA
    51195497-005 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH05. EA
    51195497-010 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH10. EA
    51195497-020 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH20. EA
    51195497-050 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH50. EA
    51195498-005 FIBER OPTIC CBL ST/ST 5M P-KFB05 EA
    51195498-010 FIBER OPTIC CBL ST/ST 10M P-KFB10 EA
    51195498-020 ST/ST FIBER OPTIC CABLE SET, MODEL P-KFB20 EA
    51195498-050 F/O CABLE, 50M EA
    51195499-100 5 SLOT C/F, CE EA 51196692-100
    51195511-100 RS485 BUS TERM EA
    51195563-200 POWER CORD EA
    51195652-100 19" COLOR CRT EA
    51195752-100 C/F 2NODE SPARE EA 51196727-100
    51195754-100 K2LCN GROUND CABLE EA
    51195755-300 QBC/QWERTY OP KYDB EA
    51195757-101 UPPER CRT W/TCH FR EC EA
    51195757-102 UPPER CRT W/TCH FR EC EA
    51195760-100 NIM MOD. FLD/REP/KIT EA
    51195761-100 ALIGNING PIN EA
    51195768-100 8PT TERM BLOCK EA
    51195769-100 12PT TERM BLOCK EA
    51195770-100 CONN BLK 8PT SE EA
    51195771-100 CONN BLK 12PT SE EA
    51195773-100 CONN BLK 8PT TE EA
    51195774-100 CONN BLK 12PT TE EA
    51195776-100 CON/BLK+ENDS(6) EA
    51195780-100 CRT ASSM 19IN EA
    51195787-102 YELLOW LAB LCNA EA
    51195787-103 GREEN LCN LABEL LCNB EA
    51195792-100 MOUSE KIT EA MP-ZMSE01-100
    51195793-100 CRT, 19IN INTERLAC EA
    51195794-100 CRT REPLACEMENT 14IN EA 51196793-100
    51195795-200 TRAY KIT EA
    51195868-200 19" CRT ASSY EA
    51195868-300 CRT REPL KIT 19IN EA
    51195868-400 CRT, KIT EA
    51195868-500 CRT, KIT EA
    51195868-510 CRT, KIT EA 51195868-700
    51195868-600 CRT, KIT EA
    51195868-650 CRT, KIT 45000 EA 51195868-800
    51195868-700 MONITOR REPL KIT 19IN EA
    51195868-800 MONITOR REPL KIT 19IN EA
    51195868-900 MONITOR KIT, BASIC OPER.STA. LCN FURNITURE EA
    51195868-925 MONITOR KIT, BASIC OPER. STA. KOP FURNITURE EA
    51195868-950 Monitor Kit, 45000 EA
    51195870-100 TAB, LOCKING EA
    51195904-112 PRINTER CBL 12FT EA
    51195904-206 CBL, CRT/COPIER EA
    51195949-311 528MB HARD DRIVE EA
    51195992-100 MICRO TOUCHSCRN EA
    51196045-100 SCREW, SEMS M3.5X20 EA
    51196063-100 MTG HDW,WREN III EA
    51196074-100 EPLCG INT CABLE EA
    51196075-100 CRT, IDEK 21INCH EA
    51196092-100 SPACER EA
    51196093-100 FTA MTG CHANNEL, NARROW MARKHON W/SH GRND BAR EA
    51196093-200 FTA MTG CHANNEL, WIDE MARKHON W/SHIELD GD BAR EA
    51196094-100 FTA MTG CHANNEL, NARROW RITTAL W/SH GRND BAR EA
    51196094-200 FTA MTG CHANNEL, WIDE RITTAL W/SHIELD GRD BAR EA
    51196094-300 SHORT FTA MNTG CHNL W/SHLD BAR NARROW EA
    51196211-112 2 PEN ROLL CHART EA MP-DPRU04-200
    51196211-113 3 PEN ROLL CHART EA MP-DPRU04-200
    51196211-122 2 PEN FAN FOLD EA
    51196211-123 3 PEN FAN FOLD EA
    51196212-213 DPR1000 CONF. PKG EA
    51196214-145 LOAD RESISTOR EA
    51196217-107 BLACK INKJET PRINT CARTRIDGE EA
    51196217-108 COLOR INKJET PRINT CARTRIDGE EA
    51196218-300 HP - 3M CABLE EA
    51196220-100 DRIVE_3-1/2 - 210MB EA 51196269-100
    51196226-100 ADAPTOR PLATE EA
    51196243-100 DRIVE 3-1/2 445MB EA 51196351-100
    51196254-100 HP 400MB W/SW EA 51402486-800
    51196257-100 DATT TAPE DR 4MW EA 51196865-100
    51196257-200 DAT CLEAN TAPE EA 51196863-920
    51196264-100 MAPWARE CABLE EA
    51196265-100 110V MODEM EA
    51196265-200 220V MODEM EA
    51196266-100 HR100 REMOD,110V EA
    51196266-200 HR100 REMOD,220V EA
    51196267-100 TRACKBALL REPLCT EA
    51196269-100 210MB REPLACEMENT DRIVE 3-1/2IN EA
    51196308-100 MOUSE KIT EA MP-ZMSE01-100
    51196308-200 MOUSE, UXS EA 51196713-200
    51196314-100 TONER CARTRIDGE EA 51196317-100
    51196315-100 TONER CARTRDIGE EA 51196317-100
    51196315-500 JETDIRECT CARD EA 51196319-400
    51196315-700 CARTRIDGE, PTR EA 51196316-700
    51196316-100 HP LJ5 115V EA 51196317-100
    51196316-500 LSZRJET ETHERNET EA 51196319-400
    51196316-700 TONER CARTRIDGE EA
    51196317-100 HP400 110V B&W DSKTPC4118A EA 51196322-100
    51196317-101 JETDIRECT 230VAC B&W DSKTP J3111A EA 51196322-200
    51196317-202 EDO DIMM FOR HP LJET4000T 4MB EA 51196322-203
    51196317-400 JETDIRECT CARD FOR 10BASE2 EA
    51196317-500 JETDIRECT CARD FOR 10/100 BASET EA 51196322-500
    51196317-700 REPLACEMENT TONER CARTRIDGE EA 51196322-700
    51196319-100 HP COLOR LASERJET 5 DESKTOP PRINTER, 115VAC EA 51196983-100
    51196319-101 HP COLOR LASERJET 5 DESKTOP PRINTER, 230VAC EA 51196983-101
    51196319-208 TONER CARTRIDGE CYANFOR COLOR LASERJET 5 EA
    51196319-209 TONER CARTRIDGE, YELFOR COLOR LASERJET 5 EA
    51196319-210 TONER CARTRIDGE, MAGFOR COLOR LASERJET 5 EA
    51196319-211 TONER CARTRIDGE, BLKFOR COLOR LASERJET 5 EA
    51196319-400 JET DIRECT CARD FOR COLOR PRTR(10 BASE2) EA
    51196319-500 JETDIRECT CARD FOR COLOR PNTR(10/100 BASET) EA
    51196321-100 EDO DIMM 64MB TP-ERM064-100 EA
    51196321-200 EDO DIMM 128MB TP-ERM128-100 EA
    51196322-100 LJET PRINTER 4050T, 117VAC EA 51196322-101
    51196322-101 LJET Printer, HP C8051A EA
    51196322-200 LJET Printer 4050T.220VAC EA
    51196322-202 4MB DIMM C4140A EA
    51196322-203 8MB PRINTER DIMM EA
    51196322-500 Ethernet Card, RJ45 10BaseT J3113A EA 51196322-501
    51196322-501 Ethernet Card, RJ45 10Base T J4169A EA
    51196322-700 REPLACEMENT TONER C4127X EA
    51196342-100 SPC FW KIT EA 51191561-100
    51196353-100 RCDR OPENING CVT KIT EA
    51196363-100 COLOR MONITOR 21IN EA
    51196418-300 PWA,ECC 16MB RAM EA
    51196418-301 PWA,ECC 32MB RAM EA
    51196418-302 PWA,ECC 64MB RAM EA
    51196418-400 BATTERY,COPROC EA
    51196432-100 DRIVE 1.2G UNPRG EA
    51196433-100 525MB W/O SOFTWARE EA 51402486-300
    51196454-300 DRIVE, EXT 525MB EA
    51196468-100 KIT, LOAD BANK EA
    51196478-101 Loop I/F Card (Printer) EA
    51196478-102 APHO Card (Printer) EA
    51196478-103 APTR/12 Card (Printer) EA
    51196478-104 Printhead Driver Card EA
    51196478-105 Power Card (Printer) EA
    51196478-106 ACL/1 Regulator Card EA
    51196478-107 Printhead, 18 Wire EA
    51196478-108 Carriage Assembly EA
    51196478-109 Cable, Carriage EA
    51196478-110 Motor, Carriage EA
    51196478-111 CABLE, PRINTHEAD EA
    51196478-112 CABLE, PRINTHEAD EA
    51196478-113 Carriage Stop EA
    51196478-114 Roller, Turnaround EA
    51196478-115 Shaft, Turnaround EA
    51196478-116 Bracket, Turnaround EA
    51196478-117 Switch, Paper Out EA
    51196478-118 MOTOR,RIBBON DRI EA
    51196478-119 Switch, Paperout EA
    51196478-120 TRACTOR ASM,LEFT EA 30754420-020
    51196478-121 Tractor Asm, Right EA
    51196478-122 Motor, Paperfeed EA
    51196478-123 Bushing, Tractor EA
    51196478-124 BELT,PAPER DRIVE EA
    51196478-132 FUSE,2A 125V EA
    51196478-133 FUSE, 7A 125V EA
    51196478-134 FUSE, 25A 125V EA
    51196478-135 FUSE, 3A 125V EA
    51196478-136 FUSE, 7A 125V EA
    51196478-139 PTR RIBBON, REINKABLE EA
    51196478-140 PWA,ECPU/I EA
    51196478-141 PWA, ACPL EA
    51196478-142 PWA, CPAR/1 EA
    51196478-143 BUSHING, TRACTOR EA
    51196478-145 GEAR,UP FRICTION EA
    51196478-146 TRACTOR, LEFT EA
    51196478-147 TRACTOR, RIGHT EA
    51196478-148 GEAR,LWR FRICSHF EA
    51196478-149 ROLLER ASM,LWRFR EA
    51196478-150 SHAFT ASM,UPRFRI EA
    51196478-151 SWITCH,ROCKER AC EA
    51196479-100 HP 2GB DRIVE W/O SOFTWARE EA 51402486-800
    51196480-100 CD ROM EA
    51196480-101 DISK CADDY EA
    51196483-100 150MB CART DRIVE EA
    51196485-400 CARTRIDGE, 150MB FOR USE W/LCN OR UxS EA
    51196485-500 CLEANING KIT, LCN 150MB CARTRIDGE DRIVE EA
    51196488-101 AM RED CBL EA
    51196489-001 SCSI I/F CBL EA
    51196489-002 SCSI CBL EA
    51196497-100 CRT REPL KIT 19IN EA 51195868-700
    51196497-200 CRT KIT EA
    51196650-100 KYBD BEEPER ASSM EA
    51196653-100 POWER SUPPLY, 5 SLOT EC EA
    51196654-100 P/S 10 SLOT EC EA
    51196655-100 P/S DUAL NODE EC EA
    51196659-100 FDD 5-1/4IN EA
    51196674-100 DPR100 RECORDER EA
    51196674-113 BATTERY EA
    51196680-100 870MB DRIVE EA 51196680-200
    51196680-200 870MB DRIVE ***SEE NOTES EA
    51196680-200EXCH 870MB HARD DRIVE EXCHANGE ONLY EA
    51196682-100 ANNUNCIATOR EA
    51196684-200 10 SLOT TOWER EA
    51196689-100 UPGR, BAS CMOS EA
    51196689-200 UPGR,EX CTL CMOS EA
    51196690-100 PRINTER, 110V EA
    51196690-200 PRINTER, 230V EA
    51196690-401 RIBBON, BLACK EA
    51196690-501 RIBBON, COLOR EA
    51196690-800 PAPER TRACTOR EA
    51196690-900 PEDESTAL,PRINTER EA
    51196690-920 PRINT HEAD EA
    51196692-100 CLASSIC 5 SLOT SPARE CARD FILE CE EA
    51196694-150 Z KB W/O TRKBL EA
    51196694-200 UNIVERSAL KEYBOARD W/TRACKBALL LCN FURNITURE EA
    51196694-250 KYBD W/TRACKBALL, Z FURN EA
    51196694-300 PS-2 IKB W/TBALL EA
    51196694-310 IKB, W/TBALL,PS2 EA
    51196694-350 IKB/WTRKBALL, GUS Z-CONSOLE EA
    51196694-901 TRACKBALL FOR INTEGRATED KEYBOARD EA
    51196694-902 IKB CTRL PWB EA
    51196694-903 IKB CTRL GUS EA
    51196694-904 K/B FULL TRAVEL EA
    51196694-905 LEGENDED KEYCAPS FOR UNIV. KEYBOARD EA
    51196694-906 BLANK KEYCAP SET NO LEGEND UNIV KEYBOARD EA
    51196694-907 OPERATOR MEMBRANE CONTROL PANEL EA
    51196694-908 MEMBRANE FUNCTION KEY PANEL EA
    51196694-909 Z CONSOLE FUNCTION KEY PANEL EA
    51196694-910 OPERATOR KEYSWITCH WITH KEYS EA
    51196694-911 KEYBD INSERTS 3 SETS RELEGENDABLE EA
    51196694-912 IKB K/B CBL 36IN (DESKTOP LGTH) EA
    51196694-913 IKB K/B CBL 72IN Z CONSOLE EA
    51196694-914 T/B CBL FOR IKB LCN (S/M) 72IN EA
    51196694-915 IKB K/B CBL 36IN EA
    51196694-916 T/B CBL FOR IKB GUS (S/M) 72IN EA
    51196694-917 CURSOR BLANKING PLT EA
    51196694-919 KEYBOARD FIRMWARE RETROFIT KIT (1KB) EA 51191510-100
    51196694-920 TRACKBALL FIRMWARE RETROFIT KIT (SUMMAGR.) EA
    51196694-921 TRACKBALL FIRMWARE RETROFIT KIT (PS/2) EA
    51196694-922 IKB CONTROLLER BOARDSURFACE MOUNT(SUMMAGRAPH) EA
    51196694-923 IKB CONTROLLER BOARDSURFACE MOUNT (PS/2) EA
    51196696-100 ENHANCED KIT EA 51304449-500
    51196696-200 19IN MONITOR EA 51304449-500
    51196701-100 PWB, CLI I/O EA
    51196703-100 1.44MB FLPY DRIVE EA
    51196704-200 1 GB H/D EA
    51196705-100 CONSOLE 250W P/S EA
    51196706-200 DAT TAPE MEDIA EA
    51196706-300 DAT CLEAN KIT EA
    51196707-100 Drive, CD ROM EA
    51196708-100 TOWER W/PS EA
    51196708-110 TOWER P/S EA
    51196708-156 604 132 MHZ BD (GUS MOTHER BOARD) EA
    51196708-170 1M GRAPHICS MEM EA
    51196708-180 KYBD, W/MOUSE EA
    51196709-100 RISER CARD EA
    51196710-100 MONITOR, INTECOLOR EA 51195868-700
    51196710-200 CRT, 19IN EA
    51196710-250 INTCOLOR CRT EA 51195868-800
    51196710-300 Monitor, Basic in Univ. Furn. EA 51195868-700
    51196710-400 Monitor, Basic in KOP Furn. EA
    51196712-100 BEIGE ENG KYBD EA MP-ZEKBF1-100
    51196712-200 ENG KYBD, GRAY ROVING EA
    51196713-200 MOUSE, USX EA
    51196714-100 MICRO TRACKBALL EA
    51196720-100 875MB HARD DRIVE EA 51196680-200
    51196721-100 MEDIA_DRIVE_ENCL EA 51196721-300
    51196721-300 MEDIA DRIVE ENCL EA
    51196721-400 MED DRVS ENC ASSM EA
    51196722-100 MEDIA DR ACC KIT EA 51196722-300
    51196722-200 AC KIT W/O MEDIA EA 51196722-400
    51196722-300 MEDIA DR ACC KIT EA
    51196722-400 AC KIT W/O MEDIA EA
    51196722-600 No Media AccKit IKB EA
    51196727-100 C/F 2NODE SPARE EA
    51196728-100 C/F 2NODE "Z" EC EA
    51196729-100 C/F 5 SLT "Z" EC EA
    51196730-100 CLASSIC 3/3/2/2 SPARE FILE EC EA
    51196734-100 CONN PLATE ACCM KIT EA
    51196734-400 CONN PLATE ACCM KIT EA
    51196736-100 CLASSIC 10 SLOT 6/4. 3/4 SPARE EA
    51196742-100 VIDEO CABLE EA
    51196742-300 DUAL VIDEO CABLE CLASSIC DUAL CRT EC EA
    51196742-400 VIDEO CABLE 6 FT EA
    51196742-500 VIDEO CABLE 8FT EA
    51196744-100 256MB CACHE MEM EA 51196744-106
    51196744-106 256MB CACHE MEM EA
    51196749-100 SPEAKER 2.25IN EA
    51196777-100 FACE PLATE - BLK EA
    51196787-100 ATTENTION LABEL EA
    51196793-200 MONITOR, SAMSUNG 17" #700IFT EA
    51196797-100 BLK FLANGE COVER EA
    51196802-100 DUAL NODE PWR SUPPLY EA 51402184-100
    51196805-100 P/S 5 CARD N/CE EA 51402184-200
    51196810-100 P/S 10 CARD N/CE EA 51402184-300
    51196837-100 UCN A LABEL EA
    51196837-200 UCN B LABEL EA
    51196853-100 HARD DRIVE 4.3GB EA 51191579-300
    51196854-100 HARD DRIVE 9.1GB EA 51196968-100
    51196856-100 DAT TAPE DRIVE EA 51196863-100
    51196856-900 120M DAT CART (SEE NOTE FIELD) EA 51196863-910
    51196863-100 INTERNAL DDS2 TAPE DRIVE EA
    51196863-900 HP90M DDS-1 CARTRIDGE EA
    51196863-910 HP120 DDS-2 CARTRIDGE EA
    51196863-920 HP DDS CLEANING CARTRIDGE EA
    51196865-100 INTERNAL DDS2 TAPE DR W/TERM EA
    51196879-100 UCPU(CB)REPL KIT EA
    51196880-100 UCPU(CB) W/DEP EA
    51196881-100 UCPU(EC)REPL KIT EA
    51196882-100 UCPU(EC) W/DIDEP EA
    51196885-100 UDHI REPL KIT EA
    51196886-100 UCIO REPL KIT EA
    51196886-200 UCIO SPARE KIT EA
    51196895-100 1.8GB HARD DRIVE EA
    51196895-100EXCH 1.8GB HARD DRIVE EXCHANGE ONLY EA
    51196907-200 DAT DRIVE EA 51196706-100
    51196908-200 1.44MB FLOPPY DRIVE EA 51196703-100
    51196909-200 CD ROM EA 51196707-100
    51196919-100 DUAL CRT CONTROLLER EA 51196928-100
    51196920-400 CRT CABLE ASSM 9 PIN5BNC 10FT EA
    51196927-400 TPS Console Mtg Electronics EA
    51196928-100 DUAL CRT CTRL EA
    51196929-100 ZIP DRIVE EA
    51196930-100 T/S CTRL(ISA CD) EA
    51196931-202 2 DRIVE ENCL KIT EA
    51196932-100 ZIP DRIVE TP-DZIP00-100 EA
    51196932-200 ZIP DRIVE EA 51196929-100
    51196933-200 ASY ZIP/F-PLATE EA
    51196935-100 DELL GX PRO PC EA
    51196935-900 MOUSE, PS2 EA
    51196935-901 KEYBOARD, 104 EA
    51196935-902 TERM 2ND PROG EA
    51196935-903 64MB MEMORY ECC EA
    51196935-904 1.44 MB FLOPPY DRIVE EA 51196946-905
    51196935-905 8X CD ROM DR EA 51196982-906
    51196935-906 ADAPTOR, 2940 EA 51196946-907
    51196935-907 2MB VIDEO PWB EA
    51196935-922 2GB H/D EA 51191579-300
    51196935-924 4GB H/D EA 51196968-100
    51196935-928 4GB HARD DRIVE EA 51196854-100
    51196936-100 MINICART T/DRIVE EA
    51196936-200 MINICART T/MEDIA EA
    51196936-300 M/CART CLEAN KIT EA
    51196939-100 PS2 MOUSE, INDUSTRIAL CE TP-ICEMS1 EA
    51196943-100 QWERTY K/B INDUSTRAL CE TP-ICEKB1 EA 51191508-100
    51196944-100 4MB DUAL VIDEO PWB EA 51197011-100
    51196944-101 DUAL VIDEO BOARD 4MW EA 51197072-100
    51196946-100 DELL 266Mh PENTIUMIIOPTIPLEX GXA DESKTOP EA
    51196946-200 DELL 266MHz PENTIUM II OPPLX 4000LX DESK SIDE EA
    51196946-900 MOUSE EA 51196982-900
    51196946-901 KEYBOARD EA
    51196946-903 64MB ECC SDRAM DIMM EA 51196971-100
    51196946-904 128MB ECC SDRAM DIMM EA 51196971-101
    51196946-905 FLOPPY DR 1.44MB EA
    51196946-906 CD, 680MB 12/24X NEC EA 51196982-906
    51196946-907 PWA, ADAPT, 2940, PCI/S EA
    51196946-910 FILLER PLATE FOR EXTERNAL BAY EA 51196982-910
    51196946-911 BASE MOUNT IN DESK SIDE CONFIG. EA
    51196962-901 ADAPTEC 2940W DUAL CHANNEL PCI EA 51198718-907
    51196966-300 MINICARTRIDGE CLEANING KIT EA
    51196968-100 9.1 GB HARD DRIVE EA 51191579-300
    51196969-100 MOTOROLA PENTIUM II 300 MHz PC DESKTOP EA
    51196969-200 MOTOROLA PENTIUM II 300 MHz PC DESKSIDE EA
    51196969-900 KEYBD/MOUSE KIT -US (66433577 MOTOROLA PART) EA
    51196969-901 KEYBOARD/MOUSE EA 51196969-900
    51196969-903 PWB,64MB SDRAM DIMM (96014164) EA 51196321-100
    51196969-906 CD ROM DRIVE 2X (96014128) EA 51196982-906
    51196969-908 PWB, GRAPHICS, 4MB APG SVAG (96014167) EA 51191564-100
    51196969-910 FILLER PLATE EA
    51196969-912 SCSI 4GB HARD DRIVE EA 51196968-100
    51196969-914 POWER SUPPLY 300W EA
    51196969-916 MOTHERBOARD W/300 MHPROCESSOR EA
    51196971-100 64MB SDRAM DIMM FOR PENTIUM II EA
    51196971-101 128MB SDRAM DIMM FOR PENTIUM II EA 87758
    51196972-100 SCSI ADAPTER EA
    51196979-100 CRT 20IN MULTISYNC CLASSIC EA
    51196982-100 450MHZ GX1 DESKTOP/IN CONSOLE PC EA
    51196982-101 450MHZ GX1 DESKTOP/IN CONSOLE PC W/O CD DR EA
    51196982-102 500MH PIII DESK CONS W/O CD DRIVE EA
    51196982-200 450MHZ DESKSIDE GX1 PC EA
    51196982-201 450MHZ GX1 DESKSIDE PC W/O CD DRIVE EA
    51196982-202 500MH PIII MINI TOWER W/O CD DRIVE EA
    51196982-900 PS2 MOUSE EA
    51196982-901 KEYBOARD, 104 EA
    51196982-902 450MHZ DESKTOP PROCESSOR EA
    51196982-903 POWER SUPPLY 200WATT EA
    51196982-904 DIMM, 128, 100M 16X72 4K 168 EA
    51196982-905 FLOPPY DRIVE EA
    51196982-906 CD 680M, 17/40X EA 51198718-906
    51196982-907 SCSI CONTROLLER, 2940 DUAL PCI/S (DELL 6982D) EA
    51196982-908 SCSI 9.1GB UWIDE H/D EA
    51196982-909 RISER 5 SLOT ACTIVE EA
    51196982-910 FILLER PLATE EA
    51196982-912 MOTHERBOARD GX1 EA
    51196982-913 SCSI ADAPTOR 2940 (DELL 36849) EA
    51196982-914 9GB U2W SCSI HD (10K RPM) EA
    51196982-915 PROCESSOR KIT 500MH EA
    51196982-916 PROCESSOR 550M PIII EA
    51196982-953 POWER SUPPLY EA 51196982-903
    51196982-959 RISER, 7 SLOT ACTIVE EA
    51196983-100 COLOR PRINTER 120VAC HP4500N EA
    51196983-101 COLOR PRINTER 240VAC HP4500N EA 51196983-103
    51196983-102 HP C7086A/ABA, 120V EA
    51196983-103 HP C7086A/ABB, 220V EA
    51196983-208 TONER, CYAN EA
    51196983-209 TONER, YELLOW EA
    51196983-210 TONER, MAGENTA EA
    51196983-211 TONER, BLACK EA
    51196983-308 DRUM KIT EA
    51196983-309 TRANSFER KIT EA
    51196983-310 FUSE KIT 120V EA
    51196983-311 FUSE KIT 220V EA
    51196988-100 DUAL VIDEO BOARD EA 51197072-100
    51196988-200 Video Card, Matrox G2+/DUALP-PL EA 51197072-100
    51196989-100 UNIVERSAL REGULATOR PWB EA
    51197000-100 FST HI RES MON 21IN EA
    51197002-100 HI RES CRT EA 51304449-500
    51197002-200 HI RES CRT EA 51304449-500
    51197004-100 POWER SUPPLY EA 51197004-200
    51197004-200 PWR SUPPLY EA
    51197004-300 P/S UPPER POD EA
    51197005-100 IDEK T/S CTL BOX EA
    51197005-200 T/S CON W/O CASE EA
    51197006-100 TOUCH SCREEN 21IN EA
    51197007-100 IDEK TOUCHSCREEN EA
    51197008-100 BUMPER/ PER FOOT EA
    51197009-100 EXTERNAL T/S CONTR. CARD EA 51305386-100
    51197009-101 TOUCH SCREEN CONTRLR EA 51305386-100
    51197011-100 AUGMENT KIT DL VIDEO TP-DCRTVB-100 EA 51197072-100
    51197012-100 A4484A 4.55Gb HDRV EA 51402486-800
    51197013-200 TOUCH SCREEN 21IN W/ 9 PIN CONN EA
    51197013-201 TOUCH SCREEN 21IN W/76IN CABLE EA
    51197013-202 TOUCH SCREEN 21IN W/PHONE CONN EA
    51197013-300 BEZEL KIT EA
    51197013-400 BEZEL BUTTONS (EA4) EA
    51197014-100 Monitor, 21" EA
    51197015-200 T/S ASSM LCN EC EA
    51197015-201 T/S ASSM GUS EC EA
    51197015-202 T/S ASSM FOR 21 IN MONITOR W/20 IN CBL EA
    51197015-300 BEZEL KIT EA
    51197015-400 T/S BUTTONS EA
    51197016-100 21IN MONITOR EA
    51197017-100 19IN HI-RES MONITOR (OBSOLETE) EA 51304449-500
    51197018 100 21" CRT EA
    51197018-100 21" CRT (OBSOLETE SEE NOTES) EA
    51197019-100 MICRO 21IN T/S EA
    51197019-300 BEZEL BUTTONS EA
    51197020-100 21IN FST L/RES MON EA
    51197021-100 COLOR MONITOR 21 EA
    51197022-100 T/S FRAME EA 51197022-200
    51197022-200 T/S FRAME, EC EA
    51197022-201 TOUCHSCREEN 21IN EA
    51197022-400 BEZEL BUTTONS (4each EA
    51197024-100 FOAM RUBBER GASKET EA
    51197025-100 Z LEVELING GLIDE PS EA
    51197031-100 BASKET BRACKET EA
    51197035-100 MONITOR MNTG ACCM K IT EA
    51197035-400 MOUNTING KIT, LOWER CRT (SONY) EA
    51197040-300 UPPER CARDFILE UPGRADE KIT, NON-GUS EA
    51197040-400 LOWER CARDFILE UPGRADE KIT, NON-GUS EA
    51197040-500 GUS/INTEL UPPER CARDFILE UPGRADE KIT EA
    51197041-100 KYBD SHELF ASSM EA
    51197041-200 KYBD SHELF ASSM EA
    51197044-100 PAPER BASKET ACCM KIT EA
    51197049-100 CONSOLE BASE KIT, 1 CF EC EA
    51197049-200 CNSL BSK KIT 2 CF ASSM EA
    51197049-300 MED CNSL BASE KIT, 0CF EA
    51197051-100 KIT,TOUCHSCREEN EA
    51197052-500 AUX EQUIP LWR/UPR EA
    51197052-600 AUX-EQUIP LWR/UPR EA
    51197053-100 AUX PWR STRIP & CBLE EA
    51197055-200 BLANK PLATE ASSM EA
    51197057-100 PLASTITE SCREW BLAN K EA
    51197057-200 SCREW PLASTITE EA
    51197058-300 2NODE CARDFILE ST E C EA
    51197063-100 MONITOR LABEL EA
    51197066-100 PWR ENTRY FILTER EA
    51197066-200 A/C POWER ENTRY EA
    51197068-100 SPARE 5S ENH CFA EA 51196729-100
    51197069-100 C/FC2NODE "Z" EC EA 51196728-100
    51197072-100 DUAL VIDEO UPGRADE KIT EA
    51197074-100 LABEL EQUIPOTENTIAL EA
    51197079-100 LOAD RES KIT EA
    51197083-100 12 PORT E NET SWITCH EA
    51197083-101 E NET SWITCH CASCADE EA
    51197084-100 HI SWITCH 2 NODE EA
    51197084-500 KVM 4 Port Switch, Modified EA
    51197085-100 DUAL NET IF CARD EA
    51197086-100 Junction Box EA
    51197087-100 GPS 8 Channel Antenna EA
    51197087-200 Antenna, GPS Accutime2000 EA
    51197088-200 SONY MONITOR W/TS 21IN EA 51199161-200
    51197088-300 MONITOR W/ T/S EA
    51197090-100 Z STYLE 21IN MONITOR (SONY) EA
    51197096-100 19" SONY CRT EA
    51197097-100 Z STYLE 21IN MONITOR (SONY) EA
    51197103-101 XPM HDDO (REV F) RETROFIT KIT EA
    51197103-103 LCNP4 FLASH PROM PROG DISK N/C RETROFIT EA
    51197103-104 LCNP4 SERIAL EPROM N/C RETROFIT EA
    51197103-105 CB-UCPU FW RETROFIT KIT EA
    51197103-106 UCPU EC RETROFIT KIT RETROFIT #99-01 EA
    51197103-107 RETRO99-08 TH IKB FW EA
    51197103-108 RETRO98-08 SMT IKBFW EA
    51197103-109 RETROIT #97-03 & 99-02 IKBI2 FIRMWARE EA
    51197103-110 RETROFIT KIT #2001-02,LLMUX PRE-CAL FW EA
    51197103-111 Retro Kit #2001-03 19" Touchscreen` EA
    51197103-112 HLAI2 Firmware Upgrade Kit EA
    51197155-000 POWER CBL,INTRNL USE EA
    51197160-100 LIGHT, HPM TS8 CABINET, UNIVERSAL VOLTAGE EA
    51197164-100 TB A/C & TB ALARM EA
    51197170-100 HPM PS/FAN ALARM WIR EA
    51197173-100 THERMOSTAT, TS8 CABINET EA
    51197515-100 WARNING LABEL EA
    51197555-300 LCN AUX CAB/KEY EA
    51197564-100 UCNE, 2KM 85-236VAC EA
    51197564-200 UCNE, 2KM 18-36VDC MU-FOED02 EA
    51197577-100 MOUNTING KIT EA
    51197597-100 OUTDOOR RH MUST CABLE 1000FT EA 51197597-305
    51197597-305 4 WIRE MUX CABLE MU-KLO305 EA
    51198706-100 CTLR UPGRADE KIT EA
    51198707-100 CTLR UPGRADE KIT EA
    51198708-100 CTLR UPGRADE KIT EA
    51198709-100 CTLR UPGRADE KIT EA
    51198711-100 RESERVE CTLR UPGRADE KIT EA
    51198717-100 2ND H/DRIVE TRAY W/H/D (KIT) EA
    51198718-100 866MH DESKTOP PC EA
    51198718-101 GX200 1GHZ Desktop PC EA
    51198718-200 866MH TOWER PC EA
    51198718-201 GX200 1GHZ Deskside PC EA
    51198718-900 MOUSE, PS2 EA
    51198718-901 KEYBOARD, 104 EA
    51198718-902 PROCESSOR, 80526, 866, 256, 133, FC EA
    51198718-903 POWER SUPPLY 200W EA
    51198718-904 MEMORY, 128MB, ECC EA
    51198718-905 1.44MH FLOPPY DRIVE EA
    51198718-906 CD DRIVE 17/40X, SCSI(PLEXOR) EA
    51198718-907 CRD, SCSI CTL, 29160N, XLOB EA
    51198718-908 9.1GB 10K RPM H/ D TYPHOON QTM EA
    51198718-909 PWA RISER, 5 SLOT(DESKTOP) EA
    51198718-910 FILLER PLATE EA
    51198718-911 DESKTOP BASE MOUNT EA
    51198718-912 GX200 MOTHERBOARD EA
    51198718-913 256MB PC700 ECC RDRAM RIMM EA
    51198718-914 Processor, 1Ghz EA
    51198718-959 PWA RISER, 7 SLOT PCI/ISA,MT(TOWER) EA
    51198801-100 UPGRADE KIT UPIU EA
    51198920-100 28P PROTECT BOOT EA
    51198946-100 M2.5X.045 I/O SCREW EA
    51198947-100 PM POWER SUPPLY EA
    51198959-200 NAMEPLATE RITTAL EA
    51198963-100 HLAI/STI DIN REPLACEMENT KIT (DIN TO PHONE) EA
    51198964-100 LLAI FTA REPLACEMENT KIT (DIN TO PHONE) EA
    51199156-100 PCI FORMAT 8Mb VIDEO BOARD EA 51191564-100
    51199159-100 Z CNS, 15 DEG WEDGE/SHROUD KIT EA
    51199159-200 Z CNS, 30 DEG WEDGE/SHROUD KIT EA
    51199161-100 FREE STANDING CRT W/O T/S EA
    51199161-200 GUS 21" SONY W/TS EA
    51199161-300 REPL KIT, 21 SONY MONITOR EA
    51199164-100 FLOPPY P/S REPL. KIT EA
    51199200-100 RETROFIT 99-01 PP INSTALLATION INSTRUCTIONS EA
