深圳市德威达科技有限公司
  • Dwyer DPM系列尘挨浓度监视报警器
  • 发布时间:2008/8/22 22:29:09   修改时间:2008/8/19 14:25:42 浏览次数:515
  • 产品名称:  DPM系列尘挨浓度监视报警器
    产品型号:  DPM
    实时监测尘埃浓度,可调整报警设定点
    Inputs: From PMS Sensor.
    Output Ratings: Alarm Relays: 2 Form A (SPST) rated 5A @ 240V res. (must provide an 8A (maximum) fuse in series with relay load); Analog: 4 to 20 mA (Option RC).
    Power Requirements: 115 VAC 50/60Hz, 230 VAC 50/60Hz, or 24 VDC.
    Power Consumption: 6 Watts Max.
    Accuracy: Standard: ±5% of range; Optional: ±1% of range.
    Display: LCD.
    Display Resolution: Standard: 5 pA; Optional: 0.5 pA.
    Memory Backup: For set point storage only.
    Temperature Limits: -13 to 160°F (-25 to 70°C).
    Weight: 4.5 lbs (2.0 kg).
    Enclosure: Cast Aluminum, Weatherproof, NEMA 4X.
    Loop Power Supply (Isolated): 17 VDC loop supply provided by DPM control unit for PMS Sensor.
    Agency Approvals: Standard, Ordinary/General Purpose Locations (CE and CSA) or Optional, Class I, II, III, Div. I & II, All Groups (Intrinsically Safe- CSA).
    选型表
    Model No.
    Enclosure Rating
    Range
    Input Power
    DPM-A111
    Weatherproof/NEMA 4X
    5.0 pA-5000 pA
    115 VAC, 50/60 Hz
    DPM-A112
    5.0 pA-5000 pA
    230 VAC, 50/16 Hz
    DPM-A113
    5.0 pA-5000 pA
    24 VDC
    DPM-A121
    0.5 pA-5000 pA
    115 VAC, 50/60 Hz
    DPM-A122
    0.5 pA-5000 pA
    230 VAC, 50/16 Hz
    DPM-A123
    0.5 pA-5000 pA
    24 VDC
    DPM-AHZ111
    Intrinsically Safe
    5.0 pA-5000 pA
    115 VAC, 50/60 Hz
    DPM-AHZ112
    Intrinsically Safe
    5.0 pA-5000 pA
    230 VAC, 50/16 Hz
    DPM-AHZ113
    Intrinsically Safe
    5.0 pA-5000 pA
    24 VDC
    DPM-AHZ121
    Intrinsically Safe
    0.5 pA-5000 pA
    115 VAC, 50/60 Hz
    DPM-AHZ122
    Intrinsically Safe
    0.5 pA-5000 pA
    230 VAC, 50/16 Hz
    DPM-AHZ123
    Intrinsically Safe
    0.5 pA-5000 pA
    24 VDC
深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动控制经验 ,技术力量雄厚。公司代理品牌有 美国 DWYER、ANDERSON、MERC…  更多>>
深圳市德威达科技有限公司
联系人:李小姐
地址:深圳市福田区福田大厦1109
邮编:518033
电话:0755-83692637
传真:-
公司网址:http://www.szdwd.com
