北京祥顺达恒科技有限公司
  • Quantum Processor 处理器
  • 发布时间:2008/7/6 4:47:08   修改时间:2008/7/5 15:59:55 浏览次数:598
    140CPU11302 CPU 256K SRAM, 8K LL984,109K IEC,10K 寄存器,1MB&1MB+
    140CPU11302C CPU 256K SRAM, 8K LL984,109K IEC,10K 寄存器,1MB&1MB+,涂层保护
    140CPU11303 CPU 512K SRAM, 16K LL984,368K IEC,10K 寄存器,1MB&1MB+
    140CPU11303C CPU 512K SRAM, 16K LL984,368K IEC,10K 寄存器,1MB&1MB+,涂层保护
    140CPU31110 Unity CPU 486处理器,66MHz, 2M SRAM,  2MB&1MB+
    140CPU31110C Unity CPU 486处理器,66MHz, 2M SRAM,  2MB&1MB+,涂层保护
    140CPU43412A CPU486, 2M SRAM, 64K LL984,896K IEC,57K 寄存器,2MB&1MB+
    140CPU43412AC CPU486, 2M SRAM, 64K LL984,896K IEC,57K 寄存器,2MB&1MB+,涂层保护
    140CPU43412U Unity CPU 486 处理器,66MHz, 2M SRAM, 2MB&1MB+
    140CPU43412UC Unity CPU 486 处理器,66MHz, 2M SRAM, 2MB&1MB+,涂层保护
    140CPU53414B CPU 586, 4M SRAM, 64K LL984,2.5M IEC,57K 寄存器,2MB&1MB+
    140CPU53414BC Unity CPU 586 处理器,133MHz,  4M SRAM, 2MB&1MB+
    140CPU65150 Unity CPU 166MHz, 2M, 768/7168Kb, 1MB, 1MB+, 1USB, 1ETH
    140CPU65160 Unity CPU 266MHz, 2M, 1024/7168Kb, 1MB, 1MB+, 1USB, 1ETH
    140CPU67160 Unity HSBY CPU 67160 ,热备冗余CPU
    140CPU65260 Unity CPU 266MHz, 4M, 4096/7168K
    140CPU65260C Unity Quantum 65260 CPU,带涂敷涂层
    140CPU65150C Unity Quantum 65150 CPU, 带涂敷涂层
    140CPU65160C Unity Quantum 65160 CPU, 带涂敷涂层
    140CPU67160C Unity Quantum 67160 CPU, 带涂敷涂层
    Quantum Hot Standby  双机热备
    140CHS11000 QUANTUM 热备模块
    140CHS11000C QUANTUM 热备模块, 涂层保护
    140CHS21000 QUANTUM 热备套件
    140CHS21000C QUANTUM 热备套件, 涂层保护
    140CHS32000 QUANTUM 热备远程I/O同轴电缆终结套件
    140CHS41010 Level One 低成本热备套件
    140CHS41020 Level One 低成本热备套件
    140SHS94500 热备功能可装载软件
    990XCA65609 热备模块光纤电缆
    490NOR00003 Ethernet MTRJ- MTRJ 光纤电缆,3m(可作为Unity 热备光纤电缆)
    490NOR00005 Ethernet MTRJ- MTRJ 光纤电缆,5m(可作为Unity 热备光纤电缆)
    490NOR00015 Ethernet MTRJ- MTRJ 光纤电缆,15m(可作为Unity 热备光纤电缆)
    Quantum Memory  内存卡
    TSXMCPC002M Unity V2 PCMCIA存储扩展卡,程序存储2x1024K(Flash),数据存储1024K(RAM)
    TSXMCPC224K Unity V2 PCMCIA存储扩展卡,程序存储224K(Flash),数据存储256K(RAM)
    TSXMCPC512K Unity V2 PCMCIA存储扩展卡,程序存储512K(Flash),数据存储512K(RAM)
    TSXMFPB096K Unity V2 PCMCIA程序备份卡,程序存储96KB(Flash)
    TSXMFPP001M Unity V2 PCMCIA存储扩展卡,程序存储1x1024K(Flash)
    TSXMFPP002M Unity V2 PCMCIA存储扩展卡,程序存储2x1024K(Flash)