    51199201-100 RETROFIT 99-02-PP INSTALLATION INSTRUCTIONS EA
    51199202-100 RETROFIT 99-004 MAU INSULATOR INSTALL INSTRUC EA
    51199203-100 Retrofit 99-05-PP Instructions OSM CONN ASSM EA
    51199204-100 Retrofit 99-08 IKB KYBD Frmwre Instal Instr EA
    51199205-100 Retrofit99-09 CB-UCPU Frmwr Instal Instruc EA
    51199206-100 Retrofit 2001-02 LLMUX FW Instructions EA
    51199207-100 Retrofit 2001-03 Installation Instructions EA
    51199825-100 8301-HI-IS-HON EA 8301-HI-IS-HON
    51199827-100 8304-AO-IS-HON EA 8304-AO-IS-HON
    51199828-100 8305-TI-IS-HON EA 8305-TI-IS-HON
    51199829-100 8306-TI-IS-HON EA 8306-TI-IS-HON
    51199830-100 8315-DO-IS-HON EA 8315-DO-IS-HON
    51199831-100 8320-DI-IS-HON EA 8320-DI-IS-HON
    51199835-100 MF-FCAR11 EA MF-FCAR11
    51199836-100 MF-BIMS11 EA MF-BIMS11
    51199837-100 8930-PS-AC-HON EA 8930-PS-AC-HON
    51199838-100 8931-PS-AC-HON EA 8931-PS-AC-HON
    51199846-100 MF-CIOL11 EA MF-CIOL11
    51199847-100 MF-CAUX11 EA MF-CAUX11
    51199848-100 MF-CFCP11 EA MF-CFCP11
    51199849-100 MF-CIOE11 EA MF-CIOE11
    51199850-100 MF-CAXE11 EA MF-CAXE11
    51200523-106 NYLON SPACER EA
    51200536-601 FASTENER 1/4IN EA
    51200620-100 NEMA BOX, NO CERTIFICATION EA 51303005-101
    51200620-101 NEMA BOX EA 51303005-105
    51200641-100 SHIELD TERM BLK W/TERM MTG LL P-OTS12 EA
    51200641-101 TERMINAL PANEL (HL) EA
    51200642-100 COVER EA
    51200844-100 PUR SUPPLY BRACKET EA
    51200845-100 PWR SUP SUPPORT EA
    51200849-100 SWITCH, CFA. 24V EA
    51200852-101 CABLE, MUX BOX EA
    51200852-102 DATA CABLE ASSY EA
    51200852-103 DATA CABLE ASSY EA
    51200873-100 CABLE ASSEMBLY EA
    51201122-006 VERT MTG RAIL EA
    51201200-100 EXTENSION SPRING EA
    51201201-100 AIR FILTER 29.13" X 6.70" X 1.00" EA
    51201201-200 AIR FILTER 16.41" X 13.81" X .50 EA
    51201201-300 AIR FILTER 13.38" X 14.78" X .62" EA
    51201201-400 AIR FILTER 16.50" X 6.75" X .62" EA
    51201201-500 AIR FILTER 20.81" X 8.72" X .50" EA
    51201201-600 AIR FILTER 16.50" X 12.00" X .62" EA
    51201201-700 AIR FILTER EA
    51201201-800 AIR FILTER 17x4 EA
    51201201-900 AIR FILTER EA
    51201248-300 AIR DUCT PANEL BLANK EC EA
    51201248-400 AIR DUCT BLANK PANEL EC EA
    51201254-100 SUPPORT BAR EA
    51201255-100 HNG. PN RTNR. FREAST EA
    51201261-100 STRAP, COMPLEX EA
    51201262-100 KBD CLAMP BAR EA
    51201271-100 THUMBWHEEL EA
    51201274-100 SUPPORT PLATE EA
    51201275-100 RETAINER EA
    51201280-100 CRT STOP BAR EA
    51201284-100 HORIZ DUCT BRACKET EA
    51201288-100 GROUND BLOCK EA
    51201298-290 GROUND CABLE EA
    51201349-100 FILTER, AIR EA
    51201354-001 BATT CBL, N-BLK EA
    51201354-002 BATT,CBL P-RED EA
    51201354-003 BATTCBL X-ENDRED EA
    51201385-100 FDD PLANT PLATE EA P-ZKF56
    51201394-100 2-DROP TAP ASSM MU-NTAP02 EA
    51201395-100 4-DROP TAP ASSM MU-NTAP04 EA
    51201396-002 CABLE, 2M I/O EA
    51201396-003 CABLE, 3M I/O MU-KTPC03 EA
    51201396-004 CABLE, 4M I/O EA
    51201396-005 CABLE, 5M I/O MU-KTPC05 EA
    51201396-008 CABLE, 8M I/O EA
    51201396-010 CABLE, 10M I/O MU-KTPC10 EA
    51201396-015 CABLE, 15M I/O EA
    51201396-020 CABLE, 20M I/O MU-KTPC20 EA
    51201396-025 CABLE, 25M I/O EA
    51201396-030 FTA I/O CBL,30M EA
    51201396-050 FTA I/O CBL,50M EA
    51201397-001 DS PWR CABLE,1M EA
    51201397-002 DS PWR CABLE,2M EA
    51201397-004 DS PWR CABLE,4M EA
    51201397-005 DS PWR CABLE,5M MU-KDPR05 EA
    51201397-006 DS PWR CABLE,6M EA
    51201397-008 DS PWR CABLE,8M EA
    51201397-010 DS PWR CABLE,10M MU-KDPR10 EA
    51201397-015 DS PWR CABLE,15M MU-KDPR15 EA
    51201397-020 DS PWR CABLE,20M MU-KDPR20 EA
    51201397-025 DS PWR CABLE,25M MU-KDPR25 EA
    51201397-030 DS PWR CABLE,30M MU-KDPR30 EA
    51201397-035 DS PWR CABLE,35M MU-KDPR35 EA
    51201397-040 DS PWR CABLE,40M MU-KDPR40 EA
    51201397-050 DS PWR CABLE,50M MU-KDPR50 EA
    51201397-915 DS PWR CBLE,1.5M EA
    51201398-200 I/O LINK CBL SET EA 51195479-200
    51201418-101 SGL BLANK PLATE EA
    51201418-300 CABLE CLAMP BRACKET EA
    51201418-304 BRKT, CABLE CLMP EA
    51201418-305 BRKT,CABLE FTC4 EA
    51201418-400 CABLE CLAMP BRACKET EA
    51201420-001 FTA I/O CBL, 1M, non-CE EA
    51201420-002 FTA I/O CBL, 2M, non-CE MU-KFTA02 EA
    51201420-003 FTA I/O CBL, 3M, non-CE EA
    51201420-004 FTA I/O CBL, 4M, non-CE EA
    51201420-005 FTA I/O CBL, 5M, non-CE MU-KFTA05 EA
    51201420-006 FTA I/O CBL, 6M, non-CE EA
    51201420-008 FTA I/O CBL, 8M, non-CE EA
    51201420-010 FTA I/O CBL, 10M, non-CE MU-KFTA10 EA
    51201420-012 FTA I/O CBL, 12M, non-CE EA
    51201420-015 FTA I/O CBL, 15M, non-CE MU-KFTA15 EA
    51201420-020 FTA I/O CBL, 20M, non-CE MU-KFTA20 EA
    51201420-025 FTA I/O CBL, 25M, non-CE MU-KFTA25 EA
    51201420-030 FTA I/O CBL, 30M, non-CE MU-KFTA30 EA
    51201420-035 FTA I/O CBL, 35M, non-CE MU-KFTA35 EA
    51201420-040 FTA I/O CBL, 40M, non-CE MU-KFTA40 EA
    51201420-045 FTA I/O CBL, 45M, non-CE MU-KFTA45 EA
    51201420-050 FTA I/O CBL, 50M, non-CE MU-KFTA50 EA
    51201420-060 FTA I/O CBL, 60M, non-CE EA
    51201420-905 Cable, .5m FTA Phone to Phone EA
    51201420-915 FTA I/O CBL, 1.5M, non-CE EA
    51201421-001 REDUNDANCY CABLE EA 51201421-100
    51201421-100 REDUNDANCY CABLE EA
    51201436-300 5 SLOT PWR SPLY EA
    51201436-400 10 SLOT PWR SPLY EA
    51201438-100 FAN GUIDE BRACKET EA
    51201443-100 TERMINATOR BRACKET EA
    51201450-100 HLAI CALIB TOOL FOR GI/IS MU-GACT02 EA
    51201465-100 TRIM LEFT SIDE-FULL EA
    51201465-200 TRIM RIGHT SIDE-FULL EA
    51201467-100 TRIM BOTTOM FULL EA
    51201468-100 TRIM CENTER - FULL EA
    51201469-100 TRIM LEFT SIDE - HALF EA
    51201469-200 TRIM RIGHT SIDE - HALF EA
    51201470-100 TRIM PANEL TOP EA
    51201550-100 BRKT, FILLER MTG EA
    51201551-100 TRIM FILER PLATE EA
    51201551-200 HPM FILLER PLATE EA
    51201551-300 FRONT COVER EA
    51201553-100 DIN-PHONE ADAPTR MU-ZFTD02 EA
    51201557-100 I/O LINK(1) ASSM EA
    51201557-150 I/O LINK ASSM CC EA
    51201557-300 I/O LINK(3) ASSM EA
    51201557-350 I/O LINK ASSM CC EA
    51201559-100 CLIP, PANEL EA
    51201561-001 CBL, 1M DIN/PHO (SEE NOTES) EA
    51201561-003 CBL, 3M DIN/PHO EA
    51201561-004 CBL, 4M DIN/PHO EA
    51201561-005 CBL, 5M DIN/PHO MU-KFTD05 EA
    51201561-010 CBL,10M DIN/PHONE MU-KFTD10 EA
    51201561-015 CBL,15M DIN/PHONE MU-KFTD15 EA
    51201561-020 CBL,20M DIN/PHONE MU-KFTD20 EA
    51201561-025 CBL, 25M DIN/PHONE MU-KFTD25 EA
    51201561-030 CBL,30M DIN/PHONE MU-KFTD30 EA
    51201561-050 CBL,50M DIN/PHONE MU-KFTD50 EA
    51201566-100 SHIELD GRND BAR EA 51201653-100
    51201568-200 TRAY, NARROW RITTAL EA 51401246-200
    51201602-100 PLUG-IN MODULE, PULSE INPUT EA
    51201616-100 PWB, FIBER OPT EA
    51201623-100 FTA SPACER RIGHT EA
    51201624-100 FTA SPACER LEFT EA
    51201645-400 K4 MEZZ-4MW EA
    51201645-800 K4 MEZZ 8MW EA
    51201653-100 SHIELD GRND BAR EA
    51201666-100 MTG CHAN HOZ NAR W/ SGB MU-TMHN02 EA
    51201667-100 HPM RED CBL EA
    51201691-002 FAN POWER CABLE 2M EA
    51201691-005 FAN POWER CABLE 5M EA
    51201691-010 FAN POWER CABLE 10M EA
    51201699-001 PWR CBL LNK PTR EA 51204127-100
    51201736-100 UxS ROLLER, K/B TRA Y EA
    51201748-100 LOAD KIT EA 51196468-100
    51201748-110 LOAD RESISTOR KIT EA 51197079-100
    51201748-120 LOAD KIT EA
    51201748-210 LOAD RESISTOR KIT EA 51197079-100
    51201759-160 16MW MEZ PWB EA
    51201762-100 BRKT, DISK MTG EA
    51201766-100 SLEEVE SCREW EA
    51201772-100 COVER EA
    51201786-100 IKB BUMPER BRACKET EA
    51201793-160 K4SS, 16MB EA
    51201795-400 K4-SS 4M, Memory EA
    51201795-800 K4-SS 8M, Memory EA
    51201807-100 GND CABLE EA
    51201821-100 RETAINER BRACKET EA
    51201829-100 BLANK PLATE EA
    51201830-200 CRT BASE CLAMP EA
    51201830-400 CRT BASE CLAMP EA
    51201835-100 TRACKBALL BUTTON EA 51191524-100
    51201840-100 STEEL CABLE EA
    51201846-100 CPU EMULATOR (FOR YAMATAKE ONLY) EA
    51201862-100 CRT PANEL ASSY(SONY) EA
    51201863-100 T/S ASSM Z FURN (SONY) EA TP-ZSTSR1-100
    51201872-100 MONITOR CONTROL PNL EA
    51201875-100 CRT CTRL PNL ASM(SONY) EA
    51202005-100 TRAY GUIDE EA
    51202018-100 WEDGE BUMPER BRACKET EA
    51202020-100 POWER SUPPLY MTG. BRACKET EA
    51202023-100 TABLE SPACER EA
    51202023-200 TABLE SPACER EA
    51202026-100 RETAINER BLOCK EA
    51202027-100 CABLE COVER EA
    51202032-100 POWER/FAN BLANK COVER EA
    51202034-100 INLINE WEDGE ASSM EA
    51202037-100 WEAR CHANNEL EA
    51204031-100 MOUNTING ANGLE EA
    51204033-002 FTA I/O CBL, 2M, CE EA
    51204033-003 FTA I/O CBL, 3M, CE EA
    51204033-004 FTA I/O CBL, 4M, CE EA
    51204033-005 FTA I/O CBL, 5M, CE MU-KFTS05 EA
    51204033-008 FTA_I/O_CBL, 8M, CE EA
    51204033-010 FTA I/O CBL, 10M, CE MU-KFTS10 EA
    51204033-015 FTA I/O CBL, 15M, CE MU-KFTS15 EA
    51204033-020 FTA I/O CBL, 20M, CE MU-KFTS20 EA
    51204033-025 FTA I/O CBL, 25M, CE MU-KFTS25 EA
    51204033-030 FTA I/O CBL, 30M CE MU-KFTS30 EA
    51204033-035 FTA I/O CBL, 35M, CE MU-KFTS35 EA
    51204033-040 FTA I/O CBL, 40M, CE MU-KFTS40 EA
    51204033-050 FTA I/O CBL, 50M, CE MU-KFTS50 EA
    51204037-002 POWER CABLE 2M EA
    51204037-004 POWER_CABLE 4M EA
    51204037-005 POWER_CABLE 5M EA
    51204037-010 POWER_CABLE 10M EA
    51204037-015 POWER_CABLE 15M EA
    51204037-020 POWER_CABLE 20M EA
    51204037-025 POWER_CABLE 25M EA
    51204037-030 POWER_CABLE 30M EA
    51204037-035 POWER_CABLE 35M EA
    51204037-040 POWER_CABLE 40M EA
    51204037-050 POWER_CABLE 50M EA
    51204039-100 SHROUD, I/O LINK EA
    51204042-100 CBL, ASY 2 DROP EA
    51204042-200 CBL, ASY 3 DROP EA
    51204042-300 CBL, ASY 4 DROP EA
    51204042-400 CBL, ASY 5 DROP EA
    51204042-500 CBL, ASY 6 DROP EA
    51204043-100 ADAPTER KIT EA
    51204126-001 PM PWR CBL SET W/LINK PROTECT 1M EA
    51204126-002 PM PWR CBL SET W/LINK PROTECT 2M EA
    51204126-004 PM PWR CBLE SET W/LINK PROTECT 4M EA
    51204126-005 PM PWR CBL SET W/LINK PROTECT 5M EA
    51204126-006 PM PWR CBL SET W/LINK PROTECT 6M EA
    51204126-915 PM PWR CBL SET W/LINK PROTECT 1.5M EA
    51204127-100 PWR CBL LNK PTR EA
    51204132-100 BATTERY CABLE EA
    51204135-001 BATTERY HOLDER EA
    51204138-002 PM PWR CBL, EC EA
    51204140-100 PM PWR CBL ADAP SET (EC) EA
    51204154-125 FTA, DI 24VDC SCREW, CE EA
    51204154-175 FTA, DI 24VDC SCREW, CE, CC EA
    51204156-125 FTA, DO 24VDC SCREW, CE EA
    51204156-175 FTA, DO 24VDC SCREW, CE, CC EA
    51204160-125 FTA, DI 24VDC COMP, CE EA
    51204160-175 FTA, DI 24VDC COMP, CE, CC EA
    51204162-125 FTA, DO 24VDC COMP, CE EA
    51204162-175 FTA, DO 24VDC COMP, CE, CC EA
    51204164-125 HD FTA, DO RELAY SCREW, CE EA
    51204164-175 HD FTA, DO RELAY SCREW, CE, CC EA
    51204166-125 HD FTA, DO RELAY COMP, CE EA
    51204166-175 HD FTA, DO RELAY COMP, CE, CC EA
    51204168-100 HD FTA, HLAI/STI SCREW EA
    51204168-150 HD FTA, HLAI/STI SCREW, CC EA
    51204170-100 HD FTA, HLAI/STI COMP EA 51204170-200
    51204170-125 HD FTA, HLAI/STI COMP, CE EA
    51204170-150 HD FTA, HLAI/STI COMP, CC EA 51204170-250
    51204170-175 HD FTA, HLAI/STI COMP, CE, CC EA 51204170-275
    51204170-200 HD FTA, HLAI/STI COMP EA
    51204170-225 HD FTA, HLAI/STI COMP, CE EA
    51204170-250 HD FTA, HLAI/STI COMP, CC EA
    51204170-275 HD FTA, HLAI/STI COMP, CE, CC EA
    51204172-125 HD FTA, AO COMP W/STBY, CE EA
    51204172-175 HD FTA, AO COMP W/STBY, CE, CC EA
    51204174-125 HD FTA, AO SCREW W/STBY, CE EA
    51204174-175 HD FTA, AO SCREW W/STBY, CE, CC EA
    51204176-100 AI ADAPTOR ASM EA 80367163-001
    51204178-150 HPM HD I/O IOP EA 80363969-150
    51204180-100 DI IOP 24V EA 80363972-100
    51204182-150 DO IOP CC EA 80363975-150
    51204192-100 HEATER, 120 VAC EA
    51204192-200 HEATER, 240 VAC EA
    51206056-100 FILTER C/F EA
    51301239-100 PWB, LOGIC MUX TC EA
    51301256-100 LE MUX TERMINAL EA
    51301259-100 PWA, LE RTD LOGIC EA
    51301844-300 CABLE EA
    51301848-100 SIDE PANEL 7IN EA
    51301848-101 SIDE OR REAR PANEL EA
    51301850-007 DOOR-VENTED LH H EA
    51301850-100 CABINET DOOR LEFT HAND VENTED EA
    51301850-101 SOLID 24X77IN EA
    51301850-102 DOOR PANEL EA
    51301850-103 SOLID 24X70IN EA
    51301874-100 PWA, T/C MUS LOGIC EA
    51301877-100 PWA, RTD MUX LOGIC EA
    51301880-100 PWA, T/C MUX TERM EA
    51301882-100 PWA, RTD MUX TERM EA
    51301926-100 125V PWR SPLY EA
    51301994-100 POINT FILE EXTEN EA
    51302287-100 CABLE, TOUCHSCREEN I/F EA
    51302297-100 CABLE, TOUCHSCREEN INTERCONNECT EA
    51302362-200 MODIFIED P-XID21 PWA EA
    51302371-100 FM IS LABEL EA
    51302371-101 FM IS LABEL EA
    51302390-100 HL I/O BUS INTEG EA
    51302607-100 PWA, MUX RTD LOGIC EA
    51302608-100 PWA, MUX T/C LOGIC EA
    51302804-100 PLATE, TOP COVER EA
    51303000-100 F/6 NEMA BOX EA
    51303005-101 NEMA BOX, NO CERTIFICATION EA
    51303005-105 NEMA BOX EA
    51303005-106 LE NEMA BOX EA
    51303005-108 ENCL, NEMA BOX EA
    51303005-109 ENCL,NEMA BOX EA
    51303005-115 BOX,MUX STAINLES EA
    51303099-200 LBL RETROFIT R320B EA
    51303294-100 POWER SUP CONTL EA
    51303378-116 WARNING LABEL EA
    51303402-122 KEYBOARD CABLE EA 51303409-122
    51303402-305 FLOPPY DISC CABLE EA
    51303404-056 FLOPPY AC PWR CA EA
    51303406-002 CABLE SET 2M EA 51308111-002
    51303406-003 CABLE, CRT COAX EA 51308111-003
    51303407-305 FLOPPY DISC CABLE EA
    51303409-089 WREN II CABLE EA
    51303409-099 WREN II CABLE EA 51303409-089
    51303409-122 KEYBOARD CABLE EA
    51303409-305 KEYBOARD CABLE EA
    51303410-007 PER INTFC CONT V EA
    51303411-077 FLOPPY DC PWR CA EA
    51303412-132 WREN #1 DATA CBL EA 51303412-190
    51303412-190 WREN DATA CABLE EA
    51303413-015 TOUCH SCR CABLE EA
    51303413-150 K/B T/S CABLE EA
    51303414-016 ENG KY CABLE EA
    51303415-010 KYBD CLICKER CBL EA
    51303416-010 KYBD ALARM CABLE EA
    51303417-092 KEYLOCK ASSEMBLY EA
    51303419-152 KB INTFC DC PWR EA
    51303420-061 CBL, MOD STATUS EA 51303420-561
    51303420-081 CBL, MOD STATUS EA 51303420-581
    51303420-086 CBL, MOD STATUS EA 51303420-586
    51303420-122 MOD STATUS CABLE EA 51303420-622
    51303420-152 Module Status CB EA
    51303420-561 CBL, MOD STATUS EA
    51303420-581 MOD STATUS CBL EA
    51303420-586 CBL, MOD STATS EA
    51303420-622 CBL, MOD STATS EA
    51303420-652 MOD STATUS CABLE EA
    51303421-092 125V AC CORD,3FT EA
    51303421-152 125V AC CORD,5FT EA
    51303421-153 AC 125V PWR CORD EA
    51303421-183 125V AC CORD,6FT EA
    51303422-088 DUAL FLOPPY DC P EA
    51303423-087 DUAL FLOPPY AC P EA
    51303497-100 KYBD TMPLTE SET EA
    51303501-100 ANGLE BRACKET EA
    51303508-100 AC POWER CORD FOR NON-EC P/S EA
    51303508-200 PWR CORD, 220V USED ON NON EC P/S EA
    51303509-100 COVER, KYBD HNGE EA
    51303513-300 WINDOW, VERTICAL EA
    51303513-400 WINDOW, HORIZNTL EA
    51303521-300 AIR DUCT BAFFLE EA
    51303521-400 AIR DUCT BAFFLE EA
    51303526-200 RETAINER, W/INSERTS EA
    51303534-103 WINC COMMD CABLE EA
    51303534-190 COMMAND CABLE EA
    51303535-080 WREN II DATA CBL EA
    51303535-097 WREN II DATA CBL EA
    51303535-190 USE -080 OR -097 EA
    51303536-061 WIN DPWR CABLE EA
    51303549-100 FAN POWER CABLE EA
    51303625-019 CABLE,WINC,19CM EA
    51303628-134 COMMAND CABLE EA
    51303628-190 WINCHESTER COMM EA
    51303628-305 WIN CMD CABLE EA
    51303628-762 CABLE, FL DISC EA
    51303629-092 250V POWER CORD EA
    51303629-152 220V FLOPPY AC CBL 5FT EA
    51303629-183 POWER CORD EA 51303629-152
    51303630-305 FLOPPY DISK CABL EA
    51303631-003 CABLE LCN PTR 3M EA
    51303631-005 CABLE LCN PTR 5M EA
    51303631-008 Cable, LCN Printer 8m EA
    51303631-010 CABLE LCN PTR 10M EA
    51303631-015 CABLE LCN PTR 15M EA
    51303632-031 SW AC CABLE EA
    51303633-022 PWR TREND CBL EA
    51303635-061 PWR STATUS CBL EA
    51303636-304 TREND I/F CABLE EA
    51303639-100 VIDEO ADAPTOR AS EA
    51303641-044 TREND DC CABLE EA
    51303642-100 ANNUNCIATOR PAN EA
    51303642-200 ANNUNCIATOR T/B EA 51303642-400
    51303642-300 ANNUNC, Z-FURN EA
    51303642-400 ANNUNCIATOR T/B EA
    51303642-500 ANNUNCIATOR TB ASSM EA
    51303642-600 ANN CTR W/CBL EA
    51303642-700 ANNUNCIATOR ASSM EA
    51303646-100 BLANK KYBD BEZEL EA
    51303646-300 KYBD BEZEL, NEW EA
    51303650-100 CHANNEL SUPPORT EA
    51303651-100 FRONT PLATE EA
    51303654-092 110V AC CBL 3FT EA
    51303654-304 110V TREND CABLE EA
    51303657-100 BEZEL ASSY,LOWER EA
    51303657-200 BEZEL ASM CNSTS EA
    51303657-300 BEZEL TOP EA
    51303657-400 BEZEL WINDOW ASSM EA
    51303657-500 BEZEL ASSM, 520/300 0 EA
    51303657-600 BEZEL WINDOW ASY EA
    51303657-700 LOWER BEZEL ASM EA
    51303657-800 UPPER BEZEL ASSY EA
    51303658-100 Front Plate Mtg Brkt, Left EA
    51303658-200 Front Plate Mtg Brkt, Right EA
    51303659-100 FLOPPY BLANK PAN EA
    51303661-003 LCN CABLE, 3M EA 51308112-003
    51303661-008 LCN CABLE, 8M EA 51308112-008
    51303661-015 LCN CABLE, 15M EA 51308112-015
    51303661-050 LCN CABLE, 50M EA 51308112-050
    51303661-100 LCN CABLE, 100M EA 51308112-100
    51303661-200 LCN CABLE, 200M EA 51308112-200
    51303663-100 CRT SUPPORT EA
    51303663-200 CRT SUPPORT EA
    51303664-100 REMOTE SW MT BKT EA
    51303672-100 COMPLEX STR PL EA
    51303782-100 POWER ENTRY MTG PLA TE EA
    51303790-010 COMPUTER DATA CABLE EA
    51303790-015 COMPUTER DATA CABLE EA
    51303791-006 CABLE,REDUN REQ EA
    51303793-015 CABLE EA
    51303793-020 CABLE,GRANT/REQ EA
    51303793-025 CABLE,GRANT/REQ EA
    51303794-100 CRT SHROUD COVER EA
    51303794-200 CRT SHROUD COVER EA
    51303799-100 PWR CORD 7.5FT EA
    51303799-300 PWR CORD 3.5FT EA
    51303800-100 NAMEPLATE, TDC3000 EA
    51303816-100 PTR EXT CORD EA
    51303816-200 PTR EXT CORD EA
    51303817-200 UP/HINGE R/DOOR EA
    51303818-100 LOW/HINGE L/DOOR EA
    51303818-200 LOW/HINGE R/DOOR EA
    51303849-100 BRACKET, FDD MTG EA
    51303849-200 BRACKET, FDD MTG EA
    51303863-100 OP STN PANEL EA
    51303880-100 TREND I/F CABLE EA
    51303888-100 PWB, PC I/F EA
    51303893-200 CABLE, PC IF 50' EA
    51303893-300 CB PCSI TO PC 12FT EA
    51303903-100 TERMINAL PANEL P-TCB60 EA
    51303905-001 SUPPORT PAN ASSY EA
    51303905-002 SUPPORT PAN ASSY EA
    51303906-001 MOUNTING PLATE EA
    51303907-001 MOUNTING BRACKET EA
    51303909-001 BUS BAR DIVIDER EA
    51303911-001 BRACKET, LOCKING EA
    51303912-001 CABINET BASE EA
    51303925-100 PANEL SUPT BRKT EA
    51303926-100 FRONT PANEL ASM EA
    51303928-100 FTA, D/I 24VDC MU-TDID72 EA
    51303928-150 FTA,D/O 24VDC CC EA
    51303930-100 FTA, D/I (32) MU-TDIA72 EA
    51303930-150 FTA, 120VDI (CC) EA
    51303932-201 SER DEV I/F FTA EA 51303932-226
    51303932-202 SER DEV I/F FTA EA 51303932-227
    51303932-203 FTA, SD I/F UDC6 EA 51303932-228
    51303932-226 SER DEV I/F FTA MU-TSDT02 EA
    51303932-227 SER DEV I/F FTA MU-TSDM02 EA
    51303932-228 FTA, SD I/F UDC6 MU-TSDU02 EA
    51303932-251 FTA, SER I/F TOLEDO MC-TSDT02 EA 51303932-276
    51303932-252 FTA,SER DEV BASE EA 51303932-277
    51303932-253 FTA,SDI UDC6000 EA 51303932-278
    51303932-276 SD TOLEDO I/F CC MC-TSDT02 EA
    51303932-277 SD MANUAL I/F CC MC-TSDM02 EA
    51303932-278 SD UDC6000 IF CC MC-TSDU02 EA
    51303932-401 SERIAL I/F EA 51303932-426
    51303932-403 SERIAL I/F EA 51303932-428
    51303932-426 SERIAL INTERFACE FTA - MODBUS MU-TSIM12 EA
    51303932-428 SERIAL INTERFACE - ALLEN BRADLEY MU-TSIA12 EA
    51303932-451 Modbus FTA EA 51303932-476
    51303932-453 FTA,SDI-AB EC/CC EA 51303932-478
    51303933-100 MOUNTING PLATE AC/DC EA
    51303934-401 SI RS-232 (SPARE) EA 51303932-426
    51303934-403 SI RS-323 (SPARE) EA 51303932-428
    51303939-100 BATTERY TRIM PLATE EA
    51303940-100 FAN W/ALARM,115V EA
    51303940-150 FAN W/ALARM 120V EA
    51303940-200 FAN W/ALARM 240V EA
    51303940-250 FAN W/ALARM 240V EA
    51303948-100 48V BATTERY ASSM EA
    51303951-100 FTA,D/I SENS PWR EA 51304425-125
    51303953-100 MODULE, A/O FTA See Note Field EA
    51303959-100 MODULE, D/O FTA See Note Field EA
    51303968-100 CMOS BACKUP ASSY EA 51309206-175
    51303968-150 B/U PWB EA 51309206-175
    51303976-300 PM COMM MOD,R210 EA 51304685-300
    51303976-400 PM COMM MODULE EA 51304685-250
    51303979-300 PM,I/O LINK R300 EA 51303979-400
    51303979-400 I/O LINK INTERFACE EA 51303979-450
    51303979-450 I/O LINK R300 CC EA
    51303979-500 APM I/O LINK DRIVER EA 51303979-550
    51303979-550 APM I/O LINK DRIVER CC EA
    51303982-200 PM-CONTROL W/O DAUGHPWA EA
    51303982-300 PM CTLR CARD, R210/R230 REDUNDANT EA
    51303982-400 R300 PM CONTROLLER EA 51304518-250
    51303982-800 PM CONTROLLER EA 51304518-200
    51303982-900 PM CONTROLLER EA 51304518-200
    51303985-200 PWA, AO/IOP EA 51309152-175
    51303985-300 PWA, IO/IOP EA 51309152-175
    51303988-200 LLAI IOP ASSY EA 51304481-100
    51303988-300 LLAI IOP ASSY EA 51304481-100
    51303991-200 IOP, HLAI (CC) EA 51304754-150
    51303991-300 IOP, HLAI (CC) EA 51304754-150
    51303994-200 D/O IOP ASSM EA 51304487-100
    51303994-300 D/O IOP ASSM EA 51304487-100
    51303997-200 D/I IOP ASSM EA 51304485-100
    51303997-300 D/I IOP ASSY EA 51304485-100
    51304029-092 KEYLOCK SWITCH ASSM EA
    51304029-200 KEY/SWITCH CABLE EA 51304029-500
    51304029-500 KEYLOCK SWITCH ASSM. EA
    51304030-150 SMT FR DATA CBL EA
    51304030-300 SMT FR DATA CBL 300CM EA
    51304031-150 SMT FR PWR CBL EA
    51304031-183 SMT FR PWR CBL EA
    51304031-300 SMT FR PWR CBL EA
    51304032-003 K/B CABLE,SUPER EA
    51304033-045 MOUSE CABLE EA
    51304034-100 PANEL OVERLAY EA
    51304036-051 KEYBOARD I/F CBL UWS EA
    51304037-183 POWER CORD EA
    51304038-100 FLOPPY STAT CBL EA
    51304039-122 FLOPPY DC CM CBL EA
    51304040-101 FLOPPY COM CBL EA
    51304047-152 CBL, ANNUM, 22GU EA 51304047-652
    51304047-652 CBL, ANNUM, 22GU EA
    51304050-010 CABLE ASSY-10FT EA
    51304050-020 CABLE 20 FT EA
    51304050-100 CABLE ASSEMBLY EA
    51304051-100 WEDGE MTG PLATE P-ZKF55 EA
    51304053-200 FDD BRACKET EA
    51304063-100 FTA MTG RAIL EA
    51304069-100 BEZEL ASSEMBLY EA
    51304072-100 IOP CASE EA 51404092-400
    51304072-200 MOD CHASSIS ASSM EA 51404092-500
    51304074-100 PM CAB 120V FAN ASSM EA
    51304074-200 CAB AC FAN 240V 50H Z EA
    51304076-100 PWB, D/O STANDBY EA
    51304080-100 LLAI 8 MOD EA 51309280-100
    51304084-100 FTA, PULSE INPUT EA 51304084-125
    51304084-125 FTA, PULSE INPUT MU-TPIX12 COMP TERM. EA
    51304084-150 FTA, PUL INP CC EA 51304084-175
    51304084-175 FTA, PUL INP CC MC-TPIX12 EA
    51304084-200 FTA, PULSE INPUT EA 51304084-225
    51304084-225 FTA, PULSE INPUT SCR TERM EA
    51304084-275 FTA, PUL INP CC MC-TPIX52 EA
    51304085-100 LLAI-8 MOD, EC EA 51309280-100
    51304085-150 LLAI MODULE CC EA 51309280-100
    51304086-100 VERTICAL TRIM PANEL CC EA
    51304086-200 VERTICAL TRIM PANEL EA
    51304086-300 VERTICAL TRIM PANEL EA
    51304086-400 VERTICAL TRIM PANEL EA
    51304086-500 TRIM PNL LEFT SIDE EA
    51304086-600 TRIM PNL RIGHT SIDE EA
    51304086-700 TRIM PNL CENTER EA
    51304095-100 FTA, D/O STNDBY OBSOLETE SEE NOTE FIELD EA
    51304095-200 D/O STDBY W/CASE See note field EA
    51304096-100 FTA, D/O STNDBY See note field EA
    51304098-200 COVER, FAN PM EA
    51304154-100 PWA, PLC(
    培训)G RELAY EA 51304421-200
    51304156-100 PWB, SPC I/O EA
    51304159-100 PWB, AM RED I/O EA
    51304159-200 AM RED I/O EA
    51304161-100 Fiber Optic Clock Xmtr EA
    51304161-200 Fiber Optic Clock Rcvr EA
    51304161-300 Fiber Optic Clock Xmtr EA
    51304161-400 Fiber Optic Clock Rcvr EA
    51304163-300 PM MODEM EA 51304493-150
    51304163-400 APM MODEM EA 51304493-250
