珠海科尔迈测试设备有限公司
  • Simpson229-2, AC Leakage Current Tester
  • 发布时间:2008/5/14 5:23:25   修改时间:2008/5/7 15:11:06 浏览次数:557
  • Simpson 229-2 AC Leakage Current Tester
    Testing for dangerous small leakage currents is easy with the Simpson Model 229-2 Leakage Current Tester. For use in appliance field service, in the lab, or in production, the 229-2 approximates the human threshold of perception in detecting hazardous AC leakage current. The 229-2 comes with test leads with alligator clips, manual and batteries.
    • Checks both 120VAC and 240VAC appliances, motors and other equipment
    • Conforms to ANSI C101.1-1986 and UL safety standards
    • Overload protected up to 500V peak momentarily on all ranges
    • Compensated to approximate Dalziel's threshold of perception curve
    • Specifications
      Ranges: AC current: 0-0.3-1-3-10 mA
      AC voltage: 0-150 and 0-300 volts
      Battery Test: Replace-Good
      Short Test: Red Arc: 30 mA FS, Green arc: 10 mA or less
      Resolution: 5_A on 0-0.3 mA range
      Accuracy: _3% at 60 Hz
      Input Impedance: For current tests, 1.5K_ in parallel with 0.15 mF
      Input Resistance: 0.5 for 150V Range, 1.0 M_ for the 300V range
      Accuracy Vs. Frequency: Approximates Dalziel's "Percentile 50 Threshold of Perception Curve" within _1.0 dB
      Overload Protection: Up to 500V peak momentary on all ranges
      Size: 7" x 5-1/4" x 3-1/8"
      Weight: 3 Ibs. (1.4 Kg)
      Battery: 1 9V (NEDA No. 13F, 1604A)
      Specifications subject to change without notice.
      Carrying Case accommodates the Tester as well as test leads and accessories.
珠海科尔迈测试设备有限公司位于珠海市吉大景园路,是一家专业经销世界一流科学仪器,工业测试仪器,环境实验设备,光学仪器,力学仪器,电磁兼容,电子安规等检测设备的公司。主要客户有研发实验室,认证机构,学校及电子,汽车制造业,玩具加…  更多>>
珠海科尔迈测试设备有限公司
联系人:陈小姐
地址:珠海市吉大景园路16号华庆大厦3楼
邮编:519000
电话:0756-3353658
传真:0756-3361895
公司网址:http://www.keermai.com