    TSXMFPP004M Unity V2 PCMCIA存储扩展卡,程序存储4x1024K(Flash)
    TSXMFPP128K Unity V2 PCMCIA存储扩展卡,程序存储128K(Flash)
    TSXMFPP224K Unity V2 PCMCIA存储扩展卡,程序存储224K(Flash)
    TSXMFPP384K Unity V2 PCMCIA存储扩展卡,程序存储384K(Flash)
    TSXMFPP512K Unity V2 PCMCIA存储扩展卡,程序存储512K(Flash)
    TSXMRPC001M Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-1024K,数据存储832-0K
    TSXMRPC001MC Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-1024K,数据存储832-0K,带涂敷涂层
    TSXMRPC002M Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-2048K,数据存储1856-0K
    TSXMRPC003M Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-3072K,数据存储2880-0K
    TSXMRPC003MC Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-3072K,数据存储2880-0K,带涂敷涂层
    TSXMRPC007M Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-7168K,数据存储6976-0K
    TSXMRPC007MC Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-7168K,数据存储6976-0K,带涂敷涂层
    TSXMRPC01M7 Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-1792K,数据存储1600-0K
    TSXMRPC448K Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-448K,数据存储256-0K
    TSXMRPC768K Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-768K,数据存储576-0K
    TSXMRPF004M Unity V2 PCMCIA存储扩展卡(SRAM),文件存储4096K
    TSXMRPF008M Unity V2 PCMCIA存储扩展卡(SRAM),文件存储8192K
    TSXMRPP128K Unity V2 PCMCIA存储扩展卡(SRAM),程序存储128K,数据存储0K
    TSXMRPP224K Unity V2 PCMCIA存储扩展卡(SRAM),程序存储224K,数据存储0K
    TSXMRPP384K Unity V2 PCMCIA存储扩展卡(SRAM),程序存储384K,数据存储0K
    Quantum Power Supply  电源模板
    140CPS11100 电源 115/230 VAC,独立 3A
    140CPS11100C 电源, 115/230 VAC, 独立, 3A, 涂层保护
    140CPS11420 Quantum 电源,115/230 VAC,可累加,11Amp
    140CPS11420C Quantum 电源, 115/230 VAC, 可累加, 11Amp, 带保护涂层
    140CPS12420 Quantum 电源,115/230 VAC,冗余,11Amp
    140CPS12420C Quantum 电源, 115/230 VAC, 冗余, 11Amp,带保护涂层
    140CPS21100 Quantum电源 24 VDC,独立 3A
    140CPS21100C Quantum电源, 24 VDC, 独立, 3A, 涂层保护
    140CPS21400 Quantum电源,24 VDC,可累加,8A
    140CPS21400C Quantum电源, 24 VDC, 可累加, 8A, 涂层保护
    140CPS22400 Quantum 电源,24 VDC,冗余,8Amp
    140CPS22400C Quantum电源, 24 VDC, 冗余, 8A, 涂层保护
    140CPS41400 Quantum 电源,48-60 VDC,可累加,8Amp
    140CPS41400C Quantum电源, 48/60 VDC, 可累加, 8A, 涂层保护
    140CPS42400 Quantum 电源,48-60 VDC,冗余,8Amp