    51304186-100 DC/DC CONVERTER EA
    51304188-102 CBL FIBER OPTIC EA 51308113-102
    51304188-202 CABLE,FBR OPT CL EA
    51304190-200 PM JUMPER CARD EA
    51304190-300 APM JUMPER CARD EA
    51304191-100 SGL WIN INT CBL EA
    51304191-200 CABLE,WREN 3 SGL EA
    51304191-300 SGL WINCHESTER INTF CBL EA
    51304192-100 WREN DATA CABLE EA
    51304193-100 WREN DATA CABLE EA
    51304194-100 WREN DATA CABLE EA
    51304197-100 AM I/F CABLE EA
    51304197-200 CABLE AM/TPDG/WSI EA
    51304198-100 AM REDUN CABLE EA
    51304199-100 CABLE, I/F EA 51304199-201
    51304199-200 CABLE, I/F EA 51304199-201
    51304199-201 CABLE, I/F EA
    51304199-300 CABLE, I/F EA
    51304203-100 P.S. MTG BRACKET EA
    51304207-100 PWB, PAE LOGIC EA
    51304208-100 MOUNTING PANEL EA
    51304209-100 FAN MTG, BRACKET EA
    51304211-100 SNGL DC FW/C CBL EA
    51304212-100 FILTER RETAINER EA
    51304217-100 DC-DC CONV ASSY EA
    51304218-100 CABLE ADAPTOR EA
    51304219-100 FTA, D/I 240VAC See note field EA
    51304255-100 MOUNTING BRACKET EA
    51304260-200 FLR PNL (BEIGE) EA 51309228-300
    51304260-300 PMM FILLER PLATE EA 51309228-200
    51304260-400 PM FILLER PLATE EA 51309228-200
    51304270-100 PWB, EPDGP I/O EA 51304584-100
    51304272-100 CABLE, D TO DIN EA
    51304279-150 KYBD POWER CABLE EA
    51304279-300 CBL, KYBD 300CM EA
    51304281-200 ST I/F IOP ASSM EA 51304516-100
    51304281-300 ST I/F IOP ASSM EA 51304516-100
    51304283-100 PWB, HTD LOGIC EA
    51304286-100 PWB, PRECISION CLOCK SOURCE REPEATER (PCSR) EA
    51304286-200 PRECISION CLOCK EA
    51304290-100 CLOCK CABLE EA
    51304315-100 CABINET SPACER EA
    51304335-100 AO FTA RED. COMP EA 51304335-125
    51304335-125 AO FTA RED. COMP MU-TAOX12 EA
    51304335-150 FTA, A/O RED CC EA 51304335-175
    51304335-175 FTA, A/O RED CC MC-TAOX12 EA
    51304335-200 AO FTA RED. SCRE EA 51304335-225
    51304335-225 AO FTA RED. SCREW MU-TAOX52 EA
    51304335-250 A/O RED W/SCREW EA 51304335-275
    51304335-275 A/O RED W/SCREW MC-TAOX52 EA
    51304337-100 FTA, HL/AI MU-TAIH12 COMP TERM. RED. EA
    51304337-150 FTA,HLAI RED CC MC-TAIH12 EA
    51304337-200 FTA, HLAI/STI MU-TAIH52 SCR TERM. EA
    51304337-250 FTA, HLAI-ST CC MC-TAIH52 EA
    51304338-100 A/O REDUNDANCY MODULE EA
    51304342-100 FORKLIFT BASE, DUAL EA
    51304349-100 FORKLIFT BASE, SGL EA
    51304357-036 ENG KBD CBL,36CM EA
    51304360-100 19IN ENH MONITOR EA
    51304362-100 LLAI MUX IOP MU-PLAM02 EA
    51304362-150 IOP, LLAI CC MC-PLAM02 EA
    51304362-200 IOP,SER DEV I/F MU-PSDX02 EA
    51304362-250 IOP, SER DEV CC MC-PSDX02 EA
    51304362-300 IOP, SERIAL I/F MU-PSIM11 EA
    51304362-350 IOP, SER I/F CC MC-PSIM11 EA
    51304366-002 PIX PER DAT CBL EA
    51304366-003 CRT I/F CABLE EA
    51304367-006 T/S CABLE, 6FT EA
    51304374-100 ENH CRT PWR CORD EA
    51304374-200 CBL,RTS CRT 230V EA
    51304379-100 DUAL WREN CABLE EA
    51304386-100 PULSE INPUT IOP MU-PPIX02 EA
    51304386-150 IOP,PULSE INP CC MC-PPIX02 EA
    51304392-100 CABLE, DISK PWR EA
    51304392-200 CABLE, DISK PWR EA
    51304392-300 CABLE, DISK PWR EA
    51304396-100 CARTRIDGE DISK I/F CABLE NON-EC EA
    51304396-200 CARTRIDGE DISK I/F CABLE NON-EC EA
    51304398-100 DISK MTG BRKT-LH EA
    51304398-200 DISK MTG BRKT-RH EA
    51304399-100 CABLE, UWS MONITOR 15 PIN TO 9 PIN EA 51304399-200
    51304399-200 UWS CRT CABLE 14IN EA
    51304408-100 FTA, 120/240VAC SS D/O COMP EA 51304648-175
    51304408-200 FTA, 120/240VAC SS D/O SCREW, CE EA 51304648-225
    51304419-100 FIBER OPTIC IOP EA
    51304419-150 FIBER OPTIC IOP CC EA
    51304421-100 PWA, PLC(
    培训)G RELAY NON-CE EA 51304421-200
    51304421-200 PWA, PLC(
    培训)G RELAY EA
    51304423-100 FTA, 3/30VDC D/O COMP EA 51304650-100
    51304423-200 FTA, 3/30VDC D/O SCREW EA 51304650-200
    51304425-100 PWR DIST 24VDC EA 51304425-125
    51304425-125 PWR DIST 24VDC MU-TDPR02 EA
    51304425-150 DI 24VDC PWR DST EA 51304425-175
    51304425-175 DI 24VDC PWR DST MC-TDPR02 EA
    51304426-300 FTA, 120V RELAY DO COMP EA 51309148-125
    51304427-100 FTA, 240V RELAY DO COMP EA 51309150-125
    51304427-200 FTA, 240V RELAY DO SCREW EA 51309150-225
    51304428-100 FTA, 31/200VDC DO COMP EA 51309154-175
    51304428-150 FTA, 31/200VDC DO COMP EA 51309154-175
    51304428-200 FTA, 31/200VDC DO SCREW TERM EA 51309154-225
    51304428-250 FTA, 31/200VDC DO COMP EA 51309154-175
    51304431-100 FTA, D/I 240VAC COMPRESSED TERM EA 51304431-125
    51304431-125 FTA, DI 240VAC COMPRESSED TERM MU-TDIA22 EA
    51304431-150 FTA, 240VDI (CC) EA 51304431-175
    51304431-175 FTA, D/I 240V CC MC-TDIA22 EA
    51304431-200 FTA, D/I 240VAC ISOLATED SCREW TERM EA 51304431-225
    51304431-225 FTA, D/I 240VAC ISOL SCREW TERM MU-TDIA62 EA
    51304431-250 FTA, 240VDI (CC) EA 51304431-275
    51304431-275 FTA, D/I 240V CC MC-TDIA62 EA
    51304437-100 FTA, LLAI MU-TAIL02 EA
    51304437-150 FTA, LLAI CC MC-TAIL02 EA
    51304439-100 DI FTA 120 VAC COMPRESSION TERM EA 51304439-125
    51304439-125 DI FTA 120 VAC MU-TDIA12 EA
    51304439-150 FTA, D/I 120V CC EA 51304439-175
    51304439-175 FTA, D/I 120V CC MC-TDIA12 EA
    51304439-200 FTA, D/I EA 51304439-225
    51304439-225 DI 120VAC SCREW FTA MU-TDIA52 EA
    51304439-250 FTA, 120VDI (CC) EA 51304439-275
    51304439-275 FTA, D/I 120V CC MC-TDIA52 EA
    51304441-100 FTA, D/I 24VDC COMP TERM EA 51304441-125
    51304441-125 FTA, D/I 24VDC MU-TDID12 EA
    51304441-150 FTA,D/I 24VDC CC EA 51304441-175
    51304441-175 FTA,D/I 24VDC CC MC-TDID12 EA
    51304441-200 DI FTA 24VDC SCREW TERM EA 51304441-225
    51304441-225 DI 24VDC FTA SCREW MU-TDID52 EA
    51304441-250 FTA,DIG INPUT 24VDC EA 51304441-275
    51304441-275 FTA,DIG INPUT 24VDC MC-TDID52 EA
    51304443-100 FTA, DO 120VAC EC COMP TERM EA 51309148-125
    51304443-150 DO 120 VAC RELAY FTA EA 51309148-175
    51304443-200 FTA, 120V RELAY DO SCREW TERM EA 51309148-225
    51304446-100 FTA, D/O NON-ISOL 24VDC COMP TERM MU-TDON12 EA
    51304446-150 FTA,D/O NON-ISOL 24VDC COMP CC MC-TDON12 EA
    51304446-200 FTA, D/O NON ISOL 24VDC SC TERM MU-TDON52 EA
    51304446-250 FTA D/O NON ISOL 24VDC SC TERM CC MC-TDON52 EA
    51304449-100 CRT ASSY,NON EC EA 51304449-500
    51304449-200 19IN ENH MONITOR EA 51304449-300
    51304449-300 19IN ENH MONITOR EA 51304449-500
    51304449-400 19IN ENH MONITOR EA 51304449-500
    51304449-500 INTECOLOR CRT EA
    51304451-100 DO STANDBY MANUAL P WA EA
    51304453-100 FTA, HLAI/STI COMP TERM MU-TAIH02 EA
    51304453-150 FTA,HLAI/STI COMP TERM CC MC-TAIH02 EA
    51304456-100 MONITOR 14IN EA 51196793-100
    51304465-000 POWER CABLE (ORDER INDV. LENGTH) EA
    51304467-100 FTA, LLMUX/SDI/SI PWR ADAPTER EA 51309204-175
    51304467-150 FTA, LLMUX/SDI/SI PWR ADAPTER EA 51309204-175
    51304472-100 PWA, NGI I/O EA
    51304476-100 FTA, A/O COMPR TERM EA 51304476-175
    51304476-125 A/O FTA, COMP CE MU-TAOX02 EA
    51304476-150 FTA, A/O EA 51304476-175
    51304476-175 FTA, A/O CCCE MC-TAOX02 EA
    51304477-100 LLAI RTD MUX FTA EA 51309218-125
    51304477-150 FTA,LLAI MUX RTD EA 51309218-175
    51304478-100 FTA,LLAI MUX TC (SEE NOTES) EA
    51304481-100 LLAI IOP ASSM MU-PAIL02 EA
    51304481-150 LLAI IOP ASSM CC MC-PAIL02 EA
    51304483-100 PWA, AO/IOP EA 51309152-175
    51304485-100 D/I IOP ASSM MU-PDIX02 EA
    51304485-150 DI IOP, COATED, PWA EA
    51304487-100 D/O IOP ASSM MU-PDOX02 EA
    51304487-150 DO IOP, COATED, PWA EA
    51304489-100 IOP, HLAI EA 51304754-150
    51304490-100 DC POWER CABLE EA 51304769-103
    51304490-300 DC POWER CABLE EA 51304769-303
    51304493-100 PM MODEM EA 51304493-150
    51304493-150 PM MODEM CC, R210/230/300 EA
    51304493-200 APM MODEM EA 51304493-250
    51304493-250 APM MODEM CC, R400 EA
    51304493-300 MODEM BOARD EA
    51304495-036 ENH. KB I/F CBL MICRO/UWS EA
    51304496-026 CBL, ENG KYBD EA
    51304497-051 UWS KYBD I/F CBL EA
    51304501-100 PM DRIVER (R300) EA 51304501-150
    51304501-150 PMM RED DRIVE PWB EA
    51304502-100 CABLE, TRACKBALL EA
    51304502-200 CABLE, TRACKBALL EA
    51304505-100 TWR TO TWR CBL 5FT EA
    51304505-200 CABLE,10M TOWER EA
    51304506-100 CBL,PTR ADPT 2M EA
    51304506-200 CBL,PTR ADPT 4M EA
    51304508-100 TP LCN CABLE EA
    51304511-100 PWA, NIM MODEM EA
    51304511-200 PWB, SM NIM/LCN EA
    51304514-100 RS232 CABLE 50FT EA 51308106-100
    51304516-100 PWA, ST I/F (MU-PSTX02) EA
    51304516-150 PWA, ST I/F, SMRT TRANSMITTER CC MC-PSTX02 EA
    51304516-200 PWA, MV ST I/F (MU-PSTX03) EA
    51304516-250 PWA, MV ST I/F, CC (MC-PSTX03) EA
    51304518-100 APM ADV CONTROLLER EA 51304518-150
    51304518-150 APM ADV CONTROLLER CC EA
    51304518-200 R300 PM CONTROLLER EA 51304518-250
    51304518-250 R300 CONTROLLER CC EA
    51304526-100 FTA, D/O STNDBY PHONE STYLE CONNECTION EA
    51304526-200 D/O STDBY W/CASE & CABLE W/PHN CONN MU-SMDC02 EA
    51304527-100 FTA, D/O STNDBY PHONE CONN MU-SMDX02 EA
    51304528-100 PWB, RAM/EDAC EA
    51304532-100 PWB, LD I/O EA
    51304532-150 PWB, LD I/O CC EA
    51304537-100 PWB, CNI I/O EA
    51304537-200 PWA, CNI I/O EC EA
    51304540-100 PWB, LCNE II EA
    51304540-200 LCN EXT 2 EA
    51304542-100 PWB,K2LCN A I/O (SEE NOTE FIELD) EA
    51304544-100 PWA, K2LCN B I/O (SEE NOTE FIELD) EA
    51304548-101 PTR PAPER TRAY EA
    51304584-100 PWB, EPDGP I/O EA
    51304584-200 PWB, EPDGP I/O EA
    51304584-300 EPDGP I/O Z FURN ONLY EA
    51304585-100 FAN PWR CABLE EA
    51304585-200 CBL, DC FAN EA 51304585-500
    51304585-300 DC FAN CABLE EA 51304585-600
    51304585-400 CBL, FAN POWER EA
    51304585-500 CBL, DC FAN EA
    51304585-600 CBL, DC FAN EA
    51304589-100 REMOTE SENSOR EA
    51304589-150 TC MUX REM SNSR EA
    51304632-100 TAP BRACKET/SCRW EA
    51304636-300 GI HLAI FTA, COMPRES EA 51304718-325
    51304638-100 FTA, A/O GI/IS COMP EA 51304638-175
    51304638-125 FTA, A/O GI/IS COMP. TERM CE MU-GAOX02 EA
    51304638-150 FTA, A/O GI/IS COMP, CC EA 51304638-175
    51304638-175 FTA, A/O GI/IS COMP, CE, CC MC-GAOX02 EA
    51304638-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304638-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304638-300 FTA, A/O GI/IS CRIMP TERM EA
    51304638-325 FTA, A/O GI/IS CRIMP, CE MU-GAOX72 EA
    51304638-350 FTA, A/O GI/IS CRIMP, CC EA 51304638-375
    51304638-375 FTA, A/O GI/IS CRIMP, CE, CC MC-GAOX72 EA
    51304638-500 FTA, RED A/O GI/IS COMP EA 51304638-575
    51304638-525 FTA, RED A/O GI/IS COMP TERM CE MU-GAOX12 EA
    51304638-550 FTA, RED A/O GI/IS COMP, CC EA 51304638-575
    51304638-575 FTA, RED A/O GI/IS COMP, CE, CC MC-GAOX12 EA
    51304638-600 GI FTA UNPOPULATED (PACE) EA 51304638-625
    51304638-625 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304638-650 A/O GALV FTA CC EA 51304638-675
    51304638-675 GALV FTA, UNPOPULATED (PACE ORDERS ONLY) EA
    51304638-700 FTA, RED A/O GI/IS CRIMP EA
    51304638-725 FTA, RED A/O GI/IS CRIMP, CE MU-GAOX82 EA
    51304638-750 FTA, RED A/O GI/IS CRIMP, CC EA 51304638-775
    51304638-775 FTA, RED A/O GI/IS CRIMP, CE, CC MC-GAOX82 EA
    51304640-100 FTA, 24VDC D/I GI/IS COMP EA 51304640-175
    51304640-125 FTA, 24VDC D/I GI/IS COMP, CE MU-GDID12 EA
    51304640-150 FTA, 24VDC D/I GI/IS COMP, CC EA 51304640-175
    51304640-175 FTA, 24VDC D/I GI/IS COMP, CE, CC MC-GDID12 EA
    51304640-200 GI FTA UNPOPULATED (PACE) EA 51304640-225
    51304640-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304640-250 GI FTA UNPOPULATED (PACE) EA 51304640-275
    51304640-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304640-300 FTA, 24VDC D/I GI/IS CRIMP EA 51304640-325
    51304640-325 FTA, 24VDC D/I GI/IS CRIMP, CE MU-GDID82 EA
    51304640-375 FTA, 24VDC D/I GI/IS CRIMP, CE, CC MC-GDID82 EA
    51304642-100 FTA, 24VDC D/O GI/IS COMP EA 51304642-175
    51304642-125 FTA, 24VDC D/O GI/IS COMP, CE MU-GDOD12 EA
    51304642-175 FTA, 24VDC D/O GI/IS COMP, CE, CC MC-GDOD12 EA
    51304642-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304642-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304642-300 FTA, 24VDC D/O GI/IS CRIMP EA 51304642-325
    51304642-325 FTA, 24VDC D/O GI/IS CRIMP, CE MU-GDOD82 EA
    51304642-375 FTA, 24VDC D/O GI/IS CRIMP, CE, CC MC-GDOD82 EA
    51304644-100 PWR DIST PANEL EA 51304644-125
    51304644-125 PWR DIST PANEL FTA, GI MU-GPRD02 EA
    51304644-175 PNL,GI PWR DIST MC-GPRD02 EA
    51304646-100 G/I PNL SCR TERM EA 51309156-125
    51304648-100 FTA, 120/240VAC SS D/O COMP EA 51304648-175
    51304648-125 FTA, 120/240VAC SS D/O COMP, CE EA
    51304648-150 FTA, 120/240VAC SS D/O COMP, CC EA 51304648-175
    51304648-175 FTA, 120/240VAC SS D/O COMP, CE, CC MC-TDOA13 EA
    51304648-200 FTA, 120/240VAC SS D/O SCREW EA 51304648-225
    51304648-225 FTA, 120/240VAC SS D/O SCREW, CE MU-TDOA53 EA
    51304648-275 FTA, 120/240VAC SS D/O SCREW, CE, CC EA
    51304650-100 FTA, 3/30VDC D/O COMP MU-TDOD13 EA
    51304650-150 FTA, 3/30VDC D/O COMP, CC MC-TDOD13 EA
    51304650-200 FTA, 3/30VDC D/O SCREW MU-TDOD53 EA
    51304650-250 FTA, 3/30VDC D/O SCREW, CC MC-TDOD53 EA
    51304672-100 A/O IOP EA 51309152-175
    51304672-150 PWA, AO/IOP EA 51309152-175
    51304673-100 SW ASM T/B LEFT EA 51304673-100A
    51304673-100A SW ASM T/B LEFT EA
    51304673-200 SW ASM T/B RIGHT EA 51304673-200A
    51304673-200A SW ASM T/B RIGHT EA
    51304685-100 APM ADV COMM (SEE NOTES) EA 51304685-150
    51304685-150 APM ADV COMM CC (SEE NOTES) EA
    51304685-200 R300 COMM PWA EA 51304685-250
    51304685-250 PM COMM R300(CC) SEE NOTES EA
    51304685-300 PM COMM MOD,R210 SEE NOTES EA
    51304690-100 RED DI SOE ASSM EA 51402625-125
    51304690-150 RED DI SOE ASSM EA 51402625-175
    51304692-200 BLANK OFF PLATE EA
    51304693-200 BLANK-OFF PLATE ASM EA
    51304695-100 CBL, WREN DC EA
    51304718-100 FTA, RED HLAI/STI GI/IS COMP EA 51304718-175
    51304718-125 FTA, RED HLAI/STI GI/IS COMP, CE MU-GAIH13 EA
    51304718-175 FTA, RED HLAI/STI GI/IS COMP, CE, CC EA
    51304718-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304718-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304718-300 FTA, RED HLAI/STI GI/IS CRIMP EA 51304718-325
    51304718-325 FTA, RED HLAI/STI GI/IS CRIMP, CE MU-GAIH83 EA
    51304718-375 FTA, RED HLAI/STI GI/IS CRIMP, CE, CC EA
    51304720-100 FILLER PLATE EA
    51304722-125 FTA, RH MUX GI/NI PWR ADAPTER, EC MU-TRPA01 EA
    51304722-175 FTA, RH MUX GI/NI PWR ADAPTER, EC, CC EA
    51304724-125 GI LLAI MUX POWER ADAPTER FTA MU-GRPA01 EA
    51304724-175 GI LLAI MUX PWR ADAPTER FTA CC MC-GRPA01 EA
    51304728-100 FTA, SS DI GI/IS COMP EA 51304728-125
    51304728-125 FTA, SS DI GI/IS COMP, CE MU-GDID13 EA
    51304728-150 FTA, SS DI GI/IS COMP, CC EA 51304728-175
    51304728-175 FTA, SS DI GI/IS COMP, CE, CC MC-GDID13 EA
    51304728-225 GI FTA, UNPOPULATED (PACE ORDERS ONLY) EA
    51304728-275 GI FTA, UNPOPULATED (PACE ORDERS ONLY) EA
    51304728-300 FTA, SS DI GI/IS CRIMP EA 51304728-325
    51304728-325 FTA, SS DI GI/IS CRIMP, CE MU-GDID83 EA
    51304728-375 FTA, SS DI GI/IS CRIMP, CE, CC MC-GDID83 EA
    51304730-100 FTA, RED HLAI/STI GI/IS COMP EA 51304730-125
    51304730-125 FTA, RED HLAI/STI GI/IS COMP, CE MU-GAIH14 EA
    51304730-175 FTA, RED HLAI/STI GI/IS COMP, CE, CC EA
    51304730-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304730-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304730-300 FTA, RED HLAI/STI GI/IS CRIMP EA 51304730-375
    51304730-325 FTA, RED HLAI/STI GI/IS CRIMP, CE EA
    51304730-375 FTA, RED HLAI/STI GI/IS CRIMP, CE, CC EA
    51304732-100 COMBINER PNL,LFD TO DI IOP EA 51304732-125
    51304732-125 DI/DO PANEL MU-GLFD02 EA
    51304732-150 LFD COMB PANEL EA 51304732-175
    51304732-175 LFD COMB PANEL EC/CC MC-GLFD02 EA
    51304736-100 FTA, DO GI/IS COMP EA 51304736-125
    51304736-125 FTA, DO GI/IS COMP,CE MU-GDOL12 EA
    51304736-175 FTA, DO GI/IS COMP, COATED, CE MC-GDOL12 EA
    51304736-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304736-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304736-300 FTA, DO GI/IS CRIMP EA 51304736-325
    51304736-325 FTA, DO GI/IS CRIMP,CE EA
    51304736-375 FTA, DO GI/IS CRIMP, COATED, CE MC-GDOL82 EA
    51304748-100 FTA, GAL HLAI AUX COMP EA 51304748-125
    51304748-125 FTA, GAL HLAI AUX COMP, CE MU-GAIH22 EA
    51304748-175 FTA, GAL HLAI AUX COMP, CE, CC MC-GAIH22 EA
    51304748-200 HLAI GI/IS FTA UNPOP(PACE) EA 51304748-225
    51304748-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304748-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA
    51304748-300 FTA, GAL HLAI AUX CRIMP EA 51304748-325
    51304748-325 FTA, GAL HLAI AUX CRIMP, CE MU-GAIH92 EA
    51304748-375 FTA, GAL HLAI AUX CRIMP, CE, CC MC-GAIH92 EA
    51304754-100 IOP, HLAI EA 51304754-150
    51304754-150 IOP, HLAI (CC) MC-PAIH03 EA
    51304768-200 CBL, C/D DC PWR EA 51304769-202
    51304769-100 CBL, DC POWER EA 51304769-102
    51304769-101 DC POWER CABLE EA 51304769-103
    51304769-102 CBL, C/D DC PWR EA
    51304769-103 CBL, C/D DC PWR EA
    51304769-201 CBL, C/D DC PWR EA 51304769-203
    51304769-202 CBL, C/D DC PWR EA
    51304769-203 CBL, C/D DC PWR EA
    51304769-300 C/D DC PWR CBL EA 51304769-302
    51304769-301 DC POWER CABLE EA 51304769-303
    51304769-302 CBL,C/D DC 10FT EA
    51304769-303 CBL, C/D DC PWR EA
    51304776-100 PWB, TP 485 I/O EA
    51304776-200 PWB, TP485 I/O EA
    51304776-300 PWA, TP485 I/O EA
    51304776-400 PWA, TR485 I/O EA
    51304780-100 AIR BAFFLE EA
    51304787-100 CABLE, I/F EA
    51304788-046 KYBD I/F CABLE EA
    51304789-100 I/O CARD I/F CBL EA
    51304791-100 WSI I/O ASSY EA
    51304794-100 CABLE, WDA POWER EA
    51304795-100 MTG BRACKET CONN EA
    51304797-100 PWB, DISPLAY GEN EA
    51304808-100 CABLE, WDA I/O EA
    51304808-200 CBL, WDA I/O EA
    51304812-100 PWB, EPLC(
    培训) I/O ADAPTER EA
    51304812-200 EPLC(
    培训)I I/O ADAPTR EA
    51304814-100 PWB, TREND I/O EA
    51304814-200 PWB, TREND I/O EA
    51304831-100 TPDG I/O EA
    51304833-100 CABLE, SCSI I/O EA
    51304836-100 HD/DAT PWR CBL EA
    51304837-100 HD DISK CABLE EA
    51304838-100 HD DISK PWR CBL EA
    51304839-100 HD DISK SIG CBL EA 51305070-100
    51304842-100 CART I/F CABLE EA
    51304842-200 C/D IF CBL X3000 EA
    51304850-100 DISC ADAPTOR PLATE EA
    51304854-100 CHANNEL SUPPORT EA
    51304854-200 CHANNEL SUPPORT EA
    51304871-100 CABLE, RULA SCSI EA
    51304871-300 RULA SCSI CABLE EA
    51304872-100 RULA CABLE EA
    51304875-100 SCSI ADP CBL 24IN EA
    51304875-200 SCSI ADAPT CBL 72IN EA
    51304875-300 SCSI,CBL EA
    51304877-300 CORD, PWR TREND EA
    51304878-200 TREND POWER CORD EA
    51304878-300 TREND AC PWR CBL 24 0V EA
    51304878-400 TREND PWR CABLE EA
    51304880-300 CABLE, PTR FERRI EA
    51304882-100 RIPPLE DETECTOR EA
    51304883-100 CONNECTOR BULKHEAD EA
    51304887-100 PRINTER I/C CBL EA
    51304888-100 CABLE, MOUSE EA
    51304889-100 CABLE, PTR I/F EA
    51304897-200 PLATE EA
    51304899-100 SMT LED PWB EA
    51304901-100 WDA PWA (A/C) EA
    51304903-100 WDA I/O MODULE EA
    51304903-200 WDI I/I EA
    51304904-100 FLEX CKT EA
    51304907-100 PWB, SPC II I/O EA
    51304907-200 SPC II I/O CARD EA
    51304913-100 PWA, HDDT I/O EA
    51304913-200 PWB, HDDT I/O EA
    51304917-100 SERIAL PORT CABLE EA
    51304918-100 CABLE, SCSI EA
    51304920-100 51304920-100 EA 51402176-100
    51304921-100 CBL, DRIVE PWR EA
    51304924-100 PWA, WSI I/O EA
    51304924-200 PWB, I/O I/F WORKSTATION EA
    51304947-100 WSI 2R I/O EA
    51304949-100 CABLE, SCSI EA
    51305069-100 CABLE, CONFIG EA
    51305070-100 CBL,SCSI W/O DAT EA
    51305070-101 CBL, SCSI EA
    51305070-102 CBL, SCSI EA
    51305070-103 SCSI CBL EA
    51305070-104 SCSI CBL 27IN EA
    51305070-200 CBL, SCSI W/DAT EA
    51305070-202 SCSI CBL EA
    51305072-100 PWB, XCVR I/O EA
    51305072-200 I/O CARD, K2LCN A EA
    51305072-300 I/O CARD, K2LCN B EA
    51305072-400 PWA, LCN I/O EA
    51305072-500 I/O CARD, K2LCN A EA
    51305072-600 I/O CARD, K2LCN B EA
    51305072-700 PWB, LCN I/O EA
    51305072-800 PWB, CLCN I/O EA
    51305072-900 PWB, CLCN I/O EA
    51305075-100 PWB, TPDGC I/O EA
    51305088-100 PWA, SPC3 I/O EA
    51305098-100 DIST BOX ASY EA
    51305187-100 CARDFILE TRACK EA
    51305282-100 FACE PLATE EA
    51305282-200 BLNK FACEPLATE EA
    51305293-100 FACE PLATE BLANK EA
    51305303-100 VGA_CABLE_TPS10D EA 51305382-100
    51305306-100 BRACKET PWR ENT EA
    51305309-100 IKBM-Z CONS EA
    51305313-100 MAU CABLE EA 51305380-100
    51305315-100 PARALLEL DATA CBLE FOR DOT MATRIX PRTR 2M EA
    51305315-200 PARALLEL DATA CBL FOR DOT MATRIX PRTR 3M EA 51305315-300
    51305315-300 PARALLEL DATA CBL FOR DOT MATRIX PRTR 4.5M EA
    51305317-100 PERIPH PWR CBL EA
    51305319-100 PWA, LCNP (W/BRACKET FOR NON-DELL PC INSTALL) EA 51402797-100
    51305325-100 BRACKET EA
    51305328-100 X-CEIVER CBL EA
    51305329-100 MOUNTING BRACKET EA
    51305334-100 COVER, MAU EA
    51305336-100 P/S RESET CBL EA
    51305339-100 ANNUNCIATOR CBL EA
    51305341-100 DRIVE DC PWR CBL EA
    51305342-100 DRIVE PWR CBL EA
    51305345-100 8MB LCPM MEM EA
    51305348-100 MAU ASSY EA
    51305366-100 WDA ENCL ASSM EA
    51305380-100 MAU CABLE EA
    51305382-100 VGA CABLE TPS10D EA
    51305384-100 AC POWER CABLE EA
    51305384-200 MONITOR PWR CBL EA 51308020-100
    51305386-100 T/S CONTROLLER BOX ASSM EA
    51305387-100 GUS TOUCHSCRN CABLE EA
    51305387-300 GUS T/S CBL 66IN EA
    51305388-100 ANN CTR CBL EA
    51305390-100 PWA, UCPU FOR BASIC CTLR EA
    51305390-200 PWA, UCPU W/DEP FOR BASIC CTLR EA
    51305390-300 PWA, UCPU FOR EXTENDED CTLR EA
    51305390-400 PWA, UCPU W/DIDEP FOR EXTENDED CTLR EA
    51305406-100 PWA, UCIO EA
    51305408-100 PWA, UDHI EA
    51305409-200 AC PWR CORD,115V EA
    51305409-500 AC POWER CABLE EA
    51305410-200 220 AC PWR CORD EA
    51305410-500 AC POWER CORD EA
    51305413-100 FIBER OPTIC FRONT PANEL EA
    51305418-100 OPR KYBD CABLE EA
    51305418-300 TPS100 OEP KBD CBL EA
    51305419-100 IKB MOUSE CABLE EA
    51305430-100 LCNP-4 W/O BRACKETS EA 51403282-200
    51305431-100 CABLE, GND EA
    51305444-100 WEDGE TOP EA
    51305444-105 FOAM INSULATOR EA
    51305444-400 FOAM ISOLATION EA
    51305444-403 FOAM ISOLATION EA
    51305444-500 ISOLATOR FOAM EA
    51305444-800 FOAM INSULATOR EA
    51305447-100 WEDGE ASSY EA
    51305447-200 WEDGE ASSY EA
    51305450-400 AC POWER CABLE EA
    51305450-500 AC PWR CORD EA
    51305450-600 PWR CBL, LWR CRT EA
    51305450-700 PWR CBL CRT EA
    51305450-800 PWR CBL CRT EA
    51305451-400 POWER CORD EA
    51305451-500 TPS100 POWER CORD EA
    51305458-100 FRONT PANEL EA
    51305459-100 GROUND STRAP EA
    51305464-100 EXT PER PWR CBL EA
    51305465-100 IKB EXTENDED CABLE EA
    51305467-100 EMC SHIELD EA
    51305469-800 TREND POWER CABLE EA
    51305474-100 GUS EXT. ANN. RELAY PWA EA
    51305478-100 RMT PRPH I/F ASM EA
    51305480-100 EMI DR BLNK ASSM EA
    51305482-102 2M 100BT YEL BOOT EA
    51305482-105 5M 100BT YEL BOOT EA
    51305482-110 10M 100BT YEL BOOT EA
    51305482-120 20M 100BT YEL BOOT EA
    51305482-150 50M 100BT YEL BOOT EA
    51305482-175 75M 100BT YEL BOOT EA
    51305482-199 99M 100BT YEL BOOT EA
    51305482-202 2M 100BT GRN BOOT EA
    51305482-205 5M 100BT GRN BOOT EA
    51305482-210 10M 100BT GRN BOOT EA
    51305482-220 20M 100BT GRN BOOT EA
    51305482-250 50M 100BT GRN BOOT EA
    51305482-275 75M 100BT GRN BOOT EA
    51305482-299 99M 100BT GRN BOOT EA
    51305482-502 CAT5 ScTP ETHERNET CABLE - 2M EA
    51305482-503 CAT5 ScTP ETHERNET CABLE 3M EA
    51305482-505 CAT5 ScTP ETHERNET CABLE 5M EA
    51305482-510 CAT5 ScTP ETHERNET CABLE - 10M EA
    51305482-520 CAT5 ScTP ETHERNET CABLE - 20M EA
