珠海科尔迈测试设备有限公司
  • Force Gauge(数显式测力计)
  • 发布时间:2008/9/27 11:13:16   修改时间:2008/7/31 16:18:50 浏览次数:585
  • DFS Digital force tester is a more economical digital force tester but thus, provide a and are available for all testing requirements, with capacities starting from 5 N to 2,500 N (0.5 to 250 Kg, 1.1 to 550 lbs). The DFS offers a far more functionality within its price range, with an accuracy of ±0.2%, and a lot of more features.
    NEXTECH® DFS ForceTester is a more economical digital force tester but thus,provide a and are available for all testing requirements, withcapacities starting from 5 N to 2,500 N (0.5 to 250 Kg, 1.1 to 550lbs). The DFS Force Tester are compact, easy to use and measureboth the load of tension and compression. Units of measurement canbe displayed with any units (lb, Kg, N) of measurement desired, bya buttons click. The DFS offers a far more functionality within itsprice range, with an accuracy of ±0.2%, and a lot of morefeatures.
    Features:
     • Large LCD display • Economic design  • Ease of use ofSoftware
     • Easy RS232 data connectivity • Highly accuratemeasurement
     • Check both Tension and Compression
     • Real time and peak mode (selectable)
     • NIST traceable calibration  • Overloadalarm, low battery indicator
     • Interchangeable units between lb, kg and Newton
     • Compatible with common test stands and grips
     • Operates on rechargeable batteries or from direct ACpower supply
     • Full set of accessories including hook, plateextension rod, batteries,
      carrying case andAC Charger/Adapter and a user's manual
    Specification:
    • Capacity Range: 9 Model, 5N to 2500N
    • Accuracy + 0.2%
    • Resolution 2500 divs
    • A/D Rate 1000 Hz
    • Effective Peak 0.1 sec
    • Tension and Compression Testing: Both
    • Overload Protection: 120% minimum
    • Power: Rechargeable Battery or AC Power
    • Display Type: Dot Matrix LCD
    • Data Collection: RS232
    • Weight: 27 oz (775 g) 500 N and below 37 oz(1060 g) 1000N and above
    • Operating Temperature: 60ํ - 95 F (15-35 C)
    • Includes: Hook, plate, extension rod, carrycase, batteries, charger, user’s manual, calibration certificate
    • Load Bar: Shows load percentage to minimizeoverloads
    • Battery Charge: 20 hours full operationfrom full charge
    • Accessories Available: Universal test standmounting plate, serial cable, software, quick couplers andadapters, test stands, popular grip assortment
    • Warranty: One years parts andLabor
    Model DFS Capacity and Divisions:
    Model No: mN N kN g-f kg-f oz-f lb-f
    DFS 5 5000 x2 5 x0.002 - 500 x0.2 0.5 x0.0002 17.5 x0.010 1.1 x0.0005
    DFS 10 10000 x5 10 x0.005 - 1000 x0.5 1 x0.0005 35 x0.02 2.2 x0.0010
    DFS 25 25000 x10 25 x0.010 - 2500 x1.0 2.5 x0.0010 87.5 x0.05 5.5 x0.002
    DFS 50 50000 x20 50 x0.02 - 5000 x2 5 x0.002 175 x0.10 11 x0.005
    DFS 100 - 100 x0.05 - 10000 x5 10 x0.005 350 x0.2 22 x0.010
    DFS 250 - 22 x0.010 - 25000 x10 25 x0.010 875 x0.5 55 x0.02
    DFS 500 - 500 x0.2 - 50000 x20 50 x0.02 1750 x1.0 110 x0.05
    DFS 1000 - 1000 x0.5 1 x0.0005 - 100 x0.05 - 220 x0.10
    DFS 2500 - 2500 x1.0 2.5 x0.0010 - 100 x0.05 - 550 x0.2
珠海科尔迈测试设备有限公司位于珠海市吉大景园路,是一家专业经销世界一流科学仪器,工业测试仪器,环境实验设备,光学仪器,力学仪器,电磁兼容,电子安规等检测设备的公司。主要客户有研发实验室,认证机构,学校及电子,汽车制造业,玩具加…  更多>>
珠海科尔迈测试设备有限公司
联系人:陈小姐
地址:珠海市吉大景园路16号华庆大厦3楼
邮编:519000
电话:0756-3353658
传真:0756-3361895
公司网址:http://www.keermai.com