    140CPS42400C Quantum电源, 48/60 VDC, 冗余, 8A, 涂层保护
    140CPS51100 Quantum电源 125 VDC,独立 3A
    140CPS51100C Quantum电源, 125 VDC, 独立, 3A, 涂层保护
    140CPS52400 Quantum 电源,125 VDC,冗余,8Amp
    140CPS52400C Quantum电源, 125 VDC, 冗余, 8A, 涂层保护
    Quantum Digital Input Module 开关量输入模板
    140DAI34000 开关量 AC 输入,16 点,24 VAC,隔离
    140DAI34000C 开关量 AC 输入, 16点, 24 VAC, 隔离, 涂层保护
    140DAI35300 开关量 AC 输入,32 点,24 VAC, 8 点成组隔离
    140DAI35300C 开关量 AC 输入, 32点, 24 VAC, 8点成组隔离, 涂层保护
    140DAI44000 开关量 AC 输入,16 点,48 VAC,隔离
    140DAI44000C 开关量 AC 输入, 16点, 48 VAC, 隔离, 涂层保护
    140DAI45300 开关量 AC 输入,32 点,48 VAC, 8 点成组隔离
    140DAI45300C 开关量 AC 输入, 32点, 48 VAC, 8点成组隔离, 涂层保护
    140DAI54000 开关量 AC 输入,16 点,115 VAC,隔离
    140DAI54000C 开关量 AC 输入, 16点, 115 VAC, 隔离, 涂层保护
    140DAI54300 开关量 AC 输入,16 点,115 VAC, 8 点成组隔离
    140DAI54300C 开关量 AC 输入, 16点, 115 VAC, 8点成组隔离, 涂层保护
    140DAI55300 开关量 AC 输入,32 点,115 VAC, 8 点成组隔离
    140DAI55300C 开关量 AC 输入, 32点, 115 VAC, 8点成组隔离, 涂层保护
    140DAI74000 开关量 AC 输入,16 点,230 VAC,隔离
    140DAI74000C 开关量 AC 输入, 16点, 230 VAC, 隔离, 涂层保护
    140DAI75300 开关量 AC 输入,32 点,230 VAC, 8 点成组隔离
    140DAI75300C 开关量 AC 输入, 32点, 230 VAC, 8点成组隔离, 涂层保护
    140DDI15310 开关量 DC 输入,32 点,5 VDC, 4 组隔离,负逻辑
    140DDI15310C 开关量 DC 输入, 32点, 5 VDC, 4组隔离, 负逻辑,涂层保护
    140DDI35300 开关量 DC 输入,32 点,24 VDC, 4 组隔离
    140DDI35300C 开关量 DC 输入, 32点, 24 VDC, 4组隔离, 涂层保护
    140DDI35310 开关量 DC 输入,32 点,24 VDC, 4 组隔离,负逻辑
    140DDI35310C 开关量 DC 输入, 32点, 24 VDC, 4组隔离, 负逻辑,涂层保护
    140DDI36400 开关量 DC 输入,96 点,24 VDC, 6 组隔离
    140DDI36400C 开关量 DC 输入, 96点, 24 VDC, 6组隔离, 涂层保护
    140DDI67300 开关量 DC 输入,24 点,125 VDC, 3 组隔离
    140DDI67300C 开关量 DC 输入, 24点, 125 VDC, 3组隔离,涂层保护
    140DDI84100 开关量 DC 输入,16 点,10-60 VDC, 8 组隔离
    140DDI84100C 开关量 DC 输入, 16点, 10-60 VDC, 8组隔离, 涂层保护
    140DDI85300 开关量 DC 输入,32 点,10-60 VDC, 4 组隔离
    140DDI85300C 开关量 DC 输入, 32点, 10-60 VDC, 4组隔离, 涂层保护
    140DII33000 开关量输入 8 通道, 本安型,
    140DII33000C 开关量输入, 8点, 本安型,涂层保护
    140DSI35300 开关量 Supervised DC 输入,32 点,24 VDC, 4 组隔离(断线检测)
    140DSI35300C 开关量 Supervised DC输入, 32点,4组,(断线检测),涂层保护
    Quantum Digital Output Module 开关量输出模板
    140DAO84000 开关量 AC 输出,16 点,24-230 VAC,隔离,4A/点
    140DAO84000C 开关量 AC 输出, 16点, 24-230 VAC, 隔离, 4A/点,涂层保护
    140DAO84010 开关量 AC 输出,16 点,24-115 VAC,隔离,4A/点