    51305482-530 CAT5 ScTP ETHERNET CABLE - 30M EA
    51305482-550 CAT5 ScTP ETHERNET CABLE -50M EA
    51305482-599 CAT5 ScTP ETHERNET CABLE -99M EA
    51305483-100 MNTG BRK ZIP DRIVE EA
    51305489-600 EC/SHLDED PWR CORD 240VAC EA
    51305490-600 EC/SHLDED PWR CORD 120VAC EA
    51305492-100 GROUNDED TERMINATOR EA
    51305503-100 EMI DRIVE SHIELD EA
    51305508-100 PWA, XLCNE2 Multimode, Non-CE EA
    51305508-200 PWA, XLCNE2 Multimode, CE EA
    51305529-100 NON RESTRAINT BRACKET EA
    51305538-100 DESKSIDE CD SCSI CBL EA
    51305542-100 A/C POWER CORD EA
    51305543-200 A/C POWER CORD EA
    51305543-300 A/C POWER CORD EA
    51305544-200 POWER CORD EA
    51305544-300 POWER CORD EA
    51305547-100 RT ANGLE CASCADE CBL EA
    51305548-100 DC POWER CABLE EA
    51305554-100 Cable 50 FT/15.2M EA
    51305554-200 Cable 100FT/30.5M EA
    51305554-300 Cable 200FT/61M EA
    51305559-100 SCSI CABLE EA
    51305562-400 .5M 100BT BLK BOOT EA
    51305562-402 2M 100BT BLK BOOT EA
    51305562-405 5M 100BT BLK BOOT EA
    51305562-410 10M 100BT BLK BOOT EA
    51305562-420 20M 100BT BLK BOOT EA
    51305562-450 50M 100BT BLK BOOT EA
    51305562-475 75M 100BT BLK BOOT EA
    51305562-499 99M 100BT BLK BOOT EA
    51305564-100 PS/S CABLE W/FERRITES EA
    51305568-100 I/R WINDOW EA
    51305568-200 I/R WINDOW EA
    51305569-100 T/S CABLE(SONY) EA
    51305579-100 MON RESTRAINT BRKT EA
    51305585-100 CRT SHROUD SPACER EA
    51305587-100 GUS LOWER FRONT BEZEL ASSY EA
    51305588-100 LOWER FRONT BEZEL ASSM EA
    51305589-100 UPPER FRONT BEZEL ASSM EA
    51305590-100 FRONT BEZEL ASSY-OEP, W/FLR PNL OPNG EA
    51305591-100 2ND HARD DRIVE CABLE EA
    51305594-100 CABLE, T/S EXT. 5 FT EA
    51305704-100 TS IF CBL 6' EC EA
    51305722-001 Cable, Jumper 100 Micron 1M EA
    51305722-002 Cable, Jumper 100 Micron 2M EA
    51305723-001 Cable, Dual 62.5mic Fiber Optic Jumper, 1m EA
    51305723-002 Cable, Dual 62.5mic Fiber Optic Jumper, 2m EA
    51306152-400 SMT FRME CBL EA
    51306154-100 UPIU PWA ASSY EA
    51308003-100 C/F AIR FILTER EA 51206056-100
    51308012-100 PWB, PW DIST 120 EA
    51308014-100 PWR DIST PWB 240V EA
    51308015-100 BUMPER BRACKET EA
    51308019-100 AC PWR 120V,16IN CBL EA
    51308020-100 UPPER MONITOR PWR CABLE EA
    51308020-200 MONITOR AC POWER CABLE EA
    51308021-100 DIST BTP HARNS EA
    51308033-100 FLEXIBLE SPACER BTT M EA
    51308035-100 MANIFOLD BOARD EA
    51308036-100 FLEXIBLE SPACER - T OP EA
    51308037-100 TIE PLATE-ARC EA
    51308038-100 FLEXIBLE SPACER - I N LINE EA
    51308039-100 COVER MTG. BRACKET EA
    51308042-100 FACADE, NAMEPLATE EA
    51308046-100 ACCESS COVER BLANK EA
    51308047-100 CABLE, TOUCH SCR EA
    51308050-100 A/C DIST. BRACKET EA
    51308051-200 PS ENCL CBL EA
    51308052-200 PS ENC AC CBL EA
    51308053-100 CBL, PERF PS A/C EA 51308020-200
    51308054-100 AC P/E 120V CBL EA
    51308055-100 CBL, DRV DC PWR EA 51308055-200
    51308055-200 CBL, DRV DC PWR EA
    51308055-300 CBL, DRV DC PWR EA
    51308056-100 TIE PLATE - IN LINE EA
    51308058-100 KYBD I/F CBL EA
    51308058-200 KYBD I/F CBL EA
    51308059-100 MANIFOLD KB I/C CAB LE EA
    51308060-100 ENG KYBD I/F CBL EA
    51308061-100 UCN TAP BRACKET EA
    51308065-100 T/S CONTRL ASM EA
    51308067-100 AC PWR ENTRY CBL (2 40V) EA
    51308069-200 TREND PWR CBL 240V EA
    51308070-200 TREND PWR CABLE 120V EA
    51308072-100 BEZEL BLANK PLATE EA
    51308073-100 TRACKBALL I/C CBL EA
    51308075-100 DIST ASM,TREND EA
    51308076-200 CBL,TRND REC I/F EA
    51308076-400 CBL, TREND REC EA
    51308076-500 TREND REC I/F CABLE 15FT EA
    51308077-300 CBL, TR I/F JMPR EA
    51308077-301 CBL, TDR I/F EA
    51308077-600 TREND I/F JUMPER CABLE EA
    51308078-300 TREND JUMPER CABLE EA
    51308078-301 CBL, TP JMPR EA
    51308079-300 TREND REC JMPR EA
    51308079-301 TDR PWR JUMPER EA
    51308080-200 CBL, CART DR EA 51308080-500
    51308080-400 CBL, CART DR EA
    51308080-500 CBL, CART DR EA
    51308080-600 CBL, CART DR EA
    51308080-700 CRT/DAT DRVE CBL EA
    51308082-100 MOUSE I/C CBL EA
    51308083-200 CABLE, HD DRIVE EA
    51308084-200 HD W/DAT CABLE EA
    51308086-101 SAFETY BARRIER EA
    51308086-201 CF SAFETY BARRIER EA
    51308086-202 CF SAFETY BARRIER EA
    51308087-200 AC FAN POWER CABLE EA
    51308092-100 CBL, AC PWR EA
    51308092-200 P/S 120/220 EC EA
    51308092-300 PWR CBL EA
    51308092-400 CBL, PWR 36IN EA
    51308092-500 CBL,AC PWR 48IN EA
    51308092-600 CBL, AC PWR 72IN EA
    51308092-700 POWER CORD 120IN (EC) EA
    51308093-100 CBL, AC PWR 16IN EA 51308093-300
    51308093-200 CBL, AC PWR 24IN EA
    51308093-300 PWR CORD 120V EC 35" EA
    51308093-400 CBL, AC PWR 36IN (ORDER -300) EA
    51308093-500 CBL, AC PWR 48IN EA
    51308093-600 CBL, AC PWR 72IN EA
    51308093-700 CBL, AC PWR 120IN EA
    51308093-800 POWER CORD 92IN (EC) EA
    51308094-300 PWR CORD, 220V EA
    51308094-400 PWR CBL 36IN AC CLASSIC EA 51308094-300
    51308094-500 PWR 240V CBL CLASSIC FURN EA
    51308094-600 PWR CBL 220V 72IN CLASSIC FURN EA
    51308094-800 POWER CORD 92IN (EC) EA
    51308095-100 PWA, INTERFACE CABLE EA
    51308097-100 IKB TO T/S CBL EA
    51308097-200 CBL, T/S I/F EA
    51308098-100 CBL, TWR TO JWR EA
    51308098-101 CBL, TP485 T-5 EA
    51308098-200 CBL, TWR TO TWR EA
    51308098-201 CBL, TP485 T-T EA
    51308099-100 CBL,EPDGC/MO 30IN EA
    51308099-200 CBL,EPDGC/MO 36IN EA
    51308099-300 CBL,EPDGC/MO 48IN EA
    51308099-400 CBL,EPDGC/MO 21IN EA
    51308101-100 CBL, TPDGC I/F EA
    51308101-200 CBL, TPDGC I/F EA
    51308101-300 CBL, TPDGC I/F EA
    51308102-100 CBL, TPDGC I/F EA
    51308102-200 CBL, TPDGC I/F M/TB/TS EA
    51308102-300 CBL, TPDGC I/F M/TB/TS EA
    51308103-003 CBL, PTR (3M) EA
    51308103-008 CBL, PTR (8M) EA
    51308103-015 CBL, PTR (15M) EA
    51308104-100 CBL, LCN KEYBD EA
    51308105-100 CBL, KYBD I/F EA
    51308105-200 CBL, KYBD I/F EA
    51308105-400 K/B IC TO TPD EA
    51308106-100 RS232 CABLE 50FT EA
    51308107-100 ANNUNC. CABLE EA
    51308108-100 CABLE, DESKSIDE GUS ANNC. Y- EA
    51308109-100 CBL, CRTG DC EA
    51308109-300 DC PWR CBL 14IN EA
    51308110-100 CBL, CRTG DC PWR EA
    51308110-200 CBL, CRTG DC PWR EA
    51308111-002 LCN COAX CBL SET 2M EA
    51308111-003 CBL COAX SCT(3M) SEE NOTES EA
    51308112-003 LCN COAX CBL SET 3M EA
    51308112-005 LCN COAX CBL SET 5M EA
    51308112-008 LCN COAX CBL SET 8M EA
    51308112-010 LCN COAX CBL SET 10M EA
    51308112-015 LCN COAX CBL SET 15M EA
    51308112-020 LCN COAX CBL SET 20M EA
    51308112-025 LCN COAX CBL SET 25M EA
    51308112-030 LCN COAX CBL SET 30M EA
    51308112-050 LCN COAX CBL SET 50M EA
    51308112-060 LCN COAX CBL SET 60M EA
    51308112-075 LCN COAX CBL SET 75M EA
    51308112-080 LCN COAX CBL SET 80M EA
    51308112-100 LCN COAX CBL SET 100M EA
    51308112-125 LCN COAX CBL SET 125M EA
    51308112-150 LCN COAX CBL SET 150M EA
    51308112-200 LCN COAX CBL SET 200M EA
    51308112-250 LCN COAX CBL SET 250M EA
    51308112-300 LCN COAX CBL SET 300M EA
    51308113-102 CBL FIBER OPTIC EA
    51308114-100 TS I/F CBL EA
    51308115-100 CBL, T/S I/F EA
    51308117-100 CBL, P/S AC EA
    51308118-100 CBL, FAN DC PWR EA
    51308119-100 CBL, TPDDC I/O EA
    51308119-200 TP PGC I/O CBL EA
    51308120-002 CBL, ENH CRT EA
    51308120-003 CBL, CRT DATA EA
    51308121-100 DIST HARNESS EA
    51308123-100 CBL, SMART FRAME EA
    51308123-200 SMT FRAME CBL EA
    51308123-300 CBL, SMART FRAME EA
    51308123-400 SMART FRAME CABLE E C EA
    51308124-100 CBL, NI ADAPTER EA
    51308125-100 CBL, CART DR PWR EA
    51308126-100 CBL, KEYBD IF EA
    51308129-100 CBL, CART DR PWR EA 51308129-200
    51308129-200 SN CART DRV PWR CBL EA
    51308130-100 CBL, CD PWR EA
    51308132-100 RULA SCSI CBL EA
    51308132-200 RULA SCSI CBL EA
    51308132-300 RULA SCSI CBL EA
    51308133-100 RULA DC ADAPTER CAB LE EA
    51308134-100 DC TWR PR CBL EA
    51308135-100 RULA TRANSCVR CABLE EA
    51308136-100 RULA XCVR CBL EA
    51308137-200 RULA SCSI CBL EA
    51308138-100 AUI THINK CBL EC EA
    51309101-100 RHIO ASSM 1-7L EA
    51309101-200 RHIO ASSM 9-15 R EA
    51309101-300 RHIO ASSM W/O PS L MU-CBSS11 EA
    51309101-400 RHIO ASSM W/O PS R MU-CBSS12 EA
    51309101-500 RHIO ASSM 1-7 L 220V EA
    51309101-600 RHIO ASSM 1-15R 220V EA
    51309107-100 TRIM, HPM LF1-7 EA
    51309107-200 TRIM, HPM RT9-15 EA
    51309123-100 HPM FUSE PULLER EA
    51309136-125 FTA, 6IN HLAI, COMP CE MU-TAIH03 EA
    51309136-175 FTA, 6IN HLAI, CE, CC EA
    51309138-125 FTA, 12IN HLAI COMP, CE EA
    51309138-175 FTA, 12IN HLAI COMP, CE, CC EA
    51309138-225 FTA, 12IN HLAI SCREW, CE EA
    51309138-275 FTA, 12IN HLAI SCREW, CE, CC EA
    51309140-125 FTA, 6IN STI, CE MU-TSTX03 EA
    51309140-175 FTA, 6IN STI, CE, CC EA
    51309142-125 FTA, 12IN STI COMP, CE MU-TSTX13 EA
    51309142-175 FTA, 12IN STI COMP, CE, CC EA
    51309142-225 FTA, 12IN STI SCREW, CE EA
    51309142-275 FTA, 12IN STI SCREW, CE, CC EA
    51309148-125 FTA, 120V RELAY DO COMP, CE MU-TDOR12 EA
    51309148-175 FTA, 120V RELAY DO COMP, CE, CC EA
    51309148-225 FTA, 120V RELAY DO SCREW, CE EA
    51309148-275 FTA, 120V RELAY DO SCREW, CE, CC EA
    51309150-125 FTA, 240V RELAY DO COMP, CE EA
    51309150-175 FTA, 240V RELAY DO COMP, CE, CC EA
    51309150-225 FTA, 240V RELAY DO SCREW, CE EA
    51309150-275 FTA, 240V RELAY DO SCREW, CE, CC EA
    51309152-125 PWA, AO/IOP (EC)(CC) EA 51309152-175
    51309152-175 PWA, AO/IOP (EC)(CC) EA
    51309153-125 FTA, 3/30VDC DO COMP, CE EA
    51309153-175 FTA, 3/30VDC DO COMP, CE, CC EA
    51309153-225 FTA, 3/30VDC DO SCREW, CE EA
    51309153-275 FTA, 3/30VDC DO SCREW, CE, CC EA
    51309154-125 FTA, 31/200VDC DO COMP, CE EA
    51309154-175 FTA, 31/200VDC DO COMP, CE, CC EA
    51309154-225 FTA, 31/200VDC DO SCREW, CE EA
    51309154-275 FTA, 31/200VDC DO SCREW, CE, CC EA
    51309156-125 G/I PNL SCR TERM EA
    51309156-175 PNL,GI FTA MAR EA
    51309202-125 FTA MOTHERBOARD, LLAI-8 CE MU-TAIL03 EA
    51309202-175 FTA MOTHERBOARD, LLAI-8 CE, CC EA
    51309204-125 FTA, LLMUX/SDI/SI PWR ADAPTER EA
    51309204-175 FTA, LLMUX/SDI/SI PWR ADAPTER, CC EA
    51309206-125 CHARGER, UNIV PM EA
    51309206-175 CHGR, UNIV PM CC EA
    51309208-100 PWA, FIB OPT 5KM EA
    51309208-150 PWA, FIB OPT 5KM, CC EA
    51309210-125 LLMUX TC DAUGHTERBOARD EA 51309290-125
    51309210-175 LLMUX TC DAUGHTERBOARD, CC EA 51309290-175
    51309213-125 FTA, LLMUX TC W/RCJR, CE MU-TAMT13 EA
    51309213-175 FTA, LLMUX TC W/RCJR, CE, CC EA
    51309218-125 FTA, LLMUX RTD, CE MU-TAMR03 EA
    51309218-175 FTA, LLMUX RTD, EC, CC EA
    51309222-125 order 51309223-125 EA 51309223-125
    51309223-125 FTA, LLMUX TC, EC MU-TAMT03 EA
    51309223-175 FTA, LLMUX TC, EC, CC EA
    51309228-200 FLR PNL (GREY) EA
    51309228-300 FLR PNL (BEIGE) EA
    51309250-100 RH MUX NEMA4 SS MU-CMSS03 EA
    51309250-200 RH MUX NEMA4 SC MU-CMSC03 EA
    51309254-125 FIELDBUS I/F FTA, 4 Nets MU-TFBS01 EA
    51309254-125MOD MODIF FIELDBUS I/F FTA (INCL 2 PS MTL4053) EA
    51309254-175 FIELDBUS I/F FTA, 4 Nets EA
    51309254-225 GI/IS FBUS I/F FTA, 4 NETS MU-GFBS01 EA
    51309254-275 GI/IS FBUS I/F FTA, 4 nets MU-TFBS11 EA
    51309254-325 FIELDBUS I/F FTA, 4 Nets, No PWR Cond EA
    51309254-375 FIELDBUS I/F FTA, 4 Nets, No Pwr Cond EA
    51309266-100 MTG BRACKET UCNE EA
    51309276-150 HPM I/O LINK CC EA
    51309280-100 LLAI-8 MOD, EC EA
    51309290-125 LLMUX TC DAUGHTER EC EA
    51309290-175 LLMUX TC DAUGHTER EC CC EA
    51309335-100 HPM GRD CVR, EXTNDE R EA
    51309335-200 HPM GRD CVR, EXTNDE R EA
    51309510-125 FIELDBUS I/F Processor, 4 Nets EA 51309510-175
    51309510-175 FIELDBUS I/F PROCESSOR, 4 NETS CC MC-PFBS01 EA
    51309540-125 AO GI/IS FTA (16), HART EA
    51309540-175 AO GI/IS FTA (16), HART CC EA
    51309542-125 AO FTA (16), HART EA
    51309542-175 AO FTA (16), HART CC EA
    51309562-100 V-TRIM LEFT W/O BRKR EA
    51309562-200 V-TRIM RIGHT W/O BRK EA
    51309562-300 V-TRIM LEFT W/BREAKER BOX EA
    51309563-100 TOP TRIM W/O BRKR EA
    51309564-100 Trim Bottom W/Breaker EA
    51309564-200 TRIM BOTTOM W/BRKR EA
    51400373-100 PWR SUP SUPPORT EA
    51400441-102 P.S. ASSEMBLY EA
    51400621-100 SMALL FAN BRACKET EA
    51400646-100 FAN ASSY,5 SLOT EA
    51400647-100 FAN ASSY,10 SLOT EA
    51400647-200 FAN ASSY, MICRO EA
    51400666-100 PWA, PERIPH I/F EA
    51400667-100 PWB, ENH LCN EA 51401291-100
    51400670-100 10 SLOT POWER SUPPLY EA 51201436-400
    51400671-100 5 SLOT POWER SUPPLY EA 51201436-300
    51400700-100 PWA, DATA HIWAY I/F EA
    51400705-100 WHITE SHROUD W/HOLES EA
    51400705-200 WHITE SHROUD W/O HOLES EA
    51400705-300 BEIGE SHROUD W/HOLES EA
    51400705-400 BEIGE SHROUD W/O HOLES EA
    51400706-100 BLUE LOWER REAR COVER EA
    51400706-200 GRAY LOWER REAR COVER EA
    51400712-100 5 SLOT PWR SPLY EA 51201436-300
    51400712-200 10 SLOT POWER SUPPLY EA 51201436-400
    51400738-100 SUPPORT, TABLE TOP EA
    51400738-200 TABLE TOP SUPPORT EA
    51400751-100 LOW PROFILE ENG EA
    51400751-100REP LOW PROFILE ENG KYBD EA
    51400756-100 KYBD, ABCDE MEMBRANE FOR US, UWS AND MICRO EA
    51400759-100 KYBD INSERT,WHIT EA
    51400760-100 AC ENTRY 120V EA 51402618-120
    51400760-200 AC ENTRY 230V EA 51402618-230
    51400764-100 FAN ASSM,5 SLOT EA 51400646-100
    51400776-100 PWR ENTRY COVER EA
    51400777-100 CRT MT CHASSIS EA
    51400777-200 CRT MT CHASSIS EA
    51400779-100 MTG BRCKT, U/T EA
    51400781-100 U/CRT SHROUD, WHITE EA
    51400781-200 SHROUD UPPER PD EA
    51400782-100 REAR COVER U/T EA
    51400782-200 COVER, UPPER CRT EA
    51400783-100 ENG KYBD SUPPORT EA
    51400784-100 REPLACEMNT KBD TRAY/ NO HARDWARE EA
    51400785-100 BEZEL, UPPER CRT EA
    51400786-100 BEZEL, L/T CRT EA
    51400786-200 BEZEL, LOWER EA
    51400788-100 COVER, ENG KYBD WHITE EA
    51400788-200 COVER, ENG KYBD BEIGE EA
    51400788-300 COVER, ENG KYBD BLACK EA
    51400792-100 HALF-POD SHROUD EA
    51400792-200 HALF HEIGHT SHROUD EA
    51400793-100 HALF-POD R COVER EA
    51400793-200 HALF HEIGHT COVER EA
    51400794-100 MTG PLATE, FDD EA
    51400795-100 FDD FRONT PLATE EA
    51400797-100 HALF-POD BEZEL EA
    51400808-100 PWR ENTRY 120V EA 51402619-120
    51400808-200 PWR ENTRY 230V EA 51402619-230
    51400810-100 TABLE TOP FULL WHITE EA
    51400810-200 TABLE TOP FULL- BEI GE EA
    51400810-300 TABLE TOP FULL BLK EA
    51400812-100 TBL TOP SUPPORT EA
    51400813-100 TBL TOP SUPPORT EA
    51400816-100 FLOPPY TABLE TOP EA
    51400816-300 TABLE FLOPPY EA
    51400816-500 FLOPPY TABLE BLACK EA
    51400817-100 FLOPPY SUPPORT PLAT E EA
    51400819-100 REAR SKIRT, FLOPPY EA
    51400819-200 REAR FLOPPY SKIRT EA
    51400821-100 ENG KYBD ASSEMBLY EA
    51400822-100 TOUCH SCREEN EA 51400822-200
    51400822-200 19IN TOUCHSCREEN - OBSOLETE EA
    51400850-100 FLOPPY MTG BRACKET EA
    51400850-200 FLOPPY MTG BRACKET EA
    51400851-100 FLOPPY MTG SLIDE EA
    51400851-200 FLOPPY MTG SLIDE EA
    51400855-100 PWB, SIO (TREND) EA
    51400859-100 SLIDE CHASSIS EA
    51400860-100 HALF HEIGHT BRACKET EA
    51400860-200 HALF HEIGHT BRACKET EA
    51400862-200 HALF HGHT FRONT PNL EA
    51400863-200 FULL HGHT FNT PNL EA
    51400864-100 FULL HEIGHT BRACKET EA
    51400864-200 FULL HEIGHT BRACKET EA
    51400865-100 TR PWR I/F 120V EA
    51400865-400 TR PWR I/F 240V EA
    51400866-100 BEZEL, UPPER CRT EA
    51400867-100 CRT TRAY EA
    51400868-100 CRT PNL SUPPORT EA
    51400868-200 CRT PANEL SUPPOR EA
    51400869-100 BLANK PANEL EA
    51400870-100 BLANK HALF PANEL EA
    51400870-200 BLANK FULL PANEL EA
    51400891-200 REAR DOOR BEIGE EA
    51400892-100 FRONT SKIRT EA
    51400892-200 FRONT SKIRT EA
    51400893-100 CONSOLE SKIRT EA
    51400893-200 CONSOLE SKIRT EA
    51400901-100 PWB, EMPU CPU EA
    51400902-100 T-SCR VER-WINDOW EA
    51400902-200 T-SCR HOR-WINDOW EA
    51400902-300 BEZEL, VERTICAL EA
    51400902-400 BEZEL,HORIZONTAL EA
    51400902-500 VERTICAL BEZEL,SMT TCH SC EA
    51400902-600 HORIZONTAL BEZEL,SMT TCH SC EA
    51400910-100 PWB, EMEM 1MW EA
    51400918-100 5 SLOT MOD COVER EA
    51400919-100 10 SLOT COVER EA 51402620-100
    51400926-100 PWB, ENH PDG EA 51401286-100
    51400955-100 PWB, PNI EA
    51400958-001 CABINET FRAME WI EA
    51400972-100 PWB, KEYBD, I/F EA 51401570-100
    51400972-200 PWB, KYBD I/F EA 51401570-200
    51400972-300 PWB, KYBD I/F EA 51401570-100
    51400978-100 2MW HYPER KERNEL HMPU EA
    51400988-100 SMART TOUCHSCREEN EA 51400988-200
    51400988-200 TOUCHSCREEN (EC) EA
    51400989-100 OPER KYBD ASSY EA
    51400989-200 US OPER KYBD ASY EA
    51400989-300 KEYBOARD EA 51400989-400
    51400989-400 KEYBOARD EA
    51400989-500 ABC KYBD EC EA
    51400990-100 KEYBD, UNIV W.S. EA
    51400993-100 OPR KYBD W/INTF EA
    51400993-400 OPR KYBD W/INTFC EA
    51400997-100 PWA, PLC(
    培训)I EA
    51400997-200 PWA, ENH PLC(
    培训)I EA
    51401052-100 PWA, SPCI EA
    51401056-100 FILE & BPLANE EA
    51401070-100 PWB, AMC REDUND EA
    51401072-100 PWA, QMEM 1MW EA 51400910-100
    51401072-200 PWB, QMEM 2MW EA
    51401072-300 PWB, QMEM 3MW EA
    51401072-400 PWB, QMEM 4MW EA
    51401074-100 LCN FLOPPY TRAY EA
    51401074-200 MTG TRAY FLPY-EC CL EA
    51401088-100 PWB, CNI (See note field) EA
    51401107-100 FTA, LL A/I DIN EA 51198964-100
    51401135-100 PWB, REDUNDANT P/S 115V EA
    51401135-150 PWA, 115V RED EA
    51401135-200 PWB, P.S. 115VAC EA 51401135-250
    51401135-250 PWA, 115V NONRED EA
    51401135-300 P/S 240 8A RED EA
    51401135-350 PWA, 230V REDUNDANT EA
    51401135-400 PWB, 230 V NON-REDUNDANT EA
    51401135-450 PWA,230V, NONRED EA
    51401140-100 AC ONLY P/S-RED 115V16 AMP MU-PAS121 EA
    51401140-150 P/S N RED 115V 16AMP EA
    51401140-200 AC ONLY PS-RED 120V 16AMP EA
    51401140-250 P/S RED 115V 16AMP CC EA
    51401140-300 AC ONLY PS-SGL 240V 16AMP EA
    51401140-350 P/S N RED 230V 16AMP CC EA
    51401140-400 AC ONLY PS-RED 240V 16AMP EA
    51401140-450 P/S RED 230V 16AMP CC EA
    51401140-500 AC ONLY PS-SGL 120V 8AMP EA
    51401140-550 P/S N-RED 114V 8AMP EA
    51401140-600 AC ONLY PS-RED 120V 8AMP MU-PAR111 EA
    51401140-650 R/S RED 115V 8AMP EA
    51401140-700 AC ONLY PS-SGL 240V 8AMP EA
    51401140-750 P/S N RED 230V 8AMP EA
    51401140-800 AC ONLY PS-RED 240V 8AMP EA
    51401140-850 P/S RED 230V 8 AMP CC EA
    51401151-100 ENH TERM PANEL EA
    51401157-100 MODULE,D/O S.S. See note field EA
    51401163-100 PWA, NIM MODEM EA 51195760-100
    51401166-100 PWR SYSTEM BCKPN EA
    51401166-150 PS PWB ASSY EA
    51401168-200 PS CHASSIS ASSM EA 51404170-125
    51401183-100 FTA, LL A/I,DIN EA 51198964-100
    51401186-100 FTA,120VAC D/I See Note Field EA
    51401191-100 MODULE, D/O FTA See note field EA
    51401194-100 MOD, D/O FTA See note field EA
    51401201-100 MODULE,24VDC D/I See Note Field EA
    51401212-100 FTA, LL A/I,DIN EA 51198964-100
    51401214-100 CHASSIS, PWR SYS EA
    51401216-100 CHASSIS, PWR SYS EA
    51401216-150 POWER SYSTEM CAGE CC EA
    51401220-100 MODULE, D/O S.S. See note field. MU-TDOD11 EA
    51401223-100 MOD,SS D/O FTA See Note field EA
    51401233-100 BEZEL, PWR SPLY EA
    51401235-100 PWR SYS BACKPLANE EA
    51401238-100 PWR SYS TERM PNL EA
    51401246-100 FTA MTG CHANNEL, WIDE RITTAL EA
    51401246-200 FTA MTG CHANNEL, NARROW RITTAL EA
    51401248-200 BATTERY ASSM EA 51303948-100
    51401248-300 48V BATTERY ASSY EA 51303948-100
    51401277-100 A/O STANDBY ASSM MU-SMAC01 EA
    51401277-200 A/O ST-BY MANUAL MU-SMAC02 EA
    51401286-100 PWB, ENH PDG EA
    51401286-100EXCH PWA, Enh PDG (Repair/Exchange Only) EA
    51401288-100 PWA, HPK2-2MW EA
    51401288-200 PWA, HPK2-3MW EA
    51401289-100 ENCLOSURE MODIFIED EA
    51401291-100 PWB, ENH LCN EA
    51401291-100EXCH PWA, ENH LCN (REPAIR/EXCHANGE ONLY) EA
    51401303-100 HOOTER ASSY,115V EA 51401303-100A
    51401303-100A HOOTER ASSM, CLASSIC FURN, 115V RG-PHA01-100 EA
    51401303-200 HOOTER 220V EA 51401303-200A
    51401303-200A HOOTER ASSM, CLASSIC FURN, 230V RG-PHA01-200 EA
    51401303-300 Z HOOTER, 115V EA 51401303-300A
    51401303-300A HOOTER ASSM, Z FURN, 115V RG-PHA01-300 EA
    51401303-400 Z HOOTER,220V EA 51401303-400A
    51401303-400A HOOTER ASSM, Z FURN, 230V RG-PHA01-400 EA
    51401364-100 LLAI MUX MODULE EA 51309218-125
    51401370-200 FRONT DOOR BEIGE EA
    51401381-100 5 SLOT BACKPANEL EA
    51401414-100 2 SLOT BKPNL SUPPOR T EA
    51401436-101 KEYBOARD COVER EA
    51401436-200 KEYBOARD ENCLOSURE EA
    51401437-100 ENH UWS KYBD ASY EA
    51401437-300 ENH UWS KYBD ASY EA
    51401437-301 ENH UWS KYBD ASY EA
    51401437-400 ENH OP/KYBD ASSY EA
    51401449-100 CABLE, HARNESS EA
    51401457-100 OPERATOR KYBD ASSY INCL KYBD, PWA & CABLES EA
    51401469-100 KIT EA 51402184-100
    51401473-100 2 NODE FAN PWA EA
    51401477-100 3/2 BKPNL ASM EA
    51401484-100 BACKPANEL SUPPORT EA
    51401486-100 2-NODE MOD COVER EA
    51401491-100 FTA,LLAI TC MUX EA 51309223-125
    51401491-150 FTA,TC MUX (CC) EA 51309223-175
    51401496-100 FAN ASSM, 2 NODE EA
    51401497-100 KIT, D.N. P/S EA 51402184-100
    51401512-100 PM CAB DUAL ACCESS EA
    51401513-120 RITTAL SINGLE CAB EA
    51401523-100 SPARE FILE ASSM EA 51198949-150
    51401524-100 SPARE FILE ASSY EA 51198948-150
    51401525-100 SPARE FILE ASSM EA 51198950-150
    51401526-100 PS BEZEL LABEL EA
    51401529-100 FTA MTG CHANNEL, NARROW MARKHON EA
    51401529-200 FTA MTG CHANNEL, WIDE MARKHON EA
    51401531-100 PM FILE FAN ASSY EA
    51401546-100 15 SLOT I/O EA 51404127-200
    51401546-150 15 SLOT I/O CC EA 51404127-250
    51401547-100 SPARE FILE ASSY EA 51401617-150
    51401547-150 SPARE FILE ASSM EA 51401617-150
    51401548-100 SPARE FILE 5 SLOT EA 51401616-150
    51401551-200 PWA, K2LCN 2MW EA
    51401551-201 PWA, K2LCN 2MW EA
    51401551-300 PWA, K2LCN 3MW EA 51401551-301
    51401551-301 PWA, K2LCN 3MW EA
    51401551-400 PWA, K2LCN 4MW EA 51402615-400
    51401551-401 PWA, K2LCN 4MW EA 51402615-400
    51401551-600 PWA, K2LCN 6MW EA 51401551-601
    51401551-601 PWA, 6MW K2LCN EA
    51401551-800 PWA, K2LCN 8MW EA
    51401551-801 PWA, K2LCN 8MW EA 51402615-800
    51401560-100 KYBD,QWERTY MEMBRANE FOR US, UWS AND MICRO EA
    51401564-100 PWB,TC MUX DAUGH EA 51309223-125
    51401570-100 PWB, KYBD I/F EA
    51401570-200 PWB, KYBD I/F NO ANNUN LOGIC OR ALARM LEDS EA
    51401573-100 FTA, LLAI TC MUX EA 51309213-125
    51401573-150 FTA,TC MUX (CC) EA 51309213-175
    51401577-100 QWERTY KYBD KIT EA
    51401577-300 OPER KYBD ASM EA 51401577-500
    51401577-400 QWERTY KYB EA
    51401577-500 CLASSIC OPERATOR KEYBOARD EA
    51401577-600 OPER KYBD ASSM (PACE) EA
    51401583-100 PWB, EPNI EA
    51401583-200 PWB, NGI EA
    51401594-100 PWB, KJUMP(PCIM) EA
    51401594-200 PWB, KJUMP EA
    51401596-100 PLC(
    培训)G RLY MTG PLATE INCLUDES MTG BRACKETS EA
    51401596-200 PLC(
    培训)G RLY MTG PLATE DOES NOT INCLUDE BRACKETS EA
    51401604-100 BEIGE SGL CAB EA
    51401605-100 MARKHON DUAL CAB (BEIGE) EA
    51401605-102 DUAL ACCESS CAB (BL UE) EA
    51401616-100 CARD FILE 5 I/O EA 51401616-150
    51401616-150 5 IOP FILE (CC) EA
    51401617-100 PM/APM FILE 10 I/O EA 51401617-150
    51401617-150 FILE,PM 10SLT IO EA
    51401618-100 15 SLOT I/O EA 51404127-200
    51401618-150 FILE 15 I/O CC EA 51404127-250
    51401621-100 FTA CHAN HORIZ MU-TMHN01 EA
    51401635-100 COM/CONTROLLER EA 51401635-150
    51401635-150 HPM COM/CONTRLR EA
    51401639-100 UCN I/F EA 51402573-150
    51401639-150 HPM UCN I/F EA 51402573-150
    51401642-100 HPM I/O LINK EA 51309276-150
    51401642-150 HPM I/O LINK EA 51309276-150
    51401698-100 UxS KEYBOARD TRAY EA
    51401699-100 UxS TRAY SLIDE EA
