simpson 260-9 &260-9SP,Industrial Safety VOM
The new 260 Volt-Ohm-Meter is suitable for testing most commercial and industrial installations and is rated for Category III-600V applications.
Safety is the major design feature of the 260-9S/9SP and the reputation, advantages and reliability of Simpson test equipment is guaranteed.
- Certified to EN61010-1 to 600V, Category III
- Self-contained AC current measurement up to 10 Amps
- Overload protection available
- Includes test lead set with retractable banana jacks and carrying case
- Specifications:
DC RANGES |
AC RANGES |
RESISTANCE |
DECIBEL |
Voltage |
Current |
Voltage |
Current |
Rx1 |
-20 to +43db |
0-250mV |
0-1mA |
0-2.5V |
10A |
Rx100 |
Reference: 0dB = 1mW into 600
Ohms |
0-2.5V |
0-10mA |
0-10V |
Note: Up to 250 AC Amps
w/Amp Clamp Accessory
150-2. See below. |
Rx10K |
0-10V |
0-100mA |
0-25V |
Batteries: 1.5V AA, 9V (NEDA No.13F, 1604A) |
0-25V |
0-600mA |
0-60V |
SIZE AND WEIGHT |
0-60V |
0-10A |
0-100V |
Accuracy: Better than ±2.5° of Arc on
Rx1 and ±2° of arc for Rx100 and
Rx10K range. Some improvement
possible by careful zero setting.
Fuse: F1 1A, 250V type 3AG, quick
acting littelfuse type 312001; F2 2A,
600V littelfuse type BLS or 2A 600V,
Bussman Type BBS. |
Width:
5 1/4"
(13.34 cm) |
0-100V |
Sensitivity: 5K Ohms Per Volt
Insertion Loss (mV drop): 250mV
Accuracy: ± 3% of Full Scale |
0-250V |
Length: 7" (17.78 cm) |
0-600V |
Sensitivity: 20K Ohms Per Volt
Accuracy: ±2% of Full Scale |
Depth:
3 1/8"
(7.94 cm) |
2 1/4 lbs.
(1.02 kg) |
Ordering Information:
Item
Part No. |
Replacement Accessories |
Part No.
Other Accessories |
Part No.
Model260-9S Safety
VOM with case |
12397 |
Case, Nylon Padded, Safety Orange, 260 |
00838 |
150-2 AC Clamp Adapter |
00541 |
Model 260-9SP
Safety VOM,
protected w/case |
12398 |
Test Lead Set, Retractable
Banana, Probe Tip |
07546 |
Clip Set, Alligator, Screw On |
00425 |