    140DAO84010C 开关量 AC 输出, 16点, 24-115 VAC, 隔离, 4A/点, 涂层保护
    140DAO84210 开关量 AC 输出,16 点,110-230 VAC,隔离,4 组隔离,4A/点
    140DAO84210C 开关量 AC 输出, 16点, 110-230 VAC, 隔离, 4组隔离,4A/点, 涂层保护
    140DAO84220 开关量 AC 输出,16 点,24-48 VAC,隔离,4 组隔离,4A/点
    140DAO84220C 开关量 AC 输出, 16点, 24-48 VAC, 4组隔离,4A/点, 涂层保护
    140DAO85300 开关量 AC 输出,32 点,24-230 VAC, 4 组隔离,1A/点
    140DAO85300C 开关量 AC 输出, 32点, 24-230 VAC, 4组隔离, 1A/点,涂层保护
    140DDO15310 开关量 DC 输出,32 点,5 VDC TTL, 4 组隔离, 75mA/点
    140DDO15310C 开关量 DC 输出, 32点, 5 VDC, 4组隔离, 75mA/点, 涂层保护
    140DDO35300 开关量 DC 输出,32 点,24 VDC, 4 组隔离, 0.5A/点
    140DDO35300C 开关量 DC 输出, 32点, 24 VDC, 4组隔离, 0.5A/点, 涂层保护
    140DDO35301 开关量 DC 输出,32 点,24 VDC, 4 组隔离,0.5A/点 *
    140DDO35301C 开关量 DC 输出, 32点, 24 VDC, 4组隔离, 0.5A/点, 涂层保护 *
    140DDO35310 开关量 DC 输出,32 点,24 VDC, 4 组隔离, 0.5A/点,负逻辑
    140DDO35310C 开关量 DC 输出, 32点, 24 VDC, 4组隔离, 0.5A/点, 负逻辑, 涂层保护
    140DDO36400 开关量 DC 输出,96 点,24 VDC, 6 组隔离, 0.5A/点
    140DDO84300 开关量 DC 输出,16 点,10-60 VDC, 2 组隔离, 2A/点
    140DDO84300C 开关量 DC 输出, 16点, 10-60 VDC,2组隔离, 2A/点, 涂层保护
    140DDO88500 开关量 DC 输出, 12 点, 24-125 VDC, 2 组隔离, 0.75A/点
    140DDO88500C 开关量 DC 输出, 12点, 24-125 VDC,2组隔离,0.75A/点,涂层保护
    140DIO33000 开关量输出 8 通道, 本安型
    140DIO33000C 开关量输出, 8点, 本安型,涂层保护
    140DRA84000 继电器输出,16 点,NO, 2A/点
    140DRA84000C 继电器输出, 16点, NO, 2A/点, 涂层保护
    140DRC83000 继电器输出,8 点,NO/NC, 5A/点
    140DRC83000C 继电器输出, 8点, NO/NC, 5A/点, 涂层保护
    140DVO85300 开关量Verified DC 输出,32 点,10-30 VDC, 4 组隔离, 0.5A/点
    140DVO85300C 开关量输出,32点,10-30VDC,校验0.5A/点,涂层保护
    Quantum Digital Mixed Module 开关量混合模板
    140DAM59000 开关量 DC 混合模块,16 点输入,125 VAC, 8点输出
    140DAM59000C 开关量 AC 混合模块, 16点输入, 115 VAC; 8点输出, 涂层保护
    140DDM39000 开关量 DC 混合模块,16 点输入,24 VDC, 8 点输出
    140DDM39000C 开关量 DC 混合模块, 16点输入, 24 VDC; 8点输出, 涂层保护
    140DDM69000 开关量 DC 混合模块,4 点输入,125 VDC, 4 点输出
    140DDM69000C 开关量 DC 混合模块, 4点输入, 125 VDC; 4点输出, 涂层保护
    Quantum Analog Input Module  模拟量输入模板
    140ACI03000 模拟量输入,单极性,8 通道,4-20mA 或 1-5VDC,12位
    140ACI03000C 模拟量输入, 单极性, 8通道, 4-20mA 或 1-5VDC,12位,涂层保护
    140ACI04000 模拟量输入,16 通道,4-20mA,0-20mA,0-25mA,12或14位
    140ACI04000C 模拟量输入, 16通道, 4-20mA,0-20mA,0-25mA,12或14位,涂层保护
    140AII33000 RTD/TC 输入, 8通道, 本安型