    51401748-100 TRACKBALL ASSY EA
    51401748-200 USX TRACKBALL CONSOLE MOUNT EA
    51401748-300 TRACKBALL ASSY EA
    51401782-200 C/F 3/3/2/2 SPR EA 51196730-100
    51401913-100 MICRO TOUCHSCRN EA 51195992-100
    51401914-100 PWA, GGSI (R400) EA
    51401917-100 DRIVE TRAY EA
    51401929-300 SPARE WD TRAY EA
    51401930-100 WDA ENCL ASSM EA 51305366-100
    51401946-100 K4LCN Motherboard EA
    51401946-100EXCH K4LCN Motherboard (Repair/Exchange Only) EA
    51401952-100 OEP PWA EA
    51401952-200 KYBD I/F ASSY EA
    51401952-300 KEYBOARD ASSM FOR P ACE EA
    51401975-100 ENG KYBD, GRAY ROVING EA 51196712-200
    51401979-100 KYBD TEMPLATE (QTY 1) EA
    51401996-100 EARM ASSY EA
    51402000-200 TPDG ASSY EA
    51402004-100 HALF HGT REAR CVR BIG EA
    51402004-200 HALF HGT REAR CVR BIG EA
    51402005-100 FULL HGT REAR CVR BIG EA
    51402005-200 FULL HGT REAR CVR BIG EA
    51402023-100 PWR I/F CHS,120V IN T EA
    51402023-200 PWR IF/ CHS 240V IN T EA
    51402023-400 PWR I/F CHS 240V EXT EA
    51402030-100 WSI ASSY, 16MB EA
    51402030-200 WSI ASSY, 32MB EA
    51402041-300 FAN 1/2 HGT ASSM 120V EA
    51402041-400 FAN 1/2 HGT ASSM240V EA
    51402041-500 FAN 85-250V EA
    51402041-600 FAN 85-250V EA
    51402042-500 FAN HGT ASM EA
    51402075-100 KEYBOARD EA MP-ZEKBF1-100
    51402083-100 WSI2, 64MHZ W/O GRAPH EA
    51402083-200 WSI2, 100MHZ W/O GRAPH EA
    51402083-300 WSI2, 64MHZ W/GRAPH EA
    51402083-400 WSI2, 100MHZ W/GRAPH EA
    51402089-100 PWA, EPDG2 EA
    51402157-100 10 SLOT CARD FILE EA
    51402166-100 5 SLOT CARD FILE EA
    51402167-100 DUAL NODE CARD FILE EA
    51402172-100 UNIVERSAL I/O EC 5 SLOT EA
    51402173-100 I/O CARD FILE 10SLOT EA
    51402176-100 TRAY, HDDT EA
    51402184-100 KIT, D.N. P/S EA
    51402184-200 KIT, 5 SLOT P/S EA
    51402184-300 KIT, 10 SLOT P/S EA
    51402187-100 CART DRIVE BRACKET EA 51402705-100
    51402188-100 COVER, CART DRV EA
    51402199-100 ENH 5 SLOT CARD FIL E EA
    51402447-100 PWB, EPDGC I/O EA
    51402447-200 PWA, EPDGC I/O EA
    51402453-100 CARD FILE 5 SLOT EA
    51402453-200 5 SLT CD FILE XC300 0 EA
    51402454-100 DUAL NODE I/O EA
    51402455-100 2 NODE CFA EA
    51402457-200 DUAL NODE FILE ASSM EA
    51402471-200 BLUE CABINET 77 IN EA
    51402471-201 CABINET FRAME EA
    51402486-100 INCORRECT LEVEL EA
    51402486-300 525MB W/O SFTWR EA 51402486-800
    51402486-600 2GB W/O SOFTWARE EA 51402486-800
    51402486-800 4GB HARD DRIVE W/O SFTW EA
    51402491-100 CD FILE ASSM EA
    51402492-100 10 SLT MOD COVER EA
    51402493-100 HD DISK TRAY ASSM E C EA
    51402497-100 ENH OP KB ASSY EA
    51402573-100 HPM UCN I/F EA 51402573-150
    51402573-150 HPM UCN I/F EA
    51402594-100 C/F RHIO L1-7 EA
    51402594-200 C/F RHIO R9-15 EA
    51402610-200 PWB, TPDGX EA 51402645-200
    51402615-200 PWA, K2LCN 2MW EA
    51402615-400 PWA, K2LCN 4MW EA
    51402615-800 PWA, K2LCN 8MW EA
    51402618-120 AC ENTRY 120V EA
    51402618-230 AC ENTY 230V EA
    51402619-120 CON,120V PWR ENTRY EA
    51402619-230 PWR ENTRY 230V EA
    51402620-100 10 SLOT COVER EA
    51402623-100 HD COVER EA
    51402625-125 RED DISOE2 ASSM MU-PDIS12 EA
    51402625-175 RED DISOE2(CC) EA
    51402645-200 PWB, TPDGX2 EA
    51402682-100 CONN. PLATE EC Z EA
    51402682-200 CONNECTOR PLATE EA
    51402682-300 CONNECTOR EA
    51402682-400 CONNECTOR PLATE EA
    51402682-500 CONNECTOR PLATE EA
    51402683-100 DISK DRIVE PANEL W/ CUTOUT EA
    51402683-200 DISK DR PANEL W/O C UTOUT EA
    51402684-100 FACADE PANEL EA
    51402686-100 WRITING SURF HOLDER EA
    51402688-100 UWS ENCL W/CUTOU EA
    51402688-200 UWS ENCL W/O CUT EA
    51402689-100 CRT-TS BRACKET EA
    51402690-100 UWS DRIV TRAY EC EA
    51402700-100 MON ASSM W/ TS EA
    51402700-200 MON ASSY W/O T/S EA
    51402700-300 AYDIN REPL KIT EA
    51402700-500 NTS PKG, NEW PWRENT EA
    51402700-600 MONITOR ASSM W/TS BOX EA
    51402705-100 RULA CRT DRIVE BRAC KET EA
    51402706-100 DRIVE PLATE EA
    51402707-100 RULA DRIVE BOX TOP EA
    51402708-100 RULA DRIVE BOX BASE EA
    51402709-100 RULA DRIVE BOX PLAT E EA
    51402711-100 DRIVE ENCLOSURE EA
    51402712-100 NIM TAP MNTG BRACKET EA
    51402714-100 DRV ENCL CLASSIC EC EA
    51402716-100 R/PNL ENCL CLASSIC EC EA
    51402718-100 UPPER DRV MTG PNL E C EA
    51402719-100 IKB SHELF FRAME EA
    51402720-100 IKB CABLE COVER EA
    51402721-100 IKB DRIVE FACADE EA
    51402721-200 IKB DRIVE FACADE EA
    51402724-100 BRKT, MAU/NIM MTG EA
    51402745-100 BRACKET LH EA
    51402745-200 BRACKET RH EA
    51402755-100 PWA, K4LCN, SS MOTHERBOARD ONLY - NO MEM EA
    51402762-100 AUXILIARY CARD FILE EA
    51402763-100 IKB BOTTOM PLATE EA
    51402796-100 BEZEL, LOWER EA
    51402797-100 PWA, LCNP (W/BRACKET FOR NON-DELL PC INSTALL) EA
    51402797-200 PWA, LCNP (INCL BRACKET FOR DELL PC INSTALL) EA
    51403001-200 CONSOLE FRAME MED. EA
    51403002-100 TRAY, CARD FILE (NON EC Z FURN) EA
    51403003-100 CRT BEZEL EA
    51403005-100 WINDOW OPTICAL TRANS EA
    51403006-100 DUST COVER,NON-OPTIC EA
    51403012-100 BOTTOM (FILTER) COV ER EA
    51403013-100 HINGED COVER EA
    51403015-100 COVER, REAR MON EA
    51403021-100 KEYBOARD SUPPORT FR AME EA
    51403024-100 K/B SHELF W/KEYHOLE EA
    51403024-200 K/B SHELF W/O KEYHO LE EA
    51403027-100 LEG COVER, MEDIUM EA
    51403027-101 LEG COVER, MEDIUM EA
    51403027-200 LEG COVER MEDIUM OLD STYLE WITH FASTENERS EA
    51403027-201 LEG COVER, MEDIUM OLD STYLE WITH FASTENERS EA
    51403027-300 LEG COVER, SHORT OLD STYLE "Z" FURNITURE EA
    51403027-301 LEG COVER, SHORT OLD STYLE "Z" FURNITURE EA
    51403027-400 LEG COVER, MEDIUM LONG EA
    51403027-500 LEG COVER, MED LATER "Z" WITH SCREWS EA
    51403027-600 LEG COVER, SHORT LATER "Z" WITH SCREWS EA
    51403030-100 OEP BEZEL EA
    51403031-100 WORK SURFACE WEDGE EA
    51403034-100 MEDIA DOOR EA
    51403036-100 WRITING SURFACE EA
    51403037-200 HEAVY FOOTREST EA
    51403047-100 HINGE ASSEMBLY EA
    51403056-100 BLANK OEP INSERT EA
    51403057-100 ENG KEYBOARD TRAY EA
    51403064-100 ENG. KEYBOARD ENCLO SURE EA
    51403069-100 BEZEL (MODIFIED) EA
    51403070-100 CRT MTG. BRACKET EA
    51403071-100 CRT-TS BRACKET EA 51402689-100
    51403081-100 DISK CHANNEL (NON EC) EA
    51403087-100 AYDIN CRT BRACKET EA 51402689-100
    51403089-200 UPPER FRONT COVER EA 51403089-300
    51403089-300 UPPER FRONT CVR EA
    51403090-200 UPPER FRONT COVER EA 51403090-300
    51403090-300 LWR FRONT COVER EA
    51403095-100 MONITOR MTG. SHROUD EA
    51403095-200 MONITOR MTG. SHROUD EA
    51403100-100 POWER SUPPLY ENCLOS URE EA
    51403106-100 TABLE TOP, PRINTER EA
    51403106-200 TABLE TOP, WORK SUR FACE EA
    51403114-100 WEDGE TIE PLATE- AR C EA
    51403117-100 CARD FILE ENCL ASSM EA
    51403124-100 WEDGE TIE PLATE- IN LINE EA
    51403135-100 T/S ASSM. 21 IN EA 51197006-100
    51403148-200 REAR COVER/W HDWR EA
    51403149-100 EMI SHIELD EA
    51403152-100 REAR DN COVER EA
    51403155-100 PAPER BASKET, STACK EA
    51403156-100 PAPER BASKET, FEED EA
    51403157-200 POWER SUPPLY ASSM. EA
    51403158-100 CONTROL PNL ASSY EA
    51403159-100 BEZEL ASSY EA
    51403159-200 Z FRONT BEZEL(SONY) EA
    51403160-200 CONSOLE FRAME LOW EA
    51403161-200 CONSOLE FRAME HIGH EA
    51403162-400 LEG COVER, LONG SMA LL EA
    51403162-500 LEG COVER, MEDIUM S MALL EA
    51403162-600 LEG COVER, SMALL SHORT EA
    51403163-400 TALL LONG LEG COVER EA
    51403163-500 TALL MED. LEG COVER EA
    51403163-600 TALL SHORT LEG COVE R EA
    51403165-100 OPERATOR ENT PNL ASSM EA 51403165-300
    51403165-200 OPERATOR PANEL ASSM EA 51403165-400
    51403165-300 OPR ENT PNL ASSM EA
    51403165-400 OPR PNL ASSM EA
    51403169-100 TREND PEN BEZEL ASS M EA
    51403170-700 TREND PEN ASSM EC EA
    51403170-800 TREND PEN ASSM EC EA
    51403170-900 TREND PEN ASSM EC EA
    51403171-100 REAR COVER AUX POD EA
    51403176-100 PWR SUPPLY ENCL HAR D DISK EA
    51403178-100 REAR COVER PLATE EA
    51403182-100 FAN REAR COVER ASSM 120V EA
    51403182-300 FAN REAR COVER ASSM EA
    51403185-100 MON T/S ASSM KIT EC EA
    51403190-100 CRT MOUNT 15 DEGREE HEAVY EA
    51403191-100 CRT MOUNT 30 DEGREE HEAVY EA
    51403195-100 5 SLOT CARD FILE EA
    51403223-100 FIBER OPTIC MODULE ASSM EA
    51403224-200 LCNP PWA BRACKET EA
    51403249-100 MOUNTING ENCLOSURE EA
    51403254-100 Module Chassis Assembly EA
    51403257-100 A/C POWER ENTRY EA 51197066-200
    51403280-100 RACK MTG KIT 19IN GUS(TP-MOUNTR-100) EA
    51403282-100 LCNP4 W/O CARD GUIDE EA 51403299-100
    51403282-200 LCNP4 WITH CARD GUIDE EA 51403299-200
    51403299-100 LCNP4 GPS W/O CARD GUIDE EA
    51403299-200 LCNP4 GPS WITH CARD GUIDE EA
    51403299-300 TPNB W/O SPACER EA
    51403299-400 TPNB W/SPACER EA
    51403355-100 GX1 MODIFIED APP NODE MOTHERBOARD EA
    51403355-101 450MHz APP NODE CONSOLE PC EA
    51403355-102 450MHz DESKSIDE APP NODE GX1 PC EA
    51403355-201 450MHZ GX1 DSKTP/IN CONS APP NODE W/O CD DR EA
    51403355-202 450MHZ GX1 DESKSIDE APP NODE W/O CD DRIVE EA
    51403355-203 500MH PIII DESK CONS W/O CD DRIVE APP NODE EA
    51403355-204 500MH PIII MINI TOWER W/O CD DRIVE APP NODE EA
    51403375-100 QWERTY KEYBOARD EA 51196943-100
    51403393-100 9 GB DRIVE TRAY ASSY EA MP-ZHMU19-100
    51403393-200 6 GB DRIVE TRAY ASSY EA MP-ZHMU12-100
    51403397-100 MONITOR REAR COVER EA
    51403505-100 FRONT BEZEL DOOR EA 51403530-100
    51403519-160 K4SDR 16 MW EA
    51403522-100 T/S ASSEMBLY 21IN EA
    51403527-100 BEZEL, IR TOUCHSCREEN EA
    51403530-100 BEZEL/CTRL PNL ASSM (see notes) EA
    51403531-100 BEZEL/TOUCHSCREEN ASSM EA
    51403539-100 Window, 19" Infrared T/S EA
    51403546-200 Bezel Asm, OEP Lower W/O TS EA
    51404088-100 COVER ASSY EA
    51404092-300 IOP CASE EA 51404092-400
    51404092-400 IOP CASE EA
    51404092-500 MOD CHASSIS ASSM EA
    51404106-175 RH MUX CC EA
    51404109-125 32PT IOP MU-PRHM01 EA
    51404109-175 32PT IIOP CC EA
    51404125-100 HPM 1-7 SLOT CF EA 51404125-200
    51404125-150 HPM 1-7 SLOT CF EA 51404125-250
    51404125-200 HPM FILE ASSM 7L EA
    51404125-250 HPM FILE ASSM 7L CC EA
    51404126-100 HPM 9-15 SLOT CF EA 51404126-200
    51404126-150 HPM 9-15 SLOT CF EA 51404126-250
    51404126-200 HPM FILE ASSM 7R EA
    51404126-250 HPM FILE ASSM 7R CC EA
    51404127-100 HPM 15 SLOT CF EA 51404127-200
    51404127-150 HPM 15 SLOT CF EA 51404127-250
    51404127-200 HPM FILE 15 SLOT EA
    51404127-250 HPM FILE 15 SLOT CC EA
    51404138-100 PNL, BCU MIGRAT EA
    51404169-100 PANEL EA
    51404170-125 PS CHASSIS ASM EA
    51404170-175 P/S CHASSIS ASM EA
    51404172-100 B/P PWS SUPPLY EA 51404172-125
    51404172-125 B/P PWR SYS EA
    51404172-175 B/P PWR SYS EA
    51404174-125 POWER SYSTEM ASSM MU-PSSX04 EA
    51404174-175 POWER SYSTEM ASSM EA
    51404174-225 POWER SYSTEM ASSM MU-PSRX04 EA
    51404174-275 POWER SYSTEM ASSM EA
    51404174-325 RED P/S 20 AMP W/BBUAND MTG MU-PSRB04 EA
    51404174-375 RED P/S 20 AMP W/BBUAND MTG EA
    51404191-125 HPM FILE ASSM 7-LF EC EA 51404191-325
    51404191-175 HPM FILE ASSM 7-LF EC CC EA 51404191-375
    51404191-225 HPM FILE ASSM 7-LF I/O EC EA 51404191-425
    51404191-275 HPM FILE ASSM 7-LF I/O CC EA 51404191-475
    51404191-325 HPM 7 SLOT LEFT EA
    51404191-375 HPM 7 SLOT LEFT CC EA
    51404191-425 HPM 7 SLOT LEFT EC EA
    51404191-475 HPM 7 SLOT LEFT CC EA
    51404192-125 HPM FILE ASSM 7-RT EC EA 51404192-325
    51404192-175 HPM FILE ASSM 7 RT EC CC EA 51404192-375
    51404192-225 HPM FILE ASSM 7RT I /O CC EA 51404192-425
    51404192-275 HPM FILE ASSM 7-RT I/O CC EC EA 51404192-475
    51404192-325 HPM 7 SLOT FILE, RIGHT EA
    51404192-375 HPM 7 SLOT R EA
    51404192-425 HPM 7 SLOT EA
    51404192-475 HPM 7 RT I/O EC CC EA
    51404193-125 15 SLOT EC, HPM EA 51404193-325
    51404193-175 15 SLOT CC, HPM EA 51404193-375
    51404193-225 HPM FILE ASSM 15 SLOT I/O EA 51404193-425
    51404193-275 15 SLOT I/O EC EA 51404193-475
    51404193-325 HPM 15 SLOT EC EA
    51404193-375 HPM 15 SLOT EC CC EA
    51404193-425 HPM 15 SLOT EC EA
    51404193-475 HPM FILE 15 EC CC EA
    51404210-125 15 C/F I/O ENTRY EA 51404193-425
    51404210-175 15 SLT IOP FILE EA 51404193-475
    51404211-125 PM/APM FILE 10 I/O EA 51404211-175
    51404211-175 FILE,PM I/O EA
    51404212-125 PM/APM FILE 5 I/O EA 51404212-175
    51404212-175 FILE,5SLT IOP EA
    51404256-100 MOUNTING PLATE EA
    51404331-100 UNCE ENCLOSURE EA 51404331-200
    51404331-200 UCNE ENCLOSURE EA
    51404365-200 COVER, 7-S (1-7) EA
    51404365-300 COVER, 7-S (9-15) EA
    51404366-200 COVER, 15-SLOT EA
    51404367-200 UCN FRONT PLATE EA
    51404367-300 8 SLOT UCNE PNL EA
    51404368-200 PLASTIC FRONT PANEL EA
    51404368-300 COVER, HPM PWR EA
    51404368-400 COVER, HPM AC PWR EA
    51404368-500 FILLER PANEL 15 SLOT EA
    51404368-600 COVER, UNCE EA
    51404368-700 COVER, HPM PWR (CC) EA
    51404368-800 COVER, HPM AC (CC) EA
    51404372-100 HOFFMAN CAB ASSM DUAL ACCESS (CAB ONLY) EA
    51404373-100 REMOTED HARDENED CNTRL CAB 120V MU-RCAB01 EA
    51404373-200 REMOTE HARDENED CNTRL CABINET 240V MU-RCAB02 EA
    51404374-100 REMOTE HARDENED CONTROLLER UCNE MTG KIT EA
    51404376-150 FAN ASSY EA
    51404376-250 FAN ASSY EA
    51404377-100 RHC BATTERY MOUNTINGKIT W/BATTERY EA
    51404383-100 PM POWER CHASSIS LABEL EA
    51404383-500 PM POWER CHASSIS LABEL, "CC" EA
    51404385-100 PANEL MTG BKG RH EA
    51404385-200 PANEL MTG BKT LH EA
    51404386-100 HEATER KIT 120V MU-RCHT01 EA
    51404386-200 HEATER KIT 240V MU-RCHT02 EA
    51450150-100 BEZEL EA
    51450151-100 BLANK KB BEZEL EA
    51450166-200 CONSOLE BEIGE CRT EA
    51450166-300 CONSOLE BEIGE CRT EA
    51450166-400 CONSOLE BLACK CRT EA
    51450166-500 CONSOLE WORK SURFACEBLK EA
    52527 CABLE, CD EA
    54090 144MB FLOPPY DR EA 51196946-905
    55078 POWER SUPPLY 145W EA
    55079 POWER SUPPLY 200W EA
    55168 CD, 680MB 12/24X EA 51196982-906
    57593 PWA, PLN 440LX KLMTH OPPLX ENH EA
    5812E CABLE ASSY UW EA
    59362 2GB WIDE DR W/CB EA
    5940E NEC 680M IDE 14/32 CD ROM EA
    60820 8X CD ROM DR EA 51196935-907
    6104E 9.1 GB SCSI UWIDE H/D EA 51196982-908
    612167 DUAL CRT CTRL EA 51196928-100
    62795601-001 S/L PWB C-ASL00 EA
    62795604-001 C-AA190 - PWB EA
    62795604-002 PWB C-AA290 EA
    62795607-001 PWB C-AZL01 EA 62795607-003
    62795607-002 PWB C-AZS01 EA 62795607-004
    62795607-003 PWB C-AZL01 INTEGR-LINEAR EA
    62795607-004 PWB C-AZS01 SQRT08 EA
    62795609-001 P/W BOARD-ADDER/ EA
    62795610-001 PWB C-APM00 EA
    62795613-001 PWB C-ASC00 W/87 SGL SELECTOR EA
    62795646-001 PWB, ASSEMBLY PV EA
    62795647-001 PWB, STANDBY EA
    62795648-001 SORT PWB EA
    62795649-001 62795649-001 LOOP STANDBY EA
    62795653-002 SWITCH EA
    62795653-003 SWITCH EA
    62795654-001 LAMP CARTRIDGE EA
    62795655-001 RESISTOR EA
    62795729-001 PWB, CALIBRATOR FUNCTION CARD EA
    657PW PRC,80526,1GZ,256,133,FC EA
    66051 HARD DRIVE 4 GB DELL EA 87512
    66433225 DISC DRIVE 1.44MB EA 51196969-905
    66433487 POWER SUPPLY 300W (MOTOROLA) EA 51196969-914
    66433577 KBM104-US KEYBOARD AND MOUSE EA 51196969-900
    68A8537P03 FUSE, 1.5A EA
    68A8537P07 FUSE, 5A, 250V EA
    68A8976P1 FAN,SMALL MUFFIN EA
    68A8976P2 FAN MIN BALL BEA EA
    6982D SCSI CONTROLLER EA 51196982-907
    69855 CABLE SCSI C/D EA
    69885 CABLE, IDE/SCSI, CD-ROM EA
    7020T FD,1.44M,F3,NBZ,SONY,F/EJ3 EA
    70A2551P108 FUSE, .01 AMP EA
    70A2551P111 FUSE, .25 AMP EA
    70A2551P114 FUSE, .5 AMP EA
    70A2551P119 FUSE, 1 AMP EA
    70A2551P120 FUSE, 1.5 AMP EA
    70A2552P204 SWITCH COVER EA
    70A2553P101 SWITCH MIN PWB EA
    70A2801P101 FAN ASSEMBLY EA
    70B173612G2 FAN ASSY, 230V EA
    70YY19026 ANNUNCIATOR PWB EA 51303642-600
    71915 CABLE, FLOPPY DR EA
    78140531-001 CARRIAGE ASSM EA
    8002-CC-85 Carrier Extension Cable, 0.85m EA
    8003-CC-12 Carrier Extension Cable, 1.2m EA
    8020-CE-RH Carrier Extender, Right Hand EA
    8021-CE-LH Carrier Extender, Left Hand EA
    80268 PWA,MOTHER BOARD, 440LX, OPPLX EA
    8030-CE-RH IS Carrier Extender, Right-Hand EA
    8031-CE-LH IS Carrier Extender, Left-Hand EA
    8032-CC-35 IS Carrier Extension Cable Set, 0.35m EA
    8033-CC-85 IS Carrier Extension Cable Set, 0.85 EA
    80337031-208 CONN BLK 8PT TE EA 51195773-100
    8034-CC-12 IS Carrier Extension Cable Set, 1.2m EA
    80350091-002 FUSE, .5A EA
    80350091-003 FUSE, 1AMP EA 83957061-003
    80350091-004 FUSE, 1.6 AMP EA 83957061-004
    80350091-006 FUSE, 3.2 AMP EA 83957061-006
    80350091-007 FUSE, 5 AMP EA 83957061-007
    80350514-003 FUSE 0.125A EA 30076014-011
    80350514-008 FUSE, .25A 250V EA 30076014-004
    80350514-011 FUSE 0.5A EA 30076014-006
    80350514-012 FUSE, 0.6 AMP EA 30076014-023
    80350514-013 FUSE, .75 AMP EA 30076014-010
    80350514-014 FUSE, 1A 250V EA 30076014-001
    80350514-016 FUSE 2A EA 30076014-002
    80350514-018 FUSE 3 AMP EA 30076014-009
    80350514-019 FUSE, 4 AMP EA 30076014-025
    80350514-020 FUSE 5A EA 30076014-003
    80350514-023 FUSE 8A EA 30076014-005
    80350514-025 FUSE, 10 AMP EA 30076014-012
    80350514-026 FUSE 15A EA 30076014-014
    80350613-001 LBOS CRT, 9 IN EA
    80350656-005 FUSE, 5A EA
    80350656-006 FUSE 7.5 AMP EA
    80350859-001 J-PCM20,I/O MOD EA
    80360136-001 AMC R20 BASE EA
    80360137-001 AMC R10 BASE J-MBU00 EA
    80360139-001 DIGITAL IN,32PT J-DIM00 EA
    80360140-001 DIGITAL OUT,32PT J-DOM10 EA
    80360140-011 DIG OUTPUT,16PT J-DOM00 EA
    80360140-012 I/O MODULE WITH FRONT TERM 16S/S J-DOF00 EA
    80360141-001 R20 A/I MODULE EA 80360141-011
    80360141-011 HIGH LEVEL ANALOG INPUT FOR UAC J-HAM10 EA
    80360141-012 HIGH LEVEL ANALOG INPUT 16 FOR UAC W/FTB EA
    80360142-001 HL ANALOG MUX J-HMM00 EA
    80360143-001 R20 A/O MODULE EA 80360143-011
    80360143-002 R20 A/O MODULE EA 80360143-012
    80360143-011 R20 A/O MODULE J-AOM10 EA
    80360143-012 R20 A/O MODULE J-AOF00 EA
    80360144-001 HC I/F MODULE J-HCX00 EA
    80360145-001 R20 CTRL MODULE EA 80360145-011
    80360145-011 R20 CTRL MODULE J-MSC10 EA
    80360146-001 R20 HWAY I/F MOD EA 80360146-011
    80360146-011 R20 HWAY I/F MOD J-MHM10 EA
    80360147-001 R20 UAC DIR MOD J-UDM00 EA
    80360155-001 FRONT TERM BLOCK J-FTB00 EA
    80360163-001 EC-LINK TERMINATOR, J-ELT00 EA
    80360164-001 TERM PANEL SUP EA J-TPX00
    80360169-001 AMC R20 BASE,UAC EA
    80360170-001 I/O CABLE 1M EA 80360170-010
    80360170-010 I/O CABLE 1M (J-RSL01) EA
    80360170-015 I/O CABLE 1.5M EA
    80360170-020 2M I/O CABLE EA
    80360170-030 I/O CBL 3M EA
    80360170-050 5M I/O CABLE EA
    80360170-080 8M I/O CABLE EA
    80360170-150 15M I/O CABLE EA
    80360170-300 30M I/O CABLE EA
    80360170-500 50M I/O CABLE EA
    80360171-020 REDUN I/O CBL 2M J-RRK02/J-RRL20 EA
    80360171-030 UAC CABLE, 3M J-RRL30 EA
    80360171-050 UAC I/O CABLE 5M J-RRL50 EA
    80360171-080 UAC I/O CABLE 8M J-RRL80 EA
    80360171-150 UAC CABLE, 15M J-RRK15 EA
    80360172-001 R20 UAC MAIN BSE EA 80360169-001
    80360173-001 AMC I/O BASE EA
    80360175-001 MTG KIT,TERM PNL J-TPX10 EA
    80360181-001 PWR DIST PANEL J-PDP00 EA
    80360181-002 PWR DIST PANEL EA 80360181-001
    80360185-001 PULSE INPUT, AMC J-PIM00 EA
    80360185-002 PULSE INPUT MODULE (8) WITH FTB J-PIF00 EA
    80360195-001 D/O RELAY MODULE J-DOM20 EA
    80360195-002 RELAY D/O MODULE WITH FTB J-DOF20 EA
    80360198-001 DIGITAL INPUT MODULE 48VDC J-DIM10 EA
    80360198-002 DIGITAL INPUT MODULE - 48VDC W/FTB J-DIF10 EA
    80360199-001 SM TRANS I/F-AMC J-STM00 EA
    80360206-001 PWA, CLI EA
    80360209-001 CLI ADAPT BD ASM EA
    80360211-100 PWA, 1 M/W MEMRY EA
    80360211-200 3/4 M/W PWA EA
    80360230-001 PWB, CLI I/O EA
    80360300-501 512K MEMORY PWA EA
    80360322-001 FDD CONVERT ASSY EA
    80360379-030 SIGNAL CABLE EA
    80360573-001 EC-LINK TERMINATOR J-ELT00 EA 80360163-001
    80360619-001 CABLE-AMC TO AMC J-HIC00 EA
    80360620-001 CABLE-AMC TO I/F J-HIC10 EA
    80360620-002 CABLE 3 METER EA
    80360621-001 CABLE, 1M EC-LINK INTERNAL CAB USE J-EIC10 EA
    80360621-002 EC-LINK CBL-2 EA
    80360621-004 CABLE, EC LINK EA
    80360621-005 EC-LINK CABLE J-EIC00 EA
    80360636-050 ECL CABLE, 5M J-EEK05 EA
    80360636-200 CABLE, 20M EC-LINK J-EEK20 EA
    80360641-200 HCIM POWER CABLE J-HPA20 EA
    80360643-001 BASE UNIT ADAPTER J-BUA00 EA
    80360645-001 EC-LINK ADAPTER J-ELA00 EA
    80360646-001 EC-LINK ADAPTOR J-ELA10 EA
    80360662-001 FDD CBL CONVRT EA
    80360677-001 A/I REMOTE T.P. J-RTP10 EA
    80360680-001 A/O RTP W/STDBY EA
    80360686-001 D/O REMOTE T.P. J-RTP40 EA
    80360689-001 PULSE INPUT T.P. J-RTP50 EA
    80360693-001 A/O REMOTE T.P. EA
    80360695-001 REMOTE DI/DO TP J-RTP00 EA
    80360697-001 CBL,.9M UAC INTERNAL CABINET USE J-HIC20 EA
    80360713-001 A/I ADAPTER UNIT J-AAU00 EA
    80360769-050 CBL, 50 FT EA
    80360912-001 I/O ADAPTER J-BCA00 EA
    80361024-001 REMOTE D/O T.P.J-RTP80 EA
    80361027-001 TERM PNL,ENH D/O EA
    80361394-100 HPM HD I/O IOP EA 80363969-150
    80361394-150 HPM HD I/O IOP EA 80363969-150
    80361395-100 DI IOP 32 ASSY EA 80363972-100
    80361396-100 DI IOP 32 ASSY EA 80363975-100
    80362958-001 OPR FLIP LEGS EA
    80363969-100 HPM HD I/O IOP EA 80363969-150
    80363969-150 HPM HD A/O IOP EA
    80363972-100 DI IOP 32 ASSM MU-PDIY22 EA
    80363972-150 DI IOP COATED MC-PDIY22 EA
    80363975-100 DO IOP (NON COATED) MU-PDOY22 EA
    80363975-150 HD DO IOP, COATED EA
    80364007-100 AO FTA SCR EA 80364007-200
    80364007-200 AO FTA SCR MU-TAOY53 EA
    80364007-250 AO FTA RED EA
    80364010-100 FTA, DI 24VDC SCREW EA 51204154-125
    80364010-125 DI 24VDC SCR EA 51204154-125
    80364010-175 DI 24V DC SCR EA 51204154-175
    80364013-100 FTA, DO 24VDC SCREW EA 51204156-125
    80364013-125 DO 24VDC EA 51204156-125
    80364013-175 HDIO DO FTA EA 51204156-175
    80366177-100 HD FTA, AO COMP W/STBY EA 51204172-125
    80366177-200 AO RED COMP MU-TAOY23 EA
    80366177-250 AO FTA RED EA
    80366180-100 FTA, DI 24VDC COMP EA 51204160-125
    80366180-125 D/I RED COMP EA 51204160-125
    80366180-175 HDIO DI 24V EA 51204160-175
    80366183-100 FTA, DO 24VDC COMP EA 51204162-125
    80366183-125 FTA, DO 24VDC COMP EA 51204162-125
    80366183-175 HDIO DO FTA EA 51204162-175
    80366186-100 HD FTA, DO RELAY SCREW EA 51204164-125
    80366186-125 FTA RED SCR EA 51204164-125
    80366186-175 HDIO FTA RED EA 51204164-175
    80366189-100 HD FTA, DO RELAY COMP EA 51204166-125
    80366189-125 DO FTA COMP EA 51204166-125
    80366189-175 HDIO DO FTA EA 51204166-175
    80366192-100 HLAI FTA SCR - MU-TAIH62 EA 51204168-100
    80366192-150 HDIO HLAI/STI EA 51204168-150
    80366195-100 HLAI RED COMP EA 51204170-100
    80366195-125 HLAI FTA COMPR EA 51204170-125
    80366195-150 HDIO HLAI/STI EA 51204170-150
    80366195-175 HDIO HLAI FTA EA 51204170-175
    80366198-100 BRIDGE CBL 1M MU-KBFT01 EA
    80366198-200 CABLE 2M BRIDGE MU-KBFT02 EA
    80366481-125 AO COMP EA 51204172-125
    80366481-175 HDIO A/O FTA EA 51204172-175
    80366484-125 A/O FTA SCREW EA 51204174-125
    80366484-175 HPM A/O FTA EA 51204174-175
    80367031-208 CONN BLK 8PT TE EA 51195773-100
    80367163-001 HPM AI ADAPTER EA
    80522 PROCESSOR 266Mh,512KECC EA 83613
    80585 MTHRBD,10/100 LT EA
    8060-CC-XT RAILBUS EXTENSION CABLE/CONDUIT ASSEMBLY EA
    8061-CC-XT RAILBUS EXTENSION CABLE/CONDUIT ASSY-DUST PRT EA
    8070-FC-50 FIBER PATCH CABLE, 50cm EA
    8101-HI-TX-HON 8-channel AI, 4-20mA w/HART for 2-wire Txmtr EA
    8102-HO-IP-HON 8-channel AO, 4-20mA w/HART EA
    8104-AO-IP-HON 8-channel AO, 4-20mA EA
    8105-TI-TC-HON 4-channel THC/mV input EA
    8106-TI-RT-HON 4-channel RTD input EA
    8109-DI-DC-HON 8-channel DI, 24Vdc Isolated, Sinking EA
