美国Futek称重传感器LCA345(L1618)-4000l
- 发布时间:2008/11/17 6:25:57
修改时间:2008/12/11 8:49:24 浏览次数:571
长期优惠供应美国Futek称重传感器
LAU200(L1050)-10lb/25lb/50lb/100lb/300lb
LAU220(L1055)-300lb/500lb
LAU300-3000lb
LBB200(L1501)-0.25lb/0.5lb/1lb/2lb/5lb/10lb/25lb(1ft)
LBB200(L1501)-25lb(10ft)
LBB300(L1510)-0.25lb/0.5lb/1lb/1.5lb/2lb/5lb/10lb
LCA300(L1645)-2000lb/3000lb/5000lb
LCA305(L1645)-7500lb/10000lb
LCA310(L1645)-15000lb(10ft)/20000lb/30000lb
LCA310(L1645)-15000lb(20ft)
LCA345(L1618)-4000lb
LCA350(L1618)-7500lb/10000lb
LCA700-500000lb/750000lb
LCA700-1000000lb
LCB200(L1652)-1000lb/2000lb/3000lb
LCB400(L1658)-1000lb/2000lb(standard)
LCB400(L1658)-3000lb/5000lb/10000lb(standard)
LCB400(L1658)-1000lb/2000lb/3000lb(IEEE1451.4)
LCB400(L1658)-2000lb(5VDC+/-4 VDC)
LCB450(L1659)-5000lb/10000lb/20000lb
LCB500(L2930)-500lb/1000lb/2000lb/3000lb(standard)
LCB500(L2930)-5000lb
LCB500(L2930)-100lb/200lb
LCB500(L2930)-100lb/3000lb(IEEE1451.4)
LCF250(Q10476)-2000lb
LCF290(L1660)-500lb
LCF300(L1665)-10lb/25lb/50lb/100lb
LCF300(L1665)-100lb/250lb/500lb(17-4 PH S.S.)
LCF300(L1665)-50lb(Fatigue Rated)
LCF300(L1665)-50lb(6 Pin)
LCF300(L1665)-100lb/250lb(17-4 PH S.S. 6 Pin)
LCF300()-10lb(6 Pin)
LCF300(L1665)-10lb/25lb(IEEE1451.4)
LCF400(L2920)-250lb/1000lb/2000lb/3000lb/5000lb
LCF400(L2920)-2000lb/3000lb
LCF450(L2900)-500lb/1000lb/2000lb(T4 5/8-18)
LCF450(L2900)-500lb/1000lb/2000lb(T4 M16x2)
LCF450(L2900)-2000lb/3000lb/5000lb(17-4 PH S.S.5/8-18)
LCF450(L2900)-10000lb(17-4 PH S.S.5/8-18)
LCF450(L2900)-2000lb/3000lb/5000lb(17-4 PH S.S.M16x2)
LCF450(L2900)-10000lb(17-4 PH S.S.M16x2)
LCF450(L2900)-500lb/1000lb/300lb(17-4 PH S.S.5/8-18)
LCF450(L2900)-5000lb(M16x2,IEEE1451.4)
LCF450(L2900)-5000lb(5/8-18,IEEE1451.4)
LCF450(L2900)-300lb(17-4 PH S.S.M16x2)
LCF450(L2900)-300lb/500lb/5000lb(17-4 PH S.S.5/8-18)+/-0.05% N.L.
LCF450(L2900)-300lb(IEEE1451.4)
LCF450(L2900)-1000lb(T4 5/8-18,+/-0.05% N.L.)
LCF450(L2900)-10000lb(17-4 PH S.S.5/8-18)+/-0.05% N.L.