    140AII33000C RTD/TC 输入, 8通道, 本安型, 涂层保护
    140AII33010 模拟量输入, 8通道, 电流, 本安型
    140AII33010C 模拟量输入, 8通道, 电流, 本安型,涂层保护
    140ARI03010 RTD 输入,8 通道,类型 NI 或 PT, 100, 200, 500, 1000
    140ARI03010C RTD 输入, 8通道, 类型 NI 或 PT, 100,200,500,1000, 涂层保护
    140ATI03000 TC 输入,8 通道,类型 J, K, E, T, S, R, B
    140ATI03000C TC 输入, 8通道, 类型 J,K,E,T,S,R,B, 涂层保护
    140AVI03000 模拟量输入,8 通道,双极性,多量程
    140AVI03000C 模拟量输入, 8通道, 双极性, 多量程, 涂层保护
    Quantum Analog Output Module  模拟量输出模板
    140ACO02000 模拟量输出,4 通道,4-20mA,通道隔离,12位
    140ACO02000C 模拟量输出, 4通道, 4-20mA, 通道隔离, 12位,涂层保护
    140ACO13000 模拟量输出,8 通道,高密度
    140ACO13000C 模拟量输出, 8通道, 高密度, 涂层保护
    140AIO33000 模拟量输出, 8 通道, 15-位,本安型
    140AIO33000C 模拟量输出, 8通道, 电流, 本安型, 涂层保护
    140AVO02000 模拟量输出,4 通道,电压
    140AVO02000C 模拟量输出, 4通道, 电压, 涂层保护
    Quantum Analog Mixed Module  模拟量混合模板
    140AMM09000 模拟量混合模块,4 通道输入,2 通道输出
    140AMM09000C 模拟量混合模块, 4通道输入, 2通道输出,涂层保护
    Quantum Intelligent Module  智能模板
    140EHC20200 高速计数模块,24 VDC, 500KHz, 2 通道
    140EHC10500 高速计数模块,100kHz@5 VDC, 35kHz@24VDC,5 通道
    140EHC10500C 高速计数模块,100kHz@5 VDC, 35kHz@24VDC,5 通道,涂层保护
    140EHC20200C 高速计数模块, 24 VDC, 500KHz, 2通道, 涂层保护
    140HLI34000 高速锁存/计数模块,24 VDC
    140HLI34000C 高速锁存/计数模块,24 VDC, 涂层保护
    140ERT85410 事件纪录模块,SER
    Quantum Backplane  背板
    140XBP00200 背板,2 槽
    140XBP00200C 背板, 2槽,涂层保护
    140XBP00300 背板,3 槽
    140XBP00300C 背板, 3槽, 涂层保护
    140XBP00400 背板,4 槽
    140XBP00400C 背板, 4槽, 涂层保护
    140XBP00600 背板,6 槽
    140XBP00600C 背板, 6槽, 涂层保护
    140XBP01000 背板,10 槽
    140XBP01000C 背板, 10槽, 涂层保护
    140XBP01600 背板,16 槽
    140XBP01600C 背板, 16槽, 涂层保护
    140XBE10000 背板扩展模块
    140XBE10000C 背板扩展模块, 涂层保护
    140XCA71703 背板扩展电缆,1M
    140XCA71706 背板扩展电缆,2M
    140XCA71709 背板扩展电缆,3M
    Quantum Remote I/O (S908-Coax.)   远程I/O系统
    140CRP93100 RIO 处理器接口,S908 Head,单电缆
    140CRP93200 RIO 处理器接口,S908 Head,双电缆
    140CRA93100 RIO 站适配器,S908 RIO,单电缆
    140CRA93200 RIO 站适配器,S908 RIO,双电缆
    140CRA93100C RIO 站适配器, S908 RIO, 单电缆, 涂层保护
    140CRA93101 LMS RIO 站适配器, S908 RIO, 单电缆
    140CRA93101C LMS RIO 站适配器, S908 RIO, 单电缆, 涂层保护
    140CRA93200C RIO 站适配器, S908 RIO, 双电缆, 涂层保护
    140CRP93100C RIO 处理器接口, S908 Head, 单电缆, 涂层保护
    140CRP93200C RIO 处理器接口, S908 Head, 双电缆, 涂层保护
