珠海科尔迈测试设备有限公司
  • DFT Digital force tester(数显式测力计)
  • 发布时间:2008/8/28 21:21:21   修改时间:2008/7/31 16:20:39 浏览次数:1600
  • DFT Digital force tester offers a wide range of digital force tester and are available for all testing requirements, with capacities starting from 5 N to 2,500 N (0.5 to 250 Kg, 1.1 to 550 lbs). With an accuracy of ±0.1%, DFT also has database, statistics, date/time, pass/fail, reverse display and backlight.
    NEXTECH® DFT Force Tester offers highfeatures, a wide range of digital force tester and are availablefor all testing requirements, with capacities starting from 5 N to2,500 N (0.5 to 250 Kg, 1.1 to 550 lbs). The DFT Force Tester arecompact, easy to use and measure both the load of tension andcompression. Units of measurement can be displayed with any units(lb, Kg, N) of measurement desired, by a buttons click. With anaccuracy of ±0.1%, DFT also has database, statistics, date/time,pass/fail, reverse display and backlight.
    Features:
     • Large LCD display • Economic design  • Ease of use ofSoftware
     • Easy RS232 data connectivity • Highly accuratemeasurement
     • Check both Tension and Compression
     • Real time and peak mode (selectable)
     • NIST traceable calibration  • Overloadalarm, low battery indicator
     • Interchangeable units between lb, kg and Newton
     • Compatible with common test stands and grips
     • Operates on rechargeable batteries or from direct ACpower supply
     • Full set of accessories including hook, plateextension rod, batteries,
      carrying case andAC Charger/Adapter and a user's manual
    Specification:
    • Capacity Range: 9 Model, 5N to 2500N
    • Accuracy + 0.1%
    • Resolution 2500 divs
    • A/D Rate 1000 Hz
    • Effective Peak 0.1 sec
    • Data Capture Function:DFT also has database,statistics, date/time, pass/fail, reverse display and backlight
    • Tension and Compression Testing: Both
    • Overload Protection: 120% minimum
    • Power: Rechargeable Battery or AC Power
    • Display Type: Dot Matrix LCD
    • Data Collection: RS232
    • Weight: 27 oz (775 g) 500 N and below 37 oz (1060 g) 1000N andabove
    • Operating Temperature: 60ํ - 95 F (15-35 C)
    • Includes: Hook, plate, extension rod, carry case, batteries,charger, user’s manual, calibration certificate
    • Load Bar: Shows load percentage to minimize overloads
    • Battery Charge: 20 hours full operation from full charge
    • Accessories Available: Universal test stand mounting plate,serial cable, software, quick couplers and adapters, test stands,popular grip assortment
    • Warranty: One years parts and Labor
    Model DFTCapacity and Divisions:
    Model No: mN N kN g-f kg-f oz-f lb-f
    DFT005 5000 x1 5 x0.001 - 500 x0.1 0.5 x0.0001 17.5 x0.005 1.1 x0.0002
    DFT010 10000 x2 10 x0.002 - 1000 x0.2 1 x0.0002 35 x0.01 2.2 x0.0005
    DFT025 25000 x5 25 x0.005 - 2500 x0.5 2.5 x0.0005 87.5 x0.025 5.5 x0.001
    DFT050 50000 x10 50 x0.01 - 5000 x1 5 x0.001 175 x0.05 11 x0.002
    DFT100 - 100 x0.02 - 10000 x2 10 x0.002 350 x0.1 22 x0.005
    DFT250 - 250 x0.05 - 25000 x5 25 x0.005 875 x0.25 55 x0.01
    DFT500 - 500 x0.1 - 50000 x10 50 x0.01 1750 x0.5 110 x0.02
    DFT1000 - 1000 x0.2 1 x0.0002 - 100 x0.02 - 220 x0.05
    DFT2500 - 2500 x0.5 2.5 x0.0005 - 250 x0.05 - 550 x0.1
珠海科尔迈测试设备有限公司位于珠海市吉大景园路,是一家专业经销世界一流科学仪器,工业测试仪器,环境实验设备,光学仪器,力学仪器,电磁兼容,电子安规等检测设备的公司。主要客户有研发实验室,认证机构,学校及电子,汽车制造业,玩具加…  更多>>
珠海科尔迈测试设备有限公司
联系人:陈小姐
地址:珠海市吉大景园路16号华庆大厦3楼
邮编:519000
电话:0756-3353658
传真:0756-3361895
公司网址:http://www.keermai.com