LCF450(L2900)-2000lb(M16x2,IEEE1451.4)
LCF450(L2900)-2000lb(5/8-18,IEEE1451.4)
LCF450(L2900)-10000lb(M16x2,IEEE1451.4)
LCF451(L2903)-250lb/500lb/1000lb(2024-T4 5/8-18)
LCF451(L2903)-1000lb/2500lb(17-4 PH S.S.5/8-18)
LCF451(L2903)-5000lb(17-4 PH S.S.5/8-18)
LCF451(L2903)-250lb/500lb/1000lb(2024-T4 M16x2)
LCF451(L2903)-2500lb(17-4 PH S.S. M16x2)
LCF451(L2903)-5000lb(17-4 PH S.S. M16x2)
LCF455(L2901)-500lb/2000lb/3000lb/5000lb(17-4 PH S.S.5/8-18)
LCF455(L2901)-500lb/1000lb/2000lb(2024-T4 5/8-18)
LCF455(L2901)-500lb/1000lb/2000lb(2024-T4 M16x2)
LCF455(L2901)-300lb(17-4 PH S.S. 5/8-18)
LCF455(L2901)-10000lb(17-4 PH S.S. 5/8-18)
LCF455(L2901)-300lb/3000lb/5000lb(17-4 PH S.S.M16x2)
LCF455(L2901)-10000lb(17-4 PH S.S.M16x2)
LCF455(L2901)-500lb(17-4 PH S.S.5/8-18,IEEE1451.4)
LCF455(L2901)-10000lb(17-4 PH S.S.5/8-18,IEEE1451.4)
LCF455(L2901)-1000lb(2024-T4 5/8-18,+/-0.05% N.L.IEEE1451.4)
LCF455(L2901)-300lb(17-4 PH S.S. 5/8-18,IEEE1451.4)
LCF455(L2901)-300lb(17-4 PH S.S. 5/8-18,+/-0.05% N.L.IEEE1451.4)
LCF455(L2901)-500lb/1000lb(2024-T4 5/8-18,+/-0.05% N.L.)
LCF455(L2901)-300lb(0.5-4.5 VDC Output,17-4 PH S.S. 5/8-18)
LCF456(L2902)-250lb/500lb/2500lb(17-4 PH S.S. 5/8-18)
LCF456(L2902)-250lb/500lb/1000lb(2024-T4 5/8-18)
LCF456(L2902)-250lb/500lb/1000lb(2024-T4 M16x2)
LCF456(L2902)-2500lb(17-4 PH S.S.M16x2)
LCF456(L2902)-2500lb(17-4 PH S.S. 5/8-18)
LCF456(L2902)-5000lb(17-4 PH S.S.M16x2)
LCF456(L2902)-1000lb(2024-T4 5/8-18,IEEE1451.4)
LCF500(L2900)-20000lb/30000lb(17-4 PH S.S. 1 1/4-12)
LCF500(L2900)-50000lb(17-4 PH S.S.M33x2)
LCF500(L2900)-5000lb/10000lb(17-4 PH S.S.M33x2)
LCF500()-25000lb/50000lb(17-4 PH S.S. 1 1/4-12)
LCF500()-25000lb/50000lb(17-4 PH S.S. 1 1/4-12,IEEE1451.4)
LCF500()-25000lb/50000lb(17-4 PH S.S.M33x2)
LCF501(L2903)-5000lb(17-4 PH S.S. 1 1/4-12)
LCF501(L2903)-10000lb/25000lb(17-4 PH S.S. 1 1/4-12)
LCF501(L2903)-5000lb(17-4 PH S.S.M33x2)
LCF501(L2903)-10000lb/25000lb(17-4 PH S.S.M33x2)
LCF505(L2901)-5000lb/10000lb(17-4 PH S.S. 1 1/4-12,IEEE1451.4,Standard)
LCF505(L2901)-25000lb/50000lb(17-4 PH S.S. 1 1/4-12,IEEE1451.4,4mV/V)
LCF505(L2901)-50000lb(17-4 PH S.S. 1 1/4-12,IEEE1451.4,4mV/V,0.05%N.L.)
LCF505()-50000lb(17-4 PH S.S. 1 1/4-12,+/-0.05% N.L.)
LCF505(L2901)-25000lb(17-4 PH S.S. 1 1/4-12,4mV/V)
LCF505()-50000lb(17-4 PH S.S. 1 1/4-12)
LCF506(L2902)-10000lb/25000lb(17-4 PH S.S. 1 1/4-12)