    8110-DI-DC-HON 8-channel DI, 24Vdc Non-Isolated, Module Pwrd EA
    8111-DI-AC-HON 8-channel DI, 115Vac Isolated, Sinking EA
    8112-DI-AC-HON 8-channel DI, 115Vac Non-Isolated, Mod Pwrd EA
    8113-DI-AC-HON 8-channel DI, 230Vac Isolated, Sinking EA
    8114-DI-AC-HON 8-channel DI, 230Vac Non-Isolated, Module Pwr EA
    8115-DO-DC-HON 8-channel DO, 2-60VDC Non-Isolated, Mod Pwrd EA
    8116-DO-AC-HON 8-channel DO, 20-250VAC Non-Isolated, Mod Pwr EA
    8117-DO-DC-HON 8-channel DO, 2-60VDC Isolated, Unpowered EA
    8118-DO-AC-HON 8-channel DO, 20-250VAC Isolated, Unpowered EA
    8121-DI-DC-HON 16-channel DI, 24VDC Dry Contact, Module Pwrd EA
    8122-DI-DC-HON 16-channel DI, 24VDC Field-powered EA
    81442 230W P/S EA
    81502507-001 KEYSWITCH ASSY EA
    8171E RISER 5 SLOT ACTIVE EA 51196982-909
    81730 KEYBOARD EA 51196935-901
    8201-HI-IS-HON 8-channel IS AI, 4-20mA with HART EA
    8202-HO-IS-HON 8-channel IS AO, 4-20mA with HART EA
    8204-AO-IS-HON 8-channel IS AO, 4-20mA EA
    8205-TI-IS-HON 8-channel IS THC/mV Input EA
    8206-TI-IS-HON 8-channel IS RTD/ohms Input EA
    82114805-501 ASSY, TREND I/F EA 82115012-001
    82114805-502 TREND ASSM EA 82115012-001
    82114814-501 PTR INTERFACE BD EA
    82114927-001 PWB, DG (A) R520 EA 82114927-501
    82114927-501 PWB, DG (A) R520 EA
    82114927-502 PWA, DG (A) R530 EA 82114927-002
    82114930-001 PWB, DG (B) R520 EA 82114930-501
    82114930-501 PWB, DG (B) R520 EA
    82114930-502 PWB, DG (B) R530 EA 82114930-002
    82115012-002 ASSY, TREND I/F EA
    82115045-001 CONFIG DATA BASE EA
    82115046-001 SOPL PROGRAM EA
    82115047-001 TREND DATA BASE EA
    82115048-001 RECIPE DATA BASE EA
    82115049-001 R520 DIAG DISK EA
    82115119-001 BLANK DATA BASE EA
    82115121-001 UTILITY DISKETTE EA
    82115206-001 CONFIG PROG DISK EA
    82115207-001 OP PROG w/oRECIP EA
    82115208-001 OP PROG W/RECIPE EA
    82115280-001 ASM, KEYBD FLAT J-DSG53 EA
    82115961-002 CABLE ASSM-10FT EA 51304050-010
    82116144-001 CABLE ASSEMBLY EA
    82116170-001 CABLE ASSEMBLY EA
    82116300-001 KEYSWITCH ASSM EA 81502507-001
    82116383-001 M/F SWITCH PANEL EA
    82116404-001 OP PROG w/oRECIP EA
    82116405-001 OP PROG W/RECIPE EA
    82116406-001 CONFIG PROG DISK EA
    82116410-001 UTILITY DISKETTE EA
    82116412-001 R535 DIAG DISK EA
    82116421-001 CONFIG PROG DISK EA
    82116424-001 R530 DIAG DISK EA
    82117038-001 1MW MEM REPL. EA 30752117-002
    82117038-501 1MW MEMORY REPLC(
    培训) EA 30752117-002
    8215-DO-IS-HON 4-channel IS DO, Solenoid Drvr, IIC Gas Group EA
    8220-DI-IS-HON 16-channel IS DI, Switch/Proximity Detector EA
    8223-PI-IS-HON 2-channel Pulse/Frequency Input Module EA
    82250823-005 RIBBON CABLE EA
    82250823-008 RIBBON CABLE EA
    82277 PWA, RISER, 5 SLOT PASSIVE EA
    82325 PWB, RISER, 5 SLOT EA
    82407025-100 MC PT CARD FILE J-PF100 EA
    82407025-200 MC PT CARD FILE J-PF200 EA
    82407026-001 SPARE CARD FILE EA
    82407039-001 SPARE M/ FILE EA
    82407044-001 J-CD500 FILE EA
    82407044-004 RCD FILE EA
    82407045-001 J-CDD50 FILE EA
    82407046-001 BACKUP MEM FILE J-CDM50 EA
    82407372-001 I/O TERM PANEL J-TCB50 EA
    82407387-001 PWB, IBC R15/20/30 J-CBC00 EA
    82407390-501 PWB, IBI R30 EA 82407390-001
    82407438-001 PANEL,TERM J-TPF10 EA
    82407441-001 TERM PANEL EA
    82407444-001 PANEL,TERM J-TPF40 EA
    82407465-001 PWB, REGULATOR A EA
    82407468-001 PWB, REGULATOR B EA 51196989-100
    82407468-002 PWB, REG. B R15/ EA
    82407498-001 CABLE, I/O BUS J-KR050 EA
    82407499-001 CABLE, I/O BUS EA
    82408007-001 CABLE, I/O 5M J-KE001 EA
    82408007-002 CABLE, I/O 5M J-KE002 EA
    82408007-003 CABLE, I/O 3M J-KE003 EA
    82408007-005 CABLE, I/O 5M J-KE005 EA
    82408007-008 CABLE, I/O 8M J-KE008 EA
    82408007-015 CABLE, I/O 15M EA
    82408007-030 CABLE, I/O 30M EA
    82408007-501 CABLE I/O 1.5M J-KE115 EA
    82408060-001 ASM RAM BATTERY EA 38002931-100
    82408061-001 C-LINK ADP KRA00 EA 82408061-002
    82408061-002 C-LINK ADP J-KRA00 EA
    82408108-001 FLAT CABLE ASSY EA
    82408175-002 C-LINK EXTERNAL CABLE (J-KRE02), 2 METERS. EA
    82408175-010 C-LINK EXTERNAL CABLE (J-KRE10), 10 METERS. EA
    82408175-020 C-LINK EXTERNAL CABLE (J-KRE20), 20 METERS. EA
    82408175-030 C-LINK EXTERNAL CABLE (J-KRE30), 30 METERS. EA
    82408175-100 C-LINK CBL 100M EA
    82408187-001 DSP. J-PNL EA
    82408199-001 DIG DSP BRCH PNL EA
    82408205-001 PWB, SBLA III EA 82408485-001
    82408208-003 PWB SDLA II R20 EA
    82408213-001 A/D ADDER CARD F EA
    82408215-001 PWB, IBI A/D R15 EA
    82408217-001 PWB, MOS CPU R15 EA 82408217-002
    82408217-002 PWA, PROCESSOR W/EMULATOR EA
    82408309-002 LOC COMP I/F J-DCC00 EA
    82408310-001 E/T/P RELAY ASSM J-PCM40 EA
    82408310-002 E/T/P RELAY ASSM J-PCM50 EA
    82408330-001 PWB, HIWAY #2 EA
    82408363-001 PANEL,TERM J-TPF20 EA
    82408433-004 CBL SET J-KRL40 EA
    82408440-001 PWB, UAC I/F R30 J-CBC50 EA
    82408443-001 8K RAM PWB EA 82408667-005
    82408443-002 16K RAM PWB EA
    82408443-003 24K RAM PWB EA 82408667-005
    82408443-004 ROM PWB EA 82408667-004
    82408443-005 PWB, MEMORY EA 82408667-003
    82408447-002 LBOS CPU R15 EA
    82408452-001 RBCD CONTRL R300 EA
    82408452-501 RBCD CONTRL R300 EA 82408452-001
    82408456-002 PWB, B/U MEMORY J-CBM55 EA
    82408458-002 PWB, B/U MEMORY EA 82408456-002
    82408461-001 PWB, B/U MEMORY EA 82408456-002
    82408464-001 PWB, SO SWITCH EA
    82408467-001 PWB, I/O BUS SW J-CDS50 EA
    82408470-001 PWB, I/O BUS SW EA
    82408473-001 PWB SO SW MODULE EA
    82408476-001 PRIM SO JNCT PNL J-JDD50 EA
    82408479-001 J-JDD51 R/S/O J/PNL EA
    82408482-001 S/O DISTRI PANEL J-DD55 EA
    82408485-001 PWB, SBLA III J-CBC03 EA
    82408520-001 MEM FILE W/O CDS EA
    82408609-101 I/O BUS CBL,1.4M J-KR501 EA
    82408609-102 I/O BUS CBL, 5M J-KR505 EA
    82408609-104 I/O BUS CBL 10M J-KR510 EA
    82408609-105 10' UAC CABLE EA
    82408609-201 DATA BUS CABLE 1M J-KDB01 EA
    82408609-202 DATA BUS CABLE 5M J-KDB05 EA
    82408609-204 DATA BUS CABLE 10M EA
    82408609-205 DATA BUS CABLE 3M J-KDB03 EA
    82408667-001 PWA, ROM/RAM EA
    82408667-002 PWB, ROM/RAM EA 82408667-001
    82408667-005 24K RAM PWB EA
    82409482-001 OP PROG w/oRECIP EA
    82409483-001 OP PROG W/RECIPE EA
    82409484-001 DHP CONFIG DISK EA
    82409485-001 CONFIG PROG DISK EA
    82409486-001 BLANK DATA BASE EA
    82409487-001 CONFIG DATA BASE EA
    82409488-001 TREND DATA BASE EA
    82409489-001 SOPL DATA BASE EA
    82409490-001 RECIPE DATA BASE EA
    82409491-001 R525 DIAG DISK EA
    82409497-001 UTILITY DISKETTE EA
    824KH PWR SPLY,200W,PFC,RF,PS/2,8C EA
    82665 1.44MB FLOPPY DR EA 51196946-905
    8301-HI-IS-HON 8-CH IS AI MODULE,4-20mA WITH HART EA
    8304-AO-IS-HON 8-CH IS AO MODULE, 4-20mA EA
    8305-TI-IS-HON 8-CH IS TC/mV INPUT MODULE EA
    8306-TI-IS-HON 8-CH IS RTD/ohms INPUT MODULE EA
    8315-DO-IS-HON 4-CH IS DO MODULE,SOLENOID DRIVER IIC GAS GRP EA
    8320-DI-IS-HON 16-CH IS DI MODULE, SWITCH/PROXIMITY DETECTOR EA
    83613 PROCESSOR 266Mh,512KECC EA
    83957061-002 FUSE 0.5 AMP EA 80350091-002
    83957061-003 FUSE 1.0 AMP EA
    83957061-004 FUSE, 1.6 AMP EA
    83957061-006 FUSE, 3.2 AMP EA
    83957061-007 FUSE, 5 AMP EA
    83957062-005 FUSE, 5A EA 80350656-005
    83957062-006 FUSE 7.5 AMP EA 80350656-006
    83970001-103 D/O RELAY EA
    83970001-110 RELAY,24V PLUGIN EA
    8405-LK-ZE REPLACEMENT LOOP-DISCONNECT LINK (PACK OF 10) EA
    8430-TS-MO TAG STRIP KIT (PACK OF 25, CARDS & WINDOWS) EA
    8435-PP-24 FIBER OPTIC PATCH PANEL, 24-WAY EA
    8445-BP-20 GLAND HOLE BLANKING PLUG, M20 (PACK OF 10) EA
    8475-CO-RS RS232/485 CONVERTER, CABLE AND 9V PWR SUPPLY EA
    85675 2MB VIDEO PWB EA 51196935-907
    8601-FT-NI Field Terminal, Non-Incendive, Standard EA
    8602-FT-ST Field Terminal, Standard EA
    8603-FT-FU Field Terminal, Non-incendive, Fused EA
    8604-FT-FU Field Terminal, Fused EA
    8605-FT-TC Field Terminal, thermocouple EA
    8606-FT-RT Field Terminal, RTD EA
    8610-FT-NA Field Terminal, Non-arcing, Standard EA
    8611-FT-FU Field Terminal, Non-arcing, Fused EA
    8615-FT-4W Field Terminal, 4-wire, Current Sinking EA
    8617-FT-16 Field Terminal, 16-channel DI EA
    8621-FT-IS IS FIELD TERMINAL, STANDARD EA
    8622-FT-IS IS FIELD TERMINAL, LOOP-DISCONNECT EA
    8623-FT-IS IS FIELD TERMINAL, 16-CHANNEL DIGITAL INPUT EA
    8624-FT-IS IS Field Terminal, 8-chnl DI, Loop Disconnect EA
    8625-FT-IS IS FIELD TERMINAL, 8-CHANNEL T/C INPUT EA
    8626-FT-IS IS FIELD TERMINAL, 8-CHANNEL RTD INPUT EA
    86619 ADAPTOR, 2940 EA 51196935-907
    8707-CA-08 8-module Carrier EA
    8710-CA-04 4-module Carrier EA
    8716-CA-NS Node Services Carrier EA
    8720-CA-04 4-module IS Carrier EA
    8724-CA-PS IS Module Power Supply Carrier EA
    8725-CA-RB Railbus Isolator Carrier EA
    8727-CA-08 8-module IS Carrier EA
    8731-CA-NS ZONE 1 CARRIER, BIM + 8 MODULES EA
    87346 PWR SUPPLY, 200 W EA
    8737-CA-08 ZONE 1 CARRIER, 8 MODULE EXTENTION EA
    87757 64MB ECC S DRAM EA 51196971-100
    87758 DIMM, 128 ECC SDRAM EA
    87760 PWB, 2MB VIDEO BOARDUPGRADE EA
    87998 KEYBOARD, 104 EA 4939R
    88258 PROCESSOR, 80522,266MHz,512K NONECC EA 83613
    88406 MTHRBD,10/100 LT EA 80585
    88672 FLOPPY DR 144M F3 NC 2MD EA
    886MJ MSE,PS2,6P,2BTN,WHL,MS EA
    8913-PS-AC-HON System and Field Power Supply, AC Mains EA
    8914-PS-AC-HON Field Power Supply, AC Mains EA
    8920-PS-DC-HON IS Module Power Supply, 24VDC Input EA
    8922-RB-IS Railbus Isolator EA
    8927-PS-AC UNIVERSAL AC PWR SUPPLY & CBL, AUX PORT FCAR EA
    8930-PS-AC-HON ZONE 1 POWER SUPPLY, 115VAC INPUT EA
    8931-PS-AC-HON ZONE 1 POWER SUPPLY, 230VAC INPUT EA
    8940-EN-08-HON ZONE 1 ENCLOSURE, BIM + 8 MODULE SYSTEM EA
    8941-EN-XT-HON ZONE 1 ENCLOSURE, 8 MODULE EXTENTION EA
    8942-EN-08-HON ZONE 1 ENCLOSURE, BIM + 8 MODULE - DUST PROTC EA
    8943-EN-XT-HON ZONE 1 ENCLOSURE, 8-MOD EXTENSION, DUST PROTC EA
    8946-GL-00 GLAND PLATE-UNDRILLED, ZONE 1 ENCLOSURE/EXTEN EA
    8947-GL-01 GLAND PLATE-DRILLED, ZONE 1 ENCLOSURE/EXTENSN EA
    8950-EN-16-HON Field Enclosure, 16-module, 2/2 EA
    8951-EN-12-HON Field Enclosure, 12-module, 2/1 EA
    8952-EN-12-HON Field Enclosure, 12-module, 2/2 + 2/1 EA
    8954-GL-00 Gland Plate, Undrilled 12/16-Module Enclosure EA
    89547 PWB, APAPT, NETWORK 10/100 EA
    8955-GL-01 Gland Plate Drilled, 12/16-module Enclosure EA
    9019C CABLE DATA FD, HM EA
    91289 MOUSE, PS2 EA 51196935-900
    9171E RISER, 7 SLOT ACTIVE EA 51196982-959
    9228C POWER SUPPLY 200 WATT EA 51196982-903
    93192 64MB ECC RAM EA 51196935-903
    93630 200MHZ PROCESSOR BD EA
    93906 PWA, RISER, 5 SLOT EA
    95130 KEYBOARD, 104 EA 51196935-901
    95267 32MB MEMORY DIMM EA
    95362 2GB H/D EA 51196935-922
    95821 FLOPPY DRIVE, 1.44MB EA
    96013758 HARD DRIVE 4MB SCSI (MOTOROLA PART) EA 51196968-100
    96014128 CD ROM DRIVE 2X EA 51196982-906
    96014158 MPXPII DESKTOP W/MB,PS, FLOPPY (MOTOROLA) EA
    96014159 MPXPII MINITOWER W/ MB, PS, FLPY (MOTOROLA) EA
    96014160 MOTHERBOARD W/PROC 300MHZ (MOTOROLA PART) EA 51196969-916
    96014164 PWB, 64MB SDRAM DIMM EA 51196321-100
    96014166 PWB,SCSI,PCI EA 51196969-907
    96014167 PWB,GRAPHICS, 4MB APG SVAG EA 51191564-100
    96014375 64MB ECC EDO RAM MEM EA 51196321-100
    9603C CD 680M 14/32X EA 51196982-906
    96807 SWT ASSM ALARM NTRUS16.5IN EA
    97624 PROC 180MH, 256K EA
    9C475 PWA,PLN.GX200,NIC,VID,OPLX EA 51198718-912
    BC-GART13 RTD(16) GI/IS FTA (4073), Comp Term, Coated EA
    BC-GART23 RTD(16) GI/IS FTA (4073) w/2nd Cur Output, CC EA
    BC-GATC13 T/C (16) GI/IS FTA (4073), Comp Term, Coated EA
    BC-GATC14 T/C(16) GI/IS (4073) FTA, Russian XK Type, CC EA
    BC-GATC23 T/C(16) GI/IS FTA (4073) w/2nd Cur Output, CC EA
    BC-GBSF13 AO(8) GI/IS w/Line Fault Detect FTA, Coated EA
    BC-GDOD13 DO(16) 24VDC SS GI/IS w/Override FTA, Coated EA
    BC-GDOD14 DO(16) 24VDC SS MAG GI/IS w/Override FTA, CC EA
    BC-GHAI11 GI/IS FTA, HLAI HART (16), COATED EA
    BC-THAI11 FTA, HLAI HART (16), COATED EA
    BU-ELLMUX-MTL LLMUX Kit, Zone 0 EA
    BU-GHAI11 GI/IS FTA, HLAI HART (16) EA
    BU-SLLMUX-MTL LLMUX Kit, Zone 0, Single Hiway EA
    BU-TAOC02 Analog Output Combiner Panel for GI/IS EA
    BU-TDOC02 Digital Output Combiner Panel for GI/IS EA
    BU-THAI11 FTA, HLAI HART (16) EA
    C-AA100 PWB EA 62795604-001
    C-AA101 PWB EA 30734772-001
    C-AA190 PWB EA 62795604-001
    C-AA191 PWB EA 30734772-001
    C-AA200 PWB EA 62795604-002
    C-AA201 PWB EA 30734772-002
    C-AA290 PWB EA 62795604-002
    C-AA291 PWB EA 30734772-002
    C-AC100 SINGLE UNIT CASE EA 30669206-001
    C-ACC01 PWB ANNALOG CALIB CARD EA 62795705-002
    C-ACC03 CALIBRATION CARD EA 62795705-004
    C-ACJ00 REISTOR ASSM EA 30732138-001
    C-ACU00 AU CAL EA 62795705-001
    C-AEX01 SQ ROOT EXTR EA 30731722-002
    C-AF000 AUXILIARY FILE ASSM EA 30731575-001
    C-AF002 AUXILIARY FILE ASSM EA 30731575-002
    C-AMH00 AUXILIARY PWA EA 30731723-001
    C-AMH90 AUX PWA EA 30731723-001
    C-AML01 2MV/I AUX EA 30731721-002
    C-AML02 2MV/I AUX EA 30731721-003
    C-AML91 2MV/I AUX EA 30731721-002
    C-AML92 MV-I CARD,2-100MA EA 30731721-003
    C-AML93 C-AML03 2MV/I AX(18) EA 30731721-004
    C-APM00 PWB EA 62795610-001
    C-APM90 PWB EA 62795610-001
    C-AR000 RELAY EA 30731674-001
    C-ARB01 R/I FM+CSA APPR EA 30731724-002
    C-ARB02 R/I AUX BASEEFA EA 30731724-003
    C-ARB03 R/I AUX BASEEFA EA 30731724-004
    C-ARB10 R/I FM+CSA APPRO EA 30731724-002
    C-ARB91 R/I FM+CSA APPRO EA 30731724-002
    C-ARB92 C-ARB02 R/I AUX (11) EA 30731724-003
    C-ARB93 C-ARB03 R/I AUX (11) EA 30731724-004
    C-ARM00 RELAY MOUNTING PANEL EA 30731993-001
    C-ARR01 XXXX EA 30731995-001
    C-ARR02 RANGE RES PKG (8 PER PACKAGE) EA 30731995-002
    C-ARR03 RANGE RESISTOR - ORDER 8 30731996-003 EA 30731996-003
    C-ARR04 RANGE RES PKG (4 PER PACKAGE) EA 30731995-004
    C-ARR05 RANGER RESISORS EA 30731995-005
    C-ARR06 RANGE RESISTORS EA 30731995-006
    C-ARR10 PARTS KIT-OUTPUT EA 30751404-001
    C-ARR11 RANGE RESISTORS EA 30731995-007
    C-ARR12 RANGE RESISTORS EA 30731995-008
    C-ARR13 RANGE RESISTORS EA 30731995-009
    C-ARR14 RANGE RESISTORS EA 30731995-010
    C-ARR15 RANGE RESISTORS EA 30731995-011
    C-ARR16 RANGE RESISTORS EA 30731995-012
    C-ASC00 PWB W/87 SGL SELECTOR EA 62795613-001
    C-ASC90 PWB W/87 SGL SELECTOR EA 62795613-001
    C-ASD00 PWB (W10/98)C-ARB01 AUX EA 30731719-001
    C-ASK00 SPARE PARTS KIT EA 30736356-001
    C-ASL00 S/L PWB EA 62795601-001
    C-ASL90 S/L PWB EA 62795601-001
    C-ATC00 EXT CARD FOR AF000 EA 30731906-001
    C-AXD00 (W10/98)MULT/DIV AUX EA 30731720-001
    C-AXD90 (W10/98)MULT/DIV AUX EA 30731720-001
    C-AZL01 INTEGR-LINEAR EA 62795607-003
    C-AZL91 INTEGR-LINEAR EA 62795607-003
    C-AZS01 SQRT08 PWB EA 62795607-004
    C-AZS91 PWB SQRT08 EA 62795607-004
    C-CB020 C-CB020 CTLR I-C EA 30731900-008
    C-CB120 CONTROLLER FILE EA 30731900-010
    C-CB121 CONTROLLER FILE EA 30731900-011
    C-CB200 CONTROLLER FILE EA 30731900-006
    C-CB201 CONTROLLER FILE EA 30731900-007
    C-CB501 BASIC CTLR W/O DEP EA 30731900-012
    C-CB502 BASIC CTLR W/DEP EA 30731900-013
    C-CB701 EXTENDED CTLR W/O DIDEP EA 30731900-014
    C-CB702 EXTENDED CTLR W/DIDEP EA 30731900-015
    C-CBK00 CONTROLLER PARTS KIT EA 30734578-001
    C-CBK01 CONTROLLER PARTS KIT EA 30734578-002
    C-CBK02 CONTROLLER PARTS KIT EA 30734578-003
    C-CBM00 TREND MEMORY PWB EA 30735974-502
    C-CBM01 UPGR, BAS CMOS EA 51196689-100
    C-CBM05 CONTROLLER UPGRADE KIT EA 30753116-001
    C-CBR00 PWA, DHPII ROM EA 30751044-508
    C-CBT00 PWB, TREND MEM. EA 30735974-504
    C-CD100 RCD FILE EA 30735871-004
    C-CD200 EXT CTLR B/DIR EA 30735871-004
    C-CD300 UNIVERSAL RESERVE CTLR DIR (URCD) FOR CB/EC EA 30735871-004
    C-CDD00 FILE, UAC DIG I/O EA 30750897-001
    C-CDM00 PWA, LOOP MANUAL EA 30735873-501
    C-CDS00 ANALOG SWTCHCARD EA 30735863-502
    C-CDS20 DIGITAL SWITCH CARD OPTIONAL EA 30750768-503
    C-DCK00 DISK CLEANING KIT EA 30751731-001
    C-DD420 DIAGNOSTIC DISK EA 30751793-001
    C-DD700 DIAGNOSTIC DISK EA 30751793-004
    C-DEL00 ENTERGY LIMITER EA 30735586-001
    C-DH420 HIWAY TEST DISK EA 30751793-003
    C-DK360 PROG MEDIA R360 EA 30751793-005
    C-DK420 PROG MEDIA R420 EA 30751793-002
    C-DK460 PROG MEDIA R460 EA 30751793-006
    C-DK610 PROG MEDIA R610 EA 30751793-007
    C-DK615 PROG MEDIA R615 EA 30751793-008
    C-DP100 PWA DEP I/F EA 30750318-501
    C-DP200 PWA, DEP I/F EA 30750318-503
    C-DP201 PWA, DEP I/F EA 30750318-502
    C-DPD20 PANEL,DATA ENTRY EA 30731765-002
    C-DPK00 PANEL,DATA ENTRY EA 30734579-001
    C-DPK02 BASIC DEP/EXT DE EA 30751394-001
    C-DPK03 BASIC DEP/EXT DE EA 30751395-001
    C-DPL00 DEP CBL LEFT_ EA 30731866-001
    C-DPR00 DEP CBL RGHT EA 30731866-002
    C-DPX00 DEP SELECTOR EA 30731795-001
    C-DPX20 DEP SLOT SELECTOR EA 30751287-001
    C-DSD55 FDD, 50HZ 8IN EA
    C-DSD61 DISK DRIVE #1 EA 30751139-003
    C-DSD66 FLOPPY DRIVE 60HZ EA 30753419-001
    C-DSG40 KYBD ASSM EA 30751083-001
    C-DSG52 KYBD ASSM EA 30751083-003
    C-DSH00 PWA, 128K MEM EA 30751856-501
    C-DSK72 UPGRADE R615/616 EA
    C-DSM02 CRT KIT EA 51195868-400
    C-DSP01 PWB, PRINTER I/F EA 30735887-501
    C-DSP40 GENICOM PRINTER EA 30754171-001
    C-DSP41 PRINTER&PEDESTAL EA
    C-DSP50 PRINTER EA 51196697-100
    C-DSR01 I/F PWB EA 30732425-501
    C-DSX72 MEM UPDATE KIT EA 30752117-003
    C-DSX86 OP STATION UPGRADE EA 30751313-007
    C-EF051 FAN ASSM, 220/240VAC EA 30733258-008
    C-EF060 FAN ASSM, 115VAC EA 30733258-007
    C-EF151 FAN ASSEMBLY EA 30733258-002
    C-EF160 FAN & PLATE ASSM EA 30733258-001
    C-EF162 FAN & PLATE ASSM EA 30754651-001
    C-EF251 FAN ASSM 24IN, 220V EA 30733258-005
    C-EF260 FAN AND PLATE ASSM EA 30733258-004
    C-EF262 FAN AND PLATE ASSM EA 30754651-003
    C-EPD10 C-EPD10 EA 30732094-003
    C-EPD20 MNTING PLATE EA 30732094-004
    C-EPS20 MNTG PLATE 24IN EA 30732094-002
    C-FMH00 INTEGRITY CARD W/EXTENDER EA 30736260-001
    C-HC100 GPCI EA 30732485-001
    C-HCB01 CB/EC HIWAY EA 30732171-004
    C-HCB20 KIT HWY I/F EA 30732171-005
    C-HCM00 HIWAY COUPLER MO EA 30753732-501
    C-HEX00 HIWAY EXERCISER EA 30735907-001
    C-HL100 DHPII EA 30753004-002
    C-HL200 DHPII EA 30753004-002
    C-HL201 DATA HIWAY PORT EA 30753004-003
    C-HPE20 ENH HIWAY ACCESS EA 30735150-004
    C-HPK20 C-HPE00 TO C-HPE20 UPGRADE KIT EA 30752608-003
    C-HTD10 HTD/C-HTD20 EA 30733174-003
    C-HTD20 HIWAY TRAFFIC DIRECTOR, ENHANCED EA 30733174-003
    C-HTK10 KIT-DIR FILE UPD EA 30752608-001
    C-HTK20 C-HTD00 TO C-HTD20 UPGRADE KIT EA 30752608-002
    C-JCB00 JNCT PANEL,B.C. EA 30731691-001
    C-JDD00 RESERVE JUNC PNL EA 30750780-001
    C-JDP00 JNCT PANEL, PRIM EA 30735876-001
    C-JDR00 RCD JUNCTION PANEL (UAC) EA 30735879-001
    C-JLD00 JNCT PANEL, LONG EA 30731958-001
    C-JMP00 TERMINAL PNL EA 30731950-001
    C-JR000 RCD JUNCTION PNL EA 30750851-001
    C-JSD00 JNCT PANEL,SHORT EA 30731689-001
    C-JYS01 Y - DEP EA 30732126-001
    C-JYS02 Y-MARSHAL PANEL EA 30732128-001
    C-JYS03 Y - MANUAL EA 30732130-001
    C-JYS04 Y - AUTO/MANUAL EA 30732132-001
    C-JYS05 Y - TERM EA 30732134-001
    C-JYS06 Y STANDBY EA 30732135-001
    C-JYS07 JUNCT PANEL, DI EA 30750308-001
    C-JYS08 Y STANDBY EA 30751219-001
    C-KC022 COAX CABLE EA 30732107-001
    C-KC050 COAX CABLE EA 30732107-002
    C-KC075 COAX CABLE EA 30732107-003
    C-KC100 COAX CABLE EA 30732107-004
    C-KC200 COAX CABLE EA 30732107-005
    C-KCA01 COAX TEE QTY2 EA 30732100-001
    C-KCA02 COAX TERM KIT(2) EA 30732107-009
    C-KCA03 COAX CON KIT-LGE EA 30732107-006
    C-KCA04 COAX SPLICE KIT EA 30732107-007
    C-KCA05 SMALL CON KIT(4) EA 30732107-010
    C-KCA06 CRIMP TOOL KIT EA 30732107-011
    C-KCA07 CONNECTOR KIT EA 30732107-012
    C-KCA21 DIRECT BUR KIT EA 30752094-002
    C-KCA23 KIT,DIRECT BURIA EA 30751989-002
    C-KCF00 COM I/F CABLE EA 30732485-002
    C-KD000 CBL SPLICE EA 30732038-002
    C-KD001 CABLE ASSEMBLY 50 COND (1M) EA 51201420-001
    C-KD002 CABLE ASSEMBLY 50 COND (2M) EA 51201420-002
    C-KD003 CABLE ASSEMBLY 50 COND (3M) EA 51201420-003
    C-KD005 CABLE ASSEMBLY 50 COND (5M) EA 51201420-005
    C-KD008 CABLE ASSEMBLY 50 COND (8M) EA 51201420-008
    C-KD015 CABLE ASSEMBLY 50 COND (15M) EA 51201420-015
    C-KD030 CABLE ASEMBLY 50 COND (30M) EA 51201420-030
    C-KD045 CABLE ASSEMBLY 50 COND (45M) EA 51201420-045
    C-KD060 CABLE ASSEMBLY 50 COND (60M) EA 51201420-060
    C-KD901 CABLE ASSEMBLY 50 CON (1.5M) EA 51201420-915
    C-KD902 CABLE ASSEMBLY 50 CON (3M) EA 51201420-003
    C-KDP01 DIGITAL CABLE 1.25M EA 30750509-001
    C-KDP02 DIGITAL CABLE 2M EA 30750509-002
    C-KDP03 DIGITAL CBL 3M EA 30750509-003
    C-KDP05 DIGITAL CBL 5M EA 30750509-005
    C-KDP08 DIGITAL CBL 8M EA 30750509-008
    C-KFN02 FIBR OP CBL ASSY-SMA/SMA EA 30754051-007
    C-KFN10 FIBR OP CBL ASSY-SMA/SMA EA 30754051-010
    C-KFN50 FIBER OPTIC CABLE ASSM EA 30754051-012
    C-KFT02 FIBER OPTIC CBL 2M EA 30754051-001
    C-KFT10 FIBER OPTIC CBL 10M EA 30754051-004
    C-KFT50 FIBER OPTIC CBL 50M EA 30754051-006
    C-KHA11 CABLE ASSEMBLY 15',A/B CBL EA 30753024-001
    C-KHA19 50',A/B CBL EA 30753024-002
    C-KHM11 DEP CABLE 15FT EA 30753023-001
    C-KHM19 DHP CABLE 50' EA 30753023-002
    C-KHM31 DHP CABLE MODIFIED 15' EA 30753022-001
    C-KHM39 DHP CABLE MODIFIED 50' EA 30753022-002
    C-KHM41 CABLE LL 15FT EA 30753020-001
    C-KHM49 I/F CABLE 50FT EA 30753020-002
    C-KR001 RBN CBL FOR UAC 1M EA 30735893-001
    C-KR002 RBN CBL FOR UAC 2M EA 30735893-002
    C-KR003 RBN CBL FOR UAC 3M EA 30735893-003
    C-KR005 RBN CBL FOR UAC 5M EA 30735893-005
    C-KR008 RBN CBL FOR UAC 8M EA 30735893-008
    C-LA201 AUTO/MANUAL W/SNDBY MANL CAP EA 30731737-006
    C-LAK00 ANALOG DISP KIT EA 30735465-001
    C-LAS00 ANALOG DISPLAY ASSM EA 30731737-003
    C-LC101 MANUAL W/STANDBY MANUAL CAP EA 30731737-005
    C-LC201 MANUAL W/STDBY EA 30731740-002
    C-LD100 SGL INDICTOR EA 30731738-002
    C-LD200 ASSM,DUAL VERT EA 30731738-003
    C-LMD00 MANUAL LOADRW/INDICATOR EA 30731739-002
    C-LPC00 ANALOG DISPLAY EA 30731738-001
    C-LPX00 COVER EA 30731944-001
    C-LSL00 ANALOG DISPLAY SCALES EA 30734478-001
    C-LSM01 ONE LOOP STANDBY EA 30734592-001
    C-LSM04 FOUR LOOP STANDBY EA 62795649-001
    C-LSN00 ANALOG DISPLAY SCALES EA 30734479-001
    C-LT200 TRIM KIT DUAL TRIM_ EA 30731963-001
    C-LTK00 PARTS KIT EA 30736357-001
    C-MH121 BACKPANEL KIT 21IN EA 30732101-008
    C-MH128 BACKPANEL KIT 28IN EA 30732101-001
    C-MH156 MOUNTING HARDWARE EA 30732101-002
    C-MH163 MOUNTING HDW EA 30732101-003
    C-MH177 BACKPANEL KIT 77IN EA 30732101-005
    C-MH200 MOUNTING HARDWARED EA 30732101-006
    C-MH400 SUPPORT TRAY ASSEMBLY EA 30751519-001
    C-MHK00 ANGLE BRACKET EA 30732160-001
    C-MHK01 ANGLE BRACKET EA 30732160-002
    C-MHP00 SIDE PLATE EA 30732101-007
    C-MPK00 MOUNTING KIT EA 30732160-001
    C-MPK01 ANGLE BRACKET EA 30732160-002
    C-PSM01 PWR SPLY MTG KIT EA 51195023-004
    C-PSM02 POWER SUPPLY MOUNTING KIT EA 51195023-001
    C-PSM03 PWR SPLY MTG KIT EA 51195023-005
    C-PSM04 PWR SPLY MTG KIT EA 51195023-006
    C-PSM05 PWR SPLY MTG KIT EA 51195023-002
    C-PSM06 PWR SPLY MTG KIT EA 51195023-003
    C-RP260 TDC RECORDER EA 30670667-999
    C-RT200 RECRD TRIP STRIP EA 30734551-001
    C-RTM01 TERM PNL,REMOTE EA
    C-SBH01 BBU MOUNTING HARDWARE EA 30734680-001
    C-SBK01 BBU PARTS KIT EA 30735088-001
    C-SBK11 BBU TRAY KIT EA 30735088-002
    C-SBM01 BBU MTG KIT-19 IN EA 51195022-002
    C-SBM02 BBU MTG KIT-24 IN EA 51195022-001
    C-SBU01 BATTERY BACKUP ASSM EA 30734500-003