    490NRP95400 RIO 光纤中继器
    975750000 RIO同轴电缆,RG-6
    975951000 RIO同轴电缆,RG-11
    ASMBII003 RIO预装分站电缆 15 m
    ASMBII004 RIO预装分站电缆 42 m
    MA0185100 远程I/O电缆 分支器
    MA0186100 远程I/O电缆 分离器
    MA0331000 REMOTE I/O TRUNK SPLITTER
    520402000 远程I/O分支器终端电阻
    520422000 远程I/O干电缆终结电阻,75 欧
    MA0329001 远程I/O电缆 F 接头(10个/盒)
    490RIO00211 F 连接器 用于 RG-11(6个/盒)
    520480000 右角度 F 适配器 用于半刚性电缆
    520614000 F-to-BNC 适配器 用于 RG-11 电缆
    600513000 BNC 终结电阻
    490RIO00400 RG-6 同轴电缆剥线工具
    490RIO0S411 RG-11 同轴电缆 剥线工具
    490RIO00406 替换刀片 RG-6
    490RIO00411 用于490RIO00400 同轴电缆脱膜工具的RG11替代刀片
    490RIO0C411 卷曲工具 用于 RG-11,  F 连接器
    600544000 用于 RG-6 F 连接器压接工具
    600558000 电缆切割钳
    Quantum Distributed I/O (Modbus Plus) 分布式I/O
    140CRA21110 DIO 站适配器和电源,115/230 VAC,独立,3A,单电缆
    140CRA21110C DIO 站适配器和电源, 115/230 VAC, 独立, 3A, 单电缆, 涂层保护
    140CRA21120 DIO 站适配器和电源,24 VDC,独立,3A,单电缆
    140CRA21120C DIO 站适配器和电源, 24 VDC, 独立, 3A, 单电缆, 涂层保护
    140CRA21210 DIO 站适配器和电源,115/230 VAC,独立,3A,双电缆
    140CRA21210C DIO 站适配器和电源, 115/230 VAC, 独立, 3A, 双电缆, 涂层保护
    140CRA21220 DIO 站适配器和电源,24 VDC,独立,3A,双电缆
    140CRA21220C DIO 站适配器和电源, 24 VDC, 独立, 3A, 双电缆, 涂层保护
    Quantum Communication Module 网络通讯模板
    140NOE77101 Quantum Ethernet 10/100M 模板
    140NOE77101C Quantum Ethernet  10/100M 模板,涂层保护
    140NOE77111 Quantum Factorycast Web Server Ethernet 10/100M模板
    140NOE77111C Quantum Factorycast Web Server Ethernet 10/100M 模板,涂层保护
    140NOM21100 MB+ 网络适配器,1MB, 1MB+,单电缆
    140NOM21100C MB+ 网络适配器, 1MB, 1MB+, 单电缆, 涂层保护
    140NOM21200 MB+ 网络适配器,1MB, 1MB+,双电缆
    140NOM21200C MB+ 网络适配器, 1MB, 1MB+, 双电缆, 涂层保护
    140NOM25200 MB+ 网络适配器, 光纤接口, 1 CH
    140NOM25200C MB+ 网络适配器, 光纤接口, 1CH, 涂层保护
    140NWM10000 FactoryCast HMI
    140EIA92100 Quantum AS-i MASTER模板,1通道
    140EIA92100C Quantum AS-i MASTER模块,1通道,涂层保护
    140NOA62200 Interbus 主站模块
    140ESI06210 ASCII 串行通讯模块,RS232,2通道
    140ESI06210C ASCII 串行通讯模块, RS232, 2通道, 涂层保护
    Quantum Communication Accessories  网络通讯及附件
    490NAE91100 Profibus DP Tap带Host口
    467NHP81100 467 NHP 811 00-PC/DP包
    490NAD91103 Profibus 连接器 终端
    490NAD91104 Profibus 连接器 线间
    490NAD91105 Profibus 连接器 线间 + 终端
    490NAC72100 MB+ 避雷装置
    490NRP25300 光纤中继器,单光口,Modbus Plus
