西安浩南电子电子科技有限公司
  • Astrodyne DC/DC电源
  • 发布时间:2021/5/25 12:12:25   修改时间:2009/6/27 11:56:28 浏览次数:977
  • Astrodyne  DC/DC电源
    产品信息:
    Astrodyne's extensive line of DC/DC converters provide both a high performance and low cost power conversion solutions for telecommunications, industrial, data acquisition, embedded systems, or any application where efficient distributed power is required.
    Our 0.75 watt to 350 watt power offering gives you the flexibility of high density, wide input range converters in fully encapsulated SIP, DIP, Standard 1” x 2” and ? Brick modules as well as open frame with integral heatsink and cage-enclosed styles. The modules and open frames are PCB mounted while the enclosed modules offer screw terminals for Input/Output connect ability.
      0.75W to 350W Output Power
    Single or Multiple Point-Of-Load Application
    Wide Range of Outputs From 1.1VDC to 118VDC
    Isolation Up To 1,500Volts
    Regulated Outputs
    SIP, DIP, ? Brick Modular and Open Frame Packages
    High Density Series
    0.75 Watt Supplies 1 Watt Supplies 1.5 Watt Supplies
    DUP75
     DU1P0
     ASD105
    DR1P5
    SB1R5
    3 Watt Supplies 5 Watt Supplies 6 Watt Supplies
    ASD03
    MKC03
    PMKC03
     SB03
    VKC03
     ASD05
    ASD05H
    FDC05
     FKC05
    SB05
     ASD06
    7 Watt Supplies 7.5 Watt Supplies 8 Watt Supplies
    ASD07
    ASD07H
     ASD705
     ASD08
    SB08
    10 Watt Supplies 15 Watt Supplies 20 Watt Supplies
    ASD10
    ASD10H
    FDC10
     HNA
    ST10
     ASD15
    ASD15H
    FEC15
     LCD15W
    LED15W
    ST15
     ASD20
    FDC20
    FED20W
     OPN20
    SU20
    60 Watt Supplies
    FDC60
西安浩南电子科技有限公司是一家销售电源,滤波器及电流电压传感器的贸易公司.公司为国内工业企业,船舶,电子通讯,仪器仪表,工控通讯及新能源等企业提供配套产品.   公司主要销售的电源模块,电流电压传感器及EMI/EMC滤波器等产品品牌有: Gaia,…  更多>>
西安浩南电子电子科技有限公司
联系人:刘彦成
地址:西安市高新一路6号
邮编:710075
电话:029-88231631
传真:029-88231651
公司网址:http://www.haonpower.com
  • 黄先生 在2015/9/1 12:34:00留言
  • 详细留言:我司有全新原装VICOR电源模块 型号V300A12M500BL,50片,现在低价处理,贵公司若有这方面的订单随时与我联系,谢谢!
  • 王力 在2014/12/15 17:50:00留言