    C-SBU02 BATTERY BACKUP ASSM EA 30734500-004
    C-SBU11 BATT B/U110/115V W/MERC RELAY EA 30734500-001
    C-SCD61 24VAC XFMR, 60HZ EA 30732495-001
    C-SDA00 RED'T PWR DISTRI EA 30732220-001
    C-SJA00 P/S JUNCTASM+24V AND COM EA 30732175-001
    C-SSC51 7A 50HZ PWR SPLY EA 30732106-005
    C-SSC61 7A PWR SPLY KIT EA 30732106-001
    C-STC50 20A 50HZ PWR SP EA 30732106-004
    C-STC51 20A 50HZ PWR SPL EA 30732106-006
    C-STC61 20A PWR SPLY KIT EA 30732106-002
    C-SW204 PWR JUNC BLK EA 30732172-204
    C-SW904 PWR JUNC BLK EA 30732172-904
    C-TAF00 TERM PANEL, AUX EA 30731391-001
    C-TB010 OUTPUT MOD (IS) EA 49788042-001
    C-TBL10 LINK MOD EA 49788031-001
    C-TBR10 BARRIER RESISTOR MODULE EA 30751228-001
    C-TBU10 BARRIER BOX USA EA 49788023-001
    C-TBU11 BARRIER BOX EA 49788023-002
    C-TBU12 BARRIER BOX EA 49788023-003
    C-TCB20 CONTROLLER TERMINAL PANEL EA 30751315-001
    C-TCB21 CONTROLLER TERMINAL PANEL EA 30751315-002
    C-TCB30 TERMINAL PANEL EA 30671513-001
    C-TPDI-01 HLPIU INPUT PNL EA
    C-TPM01 REMOTE MARSHALLING PANEL EA 30731865-001
    C-TPM02 LOCAL MARSHALLING PANEL EA 30731857-001
    C-TRD00 TERM PANEL RED/IND EA 30731408-001
    CREDIT SPECIAL CREDIT EA
    EJG00-05300 FUSE 3A EA 80350750-003
    FBT-2 FIELDBUS WIRE TESTER EA
    FBT-3 FIELDBUS NETWORK TESTER EA
    H94364700 FILTER,AIR EA 51107109-291
    HI-ASPI01-100 GUS D/M PRNTR //PORT EA
    HI-ASPIP1-100 GUS D/M PRNTR PEDESTAL EA
    HI-DZIP00-100 ZIP DRIVE KIT EA 51196932-100
    HI-TPMED1 ORDER QTY 5, 51196706-200 INDIVIDUAL CARTRIDG EA
    HI-ZHIKB1-100 Z GUS TO IKB EA
    HI-ZLRPD1-200 DUAL NODE RELOCATIONKIT FOR GUS, Z CONS. MED EA
    HI-ZLRPD1-300 DUAL NODE RELOCATIONKIT FOR GUS, Z CONS. TALL EA
    HI-ZPMED1-100 BLNK ZIP CTDG (10PK) EA 51196929-160
    J-AAU00 A/I ADAPTER UNIT EA 80360713-001
    J-AOF00 R20 A/O MODULE EA 80360143-012
    J-AOF10 R20 A/O MODULE EA 80360143-012
    J-AOM00 A/O MODULE EA 80360143-011
    J-AOM10 A/O MODULE EA 80360143-011
    J-BCA00 I/O ADAPTER EA 80360912-001
    J-BCK30 BASE UNIT CONTACT CABLE I/O (3M) EA 80361088-300
    J-BTP00 TERMINAL PANEL EA 80360915-001
    J-BUA00 BASE UNIT ADAPTER EA 80360643-001
    J-CBC00 IBC I/O BUS CARD EA 82407387-001
    J-CBC03 PWB, SBLA III EA 82408485-001
    J-CBC50 PWB, UAC I/F R30 EA 82408440-001
    J-CBM55 PWB, B/U MEMORY EA 82408456-002
    J-CDD50 FILE EA 82407045-001
    J-CDM50 BACKUP MEM FILE EA 82407046-001
    J-CDS50 PWB, I/O BUS SW EA 82408467-001
    J-DBK00 BLANK DISKS (10) EA
    J-DBK05 BLANK DISKS (10) EA
    J-DBK10 CONFIG DISKS(10) EA
    J-DBK15 CONFIG DISKS(10) EA
    J-DBK20 TREND DB PKG(10) EA
    J-DBK25 TREND DISKS (10) EA
    J-DBK30 SOPL DISKS (10) EA
    J-DBK35 SOPL DISKS (10) EA
    J-DBK40 RECIPE DISKS(10) EA
    J-DBK45 RECIPE DISKS(10) EA
    J-DCC00 LOC COMP I/F EA 82408309-002
    J-DCL10 OPTIC BARRIER EA 82408646-002
    J-DD520 R520 DIAG PKG EA
    J-DD525 R525 DIAG PKG EA
    J-DD530 R530 DIAG PKG EA
    J-DIF00 D/I MODULE W/FTB EA 80360139-002
    J-DIF10 DIGITAL INPUT MODULE -48VDC W/FTB EA 80360198-002
    J-DIM00 DIGITAL INPUT MODULE (32) EA 80360139-001
    J-DIM10 DIGITAL OUTPUT MODULE -48VDC EA 80360198-001
    J-DK520 R520 DISK PKG EA P-DK520
    J-DOF00 D/O MODULE WITH FRONT TERM 16S/S EA 80360140-012
    J-DOF10 D/O MODULE W/FTB EA
    J-DOF20 RELAY D/O MODULE WITH FTB EA 80360195-002
    J-DOM00 DIGITAL OUTPUT MODULE 16 SOLID STATE EA 80360140-011
    J-DOM10 DIGITAL OUTPUT MOD 16+16 SO-SOLID STATE EA 80360140-001
    J-DOM20 DIGITAL OUTPUT MODULE -16 RELAY OUTPUTS EA 80360195-001
    J-DSG53 ASM, KEYBD FLAT EA 82115280-001
    J-DST52 ASSM, TREND I/F EA 82115012-001
    J-DST53 TREND I/F ASSM EA 82115012-002
    J-EEK02 EC-LINK EXTERNAL CABLE 2M EA 80360636-020
    J-EEK05 EC-LINK EXTERNAL CABLE 5M EA 80360636-050
    J-EEK20 CABLE, 20M EC-LINK EA 80360636-200
    J-EIC00 EC-LINK CABLE EA 80360621-005
    J-EIC10 CABLE, 1M EC-LINK INTERNAL CABINET USE EA 80360621-001
    J-ELA00 EC-LINK ADAPTER EA 80360645-001
    J-ELA10 EC-LINK ADAPTOR EA 80360646-001
    J-ELT00 EC-LINK TERMINATOR EA 80360163-001
    J-FTB00 FRONT TERMINAL PANEL EA 80360155-001
    J-HAF00 HL A/I MOD W/FTB EA 80360142-001
    J-HAF10 HIGH LEVEL ANALOG INPUT 16 FOR UAC W/FTB EA 80360141-012
    J-HAM00 HIGH LEVEL ANALOG INPUT EA 80360141-011
    J-HAM10 HIGH LEVEL ANALOG INPPUT FOR UAC EA 80360141-011
    J-HCX00 HC I/F MODULE EA 80360144-001
    J-HIC00 CABLE-AMC TO AMC EA 80360619-001
    J-HIC10 CABLE-AMC TO I/F EA 80360620-001
    J-HIC20 CBL,.9M UAC INTERNAL CABINET USE EA 80360697-001
    J-HMF00 HL ANA MUX W/FTB EA
    J-HMM00 HIGH LEVEL ANALOG MULTIPLEXER MODULE EA 80360142-001
    J-HPA20 HCIM POWER CABLE EA 80360641-200
    J-JDD50 PRIM SO JNCT PNL EA 82408476-001
    J-JDD51 RESERVE SO JCT PNL ASSM EA 82408479-001
    J-JDD55 S/O DISTRI PANEL EA 82408482-001
    J-KDB01 DATA BUS CABLE 1M EA 82408609-201
    J-KDB03 DATA BUS CABLE 3M EA 82408609-205
    J-KDB05 DATA BUS CABLE 5M EA 82408609-202
    J-KDB10 DATA BUS CABLE 10M EA 82408609-204
    J-KE001 CABLE, I/O 1M EA 82408007-001
    J-KE002 CABLE, I/O 2M EA 82408007-002
    J-KE003 CABLE, I/O 3M EA 82408007-003
    J-KE005 CABLE, I/O 5M EA 82408007-005
    J-KE008 CABLE, I/O 8M EA 82408007-008
    J-KE030 CABLE, I/O 30M EA 82408007-030
    J-KE115 CABLE, I/O 1.5M EA 82408007-501
    J-KR050 CABLE, I/O BUS EA 82407498-001
    J-KR051 CABLE, I/O BUS EA 82407499-001
    J-KR501 I/O BUS CBL,1.4M EA 82408609-101
    J-KR505 I/O BUS CBL, 5M EA 82408609-102
    J-KR510 I/O BUS CBL 10M EA 82408609-104
    J-KRA00 C-LINK ADP EA 82408061-002
    J-KRE02 CBL,C-LINK 2M EA 82408175-002
    J-KRE10 CBL,C-LINK 10M EA 82408175-010
    J-KRE20 CBL,C-LINK 20M EA 82408175-020
    J-KRE30 CBL,C-LINK 30M EA 82408175-030
    J-KRL30 CBL SET EA 82408433-003
    J-KRL40 CABLE SET EA 82408433-004
    J-KRS20 CABLE SET 2M EA 82408433-001
    J-MBU00 AMC R10 BASE EA 80360137-001
    J-MBU01 AMC R20 BASE EA 80360136-001
    J-MHM00 HWAY I/F MOD EA 80360146-011
    J-MHM10 R20 HWAY I/F MOD EA 80360146-011
    J-MSC00 CTRL MODULE EA 80360145-011
    J-MSC10 R20 CTR MODULE EA 80360145-011
    J-PCM20 I/O MOD EA 80350859-001
    J-PCM40 E/T/P RELAY ASSM EA 82408310-001
    J-PCM50 E/T/P RELAY ASSM EA 82408310-002
    J-PDP00 PWR DIST PANEL EA 80360181-001
    J-PF100 MC PT CARD FILE EA 82407025-100
    J-PF200 MC PT CARD FILE EA 82407025-200
    J-PIF00 PULSE IN W/FTB EA 80360185-002
    J-PIM00 PULSE INPUT MODULE 8 INPUTS EA 80360185-001
    J-RRK02 REDUN I/O CBL 2M EA 80360171-020
    J-RRK15 UAC I/O CABLE 15M EA 80360171-150
    J-RRL20 UAC I/O CABLE 2M EA 80360171-020
    J-RRL30 CABLE, 30M UAC EA 80360171-030
    J-RRL50 UAC I/O CABLE 5M EA 80360171-050
    J-RRL80 UAC I/O CABLE 8M EA 80360171-080
    J-RSK01 I/O CABLE 1M EA 80360170-001
    J-RSK02 I/O CABLE 2M EA 80360170-020
    J-RSK03 I/O CABLE 3M EA 80360170-030
    J-RSK05 I/O CABLE 5M EA 80360170-050
    J-RSK08 I/O CABLE 8M EA 80360170-080
    J-RSK15 I/O CABLE 15M EA 80360170-150
    J-RSK30 I/O CABLE 30M EA 80360170-300
    J-RSK50 50M I/O CABLE EA 80360170-500
    J-RSL15 I/O CABLE 1.5M EA 80360170-015
    J-RTP00 DIGITAL I/O REMOTE TERMINAL PANEL EA 80360695-001
    J-RTP10 A/I REMOTE T.P. EA 80360677-001
    J-RTP20 ANALOG OUTPUT REMOTE TERMINAL PANEL EA 80360693-001
    J-RTP30 ANALOG OUTPUT RTP W/STANDBY MANUAL JACK EA 80360680-001
    J-RTP40 DUAL DIGITAL OUTPUT PANEL EA 80360686-001
    J-RTP50 PULSE INPUT TERMINAL PANEL EA 80360689-001
    J-RTP80 DIGITAL OUTPUT REMOTE TERMINAL PANEL EA 80361024-001
    J-STF00 SMT TR I/F W/FTB EA
    J-STM00 SM TRANS I/F-AMC EA 80360199-001
    J-SWP00 M/F SWITCH PANEL EA 82116383-001
    J-TCB50 I/O TERM PANEL EA 82407372-001
    J-TPF10 TERMINAL PANEL EA 82407438-001
    J-TPF20 TERMINAL PANEL EA 82408363-001
    J-TPF40 TERMINAL PANEL EA 82407444-001
    J-TPX00 TERM PANEL SUP EA
    J-TPX10 MTG KIT,TERM PNL EA 80360175-001
    J-UDM00 R20 UAC DIR MOD EA 80360147-001
    KBM-US KYBD, W/MOUSE EA 51196708-180
    L2-M011-2010 110V MODEM EA 51196265-100
    L2-M012-2010 220V MODEM EA 51196265-200
    L5-R051-2100 HR100 REMOD,110V EA 51196266-100
    L5-R052-2100 HR100 REMOD,220V EA 51196266-200
    L6-M000-2000 MAPWARE CABLE EA 51196264-100
    MC-FAN511 240V FAN W/ALARM-SEE NOTE FIELD EA
    MC-FAN611 120V FAN W/ALARM-SEE NOTE FIELD EA
    MC-GAIH13 HLAI/STI GI/IS FTA RED. W/COMPRN TERM EA 51304718-175
    MC-GAIH14 HL/STI GI/COMP CC EA 51304730-175
    MC-GAIH22 HL GI FTA COMP CC EA 51304748-175
    MC-GAIH83 FTA,_RED_HLAI/STI_GI/IS_CRIMP,_CE,_CC EA 51304718-375
    MC-GAIH84 FTA,_RED_HLAI/STI_GI/IS_CRIMP,_CE,_CC EA 51304730-375
    MC-GAIH92 FTA,_GAL_HLAI_AUX_CRIMP,_CE,_CC EA 51304748-375
    MC-GAOX02 FTA,_A/O_GI/IS_COMP,_CE,_CC EA 51304638-175
    MC-GAOX12 FTA,_RED_A/O_GI/IS_COMP,_CE,_CC EA 51304638-575
    MC-GAOX72 FTA,_A/O_GI/IS_CRIMP,_CE,_CC EA 51304638-375
    MC-GAOX82 FTA, RED A/O GI/IS CRIMP, CE, CC EA 51304638-775
    MC-GDID12 FTA, GI DI MTL COMP CE/CC EA 51304640-175
    MC-GDID13 DI 24VDC FTA GI COMP EA 51304728-175
    MC-GDID82 GI/IS DI FTA EA 51304640-375
    MC-GDID83 GI/IS DI FTA EA 51304728-375
    MC-GDOD12 FTA,_24VDC_D/O_GI/IS_COMP,_CE,_CC EA 51304642-175
    MC-GDOD82 FTA,_24VDC_D/O_GI/IS_CRIMP,_CE EA 51304642-375
    MC-GDOL12 FTA,_DO_GI/IS_COMP,_COATED,_CE EA 51304736-175
    MC-GDOL82 FTA,_DO_GI/IS_CRIMP,_COATED,_CE EA 51304736-375
    MC-GFBS01 GI/IS FIELDBUS I/F FTA, 4 NETS EA 51309254-275
    MC-GHA011 AO GI/IS FTA (16), HART CC EA 51309540-175
    MC-GHAO11 FTA, GI/IS AO HART EA 51309540-175
    MC-GIAH83 FTA, RED HLAI/STI GI/IS CRIMP, CE CC EA 51304718-375
    MC-GOAX72 FTA, A/O GI/IS CRIMP, CE, CC EA 51304638-375
    MC-GRMT01 RH MUX CC EA 51404106-175
    MC-GRPA01 IS FTA CC EA 51304724-175
    MC-HPFH01 HPM FILE ASSM 7L CC EA 51404125-250
    MC-HPFH11 HPM FILE ASSM 7R CC EA 51404126-250
    MC-HPMR01 HPM BD REDN BRD SET-SEE NOTE FIELD EA
    MC-HPMS01 HPM BD SET-SNGL-COAT-SEE NOTE FIELD EA
    MC-IOFX03 HPM FILE 15 EC CC EA 51404193-475
    MC-PAIH03 IOP, HLAI (CC) EA 51304754-150
    MC-PAIL02 IOP, LLAI CC EA 51304481-150
    MC-PAOX03 PWA, AO/IOP (EC)(CC) EA 51309152-175
    MC-PAOY22 HPM HD I/O IOP EA 80363969-150
    MC-PAR111 PWR SUPPLY 115V 8A REDUNDANT CC EA 51401140-650
    MC-PAR121 P/S RED 115V 16AMP CC EA 51401140-250
    MC-PAR211 AC-ONLY POWER SYSTEM-RED,240VAC,8AMP,NON-CE EA 51401140-850
    MC-PAR221 AC-ONLY POWER SYSTEM-RED,240VAC,16AMP,NON-CE EA 51401140-450
    MC-PAS111 AC-ONLY POWER SYSTEM-SGL,120VAC,8AMP,NON-CE EA 51401140-550
    MC-PAS121 AC-ONLY POWER SYSTEM-SGL,120VAC,16AMP EA 51401140-150
    MC-PDIS11 RED DISOE2(CC) EA 51402625-175
    MC-PDIS12 DI-SOE REDUNDANT IOP, CC EA 51402625-175
    MC-PDIX02 DI IOP, COATED, PWA EA 51304485-150
    MC-PDIY22 DI IOP COATED EA 80363972-150
    MC-PDOX02 DO IOP, COATED, PWA EA 51304487-150
    MC-PDOY22 DO IOP, COATED, PWA EA 80363975-150
    MC-PFBS01 FIELDBUS I/F PROCESSOR, 4 NETS CC EA 51309510-175
    MC-PLAM02 IOP, LLAI CC EA 51304362-150
    MC-PPIX02 IOP,PULSE INP CC EA 51304386-150
    MC-PSDX02 IOP, SER DEV CC EA 51304362-250
    MC-PSIM11 IOP, SER I/F CC EA 51304362-350
    MC-PSRB04 P/S RED 10A W/BBU & MNTG EA 51404174-375
    MC-PSRX04 P/S 20A RED W/MNTG EA 51404174-275
    MC-PSSX04 P/S SGL 20A W/MNTG EA 51404174-175
    MC-PSTX02 MV STI PWA EA 51304516-150
    MC-PSTX03 MV STI PWA EA 51304516-250
    MC-TAIH02 FTA,HLAI-ST CC EA 51304453-150
    MC-TAIH03 FTA, 6IN HLAI, CE, CC EA 51309136-175
    MC-TAIH12 FTA,HLAI RED CC EA 51304337-150
    MC-TAIH13 FTA, 12IN HLAI COMP, CE, CC EA 51309138-175
    MC-TAIH22 HD FTA, HLAI/STI COMP, CC EA 51204170-250
    MC-TAIH23 HD FTA, HLAI/STI COMP, CE, CC EA 51204170-275
    MC-TAIH52 FTA, HLAI-ST CC EA 51304337-250
    MC-TAIH53 FTA, 12IN HLAI SCREW, CE, CC EA 51309138-275
    MC-TAIH62 HD FTA, HLAI/STI SCREW, CC EA 51204168-150
    MC-TAIL02 FTA, LLAI CC EA 51304437-150
    MC-TAIL03 FTA MOTHERBOARD, LLAI-8 CE, CC EA 51309202-175
    MC-TAMR02 FTA, LLMUX RTD, EC, CC EA 51309218-175
    MC-TAMR03 FTA, LLMUX RTD, EC, CC EA 51309218-175
    MC-TAMT02 FTA, LLMUX TC, EC, CC EA 51309223-175
    MC-TAMT03 FTA, LLMUX TC, EC CC EA 51309223-175
    MC-TAMT12 FTA, LLMUX TC W/RCJR, CE, CC EA 51309213-175
    MC-TAOX02 FTA, A/O CCCE EA 51304476-175
    MC-TAOX12 FTA, A/O RED CC EA 51304335-175
    MC-TAOX52 A/O RED W/SCREW EA 51304335-275
    MC-TAOY22 HD FTA, AO COMP W/STBY, CE, CC EA 51204172-175
    MC-TAOY23 AO FTA RED EA 80366177-250
    MC-TAOY52 HD FTA, AO SCREW W/STBY, CE, CC EA 51204174-175
    MC-TAOY53 AO FTA RED EA 80364007-250
    MC-TDIA12 FTA, D/I 120V CC EA 51304439-175
    MC-TDIA22 FTA, D/I 240V CC EA 51304431-175
    MC-TDIA52 FTA, D/I 120V CC EA 51304439-275
    MC-TDIA72 FTA, 120VDI (CC) EA 51303930-150
    MC-TDID12 FTA,D/I 24VDC CC EA 51304441-175
    MC-TDID52 FTA,DIG INPUT 24VDC EA 51304441-275
    MC-TDID72 FTA,D/O 24VDC CC EA 51303928-150
    MC-TDIY22 FTA, DI 24VDC COMP, CE, CC EA 51204160-175
    MC-TDIY62 FTA, DI 24VDC SCREW, CE, CC EA 51204154-175
    MC-TDOA13 FTA, 120/240VAC SS D/O COMP, CE, CC EA 51304648-175
    MC-TDOD13 FTA, 3/30VDC D/O COMP, CC EA 51304650-150
    MC-TDOD23 FTA, 21/200VDC DO COMP, CE, CC EA 51309154-175
    MC-TDOD53 FTA, 3/30VDC D/O SCREW, CC EA 51304650-250
    MC-TDOD54 DO 3-30VDC SCRW T E C CC EA 51309153-275
    MC-TDOR12 FTA, 120V RELAY DO COMP, CE, CC EA 51309148-175
    MC-TDOR22 FTA, 240V RELAY CC EA 51309150-175
    MC-TDOR52 FTA, 120V RELAY DO SCREW, CE, CC EA 51309148-275
    MC-TDOY22 FTA, DO 24VDC COMP, CE, CC EA 51204162-175
    MC-TDOY23 HD FTA, DO RELAY COMP, CE, CC EA 51204166-175
    MC-TDOY62 FTA, DO 24VDC SCREW, CE, CC EA 51204156-175
    MC-TDOY63 HD FTA, DO RELAY SCREW, CE, CC EA 51204164-175
    MC-TDPR02 FTA D/I PWR DIST EC EA 51304425-175
    MC-TFBS01 FIELDBUS I/F FTA, 4 NETS EA 51309254-175
    MC-TFBS11 FIELDBUS I/F FTA, 4 NETS, NO PWR CONDITIONERS EA 51309254-375
    MC-THA011 AO FTA (16), HART CC EA 51309542-175
    MC-THAO11 FTA, AO HART, COATED EA 51309542-175
    MC-TLPA02 FTA, LLMUX/SDI/SI PWR ADAPTER, CC EA 51309204-175
    MC-TPIX12 PI-FTA CONFORM EA 51304084-175
    MC-TSDU02 FTA, SDI I/F CC EA 51303932-278
    MC-TSTX13 HLAI/STI EA 51309142-175
    MC-TSTX53 FTA, 12IN STI SCREW, CE, CC EA 51309142-275
    MC-ZAPR01 APM UPG RED (CC) EA
    MC-ZAPS01 APM UPG SGL (CC) EA
    MC-ZHMR01 HPMM RED UPGD EA
    MC-ZHMR02 HPM 7 SLOT RED EA
    MC-ZHMR11 HPM 15SLOT RED U/G KIT EC EA
    MC-ZHMR12 HPM 7 SLOT RED U/G EA
    MC-ZHPR01 PM/APM TO HPM EA
    MC-ZHPR02 PM-APM TO HPM UG EA
    MC-ZHPR03 NON RED PM/APM TO RED HPM EA
    MC-ZHPR11 PM/APM TO HPM U/G EA
    MC-ZHPR12 PM/APM TO HPM U/G EA
    MC-ZHPR13 N/RED PM/APRM TO REDHPM EA
    MC-ZHPS01 PM/APM TO HPM CONTAINS 2 7 SLOT FILES EA
    MC-ZHPS11 PM/APM TO HPM U/G EA
    MC-ZPSR04 HPM PWR UG (CC) EA
    MC-ZPSUG1 PM PWR SUP UPGRD EA
    MF-BIMS11 BUS INTERFACE MODULE, 1/1 VERSION EA
    MF-CAUX11 AUX/HART SIGNAL CABLE EA
    MF-CAXE11 AUX/HART SIGNAL CABLE EXTENTION EA
    MF-CFCP11 FCA/R POWER CABLE EA
    MF-CIOE11 IOLA & IOLA SIGNAL CABLE EXTENSION PAIR EA
    MF-CIOL11 IOLA & IOLB SIGNAL CABLE PAIR EA
    MF-FCAR11 ZONE 1 FIBRE/COPPER ADAPTER EA
    MF-PWRM2X Power Fail Module EA
    MNTW35WIKXN NT BOOKS W/SFTWR EA 51196708-190
    MP-C8DD01-100 DOOR, DOUBLE, LCN RITTAL TS8 CABINET EA
    MP-C8SD01-100 DOOR, FULL-SIZE, LCN RITTAL TS8 CABINET EA
    MP-CARDR2-100 SINGLE ZIP DRIVE EA
    MP-DCDCK1 US CRTRGE CLEANING KIT EA 51196485-500
    MP-DCDDC2-100 35MB CRTG 5 PAK EA MP-DCDDC3-100
    MP-DCDDC3-100 150MB CRTG 5 PAK EA
    MP-DPRU02-112 RECORDER EA MP-DPRU04-200
    MP-DPRU02-122 2 PEN FAN FOLD EA 51196211-122
    MP-DPRU03-113 RECORDER EA MP-DPRU04-200
    MP-DPRU03-123 3 PEN FAN FOLD EA 51196211-123
    MP-DPRU04-200 3 PEN RECORDER EA
    MP-EZCLP1-100 Universal CRT Clamp Kit EA
    MP-EZEE01-100 AUX EQUIP ENCLOSURE EA
    MP-EZMP01-100 SNGL CRT MOUNT, EZ EA
    MP-EZMP02-100 EZ CNSL,DUAL CRT MOUNT EA
    MP-FHSP10-200 SUPPORT CRT MNTG KIT EA 51197035-400
    MP-FLSP04-200 PRIM CRT MNTG KIT EA
    MP-FOMK02-100 UCNE MTG LCN CAB 120 EA
    MP-FOMK03-100 UCNE MTG LCN CAB 240 EA
    MP-FOMK04-100 UCNE MTG LCN CL 120 EA
    MP-FOMK05-100 UCNE MTG LCN CL 240 EA
    MP-FOMK06-100 UCNE MTG LCN Z MED EA
    MP-FOMK06-200 UCNE MTG LCN Z TALL EA
    MP-M04K4S-100 K4SS 4MW Memory Mezzanine EA
    MP-M08K4S-100 8MW DIMM BOARD-K4 EA
    MP-M16K4S-100 16MW DIMM BOARD-K4 EA
    MP-MEXT01-200 LCNE SET NON-CE EA
    MP-MMEP41-100 BLANK POD&KYBD FILLER EA
    MP-MMEP42-100 Blank Faceplate, Upper or Lower Tier EA 51197055-200
    MP-MMEP51-100 CURVED BASE ALIGN KIT EA
    MP-MMEP52-100 STRAIGHT BASE ALIGN KIT EA
    MP-MMEP53-100 15DEG UPPER TIER KIT EA
    MP-MMEP54-100 CRT MOUNT 30 DEGREE HEAVY EA 51403191-100
    MP-MMPR07-100 PRINTER 120V EA 51196690-100
    MP-MMPR07-200 PRINTER, 230V EA 51196690-200
    MP-MMPR08-100 PEDESTAL,PRINTER EA 51196690-900
    MP-MPPT01 PTR PAPER TRAY EA 51304548-101
    MP-NIMR73-100 Redundant NIM Board, power supply, K4LCN EA
    MP-NIMS73-100 SNGL/NIM K4-4 EA
    MP-REPLC(
    培训)8-100 RED/EPLC(培训)G K4-4 EA
    MP-USCRT1-100 MONITOR EA
    MP-USEL72-100 US-K4 W/O MEMORY EA
    MP-USFM02-200 US FST CRT 21IN EA
    MP-USQT01-100 US,QWERTY OP KYBD W/TKBALL EA
    MP-USTS10-100 TOUCHSCREEN EA
    MP-XLAD10-100 SPARE DRIVE 4GB EA 51402486-800
    MP-ZDNCF1-100 DUAL NODE CARD FILE UPGRADE KIT EA
    MP-ZEAMR1-100 Enh Red AM Upgrade Kit EA
    MP-ZECRT1-100 CRT UPGRADE KIT EA
    MP-ZECRT1-200 ENH 220V CRT KIT EA
    MP-ZECRT2-100 CRT UPGRADE 14IN EA
    MP-ZECRT4-100 CRT UPGRADE 21IN EA
    MP-ZEKBF1-100 ROVING ENG KYBD REPLACEMENT KIT EA
    MP-ZEPLN1-100 EPLC(
    培训) UPGRADE KIT EA
    MP-ZEPLR1-100 EPLC(
    培训) UPGRADE KIT EA
    MP-ZEPLR2-100 EPLC(
    培训) UPGRADE KIT EA
    MP-ZFHUP1-100 FULL UPR POD UPGRADE BLUE/BLK EA
    MP-ZFHUP1-200 FULL HGT U/POD U/G EA
    MP-ZFHUP2-100 FULL UPR POD UPGRADE GREY EA
    MP-ZFHUP2-200 FULL HGT U/POD U/G EA
    MP-ZFHUP3-100 U/POD U/G KIT EA
    MP-ZFHUP4-100 Z-FURN UPR POD UPGR EA
    MP-ZFZIP1-100 SGL FLOPPY TO SGL ZIP DR, TABLE MOUNT EA
    MP-ZFZIP2-100 SGL OR DUAL FLPY TO DUAL ZIP DR, TBL MOUNT EA
    MP-ZFZIP3-100 UWS-DFLPY-ZIP EA
    MP-ZFZIP3-200 UWS TO ZIPDRV 220V EA
    MP-ZGCRT1-100 M/SYNC CRT 21IN EA TP-ZSCRT1-100
    MP-ZGCRT2-100 2ND CRT 21IN UXS U/G EA TP-ZSCRT1-100
    MP-ZHHUP1-100 HALF UPR POD UPGRADE BLUE/BLK EA
    MP-ZHHUP2-100 HALF UPR POD UPGRADE GREY EA
    MP-ZHMK03-100 WREN UPGRADE KIT EA
    MP-ZHMK04-200 WREN UPGRADE KIT EA
    MP-ZHMK05-100 WREN UPGRADE KIT EA
    MP-ZHMK07-200 HM UPGRADE KIT EA
    MP-ZHMK11-100 HM UPGRADE KIT EA
    MP-ZHMK12-100 HM UPGRADE KIT EA
    MP-ZHMK13-100 HM UPGRADE KIT EA
    MP-ZHMK14-100 HM UPGRADE KIT EA
    MP-ZHMK15-100 HM UPGRADE KIT EA
    MP-ZHMK16-100 HM UPGRADE KIT EA
    MP-ZHMK21-100 HM UPGRADE KIT EA
    MP-ZHMK22-100 HM UPGRADE KIT EA
    MP-ZHMK23-100 HM UPGRADE KIT EA
    MP-ZHMK31-100 HM UPGRADE KIT EA
    MP-ZHMK32-100 HM UPGRADE KIT EA
    MP-ZHMK33-100 HM UPGRADE KIT EA
    MP-ZHMK34-100 HM UPGRADE KIT EA
    MP-ZHMK35-100 HM UPGRADE KIT EA
    MP-ZHMK36-100 HM UPGRADE KIT EA
    MP-ZHMK41-100 HM UPGRADE KIT EA
    MP-ZHMK42-100 HM UPGRADE KIT EA
    MP-ZHMK43-100 HM UPGRADE KIT EA
    MP-ZHMK51-100 HM UPGRADE KIT EA
    MP-ZHMK52-100 HM UPGRADE KIT EA
    MP-ZHMK53-100 HM UPGRADE KIT EA
    MP-ZHMK54-100 HM UPGRADE KIT EA
    MP-ZHMU01-100 HM UPGRADE KIT ONE 875 DRIVE (SEE NOTES) EA
    MP-ZHMU02-100 HM KIT, WDA TRAY EA MP-ZHMU12-100
    MP-ZHMU03 HM KIT,ADAPT ASM EA MP-ZHMU03-100
    MP-ZHMU03-100 HM KIT,ADAPT ASM EA
    MP-ZHMU04-100 HM KIT, SPC EA
    MP-ZHMU05-100 HM KIT, REDUND EA
    MP-ZHMU06-100 HM KIT, CABLES (SEE NOTE FIELD) EA
    MP-ZHMU07-100 HM KIT, CHASSIS EA
    MP-ZHMU08-100 1.8 GB HARD DR EA
    MP-ZHMU11-100 HM U/G KIT/MOD: DUAL 875MB W/O TRAY EA
    MP-ZHMU12-100 HM U/G KIT/MOD: DUAL 875MB W/ TRAY EA
    MP-ZHMU15-100 HM U/G KIT/MODULAR: CABLE KIT EA
    MP-ZHMU18-100 HM U/G KIT/MOD: DUAL 1.8GB DR W/O TRAY EA
    MP-ZHMU19-100 HM U/G KIT/MOD: DUAL 1.8GB DR W/ TRAY EA
    MP-ZIKBT1-100 KIT, IKB W/TB Z CONSOLE EA
    MP-ZIKBZ1-100 IKB W/O TRACKBAL FOR US/UXS EA
    MP-ZIP100-100 SGL BERNOULLI TO SGL ZIP DRIVE U/G EA
    MP-ZIP101-100 2ND BURN TO ZIP DRIVE U/G EA
    MP-ZIP102-100 DUAL BERNOULLI TO ZIP DRIVE U/G EA
    MP-ZKLCN2-100 K2LCN UPG 2MW EA
    MP-ZKLCN3-100 K2LCN UPG 3MW EA
    MP-ZKLCN4-100 K2LCN UPG 4MW EA
    MP-ZKLCN6-100 K2LCN-6MW:PWA/XCVR KIT EA
    MP-ZKLCN8-100 K2LCN UPG 8MW EA
    MP-ZLCNIO-100 LCN SXCR I/O PWB UG EA
    MP-ZLCNP4-100 LCNP3 TO LCNP4(16MW)U/G-R110 SW REQUIRED EA
    MP-ZMD150-100 UPG20/150MB CAR OBSOLETE EA
    MP-ZMSE01-100 MOUSE KIT EA
    MP-ZNMR03-100 REDUN NIM UPGRD EA
    MP-ZNMS03-100 SNGL NIM UPGRADE EA
    MP-ZPRC04-100 K4SS-4 PROCESSOR/MEMORY U/G PWA EA MP-ZPSC04-100
    MP-ZPRC08-100 K2LCN 8MW UPGRADE KIT EA MP-ZPSC08-100
    MP-ZPRC16-100 K4SS08 PROCESSOR/MEMU EA MP-ZPSC16-100
    MP-ZPROC2-100 2M U/G K2 EA
    MP-ZPROC4-100 K2LCN UPGR KIT, 4MW EA
    MP-ZPROC6-100 K2LCN UPGR KIT, 6MW EA MP-ZPROC8-100
    MP-ZPROC8-100 K2LCN 8MW UPGRADE KIT EA
    MP-ZPSC04-100 K4SS-4 PROCESSOR/MEMORY U/G PWA EA
    MP-ZPSC08-100 K4SS-8 PROCESSOR/MEMORY UPGRADE PWA EA
    MP-ZPSC16-100 Upgrade Kit, K4SDR-16MW EA
    MP-ZUCRT1-100 US 21IN AYDIN TO INTERCOLOR CRT REPLACEMENT EA
    MP-ZUSCP1-100 EPDG2 AND EPDGP I/O KIT EA
    MP-ZUSKL1 US KEYLOCK UPGKT EA MP-ZUSKL1-100
    MP-ZUSKL1-100 US KEYLOCK UPGKT EA
    MP-ZUSUK8-100 ABC TO QWERTY KB U/G KIT FOR UNIV STATION EA
    MP-ZUXTS1-100 TOUCHSREEN 19IN U/G EA
    MP-ZUXTS2 FST CRT T/S 24IN U/G FOR Z CONS NON/EC EA 51197051-100
    MP-ZUXTS2-100 FST CRT TOUCHSCREEN 21IN U/G (NEW CONSOLE) EA
    MP-ZXCRT1-100 USX,AYDIN TO INT OBSOLETE EA
    MPX300PII512-K PC Platform, 300Mhz Pentium II EA
    MTRISER RISER CARD EA 51196709-100
    MU-C8DRD1 DOOR, DOUBLE, HPM RITTAL TS8 CABINET EA
    MU-C8DRS1 DOOR, FULL-SIZE, HPM RITTAL TS8 CABINET EA
    MU-C8DSS1 SIDE SKIN, DUAL-ACCESS RITTAL TS8 CABINET EA
    MU-C8SSS1 SIDE SKIN, SGL-ACCESS RITTAL TS8 CABINET EA
    MU-CBSS01 C/F RHIO L1-7 EA 51309101-100
    MU-CBSS02 CF RHIO R9-15 EA 51309101-200
    MU-CBSS11 RHIO LEFT W/O PS EA 51309101-300
    MU-CBSS12 RHIO RIGHT W/O PS EA 51309101-400
    MU-CLBM01 EYEBOLT ASSM (4) EA 51109594-100
    MU-CMSC03 RH MUX NEMA4 SC EA 51309250-200
    MU-CMSS03 RH MUX NEMA4 SS EA 51309250-100
    MU-FAN511 240V FAN W/ALARM-SEE NOTE FIELD EA
    MU-FAN611 120V FAN W/ALARM-SEE NOTE FIELD EA
    MU-FOEA02 UCN FIBER OPTIC EXT SET, 2KM 85-236VAC EA
    MU-FOED02 UCN FIBER OPTIC EXT SET, 2KM 18-36VDC EA
    MU-FOMK01 PM MOUNTING KIT EA
    MU-FOMK10 UCNE MOUNTING KIT PM CAB EA
    MU-GACT02 HLAI CALIBRATOR FOR GI/IS FTAS EA 51201450-100
    MU-GAIH13 FTA, HLAI/STI GI RED/COMP EA 51304718-125
    MU-GAIH14 FTA,_RED_HLAI/STI_GI/IS_COMP,_CE EA 51304730-125
    MU-GAIH22 FTA, GAL HLAI AUX COMP, CE EA 51304748-125
    MU-GAIH83 FTA, RED HLAI/STI GI/IS CRIMP, CE EA 51304718-325
    MU-GAIH84 FTA,_RED_HLAI/STI_GI/IS_CRIMP,_CE_ EA 51304730-325
    MU-GAIH92 FTA, GAL HLAI AUX CRIMP, CE EA 51304748-325
    MU-GAOX02 FTA,_A/O_GI/IS_COMP._TERM_CE EA 51304638-125
    MU-GAOX12 FTA,_RED_A/O_GI/IS_COMP_TERM_CE EA 51304638-525
    MU-GAOX72 FTA, A/O GI/IS CRIMP, CE EA 51304638-325
    MU-GAOX82 FTA, RED A/O GI/IS CRIMP, CE EA 51304638-725
    MU-GDID12 FTA, 24VDC D/I GI/IS COMP, CE, CC EA 51304640-125
    MU-GDID13 FTA, SS DI GI/IS COMP, CE EA 51304728-125
    MU-GDID82 FTA, 24VDC D/I GI/IS CRIMP, CE EA 51304640-325
    MU-GDID83 FTA, SS DI GI/IS CRIMP, CE EA 51304728-325
    MU-GDOD82 FTA, 24VDC D/O GI/IS CRIMP, CE EA 51304642-325
    MU-GDOL12 FTA, DO GI/IS COMP,CE EA 51304736-125
    MU-GDOL82 FTA, DO GI/IS CRIMP,CE EA 51304736-325
    MU-GFBS01 GI/IS FBUS I/F FTA, 4 NETS EA 51309254-225
    MU-GHA011 AO GI/IS FTA (16), HART EA 51309540-125
    MU-GHAO11 FTA, GI/IS AO HART EA 51309540-125