    490NRP25400 光纤中继器,双光口,Modbus Plus
    490NTRJ11 TF可配置转换器,CORD
    490NAA21302 MB+ SUPPER 网络电缆,500英尺
    490NAA27101 MB+ 电缆,10英尺
    490NAA27102 MB+ 电缆,500英尺
    490NAA27103 MB+ 电缆,1000英尺
    490NAA27104 MB+ 电缆,1500英尺
    490NAA27106 MB+ 电缆,5000英尺
    990NAD21110 MB+ 站电缆, 2.4M
    990NAD21130 MB+ 站电缆, 6M
    990NAD23000 MB+ TAP接头
    990NAD23010 MB+ TAP接头, mounting plate
    990NAD23011 线缆终结器
    990NAD23020 MB+ TAP接头, DIN rail
    990NAD23021 MB+ TAP接头, mounting plate
    990NAD23022 MB+ 线缆终结器
    990NAA21510 耐用型带Modbus Plus接头编程电缆(10 英寸)
    990NAD21810 MB+ 支线电缆, 2.4m, 左向
    990NAD21830 MB+ 支线电缆, 6m, 左向
    990NAD21910 MB+  支线电缆, 2.4m, 右向
    990NAD21930 MB+  支线电缆, 6m, 右向
    990NAD23012 MB+ 加固型接头DIN导轨安装套件
    ASMBKT085 MB+ LINE 接头
    ASMBKT185 MB+ 终端接头
    ASMBPL001 MB+ 接头工具
    NWBM85C002 MB+ 网桥/多路转换器, 2 MB+, 4 RS232, Modbus, 115/220 VAC, 24 VDC,Panel
    NWBM85D008 MB+ 网桥/多路转换器, 2 MB+, 4 RS232, Modbus,19'in Rack, 24/115 VDC,Panel
    NWBM85S232 MB+ 网桥/多路转换器,2 MB+,可编程,4 RS232,Panel
    NWBM85S485 MB+ 网桥/多路转换器,2 MB+,可编程,4 RS485,Panel
    NWBP85002 MB+ 网桥,双电缆,115/230VAC, Panel
    NWRR85001 MB+ 中继器,单电缆
    Quantum Programming Cable  编程电缆
    990NAA26320 编程电缆,RS232, 3.7M/12 英尺
    990NAA26350 编程电缆,RS232, 50 英尺
    UNYXCAUSB033 Unity USB 编程电缆
    110XCA28201 连接电缆, 用于 PC RJ45 接口 1 m
    110XCA28202 连接电缆, 用于 PC RJ45 接口 3 m
    110XCA28203 连接电缆, 用于 PC RJ45 接口 6 m
    Quantum Cablefast Connection  Cablefast 预接线系统
    140CFA04000 CABLEFAST, 通用连接块, 直头连接
    140CFB03200 CABLEFAST, 数字输入块, 单独保险
    140CFC03200 CABLEFAST, 数字输出块, 成组保险
    140CFD03200 CABLEFAST, 数字输入块, 2线或3线, 单独保险
    140CFE03200 CABLEFAST, 数字输出块, 单独保险
    140CFG01600 CABLEFAST, 大功率数字 I/O 块, 单独保险
    140CFH00800 CABLEFAST, 模拟量输入块, 带保险
    140CFI00800 CABLEFAST, 模拟量输入块, 无保险
    140CFJ00400 CABLEFAST, 模拟量输出块, 带保险
    140CFK00400 CABLEFAST, 模拟量输出块, 无保险
    140CFU00600 CABLEFAST 保险, 1/16 AMP
    140CFU08000 CABLEFAST 保险, 0.8 AMP
    140CFU40000 CABLEFAST 保险, 4 AMP
    140CFX00110 CABLEFAST 端子块接地条, 10位置
    140CFX00210 CABLEFAST 保险备用跨接器
    140XCA10206 CABLEFAST电缆, 大电流, 50针D型,2M
    140XCA10215 CABLEFAST电缆, 大电流, 50针D型,5M
    140XTS00203 CABLEFAST电缆, 带 QUANTUM I/O 端子, 0.9M
    140XTS00206 CABLEFAST电缆, 带 QUANTUM I/O 端子, 1.8M
    140XTS00209 CABLEFAST电缆, 带 QUANTUM I/O 端子, 2.7M
    140XTS00212 CABLEFAST电缆, 带 QUANTUM I/O 端子, 3.7M
    140XTS01203 CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子, 0.9M
    140XTS01206 CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子, 1.8M
    140XTS01209 CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子, 2.7M
    140XTS01212 CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子, 3.7M
    140XTS10206 CABLEFAST电缆, 大电流, 带 I/O 端子, 1.8M
    140XTS10215 CABLEFAST电缆, 大电流, 带 I/O 端子, 4.6M
    Quantum Terminal Block and Accecories  端子连接器及附件
    140XCP20000 I/O 模块标签
    140XCP40100 19 英寸 前导轨安装架 125 mm
    140XCP40200 19 英寸 前导轨安装架  20 mm
    140XCP50000 空槽模块, 无端字条
    140XCP51000 空槽模块, 带悬挂门
    140XCP60000 端子条跨接器
    140XCP90000 RAM电池备用模块, 用于ESI061和EHC105
    140XCP90000C RAM电池备用模块, 用于ESI061和EHC105, 涂层保护
    140XSM00200 开关量输入模拟器, 用于DAI540或DAI740
    140XSM01000 模拟量模拟器, 2个电位器,用于AMM090
    140XTS00100 40点模块端子条, IP20
    140XTS00200 40 点模块端子条
    140XTS00500 7点端字条, IP20
    140XTS33200 40 点模块端子条, 本安型蓝色 (IP20 级)
    990MCO00065 塑包光纤,19.8M
    990MCO00095 塑包光纤,28.9M
    990MCO00105 塑包光纤,32M
    990MCO00115 SERCOS光纤电缆,115FT
    990MCOKIT00 用于安装光缆的设备
    990MCOKIT01 光缆 和 SMA-型连接器 套件
    990XCP98000 Quantum CPU 电池
    990XTS00300 B200 转换接头
    110XCA20300 适配器 RJ45 到 RS232
北京祥顺达恒科技有限公司(祥顺达恒)座落于历史悠久的北京市宣武区,创建于2002年,是一家专业从事进口工业自动化产品集成与销售的工控技术公司;公司董事均为业内知名人士。 公司现下设电子商务、市场、系统工程、售后服务等部门,为各生产企…  更多>>
北京祥顺达恒科技有限公司
联系人:谢仁
地址:北京市宣武区福长街四条4号213室
邮编:100055
电话:010-86866272
传真:010-86866272
公司网址:http://www.86866272.com
  • Kinsella 在2022/7/27 22:42:00留言
  • 详细留言:The day before yesterday I received a message that I need to pick up my prize. But I lost the email with the data to access the site. How do I restore access? >>> https://is.gd/6JIDfz
  • 张伟 在2014/12/4 14:46:00留言
  • 详细留言:施耐德M340系统PLC卡件//BMX AMM 0600 块 1 2 施耐德M340系统PLC卡件//BMX DDO 6402K,配两条3米BMX FCW 03电缆 块 1 3 施耐德M340系统PLC卡件//BMX DDI 6402K,配两条长3米的BMX FCW 03电缆 块 1 4 施耐德M340系统PLC卡件//BMX ART 0814 块 2 5 施耐德M340系统PLC卡件机架//BMX XBP 1200 块 1 6 施耐德M340系统PLC电源模块//BMX CPS 3500 块 1 7 施耐德M340系统PLC处理器//BMX P34 2020
  • 详细留言:采购货物
  • 易先生 在2012/4/5 16:10:00留言
  • 详细留言:m340系列
  • 曹喜合 在2009/10/29 14:40:00留言
  • 留言类型:
  • 详细留言:求TSXPCX3030-C 编程电缆的驱动程序