    MU-GMAR52 G/I PNL SCR TERM EA 51309156-125
    MU-GPRD02 PWR DIST PANEL EA 51304644-125
    MU-GRPA01 GI LLAI MUX POWER ADAPTER FTA EA 51304724-125
    MU-HPFH11 HPM FILE ASSM 7R EA 51404126-200
    MU-IOFX02 I/O CARD FILE EA
    MU-KBFT01 BRIDGE CBL 1M EA 80366198-100
    MU-KBFT02 CABLE 2M BRIDGE EA 80366198-200
    MU-KDPR00 DS PWR CABLE EA
    MU-KDPR01 POWER CABLE, 1M EA 51201397-001
    MU-KDPR02 DI POWER CABLE, 2M EA 51201397-002
    MU-KDPR04 POWER CABLE, 4M EA 51201397-004
    MU-KDPR05 DS PWR CABLE,5M EA 51201397-005
    MU-KDPR10 DS PWR CABLE,10M EA 51201397-010
    MU-KDPR15 DS PWR CABLE,15M EA 51201397-015
    MU-KDPR20 DS PWR CABLE,20M EA 51201397-020
    MU-KDPR25 DS PWR CABLE,25M EA 51201397-025
    MU-KDPR30 DS PWR CABLE,30M EA 51201397-030
    MU-KDPR35 DS PWR CABLE,35M EA 51201397-035
    MU-KDPR40 DS PWR CABLE,40M EA 51201397-040
    MU-KDPR50 DS PWR CABLE,50M EA 51201397-050
    MU-KFTA00 FTA I/O CABLE (SEE NOTE FIELD) EA
    MU-KFTA02 CABLE, FTA I/O (2M) EA 51201420-002
    MU-KFTA03 FTA I/O CABLE, 3M EA 51201420-003
    MU-KFTA04 FTA I/O CABLE, 4M EA 51201420-004
    MU-KFTA05 FTA I/O CBL, 5M EA 51201420-005
    MU-KFTA06 FTA CABLE, 6M EA 51201420-006
    MU-KFTA08 FTA CABLE, 8M EA 51201420-008
    MU-KFTA10 FTA I/O CBL, 10M EA 51201420-010
    MU-KFTA15 FTA I/O CBL, 15M EA 51201420-015
    MU-KFTA20 FTA I/O CBL, 20M EA 51201420-020
    MU-KFTA25 FTA I/O CBL, 25M EA 51201420-025
    MU-KFTA30 FTA I/O CBL, 30M EA 51201420-030
    MU-KFTA35 FTA I/O CBL, 35M EA 51201420-035
    MU-KFTA40 FTA I/O CBL, 40M EA 51201420-040
    MU-KFTA45 FTA I/O CBL 45M EA 51201420-045
    MU-KFTA50 FTA I/O CBL 50M EA 51201420-050
    MU-KFTD05 CBL, 5M DIN/PHONE EA 51201561-005
    MU-KFTD10 CBL,10M DIN/PHONE EA 51201561-010
    MU-KFTD15 CBL,15M DIN/PHONE EA 51201561-015
    MU-KFTD20 CBL,20M DIN/PHONE EA 51201561-020
    MU-KFTD25 CBL, 25M DIN/PHONE EA 51201561-025
    MU-KFTD30 CBL,30M DIN/PHONE EA 51201561-030
    MU-KFTD50 CBL,50M DIN/PHONE EA 51201561-050
    MU-KFTS00 FTA CABLE, EC - SEE NOTE FIELD EA
    MU-KFTS02 FTA I/O CABLE, 2M, EC EA 51204033-002
    MU-KFTS03 FTA CABLE, 3M SHIELDED EA 51204033-003
    MU-KFTS04 FTA CABLE, 4M SHIELDED EA 51204033-004
    MU-KFTS05 FTA I/O CBL (5M) EA 51204033-005
    MU-KFTS10 FTA I/O CBL (10M) EA 51204033-010
    MU-KFTS15 FTA I/O CBL (15M) EA 51204033-015
    MU-KFTS20 FTA I/O CBL (20M) EA 51204033-020
    MU-KFTS25 FTA I/O CBL (25M) EA 51204033-025
    MU-KFTS30 FTA I/O CBL (30M) EA 51204033-030
    MU-KFTS35 FTA I/O CBL (35M) EA 51204033-035
    MU-KFTS40 FTA I/O CBL (40M) EA 51204033-040
    MU-KFTS50 FTA I/O CBL (50M) EA 51204033-050
    MU-KGPR00 G.I. PWR CBL, IN CAB EA
    MU-KGPR05 PWR CABLE (IN CAB) 5M EA 51109620-195
    MU-KGPR10 G.I. PWR CBL, 10M EA 51109620-390
    MU-KLAM00 CABLE, LL MUX EA 51304465-000
    MU-KLAM04 TWISTED PR CBL W/SHLD (400cm) EA 51304465-400
    MU-KLAM05 LLMUX PWR CBL, 300CM EA 51304465-500
    MU-KLO305 RHMUS OUTDOOR PA TO FTA CABLE - 1000' EA 51197597-305
    MU-KLX076 CABLE, 250' EC EA 51192139-114
    MU-KLX152 CABLE, 500' EC EA 51192139-124
    MU-KLX305 CABLE, 1000' EC EA 51192139-134
    MU-KTPC03 CABLE, 3M I/O EA 51201396-003
    MU-KTPC05 CABLE, 5M I/O EA 51201396-005
    MU-KTPC10 CABLE, 10M I/O EA 51201396-010
    MU-KTPC20 CABLE, 20M I/O EA 51201396-020
    MU-NCSK01 UCN SPLICE KIT EA 51195160-100
    MU-NCTK01 CRIMP TOOL,RG-11 EA 51190795-200
    MU-NKD000 UCN DROP CABLE - MUST ORDER SPECIFIC LENGTH EA
    MU-NKD002 CABLE SET, 2M RG 6 EA 51195153-002
    MU-NKD005 CABLE SET, 5M RG 6 EA 51195153-005
    MU-NKD010 CABLE SET, 10M RG6 EA 51195153-010
    MU-NKD020 CABLE SET, 20M RG6 EA 51195153-020
    MU-NKD030 CABLE SET, 30M RG6 EA 51195153-030
    MU-NKD040 CABLE SET, 40M RG6 EA 51195153-040
    MU-NKD050 CABLE SET, 50M RG6 EA 51195153-050
    MU-NKDK01 CONNECTOR KIT EA 51195161-100
    MU-NKDT01 CRIMP TOOL, RG-6 EA 51190797-200
    MU-NKT002 CABLE SET, 2.5M EA 51195199-002
    MU-NKT005 CABLE SET, 5M EA 51195199-005
    MU-NKT010 CABLE SET, 10M EA 51195199-010
    MU-NKT020 CABLE SET, 20M EA 51195199-020
    MU-NKT030 CABLE SET, 30M EA 51195199-030
    MU-NKT050 CABLE SET, 50M EA 51195199-050
    MU-NKT100 CABLE SET, 100M EA 51195199-100
    MU-NKT200 CABLE SET, 200M EA 51195199-200
    MU-NKT400 CABLE SET, 400M EA 51195199-400
    MU-NKT600 CABLE SET, 600M EA 51195199-600
    MU-NKTK01 CONNECTOR KIT EA 51195162-100
    MU-NKTQ01 TORQUE WRENCH EA 51109612-100
    MU-NKTT01 CRIMP TOOL RG11 EA 51190795-200
    MU-NTAP02 2-DROP TAP ASSM EA
    MU-NTAP04 4-DROP TAP ASSM EA
    MU-NTAP08 8-DROP TAP ASSM EA
    MU-PAIH01 IOP, HLAI (CC) EA 51304754-150
    MU-PAIH02 IOP, HLAI EA 51304754-150
    MU-PAIH03 IOP, HLAI (CC) EA 51304754-150
    MU-PAIL02 LLAI IOP ASSM EA 51304481-100
    MU-PAOX01 PWA, AO/IOP EA 51309152-175
    MU-PAOX02 PWA, AO/IOP EA 51309152-175
    MU-PAOX03 PWA, AO/IOP EA 51309152-175
    MU-PAOY22 HPM HD I/O IOP EA 80363969-150
    MU-PAR111 PWR SUPPLY 115 V 8A REDUNDANT EA 51401140-600
    MU-PAS111 P/S 8A 120V SINGLE EA 51401140-500
    MU-PAS121 AC ONLY P/S RED 115V16AMP EA 51401140-100
    MU-PDIS11 RED DISOE2 ASSM EA 51402625-125
    MU-PDIS12 RED DISOE2 ASSM EA 51402625-125
    MU-PDIX01 D/I IOP ASSM EA 51304485-100
    MU-PDIX02 D/I IOP ASSM EA 51304485-100
    MU-PDIY22 DI IOP 32 ASSM EA 80363972-100
    MU-PDOX01 D/O IOP ASSM EA 51304487-100
    MU-PDOX02 D/O IOP ASSM EA 51304487-100
    MU-PDOY22 DO IOP (NON COATED) EA 80363975-100
    MU-PFBS01 FIELDBUS I/F PROCESSOR, 4 NETS EA 51309510-175
    MU-PFPX01 I/O FILLER PLATE, BEIGE EA 51309228-300
    MU-PLAM02 LLAI MUX IOP EA 51304362-100
    MU-PMFR03 FILE,5 SLOT IOP EA 51404212-175
    MU-PPIX02 PULSE INPUT IOP EA 51304386-100
    MU-PRHM01 32PT IOP EA 51404109-125
    MU-PSDX02 IOP,SER DEV I/F EA 51304362-200
    MU-PSIM11 IOP, SERIAL I/F EA 51304362-300
    MU-PSRB04 P/S RED 10A W/BBU & MNTG EA 51404174-325
    MU-PSRX04 P/S RED 20A W/MNTG EA 51404174-225
    MU-PSSX04 P/S SGL 20A W/MNTG EA 51404174-125
    MU-PSTX02 ST I/F IOP ASSM EA 51304516-100
    MU-PSTX03 ST MV I/F PROC EA 51304516-200
    MU-RCAB01 REMOTE HARDENED CNTRL CAB 120V EA 51404373-100
    MU-RCAB02 REMOTE HARDENED CNTRL CABINET 240V EA 51404373-200
    MU-RCHT01 HEATER KIT 120V EA 51404386-100
    MU-RCHT02 HEATER KIT 240V EA 51404386-200
    MU-SMAC01 A/O STANDBY ASSM EA 51401277-100
    MU-SMAC02 A/O STANDBY MANUAL EA 51401277-200
    MU-SMDC01 D/O STDBY W/CASE EA 51304095-200
    MU-SMDC02 D/O STDBY W/CASE EA 51304526-200
    MU-SMDX01 FTA, D/O STNDB EA 51304096-100
    MU-SMDX02 FTA, D/O STNDBY EA 51304527-100
    MU-TAIH01 MOD, HL A/I FTA EA 51303956-100
    MU-TAIH02 FTA, HLAI/STI EA 51304453-100
    MU-TAIH03 FTA, 6IN HLAI, CE EA 51309136-125
    MU-TAIH12 FTA, HL/AI EA 51304337-100
    MU-TAIH22 HD FTA, HLAI/STI COMP EA 51204170-200
    MU-TAIH23 HD FTA, HLAI/STI COMP, CE EA 51204170-225
    MU-TAIH52 FTA, HLAI/STI EA 51304337-200
    MU-TAIH62 HLAI FTA SCR EA 80366192-100
    MU-TAIL01 FTA, LL A/I,DIN EA 51198964-100
    MU-TAIL02 FTA, LLAI EA 51304437-100
    MU-TAIL03 FTA MOTHERBOARD, LLAI-8 CE EA 51309202-125
    MU-TAMR02 FTA, LLMUX RTD, CE EA 51309218-125
    MU-TAMR03 FTA, LLMUX RTD, CE EA 51309218-125
    MU-TAMT02 FTA, LLMUX TC, EC EA 51309223-125
    MU-TAMT03 FTA, LLMUX TC, EC EA 51309223-125
    MU-TAMT12 LL TC FTA-REMOTE EA
    MU-TAMT13 FTA, LLMUX TC W/RCJR, CE EA 51309213-125
    MU-TAOX01 MODULE, A/O FTA EA 51303953-100
    MU-TAOX02 FTA, A/O CCCE EA 51304476-175
    MU-TAOX12 AO FTA RED. COMP EA 51304335-125
    MU-TAOX52 AO FTA RED. SCREW EA 51304335-225
    MU-TAOY22 HD FTA, AO COMP W/STBY, CE EA 51204172-125
    MU-TAOY23 AO RED COMP EA 80366177-200
    MU-TAOY52 HD FTA, AO SCREW W/STBY, CE EA 51204174-125
    MU-TAOY53 AO FTA SCR EA 80364007-200
    MU-TDIA11 FTA,120VAC D/I EA 51401186-100
    MU-TDIA12 DI FTA 120 VAC EA 51304439-125
    MU-TDIA22 DI, FTA EA 51304431-125
    MU-TDIA52 FTA, D/I EA 51304439-225
    MU-TDIA62 FTA, D/I EA 51304431-225
    MU-TDIA72 FTA, D/I (32) EA 51303930-100
    MU-TDID11 MODULE,24VDC D/I EA 51401201-100
    MU-TDID12 FTA, D/I EA 51304441-125
    MU-TDID52 DI FTA 120 VA EA 51304441-225
    MU-TDID72 FTA, D/I 24VDC EA 51303928-100
    MU-TDIY22 FTA, DI 24VDC COMP, CE EA 51204160-125
    MU-TDIY62 FTA, DI 24VDC SCREW, CE EA 51204154-125
    MU-TDOA11 MODULE,D/O S.S EA 51401157-100
    MU-TDOA12 FTA, 120/240VAC SS D/O COMP, CE, CC EA 51304648-175
    MU-TDOA13 FTA, 120/240VAC SS D/O COMP, CE, CC EA 51304648-175
    MU-TDOA52 FTA, 120/240VAC SS D/O SCREW, CE EA 51304648-225
    MU-TDOA53 FTA, 120/240VAC SS D/O SCREW, CE EA 51304648-225
    MU-TDOD11 MODULE, D/O S.S EA 51401220-100
    MU-TDOD12 FTA, 3/30VDC D/O COMP EA 51304650-100
    MU-TDOD13 FTA, 3/30VDC D/O COMP EA 51304650-100
    MU-TDOD22 FTA, 31/200VDC DO COMP, CE, CC EA 51309154-175
    MU-TDOD52 FTA, 3/30VDC D/O SCREW EA 51304650-200
    MU-TDOD53 FTA, 3/30VDC D/O SCREW EA 51304650-200
    MU-TDOD62 FTA, 31/200VDC DO SCREW, CE EA 51309154-225
    MU-TDOD63 FTA, 31/200VDC DO SCREW, CE EA 51309154-225
    MU-TDON12 FTA, D/O EA 51304446-100
    MU-TDON52 FTA, D/O EA 51304446-200
    MU-TDOR02 FTA, 240V RELAY DO SCREW EA 51309150-225
    MU-TDOR11 MODULE, D/O FTA EA 51401191-100
    MU-TDOR12 FTA, DO 120VAC EC EA 51309148-125
    MU-TDOR22 FTA, 240V RELAY DO COMP, CE EA 51309150-125
    MU-TDOR52 FTA, 120V RELAY DO SCREW, CE EA 51309148-225
    MU-TDOR62 FTA, 240V RELAY DO SCREW, CE EA 51309150-225
    MU-TDOY22 FTA, DO 24VDC COMP, CE EA 51204162-125
    MU-TDOY23 HD FTA, DO RELAY COMP, CE EA 51204166-125
    MU-TDOY62 FTA, DO 24VDC SCREW, CE EA 51204156-125
    MU-TDOY63 HD FTA, DO RELAY SCREW, CE EA 51204164-125
    MU-TDPR01 PWR DIST 24VDC EA 51304425-125
    MU-TDPR02 PWR DIST 24VDC EA 51304425-125
    MU-TFBS01 FIELDBUS I/F FTA, 4 NETS EA 51309254-125
    MU-TFBS11 FIELDBUS I/F FTA, 4 NETS, NO PWR COND EA 51309254-325
    MU-THA011 AO FTA (16), HART EA 51309542-125
    MU-THAO11 FTA AO HART EA 51309542-125
    MU-TLPA02 FTA, LLMUX/SDI/SI PWR ADAPTER, CC EA 51309204-175
    MU-TMCN01 FTA MTG CHANNEL, NARROW RITTAL EA 51401246-200
    MU-TMCN02 FTA MTG CHANNEL, NARROW RITTAL W/SH GRND BAR EA 51196094-100
    MU-TMCN11 FTA MTG CHANNEL, NARROW MARKHON EA 51401529-100
    MU-TMCN12 FTA MTG CHANNEL, NARROW MARKHON W/SH GRND BAR EA 51196093-100
    MU-TMCN22 FTA CHASSIS ASSEMBLY EA 51196094-300
    MU-TMCW01 FTA MTG CHANNEL, WIDE RITTAL EA 51401246-100
    MU-TMCW02 FTA MTG CHANNEL, WIDE RITTAL W/SHIELD GRD BAR EA 51196094-200
    MU-TMCW11 FTA MTG CHANNEL, WIDE MARKHON EA 51401529-200
    MU-TMCW12 FTA MTG CHANNEL, WIDE MARKHON W/SHIELD GR BAR EA 51196093-200
    MU-TMHN01 HORIZ. FTA TRAY EA 51401621-100
    MU-TMHN02 HORIZ. FTA TRAY W/GB EA 51201666-100
    MU-TPIX12 FTA, PULSE INPUT EA 51304084-125
    MU-TPIX52 FTA, PULSE INPUT EA 51304084-225
    MU-TRPA01 FTA, RH MUX GI/NI PWR ADAPTER, EC EA 51304722-125
    MU-TSDM02 SER DEV I/F FTA EA 51303932-227
    MU-TSDT02 SER DEV I/F FTA EA 51303932-226
    MU-TSDU02 FTA, SD I/F UDC6 EA 51303932-228
    MU-TSIA12 SERIAL INTERFACE - ALLEN BRADLEY EA 51303932-428
    MU-TSIM12 SERIA INTERFACE FTA - MODBUS EA 51303932-426
    MU-TSTX03 FTA, 6IN STI, CE EA 51309140-125
    MU-TSTX13 FTA, 12IN STI COMP, CE EA 51309142-125
    MU-ZAPR01 PM TO APM U/G KIT EA MC-ZAPR01
    MU-ZAPS01 PM-APM U/G KIT EA MC-ZAPS01
    MU-ZBCAB1 CB/EC PWA MTG KT EA
    MU-ZBCJP1 CB/EC UG KIT PWA EA
    MU-ZDICS1 DI-IOP KIT EA
    MU-ZDICS1-100 DI-IOP KIT EA MU-ZDICS1
    MU-ZFTD02 DIN-PHONE ADAPTR EA 51201553-100
    MU-ZLLRT1 LLAI OC DETECTKT FIRMWARE UPGRADE EA
    MU-ZPFI03 HPM TO I/O TO I/O ONLY FILE CONV KIT (CE) EA
    MU-ZPFI03-100 HPM I/O TO I/O ONLY FILE CONV KIT (CE) EA MU-ZPFI03
    MU-ZPSR04 HPM PWR UG EA
    MU-ZSTIM1 UPGR KIT, STI-MV EA
    MX-MTLC10 CABLE,10M TOWER EA 51304505-200
    P-AST10 PWA, STDC EA 51195053-100
    P-CFA17 HL PCFA-TRM TYPE EA 4DP7APCFA107
    P-CFA18 HL, PCFA-CON TYPE EA 4DP7APCFA108
    P-CFA19 HL PCFA EA 4DP7APCFA109
    P-CFA27 LL PCFA EA 4DP7APCFA207
    P-CFA28 LL PCFA ASSM EA 4DP7APCFA208
    P-CFA29 LL 7100 CFA EA 4DP7APCFA209
    P-CFA39 CARD FILE ASSM EA 4DP7APCFA309
    P-CFA43 HL CCFA, R320B EA 4DP7APCFA403
    P-CFA52 LL CCFA EA 4DP7APCFA502
    P-CFA61 LE CCFA BKPANEL EA 4DP7APCFA601
    P-CIM14 CSA TC W/NEMA BOX EA 4DP7APCIM104
    P-CIM24 SAT MUX PWA RTD EA 4DP7APCIM204
    P-DK361 R360 5-1/4IN SET EA
    P-DK520 R520 DISK PKG 8IN FOR R520 OPS 12 DISKS EA
    P-DK525 R525 DISK PKG 5 1/4IN PKG OF 12 EA
    P-DK530 R530 8IN DISK PKG OF 13 DISKS EA
    P-DK535 R535 5 1/4IN DISK PKG 13 DISKS EA
    P-DK616 R615 5-1/4IN SET EA
    P-DSG54 ASM, KEYBD FLAT EA 82115280-001
    P-DSG56 KYBD ASSM EA 30751083-005
    P-DSX81 R520 TO R530 KIT EA
    P-DSX82 R420 TO R530/535 EA
    P-DSX83 R460/615 TO R530 EA
    P-ETP14 TERMINAL PANEL EA 82407438-001
    P-FAN19 FAN COVER PLATE EA 51302804-100
    P-FIM14 FM TC W/NEMA BOX EA 4DP7APFIM104
    P-FIM24 RTD MUX ASSM EA 4DP7APFIM204
    P-FUP51 FDD UPGRADE KIT EA
    P-FUP52 FDD UPGRADE KIT EA
    P-FUT51 FDD UPGRADE KIT EA
    P-FUT52 FDD UPGRADE KIT EA
    P-ISB12 INTRINSIC SAFETY BARRIERS & BOX PTB CERT EA 51104957-100
    P-ISB13 INTRINSIC SAFETY BARRIERS & BOX FM CERT EA 51104957-101
    P-ISB14 INTRINSIC SAFETY BARRIERS & bOX CSA CERT EA 51104957-102
    P-ISB15 INTRINSIC SAFETY BARRRIERS & BOX BASEEFA CERT EA 51104957-103
    P-KFA02 PRE-TERMINATED FIBER OPTIC CABLE (2M) EA 51195440-002
    P-KFA05 PRE-TERMINATED FIBER OPTIC CABLE (5M) EA 51195440-005
    P-KFA10 PRE-TERMINATED FIBER OPTIC CABLE (10M) EA 51195440-010
    P-KFA20 PRE-TERMINATED FIBER OPTIC CABLE (20M) EA 51195440-020
    P-KFA50 PRE-TERMINATED FIBER OPTIC CABLE (50M) EA 51195440-050
    P-KFB01 FIBER OPTIC CBL 1M ST/ST EA 51195498-001
    P-KFB02 ST/ST FIB CBL 2M EA 51195498-002
    P-KFB05 FIBER OPTIC CBL 5M ST/ST EA 51195498-005
    P-KFB10 FIBER OPTIC CBL ST/ST 10M EA 51195498-010
    P-KFB20 FIBER OPTIC CBL ST/ST 20M EA 51195498-020
    P-KFH01 CABLE SET, 1M EA 51195497-001
    P-KFH02 CABLE SET, 2M EA 51195497-002
    P-KFH05 CABLE SET, 5M EA 51195497-005
    P-KFH10 CABLE SET, 10M EA 51195497-010
    P-KFH20 CABLE SET, 20M EA 51195497-020
    P-KFH50 CABLE SET, 50M EA 51195497-050
    P-NMA11 NEMA 4 BOX EA 4DP7APNMA101
    P-ODP22 HL 24VDC POWER FILTER EA 4DP7APODP202
    P-ODP23 POWER FILTER EA 4DP7APODP203
    P-ODP24 DUAL D/I PWR FILTER EA 4DP7APODP204
    P-OIM14 TC LOGIC&TERM BDS CBLS AND NEMA BOX ASSM EA 4DP7APOIM104
    P-OIM24 RTD LOGIC&TERM BDS, CBLS AND NEMA BOX EA 4DP7APOIM204
    P-OIM31 NEMA ASSM-NON IS EA 4DP7APOIM301
    P-OIM34 TC LOGIC & TERM BDS, MTG HDW CBLS-NON IS EA 4DP7APOIM304
    P-OIM41 MUX SET W/NEMA EA 4DP7APOIM401
    P-OIM43 LE RTD MUX LOGIC EA 4DP7APOIM403
    P-OSP11 SURGE PROTECT A/I HL EA 4DP7APXSP111
    P-OSP21 SURGE PROTECT D/O RELAY AND D/I EA 4DP7APXSP211
    P-OSP31 SURGE PROTECT A/O AND SOLID STATE D/O EA 4DP7APXSP311
    P-OSP41 SURGE PROTECT POWER SUPPLY EA 4DP7APXSP411
    P-OSP51 SURGE PROTECT A/I LL EA 4DP7APXSP511
    P-OTS12 SHIELD TERM BLK W/TERM MTG LL EA 51200641-100
    P-PRT11 LE PHASE XFMR-STD TRAY MNT 120V 60HZ EA 4DP7APPRT101
    P-TCB60 TERMINAL PANEL EA 51303903-100
    P-TCB71 ST3000 STATUS OUTPUT TERMINAL PANEL EA 51195105-100
    P-TCK11 CONNECTOR KIT EA 4DP7APTCK101
    P-XCA11 BARRIER ADAPTOR EA 4DP7APXCA111
    P-XIA12 VOLTAGE INPUT 5V EA 4DP7APXIA122
    P-XIA22 4-20MA W/O XMTR EA 4DP7APXIA222
    P-XIA32 4-20MA XMTR PWR EA 4DP7APXIA322
    P-XIA42 5V WITH FAST FIL EA 4DP7APXIA422
    P-XIA81 LL AN INPUT MUX EA 4DP7APXIA811
    P-XIA91 LL ANALOG INPUT EA 4DP7APXIA911
    P-XID11 HL 24V CONTACT EA 4DP7APXID111
    P-XID21 1 MEC 24V DIG IN EA 4DP7APXID211
    P-XID31 HL 48V CONTACT EA 4DP7APXID311
    P-XID41 HL 48V CONTACT 2 EA 4DP7APXID411
    P-XID51 HL TTL LOGIC 0.1 EA 4DP7APXID511
    P-XID61 HL 125 VDC CONTACT EA 4DP7APXID611
    P-XID62 HL 125VDC CONTACT EA 4DP7APXID622
    P-XIP11 HL SLOW FORM A/C EA 4DP7APXIP111
    P-XIP31 PULSE INP SLOW EA 4DP7APXIP311
    P-XIP41 PULSE INPUT FAST EA 4DP7APXIP411
    P-XOA31 ANALOG OUTPUT EA 4DP7APXOA311
    P-XOD31 DIGITAL OUTPUT EA 4DP7APXOD311
    P-XOD41 7100 DIGITAL OUTPUT EA 4DP7APXOD411
    P-XRP11 RTD POWER SUPPLY EA 4DP7APXRP111
    P-XSC11 LL SIG COND EA 4DP7APXSC111
    P-XSD11 SIG COND EA 4DP7APXSD111
    P-XSJ11 LL SIGNAL CON - REFERENCE EA 51104410-100
    P-XSR11 PWA LL RTD EA 4DP7APXSR111
    P-XSR21 LL SIG CON EA 4DP7APXSR211
    P-XSR31 LL SIG COND EA 4DP7APXSR311
    P-XSV11 LL SIG COND EA 4DP7APXSV111
    P-XSV21 LL +1-5, 10, 20 EA 4DP7APXSV211
    P-ZHL11 310/320 TO 320B U/G W/O AD CONVERTER EA 51109322-100
    P-ZHL12 310/320 TO 30B U/G WITH CONVERTER EA 51109322-101
    P-ZHL13 310A TO 320B U/G WITH A/D CONVERTER EA 51109323-100
    P-ZKC51 UPGRADE KIT EA
    P-ZKC52 BASIC CASS UPGRD KIT,TWO 5-1/4IN FDD, POD/PNL EA
    P-ZKC53 UPGRADE KIT EA
    P-ZKC54 UPGRADE KIT EA
    P-ZKF51 BASIC 8IN FDD U/G, ONE 5-14IN FDD, POD/PNL EA
    P-ZKF52 BASIC 8IN FDD U/G, TWO 5-1/4IN FDD, POD/PNL EA
    P-ZKF53 UPGRADE KIT EA
    P-ZKF54 UPGRADE KIT EA
    P-ZKF55 WEDGE PIE PLATE EA 51304051-100
    P200-16F 16MB MEMORY EA 51196743-104
    P220-16F 16MB MEM ECC EA 51196743-204
    P270-1MBF 1M GRAPHICS MEM EA 51196708-170
    P851-DC2F 2GB DATA CASS EA 51196706-100
    P862-1GBF 1 GB H/D EA 51196704-200
    P862-545F 1.44MB FLPY CBL EA 51196703-100
    P881-600LCF CD ROM EA 51196707-100
    PHA-01 HOOTER ASSEMBLY EA
    RAL9705-100 RETROFIT KIT EA 51197103-101
    RG-PHA01-100 HOOTER ASSM, CLASSIC FURN, 115V EA 51401303-100A
    RG-PHA01-200 HOOTER ASSM, CLASSIC FURN, 230V EA 51401303-200A
    RG-PHA01-300 HOOTER ASSM, Z FURN, 115V EA 51401303-300A
    RG-PHA01-400 HOOTER ASSM, Z FURN, 230V EA 51401303-400A
    S1-W4685C03A 16MB SIMM MEMORY EA 51196743-104
    SCI72-201-001 CON,120V PWR ENTRY EA 51402619-120
    TP-10HD09-100 9.3GB ADDITIONAL HARD DRIVE EA 51198717-100
    TP-CTSC01-100 TOUCHSCREEN CLASSIC CONSL 19IN EA
    TP-CTSC02-100 TOUCHSCREEN, Z CNSL 21IN EA
    TP-CZUMVB-100 U/T 21IN CRT EA
    TP-CZUMVD-100 U/T 21IN CRT EA
    TP-DCRTVC-100 DUAL VIDEO BOARD EA 51196988-100
    TP-DIKBTA-100 IKB W/TKBL, DESKTOP EA
    TP-DLBP03-100 HP B/W LZRJT 120V EA
    TP-DM17SA-100 CRT 17IN DESKTOP EA
    TP-DM21SY-200 CRT 21IN EZ CNSL EA
    TP-DOKBNA-100 OEP KYBD,DESKSIDE GUS EA
    TP-DTAP00-100 STREAMING TAPE DRIVE 1/4IN EA 51196966-100
    TP-DTSD00-100 TOUCH FRAME OPTION 21IN EA
    TP-DZIP00-100 ZIP DRIVE EA 51196932-100
    TP-ERM064-100 EDORAM DIMM 64MB EA 51196321-100
    TP-ERM128-100 EDORAM DIMM 128MB EA 51196321-200
    TP-EUM21B-100 EZ-UPPER TIER 21IN MONITOR EA
    TP-EUM21Y-100 EZ CNSL U/TIER CRT EA
    TP-EZCBL1-100 Monitor Cable Kit EA
    TP-HDGB09-100 9.3GB H/DRIVE ADDER EA
    TP-ICEKB1-100 QWERTY K/B INDUSTRIAL CE EA 51191508-100
    TP-ICEMS1-100 PS2 MOUSE, IND EA 51196939-100
    TP-MOUNTR-100 RACK MONITOR GUS 19IN EA 51403280-100
    TP-MOUNTR-200 Rack Mount Kit 120V EA
    TP-NCBP01-100 GUS HP LZRJT N/W I/F EA
    TP-NDAT08-100 INTERNL DAT TAPE KIT EA 51196863-100
    TP-NHD09G-100 HARD DRIVE 9.1GB EA 51196968-100
    TP-QCRTVC-100 DUAL VIDEO UPGRADE KIT EA 51197072-100
    TP-RAM064-100 64MB MEMORY ECC EA 51196935-903
    TP-RMKBDM-100 Rack Mntg Kit for Montr, Kbd & Mouse, 120V EA
    TP-RMKBDM-200 Rack Mntg Kit for Montr, Kbd & Mouse, 220V EA
    TP-SRM064-100 64MB DIMM RAM EA 51196971-100
    TP-SRM128-100 128MB SDRAM DIMM FOR PENTIUM II ADDL RAM EA 87758
    TP-XM128D-100 DIMM, 128, 100M 16X72 4K 168 EA 51196982-904
    TP-XM128E-100 128MB RDRAM EA 51198718-904
    TP-XM256E-100 256MB PC700 ECC RDRAM RIMM EA 51198718-913
    TP-ZCAPPC DESKTOP APP REPLACEMENT STATION FOR CG EA
    TP-ZCAPPD DESKSIDE APP REPLACEMNT STATION FOR CG EA
    TP-ZCCRT1-200 GUS CRT U/G KIT 19IN 220V EA
    TP-ZCIKB1-100 INTEG KB (IBK) U/G EA
    TP-ZCLDUG US/UXS DUAL TO GUS U/G ORDER THRU CONFIGURATR EA
    TP-ZCLDUS-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLDUG
    TP-ZCLDUS-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLDUT-200
    TP-ZCLDUT-100 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZCLDUG
    TP-ZCLDUT-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA
    TP-ZCLSUG US/UXS SGL TO GUS CLASSIC ORDER THRU CONFIG. EA
    TP-ZCLSUS-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLSUG
    TP-ZCLSUS-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLSUT-200
    TP-ZCLSUT-100 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZCLSUG
    TP-ZCLSUT-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA
    TP-ZCRPER-100 REMOTE PERIPHERAL KIT CLASSIC EA
    TP-ZCRWSP-100 GUS REMOTE PERIPHRL U/G CLASSIC W/S EA
    TP-ZEC100-100 Upgrade Kit, XLCNE2 100 Micron CE EA
    TP-ZEC625-100 Upgrade Kit, XLCNE2 62.5 Micron CE EA
    TP-ZEN100-100 Upgrade Kit, XLCNE2 100 Micron N-CE EA
    TP-ZEN625-100 Upgrade Kit, XLCNE2 62.5 Micron N-CE EA
    TP-ZEPKC1-100 IKB TO OEP REPLACEMENT IN CLASSIC EA
    TP-ZEPKZ1-100 IKB TO OEP RELACEMENT IN Z-CONSOLE EA
    TP-ZG2G01 GUS TO GUS CONSOLE UPGRADE EA
    TP-ZG2G01-100 GUS TO GUS 450MHZ FOR CONSOLE MNT & DESKTOP EA
    TP-ZG2G02 GUS TO GUS DESKSIDE UPGRADE EA
    TP-ZG2G02-100 GUS TO GUS 450MHZ FOR DESKSIDE EA
    TP-ZGAPPC DESKTOP APP REPLACEMENT STATION EA
    TP-ZGAPPD DESKSIDE APP REPLACEMENT STATION EA
    TP-ZHAPPC DESKTOP APP REPLACEMENT STATION EA
    TP-ZHAPPD Deskside APP Replacement Station HI-SPEC EA
    TP-ZLAPPC DESKTOP APP REPLACMENT STATION FOR PLNM EA
    TP-ZLAPPD DESKSIDE APP REPLACEMENT STTION FOR PLNM EA
    TP-ZPAPPC DESKTOP APP REPLACEMENT STATION FOR PCNM EA
    TP-ZPAPPD DESKSIDE APP REPLACMENT STTION FOR PCNM EA
    TP-ZRPER1-100 GUS Rem Peripheral Single Upgrade Kit Z Con EA
    TP-ZRPER1-200 GUS Rem Peripheral Dual Upgrade Kit Z Console EA
    TP-ZRSDS1 UWS, UxS OR US UPGRADE TO DESKSIDE GUS EA
    TP-ZSCLC1-100 CRT/LWR OEP BEZEL ASSY W/O T/S EA
    TP-ZSCLCT-100 CRT/LWR OEP BEZEL ASSY W/ T/S EA
    TP-ZSCLH1-100 CRT/LW OEP BZL ASSY W/O T/S, W/FLR PNL OPNG EA
    TP-ZSCLHT-100 CRT/LWR OEP BEZEL ASSY W/T/S, W/FLR PNL OPNG EA
    TP-ZSCLN1-100 GUS CRT/LWR IKB BEZEL ASSY WO/T/S EA
    TP-ZSCLNT-100 GUS CRT/LWR IKB BEZEL ASSY W/T/S EA
    TP-ZSCLTT-100 CLASSIC 19" TOUCHSCREEN UG EA
    TP-ZSCLU1-100 CRT/ UPR BEZEL WO/T/S EA
    TP-ZSCLUT-100 CRT/ UPR BEZEL W/T/S EA
    TP-ZSCRT1-100 CRT SONY 21IN U/G W/O TS EA
    TP-ZSCRTT-100 CRT SONY 21IN U/G W/ TS EA
    TP-ZSTSR1-100 TOUCHSCREEN UG SONY 21IN EA
    TP-ZTSCC1-100 TOUCHSCREEN CONTROLLER UPGRADE FOR GUS EA
    TP-ZXAPPC DESKTOP APP REPLACEMENT STATION FOR AXM EA
    TP-ZXAPPD DESKSIDE APP REPLACEMENT STATION FOR AXM EA
    TP-ZXZD01-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZD1G
    TP-ZXZD01-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZD1T-200
    TP-ZXZD1G UX/UXS DUAL TO GUS CONSOLE ORDER THRU CONFIG EA
    TP-ZXZD1T-100 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZXZD1G
    TP-ZXZD1T-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA
    TP-ZXZS01-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZS1G
    TP-ZXZS01-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZS1T-200
    TP-ZXZS1G US/UXS SGL TO GUS CONSOLE-ORDER THRU CONFIG EA
    TP-ZXZS1T-100 UX/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZXZS1G
    TP-ZXZS1T-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA
    UB604-132PO 604 132 MHZ BD EA 51196708-156
    V-PWR51 POWER SUPPLY 20A, 50HZ, 105/120VAC EA 30731565-004
    V-PWR52 POWER SUPPLY 20A, 50HZ, 220/240VAC EA 30731565-006
    V-PWR61 20A PWR SPLY KIT EA 30731565-002
    V-PWR71 7A PWR SPLY KIT EA 30731565-001
    V-PWR72 PWR SPLY, 7A/24V, 240V/50HZ EA 30731565-005
    V-PWR73 POWER SUPPLY 7A, 50HZ, 115 VAC EA 30731565-003
南京益工科技有限公司是一家致力于工业自动化控制系统的高新技术企业,公司拥有一批素质高,技术硬的研发人员,全心为工业自动化控制系统服务,在集散控制系统(DCS)的监视器(CRT、LCD)、打印机、风扇组件、过滤网等的国产化替代和卡件备…  更多>>
南京益工科技有限公司
联系人:韩洪瑞
地址:南京沿江工业开发区大厂新华路468号钻石星城A-907
邮编:210048
电话:025-85363991
传真:025-85231050
公司网址:
